[U-Boot] [PATCH] Makefile: fix implementation of BINMAN_DEBUG
binman only accepts the -D argument early on the command-line, yet the Makefile currently passes it near the end. This causes the build to fail if this feature is used. Re-order the command-line to fix this.
Signed-off-by: Stephen Warren swarren@nvidia.com --- Note: This appears to be a change introduced in u-boot-dm.git master; the binman currently in u-boot.git master doesn't seem to need this. --- Makefile | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index 704579bec193..5906871ef27f 100644 --- a/Makefile +++ b/Makefile @@ -1196,9 +1196,10 @@ u-boot.ldr: u-boot # --------------------------------------------------------------------------- # Use 'make BINMAN_DEBUG=1' to enable debugging quiet_cmd_binman = BINMAN $@ -cmd_binman = $(srctree)/tools/binman/binman build -u -d u-boot.dtb -O . -m \ +cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ + build -u -d u-boot.dtb -O . -m \ -I . -I $(srctree) -I $(srctree)/board/$(BOARDDIR) \ - $(if $(BINMAN_DEBUG),-D) $(BINMAN_$(@F)) + $(BINMAN_$(@F))
OBJCOPYFLAGS_u-boot.ldr.hex := -I binary -O ihex
Thanks
Thanks
Applied to u-boot-dm, thanks!
sjg@google.com
Stephen Warren
