[U-Boot] [PATCH] kirkwood_egiga: updates: fix DRAM mapping and typo
DRAM window mapping uses kirkwood-provided functions instead of global gd as do other drivers--fix this.
Also, fix a typo in a comment
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- drivers/net/kirkwood_egiga.c | 10 ++++++---- 1 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index 932792e..b7374b5 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -38,6 +38,8 @@ #include <asm/arch/kirkwood.h> #include "kirkwood_egiga.h"
+DECLARE_GLOBAL_DATA_PTR; + #define KIRKWOOD_PHY_ADR_REQUEST 0xee #define KWGBE_SMI_REG (((struct kwgbe_registers *)KW_EGIGA0_BASE)->smi)
@@ -245,9 +247,9 @@ static void set_dram_access(struct kwgbe_registers *regs) /* Enable full access */ win_param.access_ctrl = EWIN_ACCESS_FULL; win_param.high_addr = 0; - /* Get bank base */ - win_param.base_addr = kw_sdram_bar(i); - win_param.size = kw_sdram_bs(i); /* Get bank size */ + /* Get bank base and size */ + win_param.base_addr = gd->bd->bi_dram[i].start; + win_param.size = gd->bd->bi_dram[i].size; if (win_param.size == 0) win_param.enable = 0; else @@ -268,7 +270,7 @@ static void set_dram_access(struct kwgbe_registers *regs) win_param.attrib = EBAR_DRAM_CS3; break; default: - /* invalide bank, disable access */ + /* invalid bank, disable access */ win_param.enable = 0; win_param.attrib = 0; break;
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Monday, July 05, 2010 11:45 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH] kirkwood_egiga: updates: fix DRAM mapping and typo
/* Get bank base */
bank size */
if (win_param.size == 0) win_param.enable = 0; elsewin_param.size = gd->bd->bi_dram[i].size;
-- 1.6.4.4
Acked-by: Prafulla Wadaskar prafulla@marvell.com
Regards.. Prafulla . .
Hi Albert,
Signed-off-by: Albert Aribaudalbert.aribaud@free.fr
Applied to net repo.
thanks, Ben
Albert Aribaud
Ben Warren
Prafulla Wadaskar
