[U-Boot] Flash protection and fw_setenv tool
I activated flash sector protection for our CFI NOR flash chip (CONFIG_SYS_FLASH_PROTECTION). Protection bits for U-Boot code sectors and environment sector are set by default during U-Boot startup. Thus from Linux, I cannot write to this sectors, which is generally a correct behavior. BUT, with this, changing the environment from user space with the fw_setenv tool does not work anymore. And here's the question: How to deal with this issue correctly? Two approaches came in my mind: a) Unprotecting the flash sectors by the Linux kernel (in CFI driver). This seems not to be implemented yet, at least for AMD CFI command set (0x0002). However, when unprotecting flash sectors from Linux side, does a sector protection actually makes sense? b) Introduce a config option in U-Boot which allows to leave the environment unprotected. See patch below. I called this option CONFIG_ENV_UNPROTECTED When defined, U-Boot does not protect the environment. For compatibility with boards in which the environment sector is already protected, I left the unprotect part in the saveenv function untouched.
Any comments about this issue? Thanks and regards Georg
Index: common/env_flash.c =================================================================== --- common/env_flash.c (revision 3966) +++ common/env_flash.c (working copy) @@ -218,9 +218,12 @@ done: if (saved_data) free(saved_data); + +#ifndef CONFIG_ENV_UNPROTECTED /* try to re-protect */ flash_sect_protect(1, (ulong)flash_addr, end_addr); flash_sect_protect(1, (ulong)flash_addr_new, end_addr_new); +#endif
return rc; } Index: drivers/mtd/cfi_flash.c =================================================================== --- drivers/mtd/cfi_flash.c (revision 3966) +++ drivers/mtd/cfi_flash.c (working copy) @@ -2294,7 +2294,7 @@ #endif
/* Environment protection ON by default */ -#ifdef CONFIG_ENV_IS_IN_FLASH +#if defined(CONFIG_ENV_IS_IN_FLASH) && !defined(CONFIG_ENV_UNPROTECTED) flash_protect(FLAG_PROTECT_SET, CONFIG_ENV_ADDR, CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1,
Waibel Georg
