[PATCH] arm: dts: Add xlnx prefix to GEM compatible string
cdns,zynq/zynqmp were recentle deprecated in Linux in favour of xlnx prefix. Add this new compatible string and retain the existing string for compatibility with uboot drivers.
Signed-off-by: Harini Katakam harini.katakam@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynq-7000.dtsi | 4 ++-- arch/arm/dts/zynqmp.dtsi | 8 ++++---- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index a7ca00fb76c6..b4aa09d149b0 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -247,7 +247,7 @@ };
gem0: ethernet@e000b000 { - compatible = "cdns,zynq-gem", "cdns,gem"; + compatible = "xlnx,zynq-gem", "cdns,zynq-gem", "cdns,gem"; reg = <0xe000b000 0x1000>; status = "disabled"; interrupts = <0 22 4>; @@ -258,7 +258,7 @@ };
gem1: ethernet@e000c000 { - compatible = "cdns,zynq-gem", "cdns,gem"; + compatible = "xlnx,zynq-gem", "cdns,zynq-gem", "cdns,gem"; reg = <0xe000c000 0x1000>; status = "disabled"; interrupts = <0 45 4>; diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index fbc6e752da93..2aaec6cf5a15 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -529,7 +529,7 @@ };
gem0: ethernet@ff0b0000 { - compatible = "cdns,zynqmp-gem", "cdns,gem"; + compatible = "xlnx,zynqmp-gem", "cdns,zynqmp-gem", "cdns,gem"; status = "disabled"; interrupt-parent = <&gic>; interrupts = <0 57 4>, <0 57 4>; @@ -543,7 +543,7 @@ };
gem1: ethernet@ff0c0000 { - compatible = "cdns,zynqmp-gem", "cdns,gem"; + compatible = "xlnx,zynqmp-gem", "cdns,zynqmp-gem", "cdns,gem"; status = "disabled"; interrupt-parent = <&gic>; interrupts = <0 59 4>, <0 59 4>; @@ -557,7 +557,7 @@ };
gem2: ethernet@ff0d0000 { - compatible = "cdns,zynqmp-gem", "cdns,gem"; + compatible = "xlnx,zynqmp-gem", "cdns,zynqmp-gem", "cdns,gem"; status = "disabled"; interrupt-parent = <&gic>; interrupts = <0 61 4>, <0 61 4>; @@ -571,7 +571,7 @@ };
gem3: ethernet@ff0e0000 { - compatible = "cdns,zynqmp-gem", "cdns,gem"; + compatible = "xlnx,zynqmp-gem", "cdns,zynqmp-gem", "cdns,gem"; status = "disabled"; interrupt-parent = <&gic>; interrupts = <0 63 4>, <0 63 4>;
Ășt 23. 8. 2022 v 14:59 odesĂlatel Michal Simek michal.simek@amd.com napsal:
-- 2.36.1
Applied. M
Michal Simek
Michal Simek
