[PATCH] ARM: mach-at91: Add compile time option to choose proper timer
New SoC's of AT91 family with ARM-9 core includes a regular timer and a 64-bit timer.This patch adds a compile time option to the Makefile such that the old timer driver is chosen and compiled as default if none of timer configuration options are explicitly defined in the board configs.
Signed-off-by: Hari Prasath Hari.PrasathGE@microchip.com --- arch/arm/mach-at91/arm926ejs/Makefile | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-at91/arm926ejs/Makefile b/arch/arm/mach-at91/arm926ejs/Makefile index 8de6a2f966..c1904d535b 100644 --- a/arch/arm/mach-at91/arm926ejs/Makefile +++ b/arch/arm/mach-at91/arm926ejs/Makefile @@ -20,8 +20,11 @@ obj-$(CONFIG_AT91_LED) += led.o obj-y += clock.o obj-y += cpu.o obj-y += reset.o -ifeq ($(CONFIG_ATMEL_PIT_TIMER),) -obj-y += timer.o +ifneq ($(CONFIG_ATMEL_PIT_TIMER),y) +ifneq ($(CONFIG_MCHP_PIT64B_TIMER),y) +# old non-DM timer driver +obj-y += timer.o +endif endif
ifndef CONFIG_SKIP_LOWLEVEL_INIT
Reviewed-by: Eugen Hristev eugen.hristev@microchip.com
Applied to u-boot-at91/next , thanks !
Eugen.Hristev@microchip.com
Hari Prasath
