[PATCH v2] board: sl28: add DSA support for variant 2
Now that u-boot gained DSA support, and it is already enabled for the kontron_sl28 board, add the last missing piece and enable the corresponding devices it in the device tree.
Signed-off-by: Michael Walle michael@walle.cc --- changes since v1: - renamed ethernet alias stem, because it was changed in commit 82a3c9ef20d43d97416589854b4bbcb4c2450c24 ("net: use the same alias stem for ethernet as linux")
Now that the mentioned commit made it finally into u-boot. We can move forward here. It would be nice if this would still make it into 2021.07, given that this is only a device tree change for a this particular board.
.../fsl-ls1028a-kontron-sl28-var2-u-boot.dtsi | 7 ++++ .../arm/dts/fsl-ls1028a-kontron-sl28-var2.dts | 40 +++++++++++++++++++ 2 files changed, 47 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2-u-boot.dtsi b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2-u-boot.dtsi index 79b771e074..4e0ce3f77d 100644 --- a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2-u-boot.dtsi +++ b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2-u-boot.dtsi @@ -1,2 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+ #include "fsl-ls1028a-kontron-sl28-u-boot.dtsi" + +/ { + aliases { + ethernet0 = &mscc_felix_port0; + ethernet1 = &mscc_felix_port1; + }; +}; diff --git a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts index 1ea1265bcf..7a3aa21408 100644 --- a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts +++ b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts @@ -22,4 +22,44 @@ /delete-property/ phy-handle; };
+&enetc2 { + status = "okay"; +}; + +&mscc_felix { + status = "okay"; +}; + +&mscc_felix_port0 { + label = "gbe0"; + phy-handle = <&phy0>; + phy-mode = "sgmii"; + status = "okay"; +}; + +&mscc_felix_port1 { + label = "gbe1"; + phy-handle = <&phy1>; + phy-mode = "sgmii"; + status = "okay"; +}; + +&mscc_felix_port4 { + ethernet = <&enetc2>; + status = "okay"; +}; + /delete-node/ &phy0; +&mdio0 { + phy0: ethernet-phy@5 { + reg = <0x5>; + eee-broken-1000t; + eee-broken-100tx; + }; + + phy1: ethernet-phy@4 { + reg = <0x4>; + eee-broken-1000t; + eee-broken-100tx; + }; +};
Am 2021-06-23 13:56, schrieb Michael Walle:
changes since v1:
Can this please go through the net queue?
By chance, I've seen this patch: https://patchwork.ozlabs.org/project/uboot/patch/20210629175317.2607470-5-vl...
Now I'm lucky that I have the following chunk, otherwise the patch wouldn't work.
In any case, I'd retest this patch today based on u-boot-net/master (together with Vladimirs new patch series which configures the autoneg at probe time).
-michael
- aliases {
+&enetc2 {
- status = "okay";
+&mscc_felix {
- status = "okay";
- label = "gbe0";
- phy-handle = <&phy0>;
- phy-mode = "sgmii";
- status = "okay";
- label = "gbe1";
- phy-handle = <&phy1>;
- status = "okay";
- ethernet = <&enetc2>;
- status = "okay";
- phy0: ethernet-phy@5 {
reg = <0x5>;
eee-broken-1000t;
eee-broken-100tx;
- phy1: ethernet-phy@4 {
reg = <0x4>;
eee-broken-1000t;
eee-broken-100tx;
+&enetc2 {
- status = "okay";
Why "lucky"? I remember you were pushing this device tree style in the first place.
I think it's best to just resend with Ramon in CC once you retest.
Am 2021-06-30 12:34, schrieb Vladimir Oltean:
+&enetc2 {
- status = "okay";
Thats correct, but in u-boot this device was still defaulting to status = "okay", thus it would have been superfluous to still enable it in the board dts. And tbh, I don't exactly know why I enabled it nonetheless. Normally I keep things small ;)
Its not about the change (which is good), but there seems to be a disconnect between which patches goes through which queue and you have to be lucky that a (newer) patch doesn't break your patch which is sitting on another queue to be picked up while the newer one is already pulled in.
+&enetc2 {
- status = "okay";
-- -michael
Applied to u-boot-net/master, Thanks ! Ramon
Michael Walle
Ramon Fried
Vladimir Oltean
