[U-Boot] [PATCH] tegra: nand: make ONFI detection work
Add the missing bits to the Tegra NAND driver to make ONFI detection work properly.
Also add it to the Tegra default config, as it seems to be a reasonable thing to have it available on all boards that use any kind of NAND.
Signed-off-by: Lucas Stach dev@lynxeye.de --- drivers/mtd/nand/tegra_nand.c | 36 ++++++++++++++++++++++++++++++++++++ include/configs/tegra20-common.h | 1 + 2 Dateien geändert, 37 Zeilen hinzugefügt(+)
diff --git a/drivers/mtd/nand/tegra_nand.c b/drivers/mtd/nand/tegra_nand.c index 2c1b533..0d7ca5d 100644 --- a/drivers/mtd/nand/tegra_nand.c +++ b/drivers/mtd/nand/tegra_nand.c @@ -219,6 +219,34 @@ static uint8_t read_byte(struct mtd_info *mtd) }
/** + * Read len bytes from the chip into a buffer + * + * @param mtd MTD device structure + * @param buf buffer to store data to + * @param len number of bytes to read + * + * Read function for 8bit bus-width + */ +static void read_buf(struct mtd_info *mtd, uint8_t *buf, int len) +{ + int i, s; + unsigned int reg; + struct nand_chip *chip = mtd->priv; + struct nand_drv *info = (struct nand_drv *)chip->priv; + + for (i = 0; i < len; i += 4) { + s = (len - i) > 4 ? 4 : len - i; + writel(CMD_PIO | CMD_RX | CMD_A_VALID | CMD_CE0 | + ((s - 1) << CMD_TRANS_SIZE_SHIFT) | CMD_GO, + &info->reg->command); + if (!nand_waitfor_cmd_completion(info->reg)) + printf("Command timeout during read_buf\n"); + reg = readl(&info->reg->resp); + memcpy(buf + i, ®, s); + } +} + +/** * Check NAND status to see if it is ready or not * * @param mtd MTD device structure @@ -317,6 +345,7 @@ static void nand_command(struct mtd_info *mtd, unsigned int command, switch (command) { case NAND_CMD_READID: writel(NAND_CMD_READID, &info->reg->cmd_reg1); + writel(column & 0xFF, &info->reg->addr_reg1); writel(CMD_GO | CMD_CLE | CMD_ALE | CMD_PIO | CMD_RX | ((4 - 1) << CMD_TRANS_SIZE_SHIFT) @@ -324,6 +353,12 @@ static void nand_command(struct mtd_info *mtd, unsigned int command, &info->reg->command); info->pio_byte_index = 0; break; + case NAND_CMD_PARAM: + writel(NAND_CMD_PARAM, &info->reg->cmd_reg1); + writel(column & 0xFF, &info->reg->addr_reg1); + writel(CMD_GO | CMD_CLE | CMD_ALE | CMD_CE0, + &info->reg->command); + break; case NAND_CMD_READ0: writel(NAND_CMD_READ0, &info->reg->cmd_reg1); writel(NAND_CMD_READSTART, &info->reg->cmd_reg2); @@ -976,6 +1011,7 @@ int tegra_nand_init(struct nand_chip *nand, int devnum) nand->options = LP_OPTIONS; nand->cmdfunc = nand_command; nand->read_byte = read_byte; + nand->read_buf = read_buf; nand->ecc.read_page = nand_read_page_hwecc; nand->ecc.write_page = nand_write_page_hwecc; nand->ecc.read_page_raw = nand_read_page_raw; diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index 744dc59..9e60020 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -204,5 +204,6 @@ #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/tegra20/u-boot-spl.lds"
#define CONFIG_SYS_NAND_SELF_INIT +#define CONFIG_SYS_NAND_ONFI_DETECTION
#endif /* __TEGRA20_COMMON_H */
Tested-by: Stephen Warren swarren@nvidia.com
(At least, I tested it for regressions to existing NAND functionality on Harmony. I have not tested whether the new ONFI detection actually works on a system with ONFI NAND; I don't believe I have such a system)
- Read len bytes from the chip into a buffer
- @param mtd MTD device structure
- @param buf buffer to store data to
- @param len number of bytes to read
- Read function for 8bit bus-width
- int i, s;
- unsigned int reg;
- struct nand_chip *chip = mtd->priv;
- struct nand_drv *info = (struct nand_drv *)chip->priv;
- for (i = 0; i < len; i += 4) {
Out of curiousity, what is it about this that needed a custom read_buf() where you didn't need one before?
-Scott
Am Freitag, den 28.09.2012, 17:35 -0500 schrieb Scott Wood:
- int i, s;
- unsigned int reg;
The ONFI parameter page is read before everything is initialized correctly. Because of this we can not use the common way of reading a page with the DMA functionality of the Tegra NAND controller. So for ONFI detection to work we have to implement a readbuf function which uses PIO to read the page.
Note that I'm still no NAND expert, this is just what I could figure out from reading the ONFI spec and the programming information for the NAND controller in the Tegra TRM.
Lucas
Lucas Stach
Scott Wood
Stephen Warren
