[PATCH] test/py: net: Add a TFTP put test
Execute tftpput command for uploading files to a server and validate its size & CRC32.
Signed-off-by: Love Kumar love.kumar@amd.com --- test/py/tests/test_net.py | 69 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 69 insertions(+)
diff --git a/test/py/tests/test_net.py b/test/py/tests/test_net.py index cd4b4dc53cbc..f69e3ea2dbba 100644 --- a/test/py/tests/test_net.py +++ b/test/py/tests/test_net.py @@ -6,6 +6,7 @@
import pytest import u_boot_utils +import datetime
""" Note: This test relies on boardenv_* containing configuration values to define @@ -50,6 +51,7 @@ env__net_tftp_readable_file = { 'addr': 0x10000000, 'size': 5058624, 'crc32': 'c2244b26', + 'timeout': 50000, }
# Details regarding a file that may be read from a NFS server. This variable @@ -260,3 +262,70 @@ def test_net_nfs(u_boot_console):
output = u_boot_console.run_command('crc32 %x $filesize' % addr) assert expected_crc in output + +@pytest.mark.buildconfigspec("cmd_crc32") +@pytest.mark.buildconfigspec("cmd_net") +def test_net_tftpput(u_boot_console): + """Test the tftpput command. + A file is downloaded from the TFTP server and then uploaded to the TFTP + server, its size and its CRC32 are validated. + The details of the file to download are provided by the boardenv_* file; + see the comment at the beginning of this file. + """ + + if not net_set_up: + pytest.skip("Network not initialized") + + f = u_boot_console.config.env.get("env__net_tftp_readable_file", None) + if not f: + pytest.skip("No TFTP readable file to read") + + addr = f.get("addr", None) + if not addr: + addr = u_boot_utils.find_ram_base(u_boot_console) + + sz = f.get("size", None) + timeout = f.get("timeout", u_boot_console.p.timeout) + fn = f["fn"] + fnu = "_".join([datetime.datetime.now().strftime("%y%m%d%H%M%S"), fn]) + expected_text = "Bytes transferred = " + if sz: + expected_text += "%d" % sz + + with u_boot_console.temporary_timeout(timeout): + output = u_boot_console.run_command("tftpboot %x %s" % (addr, fn)) + + assert "TIMEOUT" not in output + assert expected_text in output + + expected_tftpb_crc = f.get("crc32", None) + + output = u_boot_console.run_command("crc32 $fileaddr $filesize") + assert expected_tftpb_crc in output + + with u_boot_console.temporary_timeout(timeout): + output = u_boot_console.run_command( + "tftpput $fileaddr $filesize $serverip:%s" % (fnu) + ) + + expected_text = "Bytes transferred = " + if sz: + expected_text += "%d" % sz + addr = addr + sz + assert "TIMEOUT" not in output + assert "Access violation" not in output + assert expected_text in output + + with u_boot_console.temporary_timeout(timeout): + output = u_boot_console.run_command("tftpboot %x %s" % (addr, fnu)) + + expected_text = "Bytes transferred = " + if sz: + expected_text += "%d" % sz + assert "TIMEOUT" not in output + assert expected_text in output + + expected_tftpp_crc = expected_tftpb_crc + + output = u_boot_console.run_command("crc32 $fileaddr $filesize") + assert expected_tftpp_crc in output
- 'timeout': 50000,
- """Test the tftpput command.
- A file is downloaded from the TFTP server and then uploaded to the TFTP
- server, its size and its CRC32 are validated.
- The details of the file to download are provided by the boardenv_* file;
- see the comment at the beginning of this file.
- if not net_set_up:
- f = u_boot_console.config.env.get("env__net_tftp_readable_file", None)
- if not f:
- addr = f.get("addr", None)
- if not addr:
- sz = f.get("size", None)
- timeout = f.get("timeout", u_boot_console.p.timeout)
- fn = f["fn"]
- fnu = "_".join([datetime.datetime.now().strftime("%y%m%d%H%M%S"), fn])
- expected_text = "Bytes transferred = "
- if sz:
- with u_boot_console.temporary_timeout(timeout):
- assert "TIMEOUT" not in output
- assert expected_text in output
- expected_tftpb_crc = f.get("crc32", None)
- output = u_boot_console.run_command("crc32 $fileaddr $filesize")
- assert expected_tftpb_crc in output
- if sz:
addr = addr + sz
- assert "Access violation" not in output
- if sz:
- expected_tftpp_crc = expected_tftpb_crc
- assert expected_tftpp_crc in output
-- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
'timeout': 50000, }
Here should be CMD_TFTPPUT marking.
- if not f:
- if not addr:
- fn = f["fn"]
- if sz:
- if sz:
addr = addr + sz
- if sz:
I pushed this to CI to see if that goes through and I see couple of failures like this.
test/py/tests/test_net.py:409: in test_net_tftpput assert expected_text in output E assert 'Bytes transferred = 5181868' in "smc911x: detected LAN9118 controller\r\r\nsmc911x: phy initialized\r\r\nsmc911x: MAC 52:54:00:12:34:56\r\r\n*** ERROR: `serverip' not set\r\r\nsmc911x: MAC 52:54:00:12:34:56"
_______________________________ test_net_tftpput _______________________________ test/py/tests/test_net.py:417: in test_net_tftpput output = u_boot_console.run_command( test/py/u_boot_console_base.py:269: in run_command raise Exception('Bad pattern found on console: ' + E Exception: Bad pattern found on console: unknown_command
test/py/tests/test_net.py:409: in test_net_tftpput assert expected_text in output E assert 'Bytes transferred = 6096080' in "*** ERROR: `serverip' not set"
M
Love Kumar
Michal Simek
Ramon Fried
