[PATCH v5 0/2] cmd: Add support for optee commands.
Add the basic 'hello world ta' command which increments the value passed. This provides easy test for establishing a session with OP-TEE TA and verify.
It includes following subcommands: optee hello optee hello <value>; value to increment via OP-TEE HELLO WORLD TA.
Changes in v2: - Added command "optee" and subdommand "hello". - Update the man-page in doc/usage/cmd/optee.rst Changes in v3: - Rename the config from OPTEE_HELLO_WORLD_TA to CMD_OPTEE. - Rename the file from optee_hello_world_ta.c to optee.c - Add the hextoul from dectoul. Changes in v4: - Removed the hello_world_ta_open_session() and included in the hello_world_ta() itself. Changes in v5: - Updated the printf statements. - Fixed the description for doc usage.
Venkatesh Yadav Abbarapu (2): cmd: Add support for optee commands doc: man-page for optee commands
cmd/Kconfig | 6 ++++ cmd/Makefile | 1 + cmd/optee.c | 76 +++++++++++++++++++++++++++++++++++++++++ doc/usage/cmd/optee.rst | 70 +++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 5 files changed, 154 insertions(+) create mode 100644 cmd/optee.c create mode 100644 doc/usage/cmd/optee.rst
Add the basic 'hello world ta' command which increment of the value passed. This provides easy test for establishing a session with OP-TEE TA and verify.
It includes following "hello world ta" subcommands: optee hello; default value '0' is passed and gets incremented. optee hello <value>; value to increment via OP-TEE HELLO WORLD TA.
To enable the OP-TEE side HELLO WORLD example please refer https://optee.readthedocs.io/en/latest/building/gits/optee_examples/optee_ex...
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- cmd/Kconfig | 6 +++++ cmd/Makefile | 1 + cmd/optee.c | 76 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 83 insertions(+) create mode 100644 cmd/optee.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 1d7ddb4ed36..4b33468891e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1446,6 +1446,12 @@ config CMD_OPTEE_RPMB in the Replay Protection Memory Block partition in eMMC by using Persistent Objects in OPTEE
+config CMD_OPTEE + bool "Enable OP-TEE commands" + depends on OPTEE + help + OP-TEE commands support. + config CMD_MTD bool "mtd" depends on MTD diff --git a/cmd/Makefile b/cmd/Makefile index d1f369deec0..533d0f6a1be 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -118,6 +118,7 @@ obj-$(CONFIG_CMD_PAUSE) += pause.o obj-$(CONFIG_CMD_SLEEP) += sleep.o obj-$(CONFIG_CMD_MMC) += mmc.o obj-$(CONFIG_CMD_OPTEE_RPMB) += optee_rpmb.o +obj-$(CONFIG_CMD_OPTEE) += optee.o obj-$(CONFIG_CMD_MP) += mp.o obj-$(CONFIG_CMD_MTD) += mtd.o obj-$(CONFIG_CMD_MTDPARTS) += mtdparts.o diff --git a/cmd/optee.c b/cmd/optee.c new file mode 100644 index 00000000000..e8d5f4ceb36 --- /dev/null +++ b/cmd/optee.c @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2024, Advanced Micro Devices, Inc. + */ +#include <command.h> +#include <errno.h> +#include <tee.h> +#include <vsprintf.h> + +#define TA_HELLO_WORLD_CMD_INC_VALUE 0 +/* This needs to match the UUID of the Hello World TA. */ +#define TA_HELLO_WORLD_UUID \ + { 0x8aaaf200, 0x2450, 0x11e4, \ + { 0xab, 0xe2, 0x00, 0x02, 0xa5, 0xd5, 0xc5, 0x1b} } + +static int hello_world_ta(unsigned int value) +{ + const struct tee_optee_ta_uuid uuid = TA_HELLO_WORLD_UUID; + struct tee_open_session_arg session_arg; + struct udevice *tee = NULL; + struct tee_invoke_arg arg; + struct tee_param param[2]; + int rc; + + tee = tee_find_device(tee, NULL, NULL, NULL); + if (!tee) + return -ENODEV; + + memset(&session_arg, 0, sizeof(session_arg)); + tee_optee_ta_uuid_to_octets(session_arg.uuid, &uuid); + rc = tee_open_session(tee, &session_arg, 0, NULL); + if (rc) { + printf("tee_open_session(): failed(%d)\n", rc); + return rc; + } + + arg.func = TA_HELLO_WORLD_CMD_INC_VALUE; + arg.session = session_arg.session; + + param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_INOUT; + param[0].u.value.a = value; + + printf("Value before: 0x%x\n", (int)param[0].u.value.a); + printf("Calling TA\n"); + tee_invoke_func(tee, &arg, 1, param); + + printf("Value after: 0x%x\n", (int)param[0].u.value.a); + return tee_close_session(tee, session_arg.session); +} + +static int do_optee_hello_world_ta(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + int ret, value = 0; + + if (strcmp(argv[1], NULL)) + value = hextoul(argv[1], NULL); + + ret = hello_world_ta(value); + if (ret) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +U_BOOT_LONGHELP(optee, + "- commands can be verified on OP-TEE\n\n" + "optee hello\n" + "optee hello <value>\n" + "\n" + "With:\n" + "\t<value>: integer value\n" + ); + +U_BOOT_CMD_WITH_SUBCMDS(optee, "OP-TEE commands", optee_help_text, + U_BOOT_SUBCMD_MKENT(hello, 2, 1, do_optee_hello_world_ta));
+config CMD_OPTEE
- bool "Enable OP-TEE commands"
- depends on OPTEE
- help
- (C) Copyright 2024, Advanced Micro Devices, Inc.
- { 0x8aaaf200, 0x2450, 0x11e4, \
- { 0xab, 0xe2, 0x00, 0x02, 0xa5, 0xd5, 0xc5, 0x1b} }
- const struct tee_optee_ta_uuid uuid = TA_HELLO_WORLD_UUID;
- struct tee_open_session_arg session_arg;
- struct udevice *tee = NULL;
- struct tee_invoke_arg arg;
- struct tee_param param[2];
- int rc;
- tee = tee_find_device(tee, NULL, NULL, NULL);
- if (!tee)
return -ENODEV;
- memset(&session_arg, 0, sizeof(session_arg));
- tee_optee_ta_uuid_to_octets(session_arg.uuid, &uuid);
- rc = tee_open_session(tee, &session_arg, 0, NULL);
- if (rc) {
return rc;
- arg.func = TA_HELLO_WORLD_CMD_INC_VALUE;
- arg.session = session_arg.session;
- param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_INOUT;
- param[0].u.value.a = value;
- printf("Value before: 0x%x\n", (int)param[0].u.value.a);
- printf("Calling TA\n");
- tee_invoke_func(tee, &arg, 1, param);
- printf("Value after: 0x%x\n", (int)param[0].u.value.a);
- return tee_close_session(tee, session_arg.session);
- int ret, value = 0;
- if (strcmp(argv[1], NULL))
- ret = hello_world_ta(value);
- if (ret)
- return CMD_RET_SUCCESS;
What is this supposed to mean?
"optee hello\n"
Optional values are usually indicated with []
"\n"
"With:\n"
I believe the following should be clear and good enough:
U_BOOT_LONGHELP(optee, "hello [<value>] Invoke the OP-TEE 'Hello World' TA\n"); U_BOOT_CMD_WITH_SUBCMDS(optee, "OP-TEE commands", optee_help_text, U_BOOT_SUBCMD_MKENT(hello, 2, 1, do_optee_hello_world_ta));
With that:
Reviewed-by: Jerome Forissier jerome.forissier@linaro.org
Thanks,
Provide a man-page for the optee command.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/usage/cmd/optee.rst | 70 +++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 71 insertions(+) create mode 100644 doc/usage/cmd/optee.rst
diff --git a/doc/usage/cmd/optee.rst b/doc/usage/cmd/optee.rst new file mode 100644 index 00000000000..532d488d5e3 --- /dev/null +++ b/doc/usage/cmd/optee.rst @@ -0,0 +1,70 @@ +.. SPDX-License-Identifier: GPL-2.0 + +.. index:: + single: optee (command) + +optee command +============= + +Synopsis +-------- + +:: + + optee hello + optee hello <value> + +Description +----------- + +This is an OP-TEE sanity test which invokes the "Hello World" +Trusted Application (TA). The TA does two things: +- It prints debug and information messages to the secure console (if logging is enabled) +- It increments the integer value passed as a parameter and returns it """ + + +value + Integer value that the TA is expected to increment and return. + The default value is 0. + +To enable the OP-TEE Hello World example please refer +https://optee.readthedocs.io/en/latest/building/gits/optee_examples/optee_ex... + +Examples +-------- + +:: + + ==> optee hello + D/TA: TA_CreateEntryPoint:39 has been called + I/TA: Hello World! + Value before: 0x0 + Calling TA + D/TA: inc_value:105 has been called + I/TA: Got value: 0 from NW + I/TA: Increase value to: 1 + Value after: 0x1 + I/TA: Goodbye! + D/TA: TA_DestroyEntryPoint:50 has been called + + ==> optee hello 74 + D/TA: TA_CreateEntryPoint:39 has been called + I/TA: Hello World! + Value before: 0x74 + Calling TA + D/TA: inc_value:105 has been called + I/TA: Got value: 116 from NW + I/TA: Increase value to: 117 + Value after: 0x75 + I/TA: Goodbye! + D/TA: TA_DestroyEntryPoint:50 has been called + +Configuration +------------- + +The optee command is enabled by CONFIG_OPTEE=y and CONFIG_CMD_OPTEE=y. + +Return value +------------ + +The return value $? is 0 (true) if the command succeeds, 1 (false) otherwise. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index cb7a23f1170..4dd00f002cd 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -92,6 +92,7 @@ Shell commands cmd/msr cmd/mtest cmd/mtrr + cmd/optee cmd/panic cmd/part cmd/pause
+.. index::
- single: optee (command)
+Synopsis +--------
- optee hello
- optee hello <value>
Drop the """
+value
- Integer value that the TA is expected to increment and return.
- The default value is 0.
+Examples +--------
- ==> optee hello
- D/TA: TA_CreateEntryPoint:39 has been called
- I/TA: Hello World!
- Value before: 0x0
- Calling TA
- D/TA: inc_value:105 has been called
- I/TA: Got value: 0 from NW
- I/TA: Increase value to: 1
- Value after: 0x1
- I/TA: Goodbye!
- D/TA: TA_DestroyEntryPoint:50 has been called
- ==> optee hello 74
- Value before: 0x74
- Calling TA
- I/TA: Got value: 116 from NW
- I/TA: Increase value to: 117
- Value after: 0x75
- I/TA: Goodbye!
- cmd/optee cmd/panic cmd/part cmd/pause
Thanks,
Jerome Forissier
