[U-Boot] U-Boot's need for MMU
Hi, I am wondering what the ramifications of not using the MMU in U-Boot are? I have an MPC8360 (e300 core) where it is capable of disabling the MMU via the MSR[IR] and MSR[DR] bits.
Before disabling the MMU, I'm just wondering why U-Boot bothers to set up the MMU on CPU's that providing disabling of the MMU.
PS I'm not disabling the MMU just for kicks, there are/may be some program-specific scenarios where I may need to use the option of disabling the MMU.
Thanks.
Christopher M. Fairfax Sr. Software Engineer Rockwell Collins +1 540-428-3344 +1 540-428-3301 cmfairfa@rockwellcollins.com This message contains PRIVILEGED AND PROPRIETARY INFORMATION intended solely for the use of the addressee(s) named above. Any disclosure, distribution, copying or use of the information by others is strictly prohibited. If you have received this message in error, please advise the sender by immediate reply and delete the original message. Thank you.
A big one is that you can't have certain regions be cached (memory) and others uncached (I/O) -- you'll need to turn the D-cache off altogether.
And even then I'm not sure what happens to the guarded bit when the MMU is off.
Such as? One should generally lead with the reason they want to do something, and only afterwards ask "why not". :-)
-Scott
Scott Wood
