[U-Boot] [PATCH v3 1/2] eeprom: fix DM_I2C support without CONFIG_SYS_I2C_EEPROM_BUS
The current device model enabled eeprom code only works if CONFIG_SYS_I2C_EEPROM_BUS is set.
This patch makes it work without that define so that the bus number passed to 'eeprom_init' is used.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Heiko Schocher hs@denx.de ---
Changes in v3: - use eeprom_init() to set CONFIG_SYS_I2C_EEPROM_BUS, not i2c_set_bus_num to make things work with CONFIG_DM_I2C
Changes in v2: None
cmd/eeprom.c | 23 +++++++++++++++-------- 1 file changed, 15 insertions(+), 8 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 6c29b33ba3..7b1f81477f 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -59,6 +59,10 @@ #endif #endif
+#if defined(CONFIG_DM_I2C) +int eeprom_i2c_bus; +#endif + __weak int eeprom_write_enable(unsigned dev_addr, int state) { return 0; @@ -67,7 +71,9 @@ __weak int eeprom_write_enable(unsigned dev_addr, int state) void eeprom_init(int bus) { /* I2C EEPROM */ -#if defined(CONFIG_SYS_I2C) +#if defined(CONFIG_DM_I2C) + eeprom_i2c_bus = bus; +#elif defined(CONFIG_SYS_I2C) if (bus >= 0) i2c_set_bus_num(bus); i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); @@ -124,14 +130,14 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, { int ret = 0;
-#if defined(CONFIG_DM_I2C) && defined(CONFIG_SYS_I2C_EEPROM_BUS) +#if defined(CONFIG_DM_I2C) struct udevice *dev;
- ret = i2c_get_chip_for_busnum(CONFIG_SYS_I2C_EEPROM_BUS, addr[0], + ret = i2c_get_chip_for_busnum(eeprom_i2c_bus, addr[0], alen - 1, &dev); if (ret) { printf("%s: Cannot find udev for a bus %d\n", __func__, - CONFIG_SYS_I2C_EEPROM_BUS); + eeprom_i2c_bus); return CMD_RET_FAILURE; }
@@ -141,15 +147,12 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, ret = dm_i2c_write(dev, offset, buffer, len);
#else /* Non DM I2C support - will be removed */ -#if defined(CONFIG_SYS_I2C_EEPROM_BUS) - i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS); -#endif
if (read) ret = i2c_read(addr[0], offset, alen - 1, buffer, len); else ret = i2c_write(addr[0], offset, alen - 1, buffer, len); -#endif /* CONFIG_DM_I2C && CONFIG_SYS_I2C_EEPROM_BUS */ +#endif /* CONFIG_DM_I2C */ if (ret) ret = CMD_RET_FAILURE;
@@ -164,6 +167,10 @@ static int eeprom_rw(unsigned dev_addr, unsigned offset, uchar *buffer, int rcode = 0; uchar addr[3];
+#if defined(CONFIG_SYS_I2C_EEPROM_BUS) + eeprom_init(CONFIG_SYS_I2C_EEPROM_BUS); +#endif + while (offset < end) { alen = eeprom_addr(dev_addr, offset, addr);
This reverts commit 65a97e7fcf54feb7c4ebe1aee8a572830af4cf51.
The 'eeprom' command has been converted to work with DM_I2C in a patch submitted around the same time as this commit: commit 0c07a9b4078d ("eeprom: Add device model based I2C support to eeprom command")
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v3: None Changes in v2: - added patch to fix DM_I2C eeprom code to work without CONFIG_SYS_I2C_EEPROM_BUS
cmd/Kconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 2bdbfcb3d0..87012670e0 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -455,7 +455,6 @@ config CRC32_VERIFY
config CMD_EEPROM bool "eeprom - EEPROM subsystem" - depends on !DM_I2C || DM_I2C_COMPAT help (deprecated, needs conversion to driver model) Provides commands to read and write EEPROM (Electrically Erasable
Hi Simon,
Reviewed-by: Lukasz Majewski lukma@denx.de
Changes in v3:
Changes in v2: None
- eeprom_i2c_bus = bus;
addr[0],
- ret = i2c_get_chip_for_busnum(eeprom_i2c_bus, addr[0], alen - 1, &dev); if (ret) { printf("%s: Cannot find udev for a bus %d\n",
__func__,
return CMD_RET_FAILURE; }eeprom_i2c_bus);
@@ -141,15 +147,12 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, ret = dm_i2c_write(dev, offset, buffer, len); #else /* Non DM I2C support - will be removed */ -#if defined(CONFIG_SYS_I2C_EEPROM_BUS)
-#endif
- eeprom_init(CONFIG_SYS_I2C_EEPROM_BUS);
- while (offset < end) { alen = eeprom_addr(dev_addr, offset, addr);
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Am 23.04.2019 um 21:18 schrieb Simon Goldschmidt:
Please ignore this version, I've sent a diff for this fix instead.
Changes in v3:
Changes in v2: None
- __weak int eeprom_write_enable(unsigned dev_addr, int state) { return 0;
- ret = i2c_get_chip_for_busnum(eeprom_i2c_bus, addr[0], alen - 1, &dev); if (ret) { printf("%s: Cannot find udev for a bus %d\n", __func__,
-#endif
Lukasz Majewski
Simon Goldschmidt
