[U-Boot-Users] [PATCH] net: add 'ethtoggle' environment variable
This patch replaces the buildtime configuration option CONFIG_NET_DO_NOT_TRY_ANOTHER through the 'ethtoggle' runtime configuration veriable. See README.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- README | 4 ++++ net/net.c | 13 ++++++++++--- 2 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/README b/README index 9a8b3b9..9eac840 100644 --- a/README +++ b/README @@ -2687,6 +2687,10 @@ Some configuration options can be set using Environment Variables: => setenv ethact SCC ETHERNET => ping 10.0.0.1 # traffic sent on SCC ETHERNET
+ ethtoggle - When set to "no" U-Boot does not go through all + available network interfaces. + It just stays at the default interface. + netretry - When set to "no" each network operation will either succeed or fail without retrying. When set to "once" the network operation will diff --git a/net/net.c b/net/net.c index 44feee2..48ccd96 100644 --- a/net/net.c +++ b/net/net.c @@ -581,6 +581,7 @@ void NetStartAgain (void) { char *nretry; int noretry = 0, once = 0; + char *ethtoggle;
if ((nretry = getenv ("netretry")) != NULL) { noretry = (strcmp (nretry, "no") == 0); @@ -596,9 +597,15 @@ void NetStartAgain (void) NetSetHandler (startAgainHandler); #else /* !CONFIG_NET_MULTI*/ eth_halt (); -#if !defined(CONFIG_NET_DO_NOT_TRY_ANOTHER) - eth_try_another (!NetRestarted); -#endif + + /* + * Do not toggle between network interfaces when + * 'ethtoggle' variable is set to 'no'. + */ + if (((ethtoggle = getenv ("ethtoggle")) == NULL) || + (strcmp(ethtoggle, "no") != 0)) + eth_try_another (!NetRestarted); + eth_init (gd->bd); if (NetRestartWrap) { NetRestartWrap = 0;
Good idea, but surely you can come up with a better word than 'ethtoggle'... It sounds like something Elmo would show to Big Bird and doesn't have anything to do with automatically advancing devices. Of course, I don't have any useful suggestions, but will think about it.
cheers, Ben
Hi Ben,
'ethtoggle' is the result of a discussion on irc some hours ago. Arguments have been: no 'eth' prefix and underscore (because 'ethprime' and 'ethact'). It was clear that the name of the variable would be most difficult site of its implementation.
If you suggest a better name, I am willing to rename it:-)
Matthias
cheers, Ben
We discussed this on IRC this afternoon. The name was agreed between Matthias Fuchs, Stefan Roese, Jean-Christophe Plagniol-Villard, and me...
Fair enough. Lacking any creativity today, I'll shake my head and pull it in...
regards, Ben
toggle to me implies a binary sense, e.g. toggling a switch on/off, whereas this code doesn't turn eth on/off, it enables/disables the round-robin polling of eth devices. 'ethpoll' isn't quite precise enough either; what about 'ethcycle' ?
Kim
Kim
Getting better...
Getting better...
Well, the function that get's called is "eth_try_another()", so maybe "ethtryanother" ;-)
What about 'ethrotate' or 'ethshift' ?
Matthias
Kim
Getting better...
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Dear Ben,
in message 200801091756.48890.matthias.fuchs@esd-electronics.com Matthias Fuchs wrote:
Ack-by: Wolfgang Denk wd@denx.de
But please edit the doc:
- ethtoggle - When set to "no" U-Boot does not go through all
... It just stays at the currently selected interface.
This patch replaces the buildtime configuration option CONFIG_NET_DO_NOT_TRY_ANOTHER through the 'ethrotate' runtime configuration variable. See README.
diff --git a/README b/README index 9a8b3b9..9ca512d 100644 --- a/README +++ b/README @@ -2687,6 +2687,10 @@ Some configuration options can be set using Environment Variables: => setenv ethact SCC ETHERNET => ping 10.0.0.1 # traffic sent on SCC ETHERNET
+ ethrotate - When set to "no" U-Boot does not go through all + available network interfaces. + It just stays at the currently selected interface. + netretry - When set to "no" each network operation will either succeed or fail without retrying. When set to "once" the network operation will diff --git a/net/net.c b/net/net.c index 44feee2..e1b71a9 100644 --- a/net/net.c +++ b/net/net.c @@ -581,6 +581,7 @@ void NetStartAgain (void) { char *nretry; int noretry = 0, once = 0; + char *ethrotate;
if ((nretry = getenv ("netretry")) != NULL) { noretry = (strcmp (nretry, "no") == 0); @@ -596,9 +597,15 @@ void NetStartAgain (void) NetSetHandler (startAgainHandler); #else /* !CONFIG_NET_MULTI*/ eth_halt (); -#if !defined(CONFIG_NET_DO_NOT_TRY_ANOTHER) - eth_try_another (!NetRestarted); -#endif + + /* + * Do not rotate between network interfaces when + * 'ethrotate' variable is set to 'no'. + */ + if (((ethrotate = getenv ("ethrotate")) == NULL) || + (strcmp(ethrotate, "no") != 0)) + eth_try_another (!NetRestarted); + eth_init (gd->bd); if (NetRestartWrap) { NetRestartWrap = 0;
- ethrotate - When set to "no" U-Boot does not go through all
- netretry - When set to "no" each network operation will either succeed or fail without retrying. When set to "once" the network operation will
char *ethrotate;
-#endif
- if (((ethrotate = getenv ("ethrotate")) == NULL) ||
- eth_init (gd->bd); if (NetRestartWrap) { NetRestartWrap = 0;
Thanks - applied.
regards, Ben
Hi Matthias,
char *ethrotate;
-#endif
I'm a little curious about what it is you're trying to do. If you want to prevent Ethernet devices from ever rotating, this doesn't work. For example, if you set 'ethact' to an interface that isn't connected, eth_init() will rotate the interfaces until it reaches a valid link or the end of the chain, never reaching your change. If you really want to prevent rotation, I'd move your logic into the 'eth_try_another()' function itself, returning quickly if "ethrotate=no".
regards, Ben
Hi Ben,
regards, Ben
I will post a fixing patch in a minute.
Matthias
Ben Warren
Kim Phillips
Matthias Fuchs
