[U-Boot] [PATCH] dm: usb: gadget: Fix boot breakage on sunxi platforms
Fixes commit 013116243950 ("dm: usb: create a new UCLASS ID for USB gadget devices")
The UCLASS_DRIVER for id UCLASS_USB_GADGET_GENERIC needs to be declared even for platforms that do not enable DM_USB_GADGET. Otherwise the driver for their usb peripheral controller fails to bind.
Reported-by: Priit Laes plaes@plaes.org Reported-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Tested-by: Priit Laes plaes@plaes.org
build status available here: https://travis-ci.org/jjhiblot/u-boot/builds/470396811
drivers/usb/gadget/udc/Makefile | 3 ++- drivers/usb/gadget/udc/udc-uclass.c | 2 ++ 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/udc/Makefile b/drivers/usb/gadget/udc/Makefile index 38ac2dd..95dbf0c 100644 --- a/drivers/usb/gadget/udc/Makefile +++ b/drivers/usb/gadget/udc/Makefile @@ -6,4 +6,5 @@ ifndef CONFIG_$(SPL_)DM_USB_GADGET obj-$(CONFIG_USB_DWC3_GADGET) += udc-core.o endif
-obj-$(CONFIG_$(SPL_)DM_USB_GADGET) += udc-uclass.o udc-core.o +obj-$(CONFIG_$(SPL_)DM_USB_GADGET) += udc-core.o +obj-$(CONFIG_$(SPL_)DM) += udc-uclass.o diff --git a/drivers/usb/gadget/udc/udc-uclass.c b/drivers/usb/gadget/udc/udc-uclass.c index e9f8f5f..8d78647 100644 --- a/drivers/usb/gadget/udc/udc-uclass.c +++ b/drivers/usb/gadget/udc/udc-uclass.c @@ -9,6 +9,7 @@ #include <dm/device-internal.h> #include <linux/usb/gadget.h>
+#if CONFIG_IS_ENABLED(DM_USB_GADGET) #define MAX_UDC_DEVICES 4 static struct udevice *dev_array[MAX_UDC_DEVICES]; int usb_gadget_initialize(int index) @@ -51,6 +52,7 @@ int usb_gadget_handle_interrupts(int index) return -EINVAL; return dm_usb_gadget_handle_interrupts(dev_array[index]); } +#endif
UCLASS_DRIVER(usb_gadget_generic) = { .id = UCLASS_USB_GADGET_GENERIC,
On Fri, Dec 21, 2018 at 2:20 PM Jean-Jacques Hiblot jjhiblot@ti.com wrote:
Better to have proper commit head that tells the real issue.
Sorry this is unclear, you are trying to skip DM_USB_GADGET code even though UCLASS_USB_GADGET_GENERIC id used. does it make sense?
Any response on this?
We need the fix asap since the release is about a week.
I suspect most people are having xmas vacation, so pushing hard won't help. It seems you had some comment on the patch, so I expect a reply from Jean and possibly a V2.
On Fri, Dec 21, 2018 at 2:20 PM Jean-Jacques Hiblot jjhiblot@ti.com wrote: Better to have proper commit head that tells the real issue.
I found it hard to come up with a short description of the real issue.
At least this title makes it clear that it is a regression fix, not a new feature.
The details of the failures are in the commit log (or so I thought)
Sorry for the delay. This was indeed a vacation time.
This patch does not skip DM_USB_GADGET. What it does is declare the UCLASS_DRIVER for USB peripheral devices even if DM_USB_GADGET is not set.
DM_USB_GADGET is a new option and not (yet) widely used and some drivers have their own version of the DM support for gadget drivers (ie they implement their own version of usb_gadget_initialize(), usb_gadget_release() and usb_gadget_handle_interrupts()). However all those drivers use the UCLASS_USB_GADGET_GENERIC uclass ID and thus the UCLASS_DRIVER for UCLASS_USB_GADGET_GENERIC must be declared. In the past they used UCLASS_USB_DEV_GENERIC, but this option is intended for the host side.
JJ
Thanks for a detailed explanation. Would you prepare v2 soon?
JJ
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Honestly I don't know what i would change in a v2.
JJ
Lukasz Majewski
Acked-by: Jagan Teki jagan@openedev.com
Marek, any comments?
Hi Jagan,
Yes, lets wait for Marek's comment and I will prepare PR (to Marek), which also includes some other fixes.
Lukasz Majewski
On 1/3/19 7:59 AM, Lukasz Majewski wrote:
Hi Jagan,
Comment on what ? What do you need from me here ?
This is gadget code, which is not something I monitor closely.
On Thu, Jan 3, 2019 at 12:29 PM Lukasz Majewski lukma@denx.de wrote:
Hi Jagan,
Please don't miss this, sunxi need this fix.
Hi Jagan,
> Fixes commit 013116243950 ("dm: usb: create a new UCLASS ID for > USB gadget devices") > > The UCLASS_DRIVER for id UCLASS_USB_GADGET_GENERIC needs to be > declared even for platforms that do not enable DM_USB_GADGET. > Otherwise the driver for their usb peripheral controller fails > to bind. Sorry this is unclear, you are trying to skip DM_USB_GADGET code even though UCLASS_USB_GADGET_GENERIC id used. does it make sense?
Absolutely, I have nothing else to do but to monitor this one single patch. Thanks for the pressure, it really helps.
On Fri, 4 Jan 2019 01:23:17 +0530 Jagan Teki jagan@amarulasolutions.com wrote:
Hi Jagan,
> Fixes commit 013116243950 ("dm: usb: create a new UCLASS ID > for USB gadget devices") > > The UCLASS_DRIVER for id UCLASS_USB_GADGET_GENERIC needs to > be declared even for platforms that do not enable > DM_USB_GADGET. Otherwise the driver for their usb > peripheral controller fails to bind. Sorry this is unclear, you are trying to skip DM_USB_GADGET code even though UCLASS_USB_GADGET_GENERIC id used. does it make sense?
I'm now running build tests on this and Sam's patches. I will prepare PR and send it to Marek or Tom (if Marek is overloaded).
Lukasz Majewski
Hi Jagan,
On Mon, Dec 24, 2018 at 3:44 AM Jagan Teki jagan@amarulasolutions.com wrote: > On Fri, Dec 21, 2018 at 2:20 PM Jean-Jacques Hiblot > jjhiblot@ti.com wrote: Better to have proper commit head > that tells the real issue.
> >> Fixes commit 013116243950 ("dm: usb: create a new UCLASS ID >> for USB gadget devices") >> >> The UCLASS_DRIVER for id UCLASS_USB_GADGET_GENERIC needs to >> be declared even for platforms that do not enable >> DM_USB_GADGET. Otherwise the driver for their usb >> peripheral controller fails to bind. > Sorry this is unclear, you are trying to skip DM_USB_GADGET > code even though UCLASS_USB_GADGET_GENERIC id used. does it > make sense?
It is still unclear what you wanted me to comment on.
And you know where to send the PR - u-boot-usb.
Jagan Teki
Jean-Jacques Hiblot
Lukasz Majewski
