[U-Boot] [PATCH] sysreset: syscon: update regmap access to syscon
Use new API syscon_node_to_regmap in sysreset_syscon driver for compatible "syscon-reboot"; that's avoid the need of explicit syscon binding for "regmap" handle.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/sysreset/sysreset_syscon.c | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/drivers/sysreset/sysreset_syscon.c b/drivers/sysreset/sysreset_syscon.c index f19e80e..3450640 100644 --- a/drivers/sysreset/sysreset_syscon.c +++ b/drivers/sysreset/sysreset_syscon.c @@ -35,18 +35,20 @@ static struct sysreset_ops syscon_reboot_ops = {
int syscon_reboot_probe(struct udevice *dev) { - struct udevice *syscon; struct syscon_reboot_priv *priv = dev_get_priv(dev); int err; + u32 phandle; + ofnode node;
- err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, - "regmap", &syscon); - if (err) { - pr_err("unable to find syscon device\n"); + err = ofnode_read_u32(dev_ofnode(dev), "regmap", &phandle); + if (err) return err; - }
- priv->regmap = syscon_get_regmap(syscon); + node = ofnode_get_by_phandle(phandle); + if (!ofnode_valid(node)) + return -EINVAL; + + priv->regmap = syscon_node_to_regmap(node); if (!priv->regmap) { pr_err("unable to find regmap\n"); return -ENODEV;
Hi Patrick,
u32 phandle;
ofnode node;
"regmap", &syscon);
if (err) {
return -EINVAL;
Aren't you just re-implementing uclass_get_device_by_phandle() here?
Hi Simon
-----Original Message----- From: sjg@google.com sjg@google.com On Behalf Of Simon Glass Sent: mardi 10 juillet 2018 22:50
Hi Patrick,
u32 phandle;
ofnode node;
"regmap", &syscon);
if (err) {
return -EINVAL;
Not exactly, because if I use the the function uclass_get_device_by_phandle, the device need to be bounded to syscon UCLASS.
And it is not needed with my proposal as I use the new function syscon_node_to_regmap which not require explicite syscon binding.
I have the problem in stm32mp1 platform with the DT : (./arch/arm/dts/stm32mp157c.dtsi)
rcc: rcc@50000000 { compatible = "st,stm32mp1-rcc", "syscon"; #clock-cells = <1>; #reset-cells = <1>; reg = <0x50000000 0x1000>; st,pwr = <&pwr>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; };
rcc_reboot: rcc-reboot@50000000 { compatible = "syscon-reboot"; regmap = <&rcc>; offset = <0x404>; mask = <0x1>; };
1/ rcc is binded to drivers/misc/stm32_rcc.c with compatible "st,stm32mp1-rcc" =>3 roles + Clock provider => bound with stm32mp1_clk driver + Reset provide => bound with "stm32_rcc_reset" + sysreset provider with syscon.... not bound by default
2/ rcc-reboot is binded to "sysreset_syscon" driver => regmap field = handle to rcc
Without modification, the syscon-reboot driver can't have access to regmap of RCC because it is not bound to generic syscon driver.
I have 2 solutions to solve this:
1/ add a 3rd binding to syscon in RCC misc driver if (rcc_clk->soc == STM32MP1) { ret = device_bind_driver_to_node(dev, "syscon", "syscon", dev_ofnode(dev), &child); if (ret) return ret; }
2/ change sysreset to access directly to syscon regmap without explicate binding.
I choose the 2nd solution, I think it is more generic.
NB: I can change the patch to introduce a new syscon function to access to syscon form phandle if it is preferable struct regmap * syscon_handle_to_regmap(struct udevice *parent, const char *name)
or I can come back to the first solution (add the binding to syscon)
Regards Patrick
Patrick DELAUNAY
Patrick Delaunay
