[U-Boot] [PATCH 1/4] rockchip: dts: rk3399: Sync rk3399-opp from Linux
Sync rk3399-opp.dtsi from Linux.
Linux commit details about the rk3399-opp.dtsi sync: "arm64: dts: rockchip: use SPDX-License-Identifier" (sha1: 4ee99cebd486238ac433da823b95cc5f8d8a6905)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-opp.dtsi | 133 +++++++++++++++++++++++++++++++++++ 1 file changed, 133 insertions(+) create mode 100644 arch/arm/dts/rk3399-opp.dtsi
diff --git a/arch/arm/dts/rk3399-opp.dtsi b/arch/arm/dts/rk3399-opp.dtsi new file mode 100644 index 0000000000..d6f1095abb --- /dev/null +++ b/arch/arm/dts/rk3399-opp.dtsi @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd + */ + +/ { + cluster0_opp: opp-table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp00 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <800000>; + clock-latency-ns = <40000>; + }; + opp01 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <800000>; + }; + opp02 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <850000>; + }; + opp03 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <925000>; + }; + opp04 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1000000>; + }; + opp05 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1125000>; + }; + }; + + cluster1_opp: opp-table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp00 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <800000>; + clock-latency-ns = <40000>; + }; + opp01 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <800000>; + }; + opp02 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <825000>; + }; + opp03 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <875000>; + }; + opp04 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <950000>; + }; + opp05 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1025000>; + }; + opp06 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <1100000>; + }; + opp07 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1200000>; + }; + }; + + gpu_opp_table: opp-table2 { + compatible = "operating-points-v2"; + + opp00 { + opp-hz = /bits/ 64 <200000000>; + opp-microvolt = <800000>; + }; + opp01 { + opp-hz = /bits/ 64 <297000000>; + opp-microvolt = <800000>; + }; + opp02 { + opp-hz = /bits/ 64 <400000000>; + opp-microvolt = <825000>; + }; + opp03 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <875000>; + }; + opp04 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <925000>; + }; + opp05 { + opp-hz = /bits/ 64 <800000000>; + opp-microvolt = <1100000>; + }; + }; +}; + +&cpu_l0 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l1 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l2 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_l3 { + operating-points-v2 = <&cluster0_opp>; +}; + +&cpu_b0 { + operating-points-v2 = <&cluster1_opp>; +}; + +&cpu_b1 { + operating-points-v2 = <&cluster1_opp>; +}; + +&gpu { + operating-points-v2 = <&gpu_opp_table>; +};
u-boot,dm-pre-reloc is required for SDMMC booted rk3399 boards and which is U-Boot specific devicetrees binding.
Move it on global rk3399-u-boot.dtsi file and rest of the U-Boot bindings will move it future based on the requirement.
This would help to sync the devicetrees from Linux whenever required instead of adding specific nodes.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-evb.dts | 1 - arch/arm/dts/rk3399-firefly.dts | 1 - arch/arm/dts/rk3399-puma.dtsi | 1 - arch/arm/dts/rk3399-u-boot.dtsi | 8 ++++++++ 4 files changed, 8 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/rk3399-u-boot.dtsi
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index ce004d0d18..9162f3dd50 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -155,7 +155,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; status = "okay"; }; diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index f90e7e88db..46f2ffaf8d 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -592,7 +592,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; status = "okay"; }; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 8304f67192..9049694243 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -492,7 +492,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; clock-frequency = <150000000>; max-frequency = <40000000>; supports-sd; diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi new file mode 100644 index 0000000000..f533ed95eb --- /dev/null +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +&sdmmc { + u-boot,dm-pre-reloc; +};
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Hi Philipp,
On Mon, Apr 22, 2019 at 12:11 AM Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
I have v2 version for these changes, [1] please have a look, thanks!
Add initial support for Orangepi RK3399 board.
Specification - Rockchip RK3399 - 2GB/4GB DDR3 - 16GB eMMC - SD card slot - RTL8211E 1Gbps - AP6356S WiFI/BT - HDMI In/Out, DP, MIPI DSI/CSI - Mini PCIe - Sensors, Keys etc - DC12V-2A and DC5V-2A
Commit details about Linux DTS sync: "arm64: dts: rockchip: Add support for the Orange Pi RK3399" (sha1: d3e71487a790979057c0fdbf32f85033639c16e6)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-orangepi-u-boot.dtsi | 7 + arch/arm/dts/rk3399-orangepi.dts | 771 +++++++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 7 + configs/orangepi-rk3399_defconfig | 75 +++ 5 files changed, 861 insertions(+) create mode 100644 arch/arm/dts/rk3399-orangepi-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-orangepi.dts create mode 100644 configs/orangepi-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 876c032d11..9033586edc 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -50,6 +50,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3368-px5-evb.dtb \ rk3399-evb.dtb \ rk3399-firefly.dtb \ + rk3399-orangepi.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \ diff --git a/arch/arm/dts/rk3399-orangepi-u-boot.dtsi b/arch/arm/dts/rk3399-orangepi-u-boot.dtsi new file mode 100644 index 0000000000..236b61d78d --- /dev/null +++ b/arch/arm/dts/rk3399-orangepi-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-ddr3-1333.dtsi" diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts new file mode 100644 index 0000000000..cf37b96a6b --- /dev/null +++ b/arch/arm/dts/rk3399-orangepi.dts @@ -0,0 +1,771 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. + */ + +/dts-v1/; + +#include "dt-bindings/pwm/pwm.h" +#include "dt-bindings/input/input.h" +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + model = "Orange Pi RK3399 Board"; + compatible = "rockchip,rk3399-orangepi", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + button-up { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + press-threshold-microvolt = <100000>; + }; + + button-down { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + press-threshold-microvolt = <300000>; + }; + + back { + label = "Back"; + linux,code = <KEY_BACK>; + press-threshold-microvolt = <985000>; + }; + + menu { + label = "Menu"; + linux,code = <KEY_MENU>; + press-threshold-microvolt = <1314000>; + }; + }; + + dc_12v: dc-12v { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + keys: gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + power { + debounce-interval = <100>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Power"; + linux,code = <KEY_POWER>; + linux,input-type = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_btn>; + wakeup-source; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_reg_on_h>; + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + /* switched by pmic_sleep */ + vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8>; + }; + + vcc3v0_sd: vcc3v0-sd { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_pwr_h>; + regulator-boot-on; + regulator-max-microvolt = <3000000>; + regulator-min-microvolt = <3000000>; + regulator-name = "vcc3v0_sd"; + vin-supply = <&vcc3v3_sys>; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_sys>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc5v0_typec0: vcc5v0-typec0-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_typec0_en>; + regulator-name = "vcc5v0_typec0"; + vin-supply = <&vcc_sys>; + }; + + vcc_sys: vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + vin-supply = <&vcc_sys>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc3v3_s3>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + status = "okay"; +}; + +&hdmi_sound { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rtc_clko_soc", "rtc_clko_wifi"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + vcc10-supply = <&vcc3v3_sys>; + vcc11-supply = <&vcc3v3_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_3v0>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v0_tp: LDO_REG2 { + regulator-name = "vcc3v0_tp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmupll: LDO_REG3 { + regulator-name = "vcc1v8_pmupll"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <2500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <2500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-name = "vcca1v8_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <2500000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3400000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c1 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; + + ak09911@c { + compatible = "asahi-kasei,ak09911"; + reg = <0x0c>; + vdd-supply = <&vcc3v3_s3>; + }; + + mpu6500@68 { + compatible = "invensense,mpu6500"; + reg = <0x68>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PC6 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&gsensor_int_l>; + vddio-supply = <&vcc3v3_s3>; + }; + + lsm6ds3@6a { + compatible = "st,lsm6ds3"; + reg = <0x6a>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PD0 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&gyr_int_l>; + vdd-supply = <&vcc3v3_s3>; + vddio-supply = <&vcc3v3_s3>; + }; + + cm32181@10 { + compatible = "capella,cm32181"; + reg = <0x10>; + interrupt-parent = <&gpio4>; + interrupts = <RK_PD0 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&light_int_l>; + vdd-supply = <&vcc3v3_s3>; + }; +}; + +&io_domains { + status = "okay"; + bt656-supply = <&vcc_3v0>; + audio-supply = <&vcca1v8_codec>; + sdmmc-supply = <&vcc_sdio>; + gpio1830-supply = <&vcc_3v0>; +}; + +&pmu_io_domains { + status = "okay"; + pmu1830-supply = <&vcc_3v0>; +}; + +&pinctrl { + buttons { + pwr_btn: pwr-btn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sd { + sdmmc0_pwr_h: sdmmc0-pwr-h { + rockchip,pins = + <RK_GPIO0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb2 { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = + <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + vcc5v0_typec0_en: vcc5v0-typec0-en { + rockchip,pins = + <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio-pwrseq { + wifi_reg_on_h: wifi-reg-on-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + wifi { + wifi_host_wake_l: wifi-host-wake-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + bluetooth { + bt_reg_on_h: bt-enable-h { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_l: bt-wake-l { + rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + mpu6500 { + gsensor_int_l: gsensor-int-l { + rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + lsm6ds3 { + gyr_int_l: gyr-int-l { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + cm32181 { + light_int_l: light-int-l { + rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca1v8_s3>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + clock-frequency = <50000000>; + disable-wp; + keep-power-in-suspend; + max-frequency = <50000000>; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; + sd-uhs-sdr104; + status = "okay"; + + brcmf: wifi@1 { + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 GPIO_ACTIVE_HIGH>; + interrupt-names = "host-wake"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_host_wake_l>; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + clock-frequency = <150000000>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + vmmc-supply = <&vcc3v0_sd>; + vqmmc-supply = <&vcc_sdio>; + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&tcphy1 { + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + phy-supply = <&vcc5v0_typec0>; + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_reg_on_h>; + }; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + status = "okay"; + dr_mode = "otg"; +}; + +&usbdrd3_1 { + status = "okay"; +}; + +&usbdrd_dwc3_1 { + status = "okay"; + dr_mode = "host"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index caad30641e..07ee8ce92c 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -5,3 +5,10 @@ F: board/rockchip/evb_rk3399 F: include/configs/evb_rk3399.h F: configs/evb-rk3399_defconfig F: configs/firefly-rk3399_defconfig + +ORANGEPI-RK3399 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/orangepi-rk3399_defconfig +F: arch/arm/dts/rk3399-u-boot.dtsi +F: arch/arm/dts/rk3399-orangepi-u-boot.dtsi diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig new file mode 100644 index 0000000000..cdccf221b5 --- /dev/null +++ b/configs/orangepi-rk3399_defconfig @@ -0,0 +1,75 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-orangepi.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-orangepi" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Specification
- Rockchip RK3399
- 2GB/4GB DDR3
- 16GB eMMC
- SD card slot
- RTL8211E 1Gbps
- AP6356S WiFI/BT
- Mini PCIe
- Sensors, Keys etc
Since rockchip have an individual doc/README.rockchip, it would be better to update the same instead of maintaining it separately in board files.
So, add the documentation for rk3399 - procedure to build - procedure to boot from SD
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- doc/README.rockchip | 69 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 69 insertions(+)
diff --git a/doc/README.rockchip b/doc/README.rockchip index ec10ebbc26..b8d693bbc9 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -88,8 +88,36 @@ One RV3188 baord is supported:
For example:
+1. To build RK3288 board: + CROSS_COMPILE=arm-linux-gnueabi- make O=firefly firefly-rk3288_defconfig all
+2. To build RK3399 board: + + (export cross compiler path for aarch64) + + 2.1 Compile ATF + + $ git clone https://github.com/ARM-software/arm-trusted-firmware.git + $ cd arm-trusted-firmware + + (export cross compiler path for Cortex-M0 MCU likely arm-none-eabi-) + $ make realclean + $ make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 + + (copy bl31.elf U-Boot root dir) + $ cp build/rk3399/release/bl31/bl31.elf /path/to/u-boot + + 2.2 Compile U-Boot + + $ cd /path/to/u-boot + $ make orangepi-rk3399_defconfig + $ make + $ make u-boot.itb + + (Get spl/u-boot-spl-dtb.bin, u-boot.itb images and some boards would get + spl/u-boot-spl.bin since it doesn't enable CONFIG_SPL_OF_CONTROL) + (or you can use another cross compiler if you prefer)
@@ -225,6 +253,45 @@ tools/mkimage -n rk3188 -T rksd -d spl/u-boot-spl.bin out truncate -s %2048 u-boot.bin cat u-boot.bin | split -b 512 --filter='openssl rc4 -K 7C4E0304550509072D2C7B38170D1711' >> out
+Booting from an SD card on RK3399 +================================= + +To write an image that boots from an SD card (assumed to be /dev/sdc): + +1. Prefix rk3399 header to SPL image + + $ cd /path/to/u-boot + $ ./tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl-dtb.bin out + +2. Write prefixed SPL at 64th sector + + $ sudo dd if=out of=/dev/sdc seek=64 + +3. Write U-Boot proper at 16384 sector + + $ sudo dd if=u-boot.itb of=/dev/sdc seek=16384 + $ sync + +Put this SD (or micro-SD) card into your board and reset it. You should see +something like: + +U-Boot SPL board init +Trying to boot from MMC1 + + +U-Boot 2019.01-00004-g14db5ee998 (Mar 11 2019 - 13:18:41 +0530) + +Model: Orange Pi RK3399 Board +DRAM: 2 GiB +MMC: dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0 +Loading Environment from MMC... OK +In: serial@ff1a0000 +Out: serial@ff1a0000 +Err: serial@ff1a0000 +Model: Orange Pi RK3399 Board +Net: eth0: ethernet@fe300000 +Hit any key to stop autoboot: 0 +=>
Using fastboot on rk3288 ======================== @@ -385,5 +452,7 @@ There are some documents about partitions in the links below. http://rockchip.wikidot.com/partitions
-- +Jagan Teki jagan@amarulasolutions.com +11 Mar 2019 Simon Glass sjg@chromium.org 24 June 2015
Jagan Teki
Philipp Tomsich
