[PATCH v11 0/7] Add the USB5744 hub driver as per new DT binding
Add the usb5744/usb2744 hub driver which does the reset gpio toggling and the i2c initialization sequence.
Tested the USB5744/USB2744 usb hub for usb0, usb1 with the DT nodes on KR260 board.
Changes in v2: - Added the power_on_reset_us variable, for post-reset time. - Removed the DM_REGULATOR ifdef around the regulator API's. - Rename the i2c_init and fixed the return for the API's.
Changes in v3: - Rename i2c_init to init. - Fixed the return values for the dev_read_phandle_with_args API. - Removed the unneccessary cast uint8_t *.
Changes in v4: - Fixed the indentation issues. - Fixed the Reverse xmas tree for indentation. - Replaced dev_dbg to dev_err in all places.
Changes in v5: - Add new API for usb_onboard_hub_reset.
Changes in v6: - Add return for usb_onboard_hub_reset in probe.
Changes in v7: - Sort the structure onboard_hub_data data. - Remove the variable gpio_desc * for dm_gpio_free().
Changes in v8: - Sort the list for usb5744_data.
Changes in v9: - Added the Reviewer tag for patches 1/4, which got missed in v8.
Changes in v10: - Removed the GPIOD_ACTIVE_LOW flag in the devm_gpiod_get_optional.
Changes in v11: - Added the usb2514_hub_data and updated the reset_us to 1.
Venkatesh Yadav Abbarapu (7): usb: onboard-hub: Add reset-gpio support usb: onboard-hub: Fix the return values of regulator APIs usb: onboard-hub: add support for Microchip USB5744 usb: onboard-hub: Add i2c initialization for usb5744 hub usb: onboard-hub: Bail out if peer hub is already probed configs: zynqmp_kria: Enable the USB onboard hub arm64: zynqmp: Update the usb5744 hub node as per binding
arch/arm/dts/zynqmp-sck-kr-g-revA.dtso | 48 ++++++ arch/arm/dts/zynqmp-sck-kr-g-revB.dtso | 48 ++++++ arch/arm/dts/zynqmp-sck-kv-g-revA.dtso | 18 +++ arch/arm/dts/zynqmp-sck-kv-g-revB.dtso | 25 +++- common/usb_onboard_hub.c | 194 ++++++++++++++++++++++++- configs/xilinx_zynqmp_kria_defconfig | 3 +- 6 files changed, 329 insertions(+), 7 deletions(-)
As part of the reset, sets the direction of the pin to output before toggling the pin. Delay of millisecond is added in between low and high to meet the setup and hold time requirement of the reset.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Marek Vasut marex@denx.de --- common/usb_onboard_hub.c | 41 +++++++++++++++++++++++++++++++++++++++- 1 file changed, 40 insertions(+), 1 deletion(-)
diff --git a/common/usb_onboard_hub.c b/common/usb_onboard_hub.c index 68a04ac041..43f4cee40b 100644 --- a/common/usb_onboard_hub.c +++ b/common/usb_onboard_hub.c @@ -7,14 +7,50 @@ * Mostly inspired by Linux kernel v6.1 onboard_usb_hub driver */
+#include <asm/gpio.h> #include <dm.h> #include <dm/device_compat.h> +#include <linux/delay.h> #include <power/regulator.h>
struct onboard_hub { struct udevice *vdd; + struct gpio_desc *reset_gpio; };
+struct onboard_hub_data { + unsigned long reset_us; + unsigned long power_on_delay_us; +}; + +int usb_onboard_hub_reset(struct udevice *dev) +{ + struct onboard_hub_data *data = + (struct onboard_hub_data *)dev_get_driver_data(dev); + struct onboard_hub *hub = dev_get_priv(dev); + int ret; + + hub->reset_gpio = devm_gpiod_get_optional(dev, "reset", GPIOD_IS_OUT); + + /* property is optional, don't return error! */ + if (!hub->reset_gpio) + return 0; + + ret = dm_gpio_set_value(hub->reset_gpio, 1); + if (ret) + return ret; + + udelay(data->reset_us); + + ret = dm_gpio_set_value(hub->reset_gpio, 0); + if (ret) + return ret; + + udelay(data->power_on_delay_us); + + return 0; +} + static int usb_onboard_hub_probe(struct udevice *dev) { struct onboard_hub *hub = dev_get_priv(dev); @@ -30,7 +66,7 @@ static int usb_onboard_hub_probe(struct udevice *dev) if (ret) dev_err(dev, "can't enable vdd-supply: %d\n", ret);
- return ret; + return usb_onboard_hub_reset(dev); }
static int usb_onboard_hub_remove(struct udevice *dev) @@ -38,6 +74,9 @@ static int usb_onboard_hub_remove(struct udevice *dev) struct onboard_hub *hub = dev_get_priv(dev); int ret;
+ if (hub->reset_gpio) + dm_gpio_free(hub->reset_gpio->dev, hub->reset_gpio); + ret = regulator_set_enable_if_allowed(hub->vdd, false); if (ret) dev_err(dev, "can't disable vdd-supply: %d\n", ret);
Don't error out if there is no vdd regulator supply, as these are optional properties.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Marek Vasut marex@denx.de --- common/usb_onboard_hub.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/common/usb_onboard_hub.c b/common/usb_onboard_hub.c index 43f4cee40b..827ecf9b02 100644 --- a/common/usb_onboard_hub.c +++ b/common/usb_onboard_hub.c @@ -57,14 +57,18 @@ static int usb_onboard_hub_probe(struct udevice *dev) int ret;
ret = device_get_supply_regulator(dev, "vdd-supply", &hub->vdd); - if (ret) { + if (ret && ret != -ENOENT) { dev_err(dev, "can't get vdd-supply: %d\n", ret); return ret; }
- ret = regulator_set_enable_if_allowed(hub->vdd, true); - if (ret) - dev_err(dev, "can't enable vdd-supply: %d\n", ret); + if (hub->vdd) { + ret = regulator_set_enable_if_allowed(hub->vdd, true); + if (ret && ret != -ENOSYS) { + dev_err(dev, "can't enable vdd-supply: %d\n", ret); + return ret; + } + }
Add support for the Microchip USB5744 USB3.0 and USB2.0 Hub. The usb5744 driver trigger hub reset signal after soft reset. The usb5744 hub need to reset after the phy initialization, which toggles the gpio. Also update the usb2514 hub_data with the reset delay as 1us.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Marek Vasut marex@denx.de --- common/usb_onboard_hub.c | 20 ++++++++++++++++++-- 1 file changed, 18 insertions(+), 2 deletions(-)
diff --git a/common/usb_onboard_hub.c b/common/usb_onboard_hub.c index 827ecf9b02..1d146eccee 100644 --- a/common/usb_onboard_hub.c +++ b/common/usb_onboard_hub.c @@ -88,10 +88,26 @@ static int usb_onboard_hub_remove(struct udevice *dev) return ret; }
+static const struct onboard_hub_data usb2514_data = { + .reset_us = 1, +}; + +static const struct onboard_hub_data usb5744_data = { + .power_on_delay_us = 10000, + .reset_us = 10000, +}; + static const struct udevice_id usb_onboard_hub_ids[] = { /* Use generic usbVID,PID dt-bindings (usb-device.yaml) */ - { .compatible = "usb424,2514" }, /* USB2514B USB 2.0 */ - { } + { .compatible = "usb424,2514", /* USB2514B USB 2.0 */ + .data = (ulong)&usb2514_data, + }, { + .compatible = "usb424,2744", /* USB2744 USB 2.0 */ + .data = (ulong)&usb5744_data, + }, { + .compatible = "usb424,5744", /* USB5744 USB 3.0 */ + .data = (ulong)&usb5744_data, + } };
U_BOOT_DRIVER(usb_onboard_hub) = {
- .reset_us = 1,
- .power_on_delay_us = 10000,
- .reset_us = 10000,
- static const struct udevice_id usb_onboard_hub_ids[] = { /* Use generic usbVID,PID dt-bindings (usb-device.yaml) */
- { .compatible = "usb424,2514", /* USB2514B USB 2.0 */
This ^ hub has to be updated in 1/7 , otherwise if only 1/7 is applied (e.g. during bisect), this hub reset will be operated out of specification.
Also, looking at the USB2514 datasheet figure 5-3, it seems the hub needs t4=500us recovery time in SMBus mode. Does that mean usb2514_data .power_on_delay_us = 500 is missing too ?
Also, it seems t_rstio is 5us in USB5477 datasheet figure 10-4 , where do these 10000us figures above come from ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Tuesday, November 12, 2024 11:28 AM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; fabrice.gasnier@foss.st.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for Microchip USB5744
- .reset_us = 1,
We were seeing i2c failures when we update the reset delay and power on delay values mentioned from the datasheet so updated to 10000us, the linux reference is below https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7f870b967a4...
Thanks Venkatesh
- .reset_us = 1,
Is there a matching delay requirement specified in the USB hub datasheet or is this a workaround for some board-specific behavior ?
Hi Marek,
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Wednesday, November 13, 2024 1:15 AM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; fabrice.gasnier@foss.st.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for Microchip USB5744
*dev)
return ret;
- .reset_us = 1,
We were seeing i2c failures when we update the reset delay and power on delay values mentioned from the datasheet so updated to 10000us, the linux reference is below https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7f870 b967a4cb498
The matching delay is not specified in the USB5744 hub document, but based on testing on 2 boards with the above-mentioned delay i2c failures were not observed.
Thanks Venkatesh
On 11/14/24 5:16 AM, Abbarapu, Venkatesh wrote:
Hi Marek,
*dev)
return ret; }
- .reset_us = 1,
Is this 10ms a board-specific reset delay ? Why is it in a generic driver ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Thursday, November 14, 2024 8:37 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; fabrice.gasnier@foss.st.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for Microchip USB5744
Hi Marek,
*dev)
return ret; }
- .reset_us = 1,
We were seeing i2c failures when we update the reset delay and power on delay values mentioned from the datasheet so updated to 10000us, the linux reference is below https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7f8 70 b967a4cb498
testing on 2 boards with the above-mentioned delay i2c failures were not observed. Is this 10ms a board-specific reset delay ? Why is it in a generic driver ?
On our boards we observed i2c failures when we set the reset delay as 5us and power on delay as 1ms as per the USB5744 datasheet. The reason of adding 10ms delay is because of i2c failures and the linux reference is https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7f870b967a4... Do you have anything with respect to these delays, as you might have tested on some other boards? If anything, please let me know.
Thanks Venkatesh
Hi Marek,
On 11/12/24 6:07 AM, Venkatesh Yadav Abbarapu wrote: > Add support for the Microchip USB5744 USB3.0 and USB2.0 Hub. > The usb5744 driver trigger hub reset signal after soft reset. > The usb5744 hub need to reset after the phy initialization, which > toggles the gpio. > Also update the usb2514 hub_data with the reset delay as 1us. > > Signed-off-by: Venkatesh Yadav Abbarapu > venkatesh.abbarapu@amd.com > Reviewed-by: Marek Vasut marex@denx.de > --- > common/usb_onboard_hub.c | 20 ++++++++++++++++++-- > 1 file changed, 18 insertions(+), 2 deletions(-) > > diff --git a/common/usb_onboard_hub.c b/common/usb_onboard_hub.c > index 827ecf9b02..1d146eccee 100644 > --- a/common/usb_onboard_hub.c > +++ b/common/usb_onboard_hub.c > @@ -88,10 +88,26 @@ static int usb_onboard_hub_remove(struct > udevice
*dev)
> return ret; > } > > +static const struct onboard_hub_data usb2514_data = { > + .reset_us = 1, > +}; > + > +static const struct onboard_hub_data usb5744_data = { > + .power_on_delay_us = 10000, > + .reset_us = 10000, > +}; > + > static const struct udevice_id usb_onboard_hub_ids[] = { > /* Use generic usbVID,PID dt-bindings (usb-device.yaml) */ > - { .compatible = "usb424,2514" }, /* USB2514B USB 2.0 */ > - { } > + { .compatible = "usb424,2514", /* USB2514B USB 2.0 */ > + .data = (ulong)&usb2514_data, This ^ hub has to be updated in 1/7 , otherwise if only 1/7 is applied (e.g. during bisect), this hub reset will be operated out of specification.
If the 10ms delay is a board specific delay, then this has to be handled in a board specific way, not hard-coded in the driver. Probably add some new property which specifies the extra board specific reset delay, but be sure to run that property by the Linux kernel maintainers too.
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Monday, November 18, 2024 10:00 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; fabrice.gasnier@foss.st.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for Microchip USB5744
Hi Marek,
> -----Original Message----- > From: Marek Vasut marex@denx.de > Sent: Tuesday, November 12, 2024 11:28 AM > To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; > u-boot@lists.denx.de > Cc: Simek, Michal michal.simek@amd.com; > fabrice.gasnier@foss.st.com; git > (AMD-Xilinx) git@amd.com > Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for > Microchip > USB5744 > > On 11/12/24 6:07 AM, Venkatesh Yadav Abbarapu wrote: >> Add support for the Microchip USB5744 USB3.0 and USB2.0 Hub. >> The usb5744 driver trigger hub reset signal after soft reset. >> The usb5744 hub need to reset after the phy initialization, >> which toggles the gpio. >> Also update the usb2514 hub_data with the reset delay as 1us. >> >> Signed-off-by: Venkatesh Yadav Abbarapu >> venkatesh.abbarapu@amd.com >> Reviewed-by: Marek Vasut marex@denx.de >> --- >> common/usb_onboard_hub.c | 20 ++++++++++++++++++-- >> 1 file changed, 18 insertions(+), 2 deletions(-) >> >> diff --git a/common/usb_onboard_hub.c b/common/usb_onboard_hub.c >> index 827ecf9b02..1d146eccee 100644 >> --- a/common/usb_onboard_hub.c >> +++ b/common/usb_onboard_hub.c >> @@ -88,10 +88,26 @@ static int usb_onboard_hub_remove(struct >> udevice
*dev)
>> return ret; >> } >> >> +static const struct onboard_hub_data usb2514_data = { >> + .reset_us = 1, >> +}; >> + >> +static const struct onboard_hub_data usb5744_data = { >> + .power_on_delay_us = 10000, >> + .reset_us = 10000, >> +}; >> + >> static const struct udevice_id usb_onboard_hub_ids[] = { >> /* Use generic usbVID,PID dt-bindings (usb-device.yaml) */ >> - { .compatible = "usb424,2514" }, /* USB2514B USB 2.0 */ >> - { } >> + { .compatible = "usb424,2514", /* USB2514B USB 2.0 */ >> + .data = (ulong)&usb2514_data, > This ^ hub has to be updated in 1/7 , otherwise if only 1/7 is > applied (e.g. during bisect), this hub reset will be operated out of
specification.
> > Also, looking at the USB2514 datasheet figure 5-3, it seems the > hub needs t4=500us recovery time in SMBus mode. Does that mean > usb2514_data .power_on_delay_us = 500 is missing too ? > > Also, it seems t_rstio is 5us in USB5477 datasheet figure 10-4 , > where do these 10000us figures above come from ?
We were seeing i2c failures when we update the reset delay and power on delay values mentioned from the datasheet so updated to 10000us, the linux reference is below https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7 f8 70 b967a4cb498
observed.
On our boards we observed i2c failures when we set the reset delay as 5us and power on delay as 1ms as per the USB5744 datasheet. The reason of adding 10ms delay is because of i2c failures and the linux reference is https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7f870 b967a4cb498 Do you have anything with respect to these delays, as you might have tested on some other boards? If anything, please let me know.
Thanks. I will check how to add the board specific delay as new property. As this delay might be specific to the boards which we tested. There won't be any issue if we can add the default "reset_delay"(5us) and "power_on_delay" (1ms) from the USB5744 datasheet, as other boards will be working without any board specific delay?
Thanks Venkatesh
observed.
Add some reset-...-us , similar to what ethernet PHYs already do in DT.
Right, the driver has to be generic , that means it should contain delays specified in the datasheet. Board specific delays have to be configured in board specific DTs.
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Tuesday, November 19, 2024 7:49 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; fabrice.gasnier@foss.st.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for Microchip USB5744
> Is there a matching delay requirement specified in the USB hub > datasheet or is this a workaround for some board-specific behavior ? The matching delay is not specified in the USB5744 hub document, but based on
observed.
On our boards we observed i2c failures when we set the reset delay as 5us and power on delay as 1ms as per the USB5744 datasheet. The reason of adding 10ms delay is because of i2c failures and the linux reference is https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7f8 70 b967a4cb498 Do you have anything with respect to these delays, as you might have tested on some other boards? If anything, please let me know.
maintainers too.
Sure...will check and initiate discussion with the Linux team.
"power_on_delay" (1ms) from the USB5744 datasheet, as other boards will be working without any board specific delay? Right, the driver has to be generic , that means it should contain delays specified in the datasheet. Board specific delays have to be configured in board specific DTs.
Thanks. I have updated the delays based on usb5744 specification in the [PATCH v13 3/7] usb: onboard-hub: add support for Microchip USB5744 Please review.
Thanks Venkatesh
>> Is there a matching delay requirement specified in the USB hub >> datasheet or is this a workaround for some board-specific behavior ? > The matching delay is not specified in the USB5744 hub document, > but based on testing on 2 boards with the above-mentioned delay i2c failures were not
observed.
maintainers too.
V13 also enables the hub driver for Xilinx hardware, does it not ? If so, won't doing so lead to incorrect behavior due to -- now -- too short delay ? I suspect you will need V14 which adds those board specific delays via DT for the Xilinx hardware.
>>> Is there a matching delay requirement specified in the USB hub >>> datasheet or is this a workaround for some board-specific behavior ? >> The matching delay is not specified in the USB5744 hub document, >> but based on > testing on 2 boards with the above-mentioned delay i2c failures > were not
observed.
> Is this 10ms a board-specific reset delay ? > Why is it in a generic driver ? On our boards we observed i2c failures when we set the reset delay as 5us and power on delay as 1ms as per the USB5744 datasheet. The reason of adding 10ms delay is because of i2c failures and the linux reference is https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7f8 70 b967a4cb498 Do you have anything with respect to these delays, as you might have tested on some other boards? If anything, please let me know.
maintainers too.
Feel free to drop these patches from this series.
Thanks, Michal
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Wednesday, November 20, 2024 2:16 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; fabrice.gasnier@foss.st.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for Microchip USB5744
observed.
> Is this 10ms a board-specific reset delay ? > Why is it in a generic driver ? On our boards we observed i2c failures when we set the reset delay as 5us and power on delay as 1ms as per the USB5744 datasheet. The reason of adding 10ms delay is because of i2c failures and the linux reference is https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7 f8 70 b967a4cb498 Do you have anything with respect to these delays, as you might have tested on some other boards? If anything, please let me
know.
maintainers too.
board specific DTs.
There are many customers who use their own boards and they might not see the issue what we observe on Xilinx/AMD boards. Don't you think we are blocking them because of our board issues? What you think?
Thanks Venkatesh
>>>> Is there a matching delay requirement specified in the USB hub >>>> datasheet or is this a workaround for some board-specific behavior ? >>> The matching delay is not specified in the USB5744 hub document, >>> but based on >> testing on 2 boards with the above-mentioned delay i2c failures >> were not observed. >> Is this 10ms a board-specific reset delay ? >> Why is it in a generic driver ? > On our boards we observed i2c failures when we set the reset delay > as 5us and power on delay as 1ms as per the USB5744 datasheet. The > reason of adding 10ms delay is because of i2c failures and the > linux reference is > https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbfd7 > f8 > 70 > b967a4cb498 Do you have anything with respect to these delays, as > you might have tested on some other boards? If anything, please let me
know.
maintainers too.
board specific DTs.
Sure, drop 6 and 7 and the current state of 1..5 can go in I think.
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Thursday, November 21, 2024 5:26 AM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; fabrice.gasnier@foss.st.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v11 3/7] usb: onboard-hub: add support for Microchip USB5744
>>>>> Is there a matching delay requirement specified in the USB >>>>> hub datasheet or is this a workaround for some board-specific
behavior ?
>>>> The matching delay is not specified in the USB5744 hub >>>> document, but based on >>> testing on 2 boards with the above-mentioned delay i2c failures >>> were not > observed. >>> Is this 10ms a board-specific reset delay ? >>> Why is it in a generic driver ? >> On our boards we observed i2c failures when we set the reset >> delay as 5us and power on delay as 1ms as per the USB5744 >> datasheet. The reason of adding 10ms delay is because of i2c >> failures and the linux reference is >> https://github.com/torvalds/linux/commit/908f61bedb2c40c6d856bbf >> d7 >> f8 >> 70 >> b967a4cb498 Do you have anything with respect to these delays, >> as you might have tested on some other boards? If anything, >> please let me
know.
> If the 10ms delay is a board specific delay, then this has to be > handled in a board specific way, not hard-coded in the driver. > Probably add some new property which specifies the extra board > specific reset delay, but be sure to run that property by the > Linux kernel
maintainers too.
board specific DTs.
issue what we observe on Xilinx/AMD boards. Don't you think we are blocking them because of our board issues? What you think? Sure, drop 6 and 7 and the current state of 1..5 can go in I think.
Rather than dropping these patches... To not block others, update the default reset delays mentioned in the USB5744 datasheet. This way the customers can use these patch series and don’t wait for the Xilinx/AMD board issues to be fixed. We can fix Xilinx/AMD board issues with the reset delays(via DT property) for USB5744 by introducing/ discussing with Linux community. I think this way...you don't see any issue right?
Thanks Venkatesh
On 11/21/24 6:08 AM, Abbarapu, Venkatesh wrote:
> As this delay might be specific to the boards which we tested. > There won't be any issue if we can add the default > "reset_delay"(5us) and "power_on_delay" (1ms) from the USB5744 datasheet, as other boards will be working without any board specific delay? Right, the driver has to be generic , that means it should contain delays specified in the datasheet. Board specific delays have to be configured in
board specific DTs.
Sure, simply send the first five hub patches separately as v14, without the DT patches, and I'll most likely pick them up. The DT patches have to go in via Xilinx tree anyway, the USB patches go through USB tree.
Add i2c initialization hook and set usb5744 platform data with function having required i2c initialization sequence.
Apart from the USB command attach, prevent the hub from suspend. when the “USB Attach with SMBUS (0xAA56)” command is issued to the hub, the hub is getting enumerated and then it puts in a suspend mode. This causes the hub to NAK any SMBUS access made by the SMBUS Master during this period and not able to see the hub's slave address while running the "i2c probe" command.
Prevent the MCU from the putting the HUB in suspend mode through register write. The BYPASS_UDC_SUSPEND bit (Bit 3) of the RuntimeFlags2 register at address 0x411D controls this aspect of the hub. The BYPASS_UDC_SUSPEND bit in register 0x411Dh must be set to ensure that the MCU is always enabled and ready to respond to SMBus runtime commands. This register needs to be written before the USB attach command is issued. The byte sequence is as follows: Slave addr: 0x2d 00 00 05 00 01 41 1D 08 Slave addr: 0x2d 99 37 00 Slave addr: 0x2d AA 56 00
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Marek Vasut marex@denx.de --- common/usb_onboard_hub.c | 106 ++++++++++++++++++++++++++++++++++++++- 1 file changed, 105 insertions(+), 1 deletion(-)
diff --git a/common/usb_onboard_hub.c b/common/usb_onboard_hub.c index 1d146eccee..e209964f17 100644 --- a/common/usb_onboard_hub.c +++ b/common/usb_onboard_hub.c @@ -10,9 +10,15 @@ #include <asm/gpio.h> #include <dm.h> #include <dm/device_compat.h> +#include <i2c.h> #include <linux/delay.h> #include <power/regulator.h>
+#define USB5744_COMMAND_ATTACH 0x0056 +#define USB5744_COMMAND_ATTACH_LSB 0xAA +#define USB5744_CONFIG_REG_ACCESS 0x0037 +#define USB5744_CONFIG_REG_ACCESS_LSB 0x99 + struct onboard_hub { struct udevice *vdd; struct gpio_desc *reset_gpio; @@ -21,8 +27,89 @@ struct onboard_hub { struct onboard_hub_data { unsigned long reset_us; unsigned long power_on_delay_us; + int (*init)(struct udevice *dev); };
+static int usb5744_i2c_init(struct udevice *dev) +{ + /* + * Prevent the MCU from the putting the HUB in suspend mode through register write. + * The BYPASS_UDC_SUSPEND bit (Bit 3) of the RuntimeFlags2 register at address + * 0x411D controls this aspect of the hub. + * Format to write to hub registers via SMBus- 2D 00 00 05 00 01 41 1D 08 + * Byte 0: Address of slave 2D + * Byte 1: Memory address 00 + * Byte 2: Memory address 00 + * Byte 3: Number of bytes to write to memory + * Byte 4: Write configuration register (00) + * Byte 5: Write the number of data bytes (01- 1 data byte) + * Byte 6: LSB of register address 0x41 + * Byte 7: MSB of register address 0x1D + * Byte 8: value to be written to the register + */ + u8 data_buf[8] = {0x0, 0x5, 0x0, 0x1, 0x41, 0x1D, 0x08}; + u8 config_reg_access_buf = USB5744_CONFIG_REG_ACCESS; + struct udevice *i2c_bus = NULL, *i2c_dev; + struct ofnode_phandle_args phandle; + u8 buf = USB5744_COMMAND_ATTACH; + struct dm_i2c_chip *i2c_chip; + int ret, slave_addr; + + ret = dev_read_phandle_with_args(dev, "i2c-bus", NULL, 0, 0, &phandle); + if (ret) { + dev_err(dev, "i2c-bus not specified\n"); + return ret; + } + + ret = device_get_global_by_ofnode(ofnode_get_parent(phandle.node), &i2c_bus); + if (ret) { + dev_err(dev, "Failed to get i2c node, err: %d\n", ret); + return ret; + } + + ret = ofnode_read_u32(phandle.node, "reg", &slave_addr); + if (ret) + return ret; + + ret = i2c_get_chip(i2c_bus, slave_addr, 1, &i2c_dev); + if (ret) { + dev_err(dev, "%s: can't find i2c chip device for addr 0x%x\n", __func__, + slave_addr); + return ret; + } + + i2c_chip = dev_get_parent_plat(i2c_dev); + if (!i2c_chip) { + dev_err(dev, "parent platform data not found\n"); + return -EINVAL; + } + + i2c_chip->flags &= ~DM_I2C_CHIP_WR_ADDRESS; + /* SMBus write command */ + ret = dm_i2c_write(i2c_dev, 0, (uint8_t *)&data_buf, 8); + if (ret) { + dev_err(dev, "data_buf i2c_write failed, err:%d\n", ret); + return ret; + } + + /* Configuration register access command */ + ret = dm_i2c_write(i2c_dev, USB5744_CONFIG_REG_ACCESS_LSB, + &config_reg_access_buf, 2); + if (ret) { + dev_err(dev, "config_reg_access i2c_write failed, err: %d\n", ret); + return ret; + } + + /* USB Attach with SMBus */ + ret = dm_i2c_write(i2c_dev, USB5744_COMMAND_ATTACH_LSB, &buf, 2); + if (ret) { + dev_err(dev, "usb_attach i2c_write failed, err: %d\n", ret); + return ret; + } + + return 0; +} + int usb_onboard_hub_reset(struct udevice *dev) { struct onboard_hub_data *data = @@ -53,6 +140,8 @@ int usb_onboard_hub_reset(struct udevice *dev)
static int usb_onboard_hub_probe(struct udevice *dev) { + struct onboard_hub_data *data = + (struct onboard_hub_data *)dev_get_driver_data(dev); struct onboard_hub *hub = dev_get_priv(dev); int ret;
@@ -70,7 +159,21 @@ static int usb_onboard_hub_probe(struct udevice *dev) } }
- return usb_onboard_hub_reset(dev); + ret = usb_onboard_hub_reset(dev); + if (ret) + return ret; + + if (data->init) { + ret = data->init(dev); + if (ret) { + dev_err(dev, "onboard i2c init failed: %d\n", ret); + goto err; + } + } + return 0; +err: + dm_gpio_set_value(hub->reset_gpio, 0); + return ret; }
static int usb_onboard_hub_remove(struct udevice *dev) @@ -93,6 +196,7 @@ static const struct onboard_hub_data usb2514_data = { };
static const struct onboard_hub_data usb5744_data = { + .init = usb5744_i2c_init, .power_on_delay_us = 10000, .reset_us = 10000, };
The .bind function is implemented to bind the correct "half" of the hub that the driver wants to bind, and returning -ENODEV for the other "half".
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Marek Vasut marex@denx.de --- common/usb_onboard_hub.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/common/usb_onboard_hub.c b/common/usb_onboard_hub.c index e209964f17..3c5f88387f 100644 --- a/common/usb_onboard_hub.c +++ b/common/usb_onboard_hub.c @@ -176,6 +176,26 @@ err: return ret; }
+static int usb_onboard_hub_bind(struct udevice *dev) +{ + struct ofnode_phandle_args phandle; + const void *fdt = gd->fdt_blob; + int ret, off; + + ret = dev_read_phandle_with_args(dev, "peer-hub", NULL, 0, 0, &phandle); + if (ret) { + dev_err(dev, "peer-hub not specified\n"); + return ret; + } + + off = ofnode_to_offset(phandle.node); + ret = fdt_node_check_compatible(fdt, off, "usb424,5744"); + if (!ret) + return 0; + + return -ENODEV; +} + static int usb_onboard_hub_remove(struct udevice *dev) { struct onboard_hub *hub = dev_get_priv(dev); @@ -217,6 +237,7 @@ static const struct udevice_id usb_onboard_hub_ids[] = { U_BOOT_DRIVER(usb_onboard_hub) = { .name = "usb_onboard_hub", .id = UCLASS_USB_HUB, + .bind = usb_onboard_hub_bind, .probe = usb_onboard_hub_probe, .remove = usb_onboard_hub_remove, .of_match = usb_onboard_hub_ids,
USB host support on ZYNQMP KRIA SOM needs onboard USB hub driver for handling reset GPIO and for i2c initialization sequence.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Acked-by: Michal Simek michal.simek@amd.com --- configs/xilinx_zynqmp_kria_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/xilinx_zynqmp_kria_defconfig b/configs/xilinx_zynqmp_kria_defconfig index dd4df0b2da..a1d9aaaeb3 100644 --- a/configs/xilinx_zynqmp_kria_defconfig +++ b/configs/xilinx_zynqmp_kria_defconfig @@ -117,9 +117,9 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_FAT_DEVICE_AND_PART=":auto" CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SIMPLE_PM_BUS=y CONFIG_SATA=y @@ -208,6 +208,7 @@ CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y +CONFIG_USB_ONBOARD_HUB=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y
Updating the usb5744 hub node as per the latest upstream DT binding https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/ tree/Documentation/devicetree/bindings/usb/microchip,usb5744.yaml?h=v6.8.8
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Acked-by: Michal Simek michal.simek@amd.com --- arch/arm/dts/zynqmp-sck-kr-g-revA.dtso | 48 ++++++++++++++++++++++++++ arch/arm/dts/zynqmp-sck-kr-g-revB.dtso | 48 ++++++++++++++++++++++++++ arch/arm/dts/zynqmp-sck-kv-g-revA.dtso | 18 ++++++++++ arch/arm/dts/zynqmp-sck-kv-g-revB.dtso | 25 +++++++++++++- 4 files changed, 138 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso b/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso index 6349a0e108..e40840acb8 100644 --- a/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso +++ b/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso @@ -105,11 +105,19 @@ #address-cells = <1>; #size-cells = <0>; reg = <0>; + hub_1: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; usbhub_i2c1: i2c@1 { #address-cells = <1>; #size-cells = <0>; reg = <1>; + hub_2: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; /* Bus 2/3 are not connected */ }; @@ -164,6 +172,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; };
&usb1 { /* mio64 - mio75 */ @@ -188,6 +216,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub1_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub1_3_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub1_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub1_2_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; };
&gem0 { /* mdio mio50/51 */ diff --git a/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso b/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso index b0d737d3ca..ce1ad2b765 100644 --- a/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso +++ b/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso @@ -117,11 +117,19 @@ #address-cells = <1>; #size-cells = <0>; reg = <0>; + hub_1: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; usbhub_i2c1: i2c@1 { #address-cells = <1>; #size-cells = <0>; reg = <1>; + hub_2: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; /* Bus 2/3 are not connected */ }; @@ -184,6 +192,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; };
&usb1 { /* mio64 - mio75 */ @@ -209,6 +237,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub1_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub1_3_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub1_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub1_2_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; };
&gem0 { /* mdio mio50/51 */ diff --git a/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso b/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso index 561b546e37..0ef0357bd2 100644 --- a/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso +++ b/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso @@ -142,6 +142,24 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; };
&sdhci1 { /* on CC with tuned parameters */ diff --git a/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso b/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso index 64683e0ccb..92d8851eb8 100644 --- a/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso +++ b/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso @@ -92,7 +92,10 @@ label = "ina260-u14"; reg = <0x40>; }; - /* u43 - 0x2d - USB hub */ + hub: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; /* u27 - 0xe0 - STDP4320 DP/HDMI splitter */ };
@@ -146,6 +149,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + i2c-bus = <&hub>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + i2c-bus = <&hub>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; };
Abbarapu, Venkatesh
Michal Simek
