[PATCH] board: rockchip: add FriendlyElec NanoPC-T6 rk3588 board
NanoPC-T6 is a Rockchip RK3588 based SBC by FriendlyElec.
There are four variants depending on the DRAM size: 4G/32GB eMMC, 8G/64GB eMMC, 16G/16MB SPI NOR, and 16G/256GB eMMC/16MB SPI NOR
Specifications: CPU: Rockchip RK3588, 4x Cortex-A76 (up to 2.4GHz) + 4x Cortex-A55 (up to 1.8GHz) GPU: Mali-G610 MP4 VPU: 8K@60fps H.265 and VP9 decoder, 8K@30fps H.264 decoder, 4K@60fps AV1 decoder, 8K@30fps H.264 and H.265 encoder NPU: 6TOPs, supports INT4/INT8/INT16/FP16 RAM: 64-bit 4GB/8GB/16GB LPDDR4X at 2133MHz eMMC: 0GB/32GB/64GB/256GB HS400 MicroSD Slot: MicroSD SDR104 PCIe 3.0: M.2 M-Key x1, PCIe 3.0 x4 for NVMe SSDs up to 2,500 MB/s Ethernet: PCIe 2.5G 2x Ethernet (RTL8125BG) PCIe 2.1: M.2 E-Key x1, PCIe 2.1 x1 and USB2.0 Host, supports M.2 WiFi and Bluetooth 4G Module: MiniPCIe x1, MicroSIM Card Slot x1 Audio Out: 3.5mm jack for stereo headphone output Audio In: 2.0mm PH-2A connector for analog microphone input Video Input: standard HDMI input port, up to 4Kp60 2x 4-lane MIPI-CSI, compatible with MIPI V1.2 Video Output: 2x standard HDMI output ports compatible with HDMI2.1, HDMI2.0, and HDMI1.4 2x 4-lane MIPI-DSI, compatible with MIPI DPHY 2.0 or CPHY 1.1 USB-A: USB 3.0, Type A USB-C: Full function USB Type‑C port, supports DP display up to 4Kp60, USB 3.0 40-pin 2.54mm header connector: up to 2x SPIs, 6x UARTs, 1x I2Cs, 8x PWMs, 2x I2Ss, 28x GPIOs Debug UART: 3 Pin 2.54mm header, 3V level, 1500000bps Onboard IR receiver: 38KHz carrier frequency RTC Battery: 2 Pin 1.27/1.25mm RTC battery input connector for low power RTC IC HYM8563TS 5V Fan connector Working Temperature: 0C to 70C Power: 5.5*2.1mm DC Jack, 12VDC input Dimensions: 110x80x1.6mm (without case) / 86x114.5x30mm (with case)
Kernel commits: 893c17716d0c ("arm64: dts: rockchip: Add NanoPC T6") a721e28dfad2 ("arm64: dts: rockchip: Add NanoPC T6 PCIe Ethernet support") ac76b786cc37 ("arm64: dts: rockchip: Add NanoPC T6 PCIe e-key support")
Signed-off-by: John Clark inindev@gmail.com ---
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi | 36 + arch/arm/dts/rk3588-nanopc-t6.dts | 916 ++++++++++++++++++++++ arch/arm/mach-rockchip/rk3588/rk3588.c | 1 + configs/nanopc-t6-rk3588_defconfig | 113 +++ 5 files changed, 1067 insertions(+) create mode 100644 arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-nanopc-t6.dts create mode 100644 configs/nanopc-t6-rk3588_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index bde2176ec7..6a4335cf9c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -189,6 +189,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-edgeble-neu6a-io.dtb \ rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \ + rk3588-nanopc-t6.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb
diff --git a/arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi b/arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi new file mode 100644 index 0000000000..87831c9d43 --- /dev/null +++ b/arch/arm/dts/rk3588-nanopc-t6-u-boot.dtsi @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 John Clark inindev@gmail.com + * + */ + +#include "rk3588-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; + }; +}; + +&fspim1_pins { + bootph-all; +}; + +&sfc { + bootph-pre-ram; + u-boot,spl-sfc-no-dma; + pinctrl-names = "default"; + pinctrl-0 = <&fspim1_pins>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + flash@0 { + bootph-pre-ram; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <24000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; diff --git a/arch/arm/dts/rk3588-nanopc-t6.dts b/arch/arm/dts/rk3588-nanopc-t6.dts new file mode 100644 index 0000000000..965bf5263d --- /dev/null +++ b/arch/arm/dts/rk3588-nanopc-t6.dts @@ -0,0 +1,916 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2021 Rockchip Electronics Co., Ltd. + * Copyright (c) 2023 Thomas McKahan + * + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/usb/pd.h> +#include "rk3588.dtsi" + +/ { + model = "FriendlyElec NanoPC-T6"; + compatible = "friendlyarm,nanopc-t6", "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + mmc1 = &sdmmc; + serial2 = &uart2; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + sound { + compatible = "simple-audio-card"; + pinctrl-names = "default"; + pinctrl-0 = <&hp_det>; + + simple-audio-card,name = "realtek,rt5616-codec"; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + + simple-audio-card,hp-det-gpio = <&gpio1 RK_PC4 GPIO_ACTIVE_LOW>; + simple-audio-card,hp-pin-name = "Headphones"; + + simple-audio-card,widgets = + "Headphone", "Headphones", + "Microphone", "Microphone Jack"; + simple-audio-card,routing = + "Headphones", "HPOL", + "Headphones", "HPOR", + "MIC1", "Microphone Jack", + "Microphone Jack", "micbias1"; + + simple-audio-card,cpu { + sound-dai = <&i2s0_8ch>; + }; + simple-audio-card,codec { + sound-dai = <&rt5616>; + }; + }; + + leds { + compatible = "gpio-leds"; + + sys_led: led-0 { + gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; + label = "system-led"; + pinctrl-names = "default"; + pinctrl-0 = <&sys_led_pin>; + linux,default-trigger = "heartbeat"; + }; + + usr_led: led-1 { + gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>; + label = "user-led"; + pinctrl-names = "default"; + pinctrl-0 = <&usr_led_pin>; + }; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + /* vcc5v0_sys powers peripherals */ + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + /* vcc4v0_sys powers the RK806, RK860's */ + vcc4v0_sys: vcc4v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc4v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <4000000>; + regulator-max-microvolt = <4000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc_1v1_nldo_s3: vcc-1v1-nldo-s3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc-1v1-nldo-s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + vin-supply = <&vcc4v0_sys>; + }; + + vcc_3v3_pcie20: vcc3v3-pcie20-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v3_pcie20"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_3v3_s3>; + }; + + vbus5v0_typec: vbus5v0-typec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PD2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&typec5v_pwren>; + regulator-name = "vbus5v0_typec"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc3v3_pcie2x1l0: vcc3v3-pcie2x1l0-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_m2_1_pwren>; + regulator-name = "vcc3v3_pcie2x1l0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc3v3_pcie30: vcc3v3-pcie30-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio2 RK_PC5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_m2_0_pwren>; + regulator-name = "vcc3v3_pcie30"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy1_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_b0{ + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1{ + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2{ + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3{ + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&gpio0 { + gpio-line-names = /* GPIO0 A0-A7 */ + "", "", "", "", + "", "", "", "", + /* GPIO0 B0-B7 */ + "", "", "", "", + "", "", "", "", + /* GPIO0 C0-C7 */ + "", "", "", "", + "HEADER_10", "HEADER_08", "HEADER_32", "", + /* GPIO0 D0-D7 */ + "", "", "", "", + "", "", "", ""; +}; + +&gpio1 { + gpio-line-names = /* GPIO1 A0-A7 */ + "HEADER_27", "HEADER_28", "", "", + "", "", "", "HEADER_15", + /* GPIO1 B0-B7 */ + "HEADER_26", "HEADER_21", "HEADER_19", "HEADER_23", + "HEADER_24", "HEADER_22", "", "", + /* GPIO1 C0-C7 */ + "", "", "", "", + "", "", "", "", + /* GPIO1 D0-D7 */ + "", "", "", "", + "", "", "HEADER_05", "HEADER_03"; +}; + +&gpio2 { + gpio-line-names = /* GPIO2 A0-A7 */ + "", "", "", "", + "", "", "", "", + /* GPIO2 B0-B7 */ + "", "", "", "", + "", "", "", "", + /* GPIO2 C0-C7 */ + "", "CSI1_11", "CSI1_12", "", + "", "", "", "", + /* GPIO2 D0-D7 */ + "", "", "", "", + "", "", "", ""; +}; + +&gpio3 { + gpio-line-names = /* GPIO3 A0-A7 */ + "HEADER_35", "HEADER_38", "HEADER_40", "HEADER_36", + "HEADER_37", "", "DSI0_12", "", + /* GPIO3 B0-B7 */ + "HEADER_33", "DSI0_10", "HEADER_07", "HEADER_16", + "HEADER_18", "HEADER_29", "HEADER_31", "HEADER_12", + /* GPIO3 C0-C7 */ + "DSI0_08", "DSI0_14", "HEADER_11", "HEADER_13", + "", "", "", "", + /* GPIO3 D0-D7 */ + "", "", "", "", + "", "DSI1_10", "", ""; +}; + +&gpio4 { + gpio-line-names = /* GPIO4 A0-A7 */ + "DSI1_08", "DSI1_14", "", "DSI1_12", + "", "", "", "", + /* GPIO4 B0-B7 */ + "", "", "", "", + "", "", "", "", + /* GPIO4 C0-C7 */ + "", "", "", "", + "CSI0_11", "CSI0_12", "", "", + /* GPIO4 D0-D7 */ + "", "", "", "", + "", "", "", ""; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc4v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc4v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c2 { + status = "okay"; + + vdd_npu_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + rockchip,suspend-voltage-selector = <1>; + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc4v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c6 { + clock-frequency = <200000>; + status = "okay"; + + fusb302: typec-portc@22 { + compatible = "fcs,fusb302"; + reg = <0x22>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>; + pinctrl-0 = <&usbc0_int>; + pinctrl-names = "default"; + vbus-supply = <&vbus5v0_typec>; + + connector { + compatible = "usb-c-connector"; + data-role = "dual"; + label = "USB-C"; + power-role = "dual"; + try-power-role = "sink"; + source-pdos = <PDO_FIXED(5000, 2000, PDO_FIXED_USB_COMM)>; + sink-pdos = <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>; + op-sink-microwatt = <1000000>; + }; + }; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +&i2c7 { + clock-frequency = <200000>; + status = "okay"; + + rt5616: codec@1b { + compatible = "realtek,rt5616"; + reg = <0x1b>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + #sound-dai-cells = <0>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + + port { + rt5616_p0_0: endpoint { + remote-endpoint = <&i2s0_8ch_p0_0>; + }; + }; + }; + + /* connected with MIPI-CSI1 */ +}; + +&i2c8 { + pinctrl-0 = <&i2c8m2_xfer>; +}; + +&i2s0_8ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; + + i2s0_8ch_p0: port { + i2s0_8ch_p0_0: endpoint { + dai-format = "i2s"; + mclk-fs = <256>; + remote-endpoint = <&rt5616_p0_0>; + }; + }; +}; + +&pcie2x1l0 { + reset-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc_3v3_pcie20>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie2_0_rst>; + status = "okay"; +}; + +&pcie2x1l1 { + reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie2x1l0>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie2_1_rst>; + status = "okay"; +}; + +&pcie2x1l2 { + reset-gpios = <&gpio4 RK_PA4 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc_3v3_pcie20>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie2_2_rst>; + status = "okay"; +}; + +&pcie30phy { + status = "okay"; +}; + +&pcie3x4 { + reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie30>; + status = "okay"; +}; + +&pinctrl { + gpio-leds { + sys_led_pin: sys-led-pin { + rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usr_led_pin: usr-led-pin { + rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + headphone { + hp_det: hp-det { + rockchip,pins = <1 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pcie { + pcie2_0_rst: pcie2-0-rst { + rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie2_1_rst: pcie2-1-rst { + rockchip,pins = <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie2_2_rst: pcie2-2-rst { + rockchip,pins = <4 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie_m2_0_pwren: pcie-m20-pwren { + rockchip,pins = <2 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie_m2_1_pwren: pcie-m21-pwren { + rockchip,pins = <4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + typec5v_pwren: typec5v-pwren { + rockchip,pins = <1 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usbc0_int: usbc0-int { + rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm1 { + pinctrl-0 = <&pwm1m1_pins>; + status = "okay"; +}; + +&saradc { + vref-supply = <&avcc_1v8_s0>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + no-sdio; + no-sd; + non-removable; + max-frequency = <200000000>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + status = "okay"; +}; + +&sdmmc { + max-frequency = <200000000>; + no-sdio; + no-mmc; + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3_s3>; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&spi2 { + status = "okay"; + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + num-cs = <1>; + + pmic@0 { + compatible = "rockchip,rk806"; + spi-max-frequency = <1000000>; + reg = <0x0>; + + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + + vcc1-supply = <&vcc4v0_sys>; + vcc2-supply = <&vcc4v0_sys>; + vcc3-supply = <&vcc4v0_sys>; + vcc4-supply = <&vcc4v0_sys>; + vcc5-supply = <&vcc4v0_sys>; + vcc6-supply = <&vcc4v0_sys>; + vcc7-supply = <&vcc4v0_sys>; + vcc8-supply = <&vcc4v0_sys>; + vcc9-supply = <&vcc4v0_sys>; + vcc10-supply = <&vcc4v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc4v0_sys>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_1v1_nldo_s3>; + vcca-supply = <&vcc4v0_sys>; + + gpio-controller; + #gpio-cells = <2>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: vdd_gpu_mem_s0: dcdc-reg1 { + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_gpu_s0"; + regulator-enable-ramp-delay = <400>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: vdd_cpu_lit_mem_s0: dcdc-reg2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_cpu_lit_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_log_s0: dcdc-reg3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_log_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: vdd_vdenc_mem_s0: dcdc-reg4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-init-microvolt = <750000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_vdenc_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_ddr_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdd2_ddr_s3: dcdc-reg6 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vdd2_ddr_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_2v0_pldo_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_3v3_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vddq_ddr_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: dcdc-reg10 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avcc_1v8_s0: pldo-reg1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "avcc_1v8_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s0: pldo-reg2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avdd_1v2_s0: pldo-reg3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "avdd_1v2_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3_s0: pldo-reg4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + regulator-name = "vcc_3v3_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + regulator-name = "vccio_sd_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "pldo6_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-name = "vdd_0v75_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_ddr_pll_s0: nldo-reg2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-name = "vdd_ddr_pll_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + avdd_0v75_s0: nldo-reg3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-name = "avdd_0v75_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v85_s0: nldo-reg4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-name = "vdd_0v85_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-name = "vdd_0v75_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; + +&u2phy2_host { + status = "okay"; +}; + +&u2phy3_host { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3588/rk3588.c b/arch/arm/mach-rockchip/rk3588/rk3588.c index b1f535fad5..e08ebfa39b 100644 --- a/arch/arm/mach-rockchip/rk3588/rk3588.c +++ b/arch/arm/mach-rockchip/rk3588/rk3588.c @@ -40,6 +40,7 @@ DECLARE_GLOBAL_DATA_PTR; const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/mmc@fe2e0000", [BROM_BOOTSOURCE_SPINOR] = "/spi@fe2b0000/flash@0", + [BROM_BOOTSOURCE_SPINAND] = "/spi@fe2b0000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@fe2c0000", [BROM_BOOTSOURCE_SPINOR_RK3588] = "/spi@fe2b0000/flash@0", }; diff --git a/configs/nanopc-t6-rk3588_defconfig b/configs/nanopc-t6-rk3588_defconfig new file mode 100644 index 0000000000..a1d20b0770 --- /dev/null +++ b/configs/nanopc-t6-rk3588_defconfig @@ -0,0 +1,113 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-nanopc-t6" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_SPI_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3588=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-nanopc-t6.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_PCI_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_PHYLIB=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +# CONFIG_USB_XHCI_DWC3_OF_SIMPLE is not set +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_SPL_USB_DWC3_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_ERRNO_STR=y
Hi John,
Quick feedback below, will look at schematics and runtime test later.
This is missing addition of the board to the list in board documentation and an entry in the evb_rk3588 MAINTAINERS file.
- Copyright (c) 2021 Rockchip Electronics Co., Ltd.
- Copyright (c) 2023 Thomas McKahan
+/dts-v1/;
- model = "FriendlyElec NanoPC-T6";
- compatible = "friendlyarm,nanopc-t6", "rockchip,rk3588";
- aliases {
mmc0 = &sdhci;
mmc1 = &sdmmc;
serial2 = &uart2;
- chosen {
- sound {
- leds {
sys_led: led-0 {
usr_led: led-1 {
label = "user-led";
sound and leds node is out of order compared to mmind/for-next tree. Rest of the device tree seem to be a 1:1 copy.
https://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip.git/tre...
- [BROM_BOOTSOURCE_SPINAND] = "/spi@fe2b0000/flash@0",
Hum, maybe we need to look at using the atags to determine boot device. We now have 3 different bootsource values representing same dt node.
This should not be needed and may slow down boot from e.g. eMMC when there is no PCIe devices attached. Standard boot should init pci after it has tested faster boot targets.
We use 0x60000 for other rk35xx boards, odroid-m1 use 0x100000 because board vendor have existing partitions defined in the device tree.
This could be dropped, there is no use of pwm-regulator in the DT.
You can drop this line, only the pre-mainline usb3 nodes in -u-boot.dtsi use a rk3399 compatible that would load this driver. I will also send two series that make this driver obsolete on rockchip platform.
- First series will sync compatible of usb3 nodes with collabora rk3588 tree, removing the use of the rk3399 compatible. - Second series will switch rk3399 boards to use dwc3-generic and drop the use of dwc3-of-simple driver.
This is not really needed, usb nodes are not included in the spl dtb.
Regards, Jonas
So the board is using SPI NOR flash.
Why need a SPI NAND?
If this is really needed, will be a separate patch to support a new boot source from bootrom.
Thanks, - Kever
In commit fd6e425, Jonas finds the rock-5b device has a value of 6 at CFG_IRAM_BASE + 0x10 (0xff000010) when booted from spi and creates the BROM_BOOTSOURCE_SPINOR_RK3588 enum value. https://github.com/u-boot/u-boot/commit/fd6e425be243dce518a02710482514faccf3...
When I boot the nanopv-t6 from spi, I am seeing a value of 4 at 0xff000010.
We both should be expecting a value of 3:
BROM_BOOTSOURCE_SPINOR = 3, => 0x0000 0011 pre-RK3588 variants BROM_BOOTSOURCE_SPINAND = 4, => 0x0000 0100 NanoPC-T6 BROM_BOOTSOURCE_SPINOR_RK3588 = 6, => 0x0000 0110 Rock-5b
Since this is the only use of CFG_IRAM_BASE, I have to wonder if 0xff000000 is correct for the RK3588?
I have included the relevant code below for convenience:
/** * Boot-device identifiers as used by the BROM */ enum { BROM_BOOTSOURCE_NAND = 1, BROM_BOOTSOURCE_EMMC = 2, BROM_BOOTSOURCE_SPINOR = 3, BROM_BOOTSOURCE_SPINAND = 4, BROM_BOOTSOURCE_SD = 5, BROM_BOOTSOURCE_SPINOR_RK3588 = 6, BROM_BOOTSOURCE_USB = 10, BROM_LAST_BOOTSOURCE = BROM_BOOTSOURCE_USB };
extern const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1];
/** * Locations of the boot-device identifier in SRAM */ #define BROM_BOOTSOURCE_ID_ADDR (CFG_IRAM_BASE + 0x10)
https://github.com/u-boot/u-boot/blob/master/arch/arm/include/asm/arch-rockc...
./include/configs/rk3128_common.h:#define CFG_IRAM_BASE 0x10080000 ./include/configs/px30_common.h:#define CFG_IRAM_BASE 0xff0e0000 ./include/configs/rk3188_common.h:#define CFG_IRAM_BASE 0x10080000 ./include/configs/rk3568_common.h:#define CFG_IRAM_BASE 0xfdcc0000 ./include/configs/rk3399_common.h:#define CFG_IRAM_BASE 0xff8c0000 ./include/configs/rk3066_common.h:#define CFG_IRAM_BASE 0x10080000 ./include/configs/rk3308_common.h:#define CFG_IRAM_BASE 0xfff80000 ./include/configs/rk3368_common.h:#define CFG_IRAM_BASE 0xff8c0000 ./include/configs/rk3288_common.h:#define CFG_IRAM_BASE 0xff700000 ./include/configs/rk3328_common.h:#define CFG_IRAM_BASE 0xff090000 ./include/configs/rv1108_common.h:#define CFG_IRAM_BASE 0x10080000 ./include/configs/rk3588_common.h:#define CFG_IRAM_BASE 0xff000000 ./include/configs/rk322x_common.h:#define CFG_IRAM_BASE 0x10080000 ./include/configs/rv1126_common.h:#define CFG_IRAM_BASE 0xff700000
8G/64GB eMMC,
Thanks,
- Kever
Hi Kever,
I have done spi boot testing on a few rk3588 boards with SPI NOR flash, and there seem to be a correlation between the bootsource/bootdevice id written to reg by the bootrom and the fspi iomux used by the board.
Following bootsource/bootdevice value can be read from reg,
- FSPI (M0): 3 - FSPI (M1): 4 - FSPI (M2): 6
based on testing on the following boards:
- Radxa ROCK 5 Model A - fspim0_pins - rk3588s - Xunlong Orange Pi 5 - fspim0_pins - rk3588s brom_bootdevice_id: 3
- FriendlyElec NanoPC-T6 - fspim1_pins - rk3588 - Xunlong Orange Pi 5 Plus - fspim1_pins - rk3588 brom_bootdevice_id: 4
- Radxa ROCK 5 Model B - fspim2_pins - rk3588 brom_bootdevice_id: 6
Can these observations be correct? And if so, maybe we should use following constants for RK3588?
BROM_BOOTSOURCE_FSPI_M0 = 3 BROM_BOOTSOURCE_FSPI_M1 = 4 BROM_BOOTSOURCE_FSPI_M2 = 6
Any insights into what values bootrom will write to reg would be very helpful.
Regards, Jonas
Thanks,
- Kever
Add Slawomir Stepien;
Hi Jonas, John, Slawomir:
On 2023/10/18 04:47, Jonas Karlman wrote:
Hi Kever,
- FSPI (M0): 3
- FSPI (M1): 4
- FSPI (M2): 6
Very good finding, I have check internally with bootrom owner, the definition is exactly same as
these three option for SPI M0 to M2.
After add FSPI M0-M2, the spi NAND/NOR source has complete support, there is no separate definition
for SPI NAND and SPI NOR for now until RK3588, all three ports can support both SPI NAND and spi NOR.
Thanks,
- Kever
Regards, Jonas
Thanks,
- Kever
John Clark
Jonas Karlman
Kever Yang
