[U-Boot] [PATCH 1/1] efi_loader: use u16* for file name
UTF-16 strings in our code should all be u16 *. Fix an inconsistency for file names which may lead to a warning for printf("%ls", ).
Simon Glass sjg@chromium.org Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_api.h | 2 +- lib/efi_loader/efi_file.c | 14 +++++++------- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index 9b6b97457b..3b67920117 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -1151,7 +1151,7 @@ struct efi_file_handle { u64 rev; efi_status_t (EFIAPI *open)(struct efi_file_handle *file, struct efi_file_handle **new_handle, - s16 *file_name, u64 open_mode, u64 attributes); + u16 *file_name, u64 open_mode, u64 attributes); efi_status_t (EFIAPI *close)(struct efi_file_handle *file); efi_status_t (EFIAPI *delete)(struct efi_file_handle *file); efi_status_t (EFIAPI *read)(struct efi_file_handle *file, diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 128cb0a627..dfa61bc2bc 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -148,7 +148,7 @@ static int sanitize_path(char *path) * Returns: handle to the opened file or NULL */ static struct efi_file_handle *file_open(struct file_system *fs, - struct file_handle *parent, s16 *file_name, u64 mode, + struct file_handle *parent, u16 *file_name, u64 mode, u64 attributes) { struct file_handle *fh; @@ -157,8 +157,8 @@ static struct efi_file_handle *file_open(struct file_system *fs, int flen = 0;
if (file_name) { - utf16_to_utf8((u8 *)f0, (u16 *)file_name, 1); - flen = u16_strlen((u16 *)file_name); + utf16_to_utf8((u8 *)f0, file_name, 1); + flen = u16_strlen(file_name); }
/* we could have a parent, but also an absolute path: */ @@ -183,7 +183,7 @@ static struct efi_file_handle *file_open(struct file_system *fs, *p++ = '/'; }
- utf16_to_utf8((u8 *)p, (u16 *)file_name, flen); + utf16_to_utf8((u8 *)p, file_name, flen);
if (sanitize_path(fh->path)) goto error; @@ -216,7 +216,7 @@ error:
static efi_status_t EFIAPI efi_file_open(struct efi_file_handle *file, struct efi_file_handle **new_handle, - s16 *file_name, u64 open_mode, u64 attributes) + u16 *file_name, u64 open_mode, u64 attributes) { struct file_handle *fh = to_fh(file); efi_status_t ret; @@ -375,7 +375,7 @@ static efi_status_t dir_read(struct file_handle *fh, u64 *buffer_size, if (dent->type == FS_DT_DIR) info->attribute |= EFI_FILE_DIRECTORY;
- ascii2unicode((u16 *)info->file_name, dent->name); + ascii2unicode(info->file_name, dent->name);
fh->offset++;
@@ -666,7 +666,7 @@ struct efi_file_handle *efi_file_from_path(struct efi_device_path *fp) return NULL; }
- EFI_CALL(ret = f->open(f, &f2, (s16 *)fdp->str, + EFI_CALL(ret = f->open(f, &f2, fdp->str, EFI_FILE_MODE_READ, 0)); if (ret != EFI_SUCCESS) return NULL;
