[U-Boot] Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
thanks! Jagan.
The following changes since commit 24796d27be0d0f403ed6ad7e3022b33e36ac08b5:
Merge git://git.denx.de/u-boot-ubi (2017-06-06 07:13:39 -0400)
git://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to 2b1a33213e810f43f9d7e33b9d8db99e1b80a1c0:
sun50i: h5: Add initial NanoPi NEO2 support (2017-06-14 20:25:56 +0530)
---------------------------------------------------------------- Chen-Yu Tsai (1): sunxi: psci: Move entry address setting to separate function
Icenowy Zheng (12): sunxi: makes an invisible option for H3-like DRAM controllers sunxi: Rename bus-width related macros in H3 DRAM code sunxi: add option for 16-bit DW DRAM controller sunxi: add bank detection code to H3 DRAM initialization code sunxi: Add selective DRAM type and timing sunxi: enable dual rank detection in DesignWare-like DRAM code sunxi: add support for the DDR2 in V3s SoC sunxi: add support for V3s DRAM controller sunxi: enable DRAM initialization and SPL for V3s SoC sunxi: add LPDDR3 DRAM type support for DesignWare-like DRAM controller sunxi: add LPDDR3 timing from stock boot0 sunxi: add a defconfig for SoPine w/ official baseboard
Jagan Teki (4): sun8i: h3: Add initial NanoPi M1 Plus support sun50i: h5: Add initial Orangepi Zero Plus 2 support sun50i: a64: Add initial Orangepi Win/WinPlus support sun50i: h5: Add initial NanoPi NEO2 support
arch/arm/cpu/armv7/sunxi/psci.c | 25 ++- arch/arm/dts/Makefile | 6 +- arch/arm/dts/sun50i-a64-orangepi-win.dts | 94 +++++++++++ arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 86 ++++++++++ arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 97 +++++++++++ arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts | 64 +++++++ arch/arm/include/asm/arch-sunxi/dram.h | 6 +- .../{dram_sun8i_h3.h => dram_sunxi_dw.h} | 36 +++- arch/arm/mach-sunxi/Kconfig | 75 ++++++++- arch/arm/mach-sunxi/Makefile | 5 +- .../{dram_sun8i_h3.c => dram_sunxi_dw.c} | 187 +++++++-------------- arch/arm/mach-sunxi/dram_timings/Makefile | 3 + arch/arm/mach-sunxi/dram_timings/ddr2_v3s.c | 84 +++++++++ arch/arm/mach-sunxi/dram_timings/ddr3_1333.c | 87 ++++++++++ arch/arm/mach-sunxi/dram_timings/lpddr3_stock.c | 83 +++++++++ board/sunxi/MAINTAINERS | 25 +++ configs/nanopi_m1_plus_defconfig | 18 ++ configs/nanopi_neo2_defconfig | 16 ++ configs/orangepi_win_defconfig | 16 ++ configs/orangepi_zero_plus2_defconfig | 18 ++ configs/sopine_baseboard_defconfig | 22 +++ 21 files changed, 910 insertions(+), 143 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-orangepi-win.dts create mode 100644 arch/arm/dts/sun50i-h5-nanopi-neo2.dts create mode 100644 arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts create mode 100644 arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts rename arch/arm/include/asm/arch-sunxi/{dram_sun8i_h3.h => dram_sunxi_dw.h} (86%) rename arch/arm/mach-sunxi/{dram_sun8i_h3.c => dram_sunxi_dw.c} (84%) create mode 100644 arch/arm/mach-sunxi/dram_timings/Makefile create mode 100644 arch/arm/mach-sunxi/dram_timings/ddr2_v3s.c create mode 100644 arch/arm/mach-sunxi/dram_timings/ddr3_1333.c create mode 100644 arch/arm/mach-sunxi/dram_timings/lpddr3_stock.c create mode 100644 configs/nanopi_m1_plus_defconfig create mode 100644 configs/nanopi_neo2_defconfig create mode 100644 configs/orangepi_win_defconfig create mode 100644 configs/orangepi_zero_plus2_defconfig create mode 100644 configs/sopine_baseboard_defconfig
On Fri, 16 Jun 2017 21:54:47 +0530 Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Tom,
thanks! Jagan.
Isn't this rather invasive change (a) still under review and (b) scheduled for the next merge window either way?
Tom, please don't merge this pull request until we clarify its status.
arch/arm/cpu/armv7/sunxi/psci.c | 25 ++- arch/arm/dts/Makefile | 6 +- arch/arm/dts/sun50i-a64-orangepi-win.dts | 94 +++++++++++ arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 86 ++++++++++ arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 97 +++++++++++ arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts | 64 +++++++ arch/arm/include/asm/arch-sunxi/dram.h | 6 +- .../{dram_sun8i_h3.h => dram_sunxi_dw.h} | 36 +++- arch/arm/mach-sunxi/Kconfig | 75 ++++++++- arch/arm/mach-sunxi/Makefile | 5 +- .../{dram_sun8i_h3.c => dram_sunxi_dw.c} | 187 +++++++-------------- arch/arm/mach-sunxi/dram_timings/Makefile | 3 + arch/arm/mach-sunxi/dram_timings/ddr2_v3s.c | 84 +++++++++ arch/arm/mach-sunxi/dram_timings/ddr3_1333.c | 87 ++++++++++ arch/arm/mach-sunxi/dram_timings/lpddr3_stock.c | 83 +++++++++ board/sunxi/MAINTAINERS | 25 +++ configs/nanopi_m1_plus_defconfig | 18 ++ configs/nanopi_neo2_defconfig | 16 ++ configs/orangepi_win_defconfig | 16 ++ configs/orangepi_zero_plus2_defconfig | 18 ++ configs/sopine_baseboard_defconfig | 22 +++ 21 files changed, 910 insertions(+), 143 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-orangepi-win.dts create mode 100644 arch/arm/dts/sun50i-h5-nanopi-neo2.dts create mode 100644 arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts create mode 100644 arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts rename arch/arm/include/asm/arch-sunxi/{dram_sun8i_h3.h => dram_sunxi_dw.h} (86%) rename arch/arm/mach-sunxi/{dram_sun8i_h3.c => dram_sunxi_dw.c} (84%) create mode 100644 arch/arm/mach-sunxi/dram_timings/Makefile create mode 100644 arch/arm/mach-sunxi/dram_timings/ddr2_v3s.c create mode 100644 arch/arm/mach-sunxi/dram_timings/ddr3_1333.c create mode 100644 arch/arm/mach-sunxi/dram_timings/lpddr3_stock.c create mode 100644 configs/nanopi_m1_plus_defconfig create mode 100644 configs/nanopi_neo2_defconfig create mode 100644 configs/orangepi_win_defconfig create mode 100644 configs/orangepi_zero_plus2_defconfig create mode 100644 configs/sopine_baseboard_defconfig _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
On Fri, Jun 16, 2017 at 10:43 PM, Siarhei Siamashka siarhei.siamashka@gmail.com wrote:
Hi Tom,
thanks! Jagan.
NO, Initial patches were send during MW we waited there too and applied on -sunxi/master weeks ago. Better please send any patches if you find any issues.
thanks!
On Fri, Jun 16, 2017 at 9:54 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Tom,
thanks! Jagan.
Ping!
thanks!
On Fri, Jun 16, 2017 at 09:54:47PM +0530, Jagan Teki wrote:
Hi Tom,
thanks! Jagan.
Jagan Teki
Siarhei Siamashka
