[U-Boot] SPL: Reading large files with file_fat_read()
I need to read a file in spl.c, which is about 675 bytes. I used the following code:
static unsigned char helperData[675] = {0x00}; s32 err; uint8_t i = 0;
printf("\n[D] - Reading Helper Data\r\n\n"); err = file_fat_read(filename, helperData, length); if(err > 0){ printf("[D] - Received Helper Data (%d bytes):\n", err); for(i = 0; i < err; i++){ if((i%9==0)&&i>0) printf("\n"); printf("0x%02x ", helperData[i]); } }else{ printf("[E] - Error reading Helper Data file %s from MMC\n", filename); } puts("");
However, during boot time it stucks while reading the file. It only outputs:
reading foo.bar
It works with smaller files fine. Do I need to implement changes to do_fat_read() in fat.c or what could be the problem?
Best regards, -b
bin4ry
