[U-Boot] [PATCH 1/2] driver/ddr/fsl: Add DDR4 support to Freescale DDR driver
Mostly reusing DDR3 driver, this patch adds DDR4 SPD handling, register calculation and programming.
Signed-off-by: York Sun yorksun@freescale.com --- Tested on T1040QDS_D4 (patch following).
README | 13 +- arch/powerpc/include/asm/config_mpc85xx.h | 17 +- common/ddr_spd.c | 45 +- drivers/ddr/fsl/Makefile | 19 +- drivers/ddr/fsl/ctrl_regs.c | 739 ++++++++++++++++++-- drivers/ddr/fsl/ddr4_dimm_params.c | 300 ++++++++ drivers/ddr/fsl/{arm_ddr_gen3.c => fsl_ddr_gen4.c} | 56 +- drivers/ddr/fsl/interactive.c | 391 ++++++++++- drivers/ddr/fsl/lc_common_dimm_params.c | 407 ++++++----- drivers/ddr/fsl/main.c | 25 +- drivers/ddr/fsl/options.c | 34 +- drivers/ddr/fsl/util.c | 26 +- include/common_timing_params.h | 23 +- include/ddr_spd.h | 226 +++++- include/fsl_ddr.h | 7 +- include/fsl_ddr_dimm_params.h | 77 +- include/fsl_ddr_sdram.h | 63 +- include/fsl_ddrc_version.h | 18 + include/fsl_immap.h | 35 +- 19 files changed, 2182 insertions(+), 339 deletions(-) create mode 100644 drivers/ddr/fsl/ddr4_dimm_params.c copy drivers/ddr/fsl/{arm_ddr_gen3.c => fsl_ddr_gen4.c} (81%) create mode 100644 include/fsl_ddrc_version.h
diff --git a/README b/README index 216f0c7..349d982 100644 --- a/README +++ b/README @@ -454,6 +454,9 @@ The following options need to be configured: CONFIG_SYS_FSL_DDRC_GEN3 Freescale DDR3 controller.
+ CONFIG_SYS_FSL_DDRC_GEN4 + Freescale DDR4 controller. + CONFIG_SYS_FSL_DDRC_ARM_GEN3 Freescale DDR3 controller for ARM-based SoCs.
@@ -469,7 +472,15 @@ The following options need to be configured:
CONFIG_SYS_FSL_DDR3 Board config to use DDR3. It can be enabled for SoCs with - Freescale DDR3 controllers. + Freescale DDR3 or DDR3L controllers. + + CONFIG_SYS_FSL_DDR3L + Board config to use DDR3L. It can be enabled for SoCs with + DDR3L controllers. + + CONFIG_SYS_FSL_DDR4 + Board config to use DDR4. It can be enabled for SoCs with + DDR4 controllers.
CONFIG_SYS_FSL_IFC_BE Defines the IFC controller register space as Big Endian diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 9a20b97..727e981 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -19,8 +19,8 @@ */ #define CONFIG_PPC_SPINTABLE_COMPATIBLE
-#define FSL_DDR_VER_4_7 47 -#define FSL_DDR_VER_5_0 50 +#include <fsl_ddrc_version.h> +#define CONFIG_SYS_FSL_DDR_BE
/* IP endianness */ #define CONFIG_SYS_FSL_IFC_BE @@ -401,6 +401,7 @@ #define CONFIG_SYS_NUM_FM1_DTSEC 5 #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_5 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" @@ -442,6 +443,7 @@ #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_SYS_NUM_FM2_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_4 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -490,6 +492,7 @@ #define CONFIG_SYS_NUM_FM1_DTSEC 5 #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_4 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 32 @@ -527,6 +530,7 @@ #define CONFIG_SYS_NUM_FM2_DTSEC 5 #define CONFIG_SYS_NUM_FM2_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_4 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -553,6 +557,7 @@ #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_4 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 @@ -571,6 +576,7 @@ #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_6 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_DSP_DDR_ADDR 0x40000000 #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 @@ -704,6 +710,9 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ +#ifdef CONFIG_SYS_FSL_DDR4 +#define CONFIG_SYS_FSL_DDRC_GEN4 +#endif #if defined(CONFIG_PPC_T1040) || defined(CONFIG_PPC_T1042) #define CONFIG_MAX_CPUS 4 #elif defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) @@ -788,6 +797,7 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_SYS_FSL_SEC_COMPAT 6 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_6 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_A005125 @@ -808,7 +818,8 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022)
#if !defined(CONFIG_SYS_FSL_DDRC_GEN1) && \ !defined(CONFIG_SYS_FSL_DDRC_GEN2) && \ - !defined(CONFIG_SYS_FSL_DDRC_GEN3) + !defined(CONFIG_SYS_FSL_DDRC_GEN3) && \ + !defined(CONFIG_SYS_FSL_DDRC_GEN4) #define CONFIG_SYS_FSL_DDRC_GEN3 #endif
diff --git a/common/ddr_spd.c b/common/ddr_spd.c index 7a388bb..438e71a 100644 --- a/common/ddr_spd.c +++ b/common/ddr_spd.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -116,3 +116,46 @@ ddr3_spd_check(const ddr3_spd_eeprom_t *spd) return 1; } } + +unsigned int ddr4_spd_check(const struct ddr4_spd_eeprom_s *spd) +{ + char *p = (char *)spd; + int csum16; + int len; + char crc_lsb; /* byte 126 */ + char crc_msb; /* byte 127 */ + + len = 126; + csum16 = crc16(p, len); + + crc_lsb = (char) (csum16 & 0xff); + crc_msb = (char) (csum16 >> 8); + + if (spd->crc[0] != crc_lsb || spd->crc[1] != crc_msb) { + printf("SPD checksum unexpected.\n" + "Checksum lsb in SPD = %02X, computed SPD = %02X\n" + "Checksum msb in SPD = %02X, computed SPD = %02X\n", + spd->crc[0], crc_lsb, spd->crc[1], crc_msb); + return 1; + } + + p = (char *)((ulong)spd + 128); + len = 126; + csum16 = crc16(p, len); + + crc_lsb = (char) (csum16 & 0xff); + crc_msb = (char) (csum16 >> 8); + + if (spd->mod_section.uc[126] != crc_lsb || + spd->mod_section.uc[127] != crc_msb) { + printf("SPD checksum unexpected.\n" + "Checksum lsb in SPD = %02X, computed SPD = %02X\n" + "Checksum msb in SPD = %02X, computed SPD = %02X\n", + spd->mod_section.uc[126], + crc_lsb, spd->mod_section.uc[127], + crc_msb); + return 1; + } + + return 0; +} diff --git a/drivers/ddr/fsl/Makefile b/drivers/ddr/fsl/Makefile index 265204f..df66c07 100644 --- a/drivers/ddr/fsl/Makefile +++ b/drivers/ddr/fsl/Makefile @@ -1,19 +1,20 @@ # -# Copyright 2008-2011 Freescale Semiconductor, Inc. +# Copyright 2008-2014 Freescale Semiconductor, Inc. # # This program is free software; you can redistribute it and/or # modify it under the terms of the GNU General Public License # Version 2 as published by the Free Software Foundation. #
-obj-$(CONFIG_SYS_FSL_DDR1) += main.o util.o ctrl_regs.o options.o \ - lc_common_dimm_params.o +obj-$(CONFIG_SYS_FSL_DDR1) += main.o util.o ctrl_regs.o options.o \ + lc_common_dimm_params.o +obj-$(CONFIG_SYS_FSL_DDR2) += main.o util.o ctrl_regs.o options.o \ + lc_common_dimm_params.o +obj-$(CONFIG_SYS_FSL_DDR3) += main.o util.o ctrl_regs.o options.o \ + lc_common_dimm_params.o +obj-$(CONFIG_SYS_FSL_DDR4) += main.o util.o ctrl_regs.o options.o \ + lc_common_dimm_params.o
-obj-$(CONFIG_SYS_FSL_DDR2) += main.o util.o ctrl_regs.o options.o \ - lc_common_dimm_params.o - -obj-$(CONFIG_SYS_FSL_DDR3) += main.o util.o ctrl_regs.o options.o \ - lc_common_dimm_params.o ifdef CONFIG_DDR_SPD SPD := y endif @@ -24,6 +25,7 @@ ifdef SPD obj-$(CONFIG_SYS_FSL_DDR1) += ddr1_dimm_params.o obj-$(CONFIG_SYS_FSL_DDR2) += ddr2_dimm_params.o obj-$(CONFIG_SYS_FSL_DDR3) += ddr3_dimm_params.o +obj-$(CONFIG_SYS_FSL_DDR4) += ddr4_dimm_params.o endif
obj-$(CONFIG_FSL_DDR_INTERACTIVE) += interactive.o @@ -32,3 +34,4 @@ obj-$(CONFIG_SYS_FSL_DDRC_GEN2) += mpc85xx_ddr_gen2.o obj-$(CONFIG_SYS_FSL_DDRC_GEN3) += mpc85xx_ddr_gen3.o obj-$(CONFIG_SYS_FSL_DDR_86XX) += mpc86xx_ddr.o obj-$(CONFIG_SYS_FSL_DDRC_ARM_GEN3) += arm_ddr_gen3.o +obj-$(CONFIG_SYS_FSL_DDRC_GEN4) += fsl_ddr_gen4.o diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 0882932..d01eea0 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -1,5 +1,5 @@ /* - * Copyright 2008-2012 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -17,20 +17,6 @@ #include <fsl_immap.h> #include <asm/io.h>
-#define _DDR_ADDR CONFIG_SYS_FSL_DDR_ADDR - -static u32 fsl_ddr_get_version(void) -{ - struct ccsr_ddr __iomem *ddr; - u32 ver_major_minor_errata; - - ddr = (void *)_DDR_ADDR; - ver_major_minor_errata = (ddr_in32(&ddr->ip_rev1) & 0xFFFF) << 8; - ver_major_minor_errata |= (ddr_in32(&ddr->ip_rev2) & 0xFF00) >> 8; - - return ver_major_minor_errata; -} - unsigned int picos_to_mclk(unsigned int picos);
/* @@ -81,6 +67,39 @@ static inline int fsl_ddr_get_rtt(void) return rtt; }
+#ifdef CONFIG_SYS_FSL_DDR4 +/* + * compute CAS write latency according to DDR4 spec + * CWL = 9 for <= 1600MT/s + * 10 for <= 1866MT/s + * 11 for <= 2133MT/s + * 12 for <= 2400MT/s + * 14 for <= 2667MT/s + * 16 for <= 2933MT/s + * 18 for higher + */ +static inline unsigned int compute_cas_write_latency(void) +{ + unsigned int cwl; + const unsigned int mclk_ps = get_memory_clk_period_ps(); + if (mclk_ps >= 1250) + cwl = 9; + else if (mclk_ps >= 1070) + cwl = 10; + else if (mclk_ps >= 935) + cwl = 11; + else if (mclk_ps >= 833) + cwl = 12; + else if (mclk_ps >= 750) + cwl = 14; + else if (mclk_ps >= 681) + cwl = 16; + else + cwl = 18; + + return cwl; +} +#else /* * compute the CAS write latency according to DDR3 spec * CWL = 5 if tCK >= 2.5ns @@ -119,6 +138,7 @@ static inline unsigned int compute_cas_write_latency(void) } return cwl; } +#endif
/* Chip Select Configuration (CSn_CONFIG) */ static void set_csn_config(int dimm_number, int i, fsl_ddr_cfg_regs_t *ddr, @@ -135,6 +155,11 @@ static void set_csn_config(int dimm_number, int i, fsl_ddr_cfg_regs_t *ddr, unsigned int row_bits_cs_n = 0; /* Num of row bits for SDRAM on CSn */ unsigned int col_bits_cs_n = 0; /* Num of ocl bits for SDRAM on CSn */ int go_config = 0; +#ifdef CONFIG_SYS_FSL_DDR4 + unsigned int bg_bits_cs_n = 0; /* Num of bank group bits */ +#else + unsigned int n_banks_per_sdram_device; +#endif
/* Compute CS_CONFIG only for existing ranks of each DIMM. */ switch (i) { @@ -178,14 +203,18 @@ static void set_csn_config(int dimm_number, int i, fsl_ddr_cfg_regs_t *ddr, break; } if (go_config) { - unsigned int n_banks_per_sdram_device; cs_n_en = 1; ap_n_en = popts->cs_local_opts[i].auto_precharge; odt_rd_cfg = popts->cs_local_opts[i].odt_rd_cfg; odt_wr_cfg = popts->cs_local_opts[i].odt_wr_cfg; +#ifdef CONFIG_SYS_FSL_DDR4 + ba_bits_cs_n = dimm_params[dimm_number].bank_addr_bits; + bg_bits_cs_n = dimm_params[dimm_number].bank_group_bits; +#else n_banks_per_sdram_device = dimm_params[dimm_number].n_banks_per_sdram_device; ba_bits_cs_n = __ilog2(n_banks_per_sdram_device) - 2; +#endif row_bits_cs_n = dimm_params[dimm_number].n_row_addr - 12; col_bits_cs_n = dimm_params[dimm_number].n_col_addr - 8; } @@ -203,6 +232,9 @@ static void set_csn_config(int dimm_number, int i, fsl_ddr_cfg_regs_t *ddr,
| ((ba_bits_cs_n & 0x3) << 14) | ((row_bits_cs_n & 0x7) << 8) +#ifdef CONFIG_SYS_FSL_DDR4 + | ((bg_bits_cs_n & 0x3) << 4) +#endif | ((col_bits_cs_n & 0x7) << 0) ); debug("FSLDDR: cs[%d]_config = 0x%08x\n", i,ddr->cs[i].config); @@ -262,11 +294,23 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, /* Precharge powerdown exit timing (tXP). */ unsigned char pre_pd_exit_mclk; /* ODT powerdown exit timing (tAXPD). */ - unsigned char taxpd_mclk; + unsigned char taxpd_mclk = 0; /* Mode register set cycle time (tMRD). */ unsigned char tmrd_mclk;
-#ifdef CONFIG_SYS_FSL_DDR3 +#ifdef CONFIG_SYS_FSL_DDR4 + /* tXP=max(4nCK, 6ns) */ + int txp = max((get_memory_clk_period_ps() * 4), 6000); /* unit=ps */ + trwt_mclk = 2; + twrt_mclk = 1; + act_pd_exit_mclk = picos_to_mclk(txp); + pre_pd_exit_mclk = act_pd_exit_mclk; + /* + * MRS_CYC = max(tMRD, tMOD) + * tMRD = 8nCK, tMOD = max(24nCK, 15ns) + */ + tmrd_mclk = max(24, picos_to_mclk(15000)); +#elif defined(CONFIG_SYS_FSL_DDR3) /* * (tXARD and tXARDS). Empirical? * The DDR3 spec has not tXARD, @@ -275,7 +319,7 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, * spec has not the tAXPD, we use * tAXPD=1, need design to confirm. */ - int tXP = max((get_memory_clk_period_ps() * 3), 7500); /* unit=ps */ + int txp = max((get_memory_clk_period_ps() * 3), 7500); /* unit=ps */ unsigned int data_rate = get_ddr_freq(0); tmrd_mclk = 4; /* set the turnaround time */ @@ -300,7 +344,7 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr, taxpd_mclk = 1; } else { /* act_pd_exit_mclk = tXARD, see above */ - act_pd_exit_mclk = picos_to_mclk(tXP); + act_pd_exit_mclk = picos_to_mclk(txp); /* Mode register MR0[A12] is '1' - fast exit */ pre_pd_exit_mclk = act_pd_exit_mclk; taxpd_mclk = 1; @@ -364,8 +408,12 @@ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, ext_acttorw = picos_to_mclk(common_dimm->trcd_ps) >> 4; ext_caslat = (2 * cas_latency - 1) >> 4; ext_add_lat = additive_latency >> 4; +#ifdef CONFIG_SYS_FSL_DDR4 + ext_refrec = (picos_to_mclk(common_dimm->trfc1_ps) - 8) >> 4; +#else ext_refrec = (picos_to_mclk(common_dimm->trfc_ps) - 8) >> 4; /* ext_wrrec only deals with 16 clock and above, or 14 with OTF */ +#endif ext_wrrec = (picos_to_mclk(common_dimm->twr_ps) + (popts->otf_burst_chop_en ? 2 : 0)) >> 4;
@@ -404,9 +452,19 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, unsigned char acttoact_mclk; /* Last write data pair to read command issue interval (tWTR) */ unsigned char wrtord_mclk; +#ifdef CONFIG_SYS_FSL_DDR4 + /* DDR4 supports 10, 12, 14, 16, 18, 20, 24 */ + static const u8 wrrec_table[] = { + 10, 10, 10, 10, 10, + 10, 10, 10, 10, 10, + 12, 12, 14, 14, 16, + 16, 18, 18, 20, 20, + 24, 24, 24, 24}; +#else /* DDR_SDRAM_MODE doesn't support 9,11,13,15 */ static const u8 wrrec_table[] = { 1, 2, 3, 4, 5, 6, 7, 8, 10, 10, 12, 12, 14, 14, 0, 0}; +#endif
pretoact_mclk = picos_to_mclk(common_dimm->trp_ps); acttopre_mclk = picos_to_mclk(common_dimm->tras_ps); @@ -438,20 +496,34 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, * we need set extend bit for it at * TIMING_CFG_3[EXT_CASLAT] */ - caslat_ctrl = 2 * cas_latency - 1; + if (fsl_ddr_get_version() <= 0x40400) + caslat_ctrl = 2 * cas_latency - 1; + else + caslat_ctrl = (cas_latency - 1) << 1; #endif
+#ifdef CONFIG_SYS_FSL_DDR4 + refrec_ctrl = picos_to_mclk(common_dimm->trfc1_ps) - 8; + wrrec_mclk = picos_to_mclk(common_dimm->twr_ps); + acttoact_mclk = max(picos_to_mclk(common_dimm->trrds_ps), 4); + wrtord_mclk = max(2, picos_to_mclk(2500)); + if (wrrec_mclk > 24) + printf("Error: WRREC doesn't support more than 24 clocks\n"); + else + wrrec_mclk = wrrec_table[wrrec_mclk - 1]; +#else refrec_ctrl = picos_to_mclk(common_dimm->trfc_ps) - 8; wrrec_mclk = picos_to_mclk(common_dimm->twr_ps); - + acttoact_mclk = picos_to_mclk(common_dimm->trrd_ps); + wrtord_mclk = picos_to_mclk(common_dimm->twtr_ps); if (wrrec_mclk > 16) printf("Error: WRREC doesn't support more than 16 clocks\n"); else wrrec_mclk = wrrec_table[wrrec_mclk - 1]; +#endif if (popts->otf_burst_chop_en) wrrec_mclk += 2;
- acttoact_mclk = picos_to_mclk(common_dimm->trrd_ps); /* * JEDEC has min requirement for tRRD */ @@ -459,7 +531,6 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, if (acttoact_mclk < 4) acttoact_mclk = 4; #endif - wrtord_mclk = picos_to_mclk(common_dimm->twtr_ps); /* * JEDEC has some min requirements for tWTR */ @@ -526,14 +597,18 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, wr_lat = compute_cas_write_latency(); #endif
+#ifdef CONFIG_SYS_FSL_DDR4 + rd_to_pre = picos_to_mclk(7500); +#else rd_to_pre = picos_to_mclk(common_dimm->trtp_ps); +#endif /* * JEDEC has some min requirements for tRTP */ #if defined(CONFIG_SYS_FSL_DDR2) if (rd_to_pre < 2) rd_to_pre = 2; -#elif defined(CONFIG_SYS_FSL_DDR3) +#elif defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) if (rd_to_pre < 4) rd_to_pre = 4; #endif @@ -541,13 +616,20 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, rd_to_pre += 2; /* according to UM */
wr_data_delay = popts->write_data_delay; +#ifdef CONFIG_SYS_FSL_DDR4 + cpo = 0; + cke_pls = max(3, picos_to_mclk(5000)); +#else cke_pls = picos_to_mclk(popts->tcke_clock_pulse_width_ps); +#endif + four_act = picos_to_mclk(popts->tfaw_window_four_activates_ps);
ddr->timing_cfg_2 = (0 | ((add_lat_mclk & 0xf) << 28) | ((cpo & 0x1f) << 23) | ((wr_lat & 0xf) << 19) + | ((wr_lat & 0x10) << 14) | ((rd_to_pre & RD_TO_PRE_MASK) << RD_TO_PRE_SHIFT) | ((wr_data_delay & WR_DATA_DELAY_MASK) << WR_DATA_DELAY_SHIFT) | ((cke_pls & 0x7) << 6) @@ -640,7 +722,8 @@ static void set_ddr_sdram_cfg(fsl_ddr_cfg_regs_t *ddr, * we must clear it when use the on-the-fly mode, * must set it when use the 32-bits bus mode. */ - if (sdram_type == SDRAM_TYPE_DDR3) { + if ((sdram_type == SDRAM_TYPE_DDR3) || + (sdram_type == SDRAM_TYPE_DDR4)) { if (popts->burst_length == DDR_BL8) eight_be = 1; if (popts->burst_length == DDR_OTF) @@ -682,8 +765,6 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, { unsigned int frc_sr = 0; /* Force self refresh */ unsigned int sr_ie = 0; /* Self-refresh interrupt enable */ - unsigned int dll_rst_dis; /* DLL reset disable */ - unsigned int dqs_cfg; /* DQS configuration */ unsigned int odt_cfg = 0; /* ODT configuration */ unsigned int num_pr; /* Number of posted refreshes */ unsigned int slow = 0; /* DDR will be run less than 1250 */ @@ -695,9 +776,12 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, unsigned int md_en = 0; /* Mirrored DIMM Enable */ unsigned int qd_en = 0; /* quad-rank DIMM Enable */ int i; +#ifndef CONFIG_SYS_FSL_DDR4 + unsigned int dll_rst_dis = 1; /* DLL reset disable */ + unsigned int dqs_cfg; /* DQS configuration */
- dll_rst_dis = 1; /* Make this configurable */ dqs_cfg = popts->dqs_config; +#endif for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { if (popts->cs_local_opts[i].odt_rd_cfg || popts->cs_local_opts[i].odt_wr_cfg) { @@ -715,7 +799,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, * * ({EXT_REFREC || REFREC} + 8 + 2)]} * << DDR_SDRAM_INTERVAL[REFINT] */ -#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) obc_cfg = popts->otf_burst_chop_en; #else obc_cfg = 0; @@ -744,15 +828,17 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, d_init = 0; #endif
-#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) md_en = popts->mirrored_dimm; #endif qd_en = popts->quad_rank_present ? 1 : 0; ddr->ddr_sdram_cfg_2 = (0 | ((frc_sr & 0x1) << 31) | ((sr_ie & 0x1) << 30) +#ifndef CONFIG_SYS_FSL_DDR4 | ((dll_rst_dis & 0x1) << 29) | ((dqs_cfg & 0x3) << 26) +#endif | ((odt_cfg & 0x3) << 21) | ((num_pr & 0xf) << 12) | ((slow & 1) << 11) @@ -768,6 +854,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, debug("FSLDDR: ddr_sdram_cfg_2 = 0x%08x\n", ddr->ddr_sdram_cfg_2); }
+#ifdef CONFIG_SYS_FSL_DDR4 /* DDR SDRAM Mode configuration 2 (DDR_SDRAM_MODE_2) */ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, @@ -776,8 +863,93 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, { unsigned short esdmode2 = 0; /* Extended SDRAM mode 2 */ unsigned short esdmode3 = 0; /* Extended SDRAM mode 3 */ + int i; + unsigned int wr_crc = 0; /* Disable */ + unsigned int rtt_wr = 0; /* Rtt_WR - dynamic ODT off */ + unsigned int srt = 0; /* self-refresh temerature, normal range */ + unsigned int cwl = compute_cas_write_latency() - 9; + unsigned int mpr = 0; /* serial */ + unsigned int wc_lat; + const unsigned int mclk_ps = get_memory_clk_period_ps();
-#if defined(CONFIG_SYS_FSL_DDR3) + if (popts->rtt_override) + rtt_wr = popts->rtt_wr_override_value; + else + rtt_wr = popts->cs_local_opts[0].odt_rtt_wr; + + if (common_dimm->extended_op_srt) + srt = common_dimm->extended_op_srt; + + esdmode2 = (0 + | ((wr_crc & 0x1) << 12) + | ((rtt_wr & 0x3) << 9) + | ((srt & 0x3) << 6) + | ((cwl & 0x7) << 3)); + + if (mclk_ps >= 1250) + wc_lat = 0; + else if (mclk_ps >= 833) + wc_lat = 1; + else + wc_lat = 2; + + esdmode3 = (0 + | ((mpr & 0x3) << 11) + | ((wc_lat & 0x3) << 9)); + + ddr->ddr_sdram_mode_2 = (0 + | ((esdmode2 & 0xFFFF) << 16) + | ((esdmode3 & 0xFFFF) << 0) + ); + debug("FSLDDR: ddr_sdram_mode_2 = 0x%08x\n", ddr->ddr_sdram_mode_2); + + if (unq_mrs_en) { /* unique mode registers are supported */ + for (i = 1; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + if (popts->rtt_override) + rtt_wr = popts->rtt_wr_override_value; + else + rtt_wr = popts->cs_local_opts[i].odt_rtt_wr; + + esdmode2 &= 0xF9FF; /* clear bit 10, 9 */ + esdmode2 |= (rtt_wr & 0x3) << 9; + switch (i) { + case 1: + ddr->ddr_sdram_mode_4 = (0 + | ((esdmode2 & 0xFFFF) << 16) + | ((esdmode3 & 0xFFFF) << 0) + ); + break; + case 2: + ddr->ddr_sdram_mode_6 = (0 + | ((esdmode2 & 0xFFFF) << 16) + | ((esdmode3 & 0xFFFF) << 0) + ); + break; + case 3: + ddr->ddr_sdram_mode_8 = (0 + | ((esdmode2 & 0xFFFF) << 16) + | ((esdmode3 & 0xFFFF) << 0) + ); + break; + } + } + debug("FSLDDR: ddr_sdram_mode_4 = 0x%08x\n", + ddr->ddr_sdram_mode_4); + debug("FSLDDR: ddr_sdram_mode_6 = 0x%08x\n", + ddr->ddr_sdram_mode_6); + debug("FSLDDR: ddr_sdram_mode_8 = 0x%08x\n", + ddr->ddr_sdram_mode_8); + } +} +#elif defined(CONFIG_SYS_FSL_DDR3) +/* DDR SDRAM Mode configuration 2 (DDR_SDRAM_MODE_2) */ +static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + const unsigned int unq_mrs_en) +{ + unsigned short esdmode2 = 0; /* Extended SDRAM mode 2 */ + unsigned short esdmode3 = 0; /* Extended SDRAM mode 3 */ int i; unsigned int rtt_wr = 0; /* Rtt_WR - dynamic ODT off */ unsigned int srt = 0; /* self-refresh temerature, normal range */ @@ -799,14 +971,12 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, | ((asr & 0x1) << 6) | ((cwl & 0x7) << 3) | ((pasr & 0x7) << 0)); -#endif ddr->ddr_sdram_mode_2 = (0 | ((esdmode2 & 0xFFFF) << 16) | ((esdmode3 & 0xFFFF) << 0) ); debug("FSLDDR: ddr_sdram_mode_2 = 0x%08x\n", ddr->ddr_sdram_mode_2);
-#ifdef CONFIG_SYS_FSL_DDR3 if (unq_mrs_en) { /* unique mode registers are supported */ for (i = 1; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { if (popts->rtt_override) @@ -844,9 +1014,128 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, debug("FSLDDR: ddr_sdram_mode_8 = 0x%08x\n", ddr->ddr_sdram_mode_8); } +} + +#else /* for DDR2 and DDR1 */ +/* DDR SDRAM Mode configuration 2 (DDR_SDRAM_MODE_2) */ +static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + const unsigned int unq_mrs_en) +{ + unsigned short esdmode2 = 0; /* Extended SDRAM mode 2 */ + unsigned short esdmode3 = 0; /* Extended SDRAM mode 3 */ + + ddr->ddr_sdram_mode_2 = (0 + | ((esdmode2 & 0xFFFF) << 16) + | ((esdmode3 & 0xFFFF) << 0) + ); + debug("FSLDDR: ddr_sdram_mode_2 = 0x%08x\n", ddr->ddr_sdram_mode_2); +} #endif + +#ifdef CONFIG_SYS_FSL_DDR4 +/* DDR SDRAM Mode configuration 9 (DDR_SDRAM_MODE_9) */ +static void set_ddr_sdram_mode_9(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + const unsigned int unq_mrs_en) +{ + int i; + unsigned short esdmode4 = 0; /* Extended SDRAM mode 4 */ + unsigned short esdmode5; /* Extended SDRAM mode 5 */ + + esdmode5 = 0x00000400; /* Data mask enabled */ + + ddr->ddr_sdram_mode_9 = (0 + | ((esdmode4 & 0xffff) << 16) + | ((esdmode5 & 0xffff) << 0) + ); + debug("FSLDDR: ddr_sdram_mode_9) = 0x%08x\n", ddr->ddr_sdram_mode_9); + if (unq_mrs_en) { /* unique mode registers are supported */ + for (i = 1; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + switch (i) { + case 1: + ddr->ddr_sdram_mode_11 = (0 + | ((esdmode4 & 0xFFFF) << 16) + | ((esdmode5 & 0xFFFF) << 0) + ); + break; + case 2: + ddr->ddr_sdram_mode_13 = (0 + | ((esdmode4 & 0xFFFF) << 16) + | ((esdmode5 & 0xFFFF) << 0) + ); + break; + case 3: + ddr->ddr_sdram_mode_15 = (0 + | ((esdmode4 & 0xFFFF) << 16) + | ((esdmode5 & 0xFFFF) << 0) + ); + break; + } + } + debug("FSLDDR: ddr_sdram_mode_11 = 0x%08x\n", + ddr->ddr_sdram_mode_11); + debug("FSLDDR: ddr_sdram_mode_13 = 0x%08x\n", + ddr->ddr_sdram_mode_13); + debug("FSLDDR: ddr_sdram_mode_15 = 0x%08x\n", + ddr->ddr_sdram_mode_15); + } +} + +/* DDR SDRAM Mode configuration 10 (DDR_SDRAM_MODE_10) */ +static void set_ddr_sdram_mode_10(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + const unsigned int unq_mrs_en) +{ + int i; + unsigned short esdmode6 = 0; /* Extended SDRAM mode 6 */ + unsigned short esdmode7 = 0; /* Extended SDRAM mode 7 */ + unsigned int tccdl_min = picos_to_mclk(common_dimm->tccdl_ps); + + esdmode6 = ((tccdl_min - 4) & 0x7) << 10; + + ddr->ddr_sdram_mode_10 = (0 + | ((esdmode6 & 0xffff) << 16) + | ((esdmode7 & 0xffff) << 0) + ); + debug("FSLDDR: ddr_sdram_mode_10) = 0x%08x\n", ddr->ddr_sdram_mode_10); + if (unq_mrs_en) { /* unique mode registers are supported */ + for (i = 1; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + switch (i) { + case 1: + ddr->ddr_sdram_mode_12 = (0 + | ((esdmode6 & 0xFFFF) << 16) + | ((esdmode7 & 0xFFFF) << 0) + ); + break; + case 2: + ddr->ddr_sdram_mode_14 = (0 + | ((esdmode6 & 0xFFFF) << 16) + | ((esdmode7 & 0xFFFF) << 0) + ); + break; + case 3: + ddr->ddr_sdram_mode_16 = (0 + | ((esdmode6 & 0xFFFF) << 16) + | ((esdmode7 & 0xFFFF) << 0) + ); + break; + } + } + debug("FSLDDR: ddr_sdram_mode_12 = 0x%08x\n", + ddr->ddr_sdram_mode_12); + debug("FSLDDR: ddr_sdram_mode_14 = 0x%08x\n", + ddr->ddr_sdram_mode_14); + debug("FSLDDR: ddr_sdram_mode_16 = 0x%08x\n", + ddr->ddr_sdram_mode_16); + } }
+#endif + /* DDR SDRAM Interval Configuration (DDR_SDRAM_INTERVAL) */ static void set_ddr_sdram_interval(fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, @@ -867,7 +1156,7 @@ static void set_ddr_sdram_interval(fsl_ddr_cfg_regs_t *ddr, debug("FSLDDR: ddr_sdram_interval = 0x%08x\n", ddr->ddr_sdram_interval); }
-#if defined(CONFIG_SYS_FSL_DDR3) +#ifdef CONFIG_SYS_FSL_DDR4 /* DDR SDRAM Mode configuration set (DDR_SDRAM_MODE) */ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, @@ -876,6 +1165,177 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, unsigned int additive_latency, const unsigned int unq_mrs_en) { + int i; + unsigned short esdmode; /* Extended SDRAM mode */ + unsigned short sdmode; /* SDRAM mode */ + + /* Mode Register - MR1 */ + unsigned int qoff = 0; /* Output buffer enable 0=yes, 1=no */ + unsigned int tdqs_en = 0; /* TDQS Enable: 0=no, 1=yes */ + unsigned int rtt; + unsigned int wrlvl_en = 0; /* Write level enable: 0=no, 1=yes */ + unsigned int al = 0; /* Posted CAS# additive latency (AL) */ + unsigned int dic = 0; /* Output driver impedance, 40ohm */ + unsigned int dll_en = 1; /* DLL Enable 1=Enable (Normal), + 0=Disable (Test/Debug) */ + + /* Mode Register - MR0 */ + unsigned int wr = 0; /* Write Recovery */ + unsigned int dll_rst; /* DLL Reset */ + unsigned int mode; /* Normal=0 or Test=1 */ + unsigned int caslat = 4;/* CAS# latency, default set as 6 cycles */ + /* BT: Burst Type (0=Nibble Sequential, 1=Interleaved) */ + unsigned int bt; + unsigned int bl; /* BL: Burst Length */ + + unsigned int wr_mclk; + /* DDR4 support WR 10, 12, 14, 16, 18, 20, 24 */ + static const u8 wr_table[] = { + 0, 1, 1, 2, 2, 3, 3, 4, 4, 5, 5, 6, 6, 6, 6}; + /* DDR4 support CAS 9, 10, 11, 12, 13, 14, 15, 16, 18, 20, 22, 24 */ + static const u8 cas_latency_table[] = { + 0, 1, 2, 3, 4, 5, 6, 7, 8, 8, + 9, 9, 10, 10, 11, 11}; + + if (popts->rtt_override) + rtt = popts->rtt_override_value; + else + rtt = popts->cs_local_opts[0].odt_rtt_norm; + + if (additive_latency == (cas_latency - 1)) + al = 1; + if (additive_latency == (cas_latency - 2)) + al = 2; + + if (popts->quad_rank_present) + dic = 1; /* output driver impedance 240/7 ohm */ + + /* + * The esdmode value will also be used for writing + * MR1 during write leveling for DDR3, although the + * bits specifically related to the write leveling + * scheme will be handled automatically by the DDR + * controller. so we set the wrlvl_en = 0 here. + */ + esdmode = (0 + | ((qoff & 0x1) << 12) + | ((tdqs_en & 0x1) << 11) + | ((rtt & 0x7) << 8) + | ((wrlvl_en & 0x1) << 7) + | ((al & 0x3) << 3) + | ((dic & 0x3) << 1) /* DIC field is split */ + | ((dll_en & 0x1) << 0) + ); + + /* + * DLL control for precharge PD + * 0=slow exit DLL off (tXPDLL) + * 1=fast exit DLL on (tXP) + */ + + wr_mclk = picos_to_mclk(common_dimm->twr_ps); + if (wr_mclk <= 24) { + wr = wr_table[wr_mclk - 10]; + } else { + printf("Error: unsupported write recovery for mode register wr_mclk = %d\n", + wr_mclk); + } + + dll_rst = 0; /* dll no reset */ + mode = 0; /* normal mode */ + + /* look up table to get the cas latency bits */ + if (cas_latency >= 9 && cas_latency <= 24) + caslat = cas_latency_table[cas_latency - 9]; + else + printf("Error: unsupported cas latency for mode register\n"); + + bt = 0; /* Nibble sequential */ + + switch (popts->burst_length) { + case DDR_BL8: + bl = 0; + break; + case DDR_OTF: + bl = 1; + break; + case DDR_BC4: + bl = 2; + break; + default: + printf("Error: invalid burst length of %u specified. ", + popts->burst_length); + puts("Defaulting to on-the-fly BC4 or BL8 beats.\n"); + bl = 1; + break; + } + + sdmode = (0 + | ((wr & 0x7) << 9) + | ((dll_rst & 0x1) << 8) + | ((mode & 0x1) << 7) + | (((caslat >> 1) & 0x7) << 4) + | ((bt & 0x1) << 3) + | ((caslat & 1) << 2) + | ((bl & 0x3) << 0) + ); + + ddr->ddr_sdram_mode = (0 + | ((esdmode & 0xFFFF) << 16) + | ((sdmode & 0xFFFF) << 0) + ); + + debug("FSLDDR: ddr_sdram_mode = 0x%08x\n", ddr->ddr_sdram_mode); + + if (unq_mrs_en) { /* unique mode registers are supported */ + for (i = 1; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + if (popts->rtt_override) + rtt = popts->rtt_override_value; + else + rtt = popts->cs_local_opts[i].odt_rtt_norm; + + esdmode &= 0xF8FF; /* clear bit 10,9,8 for rtt */ + esdmode |= (rtt & 0x7) << 8; + switch (i) { + case 1: + ddr->ddr_sdram_mode_3 = (0 + | ((esdmode & 0xFFFF) << 16) + | ((sdmode & 0xFFFF) << 0) + ); + break; + case 2: + ddr->ddr_sdram_mode_5 = (0 + | ((esdmode & 0xFFFF) << 16) + | ((sdmode & 0xFFFF) << 0) + ); + break; + case 3: + ddr->ddr_sdram_mode_7 = (0 + | ((esdmode & 0xFFFF) << 16) + | ((sdmode & 0xFFFF) << 0) + ); + break; + } + } + debug("FSLDDR: ddr_sdram_mode_3 = 0x%08x\n", + ddr->ddr_sdram_mode_3); + debug("FSLDDR: ddr_sdram_mode_5 = 0x%08x\n", + ddr->ddr_sdram_mode_5); + debug("FSLDDR: ddr_sdram_mode_5 = 0x%08x\n", + ddr->ddr_sdram_mode_5); + } +} + +#elif defined(CONFIG_SYS_FSL_DDR3) +/* DDR SDRAM Mode configuration set (DDR_SDRAM_MODE) */ +static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + unsigned int cas_latency, + unsigned int additive_latency, + const unsigned int unq_mrs_en) +{ + int i; unsigned short esdmode; /* Extended SDRAM mode */ unsigned short sdmode; /* SDRAM mode */
@@ -907,9 +1367,6 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, */ static const u8 wr_table[] = {1, 2, 3, 4, 5, 5, 6, 6, 7, 7, 0, 0};
- const unsigned int mclk_ps = get_memory_clk_period_ps(); - int i; - if (popts->rtt_override) rtt = popts->rtt_override_value; else @@ -950,7 +1407,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, */ dll_on = 1;
- wr_mclk = (common_dimm->twr_ps + mclk_ps - 1) / mclk_ps; + wr_mclk = picos_to_mclk(common_dimm->twr_ps); if (wr_mclk <= 16) { wr = wr_table[wr_mclk - 5]; } else { @@ -1109,9 +1566,6 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, unsigned int bt; unsigned int bl; /* BL: Burst Length */
-#if defined(CONFIG_SYS_FSL_DDR2) - const unsigned int mclk_ps = get_memory_clk_period_ps(); -#endif dqs_en = !popts->dqs_config; rtt = fsl_ddr_get_rtt();
@@ -1141,7 +1595,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, #if defined(CONFIG_SYS_FSL_DDR1) wr = 0; /* Historical */ #elif defined(CONFIG_SYS_FSL_DDR2) - wr = (common_dimm->twr_ps + mclk_ps - 1) / mclk_ps - 1; + wr = picos_to_mclk(common_dimm->twr_ps); #endif dll_res = 0; mode = 0; @@ -1255,7 +1709,7 @@ static void set_timing_cfg_4(fsl_ddr_cfg_regs_t *ddr, unsigned int wwt = 0; /* Write-to-write turnaround for same CS */ unsigned int dll_lock = 0; /* DDR SDRAM DLL Lock Time */
-#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) if (popts->burst_length == DDR_BL8) { /* We set BL/2 for fixed BL8 */ rrt = 0; /* BL/2 clocks */ @@ -1265,6 +1719,11 @@ static void set_timing_cfg_4(fsl_ddr_cfg_regs_t *ddr, rrt = 2; /* BL/2 + 2 clocks */ wwt = 2; /* BL/2 + 2 clocks */ } +#endif + +#ifdef CONFIG_SYS_FSL_DDR4 + dll_lock = 2; /* tDLLK = 1024 clocks */ +#elif defined(CONFIG_SYS_FSL_DDR3) dll_lock = 1; /* tDLLK = 512 clocks from spec */ #endif ddr->timing_cfg_4 = (0 @@ -1285,9 +1744,12 @@ static void set_timing_cfg_5(fsl_ddr_cfg_regs_t *ddr, unsigned int cas_latency) unsigned int wodt_on = 0; /* Write to ODT on */ unsigned int wodt_off = 0; /* Write to ODT off */
-#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) + unsigned int wr_lat = ((ddr->timing_cfg_2 & 0x00780000) >> 19) + + ((ddr->timing_cfg_2 & 0x00040000) >> 14); /* rodt_on = timing_cfg_1[caslat] - timing_cfg_2[wrlat] + 1 */ - rodt_on = cas_latency - ((ddr->timing_cfg_2 & 0x00780000) >> 19) + 1; + if (cas_latency >= wr_lat) + rodt_on = cas_latency - wr_lat + 1; rodt_off = 4; /* 4 clocks */ wodt_on = 1; /* 1 clocks */ wodt_off = 4; /* 4 clocks */ @@ -1302,6 +1764,164 @@ static void set_timing_cfg_5(fsl_ddr_cfg_regs_t *ddr, unsigned int cas_latency) debug("FSLDDR: timing_cfg_5 = 0x%08x\n", ddr->timing_cfg_5); }
+#ifdef CONFIG_SYS_FSL_DDR4 +static void set_timing_cfg_6(fsl_ddr_cfg_regs_t *ddr) +{ + unsigned int hs_caslat = 0; + unsigned int hs_wrlat = 0; + unsigned int hs_wrrec = 0; + unsigned int hs_clkadj = 0; + unsigned int hs_wrlvl_start = 0; + + ddr->timing_cfg_6 = (0 + | ((hs_caslat & 0x1f) << 24) + | ((hs_wrlat & 0x1f) << 19) + | ((hs_wrrec & 0x1f) << 12) + | ((hs_clkadj & 0x1f) << 6) + | ((hs_wrlvl_start & 0x1f) << 0) + ); + debug("FSLDDR: timing_cfg_6 = 0x%08x\n", ddr->timing_cfg_6); +} + +static void set_timing_cfg_7(fsl_ddr_cfg_regs_t *ddr, + const common_timing_params_t *common_dimm) +{ + unsigned int txpr, tcksre, tcksrx; + unsigned int cke_rst, cksre, cksrx, par_lat, cs_to_cmd; + + txpr = max(5, picos_to_mclk(common_dimm->trfc1_ps + 10000)); + tcksre = max(5, picos_to_mclk(10000)); + tcksrx = max(5, picos_to_mclk(10000)); + par_lat = 0; + cs_to_cmd = 0; + + if (txpr <= 200) + cke_rst = 0; + else if (txpr <= 256) + cke_rst = 1; + else if (txpr <= 512) + cke_rst = 2; + else + cke_rst = 3; + + if (tcksre <= 19) + cksre = tcksre - 5; + else + cksre = 15; + + if (tcksrx <= 19) + cksrx = tcksrx - 5; + else + cksrx = 15; + + ddr->timing_cfg_7 = (0 + | ((cke_rst & 0x3) << 28) + | ((cksre & 0xf) << 24) + | ((cksrx & 0xf) << 20) + | ((par_lat & 0xf) << 16) + | ((cs_to_cmd & 0xf) << 4) + ); + debug("FSLDDR: timing_cfg_7 = 0x%08x\n", ddr->timing_cfg_7); +} + +static void set_timing_cfg_8(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + unsigned int cas_latency) +{ + unsigned int rwt_bg, wrt_bg, rrt_bg, wwt_bg; + unsigned int acttoact_bg, wrtord_bg, pre_all_rec; + unsigned int tccdl = picos_to_mclk(common_dimm->tccdl_ps); + unsigned int wr_lat = ((ddr->timing_cfg_2 & 0x00780000) >> 19) + + ((ddr->timing_cfg_2 & 0x00040000) >> 14); + + rwt_bg = cas_latency + 2 + 4 - wr_lat; + if (rwt_bg < tccdl) + rwt_bg = tccdl - rwt_bg; + else + rwt_bg = 0; + + wrt_bg = wr_lat + 4 + 1 - cas_latency; + if (wrt_bg < tccdl) + wrt_bg = tccdl - wrt_bg; + else + wrt_bg = 0; + + if (popts->burst_length == DDR_BL8) { + rrt_bg = tccdl - 4; + wwt_bg = tccdl - 4; + } else { + rrt_bg = tccdl - 2; + wwt_bg = tccdl - 4; + } + + acttoact_bg = picos_to_mclk(common_dimm->trrdl_ps); + wrtord_bg = max(4, picos_to_mclk(7500)); + pre_all_rec = 0; + + ddr->timing_cfg_8 = (0 + | ((rwt_bg & 0xf) << 28) + | ((wrt_bg & 0xf) << 24) + | ((rrt_bg & 0xf) << 20) + | ((wwt_bg & 0xf) << 16) + | ((acttoact_bg & 0xf) << 12) + | ((wrtord_bg & 0xf) << 8) + | ((pre_all_rec & 0x1f) << 0) + ); + + debug("FSLDDR: timing_cfg_8 = 0x%08x\n", ddr->timing_cfg_8); +} + +static void set_timing_cfg_9(fsl_ddr_cfg_regs_t *ddr) +{ + ddr->timing_cfg_9 = 0; + debug("FSLDDR: timing_cfg_9 = 0x%08x\n", ddr->timing_cfg_9); +} + +static void set_ddr_dq_mapping(fsl_ddr_cfg_regs_t *ddr, + const dimm_params_t *dimm_params) +{ + ddr->dq_map_0 = ((dimm_params->dq_mapping[0] & 0x3F) << 26) | + ((dimm_params->dq_mapping[1] & 0x3F) << 20) | + ((dimm_params->dq_mapping[2] & 0x3F) << 14) | + ((dimm_params->dq_mapping[3] & 0x3F) << 8) | + ((dimm_params->dq_mapping[4] & 0x3F) << 2); + + ddr->dq_map_1 = ((dimm_params->dq_mapping[5] & 0x3F) << 26) | + ((dimm_params->dq_mapping[6] & 0x3F) << 20) | + ((dimm_params->dq_mapping[7] & 0x3F) << 14) | + ((dimm_params->dq_mapping[10] & 0x3F) << 8) | + ((dimm_params->dq_mapping[11] & 0x3F) << 2); + + ddr->dq_map_2 = ((dimm_params->dq_mapping[12] & 0x3F) << 26) | + ((dimm_params->dq_mapping[13] & 0x3F) << 20) | + ((dimm_params->dq_mapping[14] & 0x3F) << 14) | + ((dimm_params->dq_mapping[15] & 0x3F) << 8) | + ((dimm_params->dq_mapping[16] & 0x3F) << 2); + + ddr->dq_map_3 = ((dimm_params->dq_mapping[17] & 0x3F) << 26) | + ((dimm_params->dq_mapping[8] & 0x3F) << 20) | + ((dimm_params->dq_mapping[9] & 0x3F) << 14) | + dimm_params->dq_mapping_ors; + + debug("FSLDDR: dq_map_0 = 0x%08x\n", ddr->dq_map_0); + debug("FSLDDR: dq_map_1 = 0x%08x\n", ddr->dq_map_1); + debug("FSLDDR: dq_map_2 = 0x%08x\n", ddr->dq_map_2); + debug("FSLDDR: dq_map_3 = 0x%08x\n", ddr->dq_map_3); +} +static void set_ddr_sdram_cfg_3(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts) +{ + int rd_pre; + + rd_pre = popts->quad_rank_present ? 1 : 0; + + ddr->ddr_sdram_cfg_3 = (rd_pre & 0x1) << 16; + + debug("FSLDDR: ddr_sdram_cfg_3 = 0x%08x\n", ddr->ddr_sdram_cfg_3); +} +#endif /* CONFIG_SYS_FSL_DDR4 */ + /* DDR ZQ Calibration Control (DDR_ZQ_CNTL) */ static void set_ddr_zq_cntl(fsl_ddr_cfg_regs_t *ddr, unsigned int zq_en) { @@ -1310,11 +1930,21 @@ static void set_ddr_zq_cntl(fsl_ddr_cfg_regs_t *ddr, unsigned int zq_en) unsigned int zqoper = 0; /* Normal Operation Short Calibration Time (tZQCS) */ unsigned int zqcs = 0; +#ifdef CONFIG_SYS_FSL_DDR4 + unsigned int zqcs_init; +#endif
if (zq_en) { +#ifdef CONFIG_SYS_FSL_DDR4 + zqinit = 10; /* 1024 clocks */ + zqoper = 9; /* 512 clocks */ + zqcs = 7; /* 128 clocks */ + zqcs_init = 5; /* 1024 refresh sequences */ +#else zqinit = 9; /* 512 clocks */ zqoper = 8; /* 256 clocks */ zqcs = 6; /* 64 clocks */ +#endif }
ddr->ddr_zq_cntl = (0 @@ -1322,6 +1952,9 @@ static void set_ddr_zq_cntl(fsl_ddr_cfg_regs_t *ddr, unsigned int zq_en) | ((zqinit & 0xF) << 24) | ((zqoper & 0xF) << 16) | ((zqcs & 0xF) << 8) +#ifdef CONFIG_SYS_FSL_DDR4 + | ((zqcs_init & 0xF) << 0) +#endif ); debug("FSLDDR: zq_cntl = 0x%08x\n", ddr->ddr_zq_cntl); } @@ -1478,7 +2111,7 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, */ cas_latency = (popts->cas_latency_override) ? popts->cas_latency_override_value - : common_dimm->lowest_common_SPD_caslat; + : common_dimm->lowest_common_spd_caslat;
additive_latency = (popts->additive_latency_override) ? popts->additive_latency_override_value @@ -1639,6 +2272,10 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, set_ddr_sdram_mode(ddr, popts, common_dimm, cas_latency, additive_latency, unq_mrs_en); set_ddr_sdram_mode_2(ddr, popts, common_dimm, unq_mrs_en); +#ifdef CONFIG_SYS_FSL_DDR4 + set_ddr_sdram_mode_9(ddr, popts, common_dimm, unq_mrs_en); + set_ddr_sdram_mode_10(ddr, popts, common_dimm, unq_mrs_en); +#endif set_ddr_sdram_interval(ddr, popts, common_dimm); set_ddr_data_init(ddr); set_ddr_sdram_clk_cntl(ddr, popts); @@ -1646,6 +2283,14 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, set_ddr_init_ext_addr(ddr); set_timing_cfg_4(ddr, popts); set_timing_cfg_5(ddr, cas_latency); +#ifdef CONFIG_SYS_FSL_DDR4 + set_ddr_sdram_cfg_3(ddr, popts); + set_timing_cfg_6(ddr); + set_timing_cfg_7(ddr, common_dimm); + set_timing_cfg_8(ddr, popts, common_dimm, cas_latency); + set_timing_cfg_9(ddr); + set_ddr_dq_mapping(ddr, dimm_params); +#endif
set_ddr_zq_cntl(ddr, zq_en); set_ddr_wrlvl_cntl(ddr, wrlvl_en, popts); diff --git a/drivers/ddr/fsl/ddr4_dimm_params.c b/drivers/ddr/fsl/ddr4_dimm_params.c new file mode 100644 index 0000000..4745b7f --- /dev/null +++ b/drivers/ddr/fsl/ddr4_dimm_params.c @@ -0,0 +1,300 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * calculate the organization and timing parameter + * from ddr3 spd, please refer to the spec + * JEDEC standard No.21-C 4_01_02_12R23A.pdf + * + * + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> + +#include <fsl_ddr.h> + +/* + * Calculate the Density of each Physical Rank. + * Returned size is in bytes. + * + * Total DIMM size = + * sdram capacity(bit) / 8 * primary bus width / sdram width + * * Logical Ranks per DIMM + * + * where: sdram capacity = spd byte4[3:0] + * primary bus width = spd byte13[2:0] + * sdram width = spd byte12[2:0] + * Logical Ranks per DIMM = spd byte12[5:3] for SDP, DDP, QDP + * spd byte12{5:3] * spd byte6[6:4] for 3DS + * + * To simplify each rank size = total DIMM size / Number of Package Ranks + * where Number of Package Ranks = spd byte12[5:3] + * + * SPD byte4 - sdram density and banks + * bit[3:0] size(bit) size(byte) + * 0000 256Mb 32MB + * 0001 512Mb 64MB + * 0010 1Gb 128MB + * 0011 2Gb 256MB + * 0100 4Gb 512MB + * 0101 8Gb 1GB + * 0110 16Gb 2GB + * 0111 32Gb 4GB + * + * SPD byte13 - module memory bus width + * bit[2:0] primary bus width + * 000 8bits + * 001 16bits + * 010 32bits + * 011 64bits + * + * SPD byte12 - module organization + * bit[2:0] sdram device width + * 000 4bits + * 001 8bits + * 010 16bits + * 011 32bits + * + * SPD byte12 - module organization + * bit[5:3] number of package ranks per DIMM + * 000 1 + * 001 2 + * 010 3 + * 011 4 + * + * SPD byte6 - SDRAM package type + * bit[6:4] Die count + * 000 1 + * 001 2 + * 010 3 + * 011 4 + * 100 5 + * 101 6 + * 110 7 + * 111 8 + * + * SPD byte6 - SRAM package type + * bit[1:0] Signal loading + * 00 Not specified + * 01 Multi load stack + * 10 Sigle load stack (3DS) + * 11 Reserved + */ +static unsigned long long +compute_ranksize(const struct ddr4_spd_eeprom_s *spd) +{ + unsigned long long bsize; + + int nbit_sdram_cap_bsize = 0; + int nbit_primary_bus_width = 0; + int nbit_sdram_width = 0; + int die_count = 0; + bool package_3ds; + + if ((spd->density_banks & 0xf) <= 7) + nbit_sdram_cap_bsize = (spd->density_banks & 0xf) + 28; + if ((spd->bus_width & 0x7) < 4) + nbit_primary_bus_width = (spd->bus_width & 0x7) + 3; + if ((spd->organization & 0x7) < 4) + nbit_sdram_width = (spd->organization & 0x7) + 2; + package_3ds = (spd->package_type & 0x3) == 0x2; + if (package_3ds) + die_count = (spd->package_type >> 4) & 0x7; + + bsize = 1ULL << (nbit_sdram_cap_bsize - 3 + + nbit_primary_bus_width - nbit_sdram_width + + die_count); + + debug("DDR: DDR III rank density = 0x%16llx\n", bsize); + + return bsize; +} + +#define spd_to_ps(mtb, ftb) \ + (mtb * pdimm->mtb_ps + (ftb * pdimm->ftb_10th_ps) / 10) +/* + * ddr_compute_dimm_parameters for DDR3 SPD + * + * Compute DIMM parameters based upon the SPD information in spd. + * Writes the results to the dimm_params_t structure pointed by pdimm. + * + */ +unsigned int +ddr_compute_dimm_parameters(const generic_spd_eeprom_t *spd, + dimm_params_t *pdimm, + unsigned int dimm_number) +{ + unsigned int retval; + int i; + + if (spd->mem_type) { + if (spd->mem_type != SPD_MEMTYPE_DDR4) { + printf("DIMM %u: is not a DDR4 SPD.\n", dimm_number); + return 1; + } + } else { + memset(pdimm, 0, sizeof(dimm_params_t)); + return 1; + } + + retval = ddr4_spd_check(spd); + if (retval) { + printf("DIMM %u: failed checksum\n", dimm_number); + return 2; + } + + /* + * The part name in ASCII in the SPD EEPROM is not null terminated. + * Guarantee null termination here by presetting all bytes to 0 + * and copying the part name in ASCII from the SPD onto it + */ + memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); + if ((spd->info_size_crc & 0xF) > 2) + memcpy(pdimm->mpart, spd->mpart, sizeof(pdimm->mpart) - 1); + + /* DIMM organization parameters */ + pdimm->n_ranks = ((spd->organization >> 3) & 0x7) + 1; + pdimm->rank_density = compute_ranksize(spd); + pdimm->capacity = pdimm->n_ranks * pdimm->rank_density; + pdimm->primary_sdram_width = 1 << (3 + (spd->bus_width & 0x7)); + if ((spd->bus_width >> 3) & 0x3) + pdimm->ec_sdram_width = 8; + else + pdimm->ec_sdram_width = 0; + pdimm->data_width = pdimm->primary_sdram_width + + pdimm->ec_sdram_width; + pdimm->device_width = 1 << ((spd->organization & 0x7) + 2); + + /* These are the types defined by the JEDEC DDR3 SPD spec */ + pdimm->mirrored_dimm = 0; + pdimm->registered_dimm = 0; + switch (spd->module_type & DDR3_SPD_MODULETYPE_MASK) { + case DDR3_SPD_MODULETYPE_RDIMM: + /* Registered/buffered DIMMs */ + pdimm->registered_dimm = 1; + break; + + case DDR3_SPD_MODULETYPE_UDIMM: + case DDR3_SPD_MODULETYPE_SO_DIMM: + /* Unbuffered DIMMs */ + if (spd->mod_section.unbuffered.addr_mapping & 0x1) + pdimm->mirrored_dimm = 1; + break; + + default: + printf("unknown module_type 0x%02X\n", spd->module_type); + return 1; + } + + /* SDRAM device parameters */ + pdimm->n_row_addr = ((spd->addressing >> 3) & 0x7) + 12; + pdimm->n_col_addr = (spd->addressing & 0x7) + 9; + pdimm->bank_addr_bits = (spd->density_banks >> 4) & 0x3; + pdimm->bank_group_bits = (spd->density_banks >> 6) & 0x3; + + /* + * The SPD spec has not the ECC bit, + * We consider the DIMM as ECC capability + * when the extension bus exist + */ + if (pdimm->ec_sdram_width) + pdimm->edc_config = 0x02; + else + pdimm->edc_config = 0x00; + + /* + * The SPD spec has not the burst length byte + * but DDR4 spec has nature BL8 and BC4, + * BL8 -bit3, BC4 -bit2 + */ + pdimm->burst_lengths_bitmask = 0x0c; + pdimm->row_density = __ilog2(pdimm->rank_density); + + /* MTB - medium timebase + * The MTB in the SPD spec is 125ps, + * + * FTB - fine timebase + * use 1/10th of ps as our unit to avoid floating point + * eg, 10 for 1ps, 25 for 2.5ps, 50 for 5ps + */ + if ((spd->timebases & 0xf) == 0x0) { + pdimm->mtb_ps = 125; + pdimm->ftb_10th_ps = 10; + + } else { + printf("Unknown Timebases\n"); + } + + /* sdram minimum cycle time */ + pdimm->tckmin_x_ps = spd_to_ps(spd->tck_min, spd->fine_tck_min); + + /* sdram max cycle time */ + pdimm->tckmax_ps = spd_to_ps(spd->tck_max, spd->fine_tck_max); + + /* + * CAS latency supported + * bit0 - CL7 + * bit4 - CL11 + * bit8 - CL15 + * bit12- CL19 + * bit16- CL23 + */ + pdimm->caslat_x = (spd->caslat_b1 << 7) | + (spd->caslat_b2 << 15) | + (spd->caslat_b3 << 23); + + BUG_ON(spd->caslat_b4 != 0); + + /* + * min CAS latency time + */ + pdimm->taa_ps = spd_to_ps(spd->taa_min, spd->fine_taa_min); + + /* + * min RAS to CAS delay time + */ + pdimm->trcd_ps = spd_to_ps(spd->trcd_min, spd->fine_trcd_min); + + /* + * Min Row Precharge Delay Time + */ + pdimm->trp_ps = spd_to_ps(spd->trp_min, spd->fine_trp_min); + + /* min active to precharge delay time */ + pdimm->tras_ps = (((spd->tras_trc_ext & 0xf) << 8) + + spd->tras_min_lsb) * pdimm->mtb_ps; + + /* min active to actice/refresh delay time */ + pdimm->trc_ps = spd_to_ps((((spd->tras_trc_ext & 0xf0) << 4) + + spd->trc_min_lsb), spd->fine_trc_min); + /* Min Refresh Recovery Delay Time */ + pdimm->trfc1_ps = ((spd->trfc1_min_msb << 8) | (spd->trfc1_min_lsb)) * + pdimm->mtb_ps; + pdimm->trfc2_ps = ((spd->trfc2_min_msb << 8) | (spd->trfc2_min_lsb)) * + pdimm->mtb_ps; + pdimm->trfc4_ps = ((spd->trfc4_min_msb << 8) | (spd->trfc4_min_lsb)) * + pdimm->mtb_ps; + /* min four active window delay time */ + pdimm->tfaw_ps = (((spd->tfaw_msb & 0xf) << 8) | spd->tfaw_min) * + pdimm->mtb_ps; + + /* min row active to row active delay time, different bank group */ + pdimm->trrds_ps = spd_to_ps(spd->trrds_min, spd->fine_trrds_min); + /* min row active to row active delay time, same bank group */ + pdimm->trrdl_ps = spd_to_ps(spd->trrdl_min, spd->fine_trrdl_min); + /* min CAS to CAS Delay Time (tCCD_Lmin), same bank group */ + pdimm->tccdl_ps = spd_to_ps(spd->tccdl_min, spd->fine_tccdl_min); + + /* + * Average periodic refresh interval + * tREFI = 7.8 us at normal temperature range + */ + pdimm->refresh_rate_ps = 7800000; + + for (i = 0; i < 18; i++) + pdimm->dq_mapping[i] = spd->mapping[i]; + + pdimm->dq_mapping_ors = ((spd->mapping[0] >> 6) & 0x3) == 0 ? 1 : 0; + + return 0; +} diff --git a/drivers/ddr/fsl/arm_ddr_gen3.c b/drivers/ddr/fsl/fsl_ddr_gen4.c similarity index 81% copy from drivers/ddr/fsl/arm_ddr_gen3.c copy to drivers/ddr/fsl/fsl_ddr_gen4.c index d4ed9ae..7cd878a 100644 --- a/drivers/ddr/fsl/arm_ddr_gen3.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -1,23 +1,19 @@ /* - * Copyright 2013 Freescale Semiconductor, Inc. + * Copyright 2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ - * - * Derived from mpc85xx_ddr_gen3.c, removed all workarounds */
#include <common.h> #include <asm/io.h> #include <fsl_ddr_sdram.h> #include <asm/processor.h> -#include <fsl_immap.h> #include <fsl_ddr.h>
#if (CONFIG_CHIP_SELECTS_PER_CTRL > 4) #error Invalid setting for CONFIG_CHIP_SELECTS_PER_CTRL #endif
- /* * regs has the to-be-set values for DDR controller registers * ctrl_num is the DDR controller number @@ -65,6 +61,9 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs,
if (regs->ddr_eor) ddr_out32(&ddr->eor, regs->ddr_eor); + + ddr_out32(&ddr->sdram_clk_cntl, regs->ddr_sdram_clk_cntl); + for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { if (i == 0) { ddr_out32(&ddr->cs0_bnds, regs->cs[i].bnds); @@ -92,7 +91,19 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->timing_cfg_0, regs->timing_cfg_0); ddr_out32(&ddr->timing_cfg_1, regs->timing_cfg_1); ddr_out32(&ddr->timing_cfg_2, regs->timing_cfg_2); + ddr_out32(&ddr->timing_cfg_4, regs->timing_cfg_4); + ddr_out32(&ddr->timing_cfg_5, regs->timing_cfg_5); + ddr_out32(&ddr->timing_cfg_6, regs->timing_cfg_6); + ddr_out32(&ddr->timing_cfg_7, regs->timing_cfg_7); + ddr_out32(&ddr->timing_cfg_8, regs->timing_cfg_8); + ddr_out32(&ddr->timing_cfg_9, regs->timing_cfg_9); + ddr_out32(&ddr->ddr_zq_cntl, regs->ddr_zq_cntl); + ddr_out32(&ddr->dq_map_0, regs->dq_map_0); + ddr_out32(&ddr->dq_map_1, regs->dq_map_1); + ddr_out32(&ddr->dq_map_2, regs->dq_map_2); + ddr_out32(&ddr->dq_map_3, regs->dq_map_3); ddr_out32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); + ddr_out32(&ddr->sdram_cfg_3, regs->ddr_sdram_cfg_3); ddr_out32(&ddr->sdram_mode, regs->ddr_sdram_mode); ddr_out32(&ddr->sdram_mode_2, regs->ddr_sdram_mode_2); ddr_out32(&ddr->sdram_mode_3, regs->ddr_sdram_mode_3); @@ -101,16 +112,19 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->sdram_mode_6, regs->ddr_sdram_mode_6); ddr_out32(&ddr->sdram_mode_7, regs->ddr_sdram_mode_7); ddr_out32(&ddr->sdram_mode_8, regs->ddr_sdram_mode_8); + ddr_out32(&ddr->sdram_mode_9, regs->ddr_sdram_mode_9); + ddr_out32(&ddr->sdram_mode_10, regs->ddr_sdram_mode_10); + ddr_out32(&ddr->sdram_mode_11, regs->ddr_sdram_mode_11); + ddr_out32(&ddr->sdram_mode_12, regs->ddr_sdram_mode_12); + ddr_out32(&ddr->sdram_mode_13, regs->ddr_sdram_mode_13); + ddr_out32(&ddr->sdram_mode_14, regs->ddr_sdram_mode_14); + ddr_out32(&ddr->sdram_mode_15, regs->ddr_sdram_mode_15); + ddr_out32(&ddr->sdram_mode_16, regs->ddr_sdram_mode_16); ddr_out32(&ddr->sdram_md_cntl, regs->ddr_sdram_md_cntl); ddr_out32(&ddr->sdram_interval, regs->ddr_sdram_interval); ddr_out32(&ddr->sdram_data_init, regs->ddr_data_init); - ddr_out32(&ddr->sdram_clk_cntl, regs->ddr_sdram_clk_cntl); ddr_out32(&ddr->init_addr, regs->ddr_init_addr); ddr_out32(&ddr->init_ext_addr, regs->ddr_init_ext_addr); - - ddr_out32(&ddr->timing_cfg_4, regs->timing_cfg_4); - ddr_out32(&ddr->timing_cfg_5, regs->timing_cfg_5); - ddr_out32(&ddr->ddr_zq_cntl, regs->ddr_zq_cntl); ddr_out32(&ddr->ddr_wrlvl_cntl, regs->ddr_wrlvl_cntl); #ifndef CONFIG_SYS_FSL_DDR_EMU /* @@ -127,14 +141,18 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, ddr_out32(&ddr->ddr_sr_cntr, regs->ddr_sr_cntr); ddr_out32(&ddr->ddr_sdram_rcw_1, regs->ddr_sdram_rcw_1); ddr_out32(&ddr->ddr_sdram_rcw_2, regs->ddr_sdram_rcw_2); + ddr_out32(&ddr->ddr_sdram_rcw_3, regs->ddr_sdram_rcw_3); + ddr_out32(&ddr->ddr_sdram_rcw_4, regs->ddr_sdram_rcw_4); + ddr_out32(&ddr->ddr_sdram_rcw_5, regs->ddr_sdram_rcw_5); + ddr_out32(&ddr->ddr_sdram_rcw_6, regs->ddr_sdram_rcw_6); ddr_out32(&ddr->ddr_cdr1, regs->ddr_cdr1); ddr_out32(&ddr->ddr_cdr2, regs->ddr_cdr2); ddr_out32(&ddr->err_disable, regs->err_disable); ddr_out32(&ddr->err_int_en, regs->err_int_en); for (i = 0; i < 32; i++) { if (regs->debug[i]) { - debug("Write to debug_%d as %08x\n", i + 1, - regs->debug[i]); + debug("Write to debug_%d as %08x\n", + i+1, regs->debug[i]); ddr_out32(&ddr->debug[i], regs->debug[i]); } } @@ -165,12 +183,12 @@ step2: * we choose the max, that is 500 us for all of case. */ udelay(500); - asm volatile("dsb sy;isb"); + asm volatile("sync;isync");
/* Let the controller go */ temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI; ddr_out32(&ddr->sdram_cfg, temp_sdram_cfg | SDRAM_CFG_MEM_EN); - asm volatile("dsb sy;isb"); + asm volatile("sync;isync");
total_gb_size_per_controller = 0; for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { @@ -179,14 +197,15 @@ step2: total_gb_size_per_controller += 1 << ( ((regs->cs[i].config >> 14) & 0x3) + 2 + ((regs->cs[i].config >> 8) & 0x7) + 12 + + ((regs->cs[i].config >> 4) & 0x3) + 0 + ((regs->cs[i].config >> 0) & 0x7) + 8 + 3 - ((regs->ddr_sdram_cfg >> 19) & 0x3) - 26); /* minus 26 (count of 64M) */ } - if (regs->cs[0].config & 0x20000000) { - /* 2-way interleaving */ + if (fsl_ddr_get_intl3r() & 0x80000000) /* 3-way interleaving */ + total_gb_size_per_controller *= 3; + else if (regs->cs[0].config & 0x20000000) /* 2-way interleaving */ total_gb_size_per_controller <<= 1; - } /* * total memory / bus width = transactions needed * transactions needed / data rate = seconds @@ -197,7 +216,7 @@ step2: bus_width = 3 - ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) >> SDRAM_CFG_DBW_SHIFT); timeout = ((total_gb_size_per_controller << (6 - bus_width)) * 100 / - (get_ddr_freq(0) >> 20)) << 1; + (get_ddr_freq(0) >> 20)) << 2; total_gb_size_per_controller >>= 4; /* shift down to gb size */ debug("total %d GB\n", total_gb_size_per_controller); debug("Need to wait up to %d * 10ms\n", timeout); @@ -211,4 +230,5 @@ step2:
if (timeout <= 0) printf("Waiting for D_INIT timeout. Memory may not work.\n"); + } diff --git a/drivers/ddr/fsl/interactive.c b/drivers/ddr/fsl/interactive.c index ebf3ed6..cfe1e1f 100644 --- a/drivers/ddr/fsl/interactive.c +++ b/drivers/ddr/fsl/interactive.c @@ -1,5 +1,5 @@ /* - * Copyright 2010-2012 Freescale Semiconductor, Inc. + * Copyright 2010-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -153,25 +153,38 @@ static void lowest_common_dimm_parameters_edit(fsl_ddr_info_t *pinfo, static const struct options_string options[] = { COMMON_TIMING(tckmin_x_ps), COMMON_TIMING(tckmax_ps), - COMMON_TIMING(tckmax_max_ps), + COMMON_TIMING(taamin_ps), COMMON_TIMING(trcd_ps), COMMON_TIMING(trp_ps), COMMON_TIMING(tras_ps), - COMMON_TIMING(twr_ps), + +#ifdef CONFIG_SYS_FSL_DDR4 + COMMON_TIMING(trfc1_ps), + COMMON_TIMING(trfc2_ps), + COMMON_TIMING(trfc4_ps), + COMMON_TIMING(trrds_ps), + COMMON_TIMING(trrdl_ps), + COMMON_TIMING(tccdl_ps), +#else COMMON_TIMING(twtr_ps), COMMON_TIMING(trfc_ps), COMMON_TIMING(trrd_ps), + COMMON_TIMING(trtp_ps), +#endif + COMMON_TIMING(twr_ps), COMMON_TIMING(trc_ps), COMMON_TIMING(refresh_rate_ps), + COMMON_TIMING(extended_op_srt), +#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) COMMON_TIMING(tis_ps), COMMON_TIMING(tih_ps), COMMON_TIMING(tds_ps), COMMON_TIMING(tdh_ps), - COMMON_TIMING(trtp_ps), COMMON_TIMING(tdqsq_max_ps), COMMON_TIMING(tqhs_ps), +#endif COMMON_TIMING(ndimms_present), - COMMON_TIMING(lowest_common_SPD_caslat), + COMMON_TIMING(lowest_common_spd_caslat), COMMON_TIMING(highest_common_derated_caslat), COMMON_TIMING(additive_latency), COMMON_TIMING(all_dimms_burst_lengths_bitmask), @@ -211,7 +224,12 @@ static void fsl_ddr_dimm_parameters_edit(fsl_ddr_info_t *pinfo, DIMM_PARM(n_row_addr), DIMM_PARM(n_col_addr), DIMM_PARM(edc_config), +#ifdef CONFIG_SYS_FSL_DDR4 + DIMM_PARM(bank_addr_bits), + DIMM_PARM(bank_group_bits), +#else DIMM_PARM(n_banks_per_sdram_device), +#endif DIMM_PARM(burst_lengths_bitmask), DIMM_PARM(row_density),
@@ -229,20 +247,32 @@ static void fsl_ddr_dimm_parameters_edit(fsl_ddr_info_t *pinfo, DIMM_PARM(trcd_ps), DIMM_PARM(trp_ps), DIMM_PARM(tras_ps), +#ifdef CONFIG_SYS_FSL_DDR4 + DIMM_PARM(trfc1_ps), + DIMM_PARM(trfc2_ps), + DIMM_PARM(trfc4_ps), + DIMM_PARM(trrds_ps), + DIMM_PARM(trrdl_ps), + DIMM_PARM(tccdl_ps), +#else DIMM_PARM(twr_ps), DIMM_PARM(twtr_ps), DIMM_PARM(trfc_ps), DIMM_PARM(trrd_ps), + DIMM_PARM(trtp_ps), +#endif DIMM_PARM(trc_ps), DIMM_PARM(refresh_rate_ps), + DIMM_PARM(extended_op_srt),
+#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) DIMM_PARM(tis_ps), DIMM_PARM(tih_ps), DIMM_PARM(tds_ps), DIMM_PARM(tdh_ps), - DIMM_PARM(trtp_ps), DIMM_PARM(tdqsq_max_ps), DIMM_PARM(tqhs_ps), +#endif
DIMM_PARM(rank_density), DIMM_PARM(capacity), @@ -270,7 +300,12 @@ static void print_dimm_parameters(const dimm_params_t *pdimm) DIMM_PARM(n_row_addr), DIMM_PARM(n_col_addr), DIMM_PARM(edc_config), +#ifdef CONFIG_SYS_FSL_DDR4 + DIMM_PARM(bank_addr_bits), + DIMM_PARM(bank_group_bits), +#else DIMM_PARM(n_banks_per_sdram_device), +#endif
DIMM_PARM(tckmin_x_ps), DIMM_PARM(tckmin_x_minus_1_ps), @@ -286,20 +321,31 @@ static void print_dimm_parameters(const dimm_params_t *pdimm) DIMM_PARM(trcd_ps), DIMM_PARM(trp_ps), DIMM_PARM(tras_ps), +#ifdef CONFIG_SYS_FSL_DDR4 + DIMM_PARM(trfc1_ps), + DIMM_PARM(trfc2_ps), + DIMM_PARM(trfc4_ps), + DIMM_PARM(trrds_ps), + DIMM_PARM(trrdl_ps), + DIMM_PARM(tccdl_ps), +#else DIMM_PARM(twr_ps), DIMM_PARM(twtr_ps), DIMM_PARM(trfc_ps), DIMM_PARM(trrd_ps), + DIMM_PARM(trtp_ps), +#endif DIMM_PARM(trc_ps), DIMM_PARM(refresh_rate_ps),
+#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) DIMM_PARM(tis_ps), DIMM_PARM(tih_ps), DIMM_PARM(tds_ps), DIMM_PARM(tdh_ps), - DIMM_PARM(trtp_ps), DIMM_PARM(tdqsq_max_ps), DIMM_PARM(tqhs_ps), +#endif }; static const unsigned int n_opts = ARRAY_SIZE(options);
@@ -326,23 +372,36 @@ static void print_lowest_common_dimm_parameters( const common_timing_params_t *plcd_dimm_params) { static const struct options_string options[] = { - COMMON_TIMING(tckmax_max_ps), + COMMON_TIMING(taamin_ps), COMMON_TIMING(trcd_ps), COMMON_TIMING(trp_ps), COMMON_TIMING(tras_ps), - COMMON_TIMING(twr_ps), +#ifdef CONFIG_SYS_FSL_DDR4 + COMMON_TIMING(trfc1_ps), + COMMON_TIMING(trfc2_ps), + COMMON_TIMING(trfc4_ps), + COMMON_TIMING(trrds_ps), + COMMON_TIMING(trrdl_ps), + COMMON_TIMING(tccdl_ps), +#else COMMON_TIMING(twtr_ps), COMMON_TIMING(trfc_ps), COMMON_TIMING(trrd_ps), + COMMON_TIMING(trtp_ps), +#endif + COMMON_TIMING(twr_ps), COMMON_TIMING(trc_ps), COMMON_TIMING(refresh_rate_ps), + COMMON_TIMING(extended_op_srt), +#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) COMMON_TIMING(tis_ps), + COMMON_TIMING(tih_ps), COMMON_TIMING(tds_ps), COMMON_TIMING(tdh_ps), - COMMON_TIMING(trtp_ps), COMMON_TIMING(tdqsq_max_ps), COMMON_TIMING(tqhs_ps), - COMMON_TIMING(lowest_common_SPD_caslat), +#endif + COMMON_TIMING(lowest_common_spd_caslat), COMMON_TIMING(highest_common_derated_caslat), COMMON_TIMING(additive_latency), COMMON_TIMING(ndimms_present), @@ -460,6 +519,9 @@ static void fsl_ddr_options_edit(fsl_ddr_info_t *pinfo, CTRL_OPTIONS(tfaw_window_four_activates_ps), CTRL_OPTIONS(trwt_override), CTRL_OPTIONS(trwt), + CTRL_OPTIONS(rtt_override), + CTRL_OPTIONS(rtt_override_value), + CTRL_OPTIONS(rtt_wr_override_value), };
static const unsigned int n_opts = ARRAY_SIZE(options); @@ -505,6 +567,7 @@ static void print_fsl_memctl_config_regs(const fsl_ddr_cfg_regs_t *ddr) CFG_REGS(timing_cfg_2), CFG_REGS(ddr_sdram_cfg), CFG_REGS(ddr_sdram_cfg_2), + CFG_REGS(ddr_sdram_cfg_3), CFG_REGS(ddr_sdram_mode), CFG_REGS(ddr_sdram_mode_2), CFG_REGS(ddr_sdram_mode_3), @@ -513,6 +576,16 @@ static void print_fsl_memctl_config_regs(const fsl_ddr_cfg_regs_t *ddr) CFG_REGS(ddr_sdram_mode_6), CFG_REGS(ddr_sdram_mode_7), CFG_REGS(ddr_sdram_mode_8), +#ifdef CONFIG_SYS_FSL_DDR4 + CFG_REGS(ddr_sdram_mode_9), + CFG_REGS(ddr_sdram_mode_10), + CFG_REGS(ddr_sdram_mode_11), + CFG_REGS(ddr_sdram_mode_12), + CFG_REGS(ddr_sdram_mode_13), + CFG_REGS(ddr_sdram_mode_14), + CFG_REGS(ddr_sdram_mode_15), + CFG_REGS(ddr_sdram_mode_16), +#endif CFG_REGS(ddr_sdram_interval), CFG_REGS(ddr_data_init), CFG_REGS(ddr_sdram_clk_cntl), @@ -520,6 +593,12 @@ static void print_fsl_memctl_config_regs(const fsl_ddr_cfg_regs_t *ddr) CFG_REGS(ddr_init_ext_addr), CFG_REGS(timing_cfg_4), CFG_REGS(timing_cfg_5), +#ifdef CONFIG_SYS_FSL_DDR4 + CFG_REGS(timing_cfg_6), + CFG_REGS(timing_cfg_7), + CFG_REGS(timing_cfg_8), + CFG_REGS(timing_cfg_9), +#endif CFG_REGS(ddr_zq_cntl), CFG_REGS(ddr_wrlvl_cntl), CFG_REGS(ddr_wrlvl_cntl_2), @@ -529,6 +608,10 @@ static void print_fsl_memctl_config_regs(const fsl_ddr_cfg_regs_t *ddr) CFG_REGS(ddr_sdram_rcw_2), CFG_REGS(ddr_cdr1), CFG_REGS(ddr_cdr2), + CFG_REGS(dq_map_0), + CFG_REGS(dq_map_1), + CFG_REGS(dq_map_2), + CFG_REGS(dq_map_3), CFG_REGS(err_disable), CFG_REGS(err_int_en), CFG_REGS(ddr_eor), @@ -574,6 +657,7 @@ static void fsl_ddr_regs_edit(fsl_ddr_info_t *pinfo, CFG_REGS(timing_cfg_2), CFG_REGS(ddr_sdram_cfg), CFG_REGS(ddr_sdram_cfg_2), + CFG_REGS(ddr_sdram_cfg_3), CFG_REGS(ddr_sdram_mode), CFG_REGS(ddr_sdram_mode_2), CFG_REGS(ddr_sdram_mode_3), @@ -582,6 +666,16 @@ static void fsl_ddr_regs_edit(fsl_ddr_info_t *pinfo, CFG_REGS(ddr_sdram_mode_6), CFG_REGS(ddr_sdram_mode_7), CFG_REGS(ddr_sdram_mode_8), +#ifdef CONFIG_SYS_FSL_DDR4 + CFG_REGS(ddr_sdram_mode_9), + CFG_REGS(ddr_sdram_mode_10), + CFG_REGS(ddr_sdram_mode_11), + CFG_REGS(ddr_sdram_mode_12), + CFG_REGS(ddr_sdram_mode_13), + CFG_REGS(ddr_sdram_mode_14), + CFG_REGS(ddr_sdram_mode_15), + CFG_REGS(ddr_sdram_mode_16), +#endif CFG_REGS(ddr_sdram_interval), CFG_REGS(ddr_data_init), CFG_REGS(ddr_sdram_clk_cntl), @@ -589,6 +683,12 @@ static void fsl_ddr_regs_edit(fsl_ddr_info_t *pinfo, CFG_REGS(ddr_init_ext_addr), CFG_REGS(timing_cfg_4), CFG_REGS(timing_cfg_5), +#ifdef CONFIG_SYS_FSL_DDR4 + CFG_REGS(timing_cfg_6), + CFG_REGS(timing_cfg_7), + CFG_REGS(timing_cfg_8), + CFG_REGS(timing_cfg_9), +#endif CFG_REGS(ddr_zq_cntl), CFG_REGS(ddr_wrlvl_cntl), CFG_REGS(ddr_wrlvl_cntl_2), @@ -598,6 +698,10 @@ static void fsl_ddr_regs_edit(fsl_ddr_info_t *pinfo, CFG_REGS(ddr_sdram_rcw_2), CFG_REGS(ddr_cdr1), CFG_REGS(ddr_cdr2), + CFG_REGS(dq_map_0), + CFG_REGS(dq_map_1), + CFG_REGS(dq_map_2), + CFG_REGS(dq_map_3), CFG_REGS(err_disable), CFG_REGS(err_int_en), CFG_REGS(ddr_sdram_rcw_2), @@ -705,6 +809,9 @@ static void print_memctl_options(const memctl_options_t *popts) CTRL_OPTIONS(tfaw_window_four_activates_ps), CTRL_OPTIONS(trwt_override), CTRL_OPTIONS(trwt), + CTRL_OPTIONS(rtt_override), + CTRL_OPTIONS(rtt_override_value), + CTRL_OPTIONS(rtt_wr_override_value), }; static const unsigned int n_opts = ARRAY_SIZE(options);
@@ -1245,6 +1352,266 @@ void ddr3_spd_dump(const ddr3_spd_eeprom_t *spd) } #endif
+#ifdef CONFIG_SYS_FSL_DDR4 +void ddr4_spd_dump(const struct ddr4_spd_eeprom_s *spd) +{ + unsigned int i; + + /* General Section: Bytes 0-127 */ + +#define PRINT_NXS(x, y, z...) printf("%-3d : %02x " z "\n", x, (u8)y); +#define PRINT_NNXXS(n0, n1, x0, x1, s) \ + printf("%-3d-%3d: %02x %02x " s "\n", n0, n1, x0, x1); + + PRINT_NXS(0, spd->info_size_crc, + "info_size_crc bytes written into serial memory, CRC coverage"); + PRINT_NXS(1, spd->spd_rev, + "spd_rev SPD Revision"); + PRINT_NXS(2, spd->mem_type, + "mem_type Key Byte / DRAM Device Type"); + PRINT_NXS(3, spd->module_type, + "module_type Key Byte / Module Type"); + PRINT_NXS(4, spd->density_banks, + "density_banks SDRAM Density and Banks"); + PRINT_NXS(5, spd->addressing, + "addressing SDRAM Addressing"); + PRINT_NXS(6, spd->package_type, + "package_type Package type"); + PRINT_NXS(7, spd->opt_feature, + "opt_feature Optional features"); + PRINT_NXS(8, spd->thermal_ref, + "thermal_ref Thermal and Refresh options"); + PRINT_NXS(9, spd->oth_opt_features, + "oth_opt_features Other SDRAM optional features"); + PRINT_NXS(10, spd->res_10, + "res_10 Reserved"); + PRINT_NXS(11, spd->module_vdd, + "module_vdd Module Nominal Voltage, VDD"); + PRINT_NXS(12, spd->organization, + "organization Module Organization"); + PRINT_NXS(13, spd->bus_width, + "bus_width Module Memory Bus Width"); + PRINT_NXS(14, spd->therm_sensor, + "therm_sensor Module Thermal Sensor"); + PRINT_NXS(15, spd->ext_type, + "ext_type Extended module type"); + PRINT_NXS(16, spd->res_16, + "res_16 Reserved"); + PRINT_NXS(17, spd->timebases, + "timebases MTb and FTB"); + PRINT_NXS(18, spd->tck_min, + "tck_min tCKAVGmin"); + PRINT_NXS(19, spd->tck_max, + "tck_max TCKAVGmax"); + PRINT_NXS(20, spd->caslat_b1, + "caslat_b1 CAS latencies, 1st byte"); + PRINT_NXS(21, spd->caslat_b2, + "caslat_b2 CAS latencies, 2nd byte"); + PRINT_NXS(22, spd->caslat_b3, + "caslat_b3 CAS latencies, 3rd byte "); + PRINT_NXS(23, spd->caslat_b4, + "caslat_b4 CAS latencies, 4th byte"); + PRINT_NXS(24, spd->taa_min, + "taa_min Min CAS Latency Time"); + PRINT_NXS(25, spd->trcd_min, + "trcd_min Min RAS# to CAS# Delay Time"); + PRINT_NXS(26, spd->trp_min, + "trp_min Min Row Precharge Delay Time"); + PRINT_NXS(27, spd->tras_trc_ext, + "tras_trc_ext Upper Nibbles for tRAS and tRC"); + PRINT_NXS(28, spd->tras_min_lsb, + "tras_min_lsb tRASmin, lsb"); + PRINT_NXS(29, spd->trc_min_lsb, + "trc_min_lsb tRCmin, lsb"); + PRINT_NXS(30, spd->trfc1_min_lsb, + "trfc1_min_lsb Min Refresh Recovery Delay Time, LSB"); + PRINT_NXS(31, spd->trfc1_min_msb, + "trfc1_min_msb Min Refresh Recovery Delay Time, MSB "); + PRINT_NXS(32, spd->trfc2_min_lsb, + "trfc2_min_lsb Min Refresh Recovery Delay Time, LSB"); + PRINT_NXS(33, spd->trfc2_min_msb, + "trfc2_min_msb Min Refresh Recovery Delay Time, MSB"); + PRINT_NXS(34, spd->trfc4_min_lsb, + "trfc4_min_lsb Min Refresh Recovery Delay Time, LSB"); + PRINT_NXS(35, spd->trfc4_min_msb, + "trfc4_min_msb Min Refresh Recovery Delay Time, MSB"); + PRINT_NXS(36, spd->tfaw_msb, + "tfaw_msb Upper Nibble for tFAW"); + PRINT_NXS(37, spd->tfaw_min, + "tfaw_min tFAW, lsb"); + PRINT_NXS(38, spd->trrds_min, + "trrds_min tRRD_Smin, MTB"); + PRINT_NXS(39, spd->trrdl_min, + "trrdl_min tRRD_Lmin, MTB"); + PRINT_NXS(40, spd->tccdl_min, + "tccdl_min tCCS_Lmin, MTB"); + + printf("%-3d-%3d: ", 41, 59); /* Reserved, General Section */ + for (i = 41; i <= 59; i++) + printf("%02x ", spd->res_41[i - 41]); + + puts("\n"); + printf("%-3d-%3d: ", 60, 77); + for (i = 60; i <= 77; i++) + printf("%02x ", spd->mapping[i - 60]); + puts(" mapping[] Connector to SDRAM bit map\n"); + + PRINT_NXS(117, spd->fine_tccdl_min, + "fine_tccdl_min Fine offset for tCCD_Lmin"); + PRINT_NXS(118, spd->fine_trrdl_min, + "fine_trrdl_min Fine offset for tRRD_Lmin"); + PRINT_NXS(119, spd->fine_trrds_min, + "fine_trrds_min Fine offset for tRRD_Smin"); + PRINT_NXS(120, spd->fine_trc_min, + "fine_trc_min Fine offset for tRCmin"); + PRINT_NXS(121, spd->fine_trp_min, + "fine_trp_min Fine offset for tRPmin"); + PRINT_NXS(122, spd->fine_trcd_min, + "fine_trcd_min Fine offset for tRCDmin"); + PRINT_NXS(123, spd->fine_taa_min, + "fine_taa_min Fine offset for tAAmin"); + PRINT_NXS(124, spd->fine_tck_max, + "fine_tck_max Fine offset for tCKAVGmax"); + PRINT_NXS(125, spd->fine_tck_min, + "fine_tck_min Fine offset for tCKAVGmin"); + + /* CRC: Bytes 126-127 */ + PRINT_NNXXS(126, 127, spd->crc[0], spd->crc[1], " SPD CRC"); + + switch (spd->module_type) { + case 0x02: /* UDIMM */ + case 0x03: /* SO-DIMM */ + PRINT_NXS(128, spd->mod_section.unbuffered.mod_height, + "mod_height (Unbuffered) Module Nominal Height"); + PRINT_NXS(129, spd->mod_section.unbuffered.mod_thickness, + "mod_thickness (Unbuffered) Module Maximum Thickness"); + PRINT_NXS(130, spd->mod_section.unbuffered.ref_raw_card, + "ref_raw_card (Unbuffered) Reference Raw Card Used"); + PRINT_NXS(131, spd->mod_section.unbuffered.addr_mapping, + "addr_mapping (Unbuffered) Address mapping from Edge Connector to DRAM"); + PRINT_NNXXS(254, 255, spd->mod_section.unbuffered.crc[0], + spd->mod_section.unbuffered.crc[1], " Module CRC"); + break; + case 0x01: /* RDIMM */ + PRINT_NXS(128, spd->mod_section.registered.mod_height, + "mod_height (Registered) Module Nominal Height"); + PRINT_NXS(129, spd->mod_section.registered.mod_thickness, + "mod_thickness (Registered) Module Maximum Thickness"); + PRINT_NXS(130, spd->mod_section.registered.ref_raw_card, + "ref_raw_card (Registered) Reference Raw Card Used"); + PRINT_NXS(131, spd->mod_section.registered.modu_attr, + "modu_attr (Registered) DIMM Module Attributes"); + PRINT_NXS(132, spd->mod_section.registered.thermal, + "thermal (Registered) Thermal Heat Spreader Solution"); + PRINT_NXS(133, spd->mod_section.registered.reg_id_lo, + "reg_id_lo (Registered) Register Manufacturer ID Code, LSB"); + PRINT_NXS(134, spd->mod_section.registered.reg_id_hi, + "reg_id_hi (Registered) Register Manufacturer ID Code, MSB"); + PRINT_NXS(135, spd->mod_section.registered.reg_rev, + "reg_rev (Registered) Register Revision Number"); + PRINT_NXS(136, spd->mod_section.registered.reg_map, + "reg_map (Registered) Address mapping"); + PRINT_NNXXS(254, 255, spd->mod_section.registered.crc[0], + spd->mod_section.registered.crc[1], " Module CRC"); + break; + case 0x04: /* LRDIMM */ + PRINT_NXS(128, spd->mod_section.loadreduced.mod_height, + "mod_height (Loadreduced) Module Nominal Height"); + PRINT_NXS(129, spd->mod_section.loadreduced.mod_thickness, + "mod_thickness (Loadreduced) Module Maximum Thickness"); + PRINT_NXS(130, spd->mod_section.loadreduced.ref_raw_card, + "ref_raw_card (Loadreduced) Reference Raw Card Used"); + PRINT_NXS(131, spd->mod_section.loadreduced.modu_attr, + "modu_attr (Loadreduced) DIMM Module Attributes"); + PRINT_NXS(132, spd->mod_section.loadreduced.thermal, + "thermal (Loadreduced) Thermal Heat Spreader Solution"); + PRINT_NXS(133, spd->mod_section.loadreduced.reg_id_lo, + "reg_id_lo (Loadreduced) Register Manufacturer ID Code, LSB"); + PRINT_NXS(134, spd->mod_section.loadreduced.reg_id_hi, + "reg_id_hi (Loadreduced) Register Manufacturer ID Code, MSB"); + PRINT_NXS(135, spd->mod_section.loadreduced.reg_rev, + "reg_rev (Loadreduced) Register Revision Number"); + PRINT_NXS(136, spd->mod_section.loadreduced.reg_map, + "reg_map (Loadreduced) Address mapping"); + PRINT_NXS(137, spd->mod_section.loadreduced.reg_drv, + "reg_drv (Loadreduced) Reg output drive strength"); + PRINT_NXS(138, spd->mod_section.loadreduced.reg_drv_ck, + "reg_drv_ck (Loadreduced) Reg output drive strength for CK"); + PRINT_NXS(139, spd->mod_section.loadreduced.data_buf_rev, + "data_buf_rev (Loadreduced) Data Buffer Revision Numbe"); + PRINT_NXS(140, spd->mod_section.loadreduced.vrefqe_r0, + "vrefqe_r0 (Loadreduced) DRAM VrefDQ for Package Rank 0"); + PRINT_NXS(141, spd->mod_section.loadreduced.vrefqe_r1, + "vrefqe_r1 (Loadreduced) DRAM VrefDQ for Package Rank 1"); + PRINT_NXS(142, spd->mod_section.loadreduced.vrefqe_r2, + "vrefqe_r2 (Loadreduced) DRAM VrefDQ for Package Rank 2"); + PRINT_NXS(143, spd->mod_section.loadreduced.vrefqe_r3, + "vrefqe_r3 (Loadreduced) DRAM VrefDQ for Package Rank 3"); + PRINT_NXS(144, spd->mod_section.loadreduced.data_intf, + "data_intf (Loadreduced) Data Buffer VrefDQ for DRAM Interface"); + PRINT_NXS(145, spd->mod_section.loadreduced.data_drv_1866, + "data_drv_1866 (Loadreduced) Data Buffer MDQ Drive Strength and RTT"); + PRINT_NXS(146, spd->mod_section.loadreduced.data_drv_2400, + "data_drv_2400 (Loadreduced) Data Buffer MDQ Drive Strength and RTT"); + PRINT_NXS(147, spd->mod_section.loadreduced.data_drv_3200, + "data_drv_3200 (Loadreduced) Data Buffer MDQ Drive Strength and RTT"); + PRINT_NXS(148, spd->mod_section.loadreduced.dram_drv, + "dram_drv (Loadreduced) DRAM Drive Strength"); + PRINT_NXS(149, spd->mod_section.loadreduced.dram_odt_1866, + "dram_odt_1866 (Loadreduced) DRAM ODT (RTT_WR, RTT_NOM)"); + PRINT_NXS(150, spd->mod_section.loadreduced.dram_odt_2400, + "dram_odt_2400 (Loadreduced) DRAM ODT (RTT_WR, RTT_NOM)"); + PRINT_NXS(151, spd->mod_section.loadreduced.dram_odt_3200, + "dram_odt_3200 (Loadreduced) DRAM ODT (RTT_WR, RTT_NOM)"); + PRINT_NXS(152, spd->mod_section.loadreduced.dram_odt_park_1866, + "dram_odt_park_1866 (Loadreduced) DRAM ODT (RTT_PARK)"); + PRINT_NXS(153, spd->mod_section.loadreduced.dram_odt_park_2400, + "dram_odt_park_2400 (Loadreduced) DRAM ODT (RTT_PARK)"); + PRINT_NXS(154, spd->mod_section.loadreduced.dram_odt_park_3200, + "dram_odt_park_3200 (Loadreduced) DRAM ODT (RTT_PARK)"); + PRINT_NNXXS(254, 255, spd->mod_section.loadreduced.crc[0], + spd->mod_section.loadreduced.crc[1], + " Module CRC"); + break; + default: + /* Module-specific Section, Unsupported Module Type */ + printf("%-3d-%3d: ", 128, 255); + + for (i = 128; i <= 255; i++) + printf("%02x", spd->mod_section.uc[i - 60]); + + break; + } + + /* Unique Module ID: Bytes 320-383 */ + PRINT_NXS(320, spd->mmid_lsb, "Module MfgID Code LSB - JEP-106"); + PRINT_NXS(321, spd->mmid_msb, "Module MfgID Code MSB - JEP-106"); + PRINT_NXS(322, spd->mloc, "Mfg Location"); + PRINT_NNXXS(323, 324, spd->mdate[0], spd->mdate[1], "Mfg Date"); + + printf("%-3d-%3d: ", 325, 328); + + for (i = 325; i <= 328; i++) + printf("%02x ", spd->sernum[i - 325]); + printf(" Module Serial Number\n"); + + printf("%-3d-%3d: ", 329, 348); + for (i = 329; i <= 348; i++) + printf("%02x ", spd->mpart[i - 329]); + printf(" Mfg's Module Part Number\n"); + + PRINT_NXS(349, spd->mrev, "Module Revision code"); + PRINT_NXS(350, spd->dmid_lsb, "DRAM MfgID Code LSB - JEP-106"); + PRINT_NXS(351, spd->dmid_msb, "DRAM MfgID Code MSB - JEP-106"); + PRINT_NXS(352, spd->stepping, "DRAM stepping"); + + printf("%-3d-%3d: ", 353, 381); + for (i = 353; i <= 381; i++) + printf("%02x ", spd->msd[i - 353]); + printf(" Mfg's Specific Data\n"); +} +#endif + static inline void generic_spd_dump(const generic_spd_eeprom_t *spd) { #if defined(CONFIG_SYS_FSL_DDR1) @@ -1253,6 +1620,8 @@ static inline void generic_spd_dump(const generic_spd_eeprom_t *spd) ddr2_spd_dump(spd); #elif defined(CONFIG_SYS_FSL_DDR3) ddr3_spd_dump(spd); +#elif defined(CONFIG_SYS_FSL_DDR4) + ddr4_spd_dump(spd); #endif }
diff --git a/drivers/ddr/fsl/lc_common_dimm_params.c b/drivers/ddr/fsl/lc_common_dimm_params.c index 610318a..05a24dd 100644 --- a/drivers/ddr/fsl/lc_common_dimm_params.c +++ b/drivers/ddr/fsl/lc_common_dimm_params.c @@ -1,5 +1,5 @@ /* - * Copyright 2008-2012 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -11,20 +11,23 @@
-#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) static unsigned int -compute_cas_latency_ddr3(const dimm_params_t *dimm_params, - common_timing_params_t *outpdimm, - unsigned int number_of_dimms) +compute_cas_latency(const dimm_params_t *dimm_params, + common_timing_params_t *outpdimm, + unsigned int number_of_dimms) { unsigned int i; - unsigned int taamin_ps = 0; - unsigned int tckmin_x_ps = 0; unsigned int common_caslat; unsigned int caslat_actual; unsigned int retry = 16; unsigned int tmp; const unsigned int mclk_ps = get_memory_clk_period_ps(); +#ifdef CONFIG_SYS_FSL_DDR3 + const unsigned int taamax = 20000; +#else + const unsigned int taamax = 18000; +#endif
/* compute the common CAS latency supported between slots */ tmp = dimm_params[0].caslat_x; @@ -34,19 +37,20 @@ compute_cas_latency_ddr3(const dimm_params_t *dimm_params, } common_caslat = tmp;
- /* compute the max tAAmin tCKmin between slots */ - for (i = 0; i < number_of_dimms; i++) { - taamin_ps = max(taamin_ps, dimm_params[i].taa_ps); - tckmin_x_ps = max(tckmin_x_ps, dimm_params[i].tckmin_x_ps); - } /* validate if the memory clk is in the range of dimms */ - if (mclk_ps < tckmin_x_ps) { + if (mclk_ps < outpdimm->tckmin_x_ps) { printf("DDR clock (MCLK cycle %u ps) is faster than " "the slowest DIMM(s) (tCKmin %u ps) can support.\n", - mclk_ps, tckmin_x_ps); + mclk_ps, outpdimm->tckmin_x_ps); + } +#ifdef CONFIG_SYS_FSL_DDR4 + if (mclk_ps > outpdimm->tckmax_ps) { + printf("DDR clock (MCLK cycle %u ps) is slower than DIMM(s) (tCKmax %u ps) can support.\n", + mclk_ps, outpdimm->tckmax_ps); } +#endif /* determine the acutal cas latency */ - caslat_actual = (taamin_ps + mclk_ps - 1) / mclk_ps; + caslat_actual = (outpdimm->taamin_ps + mclk_ps - 1) / mclk_ps; /* check if the dimms support the CAS latency */ while (!(common_caslat & (1 << caslat_actual)) && retry > 0) { caslat_actual++; @@ -54,13 +58,147 @@ compute_cas_latency_ddr3(const dimm_params_t *dimm_params, } /* once the caculation of caslat_actual is completed * we must verify that this CAS latency value does not - * exceed tAAmax, which is 20 ns for all DDR3 speed grades + * exceed tAAmax, which is 20 ns for all DDR3 speed grades, + * 18ns for all DDR4 speed grades. */ - if (caslat_actual * mclk_ps > 20000) { + if (caslat_actual * mclk_ps > taamax) { printf("The choosen cas latency %d is too large\n", caslat_actual); } - outpdimm->lowest_common_SPD_caslat = caslat_actual; + outpdimm->lowest_common_spd_caslat = caslat_actual; + debug("lowest_common_spd_caslat is 0x%x\n", caslat_actual); + + return 0; +} +#else /* for DDR1 and DDR2 */ +static unsigned int +compute_cas_latency(const dimm_params_t *dimm_params, + common_timing_params_t *outpdimm, + unsigned int number_of_dimms) +{ + int i; + const unsigned int mclk_ps = get_memory_clk_period_ps(); + unsigned int lowest_good_caslat; + unsigned int not_ok; + unsigned int temp1, temp2; + + debug("using mclk_ps = %u\n", mclk_ps); + if (mclk_ps > outpdimm->tckmax_ps) { + printf("Warning: DDR clock (%u ps) is slower than DIMM(s) (tCKmax %u ps)\n", + mclk_ps, outpdimm->tckmax_ps); + } + + /* + * Compute a CAS latency suitable for all DIMMs + * + * Strategy for SPD-defined latencies: compute only + * CAS latency defined by all DIMMs. + */ + + /* + * Step 1: find CAS latency common to all DIMMs using bitwise + * operation. + */ + temp1 = 0xFF; + for (i = 0; i < number_of_dimms; i++) { + if (dimm_params[i].n_ranks) { + temp2 = 0; + temp2 |= 1 << dimm_params[i].caslat_x; + temp2 |= 1 << dimm_params[i].caslat_x_minus_1; + temp2 |= 1 << dimm_params[i].caslat_x_minus_2; + /* + * If there was no entry for X-2 (X-1) in + * the SPD, then caslat_x_minus_2 + * (caslat_x_minus_1) contains either 255 or + * 0xFFFFFFFF because that's what the glorious + * __ilog2 function returns for an input of 0. + * On 32-bit PowerPC, left shift counts with bit + * 26 set (that the value of 255 or 0xFFFFFFFF + * will have), cause the destination register to + * be 0. That is why this works. + */ + temp1 &= temp2; + } + } + + /* + * Step 2: check each common CAS latency against tCK of each + * DIMM's SPD. + */ + lowest_good_caslat = 0; + temp2 = 0; + while (temp1) { + not_ok = 0; + temp2 = __ilog2(temp1); + debug("checking common caslat = %u\n", temp2); + + /* Check if this CAS latency will work on all DIMMs at tCK. */ + for (i = 0; i < number_of_dimms; i++) { + if (!dimm_params[i].n_ranks) + continue; + + if (dimm_params[i].caslat_x == temp2) { + if (mclk_ps >= dimm_params[i].tckmin_x_ps) { + debug("CL = %u ok on DIMM %u at tCK=%u ps with tCKmin_X_ps of %u\n", + temp2, i, mclk_ps, + dimm_params[i].tckmin_x_ps); + continue; + } else { + not_ok++; + } + } + + if (dimm_params[i].caslat_x_minus_1 == temp2) { + unsigned int tckmin_x_minus_1_ps + = dimm_params[i].tckmin_x_minus_1_ps; + if (mclk_ps >= tckmin_x_minus_1_ps) { + debug("CL = %u ok on DIMM %u at tCK=%u ps with tckmin_x_minus_1_ps of %u\n", + temp2, i, mclk_ps, + tckmin_x_minus_1_ps); + continue; + } else { + not_ok++; + } + } + + if (dimm_params[i].caslat_x_minus_2 == temp2) { + unsigned int tckmin_x_minus_2_ps + = dimm_params[i].tckmin_x_minus_2_ps; + if (mclk_ps >= tckmin_x_minus_2_ps) { + debug("CL = %u ok on DIMM %u at tCK=%u ps with tckmin_x_minus_2_ps of %u\n", + temp2, i, mclk_ps, + tckmin_x_minus_2_ps); + continue; + } else { + not_ok++; + } + } + } + + if (!not_ok) + lowest_good_caslat = temp2; + + temp1 &= ~(1 << temp2); + } + + debug("lowest common SPD-defined CAS latency = %u\n", + lowest_good_caslat); + outpdimm->lowest_common_spd_caslat = lowest_good_caslat; + + + /* + * Compute a common 'de-rated' CAS latency. + * + * The strategy here is to find the *highest* dereated cas latency + * with the assumption that all of the DIMMs will support a dereated + * CAS latency higher than or equal to their lowest dereated value. + */ + temp1 = 0; + for (i = 0; i < number_of_dimms; i++) + temp1 = max(temp1, dimm_params[i].caslat_lowest_derated); + + outpdimm->highest_common_derated_caslat = temp1; + debug("highest common dereated CAS latency = %u\n", temp1);
return 0; } @@ -82,34 +220,40 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params,
unsigned int tckmin_x_ps = 0; unsigned int tckmax_ps = 0xFFFFFFFF; - unsigned int tckmax_max_ps = 0; unsigned int trcd_ps = 0; unsigned int trp_ps = 0; unsigned int tras_ps = 0; +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) + unsigned int taamin_ps = 0; +#endif +#ifdef CONFIG_SYS_FSL_DDR4 + unsigned int twr_ps = 15000; + unsigned int trfc1_ps = 0; + unsigned int trfc2_ps = 0; + unsigned int trfc4_ps = 0; + unsigned int trrds_ps = 0; + unsigned int trrdl_ps = 0; + unsigned int tccdl_ps = 0; +#else unsigned int twr_ps = 0; unsigned int twtr_ps = 0; unsigned int trfc_ps = 0; unsigned int trrd_ps = 0; + unsigned int trtp_ps = 0; +#endif unsigned int trc_ps = 0; unsigned int refresh_rate_ps = 0; unsigned int extended_op_srt = 1; +#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) unsigned int tis_ps = 0; unsigned int tih_ps = 0; unsigned int tds_ps = 0; unsigned int tdh_ps = 0; - unsigned int trtp_ps = 0; unsigned int tdqsq_max_ps = 0; unsigned int tqhs_ps = 0; - +#endif unsigned int temp1, temp2; unsigned int additive_latency = 0; -#if !defined(CONFIG_SYS_FSL_DDR3) - const unsigned int mclk_ps = get_memory_clk_period_ps(); - unsigned int lowest_good_caslat; - unsigned int not_ok; - - debug("using mclk_ps = %u\n", mclk_ps); -#endif
temp1 = 0; for (i = 0; i < number_of_dimms; i++) { @@ -146,31 +290,34 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, * i.e., this is the slowest the whole system can go. */ tckmax_ps = min(tckmax_ps, dimm_params[i].tckmax_ps); - - /* Either find maximum value to determine slowest - * speed, delay, time, period, etc */ +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) + taamin_ps = max(taamin_ps, dimm_params[i].taa_ps); +#endif tckmin_x_ps = max(tckmin_x_ps, dimm_params[i].tckmin_x_ps); - tckmax_max_ps = max(tckmax_max_ps, dimm_params[i].tckmax_ps); trcd_ps = max(trcd_ps, dimm_params[i].trcd_ps); trp_ps = max(trp_ps, dimm_params[i].trp_ps); tras_ps = max(tras_ps, dimm_params[i].tras_ps); +#ifdef CONFIG_SYS_FSL_DDR4 + trfc1_ps = max(trfc1_ps, dimm_params[i].trfc1_ps); + trfc2_ps = max(trfc2_ps, dimm_params[i].trfc2_ps); + trfc4_ps = max(trfc4_ps, dimm_params[i].trfc4_ps); + trrds_ps = max(trrds_ps, dimm_params[i].trrds_ps); + trrdl_ps = max(trrdl_ps, dimm_params[i].trrdl_ps); + tccdl_ps = max(tccdl_ps, dimm_params[i].tccdl_ps); +#else twr_ps = max(twr_ps, dimm_params[i].twr_ps); twtr_ps = max(twtr_ps, dimm_params[i].twtr_ps); trfc_ps = max(trfc_ps, dimm_params[i].trfc_ps); trrd_ps = max(trrd_ps, dimm_params[i].trrd_ps); + trtp_ps = max(trtp_ps, dimm_params[i].trtp_ps); +#endif trc_ps = max(trc_ps, dimm_params[i].trc_ps); +#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) tis_ps = max(tis_ps, dimm_params[i].tis_ps); tih_ps = max(tih_ps, dimm_params[i].tih_ps); tds_ps = max(tds_ps, dimm_params[i].tds_ps); tdh_ps = max(tdh_ps, dimm_params[i].tdh_ps); - trtp_ps = max(trtp_ps, dimm_params[i].trtp_ps); tqhs_ps = max(tqhs_ps, dimm_params[i].tqhs_ps); - refresh_rate_ps = max(refresh_rate_ps, - dimm_params[i].refresh_rate_ps); - /* extended_op_srt is either 0 or 1, 0 having priority */ - extended_op_srt = min(extended_op_srt, - dimm_params[i].extended_op_srt); - /* * Find maximum tdqsq_max_ps to find slowest. * @@ -178,6 +325,12 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, * strategy for this parameter? */ tdqsq_max_ps = max(tdqsq_max_ps, dimm_params[i].tdqsq_max_ps); +#endif + refresh_rate_ps = max(refresh_rate_ps, + dimm_params[i].refresh_rate_ps); + /* extended_op_srt is either 0 or 1, 0 having priority */ + extended_op_srt = min(extended_op_srt, + dimm_params[i].extended_op_srt); }
outpdimm->ndimms_present = number_of_dimms - temp1; @@ -189,24 +342,37 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params,
outpdimm->tckmin_x_ps = tckmin_x_ps; outpdimm->tckmax_ps = tckmax_ps; - outpdimm->tckmax_max_ps = tckmax_max_ps; +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) + outpdimm->taamin_ps = taamin_ps; +#endif outpdimm->trcd_ps = trcd_ps; outpdimm->trp_ps = trp_ps; outpdimm->tras_ps = tras_ps; - outpdimm->twr_ps = twr_ps; +#ifdef CONFIG_SYS_FSL_DDR4 + outpdimm->trfc1_ps = trfc1_ps; + outpdimm->trfc2_ps = trfc2_ps; + outpdimm->trfc4_ps = trfc4_ps; + outpdimm->trrds_ps = trrds_ps; + outpdimm->trrdl_ps = trrdl_ps; + outpdimm->tccdl_ps = tccdl_ps; +#else outpdimm->twtr_ps = twtr_ps; outpdimm->trfc_ps = trfc_ps; outpdimm->trrd_ps = trrd_ps; + outpdimm->trtp_ps = trtp_ps; +#endif + outpdimm->twr_ps = twr_ps; outpdimm->trc_ps = trc_ps; outpdimm->refresh_rate_ps = refresh_rate_ps; outpdimm->extended_op_srt = extended_op_srt; +#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) outpdimm->tis_ps = tis_ps; outpdimm->tih_ps = tih_ps; outpdimm->tds_ps = tds_ps; outpdimm->tdh_ps = tdh_ps; - outpdimm->trtp_ps = trtp_ps; outpdimm->tdqsq_max_ps = tdqsq_max_ps; outpdimm->tqhs_ps = tqhs_ps; +#endif
/* Determine common burst length for all DIMMs. */ temp1 = 0xff; @@ -265,128 +431,9 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, if (temp1 != 0) printf("ERROR: Mix different RDIMM detected!\n");
-#if defined(CONFIG_SYS_FSL_DDR3) - if (compute_cas_latency_ddr3(dimm_params, outpdimm, number_of_dimms)) + /* calculate cas latency for all DDR types */ + if (compute_cas_latency(dimm_params, outpdimm, number_of_dimms)) return 1; -#else - /* - * Compute a CAS latency suitable for all DIMMs - * - * Strategy for SPD-defined latencies: compute only - * CAS latency defined by all DIMMs. - */ - - /* - * Step 1: find CAS latency common to all DIMMs using bitwise - * operation. - */ - temp1 = 0xFF; - for (i = 0; i < number_of_dimms; i++) { - if (dimm_params[i].n_ranks) { - temp2 = 0; - temp2 |= 1 << dimm_params[i].caslat_x; - temp2 |= 1 << dimm_params[i].caslat_x_minus_1; - temp2 |= 1 << dimm_params[i].caslat_x_minus_2; - /* - * FIXME: If there was no entry for X-2 (X-1) in - * the SPD, then caslat_x_minus_2 - * (caslat_x_minus_1) contains either 255 or - * 0xFFFFFFFF because that's what the glorious - * __ilog2 function returns for an input of 0. - * On 32-bit PowerPC, left shift counts with bit - * 26 set (that the value of 255 or 0xFFFFFFFF - * will have), cause the destination register to - * be 0. That is why this works. - */ - temp1 &= temp2; - } - } - - /* - * Step 2: check each common CAS latency against tCK of each - * DIMM's SPD. - */ - lowest_good_caslat = 0; - temp2 = 0; - while (temp1) { - not_ok = 0; - temp2 = __ilog2(temp1); - debug("checking common caslat = %u\n", temp2); - - /* Check if this CAS latency will work on all DIMMs at tCK. */ - for (i = 0; i < number_of_dimms; i++) { - if (!dimm_params[i].n_ranks) { - continue; - } - if (dimm_params[i].caslat_x == temp2) { - if (mclk_ps >= dimm_params[i].tckmin_x_ps) { - debug("CL = %u ok on DIMM %u at tCK=%u" - " ps with its tCKmin_X_ps of %u\n", - temp2, i, mclk_ps, - dimm_params[i].tckmin_x_ps); - continue; - } else { - not_ok++; - } - } - - if (dimm_params[i].caslat_x_minus_1 == temp2) { - unsigned int tckmin_x_minus_1_ps - = dimm_params[i].tckmin_x_minus_1_ps; - if (mclk_ps >= tckmin_x_minus_1_ps) { - debug("CL = %u ok on DIMM %u at " - "tCK=%u ps with its " - "tckmin_x_minus_1_ps of %u\n", - temp2, i, mclk_ps, - tckmin_x_minus_1_ps); - continue; - } else { - not_ok++; - } - } - - if (dimm_params[i].caslat_x_minus_2 == temp2) { - unsigned int tckmin_x_minus_2_ps - = dimm_params[i].tckmin_x_minus_2_ps; - if (mclk_ps >= tckmin_x_minus_2_ps) { - debug("CL = %u ok on DIMM %u at " - "tCK=%u ps with its " - "tckmin_x_minus_2_ps of %u\n", - temp2, i, mclk_ps, - tckmin_x_minus_2_ps); - continue; - } else { - not_ok++; - } - } - } - - if (!not_ok) { - lowest_good_caslat = temp2; - } - - temp1 &= ~(1 << temp2); - } - - debug("lowest common SPD-defined CAS latency = %u\n", - lowest_good_caslat); - outpdimm->lowest_common_SPD_caslat = lowest_good_caslat; - - - /* - * Compute a common 'de-rated' CAS latency. - * - * The strategy here is to find the *highest* dereated cas latency - * with the assumption that all of the DIMMs will support a dereated - * CAS latency higher than or equal to their lowest dereated value. - */ - temp1 = 0; - for (i = 0; i < number_of_dimms; i++) { - temp1 = max(temp1, dimm_params[i].caslat_lowest_derated); - } - outpdimm->highest_common_derated_caslat = temp1; - debug("highest common dereated CAS latency = %u\n", temp1); -#endif /* #if defined(CONFIG_SYS_FSL_DDR3) */
/* Determine if all DIMMs ECC capable. */ temp1 = 1; @@ -404,14 +451,6 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, } outpdimm->all_dimms_ecc_capable = temp1;
-#ifndef CONFIG_SYS_FSL_DDR3 - /* FIXME: move to somewhere else to validate. */ - if (mclk_ps > tckmax_max_ps) { - printf("Warning: some of the installed DIMMs " - "can not operate this slowly.\n"); - return 1; - } -#endif /* * Compute additive latency. * @@ -468,27 +507,20 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, additive_latency = 0;
#if defined(CONFIG_SYS_FSL_DDR2) - if (lowest_good_caslat < 4) { - additive_latency = (picos_to_mclk(trcd_ps) > lowest_good_caslat) - ? picos_to_mclk(trcd_ps) - lowest_good_caslat : 0; + if ((outpdimm->lowest_common_spd_caslat < 4) && + (picos_to_mclk(trcd_ps) > outpdimm->lowest_common_spd_caslat)) { + additive_latency = picos_to_mclk(trcd_ps) - + outpdimm->lowest_common_spd_caslat; if (mclk_to_picos(additive_latency) > trcd_ps) { additive_latency = picos_to_mclk(trcd_ps); debug("setting additive_latency to %u because it was " " greater than tRCD_ps\n", additive_latency); } } - -#elif defined(CONFIG_SYS_FSL_DDR3) - /* - * The system will not use the global auto-precharge mode. - * However, it uses the page mode, so we set AL=0 - */ - additive_latency = 0; #endif
/* * Validate additive latency - * FIXME: move to somewhere else to validate * * AL <= tRCD(min) */ @@ -516,10 +548,19 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, debug("trcd_ps = %u\n", outpdimm->trcd_ps); debug("trp_ps = %u\n", outpdimm->trp_ps); debug("tras_ps = %u\n", outpdimm->tras_ps); - debug("twr_ps = %u\n", outpdimm->twr_ps); +#ifdef CONFIG_SYS_FSL_DDR4 + debug("trfc1_ps = %u\n", trfc1_ps); + debug("trfc2_ps = %u\n", trfc2_ps); + debug("trfc4_ps = %u\n", trfc4_ps); + debug("trrds_ps = %u\n", trrds_ps); + debug("trrdl_ps = %u\n", trrdl_ps); + debug("tccdl_ps = %u\n", tccdl_ps); +#else debug("twtr_ps = %u\n", outpdimm->twtr_ps); debug("trfc_ps = %u\n", outpdimm->trfc_ps); debug("trrd_ps = %u\n", outpdimm->trrd_ps); +#endif + debug("twr_ps = %u\n", outpdimm->twr_ps); debug("trc_ps = %u\n", outpdimm->trc_ps);
return 0; diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index d62ca63..f95704f 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -1,5 +1,5 @@ /* - * Copyright 2008-2012 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -81,14 +81,37 @@ u8 spd_i2c_addr[CONFIG_NUM_DDR_CONTROLLERS][CONFIG_DIMM_SLOTS_PER_CTLR] = {
#endif
+#define SPD_SPA0_ADDRESS 0x36 +#define SPD_SPA1_ADDRESS 0x37 + static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) { int ret; +#ifdef CONFIG_SYS_FSL_DDR4 + uint8_t dummy = 0; +#endif
i2c_set_bus_num(CONFIG_SYS_SPD_BUS_NUM);
+#ifdef CONFIG_SYS_FSL_DDR4 + /* + * DDR4 SPD has 384 to 512 bytes + * To access the lower 256 bytes, we need to set EE page address to 0 + * To access the upper 256 bytes, we need to set EE page address to 1 + * See Jedec standar No. 21-C for detail + */ + i2c_write(SPD_SPA0_ADDRESS, 0, 1, &dummy, 1); + ret = i2c_read(i2c_address, 0, 1, (uchar *)spd, 256); + if (!ret) { + i2c_write(SPD_SPA1_ADDRESS, 0, 1, &dummy, 1); + ret = i2c_read(i2c_address, 0, 1, + (uchar *)((ulong)spd + 256), + min(256, sizeof(generic_spd_eeprom_t) - 256)); + } +#else ret = i2c_read(i2c_address, 0, 1, (uchar *)spd, sizeof(generic_spd_eeprom_t)); +#endif
if (ret) { if (i2c_address == diff --git a/drivers/ddr/fsl/options.c b/drivers/ddr/fsl/options.c index b0cf046..bf0d1da 100644 --- a/drivers/ddr/fsl/options.c +++ b/drivers/ddr/fsl/options.c @@ -1,5 +1,5 @@ /* - * Copyright 2008, 2010-2012 Freescale Semiconductor, Inc. + * Copyright 2008, 2010-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -29,7 +29,7 @@ struct dynamic_odt { unsigned int odt_rtt_wr; };
-#ifdef CONFIG_SYS_FSL_DDR3 +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) static const struct dynamic_odt single_Q[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, @@ -259,7 +259,7 @@ static const struct dynamic_odt odt_unknown[4] = { DDR3_RTT_OFF } }; -#else /* CONFIG_SYS_FSL_DDR3 */ +#else /* CONFIG_SYS_FSL_DDR3 || CONFIG_SYS_FSL_DDR4 */ static const struct dynamic_odt single_Q[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, @@ -507,7 +507,9 @@ unsigned int populate_memctl_options(int all_dimms_registered, unsigned int i; char buffer[HWCONFIG_BUFFER_SIZE]; char *buf = NULL; -#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR2) +#if defined(CONFIG_SYS_FSL_DDR3) || \ + defined(CONFIG_SYS_FSL_DDR2) || \ + defined(CONFIG_SYS_FSL_DDR4) const struct dynamic_odt *pdodt = odt_unknown; #endif ulong ddr_freq; @@ -519,7 +521,9 @@ unsigned int populate_memctl_options(int all_dimms_registered, if (getenv_f("hwconfig", buffer, sizeof(buffer)) > 0) buf = buffer;
-#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR2) +#if defined(CONFIG_SYS_FSL_DDR3) || \ + defined(CONFIG_SYS_FSL_DDR2) || \ + defined(CONFIG_SYS_FSL_DDR4) /* Chip select options. */ if (CONFIG_DIMM_SLOTS_PER_CTLR == 1) { switch (pdimm[0].n_ranks) { @@ -585,7 +589,9 @@ unsigned int populate_memctl_options(int all_dimms_registered,
/* Pick chip-select local options. */ for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { -#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR2) +#if defined(CONFIG_SYS_FSL_DDR3) || \ + defined(CONFIG_SYS_FSL_DDR2) || \ + defined(CONFIG_SYS_FSL_DDR4) popts->cs_local_opts[i].odt_rd_cfg = pdodt[i].odt_rd_cfg; popts->cs_local_opts[i].odt_wr_cfg = pdodt[i].odt_wr_cfg; popts->cs_local_opts[i].odt_rtt_norm = pdodt[i].odt_rtt_norm; @@ -703,7 +709,7 @@ unsigned int populate_memctl_options(int all_dimms_registered, popts->x4_en = (pdimm[0].device_width == 4) ? 1 : 0;
/* Choose burst length. */ -#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) #if defined(CONFIG_E500MC) popts->otf_burst_chop_en = 0; /* on-the-fly burst chop disable */ popts->burst_length = DDR_BL8; /* Fixed 8-beat burst len */ @@ -722,7 +728,7 @@ unsigned int populate_memctl_options(int all_dimms_registered, #endif
/* Choose ddr controller address mirror mode */ -#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) popts->mirrored_dimm = pdimm[0].mirrored_dimm; #endif
@@ -766,11 +772,9 @@ unsigned int populate_memctl_options(int all_dimms_registered, * BSTTOPRE precharge interval * * Set this to 0 for global auto precharge - * - * FIXME: Should this be configured in picoseconds? - * Why it should be in ps: better understanding of this - * relative to actual DRAM timing parameters such as tRAS. - * e.g. tRAS(min) = 40 ns + * The value of 0x100 has been used for DDR1, DDR2, DDR3. + * It is not wrong. Any value should be OK. The performance depends on + * applications. There is no one good value for all. */ popts->bstopre = 0x100;
@@ -795,12 +799,12 @@ unsigned int populate_memctl_options(int all_dimms_registered, */ popts->tfaw_window_four_activates_ps = 37500;
-#elif defined(CONFIG_SYS_FSL_DDR3) +#else popts->tfaw_window_four_activates_ps = pdimm[0].tfaw_ps; #endif popts->zq_en = 0; popts->wrlvl_en = 0; -#if defined(CONFIG_SYS_FSL_DDR3) +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) /* * due to ddr3 dimm is fly-by topology * we suggest to enable write leveling to diff --git a/drivers/ddr/fsl/util.c b/drivers/ddr/fsl/util.c index ad53658..7a22aa3 100644 --- a/drivers/ddr/fsl/util.c +++ b/drivers/ddr/fsl/util.c @@ -1,5 +1,5 @@ /* - * Copyright 2008-2012 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -23,6 +23,18 @@
#define ULL_8FS 0xFFFFFFFFULL
+u32 fsl_ddr_get_version(void) +{ + struct ccsr_ddr __iomem *ddr; + u32 ver_major_minor_errata; + + ddr = (void *)_DDR_ADDR; + ver_major_minor_errata = (ddr_in32(&ddr->ip_rev1) & 0xFFFF) << 8; + ver_major_minor_errata |= (ddr_in32(&ddr->ip_rev2) & 0xFF00) >> 8; + + return ver_major_minor_errata; +} + /* * Round up mclk_ps to nearest 1 ps in memory controller code * if the error is 0.5ps or more. @@ -175,6 +187,9 @@ void board_add_ram_info(int use_default) case SDRAM_TYPE_DDR3: puts("3"); break; + case SDRAM_TYPE_DDR4: + puts("4"); + break; default: puts("?"); break; @@ -188,9 +203,12 @@ void board_add_ram_info(int use_default) puts(", 64-bit");
/* Calculate CAS latency based on timing cfg values */ - cas_lat = ((ddr_in32(&ddr->timing_cfg_1) >> 16) & 0xf) + 1; - if ((ddr_in32(&ddr->timing_cfg_3) >> 12) & 1) - cas_lat += (8 << 1); + cas_lat = ((ddr_in32(&ddr->timing_cfg_1) >> 16) & 0xf); + if (fsl_ddr_get_version() <= 0x40400) + cas_lat += 1; + else + cas_lat += 2; + cas_lat += ((ddr_in32(&ddr->timing_cfg_3) >> 12) & 3) << 4; printf(", CL=%d", cas_lat >> 1); if (cas_lat & 0x1) puts(".5"); diff --git a/include/common_timing_params.h b/include/common_timing_params.h index 76338d4..821de21 100644 --- a/include/common_timing_params.h +++ b/include/common_timing_params.h @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -14,32 +14,45 @@ typedef struct {
unsigned int tckmin_x_ps; unsigned int tckmax_ps; - unsigned int tckmax_max_ps; unsigned int trcd_ps; unsigned int trp_ps; unsigned int tras_ps; +#if defined(CONFIG_SYS_FSL_DDR3) || defined(CONFIG_SYS_FSL_DDR4) + unsigned int taamin_ps; +#endif
- unsigned int twr_ps; /* maximum = 63750 ps */ +#ifdef CONFIG_SYS_FSL_DDR4 + unsigned int trfc1_ps; + unsigned int trfc2_ps; + unsigned int trfc4_ps; + unsigned int trrds_ps; + unsigned int trrdl_ps; + unsigned int tccdl_ps; +#else unsigned int twtr_ps; /* maximum = 63750 ps */ unsigned int trfc_ps; /* maximum = 255 ns + 256 ns + .75 ns = 511750 ps */
unsigned int trrd_ps; /* maximum = 63750 ps */ + unsigned int trtp_ps; /* byte 38, spd->trtp */ +#endif + unsigned int twr_ps; /* maximum = 63750 ps */ unsigned int trc_ps; /* maximum = 254 ns + .75 ns = 254750 ps */
unsigned int refresh_rate_ps; unsigned int extended_op_srt;
+#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) unsigned int tis_ps; /* byte 32, spd->ca_setup */ unsigned int tih_ps; /* byte 33, spd->ca_hold */ unsigned int tds_ps; /* byte 34, spd->data_setup */ unsigned int tdh_ps; /* byte 35, spd->data_hold */ - unsigned int trtp_ps; /* byte 38, spd->trtp */ unsigned int tdqsq_max_ps; /* byte 44, spd->tdqsq */ unsigned int tqhs_ps; /* byte 45, spd->tqhs */ +#endif
unsigned int ndimms_present; - unsigned int lowest_common_SPD_caslat; + unsigned int lowest_common_spd_caslat; unsigned int highest_common_derated_caslat; unsigned int additive_latency; unsigned int all_dimms_burst_lengths_bitmask; diff --git a/include/ddr_spd.h b/include/ddr_spd.h index 15a3e8d..cf2aac6 100644 --- a/include/ddr_spd.h +++ b/include/ddr_spd.h @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -290,11 +290,220 @@ typedef struct ddr3_spd_eeprom_s {
} ddr3_spd_eeprom_t;
+/* From JEEC Standard No. 21-C release 23A */ +struct ddr4_spd_eeprom_s { + /* General Section: Bytes 0-127 */ + uint8_t info_size_crc; /* 0 # bytes */ + uint8_t spd_rev; /* 1 Total # bytes of SPD */ + uint8_t mem_type; /* 2 Key Byte / mem type */ + uint8_t module_type; /* 3 Key Byte / Module Type */ + uint8_t density_banks; /* 4 Density and Banks */ + uint8_t addressing; /* 5 Addressing */ + uint8_t package_type; /* 6 Package type */ + uint8_t opt_feature; /* 7 Optional features */ + uint8_t thermal_ref; /* 8 Thermal and refresh */ + uint8_t oth_opt_features; /* 9 Other optional features */ + uint8_t res_10; /* 10 Reserved */ + uint8_t module_vdd; /* 11 Module nominal voltage */ + uint8_t organization; /* 12 Module Organization */ + uint8_t bus_width; /* 13 Module Memory Bus Width */ + uint8_t therm_sensor; /* 14 Module Thermal Sensor */ + uint8_t ext_type; /* 15 Extended module type */ + uint8_t res_16; + uint8_t timebases; /* 17 MTb and FTB */ + uint8_t tck_min; /* 18 tCKAVGmin */ + uint8_t tck_max; /* 19 TCKAVGmax */ + uint8_t caslat_b1; /* 20 CAS latencies, 1st byte */ + uint8_t caslat_b2; /* 21 CAS latencies, 2nd byte */ + uint8_t caslat_b3; /* 22 CAS latencies, 3rd byte */ + uint8_t caslat_b4; /* 23 CAS latencies, 4th byte */ + uint8_t taa_min; /* 24 Min CAS Latency Time */ + uint8_t trcd_min; /* 25 Min RAS# to CAS# Delay Time */ + uint8_t trp_min; /* 26 Min Row Precharge Delay Time */ + uint8_t tras_trc_ext; /* 27 Upper Nibbles for tRAS and tRC */ + uint8_t tras_min_lsb; /* 28 tRASmin, lsb */ + uint8_t trc_min_lsb; /* 29 tRCmin, lsb */ + uint8_t trfc1_min_lsb; /* 30 Min Refresh Recovery Delay Time */ + uint8_t trfc1_min_msb; /* 31 Min Refresh Recovery Delay Time */ + uint8_t trfc2_min_lsb; /* 32 Min Refresh Recovery Delay Time */ + uint8_t trfc2_min_msb; /* 33 Min Refresh Recovery Delay Time */ + uint8_t trfc4_min_lsb; /* 34 Min Refresh Recovery Delay Time */ + uint8_t trfc4_min_msb; /* 35 Min Refresh Recovery Delay Time */ + uint8_t tfaw_msb; /* 36 Upper Nibble for tFAW */ + uint8_t tfaw_min; /* 37 tFAW, lsb */ + uint8_t trrds_min; /* 38 tRRD_Smin, MTB */ + uint8_t trrdl_min; /* 39 tRRD_Lmin, MTB */ + uint8_t tccdl_min; /* 40 tCCS_Lmin, MTB */ + uint8_t res_41[60-41]; /* 41 Rserved */ + uint8_t mapping[78-60]; /* 60~77 Connector to SDRAM bit map */ + uint8_t res_78[117-78]; /* 78~116, Reserved */ + int8_t fine_tccdl_min; /* 117 Fine offset for tCCD_Lmin */ + int8_t fine_trrdl_min; /* 118 Fine offset for tRRD_Lmin */ + int8_t fine_trrds_min; /* 119 Fine offset for tRRD_Smin */ + int8_t fine_trc_min; /* 120 Fine offset for tRCmin */ + int8_t fine_trp_min; /* 121 Fine offset for tRPmin */ + int8_t fine_trcd_min; /* 122 Fine offset for tRCDmin */ + int8_t fine_taa_min; /* 123 Fine offset for tAAmin */ + int8_t fine_tck_max; /* 124 Fine offset for tCKAVGmax */ + int8_t fine_tck_min; /* 125 Fine offset for tCKAVGmin */ + /* CRC: Bytes 126-127 */ + uint8_t crc[2]; /* 126-127 SPD CRC */ + + /* Module-Specific Section: Bytes 128-255 */ + union { + struct { + /* 128 (Unbuffered) Module Nominal Height */ + uint8_t mod_height; + /* 129 (Unbuffered) Module Maximum Thickness */ + uint8_t mod_thickness; + /* 130 (Unbuffered) Reference Raw Card Used */ + uint8_t ref_raw_card; + /* 131 (Unbuffered) Address Mapping from + Edge Connector to DRAM */ + uint8_t addr_mapping; + /* 132~253 (Unbuffered) Reserved */ + uint8_t res_132[254-132]; + /* 254~255 CRC */ + uint8_t crc[2]; + } unbuffered; + struct { + /* 128 (Registered) Module Nominal Height */ + uint8_t mod_height; + /* 129 (Registered) Module Maximum Thickness */ + uint8_t mod_thickness; + /* 130 (Registered) Reference Raw Card Used */ + uint8_t ref_raw_card; + /* 131 DIMM Module Attributes */ + uint8_t modu_attr; + /* 132 RDIMM Thermal Heat Spreader Solution */ + uint8_t thermal; + /* 133 Register Manufacturer ID Code, LSB */ + uint8_t reg_id_lo; + /* 134 Register Manufacturer ID Code, MSB */ + uint8_t reg_id_hi; + /* 135 Register Revision Number */ + uint8_t reg_rev; + /* 136 Address mapping from register to DRAM */ + uint8_t reg_map; + /* 137~253 Reserved */ + uint8_t res_137[254-137]; + /* 254~255 CRC */ + uint8_t crc[2]; + } registered; + struct { + /* 128 (Loadreduced) Module Nominal Height */ + uint8_t mod_height; + /* 129 (Loadreduced) Module Maximum Thickness */ + uint8_t mod_thickness; + /* 130 (Loadreduced) Reference Raw Card Used */ + uint8_t ref_raw_card; + /* 131 DIMM Module Attributes */ + uint8_t modu_attr; + /* 132 RDIMM Thermal Heat Spreader Solution */ + uint8_t thermal; + /* 133 Register Manufacturer ID Code, LSB */ + uint8_t reg_id_lo; + /* 134 Register Manufacturer ID Code, MSB */ + uint8_t reg_id_hi; + /* 135 Register Revision Number */ + uint8_t reg_rev; + /* 136 Address mapping from register to DRAM */ + uint8_t reg_map; + /* 137 Register Output Drive Strength for CMD/Add*/ + uint8_t reg_drv; + /* 138 Register Output Drive Strength for CK */ + uint8_t reg_drv_ck; + /* 139 Data Buffer Revision Number */ + uint8_t data_buf_rev; + /* 140 DRAM VrefDQ for Package Rank 0 */ + uint8_t vrefqe_r0; + /* 141 DRAM VrefDQ for Package Rank 1 */ + uint8_t vrefqe_r1; + /* 142 DRAM VrefDQ for Package Rank 2 */ + uint8_t vrefqe_r2; + /* 143 DRAM VrefDQ for Package Rank 3 */ + uint8_t vrefqe_r3; + /* 144 Data Buffer VrefDQ for DRAM Interface */ + uint8_t data_intf; + /* + * 145 Data Buffer MDQ Drive Strength and RTT + * for data rate <= 1866 + */ + uint8_t data_drv_1866; + /* + * 146 Data Buffer MDQ Drive Strength and RTT + * for 1866 < data rate <= 2400 + */ + uint8_t data_drv_2400; + /* + * 147 Data Buffer MDQ Drive Strength and RTT + * for 2400 < data rate <= 3200 + */ + uint8_t data_drv_3200; + /* 148 DRAM Drive Strength */ + uint8_t dram_drv; + /* + * 149 DRAM ODT (RTT_WR, RTT_NOM) + * for data rate <= 1866 + */ + uint8_t dram_odt_1866; + /* + * 150 DRAM ODT (RTT_WR, RTT_NOM) + * for 1866 < data rate <= 2400 + */ + uint8_t dram_odt_2400; + /* + * 151 DRAM ODT (RTT_WR, RTT_NOM) + * for 2400 < data rate <= 3200 + */ + uint8_t dram_odt_3200; + /* + * 152 DRAM ODT (RTT_PARK) + * for data rate <= 1866 + */ + uint8_t dram_odt_park_1866; + /* + * 153 DRAM ODT (RTT_PARK) + * for 1866 < data rate <= 2400 + */ + uint8_t dram_odt_park_2400; + /* + * 154 DRAM ODT (RTT_PARK) + * for 2400 < data rate <= 3200 + */ + uint8_t dram_odt_park_3200; + uint8_t res_155[254-155]; /* Reserved */ + /* 254~255 CRC */ + uint8_t crc[2]; + } loadreduced; + uint8_t uc[128]; /* 128-255 Module-Specific Section */ + } mod_section; + + uint8_t res_256[320-256]; /* 256~319 Reserved */ + + /* Module supplier's data: Byte 320~383 */ + uint8_t mmid_lsb; /* 320 Module MfgID Code LSB */ + uint8_t mmid_msb; /* 321 Module MfgID Code MSB */ + uint8_t mloc; /* 322 Mfg Location */ + uint8_t mdate[2]; /* 323~324 Mfg Date */ + uint8_t sernum[4]; /* 325~328 Module Serial Number */ + uint8_t mpart[20]; /* 329~348 Mfg's Module Part Number */ + uint8_t mrev; /* 349 Module Revision Code */ + uint8_t dmid_lsb; /* 350 DRAM MfgID Code LSB */ + uint8_t dmid_msb; /* 351 DRAM MfgID Code MSB */ + uint8_t stepping; /* 352 DRAM stepping */ + uint8_t msd[29]; /* 353~381 Mfg's Specific Data */ + uint8_t res_382[2]; /* 382~383 Reserved */ + + uint8_t user[512-384]; /* 384~511 End User Programmable */ +}; + extern unsigned int ddr1_spd_check(const ddr1_spd_eeprom_t *spd); extern void ddr1_spd_dump(const ddr1_spd_eeprom_t *spd); extern unsigned int ddr2_spd_check(const ddr2_spd_eeprom_t *spd); extern void ddr2_spd_dump(const ddr2_spd_eeprom_t *spd); extern unsigned int ddr3_spd_check(const ddr3_spd_eeprom_t *spd); +unsigned int ddr4_spd_check(const struct ddr4_spd_eeprom_s *spd);
/* * Byte 2 Fundamental Memory Types. @@ -310,6 +519,7 @@ extern unsigned int ddr3_spd_check(const ddr3_spd_eeprom_t *spd); #define SPD_MEMTYPE_DDR2_FBDIMM (0x09) #define SPD_MEMTYPE_DDR2_FBDIMM_PROBE (0x0A) #define SPD_MEMTYPE_DDR3 (0x0B) +#define SPD_MEMTYPE_DDR4 (0x0C)
/* DIMM Type for DDR2 SPD (according to v1.3) */ #define DDR2_SPD_DIMMTYPE_UNDEFINED (0x00) @@ -338,4 +548,18 @@ extern unsigned int ddr3_spd_check(const ddr3_spd_eeprom_t *spd); #define DDR3_SPD_MODULETYPE_16B_SO_DIMM (0x0C) #define DDR3_SPD_MODULETYPE_32B_SO_DIMM (0x0D)
+/* DIMM Type for DDR4 SPD */ +#define DDR4_SPD_MODULETYPE_MASK (0x0f) +#define DDR4_SPD_MODULETYPE_EXT (0x00) +#define DDR4_SPD_MODULETYPE_RDIMM (0x01) +#define DDR4_SPD_MODULETYPE_UDIMM (0x02) +#define DDR4_SPD_MODULETYPE_SO_DIMM (0x03) +#define DDR4_SPD_MODULETYPE_LRDIMM (0x04) +#define DDR4_SPD_MODULETYPE_MINI_RDIMM (0x05) +#define DDR4_SPD_MODULETYPE_MINI_UDIMM (0x06) +#define DDR4_SPD_MODULETYPE_72B_SO_UDIMM (0x08) +#define DDR4_SPD_MODULETYPE_72B_SO_RDIMM (0x09) +#define DDR4_SPD_MODULETYPE_16B_SO_DIMM (0x0C) +#define DDR4_SPD_MODULETYPE_32B_SO_DIMM (0x0D) + #endif /* _DDR_SPD_H_ */ diff --git a/include/fsl_ddr.h b/include/fsl_ddr.h index 72c0b2e..5c49b22 100644 --- a/include/fsl_ddr.h +++ b/include/fsl_ddr.h @@ -1,5 +1,5 @@ /* - * Copyright 2008-2011 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -9,6 +9,7 @@ #ifndef FSL_DDR_MAIN_H #define FSL_DDR_MAIN_H
+#include <fsl_ddrc_version.h> #include <fsl_ddr_sdram.h> #include <fsl_ddr_dimm_params.h>
@@ -22,6 +23,10 @@ #define ddr_out32(a, v) out_be32(a, v) #endif
+#define _DDR_ADDR CONFIG_SYS_FSL_DDR_ADDR + +u32 fsl_ddr_get_version(void); + #if defined(CONFIG_DDR_SPD) || defined(CONFIG_SPD_EEPROM) /* * Bind the main DDR setup driver's generic names diff --git a/include/fsl_ddr_dimm_params.h b/include/fsl_ddr_dimm_params.h index 99a72bc..09a67a6 100644 --- a/include/fsl_ddr_dimm_params.h +++ b/include/fsl_ddr_dimm_params.h @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -13,7 +13,7 @@ #define EDC_ECC 2 #define EDC_AC_PARITY 4
-/* Parameters for a DDR2 dimm computed from the SPD */ +/* Parameters for a DDR dimm computed from the SPD */ typedef struct dimm_params_s {
/* DIMM organization parameters */ @@ -32,7 +32,12 @@ typedef struct dimm_params_s { unsigned int n_row_addr; unsigned int n_col_addr; unsigned int edc_config; /* 0 = none, 1 = parity, 2 = ECC */ +#ifdef CONFIG_SYS_FSL_DDR4 + unsigned int bank_addr_bits; + unsigned int bank_group_bits; +#else unsigned int n_banks_per_sdram_device; +#endif unsigned int burst_lengths_bitmask; /* BL=4 bit 2, BL=8 = bit 3 */ unsigned int row_density;
@@ -43,19 +48,19 @@ typedef struct dimm_params_s {
/* DIMM timing parameters */
- unsigned int mtb_ps; /* medium timebase ps, only for ddr3 */ - unsigned int ftb_10th_ps; /* fine timebase, in 1/10 ps, only for ddr3 */ - unsigned int taa_ps; /* minimum CAS latency time, only for ddr3 */ - unsigned int tfaw_ps; /* four active window delay, only for ddr3 */ + int mtb_ps; /* medium timebase ps */ + int ftb_10th_ps; /* fine timebase, in 1/10 ps */ + int taa_ps; /* minimum CAS latency time */ + int tfaw_ps; /* four active window delay */
/* * SDRAM clock periods * The range for these are 1000-10000 so a short should be sufficient */ - unsigned int tckmin_x_ps; - unsigned int tckmin_x_minus_1_ps; - unsigned int tckmin_x_minus_2_ps; - unsigned int tckmax_ps; + int tckmin_x_ps; + int tckmin_x_minus_1_ps; + int tckmin_x_minus_2_ps; + int tckmax_ps;
/* SPD-defined CAS latencies */ unsigned int caslat_x; @@ -65,32 +70,46 @@ typedef struct dimm_params_s { unsigned int caslat_lowest_derated; /* Derated CAS latency */
/* basic timing parameters */ - unsigned int trcd_ps; - unsigned int trp_ps; - unsigned int tras_ps; - - unsigned int twr_ps; /* maximum = 63750 ps */ - unsigned int twtr_ps; /* maximum = 63750 ps */ - unsigned int trfc_ps; /* max = 255 ns + 256 ns + .75 ns + int trcd_ps; + int trp_ps; + int tras_ps; + +#ifdef CONFIG_SYS_FSL_DDR4 + int trfc1_ps; + int trfc2_ps; + int trfc4_ps; + int trrds_ps; + int trrdl_ps; + int tccdl_ps; +#else + int twr_ps; /* maximum = 63750 ps */ + int trfc_ps; /* max = 255 ns + 256 ns + .75 ns = 511750 ps */ + int trrd_ps; /* maximum = 63750 ps */ + int twtr_ps; /* maximum = 63750 ps */ + int trtp_ps; /* byte 38, spd->trtp */ +#endif
- unsigned int trrd_ps; /* maximum = 63750 ps */ - unsigned int trc_ps; /* maximum = 254 ns + .75 ns = 254750 ps */ + int trc_ps; /* maximum = 254 ns + .75 ns = 254750 ps */
- unsigned int refresh_rate_ps; - unsigned int extended_op_srt; + int refresh_rate_ps; + int extended_op_srt;
- /* DDR3 doesn't need these as below */ - unsigned int tis_ps; /* byte 32, spd->ca_setup */ - unsigned int tih_ps; /* byte 33, spd->ca_hold */ - unsigned int tds_ps; /* byte 34, spd->data_setup */ - unsigned int tdh_ps; /* byte 35, spd->data_hold */ - unsigned int trtp_ps; /* byte 38, spd->trtp */ - unsigned int tdqsq_max_ps; /* byte 44, spd->tdqsq */ - unsigned int tqhs_ps; /* byte 45, spd->tqhs */ +#if defined(CONFIG_SYS_FSL_DDR1) || defined(CONFIG_SYS_FSL_DDR2) + int tis_ps; /* byte 32, spd->ca_setup */ + int tih_ps; /* byte 33, spd->ca_hold */ + int tds_ps; /* byte 34, spd->data_setup */ + int tdh_ps; /* byte 35, spd->data_hold */ + int tdqsq_max_ps; /* byte 44, spd->tdqsq */ + int tqhs_ps; /* byte 45, spd->tqhs */ +#endif
/* DDR3 RDIMM */ unsigned char rcw[16]; /* Register Control Word 0-15 */ +#ifdef CONFIG_SYS_FSL_DDR4 + unsigned int dq_mapping[18]; + unsigned int dq_mapping_ors; +#endif } dimm_params_t;
extern unsigned int ddr_compute_dimm_parameters( diff --git a/include/fsl_ddr_sdram.h b/include/fsl_ddr_sdram.h index 2a36431..e39b716 100644 --- a/include/fsl_ddr_sdram.h +++ b/include/fsl_ddr_sdram.h @@ -1,5 +1,5 @@ /* - * Copyright 2008-2011 Freescale Semiconductor, Inc. + * Copyright 2008-2014 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License @@ -13,11 +13,13 @@ * Pick a basic DDR Technology. */ #include <ddr_spd.h> +#include <fsl_ddrc_version.h>
-#define SDRAM_TYPE_DDR1 2 -#define SDRAM_TYPE_DDR2 3 -#define SDRAM_TYPE_LPDDR1 6 -#define SDRAM_TYPE_DDR3 7 +#define SDRAM_TYPE_DDR1 2 +#define SDRAM_TYPE_DDR2 3 +#define SDRAM_TYPE_LPDDR1 6 +#define SDRAM_TYPE_DDR3 7 +#define SDRAM_TYPE_DDR4 5
#define DDR_BL4 4 /* burst length 4 */ #define DDR_BC4 DDR_BL4 /* burst chop for ddr3 */ @@ -54,6 +56,12 @@ typedef ddr3_spd_eeprom_t generic_spd_eeprom_t; #ifndef CONFIG_FSL_SDRAM_TYPE #define CONFIG_FSL_SDRAM_TYPE SDRAM_TYPE_DDR3 #endif +#elif defined(CONFIG_SYS_FSL_DDR4) +#define FSL_DDR_MIN_TCKE_PULSE_WIDTH_DDR (3) /* FIXME */ +typedef struct ddr4_spd_eeprom_s generic_spd_eeprom_t; +#ifndef CONFIG_FSL_SDRAM_TYPE +#define CONFIG_FSL_SDRAM_TYPE SDRAM_TYPE_DDR4 +#endif #endif /* #if defined(CONFIG_SYS_FSL_DDR1) */
#define FSL_DDR_ODT_NEVER 0x0 @@ -116,7 +124,8 @@ typedef ddr3_spd_eeprom_t generic_spd_eeprom_t;
#define TIMING_CFG_2_CPO_MASK 0x0F800000
-#if defined(CONFIG_P4080) +#if defined(CONFIG_SYS_FSL_DDR_VER) && \ + (CONFIG_SYS_FSL_DDR_VER > FSL_DDR_VER_4_4) #define RD_TO_PRE_MASK 0xf #define RD_TO_PRE_SHIFT 13 #define WR_DATA_DELAY_MASK 0xf @@ -154,9 +163,27 @@ typedef ddr3_spd_eeprom_t generic_spd_eeprom_t; #define DDR_CDR2_ODT_MASK 0x1 #define DDR_CDR1_ODT(x) ((x & DDR_CDR1_ODT_MASK) << DDR_CDR1_ODT_SHIFT) #define DDR_CDR2_ODT(x) (x & DDR_CDR2_ODT_MASK) +#define DDR_CDR2_VREF_OVRD(x) (0x00008080 | ((((x) - 37) & 0x3F) << 8))
#if (defined(CONFIG_SYS_FSL_DDR_VER) && \ (CONFIG_SYS_FSL_DDR_VER >= FSL_DDR_VER_4_7)) +#ifdef CONFIG_SYS_FSL_DDR3L +#define DDR_CDR_ODT_OFF 0x0 +#define DDR_CDR_ODT_120ohm 0x1 +#define DDR_CDR_ODT_200ohm 0x2 +#define DDR_CDR_ODT_75ohm 0x3 +#define DDR_CDR_ODT_60ohm 0x5 +#define DDR_CDR_ODT_46ohm 0x7 +#elif defined(CONFIG_SYS_FSL_DDR4) +#define DDR_CDR_ODT_OFF 0x0 +#define DDR_CDR_ODT_100ohm 0x1 +#define DDR_CDR_ODT_120OHM 0x2 +#define DDR_CDR_ODT_80ohm 0x3 +#define DDR_CDR_ODT_60ohm 0x4 +#define DDR_CDR_ODT_40ohm 0x5 +#define DDR_CDR_ODT_50ohm 0x6 +#define DDR_CDR_ODT_30ohm 0x7 +#else #define DDR_CDR_ODT_OFF 0x0 #define DDR_CDR_ODT_120ohm 0x1 #define DDR_CDR_ODT_180ohm 0x2 @@ -165,6 +192,7 @@ typedef ddr3_spd_eeprom_t generic_spd_eeprom_t; #define DDR_CDR_ODT_60hm 0x5 #define DDR_CDR_ODT_70ohm 0x6 #define DDR_CDR_ODT_47ohm 0x7 +#endif /* DDR3L */ #else #define DDR_CDR_ODT_75ohm 0x0 #define DDR_CDR_ODT_55ohm 0x1 @@ -188,6 +216,7 @@ typedef struct fsl_ddr_cfg_regs_s { unsigned int timing_cfg_2; unsigned int ddr_sdram_cfg; unsigned int ddr_sdram_cfg_2; + unsigned int ddr_sdram_cfg_3; unsigned int ddr_sdram_mode; unsigned int ddr_sdram_mode_2; unsigned int ddr_sdram_mode_3; @@ -196,6 +225,14 @@ typedef struct fsl_ddr_cfg_regs_s { unsigned int ddr_sdram_mode_6; unsigned int ddr_sdram_mode_7; unsigned int ddr_sdram_mode_8; + unsigned int ddr_sdram_mode_9; + unsigned int ddr_sdram_mode_10; + unsigned int ddr_sdram_mode_11; + unsigned int ddr_sdram_mode_12; + unsigned int ddr_sdram_mode_13; + unsigned int ddr_sdram_mode_14; + unsigned int ddr_sdram_mode_15; + unsigned int ddr_sdram_mode_16; unsigned int ddr_sdram_md_cntl; unsigned int ddr_sdram_interval; unsigned int ddr_data_init; @@ -204,6 +241,10 @@ typedef struct fsl_ddr_cfg_regs_s { unsigned int ddr_init_ext_addr; unsigned int timing_cfg_4; unsigned int timing_cfg_5; + unsigned int timing_cfg_6; + unsigned int timing_cfg_7; + unsigned int timing_cfg_8; + unsigned int timing_cfg_9; unsigned int ddr_zq_cntl; unsigned int ddr_wrlvl_cntl; unsigned int ddr_wrlvl_cntl_2; @@ -211,6 +252,14 @@ typedef struct fsl_ddr_cfg_regs_s { unsigned int ddr_sr_cntr; unsigned int ddr_sdram_rcw_1; unsigned int ddr_sdram_rcw_2; + unsigned int ddr_sdram_rcw_3; + unsigned int ddr_sdram_rcw_4; + unsigned int ddr_sdram_rcw_5; + unsigned int ddr_sdram_rcw_6; + unsigned int dq_map_0; + unsigned int dq_map_1; + unsigned int dq_map_2; + unsigned int dq_map_3; unsigned int ddr_eor; unsigned int ddr_cdr1; unsigned int ddr_cdr2; @@ -225,7 +274,7 @@ typedef struct memctl_options_partial_s { unsigned int all_dimms_burst_lengths_bitmask; unsigned int all_dimms_registered; unsigned int all_dimms_unbuffered; - /* unsigned int lowest_common_SPD_caslat; */ + /* unsigned int lowest_common_spd_caslat; */ unsigned int all_dimms_minimum_trcd_ps; } memctl_options_partial_t;
diff --git a/include/fsl_ddrc_version.h b/include/fsl_ddrc_version.h new file mode 100644 index 0000000..60ba98b --- /dev/null +++ b/include/fsl_ddrc_version.h @@ -0,0 +1,18 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FSL_DDRC_VER_H +#define __FSL_DDRC_VER_H + +/* + * Only the versions with distinct features or registers are listed here. + */ +#define FSL_DDR_VER_4_4 44 +#define FSL_DDR_VER_4_6 46 +#define FSL_DDR_VER_4_7 47 +#define FSL_DDR_VER_5_0 50 + +#endif /* __FSL_DDRC_VER_H */ diff --git a/include/fsl_immap.h b/include/fsl_immap.h index 00902ca..d63cc19 100644 --- a/include/fsl_immap.h +++ b/include/fsl_immap.h @@ -1,7 +1,7 @@ /* * Common internal memory map for some Freescale SoCs * - * Copyright 2013 Freescale Semiconductor, Inc. + * Copyright 2013-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -50,7 +50,8 @@ struct ccsr_ddr { u8 res_150[16]; u32 timing_cfg_4; /* SDRAM Timing Configuration 4 */ u32 timing_cfg_5; /* SDRAM Timing Configuration 5 */ - u8 reg_168[8]; + u32 timing_cfg_6; /* SDRAM Timing Configuration 6 */ + u32 timing_cfg_7; /* SDRAM Timing Configuration 7 */ u32 ddr_zq_cntl; /* ZQ calibration control*/ u32 ddr_wrlvl_cntl; /* write leveling control*/ u8 reg_178[4]; @@ -60,14 +61,40 @@ struct ccsr_ddr { u8 reg_188[8]; u32 ddr_wrlvl_cntl_2; /* write leveling control 2 */ u32 ddr_wrlvl_cntl_3; /* write leveling control 3 */ - u8 res_198[104]; + u8 res_198[0x1a0-0x198]; + u32 ddr_sdram_rcw_3; + u32 ddr_sdram_rcw_4; + u32 ddr_sdram_rcw_5; + u32 ddr_sdram_rcw_6; + u8 res_1b0[0x200-0x1b0]; u32 sdram_mode_3; /* SDRAM Mode Configuration 3 */ u32 sdram_mode_4; /* SDRAM Mode Configuration 4 */ u32 sdram_mode_5; /* SDRAM Mode Configuration 5 */ u32 sdram_mode_6; /* SDRAM Mode Configuration 6 */ u32 sdram_mode_7; /* SDRAM Mode Configuration 7 */ u32 sdram_mode_8; /* SDRAM Mode Configuration 8 */ - u8 res_218[0x908]; + u8 res_218[0x220-0x218]; + u32 sdram_mode_9; /* SDRAM Mode Configuration 9 */ + u32 sdram_mode_10; /* SDRAM Mode Configuration 10 */ + u32 sdram_mode_11; /* SDRAM Mode Configuration 11 */ + u32 sdram_mode_12; /* SDRAM Mode Configuration 12 */ + u32 sdram_mode_13; /* SDRAM Mode Configuration 13 */ + u32 sdram_mode_14; /* SDRAM Mode Configuration 14 */ + u32 sdram_mode_15; /* SDRAM Mode Configuration 15 */ + u32 sdram_mode_16; /* SDRAM Mode Configuration 16 */ + u8 res_240[0x250-0x240]; + u32 timing_cfg_8; /* SDRAM Timing Configuration 8 */ + u32 timing_cfg_9; /* SDRAM Timing Configuration 9 */ + u8 res_258[0x260-0x258]; + u32 sdram_cfg_3; + u8 res_264[0x2a0-0x264]; + u32 deskew_cntl; + u8 res_2a4[0x400-0x2a4]; + u32 dq_map_0; + u32 dq_map_1; + u32 dq_map_2; + u32 dq_map_3; + u8 res_410[0xb20-0x410]; u32 ddr_dsr1; /* Debug Status 1 */ u32 ddr_dsr2; /* Debug Status 2 */ u32 ddr_cdr1; /* Control Driver 1 */
T1040QDS_D4 is a variant of T1040QDS, with additional circuit to support DDR4 memory.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/t1040qds/ddr.c | 17 ++++++++--------- board/freescale/t1040qds/ddr.h | 37 +++++++++++++++++++------------------ boards.cfg | 1 + include/configs/T1040QDS.h | 4 +++- 4 files changed, 31 insertions(+), 28 deletions(-)
diff --git a/board/freescale/t1040qds/ddr.c b/board/freescale/t1040qds/ddr.c index da89a36..43f952f 100644 --- a/board/freescale/t1040qds/ddr.c +++ b/board/freescale/t1040qds/ddr.c @@ -1,5 +1,5 @@ /* - * Copyright 2013 Freescale Semiconductor, Inc. + * Copyright 2013-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -39,14 +39,10 @@ void fsl_ddr_board_options(memctl_options_t *popts, if (pbsp->n_ranks == pdimm->n_ranks && (pdimm->rank_density >> 30) >= pbsp->rank_gb) { if (ddr_freq <= pbsp->datarate_mhz_high) { - popts->cpo_override = pbsp->cpo; - popts->write_data_delay = - pbsp->write_data_delay; popts->clk_adjust = pbsp->clk_adjust; popts->wrlvl_start = pbsp->wrlvl_start; popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - popts->twot_en = pbsp->force_2t; goto found; } pbsp_highest = pbsp; @@ -59,13 +55,10 @@ void fsl_ddr_board_options(memctl_options_t *popts, printf("for data rate %lu MT/s\n", ddr_freq); printf("Trying to use the highest speed (%u) parameters\n", pbsp_highest->datarate_mhz_high); - popts->cpo_override = pbsp_highest->cpo; - popts->write_data_delay = pbsp_highest->write_data_delay; popts->clk_adjust = pbsp_highest->clk_adjust; popts->wrlvl_start = pbsp_highest->wrlvl_start; popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - popts->twot_en = pbsp_highest->force_2t; } else { panic("DIMM is not supported by this board"); } @@ -81,7 +74,7 @@ found: * Factors to consider for half-strength driver enable: * - number of DIMMs installed */ - popts->half_strength_driver_enable = 0; + popts->half_strength_driver_enable = 1; /* * Write leveling override */ @@ -97,8 +90,14 @@ found: popts->zq_en = 1;
/* DHC_EN =1, ODT = 75 Ohm */ +#ifdef CONFIG_SYS_FSL_DDR4 + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | + DDR_CDR2_VREF_OVRD(70); /* Vref = 70% */ +#else popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); +#endif }
phys_size_t initdram(int board_type) diff --git a/board/freescale/t1040qds/ddr.h b/board/freescale/t1040qds/ddr.h index afa72af..a6e1673 100644 --- a/board/freescale/t1040qds/ddr.h +++ b/board/freescale/t1040qds/ddr.h @@ -1,5 +1,5 @@ /* - * Copyright 2013 Freescale Semiconductor, Inc. + * Copyright 2013-2014 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -14,9 +14,6 @@ struct board_specific_parameters { u32 wrlvl_start; u32 wrlvl_ctl_2; u32 wrlvl_ctl_3; - u32 cpo; - u32 write_data_delay; - u32 force_2t; };
/* @@ -28,21 +25,25 @@ struct board_specific_parameters { static const struct board_specific_parameters udimm0[] = { /* * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ - {2, 833, 4, 4, 6, 0x06060607, 0x08080807, 0xff, 2, 0}, - {2, 833, 0, 4, 6, 0x06060607, 0x08080807, 0xff, 2, 0}, - {2, 1350, 4, 4, 7, 0x0708080A, 0x0A0B0C09, 0xff, 2, 0}, - {2, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09, 0xff, 2, 0}, - {2, 1666, 4, 4, 7, 0x0808090B, 0x0C0D0E0A, 0xff, 2, 0}, - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A, 0xff, 2, 0}, - {1, 833, 4, 4, 6, 0x06060607, 0x08080807, 0xff, 2, 0}, - {1, 833, 0, 4, 6, 0x06060607, 0x08080807, 0xff, 2, 0}, - {1, 1350, 4, 4, 7, 0x0708080A, 0x0A0B0C09, 0xff, 2, 0}, - {1, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09, 0xff, 2, 0}, - {1, 1666, 4, 4, 7, 0x0808090B, 0x0C0D0E0A, 0xff, 2, 0}, - {1, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A, 0xff, 2, 0}, +#ifdef CONFIG_SYS_FSL_DDR4 + {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 1666, 0, 4, 6, 0x0708090B, 0x0C0D0E09,}, + {1, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 2200, 0, 4, 7, 0x08090A0D, 0x0F0F100C,}, +#elif defined(CONFIG_SYS_FSL_DDR3) + {2, 833, 0, 4, 6, 0x06060607, 0x08080807,}, + {2, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, + {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, + {1, 833, 0, 4, 6, 0x06060607, 0x08080807,}, + {1, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, + {1, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, +#else +#error DDR type not defined +#endif {} };
diff --git a/boards.cfg b/boards.cfg index 69c8936..849dbc2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -932,6 +932,7 @@ Active powerpc mpc85xx - freescale p2041rdb Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SPIFLASH P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SRIO_PCIE_BOOT P2041RDB:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale t1040qds T1040QDS T1040QDS:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale t1040qds T1040QDS_D4 T1040QDS:PPC_T1040,SYS_FSL_DDR4 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1040RDB T1040RDB:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI T1042RDB_PI:PPC_T1042 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - freescale t208xqds T2080QDS T208xQDS:PPC_T2080 - diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 993f9ae..59cc3fc 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -1,5 +1,5 @@ /* - * Copyright 2013 Freescale Semiconductor, Inc. + * Copyright 2013-2014 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -169,8 +169,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR)
#define CONFIG_DDR_SPD +#ifndef CONFIG_SYS_FSL_DDR4 #define CONFIG_SYS_FSL_DDR3 #define CONFIG_FSL_DDR_INTERACTIVE +#endif
#define CONFIG_SYS_SPD_BUS_NUM 0 #define SPD_EEPROM_ADDRESS 0x51
Applied to u-boot-mpc85xx/master.
York
Mostly reusing DDR3 driver, this patch adds DDR4 SPD handling, register calculation and programming.
York
York Sun
