[PATCH v2 0/3] cmd: ufetch improvements
Following the recent addition of the "ufetch" command, this patchset improves it in a few ways.
Signed-off-by: J. Neuschäfer j.ne@posteo.net --- Changes in v2: - Address comments and add R-b tags from Caleb - Link to v1: https://lore.kernel.org/r/20241205-ufetch-v1-0-df861318bd49@posteo.net
--- J. Neuschäfer (3): cmd: ufetch: Fix type mismatch on 32-bit cmd: Allow building ufetch without CONFIG_BLK cmd: ufetch: Show CPU architecture under "CPU"
cmd/Kconfig | 1 - cmd/ufetch.c | 17 +++++++++++------ 2 files changed, 11 insertions(+), 7 deletions(-) --- base-commit: a7efabf75cc7a31bc0c9dc8a1509a788ade238bc change-id: 20241203-ufetch-326e771b26ad
On 32-bit architectures, LAST_LINE (_LAST_LINE - 1UL) is 64 bits long, but size_t (from ARRAY_SIZE(...)) is 32 bits. This results in a warning because the max() macro expects the same type on both sides:
cmd/ufetch.c: In function ‘do_ufetch’: include/linux/kernel.h:179:24: warning: comparison of distinct pointer types lacks a cast [-Wcompare-distinct-pointer-types] 179 | (void) (&_max1 == &_max2); \ | ^~ cmd/ufetch.c:92:25: note: in expansion of macro ‘max’ 92 | int num_lines = max(LAST_LINE + 1, ARRAY_SIZE(logo_lines)); | ^~~
Fix this by casting LAST_LINE to size_t.
Reviewed-by: Caleb Connolly caleb.connolly@linaro.org Signed-off-by: J. Neuschäfer j.ne@posteo.net ---
v2: - Add Caleb's R-b --- cmd/ufetch.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/ufetch.c b/cmd/ufetch.c index 0b825d7e8c75f3b18933d3e3f77e5f40f2c7b658..5f3ef847b268dc384271fc6774720e5fd2337157 100644 --- a/cmd/ufetch.c +++ b/cmd/ufetch.c @@ -89,7 +89,7 @@ enum output_lines { static int do_ufetch(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - int num_lines = max(LAST_LINE + 1, ARRAY_SIZE(logo_lines)); + int num_lines = max((size_t)LAST_LINE + 1, ARRAY_SIZE(logo_lines)); const char *model, *compatible; char *ipaddr; int n_cmds, n_cpus = 0, ret, compatlen;
The ufetch command is still quite useful on systems without block device support; remove the CONFIG_BLK dependency and make sure the code compiles/works with and without CONFIG_BLK.
v2: - Add parentheses to avoid having declarations after the "default" label. - Add Caleb's R-b --- cmd/Kconfig | 1 - cmd/ufetch.c | 13 +++++++++---- 2 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4936a70f3ef16ddb093ceafa12d011ca1b89e95c..547fd2a91f7883e2ae5982897ec93c4483d67852 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -178,7 +178,6 @@ config CMD_CPU
config CMD_UFETCH bool "U-Boot fetch" - depends on BLK help Fetch utility for U-Boot (akin to neofetch). Prints information about U-Boot and the board it is running on in a pleasing format. diff --git a/cmd/ufetch.c b/cmd/ufetch.c index 5f3ef847b268dc384271fc6774720e5fd2337157..83cec0f6d5c875f150f7b948392a29803bdbc201 100644 --- a/cmd/ufetch.c +++ b/cmd/ufetch.c @@ -92,11 +92,9 @@ static int do_ufetch(struct cmd_tbl *cmdtp, int flag, int argc, int num_lines = max((size_t)LAST_LINE + 1, ARRAY_SIZE(logo_lines)); const char *model, *compatible; char *ipaddr; - int n_cmds, n_cpus = 0, ret, compatlen; + int n_cmds, n_cpus = 0, compatlen; size_t size; ofnode np; - struct udevice *dev; - struct blk_desc *desc; bool skip_ascii = false;
if (argc > 1 && strcmp(argv[1], "-n") == 0) { @@ -199,7 +197,12 @@ static int do_ufetch(struct cmd_tbl *cmdtp, int flag, int argc, print_size(size, "\n"); break; case STORAGE: - default: + default: { +#ifdef CONFIG_BLK + struct udevice *dev; + struct blk_desc *desc; + int ret; + ret = uclass_find_device_by_seq(UCLASS_BLK, line - STORAGE, &dev); if (!ret && dev) { desc = dev_get_uclass_plat(dev); @@ -213,8 +216,10 @@ static int do_ufetch(struct cmd_tbl *cmdtp, int flag, int argc, } else if (ret == -ENODEV && (skip_ascii || line > ARRAY_SIZE(logo_lines))) { break; } +#endif printf("\n"); } + } }
printf(RESET "\n\n");
When looking at ufetch output it isn't immediately obvious which CPU architecture the presented board has. This patch therefore adds the CPU architecture string (for example "powerpc") to the "CPU:" line. The new format is:
CPU: powerpc (1 cores, 1 in use)
v2: - Reformat the CPU message for readability --- cmd/ufetch.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/ufetch.c b/cmd/ufetch.c index 83cec0f6d5c875f150f7b948392a29803bdbc201..ed5a856c7abbe08949b81e0b2f634edd8b390be5 100644 --- a/cmd/ufetch.c +++ b/cmd/ufetch.c @@ -188,7 +188,7 @@ static int do_ufetch(struct cmd_tbl *cmdtp, int flag, int argc, if (ofnode_name_eq(np, "cpu")) n_cpus++; } - printf("CPU:" RESET " %d (1 in use)\n", n_cpus); + printf("CPU: " RESET CONFIG_SYS_ARCH " (%d cores, 1 in use)\n", n_cpus); break; case MEMORY: for (int j = 0; j < CONFIG_NR_DRAM_BANKS && gd->bd->bi_dram[j].size; j++)
Thanks for re-spinning this!
v2:
case MEMORY: for (int j = 0; j < CONFIG_NR_DRAM_BANKS && gd->bd->bi_dram[j].size; j++)printf("CPU: " RESET CONFIG_SYS_ARCH " (%d cores, 1 in use)\n", n_cpus); break;
Applied, thanks!
[1/3] cmd: ufetch: Fix type mismatch on 32-bit https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/commit/e2883663... [2/3] cmd: Allow building ufetch without CONFIG_BLK https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/commit/c38d5bad... [3/3] cmd: ufetch: Show CPU architecture under "CPU" https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/commit/3db33a6f...
Caleb Connolly
