[PATCH] binman: Complete elf test coverage
Add coverage for the new elf functions needed for the event_dump.py script.
tools/binman/elf.py | 4 ++-- tools/binman/elf_test.py | 37 +++++++++++++++++++++++++++++++++++++ 2 files changed, 39 insertions(+), 2 deletions(-)
diff --git a/tools/binman/elf.py b/tools/binman/elf.py index 940a476b931..afa05e58fdd 100644 --- a/tools/binman/elf.py +++ b/tools/binman/elf.py @@ -112,7 +112,7 @@ def GetFileOffset(fname, addr): int: Offset of that address in the ELF file, or None if not valid """ if not ELF_TOOLS: - raise ValueError('Python elftools package is not available') + raise ValueError("Python: No module named 'elftools'") with open(fname, 'rb') as fd: elf = ELFFile(fd) return _GetFileOffset(elf, addr) @@ -128,7 +128,7 @@ def GetSymbolFromAddress(fname, addr): str: Symbol name, or None if no symbol at that address """ if not ELF_TOOLS: - raise ValueError('Python elftools package is not available') + raise ValueError("Python: No module named 'elftools'") with open(fname, 'rb') as fd: elf = ELFFile(fd) syms = GetSymbols(fname, None) diff --git a/tools/binman/elf_test.py b/tools/binman/elf_test.py index 555117d33ac..9d4fb3aa3b3 100644 --- a/tools/binman/elf_test.py +++ b/tools/binman/elf_test.py @@ -284,6 +284,43 @@ class TestElf(unittest.TestCase): elf.read_loadable_segments(tools.get_bytes(100, 100)) self.assertIn('Magic number does not match', str(e.exception))
+ def test_get_file_offset(self): + """Test GetFileOffset()""" + fname = self.ElfTestFile('embed_data') + self.assertEqual(0x1000, elf.GetFileOffset(fname, 0)) + + def test_get_file_offset_fail(self): + """Test calling GetFileOffset() without elftools""" + try: + old_val = elf.ELF_TOOLS + elf.ELF_TOOLS = False + fname = self.ElfTestFile('embed_data') + with self.assertRaises(ValueError) as e: + elf.GetFileOffset(fname, 0) + self.assertIn("Python: No module named 'elftools'", + str(e.exception)) + finally: + elf.ELF_TOOLS = old_val + + def test_get_symbol_from_address(self): + """Test GetSymbolFromAddress()""" + fname = self.ElfTestFile('embed_data') + sym = elf.GetSymbolFromAddress(fname, 0x1000) + self.assertEqual('main', sym) + + def test_get_symbol_from_address_fail(self): + """Test calling GetSymbolFromAddress() without elftools""" + try: + old_val = elf.ELF_TOOLS + elf.ELF_TOOLS = False + fname = self.ElfTestFile('embed_data') + with self.assertRaises(ValueError) as e: + elf.GetSymbolFromAddress(fname, 0x1000) + self.assertIn("Python: No module named 'elftools'", + str(e.exception)) + finally: + elf.ELF_TOOLS = old_val +
if __name__ == '__main__': unittest.main()
