[PATCH v2 0/6] armv8: fixes and cleanups
revamping this small series, just small changes: - rebasing on top of origin/master, there was a trivial conflict - checking for FEAT_LSE2 before trying unaligned accesses (patch 1/6)
Michael Walle tested the whole of v1 successfully, and the changes should not affect this result. Mark Kettenis tested this on the Apple M1, but patch 1/6 has changed, so I don't dare to carry over his tag. -------------
I was looking into the arm64 boot code lately and stumbled upon some issues. Also Nishanth brought back memories of a lengthy debug session, which was caused due to U-Boot keeping SErrors masked. As the resulting patches are all somewhat related, I gathered this series here to address those problems.
Patches 1 to 3 address exception handling issues, with the SError enablement being the most prominent fix here. Patch 4 cleans up asm/io.h. This was on the list before[1], but was somehow lost when it was intercepted by a shorter version of itself. Patches 5 and 6 clean up some unnecessarily complicated AArch64 assembly code.
I did only some light testing, as some code paths do not apply to boards I have (ARMV8_MULTIENTRY). However v1 was tested by Michael Walle in both EL3 and EL2.
Cheers, Andre
[1] https://lists.denx.de/pipermail/u-boot/2019-January/354296.html
Andre Przywara (6): cmd: exception: arm64: fix undefined, add faults armv8: Always unmask SErrors armv8: Force SP_ELx stack pointer usage arm: Clean up asm/io.h armv8: Simplify switch_el macro armv8: Fix and simplify branch_if_master/branch_if_slave
arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 11 +-- arch/arm/cpu/armv8/start.S | 10 +- arch/arm/include/asm/io.h | 98 +------------------- arch/arm/include/asm/macro.h | 37 +++----- arch/arm/include/asm/system.h | 1 + arch/arm/mach-rmobile/lowlevel_init_gen3.S | 2 +- arch/arm/mach-socfpga/lowlevel_init_soc64.S | 2 +- board/cortina/presidio-asic/lowlevel_init.S | 2 +- cmd/arm/exception64.c | 64 ++++++++++++- 9 files changed, 85 insertions(+), 142 deletions(-)
The arm64 version of the exception command was just defining the undefined exception, but actually copied the AArch32 instruction.
Replace that with an encoding that is guaranteed to be and stay undefined. Also add instructions to trigger unaligned access faults and a breakpoint. This brings ARM64 on par with ARM(32) for the exception command.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- cmd/arm/exception64.c | 64 ++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 60 insertions(+), 4 deletions(-)
diff --git a/cmd/arm/exception64.c b/cmd/arm/exception64.c index d5de50a080..589a23115b 100644 --- a/cmd/arm/exception64.c +++ b/cmd/arm/exception64.c @@ -7,19 +7,73 @@
#include <common.h> #include <command.h> +#include <linux/bitops.h>
static int do_undefined(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { /* - * 0xe7f...f. is undefined in ARM mode - * 0xde.. is undefined in Thumb mode + * Instructions starting with the upper 16 bits all 0 are permanently + * undefined. The lower 16 bits can be used for some kind of immediate. + * --- ARMv8 ARM (ARM DDI 0487G.a C6.2.339: "UDF") */ - asm volatile (".word 0xe7f7defb\n"); + asm volatile (".word 0x00001234\n"); + + return CMD_RET_FAILURE; +} + +/* + * The ID_AA64MMFR2_EL1 register name is only know to binutils for ARMv8.2 + * and later architecture revisions. However the register is valid regardless + * of binutils architecture support or the core the code is running on, so + * just use the generic encoding. + */ +#define ID_AA64MMFR2_EL1 "S3_0_C0_C7_2" + +static int do_unaligned(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + uint64_t reg; + + /* + * The unaligned LDAR access below is only guaranteed to generate an + * alignment fault on cores not implementing FEAT_LSE2. To avoid false + * negatives, check this condition before we exectute LDAR. + */ + asm ("mrs %0, "ID_AA64MMFR2_EL1"\n" : "=r" (reg)); + if (reg & GENMASK(35, 32)) { + printf("unaligned access check only supported on pre-v8.4 cores\n"); + return CMD_RET_FAILURE; + } + + /* + * The load acquire instruction requires the data source to be + * naturally aligned, and will fault even if strict alignment fault + * checking is disabled (but only without FEAT_LSE2). + * --- ARMv8 ARM (ARM DDI 0487G.a B2.5.2: "Alignment of data accesses") + */ + asm volatile ( + "mov x1, sp\n\t" + "orr x1, x1, #3\n\t" + "ldar x0, [x1]\n" + ::: "x0", "x1" ); + + return CMD_RET_FAILURE; +} + +static int do_breakpoint(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + asm volatile ("brk #123\n"); + return CMD_RET_FAILURE; }
static struct cmd_tbl cmd_sub[] = { + U_BOOT_CMD_MKENT(breakpoint, CONFIG_SYS_MAXARGS, 1, do_breakpoint, + "", ""), + U_BOOT_CMD_MKENT(unaligned, CONFIG_SYS_MAXARGS, 1, do_unaligned, + "", ""), U_BOOT_CMD_MKENT(undefined, CONFIG_SYS_MAXARGS, 1, do_undefined, "", ""), }; @@ -27,7 +81,9 @@ static struct cmd_tbl cmd_sub[] = { static char exception_help_text[] = "<ex>\n" " The following exceptions are available:\n" - " undefined - undefined instruction\n" + " breakpoint - breakpoint instruction exception\n" + " unaligned - unaligned LDAR data abort\n" + " undefined - undefined instruction exception\n" ;
#include <exception.h>
The ARMv8 architecture describes the "SError interrupt" as the fourth kind of exception, next to synchronous exceptions, IRQs, and FIQs. Those SErrors signal exceptional conditions from which the system might not easily recover, and are normally generated by the interconnect as a response to some bus error. A typical situation is access to a non-existing memory address or device, but it might be deliberately triggered by a device as well. The SError interrupt replaces the Armv7 asynchronous abort.
Trusted Firmware enters U-Boot (BL33) typically with SErrors masked, and we never enable them. However any SError condition still triggers the SError interrupt, and this condition stays pending, it just won't be handled. If now later on the Linux kernel unmasks the "A" bit in PState, it will immediately take the exception, leading to a kernel crash. This leaves many people scratching their head about the reason for this, and leads to long debug sessions, possibly looking at the wrong places (the kernel, but not U-Boot).
To avoid the situation, just unmask SErrors early in the ARMv8 boot process, so that the U-Boot exception handlers reports them in a timely manner. As SErrors are typically asynchronous, the register dump does not need to point at the actual culprit, but it should happen very shortly after the condition.
For those exceptions to be taken, we also need to route them to EL2, if U-Boot is running in this exception level.
This removes the respective code snippet from the Freescale lowlevel routine, as this is now handled in generic ARMv8 code.
Reported-by: Nishanth Menon nm@ti.com Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 9 --------- arch/arm/cpu/armv8/start.S | 3 +++ arch/arm/include/asm/system.h | 1 + 3 files changed, 4 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 3aa1a9c3e5..0929c58d43 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -74,15 +74,6 @@ ENDPROC(smp_kick_all_cpus) ENTRY(lowlevel_init) mov x29, lr /* Save LR */
- /* unmask SError and abort */ - msr daifclr, #4 - - /* Set HCR_EL2[AMO] so SError @EL2 is taken */ - mrs x0, hcr_el2 - orr x0, x0, #0x20 /* AMO */ - msr hcr_el2, x0 - isb - switch_el x1, 1f, 100f, 100f /* skip if not in EL3 */ 1:
diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 91b00a46cc..d9610a5ea0 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -126,6 +126,8 @@ pie_fixup_done: b 0f 2: mrs x1, hcr_el2 tbnz x1, #34, 1f /* HCR_EL2.E2H */ + orr x1, x1, #HCR_EL2_AMO_EL2 /* Route SErrors to EL2 */ + msr hcr_el2, x1 set_vbar vbar_el2, x0 mov x0, #0x33ff msr cptr_el2, x0 /* Enable FP/SIMD */ @@ -134,6 +136,7 @@ pie_fixup_done: mov x0, #3 << 20 msr cpacr_el1, x0 /* Enable FP/SIMD */ 0: + msr daifclr, #0x4 /* Unmask SError interrupts */
#ifdef COUNTER_FREQUENCY branch_if_not_highest_el x0, 4f diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index f75eea16b3..87d1c77e8b 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -82,6 +82,7 @@ #define HCR_EL2_RW_AARCH64 (1 << 31) /* EL1 is AArch64 */ #define HCR_EL2_RW_AARCH32 (0 << 31) /* Lower levels are AArch32 */ #define HCR_EL2_HCD_DIS (1 << 29) /* Hypervisor Call disabled */ +#define HCR_EL2_AMO_EL2 (1 << 5) /* Route SErrors to EL2 */
/* * ID_AA64ISAR1_EL1 bits definitions
In ARMv8 we have the choice between two stack pointers to use: SP_EL0 or SP_ELx, which is banked per exception level. This choice is stored in the SP field of PState, and can be read and set via the SPSel special register. When the CPU takes an exception, it automatically switches to the SP_ELx stack pointer.
Trusted Firmware enters U-Boot typically with SPSel set to 1, so we use SP_ELx all along as our sole stack pointer, both for normal operation and for exceptions.
But if we now for some reason enter U-Boot with SPSel cleared, we will setup and use SP_EL0, which is fine, but leaves SP_ELx uninitialised. When we now take an exception, we try to save the GPRs to some undefined location, which will usually end badly.
To make sure we always have SP_ELx pointing to some memory, set SPSel to 1 in the early boot code, to ensure safe operation at all times.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/cpu/armv8/start.S | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index d9610a5ea0..e1461f2319 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -192,6 +192,7 @@ slave_cpu: br x0 /* branch to the given address */ #endif /* CONFIG_ARMV8_MULTIENTRY */ master_cpu: + msr SPSel, #1 /* make sure we use SP_ELx */ bl _main
asm/io.h is the header file containing the central MMIO accessor macros. Judging by the header and the comments, it was apparently once copied from the Linux kernel, but has deviated since then *heavily*. There is absolutely no point in staying close to the original Linux code anymore, so just remove the old cruft, by: - removing pointless Linux history - removing commented code - removing outdated comments - removing unused definitions (for mem_isa)
This massively improves the readability of the file.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/io.h | 98 +-------------------------------------- 1 file changed, 2 insertions(+), 96 deletions(-)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 36b840378a..89b1015bc4 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -1,45 +1,26 @@ /* - * linux/include/asm-arm/io.h + * I/O device access primitives. Based on early versions from the Linux kernel. * * Copyright (C) 1996-2000 Russell King * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. - * - * Modifications: - * 16-Sep-1996 RMK Inlined the inx/outx functions & optimised for both - * constant addresses and variable addresses. - * 04-Dec-1997 RMK Moved a lot of this stuff to the new architecture - * specific IO header files. - * 27-Mar-1999 PJB Second parameter of memcpy_toio is const.. - * 04-Apr-1999 PJB Added check_signature. - * 12-Dec-1999 RMK More cleanups - * 18-Jun-2000 RMK Removed virt_to_* and friends definitions */ #ifndef __ASM_ARM_IO_H #define __ASM_ARM_IO_H
-#ifdef __KERNEL__ - #include <linux/types.h> #include <linux/kernel.h> #include <asm/byteorder.h> #include <asm/memory.h> #include <asm/barriers.h> -#if 0 /* XXX###XXX */ -#include <asm/arch/hardware.h> -#endif /* XXX###XXX */
static inline void sync(void) { }
-/* - * Generic virtual read/write. Note that we don't support half-word - * read/writes. We define __arch_*[bl] here, and leave __arch_*w - * to the architecture specific code. - */ +/* Generic virtual read/write. */ #define __arch_getb(a) (*(volatile unsigned char *)(a)) #define __arch_getw(a) (*(volatile unsigned short *)(a)) #define __arch_getl(a) (*(volatile unsigned int *)(a)) @@ -247,13 +228,6 @@ static inline void __raw_readsl(unsigned long addr, void *data, int longlen) #define setbits_64(addr, set) setbits(64, addr, set) #define clrsetbits_64(addr, clear, set) clrsetbits(64, addr, clear, set)
-/* - * Now, pick up the machine-defined IO definitions - */ -#if 0 /* XXX###XXX */ -#include <asm/arch/io.h> -#endif /* XXX###XXX */ - /* * IO port access primitives * ------------------------- @@ -317,16 +291,6 @@ static inline void __raw_readsl(unsigned long addr, void *data, int longlen) #define writesb(a, d, s) __raw_writesb((unsigned long)a, d, s) #define readsb(a, d, s) __raw_readsb((unsigned long)a, d, s)
-/* - * DMA-consistent mapping functions. These allocate/free a region of - * uncached, unwrite-buffered mapped memory space for use with DMA - * devices. This is the "generic" version. The PCI specific version - * is in pci.h - */ -extern void *consistent_alloc(int gfp, size_t size, dma_addr_t *handle); -extern void consistent_free(void *vaddr, size_t size, dma_addr_t handle); -extern void consistent_sync(void *vaddr, size_t size, int rw); - /* * String version of IO memory access ops: */ @@ -334,8 +298,6 @@ extern void _memcpy_fromio(void *, unsigned long, size_t); extern void _memcpy_toio(unsigned long, const void *, size_t); extern void _memset_io(unsigned long, int, size_t);
-extern void __readwrite_bug(const char *fn); - /* Optimized copy functions to read from/write to IO sapce */ #ifdef CONFIG_ARM64 #include <cpu_func.h> @@ -441,62 +403,6 @@ void __memset_io(volatile void __iomem *dst, int c, size_t count) #define memcpy_toio(a, b, c) memcpy((void *)(a), (b), (c)) #endif
-/* - * If this architecture has ISA IO, then define the isa_read/isa_write - * macros. - */ -#ifdef __mem_isa - -#define isa_readb(addr) __raw_readb(__mem_isa(addr)) -#define isa_readw(addr) __raw_readw(__mem_isa(addr)) -#define isa_readl(addr) __raw_readl(__mem_isa(addr)) -#define isa_writeb(val,addr) __raw_writeb(val,__mem_isa(addr)) -#define isa_writew(val,addr) __raw_writew(val,__mem_isa(addr)) -#define isa_writel(val,addr) __raw_writel(val,__mem_isa(addr)) -#define isa_memset_io(a,b,c) _memset_io(__mem_isa(a),(b),(c)) -#define isa_memcpy_fromio(a,b,c) _memcpy_fromio((a),__mem_isa(b),(c)) -#define isa_memcpy_toio(a,b,c) _memcpy_toio(__mem_isa((a)),(b),(c)) - -#define isa_eth_io_copy_and_sum(a,b,c,d) \ - eth_copy_and_sum((a),__mem_isa(b),(c),(d)) - -static inline int -isa_check_signature(unsigned long io_addr, const unsigned char *signature, - int length) -{ - int retval = 0; - do { - if (isa_readb(io_addr) != *signature) - goto out; - io_addr++; - signature++; - length--; - } while (length); - retval = 1; -out: - return retval; -} - -#else /* __mem_isa */ - -#define isa_readb(addr) (__readwrite_bug("isa_readb"),0) -#define isa_readw(addr) (__readwrite_bug("isa_readw"),0) -#define isa_readl(addr) (__readwrite_bug("isa_readl"),0) -#define isa_writeb(val,addr) __readwrite_bug("isa_writeb") -#define isa_writew(val,addr) __readwrite_bug("isa_writew") -#define isa_writel(val,addr) __readwrite_bug("isa_writel") -#define isa_memset_io(a,b,c) __readwrite_bug("isa_memset_io") -#define isa_memcpy_fromio(a,b,c) __readwrite_bug("isa_memcpy_fromio") -#define isa_memcpy_toio(a,b,c) __readwrite_bug("isa_memcpy_toio") - -#define isa_eth_io_copy_and_sum(a,b,c,d) \ - __readwrite_bug("isa_eth_io_copy_and_sum") - -#define isa_check_signature(io,sig,len) (0) - -#endif /* __mem_isa */ -#endif /* __KERNEL__ */ - #include <asm-generic/io.h> #include <iotrace.h>
The switch_el macro is a neat contraption to handle cases where we need different code depending on the current exception level, but its implementation was longer than needed.
Simplify it by doing just one comparison, then using the different condition codes to branch to the desired target. PState.CurrentEL just holds two bits, and since we don't care about EL0, we can use >, =, < to select EL3, EL2 and EL1, respectively.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/macro.h | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index ec0171e0e6..acd519020d 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -69,12 +69,10 @@ lr .req x30 */ .macro switch_el, xreg, el3_label, el2_label, el1_label mrs \xreg, CurrentEL - cmp \xreg, 0xc - b.eq \el3_label - cmp \xreg, 0x8 + cmp \xreg, #0x8 + b.gt \el3_label b.eq \el2_label - cmp \xreg, 0x4 - b.eq \el1_label + b.lt \el1_label .endm
The branch_if_master macro jumps to a label if the CPU is the "master" core, which we define as having all affinity levels set to 0. To check for this condition, we need to mask off some bits from the MPIDR register, then compare the remaining register value against zero.
The implementation of this was slighly broken (it preserved the upper RES0 bits), overly complicated and hard to understand, especially since it lacked comments. The same was true for the very similar branch_if_slave macro.
Use a much shorter assembly sequence for those checks, use the same masking for both macros (just negate the final branch), and put some comments on them, to make it clear what the code does. This allows to drop the second temporary register for branch_if_master, so we adjust all call sites as well.
Also use the opportunity to remove a misleading comment: the macro works fine on SoCs with multiple clusters. Judging by the commit message, the original problem with the Juno SoC stems from the fact that the master CPU *can* be configured to be from cluster 1, so the assumption that the master CPU has all affinity values set to 0 does not hold there. But this is already mentioned above in a comment, so remove the extra comment.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 2 +- arch/arm/cpu/armv8/start.S | 6 ++-- arch/arm/include/asm/macro.h | 29 ++++++-------------- arch/arm/mach-rmobile/lowlevel_init_gen3.S | 2 +- arch/arm/mach-socfpga/lowlevel_init_soc64.S | 2 +- board/cortina/presidio-asic/lowlevel_init.S | 2 +- 6 files changed, 15 insertions(+), 28 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 0929c58d43..2fb4e404a2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -200,7 +200,7 @@ ENTRY(lowlevel_init) #endif
100: - branch_if_master x0, x1, 2f + branch_if_master x0, 2f
#if defined(CONFIG_MP) && defined(CONFIG_ARMV8_MULTIENTRY) /* diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index e1461f2319..6a6a4f8650 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -175,11 +175,11 @@ pie_fixup_done: bl lowlevel_init
#if defined(CONFIG_ARMV8_SPIN_TABLE) && !defined(CONFIG_SPL_BUILD) - branch_if_master x0, x1, master_cpu + branch_if_master x0, master_cpu b spin_table_secondary_jump /* never return */ #elif defined(CONFIG_ARMV8_MULTIENTRY) - branch_if_master x0, x1, master_cpu + branch_if_master x0, master_cpu
/* * Slave CPUs @@ -305,7 +305,7 @@ WEAK(lowlevel_init) #endif
#ifdef CONFIG_ARMV8_MULTIENTRY - branch_if_master x0, x1, 2f + branch_if_master x0, 2f
/* * Slave should wait for master clearing spin table. diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index acd519020d..1a1edc9870 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -121,19 +121,10 @@ lr .req x30 */ .macro branch_if_slave, xreg, slave_label #ifdef CONFIG_ARMV8_MULTIENTRY - /* NOTE: MPIDR handling will be erroneous on multi-cluster machines */ mrs \xreg, mpidr_el1 - tst \xreg, #0xff /* Test Affinity 0 */ - b.ne \slave_label - lsr \xreg, \xreg, #8 - tst \xreg, #0xff /* Test Affinity 1 */ - b.ne \slave_label - lsr \xreg, \xreg, #8 - tst \xreg, #0xff /* Test Affinity 2 */ - b.ne \slave_label - lsr \xreg, \xreg, #16 - tst \xreg, #0xff /* Test Affinity 3 */ - b.ne \slave_label + and \xreg, \xreg, 0xffffffffff /* clear bits [63:40] */ + and \xreg, \xreg, ~0x00ff000000 /* also clear bits [31:24] */ + cbnz \xreg, \slave_label #endif .endm
@@ -141,16 +132,12 @@ lr .req x30 * Branch if current processor is a master, * choose processor with all zero affinity value as the master. */ -.macro branch_if_master, xreg1, xreg2, master_label +.macro branch_if_master, xreg, master_label #ifdef CONFIG_ARMV8_MULTIENTRY - /* NOTE: MPIDR handling will be erroneous on multi-cluster machines */ - mrs \xreg1, mpidr_el1 - lsr \xreg2, \xreg1, #32 - lsl \xreg2, \xreg2, #32 - lsl \xreg1, \xreg1, #40 - lsr \xreg1, \xreg1, #40 - orr \xreg1, \xreg1, \xreg2 - cbz \xreg1, \master_label + mrs \xreg, mpidr_el1 + and \xreg, \xreg, 0xffffffffff /* clear bits [63:40] */ + and \xreg, \xreg, ~0x00ff000000 /* also clear bits [31:24] */ + cbz \xreg, \master_label #else b \master_label #endif diff --git a/arch/arm/mach-rmobile/lowlevel_init_gen3.S b/arch/arm/mach-rmobile/lowlevel_init_gen3.S index 1df2c40345..0d7780031a 100644 --- a/arch/arm/mach-rmobile/lowlevel_init_gen3.S +++ b/arch/arm/mach-rmobile/lowlevel_init_gen3.S @@ -64,7 +64,7 @@ ENTRY(lowlevel_init) #endif #endif
/* * Slave should wait for master clearing spin table. diff --git a/arch/arm/mach-socfpga/lowlevel_init_soc64.S b/arch/arm/mach-socfpga/lowlevel_init_soc64.S index 612ea8a037..875927cc4d 100644 --- a/arch/arm/mach-socfpga/lowlevel_init_soc64.S +++ b/arch/arm/mach-socfpga/lowlevel_init_soc64.S @@ -38,7 +38,7 @@ slave_wait_atf: #endif
/* * Slave should wait for master clearing spin table. diff --git a/board/cortina/presidio-asic/lowlevel_init.S b/board/cortina/presidio-asic/lowlevel_init.S index 4450a5df79..cbf8134346 100644 --- a/board/cortina/presidio-asic/lowlevel_init.S +++ b/board/cortina/presidio-asic/lowlevel_init.S @@ -50,7 +50,7 @@ skip_smp_setup: #endif
Andre Przywara
