[U-Boot] [PATCH] drivers/rtc/ds1337.c: fix GCC 4.6 build warnings
Fix: ds1337.c: In function 'rtc_get': ds1337.c:88:52: warning: variable 'control' set but not used [-Wunused-but-set-variable]
Signed-off-by: Wolfgang Denk wd@denx.de --- drivers/rtc/ds1337.c | 16 +++------------- 1 files changed, 3 insertions(+), 13 deletions(-)
diff --git a/drivers/rtc/ds1337.c b/drivers/rtc/ds1337.c index 7abf041..5bb9f94 100644 --- a/drivers/rtc/ds1337.c +++ b/drivers/rtc/ds1337.c @@ -34,16 +34,6 @@
#if defined(CONFIG_CMD_DATE)
-/*---------------------------------------------------------------------*/ -#undef DEBUG_RTC - -#ifdef DEBUG_RTC -#define DEBUGR(fmt,args...) printf(fmt ,##args) -#else -#define DEBUGR(fmt,args...) -#endif -/*---------------------------------------------------------------------*/ - /* * RTC register addresses */ @@ -97,7 +87,7 @@ int rtc_get (struct rtc_time *tmp) mon_cent = rtc_read (RTC_MON_REG_ADDR); year = rtc_read (RTC_YR_REG_ADDR);
- DEBUGR ("Get RTC year: %02x mon/cent: %02x mday: %02x wday: %02x " + debug("Get RTC year: %02x mon/cent: %02x mday: %02x wday: %02x " "hr: %02x min: %02x sec: %02x control: %02x status: %02x\n", year, mon_cent, mday, wday, hour, min, sec, control, status);
@@ -119,7 +109,7 @@ int rtc_get (struct rtc_time *tmp) tmp->tm_yday = 0; tmp->tm_isdst= 0;
- DEBUGR ("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + debug("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, tmp->tm_hour, tmp->tm_min, tmp->tm_sec);
@@ -134,7 +124,7 @@ int rtc_set (struct rtc_time *tmp) { uchar century;
- DEBUGR ("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, tmp->tm_hour, tmp->tm_min, tmp->tm_sec);
This undermines the ability of fine-grained debuging output, right? Now you can only debug whole uboot or nothing ... correct me if I'm wrong please.
- RTC register addresses
- debug("Get RTC year: %02x mon/cent: %02x mday: %02x wday: %02x " "hr: %02x min: %02x sec: %02x control: %02x status: %02x\n", year, mon_cent, mday, wday, hour, min, sec, control, status);
Cheers
Dear Marek Vasut,
In message 201110300039.59309.marek.vasut@gmail.com you wrote:
-#undef DEBUG_RTC
The normal way to enable debugging on file scope is to compile only the respective files with DEBUG defined.
Dear Marek Vasut,
-#undef DEBUG_RTC
-#ifdef DEBUG_RTC -#define DEBUGR(fmt,args...) printf(fmt ,##args) -#else -#define DEBUGR(fmt,args...) -#endif -/*-------------------------------------------------------------------- -*/ -
Roger that !!
Dear Wolfgang Denk,
Applied, thanks.
