[PATCH 1/2] fsl-layerscape: add dtb overlay feature
This patch enables the DTB overlay feature for LS platforms.
Signed-off-by: Sahil Malhotra sahil.malhotra@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/dt_optee.c | 39 +++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/dt_optee.h | 10 +++++ arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 12 ++++++ .../cpu/armv8/fsl-layerscape/lowlevel_init.S | 25 ++++++++++++ 5 files changed, 87 insertions(+) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/dt_optee.c create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/dt_optee.h create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/lowlevel_init.S
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 598c36ee66..97f1f291dd 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -7,6 +7,7 @@ obj-y += lowlevel.o obj-y += soc.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_MP) += mp.o spintable.o +obj-$(CONFIG_OF_LIBFDT_OVERLAY) += lowlevel_init.o dt_optee.o obj-$(CONFIG_OF_LIBFDT) += fdt.o endif obj-$(CONFIG_SPL) += spl.o diff --git a/arch/arm/cpu/armv8/fsl-layerscape/dt_optee.c b/arch/arm/cpu/armv8/fsl-layerscape/dt_optee.c new file mode 100644 index 0000000000..2418ad09c7 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/dt_optee.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 NXP + */ +#include <common.h> +#include <errno.h> +#include <fdt_support.h> +#include <linux/sizes.h> +#include "dt_optee.h" + +int ft_add_optee_overlay(void *fdt, struct bd_info *bd) +{ + int ret = 0; + + /* + * No BL32_BASE passed means no TEE running, so no + * need to add optee node in dts + */ + if (!rom_pointer[0]) { + debug("No BL32_BASE passed means no TEE running\n"); + return ret; + } + + if (rom_pointer[2]) { + debug("OP-TEE: applying overlay on 0x%lx\n", rom_pointer[2]); + ret = fdt_check_header((void *)rom_pointer[2]); + if (ret == 0) { + /* Copy the fdt overlay to next 1M and use copied overlay */ + memcpy((void *)(rom_pointer[2] + SZ_1M), (void *)rom_pointer[2], + fdt_totalsize((void *)rom_pointer[2])); + ret = fdt_overlay_apply_verbose(fdt, (void *)(rom_pointer[2] + SZ_1M)); + if (ret == 0) { + debug("Overlay applied with success"); + fdt_pack(fdt); + } + } + } + return ret; +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/dt_optee.h b/arch/arm/cpu/armv8/fsl-layerscape/dt_optee.h new file mode 100644 index 0000000000..d1ff25d531 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/dt_optee.h @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ +#ifndef __DT_OPTEE_H__ +#define __DT_OPTEE_H__ + +extern unsigned long rom_pointer[]; +int ft_add_optee_overlay(void *fdt, struct bd_info *bd); +#endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index f1624ff30a..0824c62264 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -31,6 +31,7 @@ #endif #include <asm/arch/speed.h> #include <fsl_qbman.h> +#include "dt_optee.h"
int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) { @@ -698,3 +699,14 @@ void ft_cpu_setup(void *blob, struct bd_info *bd) fdt_fixup_ecam(blob); #endif } + +#ifdef CONFIG_OF_SYSTEM_SETUP +int ft_system_setup(void *blob, struct bd_info *bd) +{ +#ifdef CONFIG_OF_LIBFDT_OVERLAY + return ft_add_optee_overlay(blob, bd); +#else + return 0; +#endif +} +#endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel_init.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel_init.S new file mode 100644 index 0000000000..1d6a2d85fa --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel_init.S @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ + +#include <config.h> + +.align 8 +.global rom_pointer +rom_pointer: + .space 32 + +/* + * Routine: save_boot_params (called after reset from start.S) + */ + +.global save_boot_params +save_boot_params: + /* The firmware provided FDT address can be found in r2/x0 */ + adr x0, rom_pointer + stp x1, x2, [x0], #16 + stp x3, x4, [x0], #16 + + ldr x1, =save_boot_params_ret + br x1
SoCs enabled for DTB Overlay features are: LS1046A-RDB LS1043A-RDB LS1012A-RDB LS1028A-RDB LS1088A-RDB LS2088A-RDB
Signed-off-by: Sahil Malhotra sahil.malhotra@nxp.com --- configs/ls1012ardb_tfa_defconfig | 2 ++ configs/ls1028ardb_tfa_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 2 ++ configs/ls1046ardb_tfa_defconfig | 2 ++ configs/ls1088ardb_tfa_defconfig | 2 ++ configs/ls2088ardb_tfa_defconfig | 2 ++ 6 files changed, 11 insertions(+)
diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index c52359e51d..49ee762e38 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -69,3 +69,5 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_SYSTEM_SETUP=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 8ce9da5b4f..b360427eb3 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -95,3 +95,4 @@ CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y CONFIG_VIDEO=y CONFIG_VIDEO_LS_HDP_LOAD=y +CONFIG_OF_SYSTEM_SETUP=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index de3db3e2c4..a64df243f9 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -67,3 +67,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_SYSTEM_SETUP=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index e9e2efb210..55b6016e74 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -71,3 +71,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_SYSTEM_SETUP=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index 2e99e337c8..2351749d7d 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -94,3 +94,5 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_RTL8152=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_SYSTEM_SETUP=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index de57235284..d1b6e7f7ae 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -89,3 +89,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_SYSTEM_SETUP=y
Sahil Malhotra
