[U-Boot] [PATCH 00/82] x86: Add initial support for 64-bit U-Boot
At present U-Boot runs entirely in 32-bit mode on x86, except for the initial switch from 16-bit mode. On 64-bit machines it is possible to run in 64-bit mode. This series starts the process of adding this support.
The main benefit of 64-bit mode for a boot loader is direct access to all available memory. There are also more registers, but this makes very little difference.
This feature is implemented by putting all of the 32-bit code in an SPL build. SPL then runs through all the init that has to be done in 32-bit mode, changes to 64-bit mode and then jumps to U-Boot proper.
Typically the total code size increases slightly. For example, on link in 32-bit mode, U-Boot has around 480KB of code (admittedly with a large number of features enabled). In 64-bit mode, U-Boot falls to around 460KB, but SPL adds another 60KB, for a net increase of 40KB. Partly this is due to code duplication and partly it is due to the worse code density of 64-bit code on x86.
Many major features are not implemented yet, for example: - SDRAM sizing - Booting linux - FSP support - EFI support - SCSI device init - Running video ROMs
Still, this is a big step forward towards full 64-bit support. To enable it, select CONFIG_X86_RUN_64BIT.
This series is available at u-boot-x86/64-working
Simon Glass (82): WIP: x86: Fix up types in smbios code Add _image_binary_end section declaration bios_emulator: Fix cast for 64-bit compilation board_f: Drop the extra fdtdec_prepare_fdt() console: Don't enable CONFIG-CONSOLE_MUX, etc. in SPL elf: Add the Elf64_Rela type mmc: Fix cast for 64-bit compilation rtc: Use CONFIG_X86 instead of __I386__ spl: spi: Add a debug message if loading fails spl: Makefile: Define SPL_ earlier spl: Allow CPU drivers to be used in SPL spl: Allow PCI drivers to be used in SPL spl: Allow RTC drivers to be used in SPL spl: Allow timer drivers to be used in SPL spl: Allow PCH drivers to be used in SPL spl: Don't create a BSS padding when it is separate tpm: Tidy up use of size_t usb: pci: Fix cast for 64-bit compilation video: Use ulong for video frame buffer address x86: Allow interrupts to be disabled in 64-bit mode x86: Correct address casts in cpu code x86: Correct address casts in interrupt code x86: Use unsigned long for address in table generation WIP: x86: Update mpspec to build on 64-bit machines x86: Add basic support for U-Boot as a 64-bit EFI application x86: ivybridge: Declare global data where it is used x86: i2c: Fix cast of address to 32-bit value x86: Don't export interrupt handlers with x86_64 x86: ivybridge: Add more debugging for failures x86: ivybridge: Fix types for 64-bit compilation x86: ivybridge: Fix PCH power setup x86: ivybridge: Tidy up enable_clock_gating() for 64-bit x86: dts: Mark serial as needed before relocation x86: fsp: Fix cast for 64-bit compilation x86: Drop unused init_helper functions x86: lib: Fix types and casts for 64-bit compilation x86: mrccache: Fix error handling in mrccache_get_region() x86: Add Kconfig options to build 64-bit U-Boot x86: Kconfig: Add location options for 16/32-bit init x86: Use X86_16BIT_INIT instead of X86_RESET_VECTOR x86: Use X86_32BIT_INIT instead of X86_RESET_VECTOR x86: ivybridge: Allow 32-bit init to move to SPL x86: Add 64-bit start-up code x86: board_f: Update init sequence for 64-bit startup x86: board_r: Set the global data pointer after relocation x86: Do relocation before clearing BSS x86: Refactor relocation to prepare for 64-bit x86: Add support for 64-bit relocation x86: Tidy up use of size_t in relocation x86: Add an SPL implementation x86: Move the i386 code into its own directory x86: Add cpu code for x86_64 x86: Support global_data on x86_64 x86: Fix up CONFIG_X86_64 check x86: Add a link script for 64-bit x86 x86: Add a link script for SPL x86: Add SPL build rules for start-up code x86: Fix up byteorder.h for x86_64 x86: Drop flag_is_changable() on x86_64 x86: Fix up type sizes for 64-bit x86: Mention the MRC region in the README x86: ivybridge: Only do graphics init in 32-bit mode x86: ivybridge: Skipt SATA init in SPL x86: ivybridge: Provide a dummy SDRAM init for 64-bit x86: Don't try to run the VGA BIOS in 64-bit mode x86: Don't build call64 and setjmp on 64-bit x86: Don't build cpu files which are not supported on 64-bit x86: Don't try to boot Linux from SPL x86: Drop interrupt support in 64-bit mode x86: Support jumping from SPL to U-Boot x86: Move pirq_routing_table to global_data x86: Move turbo_state to global_data x86: Change irq_already_routed to a local variable x86: Move call64 to the i386 directory x86: Move setjmp to the i386 directory x86: Add a dummy setjmp implementation for x86_64 x86: link: Add a text base for 64-bit U-Boot x86: link: Add SPL declarations to the binman image x86: link: Set up device tree for SPL x86: link: Add build options for SPL x86: Update compile/link flags to support 64-bit U-Boot x86: link: Switch to 64-bit U-Boot
Makefile | 7 +- arch/x86/Kconfig | 85 ++++ arch/x86/Makefile | 9 +- arch/x86/config.mk | 30 +- arch/x86/cpu/Makefile | 24 +- arch/x86/cpu/config.mk | 8 +- arch/x86/cpu/cpu.c | 506 -------------------- arch/x86/cpu/efi/elf_x86_64_efi.lds | 3 + arch/x86/cpu/i386/Makefile | 9 + arch/x86/cpu/{ => i386}/call64.S | 3 + arch/x86/cpu/i386/cpu.c | 599 ++++++++++++++++++++++++ arch/x86/cpu/{interrupts.c => i386/interrupt.c} | 13 +- arch/x86/cpu/{ => i386}/setjmp.S | 0 arch/x86/cpu/intel_common/Makefile | 10 +- arch/x86/cpu/irq.c | 14 +- arch/x86/cpu/ivybridge/Makefile | 11 +- arch/x86/cpu/ivybridge/bd82x6x.c | 6 + arch/x86/cpu/ivybridge/cpu.c | 4 +- arch/x86/cpu/ivybridge/gma.c | 4 +- arch/x86/cpu/ivybridge/lpc.c | 18 +- arch/x86/cpu/ivybridge/model_206ax.c | 2 + arch/x86/cpu/ivybridge/northbridge.c | 2 + arch/x86/cpu/ivybridge/sata.c | 4 +- arch/x86/cpu/ivybridge/sdram.c | 36 +- arch/x86/cpu/ivybridge/sdram_nop.c | 29 ++ arch/x86/cpu/start64.S | 39 ++ arch/x86/cpu/turbo.c | 8 +- arch/x86/cpu/u-boot-64.lds | 76 +++ arch/x86/cpu/u-boot-spl.lds | 74 +++ arch/x86/cpu/u-boot.lds | 2 +- arch/x86/cpu/x86_64/Makefile | 6 + arch/x86/cpu/x86_64/cpu.c | 48 ++ arch/x86/cpu/x86_64/interrupts.c | 30 ++ arch/x86/cpu/x86_64/setjmp.c | 20 + arch/x86/dts/binman.dtsi | 19 + arch/x86/dts/chromebook_link.dts | 15 +- arch/x86/dts/serial.dtsi | 1 + arch/x86/include/asm/acpi_table.h | 2 +- arch/x86/include/asm/byteorder.h | 17 +- arch/x86/include/asm/cpu.h | 12 + arch/x86/include/asm/fsp/fsp_hob.h | 2 +- arch/x86/include/asm/global_data.h | 8 +- arch/x86/include/asm/init_helpers.h | 2 - arch/x86/include/asm/mp.h | 3 + arch/x86/include/asm/mpspec.h | 10 +- arch/x86/include/asm/posix_types.h | 5 + arch/x86/include/asm/sfi.h | 2 +- arch/x86/include/asm/smbios.h | 4 +- arch/x86/include/asm/spl.h | 8 + arch/x86/include/asm/tables.h | 2 +- arch/x86/include/asm/types.h | 5 + arch/x86/lib/Makefile | 9 + arch/x86/lib/acpi_table.c | 4 +- arch/x86/lib/bios.c | 4 +- arch/x86/lib/bootm.c | 2 + arch/x86/lib/init_helpers.c | 12 +- arch/x86/lib/interrupts.c | 5 + arch/x86/lib/mpspec.c | 14 +- arch/x86/lib/mrccache.c | 8 +- arch/x86/lib/pinctrl_ich6.c | 2 +- arch/x86/lib/pirq_routing.c | 14 +- arch/x86/lib/reloc_x86_64.c | 90 ++++ arch/x86/lib/relocate.c | 102 +++- arch/x86/lib/sfi.c | 6 +- arch/x86/lib/smbios.c | 22 +- arch/x86/lib/spl.c | 149 ++++++ arch/x86/lib/tables.c | 2 +- arch/x86/lib/zimage.c | 2 +- board/google/chromebook_link/Kconfig | 3 +- common/board_f.c | 17 +- common/board_r.c | 5 + common/console.c | 30 +- common/spl/Kconfig | 47 ++ common/spl/spl_spi.c | 4 +- configs/chromebook_link_defconfig | 22 +- doc/README.x86 | 1 + drivers/Makefile | 5 + drivers/bios_emulator/atibios.c | 2 +- drivers/i2c/intel_i2c.c | 6 +- drivers/misc/qfw.c | 4 +- drivers/mmc/pci_mmc.c | 2 +- drivers/pci/pci_rom.c | 2 +- drivers/rtc/mc146818.c | 2 +- drivers/tpm/tpm_tis_lpc.c | 4 +- drivers/usb/host/ehci-pci.c | 4 +- include/_exports.h | 2 +- include/asm-generic/sections.h | 1 + include/configs/chromebook_link.h | 9 + include/elf.h | 6 + include/video_fb.h | 2 +- scripts/Makefile.spl | 18 +- 91 files changed, 1796 insertions(+), 705 deletions(-) create mode 100644 arch/x86/cpu/i386/Makefile rename arch/x86/cpu/{ => i386}/call64.S (98%) create mode 100644 arch/x86/cpu/i386/cpu.c rename arch/x86/cpu/{interrupts.c => i386/interrupt.c} (98%) rename arch/x86/cpu/{ => i386}/setjmp.S (100%) create mode 100644 arch/x86/cpu/ivybridge/sdram_nop.c create mode 100644 arch/x86/cpu/start64.S create mode 100644 arch/x86/cpu/u-boot-64.lds create mode 100644 arch/x86/cpu/u-boot-spl.lds create mode 100644 arch/x86/cpu/x86_64/Makefile create mode 100644 arch/x86/cpu/x86_64/cpu.c create mode 100644 arch/x86/cpu/x86_64/interrupts.c create mode 100644 arch/x86/cpu/x86_64/setjmp.c create mode 100644 arch/x86/include/asm/spl.h create mode 100644 arch/x86/lib/reloc_x86_64.c create mode 100644 arch/x86/lib/spl.c
This gives warnings with 64-bit compilation at present. Fix these up.
Note that this is a placeholder patch while we wait for this patch to be applied:
https://patchwork.ozlabs.org/patch/660592/
arch/x86/include/asm/smbios.h | 2 +- arch/x86/lib/smbios.c | 20 ++++++++++---------- 2 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/arch/x86/include/asm/smbios.h b/arch/x86/include/asm/smbios.h index 623a703..fd13f2d 100644 --- a/arch/x86/include/asm/smbios.h +++ b/arch/x86/include/asm/smbios.h @@ -221,7 +221,7 @@ static inline void fill_smbios_header(void *table, int type, * @handle: the structure's handle, a unique 16-bit number * @return: size of the structure */ -typedef int (*smbios_write_type)(u32 *addr, int handle); +typedef int (*smbios_write_type)(ulong *addr, int handle);
/** * write_smbios_table() - Write SMBIOS table diff --git a/arch/x86/lib/smbios.c b/arch/x86/lib/smbios.c index 9f30550..c338b82 100644 --- a/arch/x86/lib/smbios.c +++ b/arch/x86/lib/smbios.c @@ -69,7 +69,7 @@ static int smbios_string_table_len(char *start) return len + 1; }
-static int smbios_write_type0(u32 *current, int handle) +static int smbios_write_type0(ulong *current, int handle) { struct smbios_type0 *t = (struct smbios_type0 *)*current; int len = sizeof(struct smbios_type0); @@ -98,7 +98,7 @@ static int smbios_write_type0(u32 *current, int handle) return len; }
-static int smbios_write_type1(u32 *current, int handle) +static int smbios_write_type1(ulong *current, int handle) { struct smbios_type1 *t = (struct smbios_type1 *)*current; int len = sizeof(struct smbios_type1); @@ -114,7 +114,7 @@ static int smbios_write_type1(u32 *current, int handle) return len; }
-static int smbios_write_type2(u32 *current, int handle) +static int smbios_write_type2(ulong *current, int handle) { struct smbios_type2 *t = (struct smbios_type2 *)*current; int len = sizeof(struct smbios_type2); @@ -132,7 +132,7 @@ static int smbios_write_type2(u32 *current, int handle) return len; }
-static int smbios_write_type3(u32 *current, int handle) +static int smbios_write_type3(ulong *current, int handle) { struct smbios_type3 *t = (struct smbios_type3 *)*current; int len = sizeof(struct smbios_type3); @@ -152,7 +152,7 @@ static int smbios_write_type3(u32 *current, int handle) return len; }
-static int smbios_write_type4(u32 *current, int handle) +static int smbios_write_type4(ulong *current, int handle) { struct smbios_type4 *t = (struct smbios_type4 *)*current; int len = sizeof(struct smbios_type4); @@ -185,7 +185,7 @@ static int smbios_write_type4(u32 *current, int handle) return len; }
-static int smbios_write_type32(u32 *current, int handle) +static int smbios_write_type32(ulong *current, int handle) { struct smbios_type32 *t = (struct smbios_type32 *)*current; int len = sizeof(struct smbios_type32); @@ -198,7 +198,7 @@ static int smbios_write_type32(u32 *current, int handle) return len; }
-static int smbios_write_type127(u32 *current, int handle) +static int smbios_write_type127(ulong *current, int handle) { struct smbios_type127 *t = (struct smbios_type127 *)*current; int len = sizeof(struct smbios_type127); @@ -224,7 +224,7 @@ static smbios_write_type smbios_write_funcs[] = { u32 write_smbios_table(u32 addr) { struct smbios_entry *se; - u32 tables; + ulong tables; int len = 0; int max_struct_size = 0; int handle = 0; @@ -235,7 +235,7 @@ u32 write_smbios_table(u32 addr) /* 16 byte align the table address */ addr = ALIGN(addr, 16);
- se = (struct smbios_entry *)addr; + se = (struct smbios_entry *)(uintptr_t)addr; memset(se, 0, sizeof(struct smbios_entry));
addr += sizeof(struct smbios_entry); @@ -244,7 +244,7 @@ u32 write_smbios_table(u32 addr)
/* populate minimum required tables */ for (i = 0; i < ARRAY_SIZE(smbios_write_funcs); i++) { - int tmp = smbios_write_funcs[i](&addr, handle++); + int tmp = smbios_write_funcs[i]((ulong *)&addr, handle++); max_struct_size = max(max_struct_size, tmp); len += tmp; }
This is used in some link scripts, so add a declaration for it.
include/asm-generic/sections.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/asm-generic/sections.h b/include/asm-generic/sections.h index 54ccac9..daf021b 100644 --- a/include/asm-generic/sections.h +++ b/include/asm-generic/sections.h @@ -84,6 +84,7 @@ extern ulong __data_end; extern ulong __rel_dyn_start; extern ulong __rel_dyn_end; extern ulong __bss_end; +extern ulong _image_binary_end;
extern ulong _TEXT_BASE; /* code start */
applied to u-boot-x86, thanks!
Fix a cast that causes warnings on 64-bit machines.
drivers/bios_emulator/atibios.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/bios_emulator/atibios.c b/drivers/bios_emulator/atibios.c index 7717246..2d5b5dc 100644 --- a/drivers/bios_emulator/atibios.c +++ b/drivers/bios_emulator/atibios.c @@ -599,7 +599,7 @@ int biosemu_run(pci_dev_t pcidev, uchar *bios_rom, int bios_len, if (clean_up) { BE_exit(); if (vga_info->BIOSImage && - (u32)(vga_info->BIOSImage) != 0xc0000) + (ulong)(vga_info->BIOSImage) != 0xc0000) free(vga_info->BIOSImage); free(vga_info); vga_info = NULL;
This is already called earlier, from fdtdec_setup(), so drop this unnecessary call from the init sequence.
common/board_f.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 2c88595..e3179a1 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -912,9 +912,6 @@ static init_fnc_t init_sequence_f[] = { #ifdef CONFIG_SANDBOX sandbox_early_getopt_check, #endif -#ifdef CONFIG_OF_CONTROL - fdtdec_prepare_fdt, -#endif display_options, /* say that we are here */ display_text_info, /* show debugging info if required */ #if defined(CONFIG_MPC8260)
CONFIG_CONSOLE_MUX and CONFIG_SYS_CONSOLE_IS_IN_ENV are not applicable for SPL. Update the console code to use CONFIG_IS_ENABLED(), so that these options will be inactive in SPL.
common/console.c | 30 +++++++++++++++--------------- 1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/common/console.c b/common/console.c index 31a9b3e..4d56ed7 100644 --- a/common/console.c +++ b/common/console.c @@ -40,14 +40,14 @@ static int on_console(const char *name, const char *value, enum env_op op, case env_op_create: case env_op_overwrite:
-#ifdef CONFIG_CONSOLE_MUX +#if CONFIG_IS_ENABLED(CONSOLE_MUX) if (iomux_doenv(console, value)) return 1; #else /* Try assigning specified device */ if (console_assign(console, value) < 0) return 1; -#endif /* CONFIG_CONSOLE_MUX */ +#endif return 0;
case env_op_delete: @@ -84,7 +84,7 @@ static int on_silent(const char *name, const char *value, enum env_op op, U_BOOT_ENV_CALLBACK(silent, on_silent); #endif
-#ifdef CONFIG_SYS_CONSOLE_IS_IN_ENV +#if CONFIG_IS_ENABLED(SYS_CONSOLE_IS_IN_ENV) /* * if overwrite_console returns 1, the stdin, stderr and stdout * are switched to the serial port, else the settings in the @@ -97,7 +97,7 @@ extern int overwrite_console(void); #define OVERWRITE_CONSOLE 0 #endif /* CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE */
-#endif /* CONFIG_SYS_CONSOLE_IS_IN_ENV */ +#endif /* CONFIG_IS_ENABLED(SYS_CONSOLE_IS_IN_ENV) */
static int console_setfile(int file, struct stdio_dev * dev) { @@ -144,7 +144,7 @@ static int console_setfile(int file, struct stdio_dev * dev) return error; }
-#if defined(CONFIG_CONSOLE_MUX) +#if CONFIG_IS_ENABLED(CONSOLE_MUX) /** Console I/O multiplexing *******************************************/
static struct stdio_dev *tstcdev; @@ -264,7 +264,7 @@ static inline void console_doenv(int file, struct stdio_dev *dev) { console_setfile(file, dev); } -#endif /* defined(CONFIG_CONSOLE_MUX) */ +#endif /* CONIFIG_IS_ENABLED(CONSOLE_MUX) */
/** U-Boot INITIAL CONSOLE-NOT COMPATIBLE FUNCTIONS *************************/
@@ -289,7 +289,7 @@ int serial_printf(const char *fmt, ...) int fgetc(int file) { if (file < MAX_FILES) { -#if defined(CONFIG_CONSOLE_MUX) +#if CONFIG_IS_ENABLED(CONSOLE_MUX) /* * Effectively poll for input wherever it may be available. */ @@ -727,7 +727,7 @@ void stdio_print_current_devices(void) } }
-#ifdef CONFIG_SYS_CONSOLE_IS_IN_ENV +#if CONFIG_IS_ENABLED(SYS_CONSOLE_IS_IN_ENV) /* Called after the relocation - use desired console functions */ int console_init_r(void) { @@ -736,7 +736,7 @@ int console_init_r(void) #ifdef CONFIG_SYS_CONSOLE_ENV_OVERWRITE int i; #endif /* CONFIG_SYS_CONSOLE_ENV_OVERWRITE */ -#ifdef CONFIG_CONSOLE_MUX +#if CONFIG_IS_ENABLED(CONSOLE_MUX) int iomux_err = 0; #endif
@@ -757,7 +757,7 @@ int console_init_r(void) inputdev = search_device(DEV_FLAGS_INPUT, stdinname); outputdev = search_device(DEV_FLAGS_OUTPUT, stdoutname); errdev = search_device(DEV_FLAGS_OUTPUT, stderrname); -#ifdef CONFIG_CONSOLE_MUX +#if CONFIG_IS_ENABLED(CONSOLE_MUX) iomux_err = iomux_doenv(stdin, stdinname); iomux_err += iomux_doenv(stdout, stdoutname); iomux_err += iomux_doenv(stderr, stderrname); @@ -790,7 +790,7 @@ int console_init_r(void) console_doenv(stdin, inputdev); }
-#ifdef CONFIG_CONSOLE_MUX +#if CONFIG_IS_ENABLED(CONSOLE_MUX) done: #endif
@@ -820,7 +820,7 @@ done: return 0; }
-#else /* CONFIG_SYS_CONSOLE_IS_IN_ENV */ +#else /* !CONFIG_IS_ENABLED(SYS_CONSOLE_IS_IN_ENV) */
/* Called after the relocation - use desired console functions */ int console_init_r(void) @@ -862,7 +862,7 @@ int console_init_r(void) if (outputdev != NULL) { console_setfile(stdout, outputdev); console_setfile(stderr, outputdev); -#ifdef CONFIG_CONSOLE_MUX +#if CONFIG_IS_ENABLED(CONSOLE_MUX) console_devices[stdout][0] = outputdev; console_devices[stderr][0] = outputdev; #endif @@ -871,7 +871,7 @@ int console_init_r(void) /* Initializes input console */ if (inputdev != NULL) { console_setfile(stdin, inputdev); -#ifdef CONFIG_CONSOLE_MUX +#if CONFIG_IS_ENABLED(CONSOLE_MUX) console_devices[stdin][0] = inputdev; #endif } @@ -896,4 +896,4 @@ int console_init_r(void) return 0; }
Hi Simon,
Typo of CONFIG-CONSOLE_MUX in the commit title.
I don't understand, what's the difference between CONFIG_IS_ENABLE() and #ifdef?
[snip]
Regards, Bin
Hi Bin,
On 10 October 2016 at 21:15, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
CONFIG_IS_ENABLED() can have a different value for SPL and U-Boot proper. It uses CONFIG_xxx or CONFIG_SPL_xxx depending on which is being built.
Add this so that we can support 64-bit relocation on x86.
include/elf.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/elf.h b/include/elf.h index a35e085..bcc5eb7 100644 --- a/include/elf.h +++ b/include/elf.h @@ -394,6 +394,12 @@ typedef struct { Elf64_Xword r_info; /* index and type of relocation */ } Elf64_Rel;
+typedef struct { + Elf64_Addr r_offset; /* Location at which to apply the action */ + Elf64_Xword r_info; /* index and type of relocation */ + Elf64_Sxword r_addend; /* Constant addend used to compute value */ +} Elf64_Rela; + /* Extract relocation info - r_info */ #define ELF32_R_SYM(i) ((i) >> 8) #define ELF32_R_TYPE(i) ((unsigned char) (i))
drivers/mmc/pci_mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/pci_mmc.c b/drivers/mmc/pci_mmc.c index 340eef6..3d587cc 100644 --- a/drivers/mmc/pci_mmc.c +++ b/drivers/mmc/pci_mmc.c @@ -30,7 +30,7 @@ int pci_mmc_init(const char *name, struct pci_device_id *mmc_supported)
mmc_host->name = name; dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0, &iobase); - mmc_host->ioaddr = (void *)iobase; + mmc_host->ioaddr = (void *)(ulong)iobase; mmc_host->quirks = 0; ret = add_sdhci(mmc_host, 0, 0); if (ret)
Hi Simon, Bin,
If you are ok, I will pick this. how about?
Best Regards, Jaehoon Chung
mmc_host->quirks = 0; ret = add_sdhci(mmc_host, 0, 0); if (ret)mmc_host->ioaddr = (void *)(ulong)iobase;
Hi Jaehoon,
On Mon, Oct 10, 2016 at 2:37 PM, Jaehoon Chung jh80.chung@samsung.com wrote:
Hi Simon, Bin,
I am OK with that. thanks!
Regards, Bin
Applied on u-boot-mmc. Thanks!
For 64-bit x86, __I386__ should perhaps not be defined. It is not clear from the definition, but let's use CONFIG_X86 to be sure.
drivers/rtc/mc146818.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/rtc/mc146818.c b/drivers/rtc/mc146818.c index da804d5..4df9eda 100644 --- a/drivers/rtc/mc146818.c +++ b/drivers/rtc/mc146818.c @@ -14,7 +14,7 @@ #include <dm.h> #include <rtc.h>
-#if defined(__I386__) || defined(CONFIG_MALTA) +#if defined(CONFIG_X86) || defined(CONFIG_MALTA) #include <asm/io.h> #define in8(p) inb(p) #define out8(p, v) outb(v, p)
This currently fails silently. Add a debug message to aid debugging.
common/spl/spl_spi.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index a3caafb..3f400eb 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -96,8 +96,10 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, /* Load u-boot, mkimage header is 64 bytes. */ err = spi_flash_read(flash, CONFIG_SYS_SPI_U_BOOT_OFFS, 0x40, (void *)header); - if (err) + if (err) { + debug("%s: Failed to read from SPI flash\n", __func__); return err; + }
if (IS_ENABLED(CONFIG_SPL_LOAD_FIT)) { struct spl_load_info load;
Hi Simon,
if (err)
if (err) {
How about output the err num as well?
return err;
} if (IS_ENABLED(CONFIG_SPL_LOAD_FIT)) { struct spl_load_info load;
Regards, Bin
This Makefile variable can be used in the architecture's main Makefile but at present it is not set up until later. Set it just before this Makefile is included.
scripts/Makefile.spl | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index a5e0423..4a961f7 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -35,6 +35,12 @@ else SPL_BIN := u-boot-spl endif
+ifdef CONFIG_SPL_BUILD +SPL_ := SPL_ +else +SPL_ := +endif + include $(srctree)/config.mk include $(srctree)/arch/$(ARCH)/Makefile
Add a new Kconfig option to allow CPU drivers to be used in SPL.
common/spl/Kconfig | 10 ++++++++++ drivers/Makefile | 1 + 2 files changed, 11 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 84670b1..3c33c9e 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -123,6 +123,16 @@ config SPL_SHA256_SUPPORT SHA256 variant is supported: SHA512 and others are not currently supported in U-Boot.
+config SPL_CPU_SUPPORT + bool "Support CPU drivers" + depends on SPL + help + Enable this to support CPU drivers in SPL. These drivers can set + up CPUs and provide information about them such as the model and + name. This can be useful in SPL since setting up the CPUs earlier + may improve boot performance. Enable this option to build the + drivers in drivers/cpu as part of an SPL build. + config SPL_CRYPTO_SUPPORT bool "Support crypto drivers" depends on SPL diff --git a/drivers/Makefile b/drivers/Makefile index ca98273..b4fd0c4 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_$(SPL_)RAM) += ram/
+obj-$(CONFIG_SPL_CPU_SUPPORT) += cpu/ obj-$(CONFIG_SPL_CRYPTO_SUPPORT) += crypto/ obj-$(CONFIG_SPL_I2C_SUPPORT) += i2c/ obj-$(CONFIG_SPL_GPIO_SUPPORT) += gpio/
Add a new Kconfig option to allow PCI drivers to be used in SPL.
common/spl/Kconfig | 9 +++++++++ drivers/Makefile | 1 + 2 files changed, 10 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 3c33c9e..0c83ff1 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -378,6 +378,15 @@ config SPL_ONENAND_SUPPORT load U-Boot from supported devices. This enables the drivers in drivers/mtd/onenand as part of an SPL build.
+config SPL_PCI_SUPPORT + bool "Support PCI drivers" + depends on SPL + help + Enable support for PCI in SPL. For platforms that need PCI to boot, + or must perform some init using PCI in SPL, this provides the + necessary driver support. This enables the drivers in drivers/pci + as part of an SPL build. + config SPL_POST_MEM_SUPPORT bool "Support POST drivers" depends on SPL diff --git a/drivers/Makefile b/drivers/Makefile index b4fd0c4..ae3c76a 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -33,6 +33,7 @@ obj-$(CONFIG_SPL_DMA_SUPPORT) += dma/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += net/phy/ +obj-$(CONFIG_SPL_PCI_SUPPORT) += pci/ obj-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += usb/musb-new/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += usb/gadget/ obj-$(CONFIG_SPL_WATCHDOG_SUPPORT) += watchdog/
Add a new Kconfig option to allow RTC drivers to be used in SPL.
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0c83ff1..6e0637a 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -410,6 +410,16 @@ config SPL_POWER_SUPPORT in drivers/power, drivers/power/pmic and drivers/power/regulator as part of an SPL build.
+config SPL_RTC_SUPPORT + bool "Support RTC drivers" + depends on SPL + help + Enable RTC (Real-time Clock) support in SPL. This includes support + for reading and setting the time. Some RTC devices also have some + non-volatile (battery-backed) memory which is accessible if + needed. This enables the drivers in drivers/rtc as part of an SPL + build. + config SPL_SATA_SUPPORT bool "Support loading from SATA" depends on SPL diff --git a/drivers/Makefile b/drivers/Makefile index ae3c76a..0351eaf 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_PCI_SUPPORT) += pci/ +obj-$(CONFIG_SPL_RTC_SUPPORT) += rtc/ obj-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += usb/musb-new/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += usb/gadget/ obj-$(CONFIG_SPL_WATCHDOG_SUPPORT) += watchdog/
Add a new Kconfig option to allow timer drivers to be used in SPL.
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6e0637a..260387c 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -463,6 +463,15 @@ config SPL_SPI_SUPPORT enable SPI drivers that are needed for other purposes also, such as a SPI PMIC.
+config SPL_TIMER_SUPPORT + bool "Support timer drivers" + depends on SPL + help + Enable support for timer drivers in SPL. These can be used to get + a timer value when in SPL, or perhaps for implementing a delay + function. This enables the drivers in drivers/timer as part of an + SPL build. + config SPL_USBETH_SUPPORT bool "Support USB Ethernet drivers" depends on SPL diff --git a/drivers/Makefile b/drivers/Makefile index 0351eaf..4149836 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -35,6 +35,7 @@ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_PCI_SUPPORT) += pci/ obj-$(CONFIG_SPL_RTC_SUPPORT) += rtc/ +obj-$(CONFIG_SPL_TIMER_SUPPORT) += timer/ obj-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += usb/musb-new/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += usb/gadget/ obj-$(CONFIG_SPL_WATCHDOG_SUPPORT) += watchdog/
Add an option for building Platorm Controller Hub drivers in SPL.
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 260387c..64459e5 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -387,6 +387,15 @@ config SPL_PCI_SUPPORT necessary driver support. This enables the drivers in drivers/pci as part of an SPL build.
+config SPL_PCH_SUPPORT + bool "Support PCH drivers" + depends on SPL + help + Enable support for PCH (Platform Controller Hub) devices in SPL. + These are used to set up GPIOs and the SPI peripheral early in + boot. This enables the drivers in drivers/pch as part of an SPL + build. + config SPL_POST_MEM_SUPPORT bool "Support POST drivers" depends on SPL diff --git a/drivers/Makefile b/drivers/Makefile index 4149836..5d6acc3 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_PCI_SUPPORT) += pci/ +obj-$(CONFIG_SPL_PCH_SUPPORT) += pch/ obj-$(CONFIG_SPL_RTC_SUPPORT) += rtc/ obj-$(CONFIG_SPL_TIMER_SUPPORT) += timer/ obj-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += usb/musb-new/
When BSS does not immediate follow the SPL image we don't need padding before the device tree. Remove it in this case.
scripts/Makefile.spl | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 4a961f7..bd1f392 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -188,7 +188,8 @@ quiet_cmd_copy = COPY $@ cmd_copy = cp $< $@
ifeq ($(CONFIG_SPL_OF_CONTROL)$(CONFIG_OF_SEPARATE)$(CONFIG_SPL_OF_PLATDATA),yy) -$(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin $(obj)/$(SPL_BIN)-pad.bin \ +$(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin \ + $(if $(CONFIG_SPL_SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ $(obj)/$(SPL_BIN).dtb FORCE $(call if_changed,cat)
We should consistently use %z with size_t, and avoid passing a uint32_t as a size_t value. Fix these issues to avoid warnings on 64-bit machines.
drivers/tpm/tpm_tis_lpc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/tpm/tpm_tis_lpc.c b/drivers/tpm/tpm_tis_lpc.c index 257d035..b4efbb5 100644 --- a/drivers/tpm/tpm_tis_lpc.c +++ b/drivers/tpm/tpm_tis_lpc.c @@ -204,7 +204,7 @@ static int tis_senddata(struct udevice *dev, const u8 *data, size_t len) /* Wait till the device is ready to accept more data. */ while (!burst) { if (max_cycles++ == MAX_DELAY_US) { - printf("%s:%d failed to feed %d bytes of %d\n", + printf("%s:%d failed to feed %zd bytes of %zd\n", __FILE__, __LINE__, len - offset, len); return -ETIMEDOUT; } @@ -224,7 +224,7 @@ static int tis_senddata(struct udevice *dev, const u8 *data, size_t len) * changes to zero exactly after the last byte is fed into the * FIFO. */ - count = min((u32)burst, len - offset - 1); + count = min((size_t)burst, len - offset - 1); while (count--) tpm_write_byte(priv, data[offset++], ®s[locality].data);
drivers/usb/host/ehci-pci.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ehci-pci.c b/drivers/usb/host/ehci-pci.c index 6fc2479..f20fc33 100644 --- a/drivers/usb/host/ehci-pci.c +++ b/drivers/usb/host/ehci-pci.c @@ -32,8 +32,8 @@ static void ehci_pci_init(struct udevice *dev, struct ehci_hccr **ret_hccr, hcor = (struct ehci_hcor *)((uintptr_t) hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
- debug("EHCI-PCI init hccr 0x%x and hcor 0x%x hc_length %d\n", - (u32)hccr, (u32)hcor, + debug("EHCI-PCI init hccr %#lx and hcor %#lx hc_length %d\n", + (ulong)hccr, (ulong)hcor, (u32)HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
*ret_hccr = hccr;
Change this type from int to ulong to avoid warnings on 64-bit machines.
include/video_fb.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/video_fb.h b/include/video_fb.h index b008853..4a4fd5f 100644 --- a/include/video_fb.h +++ b/include/video_fb.h @@ -38,7 +38,7 @@ typedef struct graphic_device { unsigned int dprBase; unsigned int vprBase; unsigned int cprBase; - unsigned int frameAdrs; + unsigned long frameAdrs; unsigned int memSize; unsigned int mode; unsigned int gdfIndex;
- unsigned long frameAdrs; unsigned int memSize; unsigned int mode; unsigned int gdfIndex;
I suspect this patch is not needed after this series: http://lists.denx.de/pipermail/u-boot/2016-October/269561.html
Regards, Bin
Update the code to support both 32-bit and 64-bit modes.
arch/x86/cpu/interrupts.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/interrupts.c b/arch/x86/cpu/interrupts.c index dd2819a..46babe0 100644 --- a/arch/x86/cpu/interrupts.c +++ b/arch/x86/cpu/interrupts.c @@ -238,8 +238,11 @@ int disable_interrupts(void) { long flags;
+#ifdef CONFIG_X86_64 + asm volatile ("pushfq ; popq %0 ; cli\n" : "=g" (flags) : ); +#else asm volatile ("pushfl ; popl %0 ; cli\n" : "=g" (flags) : ); - +#endif return flags & X86_EFLAGS_IF; }
We should cast an address to unsigned long, not u32.
arch/x86/cpu/cpu.c | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 269043d..7c1d6de 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -135,7 +135,7 @@ static void load_gdt(const u64 *boot_gdt, u16 num_entries) struct gdt_ptr gdt;
gdt.len = (num_entries * X86_GDT_ENTRY_SIZE) - 1; - gdt.ptr = (u32)boot_gdt; + gdt.ptr = (ulong)boot_gdt;
asm volatile("lgdtl %0\n" : : "m" (gdt)); } @@ -630,13 +630,11 @@ static void build_pagetable(uint32_t *pgtable) memset(pgtable, '\0', PAGETABLE_SIZE);
/* Level 4 needs a single entry */ - pgtable[0] = (uint32_t)&pgtable[1024] + 7; + pgtable[0] = (ulong)&pgtable[1024] + 7;
/* Level 3 has one 64-bit entry for each GiB of memory */ - for (i = 0; i < 4; i++) { - pgtable[1024 + i * 2] = (uint32_t)&pgtable[2048] + - 0x1000 * i + 7; - } + for (i = 0; i < 4; i++) + pgtable[1024 + i * 2] = (ulong)&pgtable[2048] + 0x1000 * i + 7;
/* Level 2 has 2048 64-bit entries, each repesenting 2MiB */ for (i = 0; i < 2048; i++)
arch/x86/cpu/interrupts.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/interrupts.c b/arch/x86/cpu/interrupts.c index 46babe0..5f6cdd3 100644 --- a/arch/x86/cpu/interrupts.c +++ b/arch/x86/cpu/interrupts.c @@ -182,8 +182,8 @@ static inline void load_idt(const struct desc_ptr *dtr)
void set_vector(u8 intnum, void *routine) { - idt[intnum].base_high = (u16)((u32)(routine) >> 16); - idt[intnum].base_low = (u16)((u32)(routine) & 0xffff); + idt[intnum].base_high = (u16)((ulong)(routine) >> 16); + idt[intnum].base_low = (u16)((ulong)(routine) & 0xffff); }
We should use unsigned long rather than u32 for addresses. Update this so that the table-generation code builds correctly on 64-bit machines.
arch/x86/cpu/irq.c | 2 +- arch/x86/include/asm/acpi_table.h | 2 +- arch/x86/include/asm/mpspec.h | 2 +- arch/x86/include/asm/sfi.h | 2 +- arch/x86/include/asm/smbios.h | 2 +- arch/x86/include/asm/tables.h | 2 +- arch/x86/lib/acpi_table.c | 4 ++-- arch/x86/lib/mpspec.c | 2 +- arch/x86/lib/sfi.c | 2 +- arch/x86/lib/smbios.c | 2 +- arch/x86/lib/tables.c | 2 +- drivers/misc/qfw.c | 4 ++-- 12 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/x86/cpu/irq.c b/arch/x86/cpu/irq.c index df3cd0a..516d84a 100644 --- a/arch/x86/cpu/irq.c +++ b/arch/x86/cpu/irq.c @@ -263,7 +263,7 @@ int irq_router_probe(struct udevice *dev) return irq_router_common_init(dev); }
-u32 write_pirq_routing_table(u32 addr) +ulong write_pirq_routing_table(ulong addr) { if (!pirq_routing_table) return addr; diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index caff4d8..bbd80a1 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -316,4 +316,4 @@ int acpi_create_madt_lapic_nmi(struct acpi_madt_lapic_nmi *lapic_nmi, u8 cpu, u16 flags, u8 lint); u32 acpi_fill_madt(u32 current); void acpi_create_gnvs(struct acpi_global_nvs *gnvs); -u32 write_acpi_tables(u32 start); +ulong write_acpi_tables(ulong start); diff --git a/arch/x86/include/asm/mpspec.h b/arch/x86/include/asm/mpspec.h index ad8eba9..146a4b0 100644 --- a/arch/x86/include/asm/mpspec.h +++ b/arch/x86/include/asm/mpspec.h @@ -456,6 +456,6 @@ int mp_determine_pci_dstirq(int bus, int dev, int func, int pirq); * @addr: start address to write MP table * @return: end address of MP table */ -u32 write_mp_table(u32 addr); +ulong write_mp_table(ulong addr);
#endif /* __ASM_MPSPEC_H */ diff --git a/arch/x86/include/asm/sfi.h b/arch/x86/include/asm/sfi.h index d1f0f0c..d6c44c9 100644 --- a/arch/x86/include/asm/sfi.h +++ b/arch/x86/include/asm/sfi.h @@ -132,6 +132,6 @@ typedef int (*sfi_table_handler) (struct sfi_table_header *table); * @base: Address to write table to * @return address to use for the next table */ -u32 write_sfi_table(u32 base); +ulong write_sfi_table(ulong base);
#endif /*_LINUX_SFI_H */ diff --git a/arch/x86/include/asm/smbios.h b/arch/x86/include/asm/smbios.h index fd13f2d..4e508c3 100644 --- a/arch/x86/include/asm/smbios.h +++ b/arch/x86/include/asm/smbios.h @@ -231,6 +231,6 @@ typedef int (*smbios_write_type)(ulong *addr, int handle); * @addr: start address to write SMBIOS table * @return: end address of SMBIOS table */ -u32 write_smbios_table(u32 addr); +ulong write_smbios_table(ulong addr);
#endif /* _SMBIOS_H_ */ diff --git a/arch/x86/include/asm/tables.h b/arch/x86/include/asm/tables.h index ae9f0d0..6154dd1 100644 --- a/arch/x86/include/asm/tables.h +++ b/arch/x86/include/asm/tables.h @@ -63,6 +63,6 @@ void write_tables(void); * @start: start address to write PIRQ routing table * @return: end address of PIRQ routing table */ -u32 write_pirq_routing_table(u32 start); +ulong write_pirq_routing_table(ulong start);
#endif /* _X86_TABLES_H_ */ diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 7001e8b..355456d 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -327,7 +327,7 @@ static void enter_acpi_mode(int pm1_cnt) * QEMU's version of write_acpi_tables is defined in * arch/x86/cpu/qemu/acpi_table.c */ -u32 write_acpi_tables(u32 start) +ulong write_acpi_tables(ulong start) { u32 current; struct acpi_rsdp *rsdp; @@ -345,7 +345,7 @@ u32 write_acpi_tables(u32 start) /* Align ACPI tables to 16 byte */ current = ALIGN(current, 16);
- debug("ACPI: Writing ACPI tables at %x\n", start); + debug("ACPI: Writing ACPI tables at %lx\n", start);
/* We need at least an RSDP and an RSDT Table */ rsdp = (struct acpi_rsdp *)current; diff --git a/arch/x86/lib/mpspec.c b/arch/x86/lib/mpspec.c index 6ab43f1..516d7b3 100644 --- a/arch/x86/lib/mpspec.c +++ b/arch/x86/lib/mpspec.c @@ -365,7 +365,7 @@ static void mptable_add_lintsrc(struct mp_config_table *mc, int bus_isa) bus_isa, 0, MP_APIC_ALL, 1); }
-u32 write_mp_table(u32 addr) +ulong write_mp_table(ulong addr) { struct mp_config_table *mc; int ioapic_id, ioapic_ver; diff --git a/arch/x86/lib/sfi.c b/arch/x86/lib/sfi.c index 3d36580..9564853 100644 --- a/arch/x86/lib/sfi.c +++ b/arch/x86/lib/sfi.c @@ -131,7 +131,7 @@ static int sfi_write_xsdt(struct table_info *tab) return 0; }
-u32 write_sfi_table(u32 base) +ulong write_sfi_table(ulong base) { struct table_info table;
diff --git a/arch/x86/lib/smbios.c b/arch/x86/lib/smbios.c index c338b82..975bbf2 100644 --- a/arch/x86/lib/smbios.c +++ b/arch/x86/lib/smbios.c @@ -221,7 +221,7 @@ static smbios_write_type smbios_write_funcs[] = { smbios_write_type127 };
-u32 write_smbios_table(u32 addr) +ulong write_smbios_table(ulong addr) { struct smbios_entry *se; ulong tables; diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index f92111e..351fc44 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -18,7 +18,7 @@ * @addr: start address to write the table * @return: end address of the table */ -typedef u32 (*table_write)(u32 addr); +typedef ulong (*table_write)(ulong addr);
static table_write table_write_funcs[] = { #ifdef CONFIG_GENERATE_PIRQ_TABLE diff --git a/drivers/misc/qfw.c b/drivers/misc/qfw.c index d43d1d3..a8af9e0 100644 --- a/drivers/misc/qfw.c +++ b/drivers/misc/qfw.c @@ -32,7 +32,7 @@ static LIST_HEAD(fw_list); * be ignored. * @return: 0 on success, or negative value on failure */ -static int bios_linker_allocate(struct bios_linker_entry *entry, u32 *addr) +static int bios_linker_allocate(struct bios_linker_entry *entry, ulong *addr) { uint32_t size, align; struct fw_file *file; @@ -147,7 +147,7 @@ static int bios_linker_add_checksum(struct bios_linker_entry *entry) }
/* This function loads and patches ACPI tables provided by QEMU */ -u32 write_acpi_tables(u32 addr) +ulong write_acpi_tables(ulong addr) { int i, ret = 0; struct fw_file *file;
At present this uses u32 to store an address. We should use unsigned long and avoid special types in function return values and parameters unless necessary. This makes the code more portable.
I believe Alex Graf has a patch to correct all of these, so this is just a WIP patch.
arch/x86/include/asm/mpspec.h | 8 ++++---- arch/x86/lib/mpspec.c | 12 ++++++------ 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/x86/include/asm/mpspec.h b/arch/x86/include/asm/mpspec.h index 146a4b0..30dbdca 100644 --- a/arch/x86/include/asm/mpspec.h +++ b/arch/x86/include/asm/mpspec.h @@ -224,9 +224,9 @@ struct mp_ext_compat_address_space { * @mc: configuration table header address * @return: configuration table end address */ -static inline u32 mp_next_mpc_entry(struct mp_config_table *mc) +static inline ulong mp_next_mpc_entry(struct mp_config_table *mc) { - return (u32)mc + mc->mpc_length; + return (ulong)mc + mc->mpc_length; }
/** @@ -254,9 +254,9 @@ static inline void mp_add_mpc_entry(struct mp_config_table *mc, uint length) * @mc: configuration table header address * @return: configuration table end address */ -static inline u32 mp_next_mpe_entry(struct mp_config_table *mc) +static inline ulong mp_next_mpe_entry(struct mp_config_table *mc) { - return (u32)mc + mc->mpc_length + mc->mpe_length; + return (ulong)mc + mc->mpc_length + mc->mpe_length; }
/** diff --git a/arch/x86/lib/mpspec.c b/arch/x86/lib/mpspec.c index 516d7b3..17e977c 100644 --- a/arch/x86/lib/mpspec.c +++ b/arch/x86/lib/mpspec.c @@ -25,10 +25,10 @@ static bool isa_irq_occupied[16];
struct mp_config_table *mp_write_floating_table(struct mp_floating_table *mf) { - u32 mc; + ulong mc;
memcpy(mf->mpf_signature, MPF_SIGNATURE, 4); - mf->mpf_physptr = (u32)mf + sizeof(struct mp_floating_table); + mf->mpf_physptr = (ulong)mf + sizeof(struct mp_floating_table); mf->mpf_length = 1; mf->mpf_spec = MPSPEC_V14; mf->mpf_checksum = 0; @@ -41,7 +41,7 @@ struct mp_config_table *mp_write_floating_table(struct mp_floating_table *mf) mf->mpf_feature5 = 0; mf->mpf_checksum = table_compute_checksum(mf, mf->mpf_length * 16);
- mc = (u32)mf + sizeof(struct mp_floating_table); + mc = (ulong)mf + sizeof(struct mp_floating_table); return (struct mp_config_table *)mc; }
@@ -219,14 +219,14 @@ void mp_write_compat_address_space(struct mp_config_table *mc, int busid,
u32 mptable_finalize(struct mp_config_table *mc) { - u32 end; + ulong end;
mc->mpe_checksum = table_compute_checksum((void *)mp_next_mpc_entry(mc), mc->mpe_length); mc->mpc_checksum = table_compute_checksum(mc, mc->mpc_length); end = mp_next_mpe_entry(mc);
- debug("Write the MP table at: %x - %x\n", (u32)mc, end); + debug("Write the MP table at: %lx - %lx\n", (ulong)mc, end);
return end; } @@ -371,7 +371,7 @@ ulong write_mp_table(ulong addr) int ioapic_id, ioapic_ver; int bus_isa = 0xff; int ret; - u32 end; + ulong end;
Add a link script and relocation code for building 64-bit EFI applications. This can be used for the EFI stub.
arch/x86/cpu/efi/elf_x86_64_efi.lds | 3 ++ arch/x86/lib/reloc_x86_64.c | 90 +++++++++++++++++++++++++++++++++++++ 2 files changed, 93 insertions(+) create mode 100644 arch/x86/lib/reloc_x86_64.c
diff --git a/arch/x86/cpu/efi/elf_x86_64_efi.lds b/arch/x86/cpu/efi/elf_x86_64_efi.lds index 9d9f057..68c4522 100644 --- a/arch/x86/cpu/efi/elf_x86_64_efi.lds +++ b/arch/x86/cpu/efi/elf_x86_64_efi.lds @@ -56,6 +56,9 @@ SECTIONS *(SORT(.u_boot_list*)); . = ALIGN(8); *(.dtb*); + /* Keep U-Boot payload */ + . = ALIGN(8); + KEEP(*(.u_boot_bin.*)); }
. = ALIGN(4096); diff --git a/arch/x86/lib/reloc_x86_64.c b/arch/x86/lib/reloc_x86_64.c new file mode 100644 index 0000000..70a2b2a --- /dev/null +++ b/arch/x86/lib/reloc_x86_64.c @@ -0,0 +1,90 @@ +/* reloc_x86_64.c - position independent x86_64 ELF shared object relocator + Copyright (C) 1999 Hewlett-Packard Co. + Contributed by David Mosberger davidm@hpl.hp.com. + Copyright (C) 2005 Intel Co. + Contributed by Fenghua Yu fenghua.yu@intel.com. + + All rights reserved. + + Redistribution and use in source and binary forms, with or without + modification, are permitted provided that the following conditions + are met: + + * Redistributions of source code must retain the above copyright + notice, this list of conditions and the following disclaimer. + * Redistributions in binary form must reproduce the above + copyright notice, this list of conditions and the following + disclaimer in the documentation and/or other materials + provided with the distribution. + * Neither the name of Hewlett-Packard Co. nor the names of its + contributors may be used to endorse or promote products derived + from this software without specific prior written permission. + + THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND + CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, + INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS + BE LIABLE FOR ANYDIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, + OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, + PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR + PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY + THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR + TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF + THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + SUCH DAMAGE. +*/ + +#include <common.h> +#include <efi.h> +#include <elf.h> +#include <asm/elf.h> + +efi_status_t _relocate(long ldbase, Elf64_Dyn *dyn, efi_handle_t image, + struct efi_system_table *systab) +{ + long relsz = 0, relent = 0; + struct elf64_rel *rel = 0; + unsigned long *addr; + int i; + + for (i = 0; dyn[i].d_tag != DT_NULL; ++i) { + switch (dyn[i].d_tag) { + case DT_RELA: + rel = (struct elf64_rel *) + ((unsigned long)dyn[i].d_un.d_ptr + ldbase); + break; + case DT_RELASZ: + relsz = dyn[i].d_un.d_val; + break; + case DT_RELAENT: + relent = dyn[i].d_un.d_val; + break; + default: + break; + } + } + + if (!rel && relent == 0) + return EFI_SUCCESS; + + if (!rel || relent == 0) + return EFI_LOAD_ERROR; + + while (relsz > 0) { + /* apply the relocs */ + switch (ELF64_R_TYPE(rel->r_info)) { + case R_X86_64_NONE: + break; + case R_X86_64_RELATIVE: + addr = (unsigned long *)(ldbase + rel->r_offset); + *addr += ldbase; + break; + default: + break; + } + rel = (struct elf64_rel *)((char *)rel + relent); + relsz -= relent; + } + return EFI_SUCCESS; +}
Some files are missing this declaration. Add it to avoid build errors when we actually need the declaration.
arch/x86/cpu/ivybridge/bd82x6x.c | 2 ++ arch/x86/cpu/ivybridge/gma.c | 2 ++ arch/x86/cpu/ivybridge/lpc.c | 2 ++ arch/x86/cpu/ivybridge/model_206ax.c | 2 ++ arch/x86/cpu/ivybridge/northbridge.c | 2 ++ 5 files changed, 10 insertions(+)
diff --git a/arch/x86/cpu/ivybridge/bd82x6x.c b/arch/x86/cpu/ivybridge/bd82x6x.c index 5b58d6c..3c5e159 100644 --- a/arch/x86/cpu/ivybridge/bd82x6x.c +++ b/arch/x86/cpu/ivybridge/bd82x6x.c @@ -21,6 +21,8 @@ #include <asm/arch/pch.h> #include <asm/arch/sandybridge.h>
+DECLARE_GLOBAL_DATA_PTR; + #define GPIO_BASE 0x48 #define BIOS_CTRL 0xdc
diff --git a/arch/x86/cpu/ivybridge/gma.c b/arch/x86/cpu/ivybridge/gma.c index 37e2e6e..59866bd 100644 --- a/arch/x86/cpu/ivybridge/gma.c +++ b/arch/x86/cpu/ivybridge/gma.c @@ -19,6 +19,8 @@ #include <asm/arch/pch.h> #include <asm/arch/sandybridge.h>
+DECLARE_GLOBAL_DATA_PTR; + struct gt_powermeter { u16 reg; u32 value; diff --git a/arch/x86/cpu/ivybridge/lpc.c b/arch/x86/cpu/ivybridge/lpc.c index 4e0be2a..0b4343a 100644 --- a/arch/x86/cpu/ivybridge/lpc.c +++ b/arch/x86/cpu/ivybridge/lpc.c @@ -20,6 +20,8 @@ #include <asm/pci.h> #include <asm/arch/pch.h>
+DECLARE_GLOBAL_DATA_PTR; + #define NMI_OFF 0
#define ENABLE_ACPI_MODE_IN_COREBOOT 0 diff --git a/arch/x86/cpu/ivybridge/model_206ax.c b/arch/x86/cpu/ivybridge/model_206ax.c index 38e244b..ae7c540 100644 --- a/arch/x86/cpu/ivybridge/model_206ax.c +++ b/arch/x86/cpu/ivybridge/model_206ax.c @@ -23,6 +23,8 @@ #include <asm/arch/bd82x6x.h> #include <asm/arch/model_206ax.h>
+DECLARE_GLOBAL_DATA_PTR; + static void enable_vmx(void) { struct cpuid_result regs; diff --git a/arch/x86/cpu/ivybridge/northbridge.c b/arch/x86/cpu/ivybridge/northbridge.c index 491f289..94f31c4 100644 --- a/arch/x86/cpu/ivybridge/northbridge.c +++ b/arch/x86/cpu/ivybridge/northbridge.c @@ -19,6 +19,8 @@ #include <asm/arch/model_206ax.h> #include <asm/arch/sandybridge.h>
+DECLARE_GLOBAL_DATA_PTR; + int bridge_silicon_revision(struct udevice *dev) { struct cpuid_result result;
But I think this is not needed since gma.c has been dropped due to DM video conversion.
#define NMI_OFF 0
int bridge_silicon_revision(struct udevice *dev) { struct cpuid_result result; --
Regards, Bin
This gives a build warning on 64-bit x86. Fix it.
drivers/i2c/intel_i2c.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/intel_i2c.c b/drivers/i2c/intel_i2c.c index a0182dc..550a728 100644 --- a/drivers/i2c/intel_i2c.c +++ b/drivers/i2c/intel_i2c.c @@ -248,11 +248,11 @@ static int intel_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) static int intel_i2c_probe(struct udevice *dev) { struct intel_i2c *priv = dev_get_priv(dev); - u32 base; + ulong base;
/* Save base address from PCI BAR */ - priv->base = (u32)dm_pci_map_bar(dev, PCI_BASE_ADDRESS_4, - PCI_REGION_IO); + priv->base = (ulong)dm_pci_map_bar(dev, PCI_BASE_ADDRESS_4, + PCI_REGION_IO); base = priv->base;
/* Set SMBus enable. */
Hello Simon,
Am 26.09.2016 um 05:33 schrieb Simon Glass:
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
- u32 base;
ulong base;
PCI_REGION_IO);
PCI_REGION_IO);
base = priv->base;
We don't have a way of adjusting these at present so it is best to refuse to export these functions. This can be implemented later if the API is required.
include/_exports.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/_exports.h b/include/_exports.h index 11beeb2..0b30c9e 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -13,7 +13,7 @@ EXPORT_FUNC(putc, void, putc, const char) EXPORT_FUNC(puts, void, puts, const char *) EXPORT_FUNC(printf, int, printf, const char*, ...) -#if defined(CONFIG_X86) || defined(CONFIG_PPC) +#if (defined(CONFIG_X86) && !defined(CONFIG_X86_64)) || defined(CONFIG_PPC) EXPORT_FUNC(irq_install_handler, void, install_hdlr, int, interrupt_handler_t, void*)
Add various debug() messages in places where errors occur. This aids with debugging.
arch/x86/cpu/ivybridge/cpu.c | 4 +++- arch/x86/cpu/ivybridge/sdram.c | 36 +++++++++++++++++++++++++++--------- 2 files changed, 30 insertions(+), 10 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/cpu.c b/arch/x86/cpu/ivybridge/cpu.c index 85e361a..9d7c21d 100644 --- a/arch/x86/cpu/ivybridge/cpu.c +++ b/arch/x86/cpu/ivybridge/cpu.c @@ -169,8 +169,10 @@ int print_cpuinfo(void)
/* Enable SPD ROMs and DDR-III DRAM */ ret = uclass_first_device_err(UCLASS_I2C, &dev); - if (ret) + if (ret) { + debug("%s: Failed to get I2C\n", __func__); return ret; + }
/* Prepare USB controller early in S3 resume */ if (boot_mode == PEI_BOOT_RESUME) { diff --git a/arch/x86/cpu/ivybridge/sdram.c b/arch/x86/cpu/ivybridge/sdram.c index e0b06b5..eef6d78 100644 --- a/arch/x86/cpu/ivybridge/sdram.c +++ b/arch/x86/cpu/ivybridge/sdram.c @@ -207,8 +207,10 @@ static int copy_spd(struct udevice *dev, struct pei_data *peid) int ret;
ret = mrc_locate_spd(dev, sizeof(peid->spd_data[0]), &data); - if (ret) + if (ret) { + debug("%s: Could not locate SPD\n", __func__); return ret; + }
memcpy(peid->spd_data[0], data, sizeof(peid->spd_data[0]));
@@ -460,18 +462,26 @@ int dram_init(void)
/* We need the pinctrl set up early */ ret = syscon_get_by_driver_data(X86_SYSCON_PINCONF, &dev); - if (ret) + if (ret) { + debug("%s: Could not get pinconf\n", __func__); return ret; + }
ret = uclass_first_device_err(UCLASS_NORTHBRIDGE, &dev); - if (ret) + if (ret) { + debug("%s: Could not get northbridge\n", __func__); return ret; + } ret = syscon_get_by_driver_data(X86_SYSCON_ME, &me_dev); - if (ret) + if (ret) { + debug("%s: Could not get ME\n", __func__); return ret; + } ret = copy_spd(dev, pei_data); - if (ret) + if (ret) { + debug("%s: Could not get SPD\n", __func__); return ret; + } pei_data->boot_mode = gd->arch.pei_boot_mode; debug("Boot mode %d\n", gd->arch.pei_boot_mode); debug("mrc_input %p\n", pei_data->mrc_input); @@ -498,19 +508,27 @@ int dram_init(void)
/* Wait for ME to be ready */ ret = intel_early_me_init(me_dev); - if (ret) + if (ret) { + debug("%s: Could not init ME\n", __func__); return ret; + } ret = intel_early_me_uma_size(me_dev); - if (ret < 0) + if (ret < 0) { + debug("%s: Could not get UMA size\n", __func__); return ret; + }
ret = mrc_common_init(dev, pei_data, false); - if (ret) + if (ret) { + debug("%s: mrc_common_init() failed\n", __func__); return ret; + }
ret = sdram_find(dev); - if (ret) + if (ret) { + debug("%s: sdram_find() failed\n", __func__); return ret; + } gd->ram_size = gd->arch.meminfo.total_32bit_memory;
debug("MRC output data length %#x at %p\n", pei_data->mrc_output_len,
Hi Simon,
if (ret)
if (ret) {
} /* Prepare USB controller early in S3 resume */ if (boot_mode == PEI_BOOT_RESUME) {
if (ret)
if (ret) {
} memcpy(peid->spd_data[0], data, sizeof(peid->spd_data[0]));
if (ret)
if (ret) {
} ret = uclass_first_device_err(UCLASS_NORTHBRIDGE, &dev);
if (ret)
if (ret) {
if (ret)
if (ret) {
if (ret)
if (ret) {
if (ret)
if (ret) {
if (ret < 0)
if (ret < 0) {
} ret = mrc_common_init(dev, pei_data, false);
if (ret)
if (ret) {
} ret = sdram_find(dev);
if (ret)
if (ret) {
} gd->ram_size = gd->arch.meminfo.total_32bit_memory; debug("MRC output data length %#x at %p\n", pei_data->mrc_output_len,
How about output the return value as well?
Regards, Bin
Fix a few types that causes warnings on 64-bit machines.
arch/x86/cpu/ivybridge/gma.c | 2 +- arch/x86/cpu/ivybridge/sata.c | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/gma.c b/arch/x86/cpu/ivybridge/gma.c index 59866bd..cf0c91d 100644 --- a/arch/x86/cpu/ivybridge/gma.c +++ b/arch/x86/cpu/ivybridge/gma.c @@ -831,7 +831,7 @@ int gma_func0_init(struct udevice *dev) mtrr_add_request(MTRR_TYPE_WRCOMB, base, 256 << 20); mtrr_commit(true);
- gtt_bar = (void *)dm_pci_read_bar32(dev, 0); + gtt_bar = (void *)(ulong)dm_pci_read_bar32(dev, 0); debug("GT bar %p\n", gtt_bar); ret = gma_pm_init_pre_vbios(gtt_bar, rev); if (ret) diff --git a/arch/x86/cpu/ivybridge/sata.c b/arch/x86/cpu/ivybridge/sata.c index 1ce8195..bf11d48 100644 --- a/arch/x86/cpu/ivybridge/sata.c +++ b/arch/x86/cpu/ivybridge/sata.c @@ -54,7 +54,7 @@ static void bd82x6x_sata_init(struct udevice *dev, struct udevice *pch)
mode = fdt_getprop(blob, node, "intel,sata-mode", NULL); if (!mode || !strcmp(mode, "ahci")) { - u32 abar; + ulong abar;
debug("SATA: Controller in AHCI mode\n");
@@ -73,7 +73,7 @@ static void bd82x6x_sata_init(struct udevice *dev, struct udevice *pch)
/* Initialize AHCI memory-mapped space */ abar = dm_pci_read_bar32(dev, 5); - debug("ABAR: %08X\n", abar); + debug("ABAR: %08lx\n", abar); /* CAP (HBA Capabilities) : enable power management */ reg32 = readl(abar + 0x00); reg32 |= 0x0c006000; /* set PSC+SSC+SALP+SSS */
Hi Simon,
u32 abar;
ulong abar; debug("SATA: Controller in AHCI mode\n");
This patch does not apply due to DM video conversion on Ivybridge.
Regards, Bin
At present pch_power_options() has the arguments to writel() around the wrong way. Fix this and update it to compile on 64-bit machines.
arch/x86/cpu/ivybridge/lpc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/lpc.c b/arch/x86/cpu/ivybridge/lpc.c index 0b4343a..c564713 100644 --- a/arch/x86/cpu/ivybridge/lpc.c +++ b/arch/x86/cpu/ivybridge/lpc.c @@ -215,10 +215,10 @@ static int pch_power_options(struct udevice *pch) dm_pci_read_config16(pch, 0x40, &pmbase); pmbase &= 0xfffe;
- writel(pmbase + GPE0_EN, fdtdec_get_int(blob, node, - "intel,gpe0-enable", 0)); - writew(pmbase + ALT_GP_SMI_EN, fdtdec_get_int(blob, node, - "intel,alt-gp-smi-enable", 0)); + writel(fdtdec_get_int(blob, node, "intel,gpe0-enable", 0), + (ulong)pmbase + GPE0_EN); + writew(fdtdec_get_int(blob, node, "intel,alt-gp-smi-enable", 0), + (ulong)pmbase + ALT_GP_SMI_EN);
/* Set up power management block and determine sleep mode */ reg32 = inl(pmbase + 0x04); /* PM1_CNT */
Fix the hex case and remove unused brackets. Use -0U instead of ~0UL to allow compilation on 64-bit machines.
diff --git a/arch/x86/cpu/ivybridge/lpc.c b/arch/x86/cpu/ivybridge/lpc.c index c564713..aef1206 100644 --- a/arch/x86/cpu/ivybridge/lpc.c +++ b/arch/x86/cpu/ivybridge/lpc.c @@ -357,10 +357,10 @@ static void enable_clock_gating(struct udevice *pch) reg16 |= (1 << 2) | (1 << 11); dm_pci_write_config16(pch, GEN_PMCON_1, reg16);
- pch_iobp_update(pch, 0xEB007F07, ~0UL, (1 << 31)); - pch_iobp_update(pch, 0xEB004000, ~0UL, (1 << 7)); - pch_iobp_update(pch, 0xEC007F07, ~0UL, (1 << 31)); - pch_iobp_update(pch, 0xEC004000, ~0UL, (1 << 7)); + pch_iobp_update(pch, 0xeb007f07, ~0U, 1 << 31); + pch_iobp_update(pch, 0xeb004000, ~0U, 1 << 7); + pch_iobp_update(pch, 0xec007f07, ~0U, 1 << 31); + pch_iobp_update(pch, 0xec004000, ~0U, 1 << 7);
reg32 = readl(RCB_REG(CG)); reg32 |= (1 << 31);
Hi Simon,
Should be: ~0U
pch_iobp_update(pch, 0xec004000, ~0U, 1 << 7); reg32 = readl(RCB_REG(CG)); reg32 |= (1 << 31);
Hi Simon,
Should be: ~0U
Fixed this, and
We almost always need the serial port before relocation, so mark it as such. This will ensure that it appears in the device tree for SPL, if used.
arch/x86/dts/serial.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/x86/dts/serial.dtsi b/arch/x86/dts/serial.dtsi index 54c3faf..22f7b54 100644 --- a/arch/x86/dts/serial.dtsi +++ b/arch/x86/dts/serial.dtsi @@ -1,5 +1,6 @@ / { serial: serial { + u-boot,dm-pre-reloc; compatible = "ns16550"; reg = <0x3f8 8>; reg-shift = <0>;
Hi Simon,
The ns16550 driver already has the pre-relocation flag, why is this still needed?
Regards, Bin
Hi Bin,
On 10 October 2016 at 21:16, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Without this, it will not appear in the SPL device tree (fdtgrep will drop it). So we need it here.
Fix a cast in get_next_hob() that causes warnings on 64-bit machines.
arch/x86/include/asm/fsp/fsp_hob.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/include/asm/fsp/fsp_hob.h b/arch/x86/include/asm/fsp/fsp_hob.h index 3fb3546..4a82f63 100644 --- a/arch/x86/include/asm/fsp/fsp_hob.h +++ b/arch/x86/include/asm/fsp/fsp_hob.h @@ -139,7 +139,7 @@ struct hob_guid { */ static inline const struct hob_header *get_next_hob(const struct hob_header *hdr) { - return (const struct hob_header *)((u32)hdr + hdr->len); + return (const struct hob_header *)((uintptr_t)hdr + hdr->len); }
Hi Simon,
What about get_guid_hob_data() in the same file? I think it will cause building warning too.
Regards, Bin
Drop init_bd_struct_r() which is no-longer used. Also drop the declaration for init_func_spi() since this is now handled by generic board init.
arch/x86/include/asm/init_helpers.h | 2 -- arch/x86/lib/init_helpers.c | 10 ---------- 2 files changed, 12 deletions(-)
diff --git a/arch/x86/include/asm/init_helpers.h b/arch/x86/include/asm/init_helpers.h index c689a63..ef05ac4 100644 --- a/arch/x86/include/asm/init_helpers.h +++ b/arch/x86/include/asm/init_helpers.h @@ -9,7 +9,5 @@ #define _INIT_HELPERS_H_
int init_cache_f_r(void); -int init_bd_struct_r(void); -int init_func_spi(void);
#endif /* !_INIT_HELPERS_H_ */ diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index bac671d..2a186fc 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -30,13 +30,3 @@ int init_cache_f_r(void) /* Initialise the CPU cache(s) */ return init_cache(); } - -bd_t bd_data; - -int init_bd_struct_r(void) -{ - gd->bd = &bd_data; - memset(gd->bd, 0, sizeof(bd_t)); - - return 0; -}
Fix various compiler warnings in the x86 library code.
arch/x86/lib/bios.c | 4 ++-- arch/x86/lib/pinctrl_ich6.c | 2 +- arch/x86/lib/pirq_routing.c | 4 ++-- arch/x86/lib/sfi.c | 4 ++-- arch/x86/lib/zimage.c | 2 +- 5 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/x86/lib/bios.c b/arch/x86/lib/bios.c index 9324bdb..66d7629 100644 --- a/arch/x86/lib/bios.c +++ b/arch/x86/lib/bios.c @@ -157,7 +157,7 @@ static void setup_realmode_idt(void) for (i = 0; i < 256; i++) { idts[i].cs = 0; idts[i].offset = 0x1000 + (i * __idt_handler_size); - write_idt_stub((void *)((u32)idts[i].offset), i); + write_idt_stub((void *)((ulong)idts[i].offset), i); }
/* @@ -227,7 +227,7 @@ static void vbe_set_graphics(int vesa_mode, struct vbe_mode_info *mode_info) mode_info->video_mode = (1 << 14) | vesa_mode; vbe_get_mode_info(mode_info);
- framebuffer = (unsigned char *)mode_info->vesa.phys_base_ptr; + framebuffer = (unsigned char *)(ulong)mode_info->vesa.phys_base_ptr; debug("VBE: resolution: %dx%d@%d\n", le16_to_cpu(mode_info->vesa.x_resolution), le16_to_cpu(mode_info->vesa.y_resolution), diff --git a/arch/x86/lib/pinctrl_ich6.c b/arch/x86/lib/pinctrl_ich6.c index 3f94cdf..fb2d294 100644 --- a/arch/x86/lib/pinctrl_ich6.c +++ b/arch/x86/lib/pinctrl_ich6.c @@ -104,7 +104,7 @@ static int ich6_pinctrl_cfg_pin(s32 gpiobase, s32 iobase, int pin_node)
/* if iobase is present, let's configure the pad */ if (iobase != -1) { - int iobase_addr; + ulong iobase_addr;
/* * The offset for the same pin for the IOBASE and GPIOBASE are diff --git a/arch/x86/lib/pirq_routing.c b/arch/x86/lib/pirq_routing.c index a93d355..c98526d 100644 --- a/arch/x86/lib/pirq_routing.c +++ b/arch/x86/lib/pirq_routing.c @@ -114,14 +114,14 @@ u32 copy_pirq_routing_table(u32 addr, struct irq_routing_table *rt) addr = ALIGN(addr, 16);
debug("Copying Interrupt Routing Table to 0x%x\n", addr); - memcpy((void *)addr, rt, rt->size); + memcpy((void *)(uintptr_t)addr, rt, rt->size);
/* * We do the sanity check here against the copied table after memcpy, * as something might go wrong after the memcpy, which is normally * due to the F segment decode is not turned on to systeam RAM. */ - rom_rt = (struct irq_routing_table *)addr; + rom_rt = (struct irq_routing_table *)(uintptr_t)addr; if (rom_rt->signature != PIRQ_SIGNATURE || rom_rt->version != PIRQ_VERSION || rom_rt->size % 16) { printf("Interrupt Routing Table not valid\n"); diff --git a/arch/x86/lib/sfi.c b/arch/x86/lib/sfi.c index 9564853..507e037 100644 --- a/arch/x86/lib/sfi.c +++ b/arch/x86/lib/sfi.c @@ -38,14 +38,14 @@ static void *get_entry_start(struct table_info *tab) tab->table[tab->count] = tab->entry_start; tab->entry_start += sizeof(struct sfi_table_header);
- return (void *)tab->entry_start; + return (void *)(uintptr_t)tab->entry_start; }
static void finish_table(struct table_info *tab, const char *sig, void *entry) { struct sfi_table_header *hdr;
- hdr = (struct sfi_table_header *)(tab->base + tab->ptr); + hdr = (struct sfi_table_header *)(uintptr_t)(tab->base + tab->ptr); strcpy(hdr->sig, sig); hdr->len = sizeof(*hdr) + ((ulong)entry - tab->entry_start); hdr->rev = 1; diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index 1b33c77..b6b0f2b 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -165,7 +165,7 @@ struct boot_params *load_zimage(char *image, unsigned long kernel_size, * A very old kernel MUST have its real-mode code * loaded at 0x90000 */ - if ((u32)setup_base != 0x90000) { + if ((ulong)setup_base != 0x90000) { /* Copy the real-mode kernel */ memmove((void *)0x90000, setup_base, setup_size);
Hi Simon,
write_idt_stub((void *)((ulong)idts[i].offset), i); } /*
int iobase_addr;
ulong iobase_addr; /* * The offset for the same pin for the IOBASE and GPIOBASE are
memcpy((void *)(uintptr_t)addr, rt, rt->size); /* * We do the sanity check here against the copied table after memcpy, * as something might go wrong after the memcpy, which is normally * due to the F segment decode is not turned on to systeam RAM. */
Can the above 3 changes merged into patch#23: x86: Use unsigned long for address in table generation, since they are all table related changes?
Regards, Bin
This should return normal errors, not device-tree errors. Fix it.
arch/x86/lib/mrccache.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/x86/lib/mrccache.c b/arch/x86/lib/mrccache.c index 67bace4..eca88ac 100644 --- a/arch/x86/lib/mrccache.c +++ b/arch/x86/lib/mrccache.c @@ -198,11 +198,13 @@ int mrccache_get_region(struct udevice **devp, struct mrc_region *entry)
/* Find the flash chip within the SPI controller node */ node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); - if (node < 0) + if (node < 0) { + debug("%s: Cannot find SPI flash\n", __func__); return -ENOENT; + }
if (fdtdec_get_int_array(blob, node, "memory-map", reg, 2)) - return -FDT_ERR_NOTFOUND; + return -EINVAL; entry->base = reg[0];
/* Find the place where we put the MRC cache */ @@ -211,7 +213,7 @@ int mrccache_get_region(struct udevice **devp, struct mrc_region *entry) return -EPERM;
if (fdtdec_get_int_array(blob, mrc_node, "reg", reg, 2)) - return -FDT_ERR_NOTFOUND; + return -EINVAL; entry->offset = reg[0]; entry->length = reg[1];
if (node < 0)
if (node < 0) {
} if (fdtdec_get_int_array(blob, node, "memory-map", reg, 2))
return -EINVAL; entry->base = reg[0]; /* Find the place where we put the MRC cache */
if (node < 0)
if (node < 0) {
Add a new CONFIG_X86_64 option which will eventually cause U-Boot to be built as a 64-bit application, with SPL doing the 16/32-bit init.
arch/x86/Kconfig | 46 ++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 46 insertions(+)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 5193ee7..0505f97 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -5,6 +5,52 @@ config SYS_ARCH default "x86"
choice + prompt "Run U-Boot in 32/64-bit mode" + default X86_RUN_32BIT + help + U-Boot can be built as a 32-bit binary which runs in 32-bit mode + even on 64-bit machines. In this case SPL is not used, and U-Boot + runs directly from the reset vector (via 16-bit start-up). + + Alternatively it can be run as a 64-bit binary, thus requiring a + 64-bit machine. In this case SPL runs in 32-bit mode (via 16-bit + start-up) then jumps to U-Boot in 64-bit mode. + + For now, 32-bit mode is recommended, as 64-bit is still + experimental and is missing a lot of features. + +config X86_RUN_32BIT + bool "32-bit" + help + Build U-Boot as a 32-bit binary with no SPL. This is the currently + supported normal setup. U-Boot will stay in 32-bit mode even on + 64-bit machines. When booting a 64-bit kernel, U-Boot will switch + to 64-bit just before starting the kernel. Only the bottom 4GB of + memory can be accessed through normal means, although + arch_phys_memset() can be used for basic access to other memory. + +config X86_RUN_64BIT + bool "64-bit" + select X86_64 + select SUPPORT_SPL + select SPL + select SPL_SEPARATE_BSS + help + Build U-Boot as a 64-bit binary with a 32-bit SPL. This is + experimental and many features are missing. U-Boot SPL starts up, + runs through the 16-bit and 32-bit init, then switches to 64-bit + mode and jumps to U-Boot proper. + +endchoice + +config X86_64 + bool + +config SPL_X86_64 + bool + depends on SPL + +choice prompt "Mainboard vendor" default VENDOR_EMULATION
At present all 16/32-bit init is controlled by CONFIG_X86_RESET_VECTOR. If this is enabled, then U-Boot is the 'first' boot loader and handles execution from the reset vector through to U-Boot's command prompt. If it is not enabled then U-Boot starts at the 32-bit entry and skips most of its init, assuming that the previous boot loader has done this already.
With the move to suport 64-bit operation, we have more cases to consider. The 16-bit and 32-bit init may be in SPL rather than in U-Boot proper.
Add Kconfig options which control the location of the 16-bit and the 32-bit init. These are not intended to be user-setting except for experimentation. Their values should be determined by whether 64-bit U-Boot is used.
arch/x86/Kconfig | 39 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 0505f97..24d8f4f 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -135,6 +135,45 @@ config X86_RESET_VECTOR bool default n
+# The following options control where the 16-bit and 32-bit init lies +# If SPL is enabled then it normally holds this init code, and U-Boot proper +# is normally a 64-bit build. +# +# The 16-bit init refers to the reset vector and the small amount of code to +# get the processor into 32-bit mode. It may be in SPL or in U-Boot proper, +# or missing altogether if U-Boot is started from EFI or coreboot. +# +# The 32-bit init refers to processor init, running binary blobs including +# FSP, setting up interrupts and anything else that needs to be done in +# 32-bit code. It is normally in the same place as 32-bit init. +config X86_16BIT_INIT + bool + depends on X86_RESET_VECTOR + default y if X86_RESET_VECTOR && !SPL + help + This is enabled when 16-bit init is in U-Boot proper + +config SPL_X86_16BIT_INIT + bool + depends on X86_RESET_VECTOR + default y if X86_RESET_VECTOR && SPL + help + This is enabled when 16-bit init is in SPL + +config X86_32BIT_INIT + bool + depends on X86_RESET_VECTOR + default y if X86_RESET_VECTOR && !SPL + help + This is enabled when 32-bit init is in U-Boot proper + +config SPL_X86_32BIT_INIT + bool + depends on X86_RESET_VECTOR + default y if X86_RESET_VECTOR && SPL + help + This is enabled when 32-bit init is in SPL + config RESET_SEG_START hex depends on X86_RESET_VECTOR
Use this new option to control the location of 16-bit init. This will allow us to place this in SPL if needed.
Makefile | 7 ++++--- arch/x86/Makefile | 6 ++---- arch/x86/cpu/Makefile | 2 +- arch/x86/cpu/u-boot.lds | 2 +- 4 files changed, 8 insertions(+), 9 deletions(-)
diff --git a/Makefile b/Makefile index 64aab44..cc39128 100644 --- a/Makefile +++ b/Makefile @@ -863,7 +863,7 @@ u-boot.hex u-boot.srec: u-boot FORCE $(call if_changed,objcopy)
OBJCOPYFLAGS_u-boot-nodtb.bin := -O binary \ - $(if $(CONFIG_X86_RESET_VECTOR),-R .start16 -R .resetvec) + $(if $(CONFIG_X86_16BIT_INIT),-R .start16 -R .resetvec)
binary_size_check: u-boot-nodtb.bin FORCE @file_size=$(shell wc -c u-boot-nodtb.bin | awk '{print $$1}') ; \ @@ -1072,8 +1072,9 @@ quiet_cmd_ldr = LD $@ cmd_ldr = $(LD) $(LDFLAGS_$(@F)) \ $(filter-out FORCE,$^) -o $@
-u-boot.rom: u-boot-x86-16bit.bin u-boot.bin FORCE \ - $(if $(CONFIG_HAVE_REFCODE),refcode.bin) +u-boot.rom: u-boot-x86-16bit.bin u-boot.bin \ + $(if $(CONFIG_SPL_X86_16BIT_INIT),spl/u-boot-spl.bin) \ + $(if $(CONFIG_HAVE_REFCODE),refcode.bin) FORCE $(call if_changed,binman)
OBJCOPYFLAGS_u-boot-x86-16bit.bin := -O binary -j .start16 -j .resetvec diff --git a/arch/x86/Makefile b/arch/x86/Makefile index d104a49..dd0e22f 100644 --- a/arch/x86/Makefile +++ b/arch/x86/Makefile @@ -5,10 +5,8 @@ ifeq ($(CONFIG_EFI_APP),) head-y := arch/x86/cpu/start.o endif -ifeq ($(CONFIG_SPL_BUILD),y) -head-y += arch/x86/cpu/start16.o -head-y += arch/x86/cpu/resetvec.o -endif +head-$(CONFIG_$(SPL_)X86_16BIT_INIT) += arch/x86/cpu/start16.o +head-$(CONFIG_$(SPL_)X86_16BIT_INIT) += arch/x86/cpu/resetvec.o
libs-y += arch/x86/cpu/ libs-y += arch/x86/lib/ diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index f5b8c9e..fd81310 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -9,7 +9,7 @@ #
extra-y = start.o -obj-$(CONFIG_X86_RESET_VECTOR) += resetvec.o start16.o +extra-$(CONFIG_$(SPL_)X86_16BIT_INIT) += resetvec.o start16.o obj-y += interrupts.o cpu.o cpu_x86.o call64.o setjmp.o
AFLAGS_REMOVE_call32.o := -mregparm=3 \ diff --git a/arch/x86/cpu/u-boot.lds b/arch/x86/cpu/u-boot.lds index cca536b..186718d 100644 --- a/arch/x86/cpu/u-boot.lds +++ b/arch/x86/cpu/u-boot.lds @@ -103,7 +103,7 @@ SECTIONS /DISCARD/ : { *(.interp*) } /DISCARD/ : { *(.gnu*) }
-#ifdef CONFIG_X86_RESET_VECTOR +#ifdef CONFIG_X86_16BIT_INIT /* * The following expressions place the 16-bit Real-Mode code and * Reset Vector at the end of the Flash ROM
Use this new option to control the location of 32-bit init. This will allow us to place this in SPL if needed.
arch/x86/cpu/intel_common/Makefile | 10 ++++++---- arch/x86/lib/init_helpers.c | 2 +- 2 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index 804c539..1145e78 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -4,13 +4,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_HAVE_MRC) += car.o +ifdef CONFIG_HAVE_MRC +obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += car.o +obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += me_status.o +obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += report_platform.o +obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += mrc.o +endif obj-y += cpu.o obj-y += lpc.o -obj-$(CONFIG_HAVE_MRC) += me_status.o ifndef CONFIG_TARGET_EFI obj-y += microcode.o endif obj-y += pch.o -obj-$(CONFIG_HAVE_MRC) += report_platform.o -obj-$(CONFIG_HAVE_MRC) += mrc.o diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index 2a186fc..420393b 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -19,7 +19,7 @@ __weak ulong board_get_usable_ram_top(ulong total_size)
int init_cache_f_r(void) { -#if defined(CONFIG_X86_RESET_VECTOR) & !defined(CONFIG_HAVE_FSP) +#if CONFIG_IS_ENABLED(X86_32BIT_INIT) && !defined(CONFIG_HAVE_FSP) int ret;
ret = mtrr_commit(false);
Update the Makefile so that some 32-bit init can be built into SPL rather than U-Boot proper.
arch/x86/cpu/ivybridge/Makefile | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/Makefile b/arch/x86/cpu/ivybridge/Makefile index 9cdb07b..a853e45 100644 --- a/arch/x86/cpu/ivybridge/Makefile +++ b/arch/x86/cpu/ivybridge/Makefile @@ -7,13 +7,13 @@ ifdef CONFIG_HAVE_FSP obj-y += fsp_configs.o ivybridge.o else -obj-y += cpu.o +obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += cpu.o obj-y += early_me.o obj-y += gma.o obj-y += lpc.o obj-y += model_206ax.o obj-y += northbridge.o obj-y += sata.o -obj-y += sdram.o +obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += sdram.o endif obj-y += bd82x6x.o
Add code to start up U-Boot in 64-bit mode. It is fairly simple since we are running from RAM and SPL has done the low-level init.
arch/x86/Makefile | 5 +++++ arch/x86/cpu/Makefile | 4 ++++ arch/x86/cpu/start64.S | 39 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 48 insertions(+) create mode 100644 arch/x86/cpu/start64.S
diff --git a/arch/x86/Makefile b/arch/x86/Makefile index dd0e22f..4be1c35 100644 --- a/arch/x86/Makefile +++ b/arch/x86/Makefile @@ -3,8 +3,13 @@ #
ifeq ($(CONFIG_EFI_APP),) +ifdef CONFIG_$(SPL_)X86_64 +head-y := arch/x86/cpu/start64.o +else head-y := arch/x86/cpu/start.o endif +endif + head-$(CONFIG_$(SPL_)X86_16BIT_INIT) += arch/x86/cpu/start16.o head-$(CONFIG_$(SPL_)X86_16BIT_INIT) += arch/x86/cpu/resetvec.o
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index fd81310..97b26b0 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -8,7 +8,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifeq ($(CONFIG_$(SPL_)X86_64),y) +extra-y = start64.o +else extra-y = start.o +endif extra-$(CONFIG_$(SPL_)X86_16BIT_INIT) += resetvec.o start16.o obj-y += interrupts.o cpu.o cpu_x86.o call64.o setjmp.o
diff --git a/arch/x86/cpu/start64.S b/arch/x86/cpu/start64.S new file mode 100644 index 0000000..9eadc35 --- /dev/null +++ b/arch/x86/cpu/start64.S @@ -0,0 +1,39 @@ +/* + * 64-bit x86 Startup Code + * + * (C) Copyright 216 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <asm/global_data.h> +#include <asm/post.h> +#include <asm/processor.h> +#include <asm/processor-flags.h> +#include <generated/generic-asm-offsets.h> +#include <generated/asm-offsets.h> + +.section .text +.code64 +.globl _start +.type _start, @function +_start: + /* Set up memory using the existing stack */ + mov %rsp, %rdi + call board_init_f_alloc_reserve + mov %rax, %rsp + + call board_init_f_init_reserve + + callq board_init_f + callq board_init_f_r + + /* Should not return here */ + jmp . + + /* If the debug UART is being used, it is already set up by SPL */ + .globl board_debug_uart_init +board_debug_uart_init: + ret
Adjust the code so that 64-bit startup works. Since we don't need to do CAR changes in U-Boot proper anymore (they are done in SPL) we can simplify the flow and return normally from board_init_f().
common/board_f.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index e3179a1..28a63a6 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -767,7 +767,8 @@ static int setup_reloc(void) }
/* ARM calls relocate_code from its crt0.S */ -#if !defined(CONFIG_ARM) && !defined(CONFIG_SANDBOX) +#if !defined(CONFIG_ARM) && !defined(CONFIG_SANDBOX) && \ + !CONFIG_IS_ENABLED(X86_64)
static int jump_to_copy(void) { @@ -1045,7 +1046,8 @@ static init_fnc_t init_sequence_f[] = { #if defined(CONFIG_XTENSA) clear_bss, #endif -#if !defined(CONFIG_ARM) && !defined(CONFIG_SANDBOX) +#if !defined(CONFIG_ARM) && !defined(CONFIG_SANDBOX) && \ + !CONFIG_IS_ENABLED(X86_64) jump_to_copy, #endif NULL, @@ -1079,7 +1081,7 @@ void board_init_f(ulong boot_flags) hang();
#if !defined(CONFIG_ARM) && !defined(CONFIG_SANDBOX) && \ - !defined(CONFIG_EFI_APP) + !defined(CONFIG_EFI_APP) && !CONFIG_IS_ENABLED(X86_64) /* NOTREACHED - jump_to_copy() does not return */ hang(); #endif @@ -1103,8 +1105,10 @@ void board_init_f(ulong boot_flags) * NOTE: At present only x86 uses this route, but it is intended that * all archs will move to this when generic relocation is implemented. */ -static init_fnc_t init_sequence_f_r[] = { +static const init_fnc_t init_sequence_f_r[] = { +#if !CONFIG_IS_ENABLED(X86_64) init_cache_f_r, +#endif
NULL, };
Since 'gd' is just a normal variable on 64-bit x86, it is relocated by the time we get to board_init_r(). The old 'gd' variable is passed in as parameter to board_init_r(), presumably for this situation.
Assign it on 64-bit x86 so that gd points to the correct data.
Options to improve this: - Make gd a fixed register and remove the board_init_r() parameter - Make all archs use this board_init_r() parameter
common/board_r.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/board_r.c b/common/board_r.c index d959ad3..02800ca 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -974,6 +974,11 @@ init_fnc_t init_sequence_r[] = {
void board_init_r(gd_t *new_gd, ulong dest_addr) { + /* Set up the new global data pointer */ +#if CONFIG_IS_ENABLED(X86_64) + arch_setup_gd(new_gd); +#endif + #ifdef CONFIG_NEEDS_MANUAL_RELOC int i; #endif
The BSS region may overlap with relocations. If we clear BSS we will overwrite the start of the relocation area. This doesn't matter when running from SPI flash, since it is read-only. But when relocating 64-bit U-Boot from one place in RAM to another, relocation will fail because some of its relocations have been zeroed.
To fix this, put the ELF fixup call before the BSS clearing call.
common/board_f.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 28a63a6..a06578c 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -1040,8 +1040,8 @@ static init_fnc_t init_sequence_f[] = { setup_reloc, #if defined(CONFIG_X86) || defined(CONFIG_ARC) copy_uboot_to_ram, - clear_bss, do_elf_reloc_fixups, + clear_bss, #endif #if defined(CONFIG_XTENSA) clear_bss,
Move the core relocation code into a separate function so that the checking code can be used for 64-bit relocation also.
arch/x86/lib/relocate.c | 57 ++++++++++++++++++++++++++++--------------------- 1 file changed, 33 insertions(+), 24 deletions(-)
diff --git a/arch/x86/lib/relocate.c b/arch/x86/lib/relocate.c index 0d683bf..21cd1db 100644 --- a/arch/x86/lib/relocate.c +++ b/arch/x86/lib/relocate.c @@ -47,38 +47,18 @@ int clear_bss(void) return 0; }
-/* - * This function has more error checking than you might expect. Please see - * the commit message for more informaiton. - */ -int do_elf_reloc_fixups(void) +static void do_elf_reloc_fixups32(unsigned int text_base, uintptr_t size, + Elf32_Rel *re_src, Elf32_Rel *re_end) { - Elf32_Rel *re_src = (Elf32_Rel *)(&__rel_dyn_start); - Elf32_Rel *re_end = (Elf32_Rel *)(&__rel_dyn_end); - Elf32_Addr *offset_ptr_rom, *last_offset = NULL; Elf32_Addr *offset_ptr_ram; - unsigned int text_base = 0; - - /* The size of the region of u-boot that runs out of RAM. */ - uintptr_t size = (uintptr_t)&__bss_end - (uintptr_t)&__text_start; - - if (gd->flags & GD_FLG_SKIP_RELOC) - return 0; - if (re_src == re_end) - panic("No relocation data");
-#ifdef CONFIG_SYS_TEXT_BASE - text_base = CONFIG_SYS_TEXT_BASE; -#else - panic("No CONFIG_SYS_TEXT_BASE"); -#endif do { /* Get the location from the relocation entry */ - offset_ptr_rom = (Elf32_Addr *)re_src->r_offset; + offset_ptr_rom = (Elf32_Addr *)(uintptr_t)re_src->r_offset;
/* Check that the location of the relocation is in .text */ - if (offset_ptr_rom >= (Elf32_Addr *)text_base && + if (offset_ptr_rom >= (Elf32_Addr *)(uintptr_t)text_base && offset_ptr_rom > last_offset) {
/* Switch to the in-RAM version */ @@ -103,6 +83,35 @@ int do_elf_reloc_fixups(void) last_offset = offset_ptr_rom;
} while (++re_src < re_end); +} + +/* + * This function has more error checking than you might expect. Please see + * the commit message for more informaiton. + */ +int do_elf_reloc_fixups(void) +{ + void *re_src = (void *)(&__rel_dyn_start); + void *re_end = (void *)(&__rel_dyn_end); + uint text_base; + + /* The size of the region of u-boot that runs out of RAM. */ + uintptr_t size = (uintptr_t)&__bss_end - (uintptr_t)&__text_start; + + if (gd->flags & GD_FLG_SKIP_RELOC) + return 0; + if (re_src == re_end) { + printf("No relocation data %p %p", re_src, re_end); + while (1); + panic("No relocation data"); + } + +#ifdef CONFIG_SYS_TEXT_BASE + text_base = CONFIG_SYS_TEXT_BASE; +#else + panic("No CONFIG_SYS_TEXT_BASE"); +#endif + do_elf_reloc_fixups32(text_base, size, re_src, re_end);
return 0; }
Add a 64-bit relocation function. SPL loads U-Boot into RAM at a fixed address and runs it. U-Boot then relocates itself to the top of RAM using this relocation function.
arch/x86/lib/relocate.c | 45 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/arch/x86/lib/relocate.c b/arch/x86/lib/relocate.c index 21cd1db..bac2fb6 100644 --- a/arch/x86/lib/relocate.c +++ b/arch/x86/lib/relocate.c @@ -47,6 +47,46 @@ int clear_bss(void) return 0; }
+#if CONFIG_IS_ENABLED(X86_64) +static void do_elf_reloc_fixups64(unsigned int text_base, uintptr_t size, + Elf64_Rela *re_src, Elf64_Rela *re_end) +{ + Elf64_Addr *offset_ptr_rom, *last_offset = NULL; + Elf64_Addr *offset_ptr_ram; + + do { + /* Get the location from the relocation entry */ + offset_ptr_rom = (Elf64_Addr *)(uintptr_t)re_src->r_offset; + + /* Check that the location of the relocation is in .text */ + if (offset_ptr_rom >= (Elf64_Addr *)(uintptr_t)text_base && + offset_ptr_rom > last_offset) { + /* Switch to the in-RAM version */ + offset_ptr_ram = (Elf64_Addr *)((ulong)offset_ptr_rom + + gd->reloc_off); + + /* Check that the target points into .text */ + if (*offset_ptr_ram >= text_base && + *offset_ptr_ram <= text_base + size) { + *offset_ptr_ram = gd->reloc_off + + re_src->r_addend; + } else { + debug(" %p: %lx: rom reloc %lx, ram %p, value %lx, limit %" + PRIXPTR "\n", + re_src, (ulong)re_src->r_info, + (ulong)re_src->r_offset, offset_ptr_ram, + (ulong)*offset_ptr_ram, text_base + size); + } + } else { + debug(" %p: %lx: rom reloc %lx, last %p\n", re_src, + (ulong)re_src->r_info, (ulong)re_src->r_offset, + last_offset); + } + last_offset = offset_ptr_rom; + + } while (++re_src < re_end); +} +#else static void do_elf_reloc_fixups32(unsigned int text_base, uintptr_t size, Elf32_Rel *re_src, Elf32_Rel *re_end) { @@ -84,6 +124,7 @@ static void do_elf_reloc_fixups32(unsigned int text_base, uintptr_t size,
} while (++re_src < re_end); } +#endif
/* * This function has more error checking than you might expect. Please see @@ -111,7 +152,11 @@ int do_elf_reloc_fixups(void) #else panic("No CONFIG_SYS_TEXT_BASE"); #endif +#if CONFIG_IS_ENABLED(X86_64) + do_elf_reloc_fixups64(text_base, size, re_src, re_end); +#else do_elf_reloc_fixups32(text_base, size, re_src, re_end); +#endif
return 0; }
Addresses should not be cast to size_t. Use uintptr_t instead.
arch/x86/lib/relocate.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/lib/relocate.c b/arch/x86/lib/relocate.c index bac2fb6..ad47c7e 100644 --- a/arch/x86/lib/relocate.c +++ b/arch/x86/lib/relocate.c @@ -26,7 +26,7 @@ DECLARE_GLOBAL_DATA_PTR;
int copy_uboot_to_ram(void) { - size_t len = (size_t)&__data_end - (size_t)&__text_start; + size_t len = (uintptr_t)&__data_end - (uintptr_t)&__text_start;
if (gd->flags & GD_FLG_SKIP_RELOC) return 0; @@ -38,7 +38,7 @@ int copy_uboot_to_ram(void) int clear_bss(void) { ulong dst_addr = (ulong)&__bss_start + gd->reloc_off; - size_t len = (size_t)&__bss_end - (size_t)&__bss_start; + size_t len = (uintptr_t)&__bss_end - (uintptr_t)&__bss_start;
SPL needs to set up the machine ready for loading 64-bit U-Boot and jumping to it. Call the existing init routines in order to accomplish this.
arch/x86/include/asm/spl.h | 8 +++ arch/x86/lib/Makefile | 3 + arch/x86/lib/spl.c | 149 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 160 insertions(+) create mode 100644 arch/x86/include/asm/spl.h create mode 100644 arch/x86/lib/spl.c
diff --git a/arch/x86/include/asm/spl.h b/arch/x86/include/asm/spl.h new file mode 100644 index 0000000..a8bce98 --- /dev/null +++ b/arch/x86/include/asm/spl.h @@ -0,0 +1,8 @@ +/* + * Copyright (C) 2014 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + * + * This file is required for SPL to build, but is empty. + */ diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 1d9ebc0..1fa7f90 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -12,7 +12,9 @@ obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-y += cmd_boot.o obj-$(CONFIG_SEABIOS) += coreboot_table.o obj-$(CONFIG_EFI) += efi/ +ifndef CONFIG_SPL_BUILD obj-$(CONFIG_CMD_BOOTEFI_HELLO) += HelloWorld32.o +endif obj-y += e820.o obj-y += gcc.o obj-y += init_helpers.o @@ -39,6 +41,7 @@ endif obj-y += tables.o obj-$(CONFIG_CMD_ZBOOT) += zimage.o obj-$(CONFIG_HAVE_FSP) += fsp/ +obj-$(CONFIG_SPL_BUILD) += spl.o
extra-$(CONFIG_USE_PRIVATE_LIBGCC) += lib.a
diff --git a/arch/x86/lib/spl.c b/arch/x86/lib/spl.c new file mode 100644 index 0000000..61d085f --- /dev/null +++ b/arch/x86/lib/spl.c @@ -0,0 +1,149 @@ +/* + * Copyright (c) 2016 Google, Inc + * + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <debug_uart.h> +#include <spl.h> +#include <asm/cpu.h> +#include <asm/init_helpers.h> +#include <asm/mtrr.h> +#include <asm/processor.h> +#include <asm-generic/sections.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int x86_spl_init(void) +{ + /* + * TODO(sjg@chromium.org): We use this area of RAM for the stack + * and global_data in SPL. Once U-Boot starts up and releocates it + * is not needed. We could make this a CONFIG option or perhaps + * place it immediately below CONFIG_SYS_TEXT_BASE. + */ + char *ptr = (char *)0x110000; + int ret; + + debug("%s starting\n", __func__); + ret = spl_init(); + if (ret) { + debug("%s: spl_init() failed\n", __func__); + return ret; + } + preloader_console_init(); + + ret = arch_cpu_init(); + if (ret) { + debug("%s: arch_cpu_init() failed\n", __func__); + return ret; + } + ret = arch_cpu_init_dm(); + if (ret) { + debug("%s: arch_cpu_init_dm() failed\n", __func__); + return ret; + } + ret = print_cpuinfo(); + if (ret) { + debug("%s: print_cpuinfo() failed\n", __func__); + return ret; + } + ret = dram_init(); + if (ret) { + debug("%s: dram_init() failed\n", __func__); + return ret; + } + memset(&__bss_start, 0, (ulong)&__bss_end - (ulong)&__bss_start); + + /* TODO(sjg@chromium.org): Consider calling cpu_init_r() here */ + ret = interrupt_init(); + if (ret) { + debug("%s: interrupt_init() failed\n", __func__); + return ret; + } + + gd->new_gd = (struct global_data *)ptr + 0x100; + memcpy(gd->new_gd, gd, sizeof(*gd)); + arch_setup_gd(gd->new_gd); + gd->start_addr_sp = (ulong)ptr; + + /* Cache the SPI flash. Otherwise copying the code to RAM takes ages */ + ret = mtrr_add_request(MTRR_TYPE_WRBACK, + (1ULL << 32) - CONFIG_XIP_ROM_SIZE, + CONFIG_XIP_ROM_SIZE); + if (ret) { + debug("%s: SPI cache setup failed\n", __func__); + return ret; + } + + return 0; +} + +void board_init_f(ulong flags) +{ + int ret; + + ret = x86_spl_init(); + if (ret) { + debug("Error %d\n", ret); + hang(); + } + + /* Uninit CAR and jump to board_init_f_r() */ + board_init_f_r_trampoline(gd->start_addr_sp); +} + +void board_init_f_r(void) +{ + init_cache_f_r(); + gd->flags &= ~GD_FLG_SERIAL_READY; + debug("cache status %d\n", dcache_status()); + board_init_r(gd, 0); +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_BOARD; +} + +int spl_start_uboot(void) +{ + return 0; +} + +void spl_board_announce_boot_device(void) +{ + printf("SPI flash"); +} + +static int spl_board_load_image(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev) +{ + spl_image->size = CONFIG_SYS_MONITOR_LEN; + spl_image->entry_point = CONFIG_SYS_TEXT_BASE; + spl_image->load_addr = CONFIG_SYS_TEXT_BASE; + spl_image->os = IH_OS_U_BOOT; + spl_image->name = "U-Boot"; + + debug("Loading to %x\n", spl_image->load_addr); + + return 0; +} +SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_BOARD, spl_board_load_image); + +int spl_spi_load_image(void) +{ + return -EPERM; +} + +void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) +{ + int ret; + + printf("Jumping to 64-bit U-Boot: Note many features are missing\n"); + ret = cpu_jump_to_64bit_uboot(spl_image->entry_point); + debug("ret=%d\n", ret); + while (1); +}
Much of the cpu and interrupt code cannot be compiled on 64-bit x86. Move it into its own directory and build it only in 32-bit mode.
arch/x86/cpu/Makefile | 6 +- arch/x86/cpu/cpu.c | 504 ---------------------- arch/x86/cpu/i386/Makefile | 7 + arch/x86/cpu/i386/cpu.c | 534 ++++++++++++++++++++++++ arch/x86/cpu/{interrupts.c => i386/interrupt.c} | 4 - arch/x86/include/asm/mp.h | 3 + 6 files changed, 549 insertions(+), 509 deletions(-) create mode 100644 arch/x86/cpu/i386/Makefile create mode 100644 arch/x86/cpu/i386/cpu.c rename arch/x86/cpu/{interrupts.c => i386/interrupt.c} (99%)
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 97b26b0..41ad481 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -14,7 +14,7 @@ else extra-y = start.o endif extra-$(CONFIG_$(SPL_)X86_16BIT_INIT) += resetvec.o start16.o -obj-y += interrupts.o cpu.o cpu_x86.o call64.o setjmp.o +obj-y += cpu.o cpu_x86.o call64.o setjmp.o
AFLAGS_REMOVE_call32.o := -mregparm=3 \ $(if $(CONFIG_EFI_STUB_64BIT),-march=i386 -m32) @@ -37,3 +37,7 @@ obj-y += mtrr.o obj-$(CONFIG_PCI) += pci.o obj-$(CONFIG_SMP) += sipi_vector.o obj-y += turbo.o + +ifeq ($(CONFIG_$(SPL_)X86_64),) +obj-y += i386/ +endif diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 7c1d6de..8fa6953 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -43,55 +43,6 @@
-/* - * Constructor for a conventional segment GDT (or LDT) entry - * This is a macro so it can be used in initialisers - */ -#define GDT_ENTRY(flags, base, limit) \ - ((((base) & 0xff000000ULL) << (56-24)) | \ - (((flags) & 0x0000f0ffULL) << 40) | \ - (((limit) & 0x000f0000ULL) << (48-16)) | \ - (((base) & 0x00ffffffULL) << 16) | \ - (((limit) & 0x0000ffffULL))) - -struct gdt_ptr { - u16 len; - u32 ptr; -} __packed; - -struct cpu_device_id { - unsigned vendor; - unsigned device; -}; - -struct cpuinfo_x86 { - uint8_t x86; /* CPU family */ - uint8_t x86_vendor; /* CPU vendor */ - uint8_t x86_model; - uint8_t x86_mask; -}; - -/* - * List of cpu vendor strings along with their normalized - * id values. - */ -static const struct { - int vendor; - const char *name; -} x86_vendors[] = { - { X86_VENDOR_INTEL, "GenuineIntel", }, - { X86_VENDOR_CYRIX, "CyrixInstead", }, - { X86_VENDOR_AMD, "AuthenticAMD", }, - { X86_VENDOR_UMC, "UMC UMC UMC ", }, - { X86_VENDOR_NEXGEN, "NexGenDriven", }, - { X86_VENDOR_CENTAUR, "CentaurHauls", }, - { X86_VENDOR_RISE, "RiseRiseRise", }, - { X86_VENDOR_TRANSMETA, "GenuineTMx86", }, - { X86_VENDOR_TRANSMETA, "TransmetaCPU", }, - { X86_VENDOR_NSC, "Geode by NSC", }, - { X86_VENDOR_SIS, "SiS SiS SiS ", }, -}; - static const char *const x86_vendor_name[] = { [X86_VENDOR_INTEL] = "Intel", [X86_VENDOR_CYRIX] = "Cyrix", @@ -105,100 +56,6 @@ static const char *const x86_vendor_name[] = { [X86_VENDOR_SIS] = "SiS", };
-static void load_ds(u32 segment) -{ - asm volatile("movl %0, %%ds" : : "r" (segment * X86_GDT_ENTRY_SIZE)); -} - -static void load_es(u32 segment) -{ - asm volatile("movl %0, %%es" : : "r" (segment * X86_GDT_ENTRY_SIZE)); -} - -static void load_fs(u32 segment) -{ - asm volatile("movl %0, %%fs" : : "r" (segment * X86_GDT_ENTRY_SIZE)); -} - -static void load_gs(u32 segment) -{ - asm volatile("movl %0, %%gs" : : "r" (segment * X86_GDT_ENTRY_SIZE)); -} - -static void load_ss(u32 segment) -{ - asm volatile("movl %0, %%ss" : : "r" (segment * X86_GDT_ENTRY_SIZE)); -} - -static void load_gdt(const u64 *boot_gdt, u16 num_entries) -{ - struct gdt_ptr gdt; - - gdt.len = (num_entries * X86_GDT_ENTRY_SIZE) - 1; - gdt.ptr = (ulong)boot_gdt; - - asm volatile("lgdtl %0\n" : : "m" (gdt)); -} - -void arch_setup_gd(gd_t *new_gd) -{ - u64 *gdt_addr; - - gdt_addr = new_gd->arch.gdt; - - /* - * CS: code, read/execute, 4 GB, base 0 - * - * Some OS (like VxWorks) requires GDT entry 1 to be the 32-bit CS - */ - gdt_addr[X86_GDT_ENTRY_UNUSED] = GDT_ENTRY(0xc09b, 0, 0xfffff); - gdt_addr[X86_GDT_ENTRY_32BIT_CS] = GDT_ENTRY(0xc09b, 0, 0xfffff); - - /* DS: data, read/write, 4 GB, base 0 */ - gdt_addr[X86_GDT_ENTRY_32BIT_DS] = GDT_ENTRY(0xc093, 0, 0xfffff); - - /* FS: data, read/write, 4 GB, base (Global Data Pointer) */ - new_gd->arch.gd_addr = new_gd; - gdt_addr[X86_GDT_ENTRY_32BIT_FS] = GDT_ENTRY(0xc093, - (ulong)&new_gd->arch.gd_addr, 0xfffff); - - /* 16-bit CS: code, read/execute, 64 kB, base 0 */ - gdt_addr[X86_GDT_ENTRY_16BIT_CS] = GDT_ENTRY(0x009b, 0, 0x0ffff); - - /* 16-bit DS: data, read/write, 64 kB, base 0 */ - gdt_addr[X86_GDT_ENTRY_16BIT_DS] = GDT_ENTRY(0x0093, 0, 0x0ffff); - - gdt_addr[X86_GDT_ENTRY_16BIT_FLAT_CS] = GDT_ENTRY(0x809b, 0, 0xfffff); - gdt_addr[X86_GDT_ENTRY_16BIT_FLAT_DS] = GDT_ENTRY(0x8093, 0, 0xfffff); - - load_gdt(gdt_addr, X86_GDT_NUM_ENTRIES); - load_ds(X86_GDT_ENTRY_32BIT_DS); - load_es(X86_GDT_ENTRY_32BIT_DS); - load_gs(X86_GDT_ENTRY_32BIT_DS); - load_ss(X86_GDT_ENTRY_32BIT_DS); - load_fs(X86_GDT_ENTRY_32BIT_FS); -} - -#ifdef CONFIG_HAVE_FSP -/* - * Setup FSP execution environment GDT - * - * Per Intel FSP external architecture specification, before calling any FSP - * APIs, we need make sure the system is in flat 32-bit mode and both the code - * and data selectors should have full 4GB access range. Here we reuse the one - * we used in arch/x86/cpu/start16.S, and reload the segement registers. - */ -void setup_fsp_gdt(void) -{ - load_gdt((const u64 *)(gdt_rom + CONFIG_RESET_SEG_START), 4); - load_ds(X86_GDT_ENTRY_32BIT_DS); - load_ss(X86_GDT_ENTRY_32BIT_DS); - load_es(X86_GDT_ENTRY_32BIT_DS); - load_fs(X86_GDT_ENTRY_32BIT_DS); - load_gs(X86_GDT_ENTRY_32BIT_DS); -} -#endif - int __weak x86_cleanup_before_linux(void) { #ifdef CONFIG_BOOTSTAGE_STASH @@ -209,241 +66,6 @@ int __weak x86_cleanup_before_linux(void) return 0; }
-/* - * Cyrix CPUs without cpuid or with cpuid not yet enabled can be detected - * by the fact that they preserve the flags across the division of 5/2. - * PII and PPro exhibit this behavior too, but they have cpuid available. - */ - -/* - * Perform the Cyrix 5/2 test. A Cyrix won't change - * the flags, while other 486 chips will. - */ -static inline int test_cyrix_52div(void) -{ - unsigned int test; - - __asm__ __volatile__( - "sahf\n\t" /* clear flags (%eax = 0x0005) */ - "div %b2\n\t" /* divide 5 by 2 */ - "lahf" /* store flags into %ah */ - : "=a" (test) - : "0" (5), "q" (2) - : "cc"); - - /* AH is 0x02 on Cyrix after the divide.. */ - return (unsigned char) (test >> 8) == 0x02; -} - -/* - * Detect a NexGen CPU running without BIOS hypercode new enough - * to have CPUID. (Thanks to Herbert Oppmann) - */ - -static int deep_magic_nexgen_probe(void) -{ - int ret; - - __asm__ __volatile__ ( - " movw $0x5555, %%ax\n" - " xorw %%dx,%%dx\n" - " movw $2, %%cx\n" - " divw %%cx\n" - " movl $0, %%eax\n" - " jnz 1f\n" - " movl $1, %%eax\n" - "1:\n" - : "=a" (ret) : : "cx", "dx"); - return ret; -} - -static bool has_cpuid(void) -{ - return flag_is_changeable_p(X86_EFLAGS_ID); -} - -static bool has_mtrr(void) -{ - return cpuid_edx(0x00000001) & (1 << 12) ? true : false; -} - -static int build_vendor_name(char *vendor_name) -{ - struct cpuid_result result; - result = cpuid(0x00000000); - unsigned int *name_as_ints = (unsigned int *)vendor_name; - - name_as_ints[0] = result.ebx; - name_as_ints[1] = result.edx; - name_as_ints[2] = result.ecx; - - return result.eax; -} - -static void identify_cpu(struct cpu_device_id *cpu) -{ - char vendor_name[16]; - int i; - - vendor_name[0] = '\0'; /* Unset */ - cpu->device = 0; /* fix gcc 4.4.4 warning */ - - /* Find the id and vendor_name */ - if (!has_cpuid()) { - /* Its a 486 if we can modify the AC flag */ - if (flag_is_changeable_p(X86_EFLAGS_AC)) - cpu->device = 0x00000400; /* 486 */ - else - cpu->device = 0x00000300; /* 386 */ - if ((cpu->device == 0x00000400) && test_cyrix_52div()) { - memcpy(vendor_name, "CyrixInstead", 13); - /* If we ever care we can enable cpuid here */ - } - /* Detect NexGen with old hypercode */ - else if (deep_magic_nexgen_probe()) - memcpy(vendor_name, "NexGenDriven", 13); - } - if (has_cpuid()) { - int cpuid_level; - - cpuid_level = build_vendor_name(vendor_name); - vendor_name[12] = '\0'; - - /* Intel-defined flags: level 0x00000001 */ - if (cpuid_level >= 0x00000001) { - cpu->device = cpuid_eax(0x00000001); - } else { - /* Have CPUID level 0 only unheard of */ - cpu->device = 0x00000400; - } - } - cpu->vendor = X86_VENDOR_UNKNOWN; - for (i = 0; i < ARRAY_SIZE(x86_vendors); i++) { - if (memcmp(vendor_name, x86_vendors[i].name, 12) == 0) { - cpu->vendor = x86_vendors[i].vendor; - break; - } - } -} - -static inline void get_fms(struct cpuinfo_x86 *c, uint32_t tfms) -{ - c->x86 = (tfms >> 8) & 0xf; - c->x86_model = (tfms >> 4) & 0xf; - c->x86_mask = tfms & 0xf; - if (c->x86 == 0xf) - c->x86 += (tfms >> 20) & 0xff; - if (c->x86 >= 0x6) - c->x86_model += ((tfms >> 16) & 0xF) << 4; -} - -u32 cpu_get_family_model(void) -{ - return gd->arch.x86_device & 0x0fff0ff0; -} - -u32 cpu_get_stepping(void) -{ - return gd->arch.x86_mask; -} - -int x86_cpu_init_f(void) -{ - const u32 em_rst = ~X86_CR0_EM; - const u32 mp_ne_set = X86_CR0_MP | X86_CR0_NE; - - if (ll_boot_init()) { - /* initialize FPU, reset EM, set MP and NE */ - asm ("fninit\n" \ - "movl %%cr0, %%eax\n" \ - "andl %0, %%eax\n" \ - "orl %1, %%eax\n" \ - "movl %%eax, %%cr0\n" \ - : : "i" (em_rst), "i" (mp_ne_set) : "eax"); - } - - /* identify CPU via cpuid and store the decoded info into gd->arch */ - if (has_cpuid()) { - struct cpu_device_id cpu; - struct cpuinfo_x86 c; - - identify_cpu(&cpu); - get_fms(&c, cpu.device); - gd->arch.x86 = c.x86; - gd->arch.x86_vendor = cpu.vendor; - gd->arch.x86_model = c.x86_model; - gd->arch.x86_mask = c.x86_mask; - gd->arch.x86_device = cpu.device; - - gd->arch.has_mtrr = has_mtrr(); - } - /* Don't allow PCI region 3 to use memory in the 2-4GB memory hole */ - gd->pci_ram_top = 0x80000000U; - - /* Configure fixed range MTRRs for some legacy regions */ - if (gd->arch.has_mtrr) { - u64 mtrr_cap; - - mtrr_cap = native_read_msr(MTRR_CAP_MSR); - if (mtrr_cap & MTRR_CAP_FIX) { - /* Mark the VGA RAM area as uncacheable */ - native_write_msr(MTRR_FIX_16K_A0000_MSR, - MTRR_FIX_TYPE(MTRR_TYPE_UNCACHEABLE), - MTRR_FIX_TYPE(MTRR_TYPE_UNCACHEABLE)); - - /* - * Mark the PCI ROM area as cacheable to improve ROM - * execution performance. - */ - native_write_msr(MTRR_FIX_4K_C0000_MSR, - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); - native_write_msr(MTRR_FIX_4K_C8000_MSR, - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); - native_write_msr(MTRR_FIX_4K_D0000_MSR, - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); - native_write_msr(MTRR_FIX_4K_D8000_MSR, - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), - MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); - - /* Enable the fixed range MTRRs */ - msr_setbits_64(MTRR_DEF_TYPE_MSR, MTRR_DEF_TYPE_FIX_EN); - } - } - -#ifdef CONFIG_I8254_TIMER - /* Set up the i8254 timer if required */ - i8254_init(); -#endif - - return 0; -} - -void x86_enable_caches(void) -{ - unsigned long cr0; - - cr0 = read_cr0(); - cr0 &= ~(X86_CR0_NW | X86_CR0_CD); - write_cr0(cr0); - wbinvd(); -} -void enable_caches(void) __attribute__((weak, alias("x86_enable_caches"))); - -void x86_disable_caches(void) -{ - unsigned long cr0; - - cr0 = read_cr0(); - cr0 |= X86_CR0_NW | X86_CR0_CD; - wbinvd(); - write_cr0(cr0); - wbinvd(); -} -void disable_caches(void) __attribute__((weak, alias("x86_disable_caches"))); - int x86_init_cache(void) { enable_caches(); @@ -483,11 +105,6 @@ void x86_full_reset(void) outb(FULL_RST | SYS_RST | RST_CPU, IO_PORT_RESET); }
-int dcache_status(void) -{ - return !(read_cr0() & X86_CR0_CD); -} - /* Define these functions to allow ehch-hcd to function */ void flush_dcache_range(unsigned long start, unsigned long stop) { @@ -520,57 +137,6 @@ int icache_status(void) return 1; }
-void cpu_enable_paging_pae(ulong cr3) -{ - __asm__ __volatile__( - /* Load the page table address */ - "movl %0, %%cr3\n" - /* Enable pae */ - "movl %%cr4, %%eax\n" - "orl $0x00000020, %%eax\n" - "movl %%eax, %%cr4\n" - /* Enable paging */ - "movl %%cr0, %%eax\n" - "orl $0x80000000, %%eax\n" - "movl %%eax, %%cr0\n" - : - : "r" (cr3) - : "eax"); -} - -void cpu_disable_paging_pae(void) -{ - /* Turn off paging */ - __asm__ __volatile__ ( - /* Disable paging */ - "movl %%cr0, %%eax\n" - "andl $0x7fffffff, %%eax\n" - "movl %%eax, %%cr0\n" - /* Disable pae */ - "movl %%cr4, %%eax\n" - "andl $0xffffffdf, %%eax\n" - "movl %%eax, %%cr4\n" - : - : - : "eax"); -} - -static bool can_detect_long_mode(void) -{ - return cpuid_eax(0x80000000) > 0x80000000UL; -} - -static bool has_long_mode(void) -{ - return cpuid_edx(0x80000001) & (1 << 29) ? true : false; -} - -int cpu_has_64bit(void) -{ - return has_cpuid() && can_detect_long_mode() && - has_long_mode(); -} - const char *cpu_vendor_name(int vendor) { const char *name; @@ -616,46 +182,6 @@ int default_print_cpuinfo(void) return 0; }
-#define PAGETABLE_SIZE (6 * 4096) - -/** - * build_pagetable() - build a flat 4GiB page table structure for 64-bti mode - * - * @pgtable: Pointer to a 24iKB block of memory - */ -static void build_pagetable(uint32_t *pgtable) -{ - uint i; - - memset(pgtable, '\0', PAGETABLE_SIZE); - - /* Level 4 needs a single entry */ - pgtable[0] = (ulong)&pgtable[1024] + 7; - - /* Level 3 has one 64-bit entry for each GiB of memory */ - for (i = 0; i < 4; i++) - pgtable[1024 + i * 2] = (ulong)&pgtable[2048] + 0x1000 * i + 7; - - /* Level 2 has 2048 64-bit entries, each repesenting 2MiB */ - for (i = 0; i < 2048; i++) - pgtable[2048 + i * 2] = 0x183 + (i << 21UL); -} - -int cpu_jump_to_64bit(ulong setup_base, ulong target) -{ - uint32_t *pgtable; - - pgtable = memalign(4096, PAGETABLE_SIZE); - if (!pgtable) - return -ENOMEM; - - build_pagetable(pgtable); - cpu_call64((ulong)pgtable, setup_base, target); - free(pgtable); - - return -EFAULT; -} - void show_boot_progress(int val) { outb(val, POST_PORT); @@ -680,36 +206,6 @@ int last_stage_init(void) } #endif
-#ifdef CONFIG_SMP -static int enable_smis(struct udevice *cpu, void *unused) -{ - return 0; -} - -static struct mp_flight_record mp_steps[] = { - MP_FR_BLOCK_APS(mp_init_cpu, NULL, mp_init_cpu, NULL), - /* Wait for APs to finish initialization before proceeding */ - MP_FR_BLOCK_APS(NULL, NULL, enable_smis, NULL), -}; - -static int x86_mp_init(void) -{ - struct mp_params mp_params; - - mp_params.parallel_microcode_load = 0, - mp_params.flight_plan = &mp_steps[0]; - mp_params.num_records = ARRAY_SIZE(mp_steps); - mp_params.microcode_pointer = 0; - - if (mp_init(&mp_params)) { - printf("Warning: MP init failure\n"); - return -EIO; - } - - return 0; -} -#endif - static int x86_init_cpus(void) { #ifdef CONFIG_SMP diff --git a/arch/x86/cpu/i386/Makefile b/arch/x86/cpu/i386/Makefile new file mode 100644 index 0000000..d336495 --- /dev/null +++ b/arch/x86/cpu/i386/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# + +obj-y += cpu.o +obj-y += interrupt.o diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c new file mode 100644 index 0000000..09a5b91 --- /dev/null +++ b/arch/x86/cpu/i386/cpu.c @@ -0,0 +1,534 @@ +/* + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * Part of this file is adapted from coreboot + * src/arch/x86/lib/cpu.c + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <asm/control_regs.h> +#include <asm/cpu.h> +#include <asm/mp.h> +#include <asm/msr.h> +#include <asm/mtrr.h> +#include <asm/processor-flags.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Constructor for a conventional segment GDT (or LDT) entry + * This is a macro so it can be used in initialisers + */ +#define GDT_ENTRY(flags, base, limit) \ + ((((base) & 0xff000000ULL) << (56-24)) | \ + (((flags) & 0x0000f0ffULL) << 40) | \ + (((limit) & 0x000f0000ULL) << (48-16)) | \ + (((base) & 0x00ffffffULL) << 16) | \ + (((limit) & 0x0000ffffULL))) + +struct gdt_ptr { + u16 len; + u32 ptr; +} __packed; + +struct cpu_device_id { + unsigned vendor; + unsigned device; +}; + +struct cpuinfo_x86 { + uint8_t x86; /* CPU family */ + uint8_t x86_vendor; /* CPU vendor */ + uint8_t x86_model; + uint8_t x86_mask; +}; + +/* + * List of cpu vendor strings along with their normalized + * id values. + */ +static const struct { + int vendor; + const char *name; +} x86_vendors[] = { + { X86_VENDOR_INTEL, "GenuineIntel", }, + { X86_VENDOR_CYRIX, "CyrixInstead", }, + { X86_VENDOR_AMD, "AuthenticAMD", }, + { X86_VENDOR_UMC, "UMC UMC UMC ", }, + { X86_VENDOR_NEXGEN, "NexGenDriven", }, + { X86_VENDOR_CENTAUR, "CentaurHauls", }, + { X86_VENDOR_RISE, "RiseRiseRise", }, + { X86_VENDOR_TRANSMETA, "GenuineTMx86", }, + { X86_VENDOR_TRANSMETA, "TransmetaCPU", }, + { X86_VENDOR_NSC, "Geode by NSC", }, + { X86_VENDOR_SIS, "SiS SiS SiS ", }, +}; + +static void load_ds(u32 segment) +{ + asm volatile("movl %0, %%ds" : : "r" (segment * X86_GDT_ENTRY_SIZE)); +} + +static void load_es(u32 segment) +{ + asm volatile("movl %0, %%es" : : "r" (segment * X86_GDT_ENTRY_SIZE)); +} + +static void load_fs(u32 segment) +{ + asm volatile("movl %0, %%fs" : : "r" (segment * X86_GDT_ENTRY_SIZE)); +} + +static void load_gs(u32 segment) +{ + asm volatile("movl %0, %%gs" : : "r" (segment * X86_GDT_ENTRY_SIZE)); +} + +static void load_ss(u32 segment) +{ + asm volatile("movl %0, %%ss" : : "r" (segment * X86_GDT_ENTRY_SIZE)); +} + +static void load_gdt(const u64 *boot_gdt, u16 num_entries) +{ + struct gdt_ptr gdt; + + gdt.len = (num_entries * X86_GDT_ENTRY_SIZE) - 1; + gdt.ptr = (ulong)boot_gdt; + + asm volatile("lgdtl %0\n" : : "m" (gdt)); +} + +void arch_setup_gd(gd_t *new_gd) +{ + u64 *gdt_addr; + + gdt_addr = new_gd->arch.gdt; + + /* + * CS: code, read/execute, 4 GB, base 0 + * + * Some OS (like VxWorks) requires GDT entry 1 to be the 32-bit CS + */ + gdt_addr[X86_GDT_ENTRY_UNUSED] = GDT_ENTRY(0xc09b, 0, 0xfffff); + gdt_addr[X86_GDT_ENTRY_32BIT_CS] = GDT_ENTRY(0xc09b, 0, 0xfffff); + + /* DS: data, read/write, 4 GB, base 0 */ + gdt_addr[X86_GDT_ENTRY_32BIT_DS] = GDT_ENTRY(0xc093, 0, 0xfffff); + + /* FS: data, read/write, 4 GB, base (Global Data Pointer) */ + new_gd->arch.gd_addr = new_gd; + gdt_addr[X86_GDT_ENTRY_32BIT_FS] = GDT_ENTRY(0xc093, + (ulong)&new_gd->arch.gd_addr, 0xfffff); + + /* 16-bit CS: code, read/execute, 64 kB, base 0 */ + gdt_addr[X86_GDT_ENTRY_16BIT_CS] = GDT_ENTRY(0x009b, 0, 0x0ffff); + + /* 16-bit DS: data, read/write, 64 kB, base 0 */ + gdt_addr[X86_GDT_ENTRY_16BIT_DS] = GDT_ENTRY(0x0093, 0, 0x0ffff); + + gdt_addr[X86_GDT_ENTRY_16BIT_FLAT_CS] = GDT_ENTRY(0x809b, 0, 0xfffff); + gdt_addr[X86_GDT_ENTRY_16BIT_FLAT_DS] = GDT_ENTRY(0x8093, 0, 0xfffff); + + load_gdt(gdt_addr, X86_GDT_NUM_ENTRIES); + load_ds(X86_GDT_ENTRY_32BIT_DS); + load_es(X86_GDT_ENTRY_32BIT_DS); + load_gs(X86_GDT_ENTRY_32BIT_DS); + load_ss(X86_GDT_ENTRY_32BIT_DS); + load_fs(X86_GDT_ENTRY_32BIT_FS); +} + +#ifdef CONFIG_HAVE_FSP +/* + * Setup FSP execution environment GDT + * + * Per Intel FSP external architecture specification, before calling any FSP + * APIs, we need make sure the system is in flat 32-bit mode and both the code + * and data selectors should have full 4GB access range. Here we reuse the one + * we used in arch/x86/cpu/start16.S, and reload the segement registers. + */ +void setup_fsp_gdt(void) +{ + load_gdt((const u64 *)(gdt_rom + CONFIG_RESET_SEG_START), 4); + load_ds(X86_GDT_ENTRY_32BIT_DS); + load_ss(X86_GDT_ENTRY_32BIT_DS); + load_es(X86_GDT_ENTRY_32BIT_DS); + load_fs(X86_GDT_ENTRY_32BIT_DS); + load_gs(X86_GDT_ENTRY_32BIT_DS); +} +#endif + +/* + * Cyrix CPUs without cpuid or with cpuid not yet enabled can be detected + * by the fact that they preserve the flags across the division of 5/2. + * PII and PPro exhibit this behavior too, but they have cpuid available. + */ + +/* + * Perform the Cyrix 5/2 test. A Cyrix won't change + * the flags, while other 486 chips will. + */ +static inline int test_cyrix_52div(void) +{ + unsigned int test; + + __asm__ __volatile__( + "sahf\n\t" /* clear flags (%eax = 0x0005) */ + "div %b2\n\t" /* divide 5 by 2 */ + "lahf" /* store flags into %ah */ + : "=a" (test) + : "0" (5), "q" (2) + : "cc"); + + /* AH is 0x02 on Cyrix after the divide.. */ + return (unsigned char) (test >> 8) == 0x02; +} + +/* + * Detect a NexGen CPU running without BIOS hypercode new enough + * to have CPUID. (Thanks to Herbert Oppmann) + */ +static int deep_magic_nexgen_probe(void) +{ + int ret; + + __asm__ __volatile__ ( + " movw $0x5555, %%ax\n" + " xorw %%dx,%%dx\n" + " movw $2, %%cx\n" + " divw %%cx\n" + " movl $0, %%eax\n" + " jnz 1f\n" + " movl $1, %%eax\n" + "1:\n" + : "=a" (ret) : : "cx", "dx"); + return ret; +} + +static bool has_cpuid(void) +{ + return flag_is_changeable_p(X86_EFLAGS_ID); +} + +static bool has_mtrr(void) +{ + return cpuid_edx(0x00000001) & (1 << 12) ? true : false; +} + +static int build_vendor_name(char *vendor_name) +{ + struct cpuid_result result; + result = cpuid(0x00000000); + unsigned int *name_as_ints = (unsigned int *)vendor_name; + + name_as_ints[0] = result.ebx; + name_as_ints[1] = result.edx; + name_as_ints[2] = result.ecx; + + return result.eax; +} + +static void identify_cpu(struct cpu_device_id *cpu) +{ + char vendor_name[16]; + int i; + + vendor_name[0] = '\0'; /* Unset */ + cpu->device = 0; /* fix gcc 4.4.4 warning */ + + /* Find the id and vendor_name */ + if (!has_cpuid()) { + /* Its a 486 if we can modify the AC flag */ + if (flag_is_changeable_p(X86_EFLAGS_AC)) + cpu->device = 0x00000400; /* 486 */ + else + cpu->device = 0x00000300; /* 386 */ + if ((cpu->device == 0x00000400) && test_cyrix_52div()) { + memcpy(vendor_name, "CyrixInstead", 13); + /* If we ever care we can enable cpuid here */ + } + /* Detect NexGen with old hypercode */ + else if (deep_magic_nexgen_probe()) + memcpy(vendor_name, "NexGenDriven", 13); + } + if (has_cpuid()) { + int cpuid_level; + + cpuid_level = build_vendor_name(vendor_name); + vendor_name[12] = '\0'; + + /* Intel-defined flags: level 0x00000001 */ + if (cpuid_level >= 0x00000001) { + cpu->device = cpuid_eax(0x00000001); + } else { + /* Have CPUID level 0 only unheard of */ + cpu->device = 0x00000400; + } + } + cpu->vendor = X86_VENDOR_UNKNOWN; + for (i = 0; i < ARRAY_SIZE(x86_vendors); i++) { + if (memcmp(vendor_name, x86_vendors[i].name, 12) == 0) { + cpu->vendor = x86_vendors[i].vendor; + break; + } + } +} + +static inline void get_fms(struct cpuinfo_x86 *c, uint32_t tfms) +{ + c->x86 = (tfms >> 8) & 0xf; + c->x86_model = (tfms >> 4) & 0xf; + c->x86_mask = tfms & 0xf; + if (c->x86 == 0xf) + c->x86 += (tfms >> 20) & 0xff; + if (c->x86 >= 0x6) + c->x86_model += ((tfms >> 16) & 0xF) << 4; +} + +u32 cpu_get_family_model(void) +{ + return gd->arch.x86_device & 0x0fff0ff0; +} + +u32 cpu_get_stepping(void) +{ + return gd->arch.x86_mask; +} + +int x86_cpu_init_f(void) +{ + const u32 em_rst = ~X86_CR0_EM; + const u32 mp_ne_set = X86_CR0_MP | X86_CR0_NE; + + if (ll_boot_init()) { + /* initialize FPU, reset EM, set MP and NE */ + asm ("fninit\n" \ + "movl %%cr0, %%eax\n" \ + "andl %0, %%eax\n" \ + "orl %1, %%eax\n" \ + "movl %%eax, %%cr0\n" \ + : : "i" (em_rst), "i" (mp_ne_set) : "eax"); + } + + /* identify CPU via cpuid and store the decoded info into gd->arch */ + if (has_cpuid()) { + struct cpu_device_id cpu; + struct cpuinfo_x86 c; + + identify_cpu(&cpu); + get_fms(&c, cpu.device); + gd->arch.x86 = c.x86; + gd->arch.x86_vendor = cpu.vendor; + gd->arch.x86_model = c.x86_model; + gd->arch.x86_mask = c.x86_mask; + gd->arch.x86_device = cpu.device; + + gd->arch.has_mtrr = has_mtrr(); + } + /* Don't allow PCI region 3 to use memory in the 2-4GB memory hole */ + gd->pci_ram_top = 0x80000000U; + + /* Configure fixed range MTRRs for some legacy regions */ + if (gd->arch.has_mtrr) { + u64 mtrr_cap; + + mtrr_cap = native_read_msr(MTRR_CAP_MSR); + if (mtrr_cap & MTRR_CAP_FIX) { + /* Mark the VGA RAM area as uncacheable */ + native_write_msr(MTRR_FIX_16K_A0000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_UNCACHEABLE), + MTRR_FIX_TYPE(MTRR_TYPE_UNCACHEABLE)); + + /* + * Mark the PCI ROM area as cacheable to improve ROM + * execution performance. + */ + native_write_msr(MTRR_FIX_4K_C0000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_4K_C8000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_4K_D0000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + native_write_msr(MTRR_FIX_4K_D8000_MSR, + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK), + MTRR_FIX_TYPE(MTRR_TYPE_WRBACK)); + + /* Enable the fixed range MTRRs */ + msr_setbits_64(MTRR_DEF_TYPE_MSR, MTRR_DEF_TYPE_FIX_EN); + } + } + +#ifdef CONFIG_I8254_TIMER + /* Set up the i8254 timer if required */ + i8254_init(); +#endif + + return 0; +} + +void x86_enable_caches(void) +{ + unsigned long cr0; + + cr0 = read_cr0(); + cr0 &= ~(X86_CR0_NW | X86_CR0_CD); + write_cr0(cr0); + wbinvd(); +} +void enable_caches(void) __attribute__((weak, alias("x86_enable_caches"))); + +void x86_disable_caches(void) +{ + unsigned long cr0; + + cr0 = read_cr0(); + cr0 |= X86_CR0_NW | X86_CR0_CD; + wbinvd(); + write_cr0(cr0); + wbinvd(); +} +void disable_caches(void) __attribute__((weak, alias("x86_disable_caches"))); + +int dcache_status(void) +{ + return !(read_cr0() & X86_CR0_CD); +} + +void cpu_enable_paging_pae(ulong cr3) +{ + __asm__ __volatile__( + /* Load the page table address */ + "movl %0, %%cr3\n" + /* Enable pae */ + "movl %%cr4, %%eax\n" + "orl $0x00000020, %%eax\n" + "movl %%eax, %%cr4\n" + /* Enable paging */ + "movl %%cr0, %%eax\n" + "orl $0x80000000, %%eax\n" + "movl %%eax, %%cr0\n" + : + : "r" (cr3) + : "eax"); +} + +void cpu_disable_paging_pae(void) +{ + /* Turn off paging */ + __asm__ __volatile__ ( + /* Disable paging */ + "movl %%cr0, %%eax\n" + "andl $0x7fffffff, %%eax\n" + "movl %%eax, %%cr0\n" + /* Disable pae */ + "movl %%cr4, %%eax\n" + "andl $0xffffffdf, %%eax\n" + "movl %%eax, %%cr4\n" + : + : + : "eax"); +} + +static bool can_detect_long_mode(void) +{ + return cpuid_eax(0x80000000) > 0x80000000UL; +} + +static bool has_long_mode(void) +{ + return cpuid_edx(0x80000001) & (1 << 29) ? true : false; +} + +int cpu_has_64bit(void) +{ + return has_cpuid() && can_detect_long_mode() && + has_long_mode(); +} + +#define PAGETABLE_SIZE (6 * 4096) + +/** + * build_pagetable() - build a flat 4GiB page table structure for 64-bti mode + * + * @pgtable: Pointer to a 24iKB block of memory + */ +static void build_pagetable(uint32_t *pgtable) +{ + uint i; + + memset(pgtable, '\0', PAGETABLE_SIZE); + + /* Level 4 needs a single entry */ + pgtable[0] = (ulong)&pgtable[1024] + 7; + + /* Level 3 has one 64-bit entry for each GiB of memory */ + for (i = 0; i < 4; i++) + pgtable[1024 + i * 2] = (ulong)&pgtable[2048] + 0x1000 * i + 7; + + /* Level 2 has 2048 64-bit entries, each repesenting 2MiB */ + for (i = 0; i < 2048; i++) + pgtable[2048 + i * 2] = 0x183 + (i << 21UL); +} + +int cpu_jump_to_64bit(ulong setup_base, ulong target) +{ + uint32_t *pgtable; + + pgtable = memalign(4096, PAGETABLE_SIZE); + if (!pgtable) + return -ENOMEM; + + build_pagetable(pgtable); + cpu_call64((ulong)pgtable, setup_base, target); + free(pgtable); + + return -EFAULT; +} + +#ifdef CONFIG_SMP +static int enable_smis(struct udevice *cpu, void *unused) +{ + return 0; +} + +static struct mp_flight_record mp_steps[] = { + MP_FR_BLOCK_APS(mp_init_cpu, NULL, mp_init_cpu, NULL), + /* Wait for APs to finish initialization before proceeding */ + MP_FR_BLOCK_APS(NULL, NULL, enable_smis, NULL), +}; + +int x86_mp_init(void) +{ + struct mp_params mp_params; + + mp_params.parallel_microcode_load = 0, + mp_params.flight_plan = &mp_steps[0]; + mp_params.num_records = ARRAY_SIZE(mp_steps); + mp_params.microcode_pointer = 0; + + if (mp_init(&mp_params)) { + printf("Warning: MP init failure\n"); + return -EIO; + } + + return 0; +} +#endif diff --git a/arch/x86/cpu/interrupts.c b/arch/x86/cpu/i386/interrupt.c similarity index 99% rename from arch/x86/cpu/interrupts.c rename to arch/x86/cpu/i386/interrupt.c index 5f6cdd3..8dfbb48 100644 --- a/arch/x86/cpu/interrupts.c +++ b/arch/x86/cpu/i386/interrupt.c @@ -13,16 +13,12 @@
#include <common.h> #include <dm.h> -#include <asm/cache.h> #include <asm/control_regs.h> #include <asm/i8259.h> #include <asm/interrupt.h> #include <asm/io.h> #include <asm/lapic.h> -#include <asm/msr.h> #include <asm/processor-flags.h> -#include <asm/processor.h> -#include <asm/u-boot-x86.h>
diff --git a/arch/x86/include/asm/mp.h b/arch/x86/include/asm/mp.h index 2e6c312..83b99dc 100644 --- a/arch/x86/include/asm/mp.h +++ b/arch/x86/include/asm/mp.h @@ -90,4 +90,7 @@ int mp_init(struct mp_params *params); /* Probes the CPU device */ int mp_init_cpu(struct udevice *cpu, void *unused);
+/* Set up additional CPUs */ +int x86_mp_init(void); + #endif /* _X86_MP_H_ */
There is not much needed at present, but set up a separate directory to put this code as it grows.
arch/x86/cpu/Makefile | 4 +++- arch/x86/cpu/x86_64/Makefile | 6 ++++++ arch/x86/cpu/x86_64/cpu.c | 35 +++++++++++++++++++++++++++++++++++ arch/x86/cpu/x86_64/interrupts.c | 30 ++++++++++++++++++++++++++++++ 4 files changed, 74 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/x86_64/Makefile create mode 100644 arch/x86/cpu/x86_64/cpu.c create mode 100644 arch/x86/cpu/x86_64/interrupts.c
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 41ad481..7f89ff0 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -38,6 +38,8 @@ obj-$(CONFIG_PCI) += pci.o obj-$(CONFIG_SMP) += sipi_vector.o obj-y += turbo.o
-ifeq ($(CONFIG_$(SPL_)X86_64),) +ifeq ($(CONFIG_$(SPL_)X86_64),y) +obj-y += x86_64/ +else obj-y += i386/ endif diff --git a/arch/x86/cpu/x86_64/Makefile b/arch/x86/cpu/x86_64/Makefile new file mode 100644 index 0000000..4b06386 --- /dev/null +++ b/arch/x86/cpu/x86_64/Makefile @@ -0,0 +1,6 @@ +# +# (C) Copyright 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# + +obj-y += cpu.o interrupts.o diff --git a/arch/x86/cpu/x86_64/cpu.c b/arch/x86/cpu/x86_64/cpu.c new file mode 100644 index 0000000..c1d3788 --- /dev/null +++ b/arch/x86/cpu/x86_64/cpu.c @@ -0,0 +1,35 @@ +/* + * (C) Copyright 2016 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> + +int cpu_has_64bit(void) +{ + return true; +} + +void enable_caches(void) +{ + /* Not implemented */ +} + +void disable_caches(void) +{ + /* Not implemented */ +} + +int dcache_status(void) +{ + return true; +} + +int x86_mp_init(void) +{ + /* Not implemented */ + return 0; +} diff --git a/arch/x86/cpu/x86_64/interrupts.c b/arch/x86/cpu/x86_64/interrupts.c new file mode 100644 index 0000000..d814b6a --- /dev/null +++ b/arch/x86/cpu/x86_64/interrupts.c @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2016 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/processor-flags.h> + +void enable_interrupts(void) +{ + asm("sti\n"); +} + +int disable_interrupts(void) +{ + long flags; + + asm volatile ("pushfq ; popq %0 ; cli\n" : "=g" (flags) : ); + + return flags & X86_EFLAGS_IF; +} + +int interrupt_init(void) +{ + /* Nothing to do - this was already done in SPL */ + return 0; +} +
At present this is just an ordinary variable. We may consider making it a fixed register in the future.
arch/x86/cpu/x86_64/cpu.c | 13 +++++++++++++ arch/x86/include/asm/global_data.h | 6 +++++- 2 files changed, 18 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/x86_64/cpu.c b/arch/x86/cpu/x86_64/cpu.c index c1d3788..da2ad11 100644 --- a/arch/x86/cpu/x86_64/cpu.c +++ b/arch/x86/cpu/x86_64/cpu.c @@ -8,6 +8,19 @@ #include <common.h> #include <debug_uart.h>
+DECLARE_GLOBAL_DATA_PTR; + +/* Global declaration of gd */ +struct global_data *global_data_ptr; + +void arch_setup_gd(gd_t *new_gd) +{ + global_data_ptr = new_gd; + + /* TODO(sjg@chromium.org): Why is this needed? */ + printch(' '); +} + int cpu_has_64bit(void) { return true; diff --git a/arch/x86/include/asm/global_data.h b/arch/x86/include/asm/global_data.h index 7434f77..ce9e5cc 100644 --- a/arch/x86/include/asm/global_data.h +++ b/arch/x86/include/asm/global_data.h @@ -104,7 +104,7 @@ struct arch_global_data { #include <asm-generic/global_data.h>
#ifndef __ASSEMBLY__ -# ifdef CONFIG_EFI_APP +# if defined(CONFIG_EFI_APP) || CONFIG_IS_ENABLED(X86_64)
#define gd global_data_ptr
@@ -114,7 +114,11 @@ static inline __attribute__((no_instrument_function)) gd_t *get_fs_gd_ptr(void) { gd_t *gd_ptr;
+#if CONFIG_IS_ENABLED(X86_64) + asm volatile("fs mov 0, %0\n" : "=r" (gd_ptr)); +#else asm volatile("fs movl 0, %0\n" : "=r" (gd_ptr)); +#endif
return gd_ptr; }
When SPL and U-Boot proper have different settings for this flag, we need to use the correct one. Fix this up in the interrupt code.
arch/x86/cpu/i386/interrupt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/cpu/i386/interrupt.c b/arch/x86/cpu/i386/interrupt.c index 8dfbb48..a058303 100644 --- a/arch/x86/cpu/i386/interrupt.c +++ b/arch/x86/cpu/i386/interrupt.c @@ -234,7 +234,7 @@ int disable_interrupts(void) { long flags;
-#ifdef CONFIG_X86_64 +#if CONFIG_IS_ENABLED(X86_64) asm volatile ("pushfq ; popq %0 ; cli\n" : "=g" (flags) : ); #else asm volatile ("pushfl ; popl %0 ; cli\n" : "=g" (flags) : );
This needs a different image format from 32-bit x86, so add a new link script.
arch/x86/cpu/config.mk | 6 ++++ arch/x86/cpu/u-boot-64.lds | 76 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 82 insertions(+) create mode 100644 arch/x86/cpu/u-boot-64.lds
diff --git a/arch/x86/cpu/config.mk b/arch/x86/cpu/config.mk index 1263221..4c99a35 100644 --- a/arch/x86/cpu/config.mk +++ b/arch/x86/cpu/config.mk @@ -15,3 +15,9 @@ LDPPFLAGS += -DRESET_SEG_SIZE=$(CONFIG_RESET_SEG_SIZE) LDPPFLAGS += -DRESET_VEC_LOC=$(CONFIG_RESET_VEC_LOC) LDPPFLAGS += -DSTART_16=$(CONFIG_SYS_X86_START16) LDPPFLAGS += -DRESET_BASE="CONFIG_SYS_TEXT_BASE + (CONFIG_SYS_MONITOR_LEN - RESET_SEG_SIZE)" + +ifdef CONFIG_X86_64 +ifndef CONFIG_SPL_BUILD +LDSCRIPT = $(srctree)/arch/x86/cpu/u-boot-64.lds +endif +endif diff --git a/arch/x86/cpu/u-boot-64.lds b/arch/x86/cpu/u-boot-64.lds new file mode 100644 index 0000000..718790c --- /dev/null +++ b/arch/x86/cpu/u-boot-64.lds @@ -0,0 +1,76 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +OUTPUT_FORMAT("elf64-x86-64", "elf64-x86-64", "elf64-x86-64") +OUTPUT_ARCH(i386:x86-64) +ENTRY(_start) + +SECTIONS +{ +#ifndef CONFIG_CMDLINE + /DISCARD/ : { *(.u_boot_list_2_cmd_*) } +#endif + + . = CONFIG_SYS_TEXT_BASE; /* Location of bootcode in flash */ + __text_start = .; + .text : { *(.text*); } + + . = ALIGN(4); + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data*) } + + . = ALIGN(4); + .hash : { *(.hash*) } + + . = ALIGN(4); + .got : { *(.got*) } + + . = ALIGN(4); + __data_end = .; + __init_end = .; + + . = ALIGN(4); + .dynsym : { *(.dynsym*) } + + . = ALIGN(4); + __rel_dyn_start = .; + .rela.dyn : { + *(.rela*) + } + __rel_dyn_end = .; + . = ALIGN(4); + + .dynamic : { *(.dynamic) } + + . = ALIGN(4); + _end = .; + + .bss __rel_dyn_start (OVERLAY) : { + __bss_start = .; + *(.bss) + *(COM*) + . = ALIGN(4); + __bss_end = .; + } + + /DISCARD/ : { *(.dynsym) } + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +}
If SPL is used it is always build in 32-bit mode. Add a link script to handle the correct placement of the sections.
arch/x86/cpu/u-boot-spl.lds | 74 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 74 insertions(+) create mode 100644 arch/x86/cpu/u-boot-spl.lds
diff --git a/arch/x86/cpu/u-boot-spl.lds b/arch/x86/cpu/u-boot-spl.lds new file mode 100644 index 0000000..8a38d58 --- /dev/null +++ b/arch/x86/cpu/u-boot-spl.lds @@ -0,0 +1,74 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +OUTPUT_FORMAT("elf32-i386", "elf32-i386", "elf32-i386") +OUTPUT_ARCH(i386) +ENTRY(_start) + +SECTIONS +{ +#ifndef CONFIG_CMDLINE + /DISCARD/ : { *(.u_boot_list_2_cmd_*) } +#endif + + . = CONFIG_SPL_TEXT_BASE; /* Location of bootcode in flash */ + __text_start = .; + .text : { *(.text*); } + + . = ALIGN(4); + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data*) } + + . = ALIGN(4); + __data_end = .; + __init_end = .; + + _image_binary_end = .; + + . = 0x120000; + .bss (OVERLAY) : { + __bss_start = .; + *(.bss*) + *(COM*) + . = ALIGN(4); + __bss_end = .; + } + __bss_size = __bss_end - __bss_start; + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } + +#ifdef CONFIG_SPL_X86_16BIT_INIT + /* + * The following expressions place the 16-bit Real-Mode code and + * Reset Vector at the end of the Flash ROM + */ + . = START_16 - RESET_SEG_START; + .start16 : AT (START_16) { + KEEP(*(.start16)); + } + + . = RESET_VEC_LOC - RESET_SEG_START; + .resetvec : AT (RESET_VEC_LOC) { + KEEP(*(.resetvec)); + } +#endif + +}
When SPL is used we need to build the 16-bit start-up code. Add Makefile rules to handle this.
scripts/Makefile.spl | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index bd1f392..8964699 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -176,6 +176,8 @@ ifeq ($(CONFIG_SYS_SOC),"at91") ALL-y += boot.bin endif
+ALL-$(CONFIG_SPL_X86_16BIT_INIT) += $(obj)/u-boot-x86-16bit-spl.bin + ALL-$(CONFIG_ARCH_ZYNQ) += $(obj)/boot.bin ALL-$(CONFIG_ARCH_ZYNQMP) += $(obj)/boot.bin
@@ -280,11 +282,16 @@ endif quiet_cmd_objcopy = OBJCOPY $@ cmd_objcopy = $(OBJCOPY) $(OBJCOPYFLAGS) $(OBJCOPYFLAGS_$(@F)) $< $@
-OBJCOPYFLAGS_$(SPL_BIN)-nodtb.bin = $(SPL_OBJCFLAGS) -O binary +OBJCOPYFLAGS_$(SPL_BIN)-nodtb.bin = $(SPL_OBJCFLAGS) -O binary \ + $(if $(CONFIG_SPL_X86_16BIT_INIT),-R .start16 -R .resetvec)
$(obj)/$(SPL_BIN)-nodtb.bin: $(obj)/$(SPL_BIN) FORCE $(call if_changed,objcopy)
+OBJCOPYFLAGS_u-boot-x86-16bit-spl.bin := -O binary -j .start16 -j .resetvec +$(obj)/u-boot-x86-16bit-spl.bin: $(obj)/u-boot-spl FORCE + $(call if_changed,objcopy) + LDFLAGS_$(SPL_BIN) += -T u-boot-spl.lds $(LDFLAGS_FINAL) ifneq ($(CONFIG_SPL_TEXT_BASE),) LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_SPL_TEXT_BASE)
Remove the very old x86 code and add support for 64-bit.
arch/x86/include/asm/byteorder.h | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/arch/x86/include/asm/byteorder.h b/arch/x86/include/asm/byteorder.h index 7dfeb8b..a2d1fd8 100644 --- a/arch/x86/include/asm/byteorder.h +++ b/arch/x86/include/asm/byteorder.h @@ -8,24 +8,25 @@
static __inline__ __u32 ___arch__swab32(__u32 x) { -#ifdef CONFIG_X86_BSWAP __asm__("bswap %0" : "=r" (x) : "0" (x)); -#else - __asm__("xchgb %b0,%h0\n\t" /* swap lower bytes */ - "rorl $16,%0\n\t" /* swap words */ - "xchgb %b0,%h0" /* swap higher bytes */ - :"=q" (x) - : "0" (x)); -#endif + return x; }
+#define _constant_swab16(x) ((__u16)( \ + (((__u16)(x) & (__u16)0x00ffU) << 8) | \ + (((__u16)(x) & (__u16)0xff00U) >> 8))) + static __inline__ __u16 ___arch__swab16(__u16 x) { +#if CONFIG_IS_ENABLED(X86_64) + return _constant_swab16(x); +#else __asm__("xchgb %b0,%h0" /* swap bytes */ \ : "=q" (x) \ : "0" (x)); \ return x; +#endif }
#define __arch__swab32(x) ___arch__swab32(x)
This doesn't build at present and is not used in a 64-bit build. Disable it for now.
arch/x86/include/asm/cpu.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/x86/include/asm/cpu.h b/arch/x86/include/asm/cpu.h index 7892757..9a8ae2a 100644 --- a/arch/x86/include/asm/cpu.h +++ b/arch/x86/include/asm/cpu.h @@ -160,6 +160,8 @@ static inline unsigned int cpuid_edx(unsigned int op) return edx; }
+#if !CONFIG_IS_ENABLED(X86_64) + /* Standard macro to see if a specific flag is changeable */ static inline int flag_is_changeable_p(uint32_t flag) { @@ -180,6 +182,7 @@ static inline int flag_is_changeable_p(uint32_t flag) : "ir" (flag)); return ((f1^f2) & flag) != 0; } +#endif
static inline void mfence(void) {
Adjust types as needed to support 64-bit compilation.
arch/x86/include/asm/posix_types.h | 5 +++++ arch/x86/include/asm/types.h | 5 +++++ 2 files changed, 10 insertions(+)
diff --git a/arch/x86/include/asm/posix_types.h b/arch/x86/include/asm/posix_types.h index 5529f32..717f6cb 100644 --- a/arch/x86/include/asm/posix_types.h +++ b/arch/x86/include/asm/posix_types.h @@ -16,8 +16,13 @@ typedef int __kernel_pid_t; typedef unsigned short __kernel_ipc_pid_t; typedef unsigned short __kernel_uid_t; typedef unsigned short __kernel_gid_t; +#if CONFIG_IS_ENABLED(X86_64) +typedef unsigned long __kernel_size_t; +typedef long __kernel_ssize_t; +#else typedef unsigned int __kernel_size_t; typedef int __kernel_ssize_t; +#endif typedef int __kernel_ptrdiff_t; typedef long __kernel_time_t; typedef long __kernel_suseconds_t; diff --git a/arch/x86/include/asm/types.h b/arch/x86/include/asm/types.h index 880dcb4..a47e581 100644 --- a/arch/x86/include/asm/types.h +++ b/arch/x86/include/asm/types.h @@ -44,7 +44,12 @@ typedef __INT64_TYPE__ s64; typedef __UINT64_TYPE__ u64; #endif
+#if CONFIG_IS_ENABLED(X86_64) +#define BITS_PER_LONG 64 +#else #define BITS_PER_LONG 32 +#endif + /* Dma addresses are 32-bits wide. */
typedef u32 dma_addr_t;
This is left out of the example memory map. Add it to avoid confusion.
doc/README.x86 | 1 + 1 file changed, 1 insertion(+)
diff --git a/doc/README.x86 b/doc/README.x86 index 9d3129a..44b7388 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -308,6 +308,7 @@ Offset Description Controlling config 6f0000 MRC cache CONFIG_ENABLE_MRC_CACHE 700000 u-boot-dtb.bin CONFIG_SYS_TEXT_BASE 790000 vga.bin CONFIG_VGA_BIOS_ADDR +7a0000 mrc.bin CONFIG_X86_MRC_ADDR 7c0000 fsp.bin CONFIG_FSP_ADDR 7f8000 <spare> (depends on size of fsp.bin) 7ff800 U-Boot 16-bit boot CONFIG_SYS_X86_START16
It's not clear how we would handle graphics init in 64-bit mode. Probably we would need to change back to 32-bit or 16-bit to run the graphics ROM. For now, disable it in 64-bit mode.
arch/x86/cpu/ivybridge/Makefile | 2 +- arch/x86/cpu/ivybridge/bd82x6x.c | 4 ++++ 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/ivybridge/Makefile b/arch/x86/cpu/ivybridge/Makefile index a853e45..96185d2 100644 --- a/arch/x86/cpu/ivybridge/Makefile +++ b/arch/x86/cpu/ivybridge/Makefile @@ -9,7 +9,7 @@ obj-y += fsp_configs.o ivybridge.o else obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += cpu.o obj-y += early_me.o -obj-y += gma.o +obj-$(CONFIG_X86_32BIT_INIT) += gma.o obj-y += lpc.o obj-y += model_206ax.o obj-y += northbridge.o diff --git a/arch/x86/cpu/ivybridge/bd82x6x.c b/arch/x86/cpu/ivybridge/bd82x6x.c index 3c5e159..cdab365 100644 --- a/arch/x86/cpu/ivybridge/bd82x6x.c +++ b/arch/x86/cpu/ivybridge/bd82x6x.c @@ -169,9 +169,13 @@ static int bd82x6x_probe(struct udevice *dev) ret = syscon_get_by_driver_data(X86_SYSCON_GMA, &gma_dev); if (ret) return ret; + + /* TODO(sjg@chromium.org): Handle graphics init in SPL or 64-bit mode */ +#ifndef CONFIG_X86_64 ret = gma_func0_init(gma_dev); if (ret) return ret; +#endif
return 0; }
This doesn't work at present. Disable it for now.
arch/x86/cpu/ivybridge/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/x86/cpu/ivybridge/Makefile b/arch/x86/cpu/ivybridge/Makefile index 96185d2..8bebcf8 100644 --- a/arch/x86/cpu/ivybridge/Makefile +++ b/arch/x86/cpu/ivybridge/Makefile @@ -13,7 +13,9 @@ obj-$(CONFIG_X86_32BIT_INIT) += gma.o obj-y += lpc.o obj-y += model_206ax.o obj-y += northbridge.o +ifndef CONFIG_SPL_BUILD obj-y += sata.o +endif obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += sdram.o endif obj-y += bd82x6x.o
We don't support SDRAM init in 64-bit mode since it is essentially impossible to get into that mode before SDRAM set up. Provide dummy functions for now. At some point we will need to pass the SDRAM parameters through from SPL.
arch/x86/cpu/ivybridge/Makefile | 3 +++ arch/x86/cpu/ivybridge/sdram_nop.c | 29 +++++++++++++++++++++++++++++ 2 files changed, 32 insertions(+) create mode 100644 arch/x86/cpu/ivybridge/sdram_nop.c
diff --git a/arch/x86/cpu/ivybridge/Makefile b/arch/x86/cpu/ivybridge/Makefile index 8bebcf8..2de11fc 100644 --- a/arch/x86/cpu/ivybridge/Makefile +++ b/arch/x86/cpu/ivybridge/Makefile @@ -17,5 +17,8 @@ ifndef CONFIG_SPL_BUILD obj-y += sata.o endif obj-$(CONFIG_$(SPL_)X86_32BIT_INIT) += sdram.o +ifndef CONFIG_$(SPL_)X86_32BIT_INIT +obj-y += sdram_nop.o +endif endif obj-y += bd82x6x.o diff --git a/arch/x86/cpu/ivybridge/sdram_nop.c b/arch/x86/cpu/ivybridge/sdram_nop.c new file mode 100644 index 0000000..edb3cb1 --- /dev/null +++ b/arch/x86/cpu/ivybridge/sdram_nop.c @@ -0,0 +1,29 @@ +/* + * Copyright (c) 2016 Google, Inc + * + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->ram_size = 1ULL << 31; + gd->bd->bi_dram[0].start = 0; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + +int misc_init_r(void) +{ + return 0; +} + +int print_cpuinfo(void) +{ + return 0; +}
This is not supported, so disable it for now.
arch/x86/lib/Makefile | 2 ++ drivers/pci/pci_rom.c | 2 +- 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 1fa7f90..ad3200a 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -5,9 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifndef CONFIG_X86_64 obj-y += bios.o obj-y += bios_asm.o obj-y += bios_interrupts.o +endif obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-y += cmd_boot.o obj-$(CONFIG_SEABIOS) += coreboot_table.o diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 399055b..aa28752 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -333,7 +333,7 @@ int dm_pci_run_vga_bios(struct udevice *dev, int (*int15_handler)(void), goto err; #endif } else { -#ifdef CONFIG_X86 +#if defined(CONFIG_X86) && CONFIG_IS_ENABLED(X86_32BIT_INIT) bios_set_interrupt_handler(0x15, int15_handler);
bios_run_on_x86(dev, (unsigned long)ram, vesa_mode,
These are currently not supported. Calling 64-bit code from 64-bit U-Boot is much simpler, so this code is not needed. setjmp() is not yet implemented for 64-bit.
arch/x86/cpu/Makefile | 6 +++++- arch/x86/lib/bootm.c | 2 ++ 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 7f89ff0..f0135a7 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -14,7 +14,11 @@ else extra-y = start.o endif extra-$(CONFIG_$(SPL_)X86_16BIT_INIT) += resetvec.o start16.o -obj-y += cpu.o cpu_x86.o call64.o setjmp.o +ifndef CONFIG_$(SPL_)X86_64 +obj-y += call64.o setjmp.o +endif + +obj-y += cpu.o cpu_x86.o
AFLAGS_REMOVE_call32.o := -mregparm=3 \ $(if $(CONFIG_EFI_STUB_64BIT),-march=i386 -m32) diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 7cf9de4..b7ed1e6 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -146,7 +146,9 @@ int boot_linux_kernel(ulong setup_base, ulong load_address, bool image_64bit) puts("Cannot boot 64-bit kernel on 32-bit machine\n"); return -EFAULT; } +#if !CONFIG_IS_ENABLED(X86_64) return cpu_jump_to_64bit(setup_base, load_address); +#endif } else { /* * Set %ebx, %ebp, and %edi to 0, %esi to point to the
Some files cannot be built with 64-bit and mostly don't make sense in that context. Disable them.
arch/x86/cpu/Makefile | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index f0135a7..6889df3 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -20,11 +20,13 @@ endif
+ifndef CONFIG_$(SPL_)X86_64 AFLAGS_REMOVE_call32.o := -mregparm=3 \ $(if $(CONFIG_EFI_STUB_64BIT),-march=i386 -m32) AFLAGS_call32.o := -fpic -fshort-wchar
extra-y += call32.o +endif
obj-y += intel_common/ obj-$(CONFIG_INTEL_BAYTRAIL) += baytrail/ @@ -35,11 +37,16 @@ obj-$(CONFIG_QEMU) += qemu/ obj-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE) += ivybridge/ obj-$(CONFIG_INTEL_QUARK) += quark/ obj-$(CONFIG_INTEL_QUEENSBAY) += queensbay/ -obj-y += irq.o lapic.o ioapic.o +obj-y += lapic.o ioapic.o +ifndef CONFIG_$(SPL_)X86_64 +obj-y += irq.o obj-$(CONFIG_SMP) += mp_init.o +endif obj-y += mtrr.o obj-$(CONFIG_PCI) += pci.o +ifndef CONFIG_$(SPL_)X86_64 obj-$(CONFIG_SMP) += sipi_vector.o +endif obj-y += turbo.o
Booting into linux from 64-bit U-Boot is not yet supported. Avoid bringing in the bootm code until it is implemented.
Of course 32-bit U-Boot still supported booting into both 32- and 64-bit kernels.
arch/x86/lib/Makefile | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index ad3200a..7f6d12a 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -10,7 +10,9 @@ obj-y += bios.o obj-y += bios_asm.o obj-y += bios_interrupts.o endif +ifndef CONFIG_SPL_BUILD obj-$(CONFIG_CMD_BOOTM) += bootm.o +endif obj-y += cmd_boot.o obj-$(CONFIG_SEABIOS) += coreboot_table.o obj-$(CONFIG_EFI) += efi/ @@ -41,7 +43,9 @@ ifndef CONFIG_QEMU obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o endif obj-y += tables.o +ifndef CONFIG_SPL_BUILD obj-$(CONFIG_CMD_ZBOOT) += zimage.o +endif obj-$(CONFIG_HAVE_FSP) += fsp/ obj-$(CONFIG_SPL_BUILD) += spl.o
This is not currently supported, so drop the code.
arch/x86/lib/interrupts.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/x86/lib/interrupts.c b/arch/x86/lib/interrupts.c index dd08402..d3ae6d9 100644 --- a/arch/x86/lib/interrupts.c +++ b/arch/x86/lib/interrupts.c @@ -33,6 +33,8 @@ #include <common.h> #include <asm/interrupt.h>
+#if !CONFIG_IS_ENABLED(X86_64) + struct irq_action { interrupt_handler_t *handler; void *arg; @@ -118,10 +120,12 @@ void do_irq(int hw_irq) } } } +#endif
#if defined(CONFIG_CMD_IRQ) int do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { +#if !CONFIG_IS_ENABLED(X86_64) int irq;
printf("Spurious IRQ: %u, last unknown IRQ: %d\n", @@ -139,6 +143,7 @@ int do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) irq_handlers[irq].count); } } +#endif
return 0; }
Add a rough function to handle jumping from 32-bit SPL to 64-bit U-Boot. This still needs work to clean it up.
arch/x86/cpu/call64.S | 3 +++ arch/x86/cpu/i386/cpu.c | 65 ++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/cpu.h | 9 +++++++ 3 files changed, 77 insertions(+)
diff --git a/arch/x86/cpu/call64.S b/arch/x86/cpu/call64.S index 08dc473..970c461 100644 --- a/arch/x86/cpu/call64.S +++ b/arch/x86/cpu/call64.S @@ -81,6 +81,9 @@ lret_target: jmp *%eax /* Jump to the 64-bit target */
.data + .align 16 + .globl gdt64 +gdt64: gdt: .word gdt_end - gdt - 1 .long gdt /* Fixed up by code above */ diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index 09a5b91..ddbf367 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -503,6 +503,71 @@ int cpu_jump_to_64bit(ulong setup_base, ulong target) return -EFAULT; }
+/* + * Jump from SPL to U-Boot + * + * This function is work-in-progress with many issues to resolve. + * + * It works by setting up several regions: + * ptr - a place to put the code that jumps into 64-bit mode + * gdt - a place to put the global descriptor table + * pgtable - a place to put the page tables + * + * The cpu_call64() code is copied from ROM and then manually patched so that + * it has the correct GDT address in RAM. U-Boot is copied from ROM into + * its pre-relocation address. Then we jump to the cpu_call64() code in RAM, + * which changes to 64-bit mode and starts U-Boot. + */ +int cpu_jump_to_64bit_uboot(ulong target) +{ + typedef void (*func_t)(ulong pgtable, ulong setup_base, ulong target); + void target64(void); + uint32_t *pgtable; + func_t func; + + /* TODO(sjg@chromium.org): Find a better place for this */ + pgtable = (uint32_t *)0x1000000; + if (!pgtable) + return -ENOMEM; + + build_pagetable(pgtable); + + /* TODO(sjg@chromium.org): Find a better place for this */ + char *ptr = (char *)0x3000000; + char *gdt = (char *)0x3100000; + + extern char gdt64[]; + + memcpy(ptr, cpu_call64, 0x1000); + memcpy(gdt, gdt64, 0x100); + + /* + * TODO(sjg@chromium.org): This manually inserts the pointers into + * the code. Tidy this up to avoid this. + */ + func = (func_t)ptr; + ulong ofs = (ulong)cpu_call64 - (ulong)ptr; + *(ulong *)(ptr + 7) = (ulong)gdt; + *(ulong *)(ptr + 0xc) = (ulong)gdt + 2; + *(ulong *)(ptr + 0x13) = (ulong)gdt; + *(ulong *)(ptr + 0x117 - 0xd4) -= ofs; + + /* + * Copy U-Boot from ROM + * TODO(sjg@chromium.org): Figure out a way to get the text base + * correctly here, and in the device-tree binman definition. + * + * Also consider using FIT so we get the correct image length and + * parameters. + */ + memcpy((char *)target, (char *)0xfff00000, 0x100000); + + /* Jump to U-Boot */ + func((ulong)pgtable, 0, (ulong)target); + + return -EFAULT; +} + #ifdef CONFIG_SMP static int enable_smis(struct udevice *cpu, void *unused) { diff --git a/arch/x86/include/asm/cpu.h b/arch/x86/include/asm/cpu.h index 9a8ae2a..cd55201 100644 --- a/arch/x86/include/asm/cpu.h +++ b/arch/x86/include/asm/cpu.h @@ -265,6 +265,15 @@ void cpu_call32(ulong code_seg32, ulong target, ulong table); int cpu_jump_to_64bit(ulong setup_base, ulong target);
/** + * cpu_jump_to_64bit_uboot() - special function to jump from SPL to U-Boot + * + * This handles calling from 32-bit SPL to 64-bit U-Boot. + * + * @target: Address of U-Boot in RAM + */ +int cpu_jump_to_64bit_uboot(ulong target); + +/** * cpu_get_family_model() - Get the family and model for the CPU * * @return the CPU ID masked with 0x0fff0ff0
To avoid using BSS in SPL before SDRAM is set up, move this field to global_data.
arch/x86/cpu/irq.c | 12 +++++------- arch/x86/include/asm/global_data.h | 1 + 2 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/arch/x86/cpu/irq.c b/arch/x86/cpu/irq.c index 516d84a..cfa3dd9 100644 --- a/arch/x86/cpu/irq.c +++ b/arch/x86/cpu/irq.c @@ -17,8 +17,6 @@
-static struct irq_routing_table *pirq_routing_table; - bool pirq_check_irq_routed(struct udevice *dev, int link, u8 irq) { struct irq_router *priv = dev_get_priv(dev); @@ -218,7 +216,7 @@ static int create_pirq_routing_table(struct udevice *dev) /* Fix up the table checksum */ rt->checksum = table_compute_checksum(rt, rt->size);
- pirq_routing_table = rt; + gd->arch.pirq_routing_table = rt;
return 0; } @@ -249,8 +247,8 @@ int irq_router_common_init(struct udevice *dev) return ret; } /* Route PIRQ */ - pirq_route_irqs(dev, pirq_routing_table->slots, - get_irq_slot_count(pirq_routing_table)); + pirq_route_irqs(dev, gd->arch.pirq_routing_table->slots, + get_irq_slot_count(gd->arch.pirq_routing_table));
if (IS_ENABLED(CONFIG_GENERATE_ACPI_TABLE)) irq_enable_sci(dev); @@ -265,10 +263,10 @@ int irq_router_probe(struct udevice *dev)
ulong write_pirq_routing_table(ulong addr) { - if (!pirq_routing_table) + if (!gd->arch.pirq_routing_table) return addr;
- return copy_pirq_routing_table(addr, pirq_routing_table); + return copy_pirq_routing_table(addr, gd->arch.pirq_routing_table); }
static const struct udevice_id irq_router_ids[] = { diff --git a/arch/x86/include/asm/global_data.h b/arch/x86/include/asm/global_data.h index ce9e5cc..e24cee7 100644 --- a/arch/x86/include/asm/global_data.h +++ b/arch/x86/include/asm/global_data.h @@ -93,6 +93,7 @@ struct arch_global_data { char *mrc_output; unsigned int mrc_output_len; ulong table; /* Table pointer from previous loader */ + struct irq_routing_table *pirq_routing_table; #ifdef CONFIG_SEABIOS u32 high_table_ptr; u32 high_table_limit;
arch/x86/cpu/turbo.c | 8 ++++---- arch/x86/include/asm/global_data.h | 1 + 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/x86/cpu/turbo.c b/arch/x86/cpu/turbo.c index 254d0de..bbd255e 100644 --- a/arch/x86/cpu/turbo.c +++ b/arch/x86/cpu/turbo.c @@ -12,6 +12,8 @@ #include <asm/processor.h> #include <asm/turbo.h>
+DECLARE_GLOBAL_DATA_PTR; + #if CONFIG_CPU_INTEL_TURBO_NOT_PACKAGE_SCOPED static inline int get_global_turbo_state(void) { @@ -22,16 +24,14 @@ static inline void set_global_turbo_state(int state) { } #else -static int g_turbo_state = TURBO_UNKNOWN; - static inline int get_global_turbo_state(void) { - return g_turbo_state; + return gd->arch.turbo_state; }
static inline void set_global_turbo_state(int state) { - g_turbo_state = state; + gd->arch.turbo_state = state; } #endif
diff --git a/arch/x86/include/asm/global_data.h b/arch/x86/include/asm/global_data.h index e24cee7..0fadfc6 100644 --- a/arch/x86/include/asm/global_data.h +++ b/arch/x86/include/asm/global_data.h @@ -93,6 +93,7 @@ struct arch_global_data { char *mrc_output; unsigned int mrc_output_len; ulong table; /* Table pointer from previous loader */ + int turbo_state; /* Current turbo state */ struct irq_routing_table *pirq_routing_table; #ifdef CONFIG_SEABIOS u32 high_table_ptr;
This avoids using BSS before SDRAM is set up in SPL.
arch/x86/lib/pirq_routing.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/x86/lib/pirq_routing.c b/arch/x86/lib/pirq_routing.c index c98526d..5df3cab 100644 --- a/arch/x86/lib/pirq_routing.c +++ b/arch/x86/lib/pirq_routing.c @@ -11,9 +11,8 @@ #include <asm/pci.h> #include <asm/pirq_routing.h>
-static bool irq_already_routed[16]; - -static u8 pirq_get_next_free_irq(struct udevice *dev, u8 *pirq, u16 bitmap) +static u8 pirq_get_next_free_irq(struct udevice *dev, u8 *pirq, u16 bitmap, + bool irq_already_routed[]) { int i, link; u8 irq = 0; @@ -55,9 +54,11 @@ void pirq_route_irqs(struct udevice *dev, struct irq_info *irq, int num) { unsigned char irq_slot[MAX_INTX_ENTRIES]; unsigned char pirq[CONFIG_MAX_PIRQ_LINKS]; + bool irq_already_routed[16]; int i, intx;
memset(pirq, 0, CONFIG_MAX_PIRQ_LINKS); + memset(irq_already_routed, '\0', sizeof(irq_already_routed));
/* Set PCI IRQs */ for (i = 0; i < num; i++) { @@ -83,7 +84,8 @@ void pirq_route_irqs(struct udevice *dev, struct irq_info *irq, int num)
/* yet not routed */ if (!pirq[link]) { - irq = pirq_get_next_free_irq(dev, pirq, bitmap); + irq = pirq_get_next_free_irq(dev, pirq, bitmap, + irq_already_routed); pirq[link] = irq; } else { irq = pirq[link];
This code is only used in 32-bit mode. Move it so that it does not get built with 64-bit U-Boot.
arch/x86/cpu/Makefile | 2 +- arch/x86/cpu/i386/Makefile | 1 + arch/x86/cpu/{ => i386}/call64.S | 0 3 files changed, 2 insertions(+), 1 deletion(-) rename arch/x86/cpu/{ => i386}/call64.S (100%)
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 6889df3..2fda32d 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -15,7 +15,7 @@ extra-y = start.o endif extra-$(CONFIG_$(SPL_)X86_16BIT_INIT) += resetvec.o start16.o ifndef CONFIG_$(SPL_)X86_64 -obj-y += call64.o setjmp.o +obj-y += setjmp.o endif
obj-y += cpu.o cpu_x86.o diff --git a/arch/x86/cpu/i386/Makefile b/arch/x86/cpu/i386/Makefile index d336495..2547bba 100644 --- a/arch/x86/cpu/i386/Makefile +++ b/arch/x86/cpu/i386/Makefile @@ -3,5 +3,6 @@ # Written by Simon Glass sjg@chromium.org #
+obj-y += call64.o obj-y += cpu.o obj-y += interrupt.o diff --git a/arch/x86/cpu/call64.S b/arch/x86/cpu/i386/call64.S similarity index 100% rename from arch/x86/cpu/call64.S rename to arch/x86/cpu/i386/call64.S
arch/x86/cpu/Makefile | 3 --- arch/x86/cpu/i386/Makefile | 1 + arch/x86/cpu/{ => i386}/setjmp.S | 0 3 files changed, 1 insertion(+), 3 deletions(-) rename arch/x86/cpu/{ => i386}/setjmp.S (100%)
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 2fda32d..45f95ab 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -14,9 +14,6 @@ else extra-y = start.o endif extra-$(CONFIG_$(SPL_)X86_16BIT_INIT) += resetvec.o start16.o -ifndef CONFIG_$(SPL_)X86_64 -obj-y += setjmp.o -endif
diff --git a/arch/x86/cpu/i386/Makefile b/arch/x86/cpu/i386/Makefile index 2547bba..0c47252 100644 --- a/arch/x86/cpu/i386/Makefile +++ b/arch/x86/cpu/i386/Makefile @@ -6,3 +6,4 @@ obj-y += call64.o obj-y += cpu.o obj-y += interrupt.o +obj-y += setjmp.o diff --git a/arch/x86/cpu/setjmp.S b/arch/x86/cpu/i386/setjmp.S similarity index 100% rename from arch/x86/cpu/setjmp.S rename to arch/x86/cpu/i386/setjmp.S
We don't have the code for this yet. Add a dummy version for now, so that EFI builds correctly.
arch/x86/cpu/x86_64/Makefile | 2 +- arch/x86/cpu/x86_64/setjmp.c | 20 ++++++++++++++++++++ 2 files changed, 21 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/x86_64/setjmp.c
diff --git a/arch/x86/cpu/x86_64/Makefile b/arch/x86/cpu/x86_64/Makefile index 4b06386..400f0ff 100644 --- a/arch/x86/cpu/x86_64/Makefile +++ b/arch/x86/cpu/x86_64/Makefile @@ -3,4 +3,4 @@ # Written by Simon Glass sjg@chromium.org #
-obj-y += cpu.o interrupts.o +obj-y += cpu.o interrupts.o setjmp.o diff --git a/arch/x86/cpu/x86_64/setjmp.c b/arch/x86/cpu/x86_64/setjmp.c new file mode 100644 index 0000000..5321292 --- /dev/null +++ b/arch/x86/cpu/x86_64/setjmp.c @@ -0,0 +1,20 @@ +/* + * Copyright (c) 2016 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/setjmp.h> + +int setjmp(struct jmp_buf_data *jmp_buf) +{ + printf("WARNING: setjmp() is not supported\n"); + + return 0; +} + +void longjmp(struct jmp_buf_data *jmp_buf) +{ + printf("WARNING: longjmp() is not supported\n"); +}
Set up the 64-bit U-Boot text base if building for that target.
board/google/chromebook_link/Kconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/google/chromebook_link/Kconfig b/board/google/chromebook_link/Kconfig index fa12f33..5c57945 100644 --- a/board/google/chromebook_link/Kconfig +++ b/board/google/chromebook_link/Kconfig @@ -13,7 +13,8 @@ config SYS_CONFIG_NAME default "chromebook_link"
config SYS_TEXT_BASE - default 0xfff00000 + default 0xfff00000 if !SUPPORT_SPL + default 0x10000000 if SUPPORT_SPL
config BOARD_SPECIFIC_OPTIONS # dummy def_bool y
When building for 64-bit we need to put an SPL binary into the image. Update the binman image description to reflect this.
arch/x86/dts/binman.dtsi | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/arch/x86/dts/binman.dtsi b/arch/x86/dts/binman.dtsi index 724913f..35a7685 100644 --- a/arch/x86/dts/binman.dtsi +++ b/arch/x86/dts/binman.dtsi @@ -21,9 +21,22 @@ intel-me { }; #endif +#ifdef CONFIG_SPL + u-boot-spl-with-ucode-ptr { + pos = <CONFIG_SPL_TEXT_BASE>; + }; + + u-boot-dtb-with-ucode2 { + type = "u-boot-dtb-with-ucode"; + }; + u-boot { + pos = <0xfff00000>; + }; +#else u-boot-with-ucode-ptr { pos = <CONFIG_SYS_TEXT_BASE>; }; +#endif u-boot-dtb-with-ucode { }; u-boot-ucode { @@ -54,9 +67,15 @@ pos = <CONFIG_X86_REFCODE_ADDR>; }; #endif +#ifdef CONFIG_SPL + x86-start16-spl { + pos = <CONFIG_SYS_X86_START16>; + }; +#else x86-start16 { pos = <CONFIG_SYS_X86_START16>; }; +#endif }; }; #endif
Add the correct pre-relocation tag so that the required device tree nodes are present in the SPL device tree.
On x86 it doesn't make a lot of sense to have a separate SPL device tree. Since everything is in the same ROM we might as well just use the main device tree in both SPL and U-Boot proper. But we haven't implemented that, so this is a good first step.
arch/x86/dts/chromebook_link.dts | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/arch/x86/dts/chromebook_link.dts b/arch/x86/dts/chromebook_link.dts index 9deb56c..fad9a11 100644 --- a/arch/x86/dts/chromebook_link.dts +++ b/arch/x86/dts/chromebook_link.dts @@ -26,12 +26,14 @@ cpus { #address-cells = <1>; #size-cells = <0>; + u-boot,dm-pre-reloc;
cpu@0 { device_type = "cpu"; compatible = "intel,core-gen3"; reg = <0>; intel,apic-id = <0>; + u-boot,dm-pre-reloc; };
cpu@1 { @@ -39,6 +41,7 @@ compatible = "intel,core-gen3"; reg = <1>; intel,apic-id = <1>; + u-boot,dm-pre-reloc; };
cpu@2 { @@ -46,6 +49,7 @@ compatible = "intel,core-gen3"; reg = <2>; intel,apic-id = <2>; + u-boot,dm-pre-reloc; };
cpu@3 { @@ -53,6 +57,7 @@ compatible = "intel,core-gen3"; reg = <3>; intel,apic-id = <3>; + u-boot,dm-pre-reloc; };
}; @@ -229,14 +234,16 @@
northbridge@0,0 { reg = <0x00000000 0 0 0 0>; + u-boot,dm-pre-reloc; compatible = "intel,bd82x6x-northbridge"; board-id-gpios = <&gpio_b 9 0>, <&gpio_b 10 0>, <&gpio_b 11 0>, <&gpio_a 10 0>; - u-boot,dm-pre-reloc; spd { + u-boot,dm-pre-reloc; #address-cells = <1>; #size-cells = <0>; elpida_4Gb_1600_x16 { + u-boot,dm-pre-reloc; reg = <0>; data = [92 10 0b 03 04 19 02 02 03 52 01 08 0a 00 fe 00 @@ -272,6 +279,7 @@ 00 00 00 00 00 00 00 00]; }; samsung_4Gb_1600_1.35v_x16 { + u-boot,dm-pre-reloc; reg = <1>; data = [92 11 0b 03 04 19 02 02 03 11 01 08 0a 00 fe 00 @@ -391,9 +399,11 @@ #address-cells = <1>; #size-cells = <0>; compatible = "intel,ich9-spi"; + u-boot,dm-pre-reloc; spi-flash@0 { #size-cells = <1>; #address-cells = <1>; + u-boot,dm-pre-reloc; reg = <0>; compatible = "winbond,w25q64", "spi-flash"; @@ -401,6 +411,7 @@ rw-mrc-cache { label = "rw-mrc-cache"; reg = <0x003e0000 0x00010000>; + u-boot,dm-pre-reloc; }; }; }; @@ -478,7 +489,9 @@ };
microcode { + u-boot,dm-pre-reloc; update@0 { + u-boot,dm-pre-reloc; #include "microcode/m12306a9_0000001b.dtsi" }; };
If SPL is used we want to use the generic SPL framework and boot from SPI via a board-specific means. Add these options to the board config file.
configs/chromebook_link_defconfig | 21 ++++++++++++++++++++- include/configs/chromebook_link.h | 9 +++++++++ 2 files changed, 29 insertions(+), 1 deletion(-)
diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 34ce36b..ff28fb8 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -1,5 +1,12 @@ CONFIG_X86=y -CONFIG_SYS_MALLOC_F_LEN=0x1800 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y CONFIG_VIDEO=y CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebook_link" @@ -9,10 +16,18 @@ CONFIG_HAVE_MRC=y CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_CPU_SUPPORT=y +CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_PCI_SUPPORT=y +CONFIG_SPL_PCH_SUPPORT=y +CONFIG_SPL_RTC_SUPPORT=y +CONFIG_SPL_TIMER_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set @@ -35,8 +50,12 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_DM=y CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_INTEL=y diff --git a/include/configs/chromebook_link.h b/include/configs/chromebook_link.h index f2d798a..b116a27 100644 --- a/include/configs/chromebook_link.h +++ b/include/configs/chromebook_link.h @@ -19,4 +19,13 @@ #define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_ENV_OFFSET 0x003f8000
+#define CONFIG_SPL_FRAMEWORK + +#define CONFIG_SPL_TEXT_BASE 0xfffd0000 + +#define BOOT_DEVICE_SPI 10 + +#define CONFIG_SPL_BOARD_LOAD_IMAGE +#define BOOT_DEVICE_BOARD 11 + #endif /* __CONFIG_H */
Update config.mk settings to support both 32-bit and 64-bit U-Boot.
arch/x86/config.mk | 30 ++++++++++++++++++++++++++++-- arch/x86/cpu/config.mk | 2 -- 2 files changed, 28 insertions(+), 4 deletions(-)
diff --git a/arch/x86/config.mk b/arch/x86/config.mk index d7addd8..cd6ddef 100644 --- a/arch/x86/config.mk +++ b/arch/x86/config.mk @@ -15,11 +15,25 @@ PF_CPPFLAGS_X86 := $(call cc-option, -fno-toplevel-reorder, \
PLATFORM_CPPFLAGS += $(PF_CPPFLAGS_X86) PLATFORM_CPPFLAGS += -fno-dwarf2-cfi-asm + +ifdef CONFIG_SPL_BUILD +IS_32BIT := y +else +ifndef CONFIG_X86_64 +IS_32BIT := y +endif +endif + +ifeq ($(IS_32BIT),y) PLATFORM_CPPFLAGS += -march=i386 -m32 +else +PLATFORM_CPPFLAGS += $(if $(CONFIG_SPL_BUILD),,-fpic) -fno-common +endif
PLATFORM_RELFLAGS += -ffunction-sections -fvisibility=hidden
-PLATFORM_LDFLAGS += -Bsymbolic -Bsymbolic-functions -m elf_i386 +PLATFORM_LDFLAGS += -Bsymbolic -Bsymbolic-functions +PLATFORM_LDFLAGS += -m $(if $(IS_32BIT),elf_i386,elf_x86_64)
LDFLAGS_FINAL += --wrap=__divdi3 --wrap=__udivdi3 LDFLAGS_FINAL += --wrap=__moddi3 --wrap=__umoddi3 @@ -31,7 +45,9 @@ LDFLAGS_EFI_PAYLOAD := -Bsymbolic -Bsymbolic-functions -shared --no-undefined OBJCOPYFLAGS_EFI := -j .text -j .sdata -j .data -j .dynamic -j .dynsym \ -j .rel -j .rela -j .reloc
+ifeq ($(IS_32BIT),y) CFLAGS_NON_EFI := -mregparm=3 +endif CFLAGS_EFI := -fpic -fshort-wchar
ifeq ($(CONFIG_EFI_STUB_64BIT),) @@ -62,6 +78,16 @@ else
PLATFORM_CPPFLAGS += $(CFLAGS_NON_EFI) PLATFORM_LDFLAGS += --emit-relocs -LDFLAGS_FINAL += --gc-sections -pie +LDFLAGS_FINAL += --gc-sections $(if $(CONFIG_SPL_BUILD),,-pie) + +endif
+ifdef CONFIG_X86_64 +ifndef CONFIG_SPL_BUILD +PLATFORM_CPPFLAGS += -D__x86_64__ +else +PLATFORM_CPPFLAGS += -D__I386__ +endif +else +PLATFORM_CPPFLAGS += -D__I386__ endif diff --git a/arch/x86/cpu/config.mk b/arch/x86/cpu/config.mk index 4c99a35..b519f43 100644 --- a/arch/x86/cpu/config.mk +++ b/arch/x86/cpu/config.mk @@ -7,8 +7,6 @@
CROSS_COMPILE ?= i386-linux-
-PLATFORM_CPPFLAGS += -D__I386__ - # DO NOT MODIFY THE FOLLOWING UNLESS YOU REALLY KNOW WHAT YOU ARE DOING! LDPPFLAGS += -DRESET_SEG_START=$(CONFIG_RESET_SEG_START) LDPPFLAGS += -DRESET_SEG_SIZE=$(CONFIG_RESET_SEG_SIZE)
Change link to use 64-bit U-Boot. This is not fully functional but is it a start. Missing features:
- SDRAM sizing - Booting linux - EFI support - SCSI device init (and others)
configs/chromebook_link_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index ff28fb8..2b94d1e 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_VIDEO=y +CONFIG_X86_RUN_64BIT=y CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebook_link" CONFIG_TARGET_CHROMEBOOK_LINK=y
Hi Simon,
On Mon, Sep 26, 2016 at 11:33 AM, Simon Glass sjg@chromium.org wrote:
At present U-Boot runs entirely in 32-bit mode on x86, except for the initial switch from 16-bit mode. On 64-bit machines it is possible to run in 64-bit mode. This series starts the process of adding this support.
The main benefit of 64-bit mode for a boot loader is direct access to all available memory. There are also more registers, but this makes very little difference.
This feature is implemented by putting all of the 32-bit code in an SPL build. SPL then runs through all the init that has to be done in 32-bit mode, changes to 64-bit mode and then jumps to U-Boot proper.
Typically the total code size increases slightly. For example, on link in 32-bit mode, U-Boot has around 480KB of code (admittedly with a large number of features enabled). In 64-bit mode, U-Boot falls to around 460KB, but SPL adds another 60KB, for a net increase of 40KB. Partly this is due to code duplication and partly it is due to the worse code density of 64-bit code on x86.
Many major features are not implemented yet, for example:
- SDRAM sizing
- Booting linux
- FSP support
- EFI support
- SCSI device init
- Running video ROMs
Still, this is a big step forward towards full 64-bit support. To enable it, select CONFIG_X86_RUN_64BIT.
This series is available at u-boot-x86/64-working
Looks it requires a 64-bit toolchain to compile 64-bit U-Boot. For example, I used kernel.org i386 toolchain to compile 64-bit U-Boot, I got:
include/asm-generic/bitops/__fls.h: In function '__fls': include/asm-generic/bitops/__fls.h:17:2: warning: left shift count >= width of type if (!(word & (~0ul << 32))) { ^ include/asm-generic/bitops/__fls.h:19:3: warning: left shift count >= width of type word <<= 32; ^ include/asm-generic/bitops/__fls.h:22:2: warning: left shift count >= width of type if (!(word & (~0ul << (BITS_PER_LONG-16)))) { ^ include/asm-generic/bitops/__fls.h:26:2: warning: left shift count >= width of type if (!(word & (~0ul << (BITS_PER_LONG-8)))) { ^ include/asm-generic/bitops/__fls.h:30:2: warning: left shift count >= width of type if (!(word & (~0ul << (BITS_PER_LONG-4)))) { ^ include/asm-generic/bitops/__fls.h:34:2: warning: left shift count >= width of type if (!(word & (~0ul << (BITS_PER_LONG-2)))) { ^ include/asm-generic/bitops/__fls.h:38:2: warning: left shift count >= width of type if (!(word & (~0ul << (BITS_PER_LONG-1)))) ^ arch/x86/cpu/intel_common/microcode.c: In function 'microcode_read_rev': arch/x86/cpu/intel_common/microcode.c:79:2: error: PIC register clobbered by 'ebx' in 'asm' asm volatile ( ^ make[2]: *** [arch/x86/cpu/intel_common/microcode.o] Error 1
After I switched to 64-bit toolchain from kernel.org (x86_64-linux), there was no such warnings/errors, but I still got build failure at last.
./tools/binman/binman -d u-boot.dtb -O . -I . -I ./board/google/chromebook_link u-boot-x86-16bit.bin Traceback (most recent call last): File "./tools/binman/binman", line 31, in <module> import control File "./tools/binman/control.py", line 17, in <module> from image import Image File "./tools/binman/image.py", line 12, in <module> import entry File "./tools/binman/etype/entry.py", line 8, in <module> import importlib ImportError: No module named importlib make: *** [u-boot.rom] Error 1
Regards, Bin
Hi Bin,
On 10 October 2016 at 23:36, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
- SDRAM sizing
- Booting linux
- FSP support
- EFI support
- SCSI device init
Yes, that is expected.
What version of python do you use?
Hi Simon,
On Tue, Oct 18, 2016 at 6:17 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
- SDRAM sizing
- Booting linux
- FSP support
- EFI support
- SCSI device init
Can we make the i386 toolchain work? Linux 64-bit kernel build does not require the toolchain to be 64-bit.
$ python -V Python 2.7.12
Regards, Bin
Hi Bin,
On 17 October 2016 at 19:25, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
- SDRAM sizing
- Booting linux
- FSP support
- EFI support
- SCSI device init
I can fix the header file warnings, but things like pushq do not seem to be supported on the i386 toolchain. Perhaps this is something to look at later.
I thought importlib was implemented in 2.7 (I am using 2.7.6 which is older). But I'll add a work-around for this as it seems I was wrong.
Bin Meng
Heiko Schocher
Jaehoon Chung
