[U-Boot] Is somebody workin on getting the AT91SAM9G45EKES working on the latest build?
I need the AT91SAM9G45 port - if I need to bring it up to date to keep it among the living I will volunteer, but if one of the usual AT91 maintainers is already working on it I suspect they can do it more easily than I.
I can start work on the 9G45 update in early July if necessary.
Thanks,
Bill Landolina Technology Atlanta Corporation 500 Sugar Mill Road - Suite 202A Atlanta, Georgia 30350
(404) 303-0446 (Voice) (678) 596-3625 (Cell) wcl@techatl.com
Bill,
I have been using this board as well. I managed to fix my compilation locally. The patch I submitted was before a lot of the updates for the over all ARM stuff went through. I am pretty sure it should still apply though. I could repost it if you are interested.
Best regards, Alex
Hi Aex,
Le 30/06/2011 14:32, Alex Waterman a écrit :
Bill,
In this case please first, make sure it does apply cleanly, and second, add the board maintainer and the Atmel custodian as Cc: when you post it.
Best regards, Alex
Amicalement,
Albert,
I sent my patch to the u-boot mailing list and the patch appears in patchwork but it has yet to actually get to the mailing list. Is a delay normal or should I try and email it again or something else entirely?
Best regards, Alex
This patch set fixes the at91sam9mg45ek build for my set up. I have only been able to test this patch on my own NAND booting at91sam9m10g45ek. Dataflash and norflash are untested. Anyway, this is a rough approximation of a patch; I would need more input from people with nor-flash, working at91bootstrapers, dataflash, etc before I can get truely generic working at91sam9m10g45ek board support.
Also, some notes:
I wrote my own boot strapper because I could not find a working boot strapper. The boot strappers I found on the web either had their own issues or did not enable the second bank of RAM. Thus I wrote my own that works and enables the second bank of RAM. The patch here expects that the second bank works. If you are using a working at91bootstrapper or the like, I don't think that should cause this u-boot patch to not work; just set the number of banks back to 1 in the config file.
If I am not alone in having trouble with the existing at91bootstrap projects, maybe we could merge my bootstrapper into (or the preexisting at91bootstrapper proejcts) into the NAND SPL (for NAND booting boards) section of U-Boot?
Alex Waterman (8): Remove old config stuff from Makefile Update at91sam9m10g45_devices.c to fix compile errors. Fix compile problem for some boards in the clock code. Updates the at91sam9mg45_matrix.h header to new defines. Updates the board specific files for the at91sam9mg45ek. Adds wait to atmel_usart serial_init function Updates the at91sam9m10g45ek.h config file. Updates the boards.cfg file
Makefile | 21 --- .../cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 26 ++-- arch/arm/cpu/arm926ejs/at91/clock.c | 4 + .../arm/include/asm/arch-at91/at91sam9g45_matrix.h | 84 +++++----- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 128 +++++++------- board/atmel/at91sam9m10g45ek/led.c | 6 +- boards.cfg | 1 + drivers/serial/atmel_usart.c | 6 + include/configs/at91sam9m10g45ek.h | 188 ++++++++++++-------- 9 files changed, 246 insertions(+), 218 deletions(-)
Start the process of pushing the at91sam9m10g45ek* boards to the new builds.cfg configuration style. At the moment just the generic config is available, add the rest as necessary.
Signed-off-by: Alex Waterman awaterman@dawning.com --- Makefile | 21 --------------------- 1 files changed, 0 insertions(+), 21 deletions(-)
diff --git a/Makefile b/Makefile index 3454db6..63acc94 100644 --- a/Makefile +++ b/Makefile @@ -850,27 +850,6 @@ at91sam9rlek_config : unconfig fi; @$(MKCONFIG) -n $@ -a at91sam9rlek arm arm926ejs at91sam9rlek atmel at91
-at91sam9m10g45ek_nandflash_config \ -at91sam9m10g45ek_dataflash_config \ -at91sam9m10g45ek_dataflash_cs0_config \ -at91sam9m10g45ek_config \ -at91sam9g45ekes_nandflash_config \ -at91sam9g45ekes_dataflash_config \ -at91sam9g45ekes_dataflash_cs0_config \ -at91sam9g45ekes_config : unconfig - @mkdir -p $(obj)include - @if [ "$(findstring 9m10,$@)" ] ; then \ - echo "#define CONFIG_AT91SAM9M10G45EK 1" >>$(obj)include/config.h ; \ - else \ - echo "#define CONFIG_AT91SAM9G45EKES 1" >>$(obj)include/config.h ; \ - fi; - @if [ "$(findstring _nandflash,$@)" ] ; then \ - echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ - else \ - echo "#define CONFIG_ATMEL_SPI 1" >>$(obj)include/config.h ; \ - fi; - @$(MKCONFIG) -n $@ -a at91sam9m10g45ek arm arm926ejs at91sam9m10g45ek atmel at91 - pm9g45_config : unconfig @mkdir -p $(obj)include @$(MKCONFIG) -a pm9g45 arm arm926ejs pm9g45 ronetix at91
Move this file to the new ATMEL_BASE_* and ATMEL_ID_* defines.
Also fixed a problem appearing in the ethernet initialization where the entire board was being reset, not just the ethernet controller. This at least makes ethernet work on my board if the correct environment (mac address, ip address, etc) is available on boot.
Signed-off-by: Alex Waterman awaterman@dawning.com --- .../cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 26 ++++++++++---------- 1 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c index 4ad9b1f..9ef8966 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -26,42 +26,42 @@ #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> +#include <asm/io.h>
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 19, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTB, 18, 0); /* RXD0 */ - writel(1 << AT91SAM9G45_ID_US0, &pmc->pcer); + writel(1 << ATMEL_ID_USART0, &pmc->pcer); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 4, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTB, 5, 0); /* RXD1 */ - writel(1 << AT91SAM9G45_ID_US1, &pmc->pcer); + writel(1 << ATMEL_ID_USART1, &pmc->pcer); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTD, 6, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTD, 7, 0); /* RXD2 */ - writel(1 << AT91SAM9G45_ID_US2, &pmc->pcer); + writel(1 << ATMEL_ID_USART2, &pmc->pcer); }
void at91_serial3_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTB, 13, 1); /* DTXD */ - writel(1 << AT91_ID_SYS, &pmc->pcer); + writel(1 << ATMEL_ID_USART3, &pmc->pcer); }
void at91_serial_hw_init(void) @@ -86,14 +86,14 @@ void at91_serial_hw_init(void) #ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 1, 0); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* SPI0_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9G45_ID_SPI0, &pmc->pcer); + writel(1 << ATMEL_ID_SPI0, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 3, 0); @@ -123,14 +123,14 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 15, 0); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 16, 0); /* SPI1_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9G45_ID_SPI1, &pmc->pcer); + writel(1 << ATMEL_ID_SPI1, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 17, 0);
Some boards use AT91_SLOW_CLOCK and other use CONFIG_SYS_AT91_SLOW_CLOCK. This patch makes it so the arm926ejs clock code will return which ever is set.
Signed-off-by: Alex Waterman awaterman@dawning.com --- arch/arm/cpu/arm926ejs/at91/clock.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index 608af2c..0083bd2 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -57,7 +57,11 @@ static unsigned long at91_css_to_rate(unsigned long css) { switch (css) { case AT91_PMC_MCKR_CSS_SLOW: +#ifdef AT91_SLOW_CLOCK + return AT91_SLOW_CLOCK; +#else return CONFIG_SYS_AT91_SLOW_CLOCK; +#endif case AT91_PMC_MCKR_CSS_MAIN: return gd->main_clk_rate_hz; case AT91_PMC_MCKR_CSS_PLLA:
Moves the at91sam9g45_matrix.h header file to use the new ATMEL_BASE_MATRIX define.
Signed-off-by: Alex Waterman awaterman@dawning.com --- .../arm/include/asm/arch-at91/at91sam9g45_matrix.h | 84 ++++++++++---------- 1 files changed, 42 insertions(+), 42 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h index 1620e1b..9808e38 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h @@ -15,18 +15,18 @@ #ifndef AT91SAM9G45_MATRIX_H #define AT91SAM9G45_MATRIX_H
-#define AT91_MATRIX_MCFG0 (AT91_MATRIX + 0x00) /* Master Configuration Register 0 */ -#define AT91_MATRIX_MCFG1 (AT91_MATRIX + 0x04) /* Master Configuration Register 1 */ -#define AT91_MATRIX_MCFG2 (AT91_MATRIX + 0x08) /* Master Configuration Register 2 */ -#define AT91_MATRIX_MCFG3 (AT91_MATRIX + 0x0C) /* Master Configuration Register 3 */ -#define AT91_MATRIX_MCFG4 (AT91_MATRIX + 0x10) /* Master Configuration Register 4 */ -#define AT91_MATRIX_MCFG5 (AT91_MATRIX + 0x14) /* Master Configuration Register 5 */ -#define AT91_MATRIX_MCFG6 (AT91_MATRIX + 0x18) /* Master Configuration Register 6 */ -#define AT91_MATRIX_MCFG7 (AT91_MATRIX + 0x1C) /* Master Configuration Register 7 */ -#define AT91_MATRIX_MCFG8 (AT91_MATRIX + 0x20) /* Master Configuration Register 8 */ -#define AT91_MATRIX_MCFG9 (AT91_MATRIX + 0x24) /* Master Configuration Register 9 */ -#define AT91_MATRIX_MCFG10 (AT91_MATRIX + 0x28) /* Master Configuration Register 10 */ -#define AT91_MATRIX_MCFG11 (AT91_MATRIX + 0x2C) /* Master Configuration Register 11 */ +#define AT91_MATRIX_MCFG0 (ATMEL_BASE_MATRIX + 0x00) /* Master Configuration Register 0 */ +#define AT91_MATRIX_MCFG1 (ATMEL_BASE_MATRIX + 0x04) /* Master Configuration Register 1 */ +#define AT91_MATRIX_MCFG2 (ATMEL_BASE_MATRIX + 0x08) /* Master Configuration Register 2 */ +#define AT91_MATRIX_MCFG3 (ATMEL_BASE_MATRIX + 0x0C) /* Master Configuration Register 3 */ +#define AT91_MATRIX_MCFG4 (ATMEL_BASE_MATRIX + 0x10) /* Master Configuration Register 4 */ +#define AT91_MATRIX_MCFG5 (ATMEL_BASE_MATRIX + 0x14) /* Master Configuration Register 5 */ +#define AT91_MATRIX_MCFG6 (ATMEL_BASE_MATRIX + 0x18) /* Master Configuration Register 6 */ +#define AT91_MATRIX_MCFG7 (ATMEL_BASE_MATRIX + 0x1C) /* Master Configuration Register 7 */ +#define AT91_MATRIX_MCFG8 (ATMEL_BASE_MATRIX + 0x20) /* Master Configuration Register 8 */ +#define AT91_MATRIX_MCFG9 (ATMEL_BASE_MATRIX + 0x24) /* Master Configuration Register 9 */ +#define AT91_MATRIX_MCFG10 (ATMEL_BASE_MATRIX + 0x28) /* Master Configuration Register 10 */ +#define AT91_MATRIX_MCFG11 (ATMEL_BASE_MATRIX + 0x2C) /* Master Configuration Register 11 */ #define AT91_MATRIX_ULBT (7 << 0) /* Undefined Length Burst Type */ #define AT91_MATRIX_ULBT_INFINITE (0 << 0) #define AT91_MATRIX_ULBT_SINGLE (1 << 0) @@ -37,14 +37,14 @@ #define AT91_MATRIX_ULBT_SIXTYFOUR (6 << 0) #define AT91_MATRIX_ULBT_128 (7 << 0)
-#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x40) /* Slave Configuration Register 0 */ -#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x44) /* Slave Configuration Register 1 */ -#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x48) /* Slave Configuration Register 2 */ -#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x4C) /* Slave Configuration Register 3 */ -#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x50) /* Slave Configuration Register 4 */ -#define AT91_MATRIX_SCFG5 (AT91_MATRIX + 0x54) /* Slave Configuration Register 5 */ -#define AT91_MATRIX_SCFG6 (AT91_MATRIX + 0x58) /* Slave Configuration Register 6 */ -#define AT91_MATRIX_SCFG7 (AT91_MATRIX + 0x5C) /* Slave Configuration Register 7 */ +#define AT91_MATRIX_SCFG0 (ATMEL_BASE_MATRIX + 0x40) /* Slave Configuration Register 0 */ +#define AT91_MATRIX_SCFG1 (ATMEL_BASE_MATRIX + 0x44) /* Slave Configuration Register 1 */ +#define AT91_MATRIX_SCFG2 (ATMEL_BASE_MATRIX + 0x48) /* Slave Configuration Register 2 */ +#define AT91_MATRIX_SCFG3 (ATMEL_BASE_MATRIX + 0x4C) /* Slave Configuration Register 3 */ +#define AT91_MATRIX_SCFG4 (ATMEL_BASE_MATRIX + 0x50) /* Slave Configuration Register 4 */ +#define AT91_MATRIX_SCFG5 (ATMEL_BASE_MATRIX + 0x54) /* Slave Configuration Register 5 */ +#define AT91_MATRIX_SCFG6 (ATMEL_BASE_MATRIX + 0x58) /* Slave Configuration Register 6 */ +#define AT91_MATRIX_SCFG7 (ATMEL_BASE_MATRIX + 0x5C) /* Slave Configuration Register 7 */ #define AT91_MATRIX_SLOT_CYCLE (0x1ff << 0) /* Maximum Number of Allowed Cycles for a Burst */ #define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ #define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) @@ -52,22 +52,22 @@ #define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) #define AT91_MATRIX_FIXED_DEFMSTR (0xf << 18) /* Fixed Index of Default Master */
-#define AT91_MATRIX_PRAS0 (AT91_MATRIX + 0x80) /* Priority Register A for Slave 0 */ -#define AT91_MATRIX_PRBS0 (AT91_MATRIX + 0x84) /* Priority Register B for Slave 0 */ -#define AT91_MATRIX_PRAS1 (AT91_MATRIX + 0x88) /* Priority Register A for Slave 1 */ -#define AT91_MATRIX_PRBS1 (AT91_MATRIX + 0x8C) /* Priority Register B for Slave 1 */ -#define AT91_MATRIX_PRAS2 (AT91_MATRIX + 0x90) /* Priority Register A for Slave 2 */ -#define AT91_MATRIX_PRBS2 (AT91_MATRIX + 0x94) /* Priority Register B for Slave 2 */ -#define AT91_MATRIX_PRAS3 (AT91_MATRIX + 0x98) /* Priority Register A for Slave 3 */ -#define AT91_MATRIX_PRBS3 (AT91_MATRIX + 0x9C) /* Priority Register B for Slave 3 */ -#define AT91_MATRIX_PRAS4 (AT91_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ -#define AT91_MATRIX_PRBS4 (AT91_MATRIX + 0xA4) /* Priority Register B for Slave 4 */ -#define AT91_MATRIX_PRAS5 (AT91_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ -#define AT91_MATRIX_PRBS5 (AT91_MATRIX + 0xAC) /* Priority Register B for Slave 5 */ -#define AT91_MATRIX_PRAS6 (AT91_MATRIX + 0xB0) /* Priority Register A for Slave 6 */ -#define AT91_MATRIX_PRBS6 (AT91_MATRIX + 0xB4) /* Priority Register B for Slave 6 */ -#define AT91_MATRIX_PRAS7 (AT91_MATRIX + 0xB8) /* Priority Register A for Slave 7 */ -#define AT91_MATRIX_PRBS7 (AT91_MATRIX + 0xBC) /* Priority Register B for Slave 7 */ +#define AT91_MATRIX_PRAS0 (ATMEL_BASE_MATRIX + 0x80) /* Priority Register A for Slave 0 */ +#define AT91_MATRIX_PRBS0 (ATMEL_BASE_MATRIX + 0x84) /* Priority Register B for Slave 0 */ +#define AT91_MATRIX_PRAS1 (ATMEL_BASE_MATRIX + 0x88) /* Priority Register A for Slave 1 */ +#define AT91_MATRIX_PRBS1 (ATMEL_BASE_MATRIX + 0x8C) /* Priority Register B for Slave 1 */ +#define AT91_MATRIX_PRAS2 (ATMEL_BASE_MATRIX + 0x90) /* Priority Register A for Slave 2 */ +#define AT91_MATRIX_PRBS2 (ATMEL_BASE_MATRIX + 0x94) /* Priority Register B for Slave 2 */ +#define AT91_MATRIX_PRAS3 (ATMEL_BASE_MATRIX + 0x98) /* Priority Register A for Slave 3 */ +#define AT91_MATRIX_PRBS3 (ATMEL_BASE_MATRIX + 0x9C) /* Priority Register B for Slave 3 */ +#define AT91_MATRIX_PRAS4 (ATMEL_BASE_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ +#define AT91_MATRIX_PRBS4 (ATMEL_BASE_MATRIX + 0xA4) /* Priority Register B for Slave 4 */ +#define AT91_MATRIX_PRAS5 (ATMEL_BASE_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ +#define AT91_MATRIX_PRBS5 (ATMEL_BASE_MATRIX + 0xAC) /* Priority Register B for Slave 5 */ +#define AT91_MATRIX_PRAS6 (ATMEL_BASE_MATRIX + 0xB0) /* Priority Register A for Slave 6 */ +#define AT91_MATRIX_PRBS6 (ATMEL_BASE_MATRIX + 0xB4) /* Priority Register B for Slave 6 */ +#define AT91_MATRIX_PRAS7 (ATMEL_BASE_MATRIX + 0xB8) /* Priority Register A for Slave 7 */ +#define AT91_MATRIX_PRBS7 (ATMEL_BASE_MATRIX + 0xBC) /* Priority Register B for Slave 7 */ #define AT91_MATRIX_M0PR (3 << 0) /* Master 0 Priority */ #define AT91_MATRIX_M1PR (3 << 4) /* Master 1 Priority */ #define AT91_MATRIX_M2PR (3 << 8) /* Master 2 Priority */ @@ -81,7 +81,7 @@ #define AT91_MATRIX_M10PR (3 << 8) /* Master 10 Priority (in Register B) */ #define AT91_MATRIX_M11PR (3 << 12) /* Master 11 Priority (in Register B) */
-#define AT91_MATRIX_MRCR (AT91_MATRIX + 0x100) /* Master Remap Control Register */ +#define AT91_MATRIX_MRCR (ATMEL_BASE_MATRIX + 0x100) /* Master Remap Control Register */ #define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ #define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ #define AT91_MATRIX_RCB2 (1 << 2) @@ -95,7 +95,7 @@ #define AT91_MATRIX_RCB10 (1 << 10) #define AT91_MATRIX_RCB11 (1 << 11)
-#define AT91_MATRIX_TCMR (AT91_MATRIX + 0x110) /* TCM Configuration Register */ +#define AT91_MATRIX_TCMR (ATMEL_BASE_MATRIX + 0x110) /* TCM Configuration Register */ #define AT91_MATRIX_ITCM_SIZE (0xf << 0) /* Size of ITCM enabled memory block */ #define AT91_MATRIX_ITCM_0 (0 << 0) #define AT91_MATRIX_ITCM_32 (6 << 0) @@ -107,12 +107,12 @@ #define AT91_MATRIX_TCM_NO_WS (0x0 << 11) #define AT91_MATRIX_TCM_ONE_WS (0x1 << 11)
-#define AT91_MATRIX_VIDEO (AT91_MATRIX + 0x118) /* Video Mode Configuration Register */ +#define AT91_MATRIX_VIDEO (ATMEL_BASE_MATRIX + 0x118) /* Video Mode Configuration Register */ #define AT91C_VDEC_SEL (0x1 << 0) /* Video Mode Selection */ #define AT91C_VDEC_SEL_OFF (0 << 0) #define AT91C_VDEC_SEL_ON (1 << 0)
-#define AT91_MATRIX_EBICSA (AT91_MATRIX + 0x128) /* EBI Chip Select Assignment Register */ +#define AT91_MATRIX_EBICSA (ATMEL_BASE_MATRIX + 0x128) /* EBI Chip Select Assignment Register */ #define AT91_MATRIX_EBI_CS1A (1 << 1) /* Chip Select 1 Assignment */ #define AT91_MATRIX_EBI_CS1A_SMC (0 << 1) #define AT91_MATRIX_EBI_CS1A_SDRAMC (1 << 1) @@ -138,13 +138,13 @@ #define AT91_MATRIX_EBI_DDR_IOSR_REDUCED (0 << 18) #define AT91_MATRIX_EBI_DDR_IOSR_NORMAL (1 << 18)
-#define AT91_MATRIX_WPMR (AT91_MATRIX + 0x1E4) /* Write Protect Mode Register */ +#define AT91_MATRIX_WPMR (ATMEL_BASE_MATRIX + 0x1E4) /* Write Protect Mode Register */ #define AT91_MATRIX_WPMR_WPEN (1 << 0) /* Write Protect ENable */ #define AT91_MATRIX_WPMR_WP_WPDIS (0 << 0) #define AT91_MATRIX_WPMR_WP_WPEN (1 << 0) #define AT91_MATRIX_WPMR_WPKEY (0xFFFFFF << 8) /* Write Protect KEY */
-#define AT91_MATRIX_WPSR (AT91_MATRIX + 0x1E8) /* Write Protect Status Register */ +#define AT91_MATRIX_WPSR (ATMEL_BASE_MATRIX + 0x1E8) /* Write Protect Status Register */ #define AT91_MATRIX_WPSR_WPVS (1 << 0) /* Write Protect Violation Status */ #define AT91_MATRIX_WPSR_NO_WPV (0 << 0) #define AT91_MATRIX_WPSR_WPV (1 << 0)
Fixes the compile errors in the board specific initializations for the at91sam9m10g45ek specific files.
Signed-off-by: Alex Waterman awaterman@dawning.com --- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 128 +++++++++++------------ board/atmel/at91sam9m10g45ek/led.c | 6 +- 2 files changed, 67 insertions(+), 67 deletions(-)
diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index f92b20f..f8e687e 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -23,6 +23,7 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/sizes.h> #include <asm/arch/at91sam9g45.h> #include <asm/arch/at91sam9_matrix.h> @@ -32,7 +33,6 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> #include <asm/arch/hardware.h> #include <lcd.h> #include <atmel_lcdc.h> @@ -41,6 +41,14 @@ #endif #include <netdev.h>
+/* + * arch/arm/include/asm/arch-at91/at91sam9g45.h defines ATMEL_BASE_SCM; + * however, other code still wants AT91_SMC instead. Likewise for the AT91_PMC + * definition. + */ +#define AT91_SMC ATMEL_BASE_SMC +#define AT91_PMC ATMEL_BASE_PMC + DECLARE_GLOBAL_DATA_PTR;
/* ------------------------------------------------------------------------- */ @@ -49,35 +57,35 @@ DECLARE_GLOBAL_DATA_PTR; */
#ifdef CONFIG_CMD_NAND -static void at91sam9m10g45ek_nand_hw_init(void) +void at91sam9m10g45ek_nand_hw_init(void) { unsigned long csa;
/* Enable CS3 */ - csa = at91_sys_read(AT91_MATRIX_EBICSA); - at91_sys_write(AT91_MATRIX_EBICSA, - csa | AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA); + csa = readl(AT91_MATRIX_EBICSA); + writel(csa | AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA, AT91_MATRIX_EBICSA);
/* Configure SMC CS3 for NAND/SmartMedia */ - at91_sys_write(AT91_SMC_SETUP(3), - AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | - AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); - at91_sys_write(AT91_SMC_PULSE(3), - AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(3) | - AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(2)); - at91_sys_write(AT91_SMC_CYCLE(3), - AT91_SMC_NWECYCLE_(7) | AT91_SMC_NRDCYCLE_(4)); - at91_sys_write(AT91_SMC_MODE(3), - AT91_SMC_READMODE | AT91_SMC_WRITEMODE | - AT91_SMC_EXNWMODE_DISABLE | + writel(AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0), + AT91_SMC_SETUP(3)); + writel(AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(2), + AT91_SMC_PULSE(3)); + + writel(AT91_SMC_NWECYCLE_(7) | AT91_SMC_NRDCYCLE_(4), + AT91_SMC_CYCLE(3)); + writel(AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | #ifdef CONFIG_SYS_NAND_DBW_16 AT91_SMC_DBW_16 | #else /* CONFIG_SYS_NAND_DBW_8 */ AT91_SMC_DBW_8 | #endif - AT91_SMC_TDF_(3)); + AT91_SMC_TDF_(3), + AT91_SMC_MODE(3));
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIOC); + writel(1 << ATMEL_ID_PIOC, AT91_PMC_PCER);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -90,7 +98,7 @@ static void at91sam9m10g45ek_nand_hw_init(void) #ifdef CONFIG_CMD_USB static void at91sam9m10g45ek_usb_hw_init(void) { - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIODE); + writel(1 << ATMEL_ID_PIODE, AT91_PMC_PCER);
at91_set_gpio_output(AT91_PIN_PD1, 0); at91_set_gpio_output(AT91_PIN_PD3, 0); @@ -100,48 +108,13 @@ static void at91sam9m10g45ek_usb_hw_init(void) #ifdef CONFIG_MACB static void at91sam9m10g45ek_macb_hw_init(void) { - unsigned long rstc;
/* Enable clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_EMAC); - - /* - * Disable pull-up on: - * RXDV (PA15) => PHY normal mode (not Test mode) - * ERX0 (PA12) => PHY ADDR0 - * ERX1 (PA13) => PHY ADDR1 => PHYADDR = 0x0 - * - * PHY has internal pull-down - */ - writel(pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA12) | - pin_to_mask(AT91_PIN_PA13), - pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); - - rstc = at91_sys_read(AT91_RSTC_MR); - - /* Need to reset PHY -> 500ms reset */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - (AT91_RSTC_ERSTL & (0x0D << 8)) | - AT91_RSTC_URSTEN); - - at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); - - /* Wait for end hardware reset */ - while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); - - /* Restore NRST value */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - (rstc) | - AT91_RSTC_URSTEN); - - /* Re-enable pull-up */ - writel(pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA12) | - pin_to_mask(AT91_PIN_PA13), - pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + writel(1 << ATMEL_ID_EMAC, AT91_PMC_PCER);
+ /* And the pins. */ at91_macb_hw_init(); + } #endif
@@ -161,7 +134,7 @@ vidinfo_t panel_info = { vl_vsync_len: 1, vl_upper_margin:40, vl_lower_margin:1, - mmio: AT91SAM9G45_LCDC_BASE, + mmio : ATMEL_BASE_LCDC, };
@@ -208,7 +181,7 @@ static void at91sam9m10g45ek_lcd_hw_init(void) at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */ at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_LCDC); + writel(1 << ATMEL_ID_LCDC, AT91_PMC_PCER);
gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE; } @@ -227,7 +200,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", - CONFIG_SYS_AT91_CPU_NAME, + ATMEL_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; @@ -257,7 +230,8 @@ int board_init(void) /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91_serial_hw_init(); + + #ifdef CONFIG_CMD_NAND at91sam9m10g45ek_nand_hw_init(); #endif @@ -270,11 +244,9 @@ int board_init(void) #ifdef CONFIG_ATMEL_SPI at91_spi0_hw_init(1 << 4); #endif - #ifdef CONFIG_MACB at91sam9m10g45ek_macb_hw_init(); #endif - #ifdef CONFIG_LCD at91sam9m10g45ek_lcd_hw_init(); #endif @@ -283,9 +255,23 @@ int board_init(void)
int dram_init(void) { + gd->ram_size = PHYS_SDRAM_SIZE; + return 0; +} + +void dram_init_banksize() +{ + + /* Bank 1. */ gd->bd->bi_dram[0].start = PHYS_SDRAM; gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; - return 0; + + /* Bank 2. */ +#if (CONFIG_NR_DRAM_BANKS == 2) + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_SIZE_2; +#endif + }
#ifdef CONFIG_RESET_PHY_R @@ -298,7 +284,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91SAM9G45_BASE_EMAC, 0x00); + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x00); #endif return rc; } @@ -338,3 +324,15 @@ void spi_cs_deactivate(struct spi_slave *slave) } } #endif /* CONFIG_ATMEL_SPI */ + +extern void at91_serial_hw_init(void); +/* + * (re)Initialize the serial hardware. + */ +int board_early_init_f(void) +{ + + at91_serial_hw_init(); + return 0; + +} diff --git a/board/atmel/at91sam9m10g45ek/led.c b/board/atmel/at91sam9m10g45ek/led.c index ff59a2d..b939c5b 100644 --- a/board/atmel/at91sam9m10g45ek/led.c +++ b/board/atmel/at91sam9m10g45ek/led.c @@ -23,15 +23,17 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/arch/at91sam9g45.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> + +#define AT91_PMC ATMEL_BASE_PMC
void coloured_LED_init(void) { /* Enable clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIODE); + writel(AT91_PMC_PCER, 1 << ATMEL_ID_PIODE);
at91_set_gpio_output(CONFIG_RED_LED, 1); at91_set_gpio_output(CONFIG_GREEN_LED, 1);
Adds a short busy loop wait to the atmel_usart.c serial_init() function.
Signed-off-by: Alex Waterman awaterman@dawning.com --- drivers/serial/atmel_usart.c | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index e326b2b..e355706 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -47,6 +47,8 @@ void serial_setbrg(void)
int serial_init(void) { + + volatile int i = 0; atmel_usart3_t *usart = (atmel_usart3_t *)CONFIG_USART_BASE;
writel(USART3_BIT(RSTRX) | USART3_BIT(RSTTX), &usart->cr); @@ -61,6 +63,10 @@ int serial_init(void) | USART3_BF(NBSTOP, USART3_NBSTOP_1)), &usart->mr);
+ /* Short wait to let the serial port init. */ + for (; i < 10000; i++) + ; + return 0; }
Moves to using newer defines and adds possible support for the second bank of RAM (if so desired).
Also, some coding clean up: removed the needless define to 1s for defines that just act as flags.
Signed-off-by: Alex Waterman awaterman@dawning.com --- include/configs/at91sam9m10g45ek.h | 188 +++++++++++++++++++++-------------- 1 files changed, 113 insertions(+), 75 deletions(-)
diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index de74dcf..5e02dde 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -27,48 +27,65 @@ #ifndef __CONFIG_H #define __CONFIG_H
+/*#define DEBUG*/ + #define CONFIG_AT91_LEGACY +#define CONFIG_ATMEL_LEGACY
/* ARM asynchronous clock */ -#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_HZ 1000
-#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ -#ifdef CONFIG_AT91SAM9M10G45EK -#define CONFIG_AT91SAM9M10G45 1 /* It's an Atmel AT91SAM9M10G45 SoC*/ -#else -#define CONFIG_AT91SAM9G45 1 /* It's an Atmel AT91SAM9G45 SoC*/ -#endif +#define CONFIG_AT91SAM9M10G45 +#define CONFIG_AT91FAMILY #define CONFIG_ARCH_CPU_INIT +#define CONFIG_BOARD_EARLY_INIT_F #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
-#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 +#define CONFIGMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG
#define CONFIG_SKIP_LOWLEVEL_INIT
+#define ATMEL_PIO_PORTS 5 /* 5 PIO ports. */ +#define CONFIG_SYS_SDRAM_BASE 0x70000000 + /* * Hardware drivers */ -#define CONFIG_AT91_GPIO 1 -#define CONFIG_ATMEL_USART 1 +#define CONFIG_AT91_GPIO +#define CONFIG_ATMEL_USART #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART3 /* USART 3 is DBGU */ +#define CONFIG_USART_BASE 0xffffee00 /* Use the DBGU hardware. */ +#define CONFIG_USART_ID 10 + +/* + * This needs to be defined for the OHCI code to work but it is defined as + * ATMEL_ID_UHPHS in the CPU specific header files. + */ +#define ATMEL_ID_UHP ATMEL_ID_UHPHS + +/* + * Specify the clock enable bit in the PMC_SCER register. + */ +#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* LCD */ -#define CONFIG_LCD 1 +#define CONFIG_LCD #define LCD_BPP LCD_COLOR8 -#define CONFIG_LCD_LOGO 1 +#define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN -#define CONFIG_LCD_INFO 1 -#define CONFIG_LCD_INFO_BELOW_LOGO 1 -#define CONFIG_SYS_WHITE_ON_BLACK 1 -#define CONFIG_ATMEL_LCD 1 -#define CONFIG_ATMEL_LCD_RGB565 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +#define CONFIG_LCD_INFO +#define CONFIG_LCD_INFO_BELOW_LOGO +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_ATMEL_LCD +#define CONFIG_ATMEL_LCD_RGB565 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* board specific(not enough SRAM) */ #define CONFIG_AT91SAM9G45_LCD_BASE 0x73E00000
@@ -82,10 +99,10 @@ /* * BOOTP options */ -#define CONFIG_BOOTP_BOOTFILESIZE 1 -#define CONFIG_BOOTP_BOOTPATH 1 -#define CONFIG_BOOTP_GATEWAY 1 -#define CONFIG_BOOTP_HOSTNAME 1 +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME
/* * Command line configuration. @@ -98,35 +115,37 @@ #undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_LOADS
-#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 -#define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_CMD_USB
/* SDRAM */ -#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_NR_DRAM_BANKS 2 #define PHYS_SDRAM 0x70000000 #define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ +#define PHYS_SDRAM_2 0x20000000 +#define PHYS_SDRAM_SIZE_2 0x08000000 /* 128 megs */
/* DataFlash */ #ifdef CONFIG_ATMEL_SPI #define CONFIG_CMD_SF #define CONFIG_CMD_SPI -#define CONFIG_SPI_FLASH 1 -#define CONFIG_SPI_FLASH_ATMEL 1 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_ATMEL #define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 #endif
/* NOR flash, if populated */ -#ifndef CONFIG_CMD_NAND -#define CONFIG_SYS_NO_FLASH 1 +#ifdef CONFIG_CMD_NAND +#define CONFIG_SYS_NO_FLASH #else -#define CONFIG_SYS_FLASH_CFI 1 -#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER #define PHYS_FLASH_1 0x10000000 -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MAX_FLASH_SECT 256 -#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 #endif
/* NAND flash */ @@ -156,51 +175,69 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_DOS_PARTITION 1 -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 -#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* AT91SAM9G45_UHP_OHCI_BASE */ -#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1
-#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ - -#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM -#define CONFIG_SYS_MEMTEST_END 0x23e00000 - -#ifdef CONFIG_SYS_USE_DATAFLASH +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
-/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_SPI_FLASH 1 -#define CONFIG_SYS_MONITOR_BASE (0xC0000000 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 -#define CONFIG_ENV_ADDR (0xC0000000 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock0 " \ - "mtdparts=atmel_nand:-(root) "\ - "rw rootfstype=jffs2" - -#else /* CONFIG_SYS_USE_NANDFLASH */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x60000 #define CONFIG_ENV_OFFSET_REDUND 0x80000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ -#define CONFIG_BOOTCOMMAND "nand read 0x72000000 0x200000 0x200000; bootm" -#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ - "root=/dev/mtdblock5 " \ - "mtdparts=atmel_nand:128k(bootstrap)ro, \ - 256k(uboot)ro,128k(env1)ro,128k(env2)ro, \ - 2M(linux),-(root) " \ - "rw rootfstype=jffs2" +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_BOOTCOMMAND "nand read 0x70000000 0x100000 0x200000;" \ + "bootm 0x70000000" +#define CONFIG_BOOTARGS \ + "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=atmel_nand:128k(bootstrap)ro," \ + "256k(uboot)ro,128k(env1)ro,128k(env2)ro," \ + "2M@1M(linux),-(root) " \ + "rw rootfstype=jffs2" + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 }
-#endif +/* + * Extra environment variables. + */ +#define UPDATE_BOOTSTRAP \ + "update_bootstrap=" \ + "tftpboot 0x70000000 ${_bootstrap}; " \ + "nand erase 0x0 0x20000; " \ + "nand write 0x70000000 0x0 0x20000\0" +#define UPDATE_UBOOT \ + "update_uboot=" \ + "tftpboot 0x70000000 ${_uboot}; " \ + "nand erase 0x20000 0x40000; " \ + "nand write 0x70000000 0x20000 0x40000\0" +#define UPDATE_KERNEL \ + "update_kernel=" \ + "tftpboot 0x70000000 ${_kernel}; " \ + "nand erase 0x100000 0x200000; " \ + "nand write 0x70000000 0x100000 0x200000\0" +#define UPDATE_FS \ + "update_fs=" \ + "tftpboot 0x70000000 ${_rootfs}; " \ + "nand erase 0x300000 0xfd00000; " \ + "nand write 0x70000000 0x300000 ${filesize}\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + UPDATE_BOOTSTRAP \ + UPDATE_UBOOT \ + UPDATE_KERNEL \ + UPDATE_FS \ + "_bootstrap=arm/at91bootstrap.bin\0" \ + "_uboot=arm/u-boot.bin\0" \ + "_kernel=arm/linux-kernel.bin\0" \ + "_rootfs=arm/atmel_fs.bin\0"
-#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 }
#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 @@ -216,7 +253,8 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) - +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - \ + GENERATED_GBL_DATA_SIZE) #define CONFIG_STACKSIZE (32*1024) /* regular stack */
#ifdef CONFIG_USE_IRQ
Add the default generic at91sam9m10g45ek_config target to the new config system. Not all possible configurations of u-boot for the at91sam9m10g45ek are included yet. Add them as needed.
Signed-off-by: Alex Waterman awaterman@dawning.com --- boards.cfg | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/boards.cfg b/boards.cfg index dfefc3f..470bc18 100644 --- a/boards.cfg +++ b/boards.cfg @@ -72,6 +72,7 @@ netstar arm arm925t voiceblue arm arm925t omap1510inn arm arm925t - ti aspenite arm arm926ejs - Marvell armada100 +at91sam9m10g45ek arm arm926ejs at91sam9m10g45ek atmel at91 afeb9260 arm arm926ejs - - at91 at91cap9adk arm arm926ejs - atmel at91 at91sam9260ek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_NANDFLASH
Also, some notes:
Dear Alex Waterman,
- writel(1 << ATMEL_ID_USART0, &pmc->pcer);
- writel(1 << ATMEL_ID_USART1, &pmc->pcer);
- writel(1 << ATMEL_ID_USART2, &pmc->pcer);
- writel(1 << ATMEL_ID_USART3, &pmc->pcer);
If this is the debug UART, ID_USART3 is definitely wrong here. Also following the example set up by at91sam9260_devives.c, this function should be named "at91_seriald_hw_init".
There should be no such function left after rework.
/* Enable clock */
/* Enable clock */
Those also miss the pull-up option like in at91sam9260_devices.c.
Please fix this file in the style done by at91sam9260_devices.c or wait until I have done so.
Best Regards, Reinhard
Dear Alex Waterman,
NAK. "Compile problems" for some boards shall not be fixed by hacks into common source. Fix the board's definition file instead.
Hello.
Signed-off-by: Alex Watermanawaterman@dawning.com
- volatile int i = 0;
Why 'volatile'? Also, there shouldn't be an empty line before it but there should be one after it...
writel(USART3_BIT(RSTRX) | USART3_BIT(RSTTX),&usart->cr); @@ -61,6 +63,10 @@ int serial_init(void) | USART3_BF(NBSTOP, USART3_NBSTOP_1)), &usart->mr);
- /* Short wait to let the serial port init. */
- for (; i < 10000; i++)
- return 0; }
WBR, Sergei
I used a volatile to prevent the compiler from optimizing out the (normally) useless loop. Is there a cleaner way to do this?
Best regards, Alex
Hi Alex,
If the board supports udelay(), you should use that instead of a loop.
Best regards, Alex
Amicalement,
Dear Alex Waterman,
1. Why is this delay needed in the first place? Apparently it has not been required before.
2. Such a delay loop is highly dependant on toolchain, cache and page situation and processor speed. It can not be accepted as a solution. If a delay is really required here and cannot be substituting by reading the UARTs status register, udelay() must be used.
Dear Alex Waterman,
+/*#define DEBUG*/
Must be CONFIG_SYS_AT91_SLOW_CLOCK here.
- Hardware drivers
Please follow the examples in at91sam9260ek.h There is no CONFIG_USARTx anymore. Just defining BASE and ID is sufficient.
- This needs to be defined for the OHCI code to work but it is defined as
- ATMEL_ID_UHPHS in the CPU specific header files.
- Specify the clock enable bit in the PMC_SCER register.
- BOOTP options
Thanks for removing the "1"s !
- Command line configuration.
Preferably those numeric constants should be replaced by defines from a proper at91sam10g45.h....
- "bootm 0x70000000"
- "console=ttyS0,115200 " \
- "mtdparts=atmel_nand:128k(bootstrap)ro," \
- "256k(uboot)ro,128k(env1)ro,128k(env2)ro," \
- "2M@1M(linux),-(root) " \
-#endif +/*
- Extra environment variables.
- "update_bootstrap=" \
- "tftpboot 0x70000000 ${_bootstrap}; " \
- "nand erase 0x0 0x20000; " \
- "nand write 0x70000000 0x0 0x20000\0"
- "update_uboot=" \
- "tftpboot 0x70000000 ${_uboot}; " \
- "nand erase 0x20000 0x40000; " \
- "nand write 0x70000000 0x20000 0x40000\0"
- "update_kernel=" \
- "tftpboot 0x70000000 ${_kernel}; " \
- "nand erase 0x100000 0x200000; " \
- "nand write 0x70000000 0x100000 0x200000\0"
- "update_fs=" \
- "tftpboot 0x70000000 ${_rootfs}; " \
- "nand erase 0x300000 0xfd00000; " \
- "nand write 0x70000000 0x300000 ${filesize}\0"
- UPDATE_BOOTSTRAP \
- UPDATE_UBOOT \
- UPDATE_KERNEL \
- UPDATE_FS \
- "_bootstrap=arm/at91bootstrap.bin\0" \
- "_uboot=arm/u-boot.bin\0" \
- "_kernel=arm/linux-kernel.bin\0" \
- "_rootfs=arm/atmel_fs.bin\0"
- Size of malloc() pool
Dear Alex Waterman,
Please sort by manufacturer. The at91sam9m10 would be behind any atmel at91sam926x boards.
Hello Alex,
I am interested in seeing this work merged into U-Boot. Will you have the time to fix the issues pointed out by Reinhard Meyer and post an updated version, or would you accept if somebody else takes over your patch set and posts an updated version ?
Thanks,
Thomas
Le Thu, 30 Jun 2011 15:32:59 -0400, Alex Waterman awaterman@dawning.com a écrit :
Also, some notes:
participants (7)
Albert ARIBAUD
Alex Waterman
Alex.Waterman.awaterman@dawning.com
Reinhard Meyer
Sergei Shtylyov
Thomas Petazzoni
William C. Landolina
