[U-Boot] [PATCH v6 01/21] serial: Kconfig: Add MXC_UART entry
Added kconfig for MXC_UART driver.
Cc: Simon Glass sjg@chromium.org Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/serial/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 541cf2e..317d158 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -309,6 +309,13 @@ config MVEBU_A3700_UART Choose this option to add support for UART driver on the Marvell Armada 3700 SoC. The base address is configured via DT.
+config MXC_UART + bool "IMX serial port support" + depends on MX6 + help + If you have a machine based on a Motorola IMX CPU you + can enable its onboard serial port by enabling this option. + config PIC32_SERIAL bool "Support for Microchip PIC32 on-chip UART" depends on DM_SERIAL && MACH_PIC32
Added kconfig for IMX_THERMAL driver.
Cc: Simon Glass sjg@chromium.org Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/thermal/Kconfig | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/thermal/Kconfig b/drivers/thermal/Kconfig index 8e22ea7..f0ffbb3 100644 --- a/drivers/thermal/Kconfig +++ b/drivers/thermal/Kconfig @@ -5,3 +5,16 @@ config DM_THERMAL temperature sensors to permit warnings, speed throttling or even automatic power-off when the temperature gets too high or low. Other devices may be discrete but connected on a suitable bus. + +if DM_THERMAL + +config IMX_THERMAL + bool "Temperature sensor driver for Freescale i.MX SoCs" + depends on MX6 + help + Support for Temperature Monitor (TEMPMON) found on Freescale i.MX SoCs. + It supports one critical trip point and one passive trip point. The + cpufreq is used as the cooling device to throttle CPUs when the + passive trip is crossed. + +endif # if DM_THERMAL
Add kconfig entry for CONFIG_DEFAULT_FDT_FILE
Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- common/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/Kconfig b/common/Kconfig index c69c141..9cbcbd4 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -203,6 +203,11 @@ config IDENT_STRING help This options adds the board specific name to u-boot version.
+config DEFAULT_FDT_FILE + string "Default fdt file" + help + This option is used to set the default fdt file to boot OS. + config SYS_NO_FLASH bool "Disable support for parallel NOR flash" default n
Boot Log for i.CoreM6 DualLite/Solo Starter Kit: -----------------------------------------------
U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46) Trying to boot from MMC1
U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530)
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 31C Reset cause: POR DRAM: 256 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device switch to partitions #0, OK mmc0 is current device reading boot.scr ** Unable to read file boot.scr ** reading zImage 6741808 bytes read in 341 ms (18.9 MiB/s) Booting from mmc ... reading imx6dl-icore.dtb 30600 bytes read in 19 ms (1.5 MiB/s) Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800a787
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
Boot Log for i.CoreM6 Quad/Dual Starter Kit: --------------------------------------------
CPU: Freescale i.MX6Q rev1.2 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 28C Reset cause: POR DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 icorem6qdl>
Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Acked-by: Peng Fan peng.fan@nxp.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 8 + arch/arm/include/asm/imx-common/sys_proto.h | 2 + board/engicam/icorem6/Kconfig | 12 + board/engicam/icorem6/MAINTAINERS | 6 + board/engicam/icorem6/Makefile | 6 + board/engicam/icorem6/README | 31 +++ board/engicam/icorem6/icorem6.c | 400 ++++++++++++++++++++++++++++ configs/imx6qdl_icore_mmc_defconfig | 35 +++ include/configs/imx6qdl_icore.h | 120 +++++++++ 9 files changed, 620 insertions(+) create mode 100644 board/engicam/icorem6/Kconfig create mode 100644 board/engicam/icorem6/MAINTAINERS create mode 100644 board/engicam/icorem6/Makefile create mode 100644 board/engicam/icorem6/README create mode 100644 board/engicam/icorem6/icorem6.c create mode 100644 configs/imx6qdl_icore_mmc_defconfig create mode 100644 include/configs/imx6qdl_icore.h
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index d851b26..5d549bd 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -95,6 +95,13 @@ config TARGET_MX6CUBOXI config TARGET_MX6QARM2 bool "mx6qarm2"
+config TARGET_MX6Q_ICORE + bool "Support Engicam i.Core" + select MX6QDL + select DM + select DM_THERMAL + select SUPPORT_SPL + config TARGET_MX6QSABREAUTO bool "mx6qsabreauto" select DM @@ -225,6 +232,7 @@ source "board/compulab/cm_fx6/Kconfig" source "board/congatec/cgtqmx6eval/Kconfig" source "board/el/el6x/Kconfig" source "board/embest/mx6boards/Kconfig" +source "board/engicam/icorem6/Kconfig" source "board/freescale/mx6qarm2/Kconfig" source "board/freescale/mx6qsabreauto/Kconfig" source "board/freescale/mx6sabresd/Kconfig" diff --git a/arch/arm/include/asm/imx-common/sys_proto.h b/arch/arm/include/asm/imx-common/sys_proto.h index 6ace8bb..005435a 100644 --- a/arch/arm/include/asm/imx-common/sys_proto.h +++ b/arch/arm/include/asm/imx-common/sys_proto.h @@ -30,8 +30,10 @@ #define is_mx6dqp() (is_cpu_type(MXC_CPU_MX6QP) || is_cpu_type(MXC_CPU_MX6DP)) #define is_mx6dq() (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) #define is_mx6sdl() (is_cpu_type(MXC_CPU_MX6SOLO) || is_cpu_type(MXC_CPU_MX6DL)) +#define is_mx6dl() (is_cpu_type(MXC_CPU_MX6DL)) #define is_mx6sx() (is_cpu_type(MXC_CPU_MX6SX)) #define is_mx6sl() (is_cpu_type(MXC_CPU_MX6SL)) +#define is_mx6solo() (is_cpu_type(MXC_CPU_MX6SOLO)) #define is_mx6ul() (is_cpu_type(MXC_CPU_MX6UL)) #define is_mx6ull() (is_cpu_type(MXC_CPU_MX6ULL))
diff --git a/board/engicam/icorem6/Kconfig b/board/engicam/icorem6/Kconfig new file mode 100644 index 0000000..6d62f0e --- /dev/null +++ b/board/engicam/icorem6/Kconfig @@ -0,0 +1,12 @@ +if TARGET_MX6Q_ICORE + +config SYS_BOARD + default "icorem6" + +config SYS_VENDOR + default "engicam" + +config SYS_CONFIG_NAME + default "imx6qdl_icore" + +endif diff --git a/board/engicam/icorem6/MAINTAINERS b/board/engicam/icorem6/MAINTAINERS new file mode 100644 index 0000000..3e06c6b --- /dev/null +++ b/board/engicam/icorem6/MAINTAINERS @@ -0,0 +1,6 @@ +ICOREM6QDL BOARD +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: board/engicam/icorem6 +F: include/configs/icorem6qdl.h +F: configs/icorem6qdl_defconfig diff --git a/board/engicam/icorem6/Makefile b/board/engicam/icorem6/Makefile new file mode 100644 index 0000000..9ec9ecd --- /dev/null +++ b/board/engicam/icorem6/Makefile @@ -0,0 +1,6 @@ +# Copyright (C) 2016 Amarula Solutions B.V. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := icorem6.o diff --git a/board/engicam/icorem6/README b/board/engicam/icorem6/README new file mode 100644 index 0000000..cf2eff2 --- /dev/null +++ b/board/engicam/icorem6/README @@ -0,0 +1,31 @@ +How to use U-Boot on Engicam i.CoreM6 DualLite/Solo and Quad/Dual Starter Kit: +----------------------------------------------------------------------------- + +- Build U-Boot for Engicam i.CoreM6 QDL: + +$ make mrproper +$ make icorem6qdl_mmc_defconfig +$ make + +This will generate the SPL image called SPL and the u-boot.img. + +- Flash the SPL image into the micro SD card: + +sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync + +- Flash the u-boot.img image into the micro SD card: + +sudo dd if=u-boot.img of=/dev/mmcblk0 bs=1k seek=69; sync + +- Jumper settings: + +MMC Boot: JM3 Closed + +- Connect the Serial cable between the Starter Kit and the PC for the console. +(J28 is the Linux Serial console connector) + +- Insert the micro SD card in the board, power it up and U-Boot messages should +come up. + +- Note: For loading Linux on Quad/Dual modules set the dtb as + icorem6qdl> setenv fdt_file imx6q-icore.dtb diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c new file mode 100644 index 0000000..1856972 --- /dev/null +++ b/board/engicam/icorem6/icorem6.c @@ -0,0 +1,400 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * Author: Jagan Teki jagan@amarulasolutions.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> + +#include <asm/io.h> +#include <asm/gpio.h> +#include <linux/sizes.h> + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/iomux-v3.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart4_pads[] = { + IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | MUX_PAD_CTRL(NO_PAD_CTRL)),/* CD */ +}; + +#ifdef CONFIG_FSL_ESDHC +#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 1) + +struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC1_BASE_ADDR, 0, 4}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + SETUP_IOMUX_PADS(usdhc1_pads); + gpio_direction_input(USDHC1_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + default: + printf("Warning - USDHC%d controller not supporting\n", + i + 1); + return 0; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} +#endif + +int board_early_init_f(void) +{ + SETUP_IOMUX_PADS(uart4_pads); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +#ifdef CONFIG_SPL_BUILD +#include <libfdt.h> +#include <spl.h> + +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-ddr.h> + +/* + * Driving strength: + * 0x30 == 40 Ohm + * 0x28 == 48 Ohm + */ + +#define IMX6DQ_DRIVE_STRENGTH 0x30 +#define IMX6SDL_DRIVE_STRENGTH 0x28 + +/* configure MX6Q/DUAL mmdc DDR io registers */ +static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { + .dram_sdqs0 = 0x28, + .dram_sdqs1 = 0x28, + .dram_sdqs2 = 0x28, + .dram_sdqs3 = 0x28, + .dram_sdqs4 = 0x28, + .dram_sdqs5 = 0x28, + .dram_sdqs6 = 0x28, + .dram_sdqs7 = 0x28, + .dram_dqm0 = 0x28, + .dram_dqm1 = 0x28, + .dram_dqm2 = 0x28, + .dram_dqm3 = 0x28, + .dram_dqm4 = 0x28, + .dram_dqm5 = 0x28, + .dram_dqm6 = 0x28, + .dram_dqm7 = 0x28, + .dram_cas = 0x30, + .dram_ras = 0x30, + .dram_sdclk_0 = 0x30, + .dram_sdclk_1 = 0x30, + .dram_reset = 0x30, + .dram_sdcke0 = 0x3000, + .dram_sdcke1 = 0x3000, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = 0x30, + .dram_sdodt1 = 0x30, +}; + +/* configure MX6Q/DUAL mmdc GRP io registers */ +static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = { + .grp_b0ds = 0x30, + .grp_b1ds = 0x30, + .grp_b2ds = 0x30, + .grp_b3ds = 0x30, + .grp_b4ds = 0x30, + .grp_b5ds = 0x30, + .grp_b6ds = 0x30, + .grp_b7ds = 0x30, + .grp_addds = 0x30, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_ddrmode = 0x00020000, + .grp_ctlds = 0x30, + .grp_ddr_type = 0x000c0000, +}; + +/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ +struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { + .dram_sdclk_0 = 0x30, + .dram_sdclk_1 = 0x30, + .dram_cas = 0x30, + .dram_ras = 0x30, + .dram_reset = 0x30, + .dram_sdcke0 = 0x30, + .dram_sdcke1 = 0x30, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = 0x30, + .dram_sdodt1 = 0x30, + .dram_sdqs0 = 0x28, + .dram_sdqs1 = 0x28, + .dram_sdqs2 = 0x28, + .dram_sdqs3 = 0x28, + .dram_sdqs4 = 0x28, + .dram_sdqs5 = 0x28, + .dram_sdqs6 = 0x28, + .dram_sdqs7 = 0x28, + .dram_dqm0 = 0x28, + .dram_dqm1 = 0x28, + .dram_dqm2 = 0x28, + .dram_dqm3 = 0x28, + .dram_dqm4 = 0x28, + .dram_dqm5 = 0x28, + .dram_dqm6 = 0x28, + .dram_dqm7 = 0x28, +}; + +/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ +struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = 0x30, + .grp_ctlds = 0x30, + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x28, + .grp_b1ds = 0x28, + .grp_b2ds = 0x28, + .grp_b3ds = 0x28, + .grp_b4ds = 0x28, + .grp_b5ds = 0x28, + .grp_b6ds = 0x28, + .grp_b7ds = 0x28, +}; + +/* mt41j256 */ +static struct mx6_ddr3_cfg mt41j256 = { + .mem_speed = 1066, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 13, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, + .SRT = 0, +}; + +static struct mx6_mmdc_calibration mx6dq_mmdc_calib = { + .p0_mpwldectrl0 = 0x000E0009, + .p0_mpwldectrl1 = 0x0018000E, + .p1_mpwldectrl0 = 0x00000007, + .p1_mpwldectrl1 = 0x00000000, + .p0_mpdgctrl0 = 0x43280334, + .p0_mpdgctrl1 = 0x031C0314, + .p1_mpdgctrl0 = 0x4318031C, + .p1_mpdgctrl1 = 0x030C0258, + .p0_mprddlctl = 0x3E343A40, + .p1_mprddlctl = 0x383C3844, + .p0_mpwrdlctl = 0x40404440, + .p1_mpwrdlctl = 0x4C3E4446, +}; + +/* DDR 64bit */ +static struct mx6_ddr_sysinfo mem_q = { + .ddr_type = DDR_TYPE_DDR3, + .dsize = 2, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 2, + .rtt_wr = 2, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +static struct mx6_mmdc_calibration mx6dl_mmdc_calib = { + .p0_mpwldectrl0 = 0x001F0024, + .p0_mpwldectrl1 = 0x00110018, + .p1_mpwldectrl0 = 0x001F0024, + .p1_mpwldectrl1 = 0x00110018, + .p0_mpdgctrl0 = 0x4230022C, + .p0_mpdgctrl1 = 0x02180220, + .p1_mpdgctrl0 = 0x42440248, + .p1_mpdgctrl1 = 0x02300238, + .p0_mprddlctl = 0x44444A48, + .p1_mprddlctl = 0x46484A42, + .p0_mpwrdlctl = 0x38383234, + .p1_mpwrdlctl = 0x3C34362E, +}; + +/* DDR 64bit 1GB */ +static struct mx6_ddr_sysinfo mem_dl = { + .dsize = 2, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 1, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +/* DDR 32bit 512MB */ +static struct mx6_ddr_sysinfo mem_s = { + .dsize = 1, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 1, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00003F3F, &ccm->CCGR0); + writel(0x0030FC00, &ccm->CCGR1); + writel(0x000FC000, &ccm->CCGR2); + writel(0x3F300000, &ccm->CCGR3); + writel(0xFF00F300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003CC, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + +static void spl_dram_init(void) +{ + if (is_mx6solo()) { + mx6sdl_dram_iocfg(32, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&mem_s, &mx6dl_mmdc_calib, &mt41j256); + } else if (is_mx6dl()) { + mx6sdl_dram_iocfg(64, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&mem_dl, &mx6dl_mmdc_calib, &mt41j256); + } else if (is_mx6dq()) { + mx6dq_dram_iocfg(64, &mx6dq_ddr_ioregs, &mx6dq_grp_ioregs); + mx6_dram_cfg(&mem_q, &mx6dq_mmdc_calib, &mt41j256); + } + + udelay(100); +} + +void board_init_f(ulong dummy) +{ + ccgr_init(); + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + gpr_init(); + + /* iomux */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig new file mode 100644 index 0000000..ced6b10 --- /dev/null +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -0,0 +1,35 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_MX6Q_ICORE=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_DEFAULT_FDT_FILE="imx6dl-icore.dtb" +CONFIG_SYS_PROMPT="icorem6qdl> " +CONFIG_SPL=y +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTO_COMPLETE=y +CONFIG_SYS_MAXARGS=32 +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_LIBFDT=y +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SPL_EXT_SUPPORT=y diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h new file mode 100644 index 0000000..0bd0f23 --- /dev/null +++ b/include/configs/imx6qdl_icore.h @@ -0,0 +1,120 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * Configuration settings for the Engicam i.CoreM6 QDL Starter Kits. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __IMX6QLD_ICORE_CONFIG_H +#define __IMX6QLD_ICORE_CONFIG_H + +#include <linux/sizes.h> +#include "mx6_common.h" + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M) + +/* Total Size of Environment Sector */ +#define CONFIG_ENV_SIZE SZ_128K + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Environment */ +#ifndef CONFIG_ENV_IS_NOWHERE +/* Environment in MMC */ +# if defined(CONFIG_ENV_IS_IN_MMC) +# define CONFIG_ENV_OFFSET 0x100000 +# endif +#endif + +/* Default environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "console=ttymxc3\0" \ + "fdt_high=0xffffffff\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x18000000\0" \ + "boot_fdt=try\0" \ + "mmcdev=0\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "fi; " \ + "fi; " \ + "fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x8000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_SP_OFFSET) + +/* UART */ +#ifdef CONFIG_MXC_UART +# define CONFIG_MXC_UART_BASE UART4_BASE +#endif + +/* MMC */ +#ifdef CONFIG_FSL_USDHC +# define CONFIG_SYS_MMC_ENV_DEV 0 +# define CONFIG_SYS_FSL_USDHC_NUM 1 +# define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR +#endif + +/* SPL */ +#ifdef CONFIG_SPL +# define CONFIG_SPL_MMC_SUPPORT +# include "imx6_spl.h" +#endif + +#endif /* __IMX6QLD_ICORE_CONFIG_H */
Added kconfig for FEC_MXC driver.
Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/net/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 302c005..7b9961d 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -129,6 +129,13 @@ config ETHOC help This MAC is present in OpenRISC and Xtensa XTFPGA boards.
+config FEC_MXC + bool "FEC Ethernet controller" + depends on MX6 + help + This driver supports the 10/100 Fast Ethernet controller for + NXP i.MX processors. + config MVPP2 bool "Marvell Armada 375 network interface support" depends on ARMADA_375
Add enet support for engicam icorem6 qdl starter kit. - Add pinmux settings - Add board_eth_init
TFTP log: -------- Net: FEC [PRIME] Hit any key to stop autoboot: 0 icorem6qdl> tftpboot {fdt_addr} imx6dl-icore.dtb Using FEC device TFTP from server 192.168.2.96; our IP address is 192.168.2.75 Filename 'imx6dl-icore.dtb'. Load address: 0x0 Loading: ###### 1.3 MiB/s done Bytes transferred = 28976 (7130 hex) CACHE: Misaligned operation at range [00000000, 00007130] icorem6qdl>
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Acked-by: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6/icorem6.c | 72 +++++++++++++++++++++++++++++++++++++ configs/imx6qdl_icore_mmc_defconfig | 4 +++ include/configs/imx6qdl_icore.h | 12 +++++++ 3 files changed, 88 insertions(+)
diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index 1856972..a23cb7e 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -9,12 +9,15 @@ #include <common.h> #include <fsl_esdhc.h> #include <mmc.h> +#include <miiphy.h> +#include <netdev.h>
#include <asm/io.h> #include <asm/gpio.h> #include <linux/sizes.h>
#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> #include <asm/arch/iomux.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> @@ -30,11 +33,28 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + static iomux_v3_cfg_t const uart4_pads[] = { IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
+static iomux_v3_cfg_t const enet_pads[] = { + IOMUX_PADS(PAD_ENET_CRS_DV__ENET_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_GPIO_16__ENET_REF_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL | PAD_CTL_SRE_FAST)), + IOMUX_PADS(PAD_ENET_TX_EN__ENET_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_RXD1__ENET_RX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_RXD0__ENET_RX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_TXD1__ENET_TX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_TXD0__ENET_TX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + static iomux_v3_cfg_t const usdhc1_pads[] = { IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), @@ -99,6 +119,58 @@ int board_mmc_init(bd_t *bis) } #endif
+#ifdef CONFIG_FEC_MXC +#define ENET_PHY_RST IMX_GPIO_NR(7, 12) +static int setup_fec(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + s32 timeout = 100000; + u32 reg = 0; + int ret; + + /* Enable fec clock */ + setbits_le32(&ccm->CCGR1, MXC_CCM_CCGR1_ENET_MASK); + + /* use 50MHz */ + ret = enable_fec_anatop_clock(0, ENET_50MHZ); + if (ret) + return ret; + + /* Enable PLLs */ + reg = readl(&anatop->pll_enet); + reg &= ~BM_ANADIG_PLL_SYS_POWERDOWN; + writel(reg, &anatop->pll_enet); + reg = readl(&anatop->pll_enet); + reg |= BM_ANADIG_PLL_SYS_ENABLE; + while (timeout--) { + if (readl(&anatop->pll_enet) & BM_ANADIG_PLL_SYS_LOCK) + break; + } + if (timeout <= 0) + return -EIO; + reg &= ~BM_ANADIG_PLL_SYS_BYPASS; + writel(reg, &anatop->pll_enet); + + /* reset the phy */ + gpio_direction_output(ENET_PHY_RST, 0); + udelay(10000); + gpio_set_value(ENET_PHY_RST, 1); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int ret; + + SETUP_IOMUX_PADS(enet_pads); + setup_fec(); + + return ret = cpu_eth_init(bis); +} +#endif + int board_early_init_f(void) { SETUP_IOMUX_PADS(uart4_pads); diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index ced6b10..c2c2fe8 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -14,6 +14,8 @@ CONFIG_SYS_MAXARGS=32 # CONFIG_CMD_IMLS is not set CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y @@ -23,7 +25,9 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y +CONFIG_FEC_MXC=y CONFIG_MXC_UART=y +CONFIG_NETDEVICES=y CONFIG_IMX_THERMAL=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index 0bd0f23..ad4c5f2 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -111,6 +111,18 @@ # define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR #endif
+/* Ethernet */ +#ifdef CONFIG_FEC_MXC +# define IMX_FEC_BASE ENET_BASE_ADDR +# define CONFIG_FEC_MXC_PHYADDR 0 +# define CONFIG_FEC_XCV_TYPE RMII +# define CONFIG_ETHPRIME "FEC" + +# define CONFIG_MII +# define CONFIG_PHYLIB +# define CONFIG_PHY_SMSC +#endif + /* SPL */ #ifdef CONFIG_SPL # define CONFIG_SPL_MMC_SUPPORT
Fixed typo for doc/README.imximage on respective imximage.cfg files.
Cc: Tom Rini trini@konsulko.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Acked-by: Peng Fan peng.fan@nxp.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/barco/titanium/imximage.cfg | 2 +- board/ccv/xpress/imximage.cfg | 2 +- board/denx/m53evk/imximage.cfg | 2 +- board/freescale/mx6sabresd/mx6dlsabresd.cfg | 2 +- board/freescale/mx6slevk/imximage.cfg | 2 +- board/freescale/mx6ullevk/imximage.cfg | 2 +- board/freescale/mx7dsabresd/imximage.cfg | 2 +- board/freescale/s32v234evb/s32v234evb.cfg | 2 +- board/freescale/vf610twr/imximage.cfg | 2 +- board/phytec/pcm052/imximage.cfg | 2 +- board/technexion/pico-imx6ul/imximage.cfg | 2 +- board/toradex/colibri_imx7/imximage.cfg | 2 +- board/toradex/colibri_vf/imximage.cfg | 2 +- board/warp/imximage.cfg | 2 +- board/warp7/imximage.cfg | 2 +- 15 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/board/barco/titanium/imximage.cfg b/board/barco/titanium/imximage.cfg index 7219256..4fb6982 100644 --- a/board/barco/titanium/imximage.cfg +++ b/board/barco/titanium/imximage.cfg @@ -7,7 +7,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/ccv/xpress/imximage.cfg b/board/ccv/xpress/imximage.cfg index 92167c9..d98bc36 100644 --- a/board/ccv/xpress/imximage.cfg +++ b/board/ccv/xpress/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/denx/m53evk/imximage.cfg b/board/denx/m53evk/imximage.cfg index 4cd002c..c0e2602 100644 --- a/board/denx/m53evk/imximage.cfg +++ b/board/denx/m53evk/imximage.cfg @@ -4,7 +4,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/freescale/mx6sabresd/mx6dlsabresd.cfg b/board/freescale/mx6sabresd/mx6dlsabresd.cfg index f35f22e..be9f87f 100644 --- a/board/freescale/mx6sabresd/mx6dlsabresd.cfg +++ b/board/freescale/mx6sabresd/mx6dlsabresd.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/freescale/mx6slevk/imximage.cfg b/board/freescale/mx6slevk/imximage.cfg index c77bbde..024de9c 100644 --- a/board/freescale/mx6slevk/imximage.cfg +++ b/board/freescale/mx6slevk/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/freescale/mx6ullevk/imximage.cfg b/board/freescale/mx6ullevk/imximage.cfg index 4604b62..3ae4912 100644 --- a/board/freescale/mx6ullevk/imximage.cfg +++ b/board/freescale/mx6ullevk/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/freescale/mx7dsabresd/imximage.cfg b/board/freescale/mx7dsabresd/imximage.cfg index 76574ff..c2b3a8c 100644 --- a/board/freescale/mx7dsabresd/imximage.cfg +++ b/board/freescale/mx7dsabresd/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/freescale/s32v234evb/s32v234evb.cfg b/board/freescale/s32v234evb/s32v234evb.cfg index 6017a40..6449ef2 100644 --- a/board/freescale/s32v234evb/s32v234evb.cfg +++ b/board/freescale/s32v234evb/s32v234evb.cfg @@ -5,7 +5,7 @@ */
/* - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/freescale/vf610twr/imximage.cfg b/board/freescale/vf610twr/imximage.cfg index 9c823c4..09125cf 100644 --- a/board/freescale/vf610twr/imximage.cfg +++ b/board/freescale/vf610twr/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/phytec/pcm052/imximage.cfg b/board/phytec/pcm052/imximage.cfg index f5a9747..2fbb5c1b 100644 --- a/board/phytec/pcm052/imximage.cfg +++ b/board/phytec/pcm052/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/technexion/pico-imx6ul/imximage.cfg b/board/technexion/pico-imx6ul/imximage.cfg index 9145b44..c753a71 100644 --- a/board/technexion/pico-imx6ul/imximage.cfg +++ b/board/technexion/pico-imx6ul/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/toradex/colibri_imx7/imximage.cfg b/board/toradex/colibri_imx7/imximage.cfg index d891e82..ca3cd89 100644 --- a/board/toradex/colibri_imx7/imximage.cfg +++ b/board/toradex/colibri_imx7/imximage.cfg @@ -4,7 +4,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/toradex/colibri_vf/imximage.cfg b/board/toradex/colibri_vf/imximage.cfg index 8c52886..baab812 100644 --- a/board/toradex/colibri_vf/imximage.cfg +++ b/board/toradex/colibri_vf/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/warp/imximage.cfg b/board/warp/imximage.cfg index 7b1d6b7..771dbb3 100644 --- a/board/warp/imximage.cfg +++ b/board/warp/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0+ * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage diff --git a/board/warp7/imximage.cfg b/board/warp7/imximage.cfg index e7b6d30..5b42793 100644 --- a/board/warp7/imximage.cfg +++ b/board/warp7/imximage.cfg @@ -3,7 +3,7 @@ * * SPDX-License-Identifier: GPL-2.0 * - * Refer docs/README.imxmage for more details about how-to configure + * Refer doc/README.imximage for more details about how-to configure * and create imximage boot image * * The syntax is taken as close as possible with the kwbimage
Add i.MX6DL dtsi support from Linux.
Here is the last commit: "ARM: dts: add gpio-ranges property to iMX GPIO controllers" (sha1: bb728d662bed0fe91b152550e640cb3f6caa972c)
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6dl.dtsi | 133 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 133 insertions(+) create mode 100644 arch/arm/dts/imx6dl.dtsi
diff --git a/arch/arm/dts/imx6dl.dtsi b/arch/arm/dts/imx6dl.dtsi new file mode 100644 index 0000000..9a4c22c --- /dev/null +++ b/arch/arm/dts/imx6dl.dtsi @@ -0,0 +1,133 @@ + +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include "imx6dl-pinfunc.h" +#include "imx6qdl.dtsi" + +/ { + aliases { + i2c3 = &i2c4; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <0>; + next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 996000 1250000 + 792000 1175000 + 396000 1150000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 996000 1175000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; + }; + + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <1>; + next-level-cache = <&L2>; + }; + }; + + soc { + ocram: sram@00900000 { + compatible = "mmio-sram"; + reg = <0x00900000 0x20000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + aips1: aips-bus@02000000 { + iomuxc: iomuxc@020e0000 { + compatible = "fsl,imx6dl-iomuxc"; + }; + + pxp: pxp@020f0000 { + reg = <0x020f0000 0x4000>; + interrupts = <0 98 IRQ_TYPE_LEVEL_HIGH>; + }; + + epdc: epdc@020f4000 { + reg = <0x020f4000 0x4000>; + interrupts = <0 97 IRQ_TYPE_LEVEL_HIGH>; + }; + + lcdif: lcdif@020f8000 { + reg = <0x020f8000 0x4000>; + interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + aips2: aips-bus@02100000 { + i2c4: i2c@021f8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021f8000 0x4000>; + interrupts = <0 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6DL_CLK_I2C4>; + status = "disabled"; + }; + }; + }; + + display-subsystem { + compatible = "fsl,imx-display-subsystem"; + ports = <&ipu1_di0>, <&ipu1_di1>; + }; + + gpu-subsystem { + compatible = "fsl,imx-gpu-subsystem"; + cores = <&gpu_2d>, <&gpu_3d>; + }; +}; + +&gpt { + compatible = "fsl,imx6dl-gpt"; +}; + +&hdmi { + compatible = "fsl,imx6dl-hdmi"; +}; + +&ldb { + clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, + <&clks IMX6QDL_CLK_LDB_DI0>, <&clks IMX6QDL_CLK_LDB_DI1>; + clock-names = "di0_pll", "di1_pll", + "di0_sel", "di1_sel", + "di0", "di1"; +}; + +&vpu { + compatible = "fsl,imx6dl-vpu", "cnm,coda960"; +};
Add i.MX6DQL dtsi support from Linux.
Here is the last commit: "ARM: dts: imx6qdl: Fix SPDIF regression" (sha1: f065e9e4addd75c21bb976bb2558648bf4f61de6)
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6qdl.dtsi | 1281 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 1281 insertions(+) create mode 100644 arch/arm/dts/imx6qdl.dtsi
diff --git a/arch/arm/dts/imx6qdl.dtsi b/arch/arm/dts/imx6qdl.dtsi new file mode 100644 index 0000000..b13b0b2 --- /dev/null +++ b/arch/arm/dts/imx6qdl.dtsi @@ -0,0 +1,1281 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * Copyright 2011 Linaro Ltd. + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +#include <dt-bindings/clock/imx6qdl-clock.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +#include "skeleton.dtsi" + +/ { + aliases { + ethernet0 = &fec; + can0 = &can1; + can1 = &can2; + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; + gpio5 = &gpio6; + gpio6 = &gpio7; + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + ipu0 = &ipu1; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + mmc2 = &usdhc3; + mmc3 = &usdhc4; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + serial4 = &uart5; + spi0 = &ecspi1; + spi1 = &ecspi2; + spi2 = &ecspi3; + spi3 = &ecspi4; + usbphy0 = &usbphy1; + usbphy1 = &usbphy2; + }; + + clocks { + #address-cells = <1>; + #size-cells = <0>; + + ckil { + compatible = "fsl,imx-ckil", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + + ckih1 { + compatible = "fsl,imx-ckih1", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + osc { + compatible = "fsl,imx-osc", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + interrupt-parent = <&gpc>; + ranges; + + dma_apbh: dma-apbh@00110000 { + compatible = "fsl,imx6q-dma-apbh", "fsl,imx28-dma-apbh"; + reg = <0x00110000 0x2000>; + interrupts = <0 13 IRQ_TYPE_LEVEL_HIGH>, + <0 13 IRQ_TYPE_LEVEL_HIGH>, + <0 13 IRQ_TYPE_LEVEL_HIGH>, + <0 13 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gpmi0", "gpmi1", "gpmi2", "gpmi3"; + #dma-cells = <1>; + dma-channels = <4>; + clocks = <&clks IMX6QDL_CLK_APBH_DMA>; + }; + + gpmi: gpmi-nand@00112000 { + compatible = "fsl,imx6q-gpmi-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x00112000 0x2000>, <0x00114000 0x2000>; + reg-names = "gpmi-nand", "bch"; + interrupts = <0 15 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "bch"; + clocks = <&clks IMX6QDL_CLK_GPMI_IO>, + <&clks IMX6QDL_CLK_GPMI_APB>, + <&clks IMX6QDL_CLK_GPMI_BCH>, + <&clks IMX6QDL_CLK_GPMI_BCH_APB>, + <&clks IMX6QDL_CLK_PER1_BCH>; + clock-names = "gpmi_io", "gpmi_apb", "gpmi_bch", + "gpmi_bch_apb", "per1_bch"; + dmas = <&dma_apbh 0>; + dma-names = "rx-tx"; + status = "disabled"; + }; + + hdmi: hdmi@0120000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x00120000 0x9000>; + interrupts = <0 115 0x04>; + gpr = <&gpr>; + clocks = <&clks IMX6QDL_CLK_HDMI_IAHB>, + <&clks IMX6QDL_CLK_HDMI_ISFR>; + clock-names = "iahb", "isfr"; + status = "disabled"; + + port@0 { + reg = <0>; + + hdmi_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_hdmi>; + }; + }; + + port@1 { + reg = <1>; + + hdmi_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_hdmi>; + }; + }; + }; + + gpu_3d: gpu@00130000 { + compatible = "vivante,gc"; + reg = <0x00130000 0x4000>; + interrupts = <0 9 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_GPU3D_AXI>, + <&clks IMX6QDL_CLK_GPU3D_CORE>, + <&clks IMX6QDL_CLK_GPU3D_SHADER>; + clock-names = "bus", "core", "shader"; + power-domains = <&gpc 1>; + }; + + gpu_2d: gpu@00134000 { + compatible = "vivante,gc"; + reg = <0x00134000 0x4000>; + interrupts = <0 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_GPU2D_AXI>, + <&clks IMX6QDL_CLK_GPU2D_CORE>; + clock-names = "bus", "core"; + power-domains = <&gpc 1>; + }; + + timer@00a00600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x00a00600 0x20>; + interrupts = <1 13 0xf01>; + interrupt-parent = <&intc>; + clocks = <&clks IMX6QDL_CLK_TWD>; + }; + + intc: interrupt-controller@00a01000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x00a01000 0x1000>, + <0x00a00100 0x100>; + interrupt-parent = <&intc>; + }; + + L2: l2-cache@00a02000 { + compatible = "arm,pl310-cache"; + reg = <0x00a02000 0x1000>; + interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; + cache-unified; + cache-level = <2>; + arm,tag-latency = <4 2 3>; + arm,data-latency = <4 2 3>; + arm,shared-override; + }; + + pcie: pcie@0x01000000 { + compatible = "fsl,imx6q-pcie", "snps,dw-pcie"; + reg = <0x01ffc000 0x04000>, + <0x01f00000 0x80000>; + reg-names = "dbi", "config"; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges = <0x81000000 0 0 0x01f80000 0 0x00010000 /* downstream I/O */ + 0x82000000 0 0x01000000 0x01000000 0 0x00f00000>; /* non-prefetchable memory */ + num-lanes = <1>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &gpc GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 2 &gpc GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 3 &gpc GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 4 &gpc GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_PCIE_AXI>, + <&clks IMX6QDL_CLK_LVDS1_GATE>, + <&clks IMX6QDL_CLK_PCIE_REF_125M>; + clock-names = "pcie", "pcie_bus", "pcie_phy"; + status = "disabled"; + }; + + pmu { + compatible = "arm,cortex-a9-pmu"; + interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; + }; + + aips-bus@02000000 { /* AIPS1 */ + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x02000000 0x100000>; + ranges; + + spba-bus@02000000 { + compatible = "fsl,spba-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x02000000 0x40000>; + ranges; + + spdif: spdif@02004000 { + compatible = "fsl,imx35-spdif"; + reg = <0x02004000 0x4000>; + interrupts = <0 52 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 14 18 0>, + <&sdma 15 18 0>; + dma-names = "rx", "tx"; + clocks = <&clks IMX6QDL_CLK_SPDIF_GCLK>, <&clks IMX6QDL_CLK_OSC>, + <&clks IMX6QDL_CLK_SPDIF>, <&clks IMX6QDL_CLK_ASRC>, + <&clks IMX6QDL_CLK_DUMMY>, <&clks IMX6QDL_CLK_ESAI_EXTAL>, + <&clks IMX6QDL_CLK_IPG>, <&clks IMX6QDL_CLK_DUMMY>, + <&clks IMX6QDL_CLK_DUMMY>, <&clks IMX6QDL_CLK_SPBA>; + clock-names = "core", "rxtx0", + "rxtx1", "rxtx2", + "rxtx3", "rxtx4", + "rxtx5", "rxtx6", + "rxtx7", "spba"; + status = "disabled"; + }; + + ecspi1: ecspi@02008000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02008000 0x4000>; + interrupts = <0 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI1>, + <&clks IMX6QDL_CLK_ECSPI1>; + clock-names = "ipg", "per"; + dmas = <&sdma 3 8 1>, <&sdma 4 8 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi2: ecspi@0200c000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x0200c000 0x4000>; + interrupts = <0 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI2>, + <&clks IMX6QDL_CLK_ECSPI2>; + clock-names = "ipg", "per"; + dmas = <&sdma 5 8 1>, <&sdma 6 8 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi3: ecspi@02010000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02010000 0x4000>; + interrupts = <0 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI3>, + <&clks IMX6QDL_CLK_ECSPI3>; + clock-names = "ipg", "per"; + dmas = <&sdma 7 8 1>, <&sdma 8 8 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi4: ecspi@02014000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02014000 0x4000>; + interrupts = <0 34 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ECSPI4>, + <&clks IMX6QDL_CLK_ECSPI4>; + clock-names = "ipg", "per"; + dmas = <&sdma 9 8 1>, <&sdma 10 8 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart1: serial@02020000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x02020000 0x4000>; + interrupts = <0 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 25 4 0>, <&sdma 26 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + esai: esai@02024000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx35-esai"; + reg = <0x02024000 0x4000>; + interrupts = <0 51 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ESAI_IPG>, + <&clks IMX6QDL_CLK_ESAI_MEM>, + <&clks IMX6QDL_CLK_ESAI_EXTAL>, + <&clks IMX6QDL_CLK_ESAI_IPG>, + <&clks IMX6QDL_CLK_SPBA>; + clock-names = "core", "mem", "extal", "fsys", "spba"; + dmas = <&sdma 23 21 0>, <&sdma 24 21 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ssi1: ssi@02028000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx6q-ssi", + "fsl,imx51-ssi"; + reg = <0x02028000 0x4000>; + interrupts = <0 46 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SSI1_IPG>, + <&clks IMX6QDL_CLK_SSI1>; + clock-names = "ipg", "baud"; + dmas = <&sdma 37 1 0>, + <&sdma 38 1 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + ssi2: ssi@0202c000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx6q-ssi", + "fsl,imx51-ssi"; + reg = <0x0202c000 0x4000>; + interrupts = <0 47 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SSI2_IPG>, + <&clks IMX6QDL_CLK_SSI2>; + clock-names = "ipg", "baud"; + dmas = <&sdma 41 1 0>, + <&sdma 42 1 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + ssi3: ssi@02030000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx6q-ssi", + "fsl,imx51-ssi"; + reg = <0x02030000 0x4000>; + interrupts = <0 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SSI3_IPG>, + <&clks IMX6QDL_CLK_SSI3>; + clock-names = "ipg", "baud"; + dmas = <&sdma 45 1 0>, + <&sdma 46 1 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + asrc: asrc@02034000 { + compatible = "fsl,imx53-asrc"; + reg = <0x02034000 0x4000>; + interrupts = <0 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ASRC_IPG>, + <&clks IMX6QDL_CLK_ASRC_MEM>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks IMX6QDL_CLK_ASRC>, <&clks 0>, <&clks 0>, + <&clks IMX6QDL_CLK_SPBA>; + clock-names = "mem", "ipg", "asrck_0", + "asrck_1", "asrck_2", "asrck_3", "asrck_4", + "asrck_5", "asrck_6", "asrck_7", "asrck_8", + "asrck_9", "asrck_a", "asrck_b", "asrck_c", + "asrck_d", "asrck_e", "asrck_f", "spba"; + dmas = <&sdma 17 23 1>, <&sdma 18 23 1>, <&sdma 19 23 1>, + <&sdma 20 23 1>, <&sdma 21 23 1>, <&sdma 22 23 1>; + dma-names = "rxa", "rxb", "rxc", + "txa", "txb", "txc"; + fsl,asrc-rate = <48000>; + fsl,asrc-width = <16>; + status = "okay"; + }; + + spba@0203c000 { + reg = <0x0203c000 0x4000>; + }; + }; + + vpu: vpu@02040000 { + compatible = "cnm,coda960"; + reg = <0x02040000 0x3c000>; + interrupts = <0 12 IRQ_TYPE_LEVEL_HIGH>, + <0 3 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "bit", "jpeg"; + clocks = <&clks IMX6QDL_CLK_VPU_AXI>, + <&clks IMX6QDL_CLK_MMDC_CH0_AXI>; + clock-names = "per", "ahb"; + power-domains = <&gpc 1>; + resets = <&src 1>; + iram = <&ocram>; + }; + + aipstz@0207c000 { /* AIPSTZ1 */ + reg = <0x0207c000 0x4000>; + }; + + pwm1: pwm@02080000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x02080000 0x4000>; + interrupts = <0 83 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM1>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + pwm2: pwm@02084000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x02084000 0x4000>; + interrupts = <0 84 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM2>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + pwm3: pwm@02088000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x02088000 0x4000>; + interrupts = <0 85 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM3>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + pwm4: pwm@0208c000 { + #pwm-cells = <2>; + compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; + reg = <0x0208c000 0x4000>; + interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>, + <&clks IMX6QDL_CLK_PWM4>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + can1: flexcan@02090000 { + compatible = "fsl,imx6q-flexcan"; + reg = <0x02090000 0x4000>; + interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_CAN1_IPG>, + <&clks IMX6QDL_CLK_CAN1_SERIAL>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + can2: flexcan@02094000 { + compatible = "fsl,imx6q-flexcan"; + reg = <0x02094000 0x4000>; + interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_CAN2_IPG>, + <&clks IMX6QDL_CLK_CAN2_SERIAL>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + gpt: gpt@02098000 { + compatible = "fsl,imx6q-gpt", "fsl,imx31-gpt"; + reg = <0x02098000 0x4000>; + interrupts = <0 55 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_GPT_IPG>, + <&clks IMX6QDL_CLK_GPT_IPG_PER>, + <&clks IMX6QDL_CLK_GPT_3M>; + clock-names = "ipg", "per", "osc_per"; + }; + + gpio1: gpio@0209c000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x0209c000 0x4000>; + interrupts = <0 66 IRQ_TYPE_LEVEL_HIGH>, + <0 67 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@020a0000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020a0000 0x4000>; + interrupts = <0 68 IRQ_TYPE_LEVEL_HIGH>, + <0 69 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@020a4000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020a4000 0x4000>; + interrupts = <0 70 IRQ_TYPE_LEVEL_HIGH>, + <0 71 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio@020a8000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020a8000 0x4000>; + interrupts = <0 72 IRQ_TYPE_LEVEL_HIGH>, + <0 73 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio5: gpio@020ac000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020ac000 0x4000>; + interrupts = <0 74 IRQ_TYPE_LEVEL_HIGH>, + <0 75 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio6: gpio@020b0000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020b0000 0x4000>; + interrupts = <0 76 IRQ_TYPE_LEVEL_HIGH>, + <0 77 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio7: gpio@020b4000 { + compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; + reg = <0x020b4000 0x4000>; + interrupts = <0 78 IRQ_TYPE_LEVEL_HIGH>, + <0 79 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + kpp: kpp@020b8000 { + compatible = "fsl,imx6q-kpp", "fsl,imx21-kpp"; + reg = <0x020b8000 0x4000>; + interrupts = <0 82 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPG>; + status = "disabled"; + }; + + wdog1: wdog@020bc000 { + compatible = "fsl,imx6q-wdt", "fsl,imx21-wdt"; + reg = <0x020bc000 0x4000>; + interrupts = <0 80 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_DUMMY>; + }; + + wdog2: wdog@020c0000 { + compatible = "fsl,imx6q-wdt", "fsl,imx21-wdt"; + reg = <0x020c0000 0x4000>; + interrupts = <0 81 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_DUMMY>; + status = "disabled"; + }; + + clks: ccm@020c4000 { + compatible = "fsl,imx6q-ccm"; + reg = <0x020c4000 0x4000>; + interrupts = <0 87 IRQ_TYPE_LEVEL_HIGH>, + <0 88 IRQ_TYPE_LEVEL_HIGH>; + #clock-cells = <1>; + }; + + anatop: anatop@020c8000 { + compatible = "fsl,imx6q-anatop", "syscon", "simple-bus"; + reg = <0x020c8000 0x1000>; + interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>, + <0 54 IRQ_TYPE_LEVEL_HIGH>, + <0 127 IRQ_TYPE_LEVEL_HIGH>; + + regulator-1p1 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd1p1"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1375000>; + regulator-always-on; + anatop-reg-offset = <0x110>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <4>; + anatop-min-voltage = <800000>; + anatop-max-voltage = <1375000>; + }; + + regulator-3p0 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd3p0"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <3150000>; + regulator-always-on; + anatop-reg-offset = <0x120>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <0>; + anatop-min-voltage = <2625000>; + anatop-max-voltage = <3400000>; + }; + + regulator-2p5 { + compatible = "fsl,anatop-regulator"; + regulator-name = "vdd2p5"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2750000>; + regulator-always-on; + anatop-reg-offset = <0x130>; + anatop-vol-bit-shift = <8>; + anatop-vol-bit-width = <5>; + anatop-min-bit-val = <0>; + anatop-min-voltage = <2000000>; + anatop-max-voltage = <2750000>; + }; + + reg_arm: regulator-vddcore { + compatible = "fsl,anatop-regulator"; + regulator-name = "vddarm"; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1450000>; + regulator-always-on; + anatop-reg-offset = <0x140>; + anatop-vol-bit-shift = <0>; + anatop-vol-bit-width = <5>; + anatop-delay-reg-offset = <0x170>; + anatop-delay-bit-shift = <24>; + anatop-delay-bit-width = <2>; + anatop-min-bit-val = <1>; + anatop-min-voltage = <725000>; + anatop-max-voltage = <1450000>; + }; + + reg_pu: regulator-vddpu { + compatible = "fsl,anatop-regulator"; + regulator-name = "vddpu"; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1450000>; + regulator-enable-ramp-delay = <150>; + anatop-reg-offset = <0x140>; + anatop-vol-bit-shift = <9>; + anatop-vol-bit-width = <5>; + anatop-delay-reg-offset = <0x170>; + anatop-delay-bit-shift = <26>; + anatop-delay-bit-width = <2>; + anatop-min-bit-val = <1>; + anatop-min-voltage = <725000>; + anatop-max-voltage = <1450000>; + }; + + reg_soc: regulator-vddsoc { + compatible = "fsl,anatop-regulator"; + regulator-name = "vddsoc"; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1450000>; + regulator-always-on; + anatop-reg-offset = <0x140>; + anatop-vol-bit-shift = <18>; + anatop-vol-bit-width = <5>; + anatop-delay-reg-offset = <0x170>; + anatop-delay-bit-shift = <28>; + anatop-delay-bit-width = <2>; + anatop-min-bit-val = <1>; + anatop-min-voltage = <725000>; + anatop-max-voltage = <1450000>; + }; + }; + + tempmon: tempmon { + compatible = "fsl,imx6q-tempmon"; + interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>; + fsl,tempmon = <&anatop>; + fsl,tempmon-data = <&ocotp>; + clocks = <&clks IMX6QDL_CLK_PLL3_USB_OTG>; + }; + + usbphy1: usbphy@020c9000 { + compatible = "fsl,imx6q-usbphy", "fsl,imx23-usbphy"; + reg = <0x020c9000 0x1000>; + interrupts = <0 44 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBPHY1>; + fsl,anatop = <&anatop>; + }; + + usbphy2: usbphy@020ca000 { + compatible = "fsl,imx6q-usbphy", "fsl,imx23-usbphy"; + reg = <0x020ca000 0x1000>; + interrupts = <0 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBPHY2>; + fsl,anatop = <&anatop>; + }; + + snvs: snvs@020cc000 { + compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; + reg = <0x020cc000 0x4000>; + + snvs_rtc: snvs-rtc-lp { + compatible = "fsl,sec-v4.0-mon-rtc-lp"; + regmap = <&snvs>; + offset = <0x34>; + interrupts = <0 19 IRQ_TYPE_LEVEL_HIGH>, + <0 20 IRQ_TYPE_LEVEL_HIGH>; + }; + + snvs_poweroff: snvs-poweroff { + compatible = "syscon-poweroff"; + regmap = <&snvs>; + offset = <0x38>; + mask = <0x60>; + status = "disabled"; + }; + }; + + epit1: epit@020d0000 { /* EPIT1 */ + reg = <0x020d0000 0x4000>; + interrupts = <0 56 IRQ_TYPE_LEVEL_HIGH>; + }; + + epit2: epit@020d4000 { /* EPIT2 */ + reg = <0x020d4000 0x4000>; + interrupts = <0 57 IRQ_TYPE_LEVEL_HIGH>; + }; + + src: src@020d8000 { + compatible = "fsl,imx6q-src", "fsl,imx51-src"; + reg = <0x020d8000 0x4000>; + interrupts = <0 91 IRQ_TYPE_LEVEL_HIGH>, + <0 96 IRQ_TYPE_LEVEL_HIGH>; + #reset-cells = <1>; + }; + + gpc: gpc@020dc000 { + compatible = "fsl,imx6q-gpc"; + reg = <0x020dc000 0x4000>; + interrupt-controller; + #interrupt-cells = <3>; + interrupts = <0 89 IRQ_TYPE_LEVEL_HIGH>, + <0 90 IRQ_TYPE_LEVEL_HIGH>; + interrupt-parent = <&intc>; + pu-supply = <®_pu>; + clocks = <&clks IMX6QDL_CLK_GPU3D_CORE>, + <&clks IMX6QDL_CLK_GPU3D_SHADER>, + <&clks IMX6QDL_CLK_GPU2D_CORE>, + <&clks IMX6QDL_CLK_GPU2D_AXI>, + <&clks IMX6QDL_CLK_OPENVG_AXI>, + <&clks IMX6QDL_CLK_VPU_AXI>; + #power-domain-cells = <1>; + }; + + gpr: iomuxc-gpr@020e0000 { + compatible = "fsl,imx6q-iomuxc-gpr", "syscon"; + reg = <0x020e0000 0x38>; + }; + + iomuxc: iomuxc@020e0000 { + compatible = "fsl,imx6dl-iomuxc", "fsl,imx6q-iomuxc"; + reg = <0x020e0000 0x4000>; + }; + + ldb: ldb@020e0008 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ldb", "fsl,imx53-ldb"; + gpr = <&gpr>; + status = "disabled"; + + lvds-channel@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + status = "disabled"; + + port@0 { + reg = <0>; + + lvds0_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_lvds0>; + }; + }; + + port@1 { + reg = <1>; + + lvds0_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_lvds0>; + }; + }; + }; + + lvds-channel@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + status = "disabled"; + + port@0 { + reg = <0>; + + lvds1_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_lvds1>; + }; + }; + + port@1 { + reg = <1>; + + lvds1_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_lvds1>; + }; + }; + }; + }; + + dcic1: dcic@020e4000 { + reg = <0x020e4000 0x4000>; + interrupts = <0 124 IRQ_TYPE_LEVEL_HIGH>; + }; + + dcic2: dcic@020e8000 { + reg = <0x020e8000 0x4000>; + interrupts = <0 125 IRQ_TYPE_LEVEL_HIGH>; + }; + + sdma: sdma@020ec000 { + compatible = "fsl,imx6q-sdma", "fsl,imx35-sdma"; + reg = <0x020ec000 0x4000>; + interrupts = <0 2 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SDMA>, + <&clks IMX6QDL_CLK_SDMA>; + clock-names = "ipg", "ahb"; + #dma-cells = <3>; + fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; + }; + }; + + aips-bus@02100000 { /* AIPS2 */ + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x02100000 0x100000>; + ranges; + + crypto: caam@2100000 { + compatible = "fsl,sec-v4.0"; + fsl,sec-era = <4>; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x2100000 0x10000>; + ranges = <0 0x2100000 0x10000>; + clocks = <&clks IMX6QDL_CLK_CAAM_MEM>, + <&clks IMX6QDL_CLK_CAAM_ACLK>, + <&clks IMX6QDL_CLK_CAAM_IPG>, + <&clks IMX6QDL_CLK_EIM_SLOW>; + clock-names = "mem", "aclk", "ipg", "emi_slow"; + + sec_jr0: jr0@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr1@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + aipstz@0217c000 { /* AIPSTZ2 */ + reg = <0x0217c000 0x4000>; + }; + + usbotg: usb@02184000 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184000 0x200>; + interrupts = <0 43 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbphy = <&usbphy1>; + fsl,usbmisc = <&usbmisc 0>; + ahb-burst-config = <0x0>; + tx-burst-size-dword = <0x10>; + rx-burst-size-dword = <0x10>; + status = "disabled"; + }; + + usbh1: usb@02184200 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184200 0x200>; + interrupts = <0 40 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbphy = <&usbphy2>; + fsl,usbmisc = <&usbmisc 1>; + dr_mode = "host"; + ahb-burst-config = <0x0>; + tx-burst-size-dword = <0x10>; + rx-burst-size-dword = <0x10>; + status = "disabled"; + }; + + usbh2: usb@02184400 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184400 0x200>; + interrupts = <0 41 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbmisc = <&usbmisc 2>; + dr_mode = "host"; + ahb-burst-config = <0x0>; + tx-burst-size-dword = <0x10>; + rx-burst-size-dword = <0x10>; + status = "disabled"; + }; + + usbh3: usb@02184600 { + compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; + reg = <0x02184600 0x200>; + interrupts = <0 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + fsl,usbmisc = <&usbmisc 3>; + dr_mode = "host"; + ahb-burst-config = <0x0>; + tx-burst-size-dword = <0x10>; + rx-burst-size-dword = <0x10>; + status = "disabled"; + }; + + usbmisc: usbmisc@02184800 { + #index-cells = <1>; + compatible = "fsl,imx6q-usbmisc"; + reg = <0x02184800 0x200>; + clocks = <&clks IMX6QDL_CLK_USBOH3>; + }; + + fec: ethernet@02188000 { + compatible = "fsl,imx6q-fec"; + reg = <0x02188000 0x4000>; + interrupts-extended = + <&intc 0 118 IRQ_TYPE_LEVEL_HIGH>, + <&intc 0 119 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET_REF>; + clock-names = "ipg", "ahb", "ptp"; + status = "disabled"; + }; + + mlb@0218c000 { + reg = <0x0218c000 0x4000>; + interrupts = <0 53 IRQ_TYPE_LEVEL_HIGH>, + <0 117 IRQ_TYPE_LEVEL_HIGH>, + <0 126 IRQ_TYPE_LEVEL_HIGH>; + }; + + usdhc1: usdhc@02190000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x02190000 0x4000>; + interrupts = <0 22 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC1>, + <&clks IMX6QDL_CLK_USDHC1>, + <&clks IMX6QDL_CLK_USDHC1>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc2: usdhc@02194000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x02194000 0x4000>; + interrupts = <0 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC2>, + <&clks IMX6QDL_CLK_USDHC2>, + <&clks IMX6QDL_CLK_USDHC2>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc3: usdhc@02198000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x02198000 0x4000>; + interrupts = <0 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC3>, + <&clks IMX6QDL_CLK_USDHC3>, + <&clks IMX6QDL_CLK_USDHC3>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + usdhc4: usdhc@0219c000 { + compatible = "fsl,imx6q-usdhc"; + reg = <0x0219c000 0x4000>; + interrupts = <0 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_USDHC4>, + <&clks IMX6QDL_CLK_USDHC4>, + <&clks IMX6QDL_CLK_USDHC4>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + i2c1: i2c@021a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021a0000 0x4000>; + interrupts = <0 36 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_I2C1>; + status = "disabled"; + }; + + i2c2: i2c@021a4000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021a4000 0x4000>; + interrupts = <0 37 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_I2C2>; + status = "disabled"; + }; + + i2c3: i2c@021a8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; + reg = <0x021a8000 0x4000>; + interrupts = <0 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_I2C3>; + status = "disabled"; + }; + + romcp@021ac000 { + reg = <0x021ac000 0x4000>; + }; + + mmdc0: mmdc@021b0000 { /* MMDC0 */ + compatible = "fsl,imx6q-mmdc"; + reg = <0x021b0000 0x4000>; + }; + + mmdc1: mmdc@021b4000 { /* MMDC1 */ + reg = <0x021b4000 0x4000>; + }; + + weim: weim@021b8000 { + compatible = "fsl,imx6q-weim"; + reg = <0x021b8000 0x4000>; + interrupts = <0 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_EIM_SLOW>; + }; + + ocotp: ocotp@021bc000 { + compatible = "fsl,imx6q-ocotp", "syscon"; + reg = <0x021bc000 0x4000>; + clocks = <&clks IMX6QDL_CLK_IIM>; + }; + + tzasc@021d0000 { /* TZASC1 */ + reg = <0x021d0000 0x4000>; + interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; + }; + + tzasc@021d4000 { /* TZASC2 */ + reg = <0x021d4000 0x4000>; + interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; + }; + + audmux: audmux@021d8000 { + compatible = "fsl,imx6q-audmux", "fsl,imx31-audmux"; + reg = <0x021d8000 0x4000>; + status = "disabled"; + }; + + mipi_csi: mipi@021dc000 { + reg = <0x021dc000 0x4000>; + }; + + mipi_dsi: mipi@021e0000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x021e0000 0x4000>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + mipi_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_mipi>; + }; + }; + + port@1 { + reg = <1>; + + mipi_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_mipi>; + }; + }; + }; + }; + + vdoa@021e4000 { + reg = <0x021e4000 0x4000>; + interrupts = <0 18 IRQ_TYPE_LEVEL_HIGH>; + }; + + uart2: serial@021e8000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021e8000 0x4000>; + interrupts = <0 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 27 4 0>, <&sdma 28 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart3: serial@021ec000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021ec000 0x4000>; + interrupts = <0 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 29 4 0>, <&sdma 30 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart4: serial@021f0000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021f0000 0x4000>; + interrupts = <0 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 31 4 0>, <&sdma 32 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart5: serial@021f4000 { + compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; + reg = <0x021f4000 0x4000>; + interrupts = <0 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_UART_IPG>, + <&clks IMX6QDL_CLK_UART_SERIAL>; + clock-names = "ipg", "per"; + dmas = <&sdma 33 4 0>, <&sdma 34 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + }; + + ipu1: ipu@02400000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ipu"; + reg = <0x02400000 0x400000>; + interrupts = <0 6 IRQ_TYPE_LEVEL_HIGH>, + <0 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPU1>, + <&clks IMX6QDL_CLK_IPU1_DI0>, + <&clks IMX6QDL_CLK_IPU1_DI1>; + clock-names = "bus", "di0", "di1"; + resets = <&src 2>; + + ipu1_csi0: port@0 { + reg = <0>; + }; + + ipu1_csi1: port@1 { + reg = <1>; + }; + + ipu1_di0: port@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + + ipu1_di0_disp0: disp0-endpoint { + }; + + ipu1_di0_hdmi: hdmi-endpoint { + remote-endpoint = <&hdmi_mux_0>; + }; + + ipu1_di0_mipi: mipi-endpoint { + remote-endpoint = <&mipi_mux_0>; + }; + + ipu1_di0_lvds0: lvds0-endpoint { + remote-endpoint = <&lvds0_mux_0>; + }; + + ipu1_di0_lvds1: lvds1-endpoint { + remote-endpoint = <&lvds1_mux_0>; + }; + }; + + ipu1_di1: port@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + + ipu1_di1_disp1: disp1-endpoint { + }; + + ipu1_di1_hdmi: hdmi-endpoint { + remote-endpoint = <&hdmi_mux_1>; + }; + + ipu1_di1_mipi: mipi-endpoint { + remote-endpoint = <&mipi_mux_1>; + }; + + ipu1_di1_lvds0: lvds0-endpoint { + remote-endpoint = <&lvds0_mux_1>; + }; + + ipu1_di1_lvds1: lvds1-endpoint { + remote-endpoint = <&lvds1_mux_1>; + }; + }; + }; + }; +};
Add imx6dl pinctrl defines support from Linux.
Here is the last commit: "ARM: dts: imx: pinfunc: add MX6QDL_PAD_GPIO_6__ENET_IRQ" (sha1: d8c765e0d1ddbd5032c2491c82cc9660c2f0e7f2)
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6dl-pinfunc.h | 1091 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 1091 insertions(+) create mode 100644 arch/arm/dts/imx6dl-pinfunc.h
diff --git a/arch/arm/dts/imx6dl-pinfunc.h b/arch/arm/dts/imx6dl-pinfunc.h new file mode 100644 index 0000000..0ead323 --- /dev/null +++ b/arch/arm/dts/imx6dl-pinfunc.h @@ -0,0 +1,1091 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#ifndef __DTS_IMX6DL_PINFUNC_H +#define __DTS_IMX6DL_PINFUNC_H + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ +#define MX6QDL_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 0x04c 0x360 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT10__AUD3_RXC 0x04c 0x360 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ECSPI2_MISO 0x04c 0x360 0x7f8 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x04c 0x360 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__UART1_RX_DATA 0x04c 0x360 0x8fc 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__GPIO5_IO28 0x04c 0x360 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ARM_TRACE07 0x04c 0x360 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 0x050 0x364 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT11__AUD3_RXFS 0x050 0x364 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ECSPI2_SS0 0x050 0x364 0x800 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x050 0x364 0x8fc 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT11__UART1_TX_DATA 0x050 0x364 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT11__GPIO5_IO29 0x050 0x364 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ARM_TRACE08 0x050 0x364 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x054 0x368 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT12__EIM_DATA08 0x054 0x368 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x054 0x368 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_RX_DATA 0x054 0x368 0x914 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT12__GPIO5_IO30 0x054 0x368 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT12__ARM_TRACE09 0x054 0x368 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x058 0x36c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT13__EIM_DATA09 0x058 0x36c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x058 0x36c 0x914 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT13__UART4_TX_DATA 0x058 0x36c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT13__GPIO5_IO31 0x058 0x36c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT13__ARM_TRACE10 0x058 0x36c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x05c 0x370 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT14__EIM_DATA10 0x05c 0x370 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_TX_DATA 0x05c 0x370 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_RX_DATA 0x05c 0x370 0x91c 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT14__GPIO6_IO00 0x05c 0x370 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT14__ARM_TRACE11 0x05c 0x370 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x060 0x374 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT15__EIM_DATA11 0x060 0x374 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT15__UART5_RX_DATA 0x060 0x374 0x91c 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT15__UART5_TX_DATA 0x060 0x374 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT15__GPIO6_IO01 0x060 0x374 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT15__ARM_TRACE12 0x060 0x374 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x064 0x378 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT16__EIM_DATA12 0x064 0x378 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B 0x064 0x378 0x910 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B 0x064 0x378 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__GPIO6_IO02 0x064 0x378 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT16__ARM_TRACE13 0x064 0x378 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x068 0x37c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT17__EIM_DATA13 0x068 0x37c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B 0x068 0x37c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B 0x068 0x37c 0x910 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x068 0x37c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT17__ARM_TRACE14 0x068 0x37c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x06c 0x380 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT18__EIM_DATA14 0x06c 0x380 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT18__UART5_RTS_B 0x06c 0x380 0x918 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT18__UART5_CTS_B 0x06c 0x380 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT18__GPIO6_IO04 0x06c 0x380 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT18__ARM_TRACE15 0x06c 0x380 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x070 0x384 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT19__EIM_DATA15 0x070 0x384 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_CTS_B 0x070 0x384 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_RTS_B 0x070 0x384 0x918 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT19__GPIO6_IO05 0x070 0x384 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 0x074 0x388 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT4__EIM_DATA02 0x074 0x388 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ECSPI1_SCLK 0x074 0x388 0x7d8 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT4__KEY_COL5 0x074 0x388 0x8c0 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x074 0x388 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT4__GPIO5_IO22 0x074 0x388 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ARM_TRACE01 0x074 0x388 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 0x078 0x38c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT5__EIM_DATA03 0x078 0x38c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ECSPI1_MOSI 0x078 0x38c 0x7e0 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT5__KEY_ROW5 0x078 0x38c 0x8cc 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x078 0x38c 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT5__GPIO5_IO23 0x078 0x38c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ARM_TRACE02 0x078 0x38c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 0x07c 0x390 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT6__EIM_DATA04 0x07c 0x390 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ECSPI1_MISO 0x07c 0x390 0x7dc 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT6__KEY_COL6 0x07c 0x390 0x8c4 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x07c 0x390 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT6__GPIO5_IO24 0x07c 0x390 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ARM_TRACE03 0x07c 0x390 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 0x080 0x394 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT7__EIM_DATA05 0x080 0x394 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ECSPI1_SS0 0x080 0x394 0x7e4 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT7__KEY_ROW6 0x080 0x394 0x8d0 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x080 0x394 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x080 0x394 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ARM_TRACE04 0x080 0x394 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 0x084 0x398 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT8__EIM_DATA06 0x084 0x398 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ECSPI2_SCLK 0x084 0x398 0x7f4 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT8__KEY_COL7 0x084 0x398 0x8c8 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x084 0x398 0x86c 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x084 0x398 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ARM_TRACE05 0x084 0x398 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 0x088 0x39c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT9__EIM_DATA07 0x088 0x39c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ECSPI2_MOSI 0x088 0x39c 0x7fc 0x2 0x0 +#define MX6QDL_PAD_CSI0_DAT9__KEY_ROW7 0x088 0x39c 0x8d4 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x088 0x39c 0x868 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT9__GPIO5_IO27 0x088 0x39c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ARM_TRACE06 0x088 0x39c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN 0x08c 0x3a0 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__EIM_DATA00 0x08c 0x3a0 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x08c 0x3a0 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__ARM_TRACE_CLK 0x08c 0x3a0 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x090 0x3a4 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x090 0x3a4 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x090 0x3a4 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_MCLK__ARM_TRACE_CTL 0x090 0x3a4 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x094 0x3a8 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x094 0x3a8 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__ARM_EVENTO 0x094 0x3a8 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x098 0x3ac 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__EIM_DATA01 0x098 0x3ac 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x098 0x3ac 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__ARM_TRACE00 0x098 0x3ac 0x000 0x7 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x09c 0x3b0 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__LCD_CLK 0x09c 0x3b0 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__GPIO4_IO16 0x09c 0x3b0 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__LCD_WR_RWN 0x09c 0x3b0 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15 0x0a0 0x3b4 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN15__LCD_ENABLE 0x0a0 0x3b4 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN15__AUD6_TXC 0x0a0 0x3b4 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN15__GPIO4_IO17 0x0a0 0x3b4 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN15__LCD_RD_E 0x0a0 0x3b4 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0x0a4 0x3b8 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN2__LCD_HSYNC 0x0a4 0x3b8 0x8d8 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN2__AUD6_TXD 0x0a4 0x3b8 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN2__GPIO4_IO18 0x0a4 0x3b8 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN2__LCD_RS 0x0a4 0x3b8 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0x0a8 0x3bc 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN3__LCD_VSYNC 0x0a8 0x3bc 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN3__AUD6_TXFS 0x0a8 0x3bc 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN3__GPIO4_IO19 0x0a8 0x3bc 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN3__LCD_CS 0x0a8 0x3bc 0x000 0x8 0x0 +#define MX6QDL_PAD_DI0_PIN4__IPU1_DI0_PIN04 0x0ac 0x3c0 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN4__LCD_BUSY 0x0ac 0x3c0 0x8d8 0x1 0x1 +#define MX6QDL_PAD_DI0_PIN4__AUD6_RXD 0x0ac 0x3c0 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN4__SD1_WP 0x0ac 0x3c0 0x92c 0x3 0x0 +#define MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x0ac 0x3c0 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN4__LCD_RESET 0x0ac 0x3c0 0x000 0x8 0x0 +#define MX6QDL_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 0x0b0 0x3c4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT0__LCD_DATA00 0x0b0 0x3c4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT0__ECSPI3_SCLK 0x0b0 0x3c4 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT0__GPIO4_IO21 0x0b0 0x3c4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0x0b4 0x3c8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT1__LCD_DATA01 0x0b4 0x3c8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT1__ECSPI3_MOSI 0x0b4 0x3c8 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT1__GPIO4_IO22 0x0b4 0x3c8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0x0b8 0x3cc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT10__LCD_DATA10 0x0b8 0x3cc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT10__GPIO4_IO31 0x0b8 0x3cc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0x0bc 0x3d0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT11__LCD_DATA11 0x0bc 0x3d0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x0bc 0x3d0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0x0c0 0x3d4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT12__LCD_DATA12 0x0c0 0x3d4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT12__GPIO5_IO06 0x0c0 0x3d4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0x0c4 0x3d8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT13__LCD_DATA13 0x0c4 0x3d8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT13__AUD5_RXFS 0x0c4 0x3d8 0x7bc 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT13__GPIO5_IO07 0x0c4 0x3d8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0x0c8 0x3dc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT14__LCD_DATA14 0x0c8 0x3dc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT14__AUD5_RXC 0x0c8 0x3dc 0x7b8 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT14__GPIO5_IO08 0x0c8 0x3dc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0x0cc 0x3e0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT15__LCD_DATA15 0x0cc 0x3e0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI1_SS1 0x0cc 0x3e0 0x7e8 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI2_SS1 0x0cc 0x3e0 0x804 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT15__GPIO5_IO09 0x0cc 0x3e0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0x0d0 0x3e4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT16__LCD_DATA16 0x0d0 0x3e4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT16__ECSPI2_MOSI 0x0d0 0x3e4 0x7fc 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT16__AUD5_TXC 0x0d0 0x3e4 0x7c0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 0x0d0 0x3e4 0x8e8 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT16__GPIO5_IO10 0x0d0 0x3e4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 0x0d4 0x3e8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT17__LCD_DATA17 0x0d4 0x3e8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT17__ECSPI2_MISO 0x0d4 0x3e8 0x7f8 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT17__AUD5_TXD 0x0d4 0x3e8 0x7b4 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 0x0d4 0x3e8 0x8ec 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT17__GPIO5_IO11 0x0d4 0x3e8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 0x0d8 0x3ec 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT18__LCD_DATA18 0x0d8 0x3ec 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT18__ECSPI2_SS0 0x0d8 0x3ec 0x800 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT18__AUD5_TXFS 0x0d8 0x3ec 0x7c4 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT18__AUD4_RXFS 0x0d8 0x3ec 0x7a4 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT18__GPIO5_IO12 0x0d8 0x3ec 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__EIM_CS2_B 0x0d8 0x3ec 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 0x0dc 0x3f0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT19__LCD_DATA19 0x0dc 0x3f0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT19__ECSPI2_SCLK 0x0dc 0x3f0 0x7f4 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT19__AUD5_RXD 0x0dc 0x3f0 0x7b0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT19__AUD4_RXC 0x0dc 0x3f0 0x7a0 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT19__GPIO5_IO13 0x0dc 0x3f0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT19__EIM_CS3_B 0x0dc 0x3f0 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0x0e0 0x3f4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT2__LCD_DATA02 0x0e0 0x3f4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT2__ECSPI3_MISO 0x0e0 0x3f4 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT2__GPIO4_IO23 0x0e0 0x3f4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 0x0e4 0x3f8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT20__LCD_DATA20 0x0e4 0x3f8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT20__ECSPI1_SCLK 0x0e4 0x3f8 0x7d8 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT20__AUD4_TXC 0x0e4 0x3f8 0x7a8 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT20__GPIO5_IO14 0x0e4 0x3f8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 0x0e8 0x3fc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT21__LCD_DATA21 0x0e8 0x3fc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT21__ECSPI1_MOSI 0x0e8 0x3fc 0x7e0 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT21__AUD4_TXD 0x0e8 0x3fc 0x79c 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT21__GPIO5_IO15 0x0e8 0x3fc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 0x0ec 0x400 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT22__LCD_DATA22 0x0ec 0x400 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT22__ECSPI1_MISO 0x0ec 0x400 0x7dc 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT22__AUD4_TXFS 0x0ec 0x400 0x7ac 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT22__GPIO5_IO16 0x0ec 0x400 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 0x0f0 0x404 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT23__LCD_DATA23 0x0f0 0x404 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT23__ECSPI1_SS0 0x0f0 0x404 0x7e4 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT23__AUD4_RXD 0x0f0 0x404 0x798 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT23__GPIO5_IO17 0x0f0 0x404 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0x0f4 0x408 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT3__LCD_DATA03 0x0f4 0x408 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT3__ECSPI3_SS0 0x0f4 0x408 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT3__GPIO4_IO24 0x0f4 0x408 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0x0f8 0x40c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT4__LCD_DATA04 0x0f8 0x40c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT4__ECSPI3_SS1 0x0f8 0x40c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT4__GPIO4_IO25 0x0f8 0x40c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0x0fc 0x410 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT5__LCD_DATA05 0x0fc 0x410 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT5__ECSPI3_SS2 0x0fc 0x410 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT5__AUD6_RXFS 0x0fc 0x410 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT5__GPIO4_IO26 0x0fc 0x410 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0x100 0x414 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT6__LCD_DATA06 0x100 0x414 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT6__ECSPI3_SS3 0x100 0x414 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT6__AUD6_RXC 0x100 0x414 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT6__GPIO4_IO27 0x100 0x414 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0x104 0x418 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT7__LCD_DATA07 0x104 0x418 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT7__ECSPI3_RDY 0x104 0x418 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT7__GPIO4_IO28 0x104 0x418 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0x108 0x41c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT8__LCD_DATA08 0x108 0x41c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT8__PWM1_OUT 0x108 0x41c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT8__WDOG1_B 0x108 0x41c 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT8__GPIO4_IO29 0x108 0x41c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0x10c 0x420 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT9__LCD_DATA09 0x10c 0x420 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT9__PWM2_OUT 0x10c 0x420 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT9__WDOG2_B 0x10c 0x420 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT9__GPIO4_IO30 0x10c 0x420 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A16__EIM_ADDR16 0x110 0x4e0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A16__IPU1_DI1_DISP_CLK 0x110 0x4e0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A16__IPU1_CSI1_PIXCLK 0x110 0x4e0 0x8b8 0x2 0x0 +#define MX6QDL_PAD_EIM_A16__GPIO2_IO22 0x110 0x4e0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A16__SRC_BOOT_CFG16 0x110 0x4e0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A16__EPDC_DATA00 0x110 0x4e0 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A17__EIM_ADDR17 0x114 0x4e4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A17__IPU1_DISP1_DATA12 0x114 0x4e4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A17__IPU1_CSI1_DATA12 0x114 0x4e4 0x890 0x2 0x0 +#define MX6QDL_PAD_EIM_A17__GPIO2_IO21 0x114 0x4e4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A17__SRC_BOOT_CFG17 0x114 0x4e4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A17__EPDC_PWR_STAT 0x114 0x4e4 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A18__EIM_ADDR18 0x118 0x4e8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A18__IPU1_DISP1_DATA13 0x118 0x4e8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A18__IPU1_CSI1_DATA13 0x118 0x4e8 0x894 0x2 0x0 +#define MX6QDL_PAD_EIM_A18__GPIO2_IO20 0x118 0x4e8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A18__SRC_BOOT_CFG18 0x118 0x4e8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A18__EPDC_PWR_CTRL0 0x118 0x4e8 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A19__EIM_ADDR19 0x11c 0x4ec 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A19__IPU1_DISP1_DATA14 0x11c 0x4ec 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A19__IPU1_CSI1_DATA14 0x11c 0x4ec 0x898 0x2 0x0 +#define MX6QDL_PAD_EIM_A19__GPIO2_IO19 0x11c 0x4ec 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A19__SRC_BOOT_CFG19 0x11c 0x4ec 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A19__EPDC_PWR_CTRL1 0x11c 0x4ec 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A20__EIM_ADDR20 0x120 0x4f0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A20__IPU1_DISP1_DATA15 0x120 0x4f0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A20__IPU1_CSI1_DATA15 0x120 0x4f0 0x89c 0x2 0x0 +#define MX6QDL_PAD_EIM_A20__GPIO2_IO18 0x120 0x4f0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A20__SRC_BOOT_CFG20 0x120 0x4f0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A20__EPDC_PWR_CTRL2 0x120 0x4f0 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A21__EIM_ADDR21 0x124 0x4f4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A21__IPU1_DISP1_DATA16 0x124 0x4f4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A21__IPU1_CSI1_DATA16 0x124 0x4f4 0x8a0 0x2 0x0 +#define MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x124 0x4f4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A21__SRC_BOOT_CFG21 0x124 0x4f4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A21__EPDC_GDCLK 0x124 0x4f4 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A22__EIM_ADDR22 0x128 0x4f8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A22__IPU1_DISP1_DATA17 0x128 0x4f8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A22__IPU1_CSI1_DATA17 0x128 0x4f8 0x8a4 0x2 0x0 +#define MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x128 0x4f8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A22__SRC_BOOT_CFG22 0x128 0x4f8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A22__EPDC_GDSP 0x128 0x4f8 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A23__EIM_ADDR23 0x12c 0x4fc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_DISP1_DATA18 0x12c 0x4fc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_CSI1_DATA18 0x12c 0x4fc 0x8a8 0x2 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_SISG3 0x12c 0x4fc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A23__GPIO6_IO06 0x12c 0x4fc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A23__SRC_BOOT_CFG23 0x12c 0x4fc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A23__EPDC_GDOE 0x12c 0x4fc 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A24__EIM_ADDR24 0x130 0x500 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_DISP1_DATA19 0x130 0x500 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_CSI1_DATA19 0x130 0x500 0x8ac 0x2 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_SISG2 0x130 0x500 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x130 0x500 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A24__SRC_BOOT_CFG24 0x130 0x500 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A24__EPDC_GDRL 0x130 0x500 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A25__EIM_ADDR25 0x134 0x504 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI4_SS1 0x134 0x504 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI2_RDY 0x134 0x504 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI1_PIN12 0x134 0x504 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI0_D1_CS 0x134 0x504 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x134 0x504 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A25__HDMI_TX_CEC_LINE 0x134 0x504 0x85c 0x6 0x0 +#define MX6QDL_PAD_EIM_A25__EPDC_DATA15 0x134 0x504 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_A25__EIM_ACLK_FREERUN 0x134 0x504 0x000 0x9 0x0 +#define MX6QDL_PAD_EIM_BCLK__EIM_BCLK 0x138 0x508 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_BCLK__IPU1_DI1_PIN16 0x138 0x508 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_BCLK__GPIO6_IO31 0x138 0x508 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_BCLK__EPDC_SDCE9 0x138 0x508 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0x13c 0x50c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS0__IPU1_DI1_PIN05 0x13c 0x50c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK 0x13c 0x50c 0x7f4 0x2 0x2 +#define MX6QDL_PAD_EIM_CS0__GPIO2_IO23 0x13c 0x50c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_CS0__EPDC_DATA06 0x13c 0x50c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_CS1__EIM_CS1_B 0x140 0x510 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS1__IPU1_DI1_PIN06 0x140 0x510 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI 0x140 0x510 0x7fc 0x2 0x2 +#define MX6QDL_PAD_EIM_CS1__GPIO2_IO24 0x140 0x510 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_CS1__EPDC_DATA08 0x140 0x510 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D16__EIM_DATA16 0x144 0x514 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D16__ECSPI1_SCLK 0x144 0x514 0x7d8 0x1 0x2 +#define MX6QDL_PAD_EIM_D16__IPU1_DI0_PIN05 0x144 0x514 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D16__IPU1_CSI1_DATA18 0x144 0x514 0x8a8 0x3 0x1 +#define MX6QDL_PAD_EIM_D16__HDMI_TX_DDC_SDA 0x144 0x514 0x864 0x4 0x0 +#define MX6QDL_PAD_EIM_D16__GPIO3_IO16 0x144 0x514 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D16__I2C2_SDA 0x144 0x514 0x874 0x6 0x0 +#define MX6QDL_PAD_EIM_D16__EPDC_DATA10 0x144 0x514 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D17__EIM_DATA17 0x148 0x518 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D17__ECSPI1_MISO 0x148 0x518 0x7dc 0x1 0x2 +#define MX6QDL_PAD_EIM_D17__IPU1_DI0_PIN06 0x148 0x518 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D17__IPU1_CSI1_PIXCLK 0x148 0x518 0x8b8 0x3 0x1 +#define MX6QDL_PAD_EIM_D17__DCIC1_OUT 0x148 0x518 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D17__GPIO3_IO17 0x148 0x518 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D17__I2C3_SCL 0x148 0x518 0x878 0x6 0x0 +#define MX6QDL_PAD_EIM_D17__EPDC_VCOM0 0x148 0x518 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D18__EIM_DATA18 0x14c 0x51c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D18__ECSPI1_MOSI 0x14c 0x51c 0x7e0 0x1 0x2 +#define MX6QDL_PAD_EIM_D18__IPU1_DI0_PIN07 0x14c 0x51c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D18__IPU1_CSI1_DATA17 0x14c 0x51c 0x8a4 0x3 0x1 +#define MX6QDL_PAD_EIM_D18__IPU1_DI1_D0_CS 0x14c 0x51c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x14c 0x51c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D18__I2C3_SDA 0x14c 0x51c 0x87c 0x6 0x0 +#define MX6QDL_PAD_EIM_D18__EPDC_VCOM1 0x14c 0x51c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D19__EIM_DATA19 0x150 0x520 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D19__ECSPI1_SS1 0x150 0x520 0x7e8 0x1 0x1 +#define MX6QDL_PAD_EIM_D19__IPU1_DI0_PIN08 0x150 0x520 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D19__IPU1_CSI1_DATA16 0x150 0x520 0x8a0 0x3 0x1 +#define MX6QDL_PAD_EIM_D19__UART1_CTS_B 0x150 0x520 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__UART1_RTS_B 0x150 0x520 0x8f8 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x150 0x520 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D19__EPIT1_OUT 0x150 0x520 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D19__EPDC_DATA12 0x150 0x520 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D20__EIM_DATA20 0x154 0x524 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D20__ECSPI4_SS0 0x154 0x524 0x808 0x1 0x0 +#define MX6QDL_PAD_EIM_D20__IPU1_DI0_PIN16 0x154 0x524 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D20__IPU1_CSI1_DATA15 0x154 0x524 0x89c 0x3 0x1 +#define MX6QDL_PAD_EIM_D20__UART1_RTS_B 0x154 0x524 0x8f8 0x4 0x1 +#define MX6QDL_PAD_EIM_D20__UART1_CTS_B 0x154 0x524 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D20__GPIO3_IO20 0x154 0x524 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D20__EPIT2_OUT 0x154 0x524 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D21__EIM_DATA21 0x158 0x528 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D21__ECSPI4_SCLK 0x158 0x528 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D21__IPU1_DI0_PIN17 0x158 0x528 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D21__IPU1_CSI1_DATA11 0x158 0x528 0x88c 0x3 0x0 +#define MX6QDL_PAD_EIM_D21__USB_OTG_OC 0x158 0x528 0x920 0x4 0x0 +#define MX6QDL_PAD_EIM_D21__GPIO3_IO21 0x158 0x528 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D21__I2C1_SCL 0x158 0x528 0x868 0x6 0x1 +#define MX6QDL_PAD_EIM_D21__SPDIF_IN 0x158 0x528 0x8f0 0x7 0x0 +#define MX6QDL_PAD_EIM_D22__EIM_DATA22 0x15c 0x52c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D22__ECSPI4_MISO 0x15c 0x52c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D22__IPU1_DI0_PIN01 0x15c 0x52c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D22__IPU1_CSI1_DATA10 0x15c 0x52c 0x888 0x3 0x0 +#define MX6QDL_PAD_EIM_D22__USB_OTG_PWR 0x15c 0x52c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x15c 0x52c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D22__SPDIF_OUT 0x15c 0x52c 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D22__EPDC_SDCE6 0x15c 0x52c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D23__EIM_DATA23 0x160 0x530 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI0_D0_CS 0x160 0x530 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x160 0x530 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_RTS_B 0x160 0x530 0x908 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART1_DCD_B 0x160 0x530 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_CSI1_DATA_EN 0x160 0x530 0x8b0 0x4 0x0 +#define MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x160 0x530 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN02 0x160 0x530 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN14 0x160 0x530 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D23__EPDC_DATA11 0x160 0x530 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D24__EIM_DATA24 0x164 0x534 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI4_SS2 0x164 0x534 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x164 0x534 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_RX_DATA 0x164 0x534 0x90c 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI1_SS2 0x164 0x534 0x7ec 0x3 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI2_SS2 0x164 0x534 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D24__GPIO3_IO24 0x164 0x534 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D24__AUD5_RXFS 0x164 0x534 0x7bc 0x6 0x1 +#define MX6QDL_PAD_EIM_D24__UART1_DTR_B 0x164 0x534 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D24__EPDC_SDCE7 0x164 0x534 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D25__EIM_DATA25 0x168 0x538 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI4_SS3 0x168 0x538 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x168 0x538 0x90c 0x2 0x1 +#define MX6QDL_PAD_EIM_D25__UART3_TX_DATA 0x168 0x538 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI1_SS3 0x168 0x538 0x7f0 0x3 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI2_SS3 0x168 0x538 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D25__GPIO3_IO25 0x168 0x538 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D25__AUD5_RXC 0x168 0x538 0x7b8 0x6 0x1 +#define MX6QDL_PAD_EIM_D25__UART1_DSR_B 0x168 0x538 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D25__EPDC_SDCE8 0x168 0x538 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D26__EIM_DATA26 0x16c 0x53c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DI1_PIN11 0x16c 0x53c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_CSI0_DATA01 0x16c 0x53c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_CSI1_DATA14 0x16c 0x53c 0x898 0x3 0x1 +#define MX6QDL_PAD_EIM_D26__UART2_TX_DATA 0x16c 0x53c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__UART2_RX_DATA 0x16c 0x53c 0x904 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x16c 0x53c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_SISG2 0x16c 0x53c 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DISP1_DATA22 0x16c 0x53c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D26__EPDC_SDOED 0x16c 0x53c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D27__EIM_DATA27 0x170 0x540 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DI1_PIN13 0x170 0x540 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_CSI0_DATA00 0x170 0x540 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_CSI1_DATA13 0x170 0x540 0x894 0x3 0x1 +#define MX6QDL_PAD_EIM_D27__UART2_RX_DATA 0x170 0x540 0x904 0x4 0x1 +#define MX6QDL_PAD_EIM_D27__UART2_TX_DATA 0x170 0x540 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x170 0x540 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_SISG3 0x170 0x540 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DISP1_DATA23 0x170 0x540 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D27__EPDC_SDOE 0x170 0x540 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D28__EIM_DATA28 0x174 0x544 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D28__I2C1_SDA 0x174 0x544 0x86c 0x1 0x1 +#define MX6QDL_PAD_EIM_D28__ECSPI4_MOSI 0x174 0x544 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_CSI1_DATA12 0x174 0x544 0x890 0x3 0x1 +#define MX6QDL_PAD_EIM_D28__UART2_CTS_B 0x174 0x544 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_RTS_B 0x174 0x544 0x900 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_CTS_B 0x174 0x544 0x900 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_RTS_B 0x174 0x544 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x174 0x544 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_EXT_TRIG 0x174 0x544 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_DI0_PIN13 0x174 0x544 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D28__EPDC_PWR_CTRL3 0x174 0x544 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D29__EIM_DATA29 0x178 0x548 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI1_PIN15 0x178 0x548 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D29__ECSPI4_SS0 0x178 0x548 0x808 0x2 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_RTS_B 0x178 0x548 0x900 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_CTS_B 0x178 0x548 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_RTS_B 0x178 0x548 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_CTS_B 0x178 0x548 0x900 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x178 0x548 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_CSI1_VSYNC 0x178 0x548 0x8bc 0x6 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI0_PIN14 0x178 0x548 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D29__EPDC_PWR_WAKE 0x178 0x548 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D30__EIM_DATA30 0x17c 0x54c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DISP1_DATA21 0x17c 0x54c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DI0_PIN11 0x17c 0x54c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_CSI0_DATA03 0x17c 0x54c 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_CTS_B 0x17c 0x54c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_RTS_B 0x17c 0x54c 0x908 0x4 0x1 +#define MX6QDL_PAD_EIM_D30__GPIO3_IO30 0x17c 0x54c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D30__USB_H1_OC 0x17c 0x54c 0x924 0x6 0x0 +#define MX6QDL_PAD_EIM_D30__EPDC_SDOEZ 0x17c 0x54c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D31__EIM_DATA31 0x180 0x550 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DISP1_DATA20 0x180 0x550 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DI0_PIN12 0x180 0x550 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_CSI0_DATA02 0x180 0x550 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D31__UART3_RTS_B 0x180 0x550 0x908 0x4 0x2 +#define MX6QDL_PAD_EIM_D31__UART3_CTS_B 0x180 0x550 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x180 0x550 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D31__USB_H1_PWR 0x180 0x550 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D31__EPDC_SDCLK_P 0x180 0x550 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_D31__EIM_ACLK_FREERUN 0x180 0x550 0x000 0x9 0x0 +#define MX6QDL_PAD_EIM_DA0__EIM_AD00 0x184 0x554 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU1_DISP1_DATA09 0x184 0x554 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU1_CSI1_DATA09 0x184 0x554 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA0__GPIO3_IO00 0x184 0x554 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA0__SRC_BOOT_CFG00 0x184 0x554 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA0__EPDC_SDCLK_N 0x184 0x554 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA1__EIM_AD01 0x188 0x558 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU1_DISP1_DATA08 0x188 0x558 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU1_CSI1_DATA08 0x188 0x558 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA1__GPIO3_IO01 0x188 0x558 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA1__SRC_BOOT_CFG01 0x188 0x558 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA1__EPDC_SDLE 0x188 0x558 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA10__EIM_AD10 0x18c 0x55c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU1_DI1_PIN15 0x18c 0x55c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU1_CSI1_DATA_EN 0x18c 0x55c 0x8b0 0x2 0x1 +#define MX6QDL_PAD_EIM_DA10__GPIO3_IO10 0x18c 0x55c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA10__SRC_BOOT_CFG10 0x18c 0x55c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA10__EPDC_DATA01 0x18c 0x55c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA11__EIM_AD11 0x190 0x560 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU1_DI1_PIN02 0x190 0x560 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU1_CSI1_HSYNC 0x190 0x560 0x8b4 0x2 0x0 +#define MX6QDL_PAD_EIM_DA11__GPIO3_IO11 0x190 0x560 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA11__SRC_BOOT_CFG11 0x190 0x560 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA11__EPDC_DATA03 0x190 0x560 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA12__EIM_AD12 0x194 0x564 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU1_DI1_PIN03 0x194 0x564 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU1_CSI1_VSYNC 0x194 0x564 0x8bc 0x2 0x1 +#define MX6QDL_PAD_EIM_DA12__GPIO3_IO12 0x194 0x564 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA12__SRC_BOOT_CFG12 0x194 0x564 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA12__EPDC_DATA02 0x194 0x564 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA13__EIM_AD13 0x198 0x568 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA13__IPU1_DI1_D0_CS 0x198 0x568 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x198 0x568 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA13__SRC_BOOT_CFG13 0x198 0x568 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA13__EPDC_DATA13 0x198 0x568 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA14__EIM_AD14 0x19c 0x56c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA14__IPU1_DI1_D1_CS 0x19c 0x56c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA14__GPIO3_IO14 0x19c 0x56c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA14__SRC_BOOT_CFG14 0x19c 0x56c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA14__EPDC_DATA14 0x19c 0x56c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA15__EIM_AD15 0x1a0 0x570 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN01 0x1a0 0x570 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN04 0x1a0 0x570 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA15__GPIO3_IO15 0x1a0 0x570 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA15__SRC_BOOT_CFG15 0x1a0 0x570 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA15__EPDC_DATA09 0x1a0 0x570 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA2__EIM_AD02 0x1a4 0x574 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU1_DISP1_DATA07 0x1a4 0x574 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU1_CSI1_DATA07 0x1a4 0x574 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA2__GPIO3_IO02 0x1a4 0x574 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA2__SRC_BOOT_CFG02 0x1a4 0x574 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA2__EPDC_BDR0 0x1a4 0x574 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA3__EIM_AD03 0x1a8 0x578 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU1_DISP1_DATA06 0x1a8 0x578 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU1_CSI1_DATA06 0x1a8 0x578 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA3__GPIO3_IO03 0x1a8 0x578 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA3__SRC_BOOT_CFG03 0x1a8 0x578 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA3__EPDC_BDR1 0x1a8 0x578 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA4__EIM_AD04 0x1ac 0x57c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU1_DISP1_DATA05 0x1ac 0x57c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU1_CSI1_DATA05 0x1ac 0x57c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA4__GPIO3_IO04 0x1ac 0x57c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA4__SRC_BOOT_CFG04 0x1ac 0x57c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA4__EPDC_SDCE0 0x1ac 0x57c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA5__EIM_AD05 0x1b0 0x580 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU1_DISP1_DATA04 0x1b0 0x580 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU1_CSI1_DATA04 0x1b0 0x580 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA5__GPIO3_IO05 0x1b0 0x580 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA5__SRC_BOOT_CFG05 0x1b0 0x580 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA5__EPDC_SDCE1 0x1b0 0x580 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA6__EIM_AD06 0x1b4 0x584 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU1_DISP1_DATA03 0x1b4 0x584 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU1_CSI1_DATA03 0x1b4 0x584 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA6__GPIO3_IO06 0x1b4 0x584 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA6__SRC_BOOT_CFG06 0x1b4 0x584 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA6__EPDC_SDCE2 0x1b4 0x584 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA7__EIM_AD07 0x1b8 0x588 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU1_DISP1_DATA02 0x1b8 0x588 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU1_CSI1_DATA02 0x1b8 0x588 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA7__GPIO3_IO07 0x1b8 0x588 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA7__SRC_BOOT_CFG07 0x1b8 0x588 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA7__EPDC_SDCE3 0x1b8 0x588 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA8__EIM_AD08 0x1bc 0x58c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU1_DISP1_DATA01 0x1bc 0x58c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU1_CSI1_DATA01 0x1bc 0x58c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA8__GPIO3_IO08 0x1bc 0x58c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA8__SRC_BOOT_CFG08 0x1bc 0x58c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA8__EPDC_SDCE4 0x1bc 0x58c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_DA9__EIM_AD09 0x1c0 0x590 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU1_DISP1_DATA00 0x1c0 0x590 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU1_CSI1_DATA00 0x1c0 0x590 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA9__GPIO3_IO09 0x1c0 0x590 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA9__SRC_BOOT_CFG09 0x1c0 0x590 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA9__EPDC_SDCE5 0x1c0 0x590 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB0__EIM_EB0_B 0x1c4 0x594 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU1_DISP1_DATA11 0x1c4 0x594 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU1_CSI1_DATA11 0x1c4 0x594 0x88c 0x2 0x1 +#define MX6QDL_PAD_EIM_EB0__CCM_PMIC_READY 0x1c4 0x594 0x7d4 0x4 0x0 +#define MX6QDL_PAD_EIM_EB0__GPIO2_IO28 0x1c4 0x594 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB0__SRC_BOOT_CFG27 0x1c4 0x594 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB0__EPDC_PWR_COM 0x1c4 0x594 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB1__EIM_EB1_B 0x1c8 0x598 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU1_DISP1_DATA10 0x1c8 0x598 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU1_CSI1_DATA10 0x1c8 0x598 0x888 0x2 0x1 +#define MX6QDL_PAD_EIM_EB1__GPIO2_IO29 0x1c8 0x598 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB1__SRC_BOOT_CFG28 0x1c8 0x598 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB1__EPDC_SDSHR 0x1c8 0x598 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB2__EIM_EB2_B 0x1cc 0x59c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB2__ECSPI1_SS0 0x1cc 0x59c 0x7e4 0x1 0x2 +#define MX6QDL_PAD_EIM_EB2__IPU1_CSI1_DATA19 0x1cc 0x59c 0x8ac 0x3 0x1 +#define MX6QDL_PAD_EIM_EB2__HDMI_TX_DDC_SCL 0x1cc 0x59c 0x860 0x4 0x0 +#define MX6QDL_PAD_EIM_EB2__GPIO2_IO30 0x1cc 0x59c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x1cc 0x59c 0x870 0x6 0x0 +#define MX6QDL_PAD_EIM_EB2__SRC_BOOT_CFG30 0x1cc 0x59c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB2__EPDC_DATA05 0x1cc 0x59c 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB3__EIM_EB3_B 0x1d0 0x5a0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB3__ECSPI4_RDY 0x1d0 0x5a0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB3__UART3_RTS_B 0x1d0 0x5a0 0x908 0x2 0x3 +#define MX6QDL_PAD_EIM_EB3__UART3_CTS_B 0x1d0 0x5a0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_EB3__UART1_RI_B 0x1d0 0x5a0 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU1_CSI1_HSYNC 0x1d0 0x5a0 0x8b4 0x4 0x1 +#define MX6QDL_PAD_EIM_EB3__GPIO2_IO31 0x1d0 0x5a0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU1_DI1_PIN03 0x1d0 0x5a0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_EB3__SRC_BOOT_CFG31 0x1d0 0x5a0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB3__EPDC_SDCE0 0x1d0 0x5a0 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_EB3__EIM_ACLK_FREERUN 0x1d0 0x5a0 0x000 0x9 0x0 +#define MX6QDL_PAD_EIM_LBA__EIM_LBA_B 0x1d4 0x5a4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_LBA__IPU1_DI1_PIN17 0x1d4 0x5a4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_LBA__ECSPI2_SS1 0x1d4 0x5a4 0x804 0x2 0x1 +#define MX6QDL_PAD_EIM_LBA__GPIO2_IO27 0x1d4 0x5a4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_LBA__SRC_BOOT_CFG26 0x1d4 0x5a4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_LBA__EPDC_DATA04 0x1d4 0x5a4 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_OE__EIM_OE_B 0x1d8 0x5a8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_OE__IPU1_DI1_PIN07 0x1d8 0x5a8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_OE__ECSPI2_MISO 0x1d8 0x5a8 0x7f8 0x2 0x2 +#define MX6QDL_PAD_EIM_OE__GPIO2_IO25 0x1d8 0x5a8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_OE__EPDC_PWR_IRQ 0x1d8 0x5a8 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_RW__EIM_RW 0x1dc 0x5ac 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_RW__IPU1_DI1_PIN08 0x1dc 0x5ac 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_RW__ECSPI2_SS0 0x1dc 0x5ac 0x800 0x2 0x2 +#define MX6QDL_PAD_EIM_RW__GPIO2_IO26 0x1dc 0x5ac 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_RW__SRC_BOOT_CFG29 0x1dc 0x5ac 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_RW__EPDC_DATA07 0x1dc 0x5ac 0x000 0x8 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_WAIT_B 0x1e0 0x5b0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_DTACK_B 0x1e0 0x5b0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_WAIT__GPIO5_IO00 0x1e0 0x5b0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_WAIT__SRC_BOOT_CFG25 0x1e0 0x5b0 0x000 0x7 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1e4 0x5b4 0x828 0x1 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__ESAI_TX_CLK 0x1e4 0x5b4 0x840 0x2 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__SPDIF_EXT_CLK 0x1e4 0x5b4 0x8f4 0x3 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1e4 0x5b4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDC__MLB_DATA 0x1e8 0x5b8 0x8e0 0x0 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1e8 0x5b8 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_MDC__ESAI_TX5_RX0 0x1e8 0x5b8 0x858 0x2 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_1588_EVENT1_IN 0x1e8 0x5b8 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDC__GPIO1_IO31 0x1e8 0x5b8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1ec 0x5bc 0x810 0x1 0x0 +#define MX6QDL_PAD_ENET_MDIO__ESAI_RX_CLK 0x1ec 0x5bc 0x83c 0x2 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT 0x1ec 0x5bc 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDIO__GPIO1_IO22 0x1ec 0x5bc 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__SPDIF_LOCK 0x1ec 0x5bc 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1f0 0x5c0 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ESAI_RX_FS 0x1f0 0x5c0 0x82c 0x2 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1f0 0x5c0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__SPDIF_SR_CLK 0x1f0 0x5c0 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x1f4 0x5c4 0x790 0x0 0x0 +#define MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1f4 0x5c4 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_RX_ER__ESAI_RX_HF_CLK 0x1f4 0x5c4 0x834 0x2 0x0 +#define MX6QDL_PAD_ENET_RX_ER__SPDIF_IN 0x1f4 0x5c4 0x8f0 0x3 0x1 +#define MX6QDL_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT 0x1f4 0x5c4 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RX_ER__GPIO1_IO24 0x1f4 0x5c4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1f8 0x5c8 0x818 0x1 0x0 +#define MX6QDL_PAD_ENET_RXD0__ESAI_TX_HF_CLK 0x1f8 0x5c8 0x838 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD0__SPDIF_OUT 0x1f8 0x5c8 0x000 0x3 0x0 +#define MX6QDL_PAD_ENET_RXD0__GPIO1_IO27 0x1f8 0x5c8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD1__MLB_SIG 0x1fc 0x5cc 0x8e4 0x0 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1fc 0x5cc 0x81c 0x1 0x0 +#define MX6QDL_PAD_ENET_RXD1__ESAI_TX_FS 0x1fc 0x5cc 0x830 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT 0x1fc 0x5cc 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x1fc 0x5cc 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x200 0x5d0 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ESAI_TX3_RX2 0x200 0x5d0 0x850 0x2 0x0 +#define MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x200 0x5d0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TX_EN__I2C4_SCL 0x200 0x5d0 0x880 0x9 0x0 +#define MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x204 0x5d4 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD0__ESAI_TX4_RX1 0x204 0x5d4 0x854 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x204 0x5d4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD1__MLB_CLK 0x208 0x5d8 0x8dc 0x0 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x208 0x5d8 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD1__ESAI_TX2_RX3 0x208 0x5d8 0x84c 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_1588_EVENT0_IN 0x208 0x5d8 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x208 0x5d8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD1__I2C4_SDA 0x208 0x5d8 0x884 0x9 0x0 +#define MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x20c 0x5dc 0x000 0x0 0x0 +#define MX6QDL_PAD_GPIO_0__KEY_COL5 0x20c 0x5dc 0x8c0 0x2 0x1 +#define MX6QDL_PAD_GPIO_0__ASRC_EXT_CLK 0x20c 0x5dc 0x794 0x3 0x0 +#define MX6QDL_PAD_GPIO_0__EPIT1_OUT 0x20c 0x5dc 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x20c 0x5dc 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_0__USB_H1_PWR 0x20c 0x5dc 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_0__SNVS_VIO_5 0x20c 0x5dc 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_1__ESAI_RX_CLK 0x210 0x5e0 0x83c 0x0 0x1 +#define MX6QDL_PAD_GPIO_1__WDOG2_B 0x210 0x5e0 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_1__KEY_ROW5 0x210 0x5e0 0x8cc 0x2 0x1 +#define MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x210 0x5e0 0x790 0x3 0x1 +#define MX6QDL_PAD_GPIO_1__PWM2_OUT 0x210 0x5e0 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_1__GPIO1_IO01 0x210 0x5e0 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_1__SD1_CD_B 0x210 0x5e0 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_16__ESAI_TX3_RX2 0x214 0x5e4 0x850 0x0 0x1 +#define MX6QDL_PAD_GPIO_16__ENET_1588_EVENT2_IN 0x214 0x5e4 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x214 0x5e4 0x80c 0x2 0x0 +#define MX6QDL_PAD_GPIO_16__SD1_LCTL 0x214 0x5e4 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_16__SPDIF_IN 0x214 0x5e4 0x8f0 0x4 0x2 +#define MX6QDL_PAD_GPIO_16__GPIO7_IO11 0x214 0x5e4 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_16__I2C3_SDA 0x214 0x5e4 0x87c 0x6 0x1 +#define MX6QDL_PAD_GPIO_16__JTAG_DE_B 0x214 0x5e4 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_17__ESAI_TX0 0x218 0x5e8 0x844 0x0 0x0 +#define MX6QDL_PAD_GPIO_17__ENET_1588_EVENT3_IN 0x218 0x5e8 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_17__CCM_PMIC_READY 0x218 0x5e8 0x7d4 0x2 0x1 +#define MX6QDL_PAD_GPIO_17__SDMA_EXT_EVENT0 0x218 0x5e8 0x8e8 0x3 0x1 +#define MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x218 0x5e8 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x218 0x5e8 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__ESAI_TX1 0x21c 0x5ec 0x848 0x0 0x0 +#define MX6QDL_PAD_GPIO_18__ENET_RX_CLK 0x21c 0x5ec 0x814 0x1 0x0 +#define MX6QDL_PAD_GPIO_18__SD3_VSELECT 0x21c 0x5ec 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_18__SDMA_EXT_EVENT1 0x21c 0x5ec 0x8ec 0x3 0x1 +#define MX6QDL_PAD_GPIO_18__ASRC_EXT_CLK 0x21c 0x5ec 0x794 0x4 0x1 +#define MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x21c 0x5ec 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__SNVS_VIO_5_CTL 0x21c 0x5ec 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_19__KEY_COL5 0x220 0x5f0 0x8c0 0x0 0x2 +#define MX6QDL_PAD_GPIO_19__ENET_1588_EVENT0_OUT 0x220 0x5f0 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_19__SPDIF_OUT 0x220 0x5f0 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_19__CCM_CLKO1 0x220 0x5f0 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_19__ECSPI1_RDY 0x220 0x5f0 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x220 0x5f0 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_19__ENET_TX_ER 0x220 0x5f0 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_2__ESAI_TX_FS 0x224 0x5f4 0x830 0x0 0x1 +#define MX6QDL_PAD_GPIO_2__KEY_ROW6 0x224 0x5f4 0x8d0 0x2 0x1 +#define MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x224 0x5f4 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_2__SD2_WP 0x224 0x5f4 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_2__MLB_DATA 0x224 0x5f4 0x8e0 0x7 0x1 +#define MX6QDL_PAD_GPIO_3__ESAI_RX_HF_CLK 0x228 0x5f8 0x834 0x0 0x1 +#define MX6QDL_PAD_GPIO_3__I2C3_SCL 0x228 0x5f8 0x878 0x2 0x1 +#define MX6QDL_PAD_GPIO_3__XTALOSC_REF_CLK_24M 0x228 0x5f8 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_3__CCM_CLKO2 0x228 0x5f8 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_3__GPIO1_IO03 0x228 0x5f8 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_3__USB_H1_OC 0x228 0x5f8 0x924 0x6 0x1 +#define MX6QDL_PAD_GPIO_3__MLB_CLK 0x228 0x5f8 0x8dc 0x7 0x1 +#define MX6QDL_PAD_GPIO_4__ESAI_TX_HF_CLK 0x22c 0x5fc 0x838 0x0 0x1 +#define MX6QDL_PAD_GPIO_4__KEY_COL7 0x22c 0x5fc 0x8c8 0x2 0x1 +#define MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x22c 0x5fc 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_4__SD2_CD_B 0x22c 0x5fc 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_5__ESAI_TX2_RX3 0x230 0x600 0x84c 0x0 0x1 +#define MX6QDL_PAD_GPIO_5__KEY_ROW7 0x230 0x600 0x8d4 0x2 0x1 +#define MX6QDL_PAD_GPIO_5__CCM_CLKO1 0x230 0x600 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x230 0x600 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_5__I2C3_SCL 0x230 0x600 0x878 0x6 0x2 +#define MX6QDL_PAD_GPIO_5__ARM_EVENTI 0x230 0x600 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_6__ESAI_TX_CLK 0x234 0x604 0x840 0x0 0x1 +#define MX6QDL_PAD_GPIO_6__ENET_IRQ 0x234 0x604 0x03c 0x11 0xff000609 +#define MX6QDL_PAD_GPIO_6__I2C3_SDA 0x234 0x604 0x87c 0x2 0x2 +#define MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x234 0x604 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_6__SD2_LCTL 0x234 0x604 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_6__MLB_SIG 0x234 0x604 0x8e4 0x7 0x1 +#define MX6QDL_PAD_GPIO_7__ESAI_TX4_RX1 0x238 0x608 0x854 0x0 0x1 +#define MX6QDL_PAD_GPIO_7__EPIT1_OUT 0x238 0x608 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x238 0x608 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_TX_DATA 0x238 0x608 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_RX_DATA 0x238 0x608 0x904 0x4 0x2 +#define MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x238 0x608 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_7__SPDIF_LOCK 0x238 0x608 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_7__USB_OTG_HOST_MODE 0x238 0x608 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_7__I2C4_SCL 0x238 0x608 0x880 0x8 0x1 +#define MX6QDL_PAD_GPIO_8__ESAI_TX5_RX0 0x23c 0x60c 0x858 0x0 0x1 +#define MX6QDL_PAD_GPIO_8__XTALOSC_REF_CLK_32K 0x23c 0x60c 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_8__EPIT2_OUT 0x23c 0x60c 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x23c 0x60c 0x7c8 0x3 0x0 +#define MX6QDL_PAD_GPIO_8__UART2_RX_DATA 0x23c 0x60c 0x904 0x4 0x3 +#define MX6QDL_PAD_GPIO_8__UART2_TX_DATA 0x23c 0x60c 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x23c 0x60c 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_8__SPDIF_SR_CLK 0x23c 0x60c 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE 0x23c 0x60c 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_8__I2C4_SDA 0x23c 0x60c 0x884 0x8 0x1 +#define MX6QDL_PAD_GPIO_9__ESAI_RX_FS 0x240 0x610 0x82c 0x0 0x1 +#define MX6QDL_PAD_GPIO_9__WDOG1_B 0x240 0x610 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_9__KEY_COL6 0x240 0x610 0x8c4 0x2 0x1 +#define MX6QDL_PAD_GPIO_9__CCM_REF_EN_B 0x240 0x610 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_9__PWM1_OUT 0x240 0x610 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_9__GPIO1_IO09 0x240 0x610 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_9__SD1_WP 0x240 0x610 0x92c 0x6 0x1 +#define MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x244 0x62c 0x7d8 0x0 0x3 +#define MX6QDL_PAD_KEY_COL0__ENET_RX_DATA3 0x244 0x62c 0x824 0x1 0x0 +#define MX6QDL_PAD_KEY_COL0__AUD5_TXC 0x244 0x62c 0x7c0 0x2 0x1 +#define MX6QDL_PAD_KEY_COL0__KEY_COL0 0x244 0x62c 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x244 0x62c 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_RX_DATA 0x244 0x62c 0x914 0x4 0x2 +#define MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x244 0x62c 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL0__DCIC1_OUT 0x244 0x62c 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x248 0x630 0x7dc 0x0 0x3 +#define MX6QDL_PAD_KEY_COL1__ENET_MDIO 0x248 0x630 0x810 0x1 0x1 +#define MX6QDL_PAD_KEY_COL1__AUD5_TXFS 0x248 0x630 0x7c4 0x2 0x1 +#define MX6QDL_PAD_KEY_COL1__KEY_COL1 0x248 0x630 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_TX_DATA 0x248 0x630 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_RX_DATA 0x248 0x630 0x91c 0x4 0x2 +#define MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x248 0x630 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL1__SD1_VSELECT 0x248 0x630 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL2__ECSPI1_SS1 0x24c 0x634 0x7e8 0x0 0x2 +#define MX6QDL_PAD_KEY_COL2__ENET_RX_DATA2 0x24c 0x634 0x820 0x1 0x0 +#define MX6QDL_PAD_KEY_COL2__FLEXCAN1_TX 0x24c 0x634 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_COL2__KEY_COL2 0x24c 0x634 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL2__ENET_MDC 0x24c 0x634 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL2__GPIO4_IO10 0x24c 0x634 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE 0x24c 0x634 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL3__ECSPI1_SS3 0x250 0x638 0x7f0 0x0 0x1 +#define MX6QDL_PAD_KEY_COL3__ENET_CRS 0x250 0x638 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x250 0x638 0x860 0x2 0x1 +#define MX6QDL_PAD_KEY_COL3__KEY_COL3 0x250 0x638 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x250 0x638 0x870 0x4 0x1 +#define MX6QDL_PAD_KEY_COL3__GPIO4_IO12 0x250 0x638 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL3__SPDIF_IN 0x250 0x638 0x8f0 0x6 0x3 +#define MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x254 0x63c 0x000 0x0 0x0 +#define MX6QDL_PAD_KEY_COL4__IPU1_SISG4 0x254 0x63c 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x254 0x63c 0x920 0x2 0x1 +#define MX6QDL_PAD_KEY_COL4__KEY_COL4 0x254 0x63c 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL4__UART5_RTS_B 0x254 0x63c 0x918 0x4 0x2 +#define MX6QDL_PAD_KEY_COL4__UART5_CTS_B 0x254 0x63c 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL4__GPIO4_IO14 0x254 0x63c 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x258 0x640 0x7e0 0x0 0x3 +#define MX6QDL_PAD_KEY_ROW0__ENET_TX_DATA3 0x258 0x640 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW0__AUD5_TXD 0x258 0x640 0x7b4 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW0__KEY_ROW0 0x258 0x640 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x258 0x640 0x914 0x4 0x3 +#define MX6QDL_PAD_KEY_ROW0__UART4_TX_DATA 0x258 0x640 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x258 0x640 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW0__DCIC2_OUT 0x258 0x640 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW1__ECSPI1_SS0 0x25c 0x644 0x7e4 0x0 0x3 +#define MX6QDL_PAD_KEY_ROW1__ENET_COL 0x25c 0x644 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW1__AUD5_RXD 0x25c 0x644 0x7b0 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW1__KEY_ROW1 0x25c 0x644 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW1__UART5_RX_DATA 0x25c 0x644 0x91c 0x4 0x3 +#define MX6QDL_PAD_KEY_ROW1__UART5_TX_DATA 0x25c 0x644 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x25c 0x644 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW1__SD2_VSELECT 0x25c 0x644 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW2__ECSPI1_SS2 0x260 0x648 0x7ec 0x0 0x1 +#define MX6QDL_PAD_KEY_ROW2__ENET_TX_DATA2 0x260 0x648 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW2__FLEXCAN1_RX 0x260 0x648 0x7c8 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW2__KEY_ROW2 0x260 0x648 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW2__SD2_VSELECT 0x260 0x648 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW2__GPIO4_IO11 0x260 0x648 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x260 0x648 0x85c 0x6 0x1 +#define MX6QDL_PAD_KEY_ROW3__ASRC_EXT_CLK 0x264 0x64c 0x794 0x1 0x2 +#define MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA 0x264 0x64c 0x864 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW3__KEY_ROW3 0x264 0x64c 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x264 0x64c 0x874 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW3__GPIO4_IO13 0x264 0x64c 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW3__SD1_VSELECT 0x264 0x64c 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x268 0x650 0x7cc 0x0 0x0 +#define MX6QDL_PAD_KEY_ROW4__IPU1_SISG5 0x268 0x650 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW4__USB_OTG_PWR 0x268 0x650 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_ROW4__KEY_ROW4 0x268 0x650 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_CTS_B 0x268 0x650 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_RTS_B 0x268 0x650 0x918 0x4 0x3 +#define MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x268 0x650 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_ALE__NAND_ALE 0x26c 0x654 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_ALE__SD4_RESET 0x26c 0x654 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_ALE__GPIO6_IO08 0x26c 0x654 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CLE__NAND_CLE 0x270 0x658 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CLE__GPIO6_IO07 0x270 0x658 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0x274 0x65c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS0__GPIO6_IO11 0x274 0x65c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS1__NAND_CE1_B 0x278 0x660 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD4_VSELECT 0x278 0x660 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD3_VSELECT 0x278 0x660 0x000 0x2 0x0 +#define MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x278 0x660 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS2__NAND_CE2_B 0x27c 0x664 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS2__IPU1_SISG0 0x27c 0x664 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS2__ESAI_TX0 0x27c 0x664 0x844 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS2__EIM_CRE 0x27c 0x664 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS2__CCM_CLKO2 0x27c 0x664 0x000 0x4 0x0 +#define MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x27c 0x664 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS3__NAND_CE3_B 0x280 0x668 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS3__IPU1_SISG1 0x280 0x668 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS3__ESAI_TX1 0x280 0x668 0x848 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS3__EIM_ADDR26 0x280 0x668 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x280 0x668 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS3__I2C4_SDA 0x280 0x668 0x884 0x9 0x2 +#define MX6QDL_PAD_NANDF_D0__NAND_DATA00 0x284 0x66c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D0__SD1_DATA4 0x284 0x66c 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x284 0x66c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D1__NAND_DATA01 0x288 0x670 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D1__SD1_DATA5 0x288 0x670 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x288 0x670 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D2__NAND_DATA02 0x28c 0x674 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D2__SD1_DATA6 0x28c 0x674 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x28c 0x674 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D3__NAND_DATA03 0x290 0x678 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D3__SD1_DATA7 0x290 0x678 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D3__GPIO2_IO03 0x290 0x678 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D4__NAND_DATA04 0x294 0x67c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x294 0x67c 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x294 0x67c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D5__NAND_DATA05 0x298 0x680 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x298 0x680 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x298 0x680 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D6__NAND_DATA06 0x29c 0x684 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x29c 0x684 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D6__GPIO2_IO06 0x29c 0x684 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D7__NAND_DATA07 0x2a0 0x688 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x2a0 0x688 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D7__GPIO2_IO07 0x2a0 0x688 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0x2a4 0x68c 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_RB0__GPIO6_IO10 0x2a4 0x68c 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0x2a8 0x690 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_WP_B__GPIO6_IO09 0x2a8 0x690 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_WP_B__I2C4_SCL 0x2a8 0x690 0x880 0x9 0x2 +#define MX6QDL_PAD_RGMII_RD0__HSI_RX_READY 0x2ac 0x694 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x2ac 0x694 0x818 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD0__GPIO6_IO25 0x2ac 0x694 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD1__HSI_TX_FLAG 0x2b0 0x698 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x2b0 0x698 0x81c 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD1__GPIO6_IO27 0x2b0 0x698 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD2__HSI_TX_DATA 0x2b4 0x69c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x2b4 0x69c 0x820 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD2__GPIO6_IO28 0x2b4 0x69c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD3__HSI_TX_WAKE 0x2b8 0x6a0 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x2b8 0x6a0 0x824 0x1 0x1 +#define MX6QDL_PAD_RGMII_RD3__GPIO6_IO29 0x2b8 0x6a0 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__USB_H3_DATA 0x2bc 0x6a4 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x2bc 0x6a4 0x828 0x1 0x1 +#define MX6QDL_PAD_RGMII_RX_CTL__GPIO6_IO24 0x2bc 0x6a4 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RXC__USB_H3_STROBE 0x2c0 0x6a8 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x2c0 0x6a8 0x814 0x1 0x1 +#define MX6QDL_PAD_RGMII_RXC__GPIO6_IO30 0x2c0 0x6a8 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD0__HSI_TX_READY 0x2c4 0x6ac 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x2c4 0x6ac 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD0__GPIO6_IO20 0x2c4 0x6ac 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD1__HSI_RX_FLAG 0x2c8 0x6b0 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x2c8 0x6b0 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD1__GPIO6_IO21 0x2c8 0x6b0 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD2__HSI_RX_DATA 0x2cc 0x6b4 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x2cc 0x6b4 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD2__GPIO6_IO22 0x2cc 0x6b4 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD3__HSI_RX_WAKE 0x2d0 0x6b8 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x2d0 0x6b8 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD3__GPIO6_IO23 0x2d0 0x6b8 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x2d4 0x6bc 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x2d4 0x6bc 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__GPIO6_IO26 0x2d4 0x6bc 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__ENET_REF_CLK 0x2d4 0x6bc 0x80c 0x7 0x1 +#define MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x2d8 0x6c0 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x2d8 0x6c0 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TXC__SPDIF_EXT_CLK 0x2d8 0x6c0 0x8f4 0x2 0x1 +#define MX6QDL_PAD_RGMII_TXC__GPIO6_IO19 0x2d8 0x6c0 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M 0x2d8 0x6c0 0x000 0x7 0x0 +#define MX6QDL_PAD_SD1_CLK__SD1_CLK 0x2dc 0x6c4 0x928 0x0 0x1 +#define MX6QDL_PAD_SD1_CLK__OSC32K_32K_OUT 0x2dc 0x6c4 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CLK__GPT_CLKIN 0x2dc 0x6c4 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x2dc 0x6c4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_CMD__SD1_CMD 0x2e0 0x6c8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_CMD__PWM4_OUT 0x2e0 0x6c8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CMD__GPT_COMPARE1 0x2e0 0x6c8 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x2e0 0x6c8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x2e4 0x6cc 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT0__GPT_CAPTURE1 0x2e4 0x6cc 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x2e4 0x6cc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x2e8 0x6d0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT1__PWM3_OUT 0x2e8 0x6d0 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPT_CAPTURE2 0x2e8 0x6d0 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x2e8 0x6d0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x2ec 0x6d4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT2__GPT_COMPARE2 0x2ec 0x6d4 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT2__PWM2_OUT 0x2ec 0x6d4 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_B 0x2ec 0x6d4 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x2ec 0x6d4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_RESET_B_DEB 0x2ec 0x6d4 0x000 0x6 0x0 +#define MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x2f0 0x6d8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPT_COMPARE3 0x2f0 0x6d8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x2f0 0x6d8 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_B 0x2f0 0x6d8 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPIO1_IO21 0x2f0 0x6d8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_RESET_B_DEB 0x2f0 0x6d8 0x000 0x6 0x0 +#define MX6QDL_PAD_SD2_CLK__SD2_CLK 0x2f4 0x6dc 0x930 0x0 0x1 +#define MX6QDL_PAD_SD2_CLK__KEY_COL5 0x2f4 0x6dc 0x8c0 0x2 0x3 +#define MX6QDL_PAD_SD2_CLK__AUD4_RXFS 0x2f4 0x6dc 0x7a4 0x3 0x1 +#define MX6QDL_PAD_SD2_CLK__GPIO1_IO10 0x2f4 0x6dc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_CMD__SD2_CMD 0x2f8 0x6e0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_CMD__KEY_ROW5 0x2f8 0x6e0 0x8cc 0x2 0x2 +#define MX6QDL_PAD_SD2_CMD__AUD4_RXC 0x2f8 0x6e0 0x7a0 0x3 0x1 +#define MX6QDL_PAD_SD2_CMD__GPIO1_IO11 0x2f8 0x6e0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x2fc 0x6e4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT0__AUD4_RXD 0x2fc 0x6e4 0x798 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT0__KEY_ROW7 0x2fc 0x6e4 0x8d4 0x4 0x2 +#define MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 0x2fc 0x6e4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__DCIC2_OUT 0x2fc 0x6e4 0x000 0x6 0x0 +#define MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x300 0x6e8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT1__EIM_CS2_B 0x300 0x6e8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT1__AUD4_TXFS 0x300 0x6e8 0x7ac 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT1__KEY_COL7 0x300 0x6e8 0x8c8 0x4 0x2 +#define MX6QDL_PAD_SD2_DAT1__GPIO1_IO14 0x300 0x6e8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x304 0x6ec 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT2__EIM_CS3_B 0x304 0x6ec 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT2__AUD4_TXD 0x304 0x6ec 0x79c 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT2__KEY_ROW6 0x304 0x6ec 0x8d0 0x4 0x2 +#define MX6QDL_PAD_SD2_DAT2__GPIO1_IO13 0x304 0x6ec 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x308 0x6f0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT3__KEY_COL6 0x308 0x6f0 0x8c4 0x2 0x2 +#define MX6QDL_PAD_SD2_DAT3__AUD4_TXC 0x308 0x6f0 0x7a8 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 0x308 0x6f0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CLK__SD3_CLK 0x30c 0x6f4 0x934 0x0 0x1 +#define MX6QDL_PAD_SD3_CLK__UART2_RTS_B 0x30c 0x6f4 0x900 0x1 0x2 +#define MX6QDL_PAD_SD3_CLK__UART2_CTS_B 0x30c 0x6f4 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CLK__FLEXCAN1_RX 0x30c 0x6f4 0x7c8 0x2 0x2 +#define MX6QDL_PAD_SD3_CLK__GPIO7_IO03 0x30c 0x6f4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CMD__SD3_CMD 0x310 0x6f8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_CTS_B 0x310 0x6f8 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_RTS_B 0x310 0x6f8 0x900 0x1 0x3 +#define MX6QDL_PAD_SD3_CMD__FLEXCAN1_TX 0x310 0x6f8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_CMD__GPIO7_IO02 0x310 0x6f8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x314 0x6fc 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_CTS_B 0x314 0x6fc 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_RTS_B 0x314 0x6fc 0x8f8 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT0__FLEXCAN2_TX 0x314 0x6fc 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_DAT0__GPIO7_IO04 0x314 0x6fc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x318 0x700 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT1__UART1_RTS_B 0x318 0x700 0x8f8 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT1__UART1_CTS_B 0x318 0x700 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT1__FLEXCAN2_RX 0x318 0x700 0x7cc 0x2 0x1 +#define MX6QDL_PAD_SD3_DAT1__GPIO7_IO05 0x318 0x700 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x31c 0x704 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT2__GPIO7_IO06 0x31c 0x704 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x320 0x708 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_CTS_B 0x320 0x708 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_RTS_B 0x320 0x708 0x908 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT3__GPIO7_IO07 0x320 0x708 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x324 0x70c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT4__UART2_RX_DATA 0x324 0x70c 0x904 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT4__UART2_TX_DATA 0x324 0x70c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x324 0x70c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x328 0x710 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_TX_DATA 0x328 0x710 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_RX_DATA 0x328 0x710 0x904 0x1 0x5 +#define MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x328 0x710 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x32c 0x714 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x32c 0x714 0x8fc 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT6__UART1_TX_DATA 0x32c 0x714 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT6__GPIO6_IO18 0x32c 0x714 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x330 0x718 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x330 0x718 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_RX_DATA 0x330 0x718 0x8fc 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT7__GPIO6_IO17 0x330 0x718 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_RST__SD3_RESET 0x334 0x71c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_RST__UART3_RTS_B 0x334 0x71c 0x908 0x1 0x5 +#define MX6QDL_PAD_SD3_RST__UART3_CTS_B 0x334 0x71c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x334 0x71c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_CLK__SD4_CLK 0x338 0x720 0x938 0x0 0x1 +#define MX6QDL_PAD_SD4_CLK__NAND_WE_B 0x338 0x720 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CLK__UART3_RX_DATA 0x338 0x720 0x90c 0x2 0x2 +#define MX6QDL_PAD_SD4_CLK__UART3_TX_DATA 0x338 0x720 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CLK__GPIO7_IO10 0x338 0x720 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_CMD__SD4_CMD 0x33c 0x724 0x000 0x0 0x0 +#define MX6QDL_PAD_SD4_CMD__NAND_RE_B 0x33c 0x724 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_TX_DATA 0x33c 0x724 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_RX_DATA 0x33c 0x724 0x90c 0x2 0x3 +#define MX6QDL_PAD_SD4_CMD__GPIO7_IO09 0x33c 0x724 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x340 0x728 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT0__NAND_DQS 0x340 0x728 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT0__GPIO2_IO08 0x340 0x728 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x344 0x72c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x344 0x72c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT1__GPIO2_IO09 0x344 0x72c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x348 0x730 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT2__PWM4_OUT 0x348 0x730 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT2__GPIO2_IO10 0x348 0x730 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x34c 0x734 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT3__GPIO2_IO11 0x34c 0x734 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x350 0x738 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x350 0x738 0x904 0x2 0x6 +#define MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA 0x350 0x738 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT4__GPIO2_IO12 0x350 0x738 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x354 0x73c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT5__UART2_RTS_B 0x354 0x73c 0x900 0x2 0x4 +#define MX6QDL_PAD_SD4_DAT5__UART2_CTS_B 0x354 0x73c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT5__GPIO2_IO13 0x354 0x73c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x358 0x740 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_CTS_B 0x358 0x740 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_RTS_B 0x358 0x740 0x900 0x2 0x5 +#define MX6QDL_PAD_SD4_DAT6__GPIO2_IO14 0x358 0x740 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x35c 0x744 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA 0x35c 0x744 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA 0x35c 0x744 0x904 0x2 0x7 +#define MX6QDL_PAD_SD4_DAT7__GPIO2_IO15 0x35c 0x744 0x000 0x5 0x0 + +#endif /* __DTS_IMX6DL_PINFUNC_H */
Add imx6qdl clock header defines support from Linux.
"clk: imx: Add clock support for imx6qp" (sha1: ee36027427c769b0b9e5e205fe43aced93d6aa66)
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/dt-bindings/clock/imx6qdl-clock.h | 274 ++++++++++++++++++++++++++++++ 1 file changed, 274 insertions(+) create mode 100644 include/dt-bindings/clock/imx6qdl-clock.h
diff --git a/include/dt-bindings/clock/imx6qdl-clock.h b/include/dt-bindings/clock/imx6qdl-clock.h new file mode 100644 index 0000000..2905033 --- /dev/null +++ b/include/dt-bindings/clock/imx6qdl-clock.h @@ -0,0 +1,274 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef __DT_BINDINGS_CLOCK_IMX6QDL_H +#define __DT_BINDINGS_CLOCK_IMX6QDL_H + +#define IMX6QDL_CLK_DUMMY 0 +#define IMX6QDL_CLK_CKIL 1 +#define IMX6QDL_CLK_CKIH 2 +#define IMX6QDL_CLK_OSC 3 +#define IMX6QDL_CLK_PLL2_PFD0_352M 4 +#define IMX6QDL_CLK_PLL2_PFD1_594M 5 +#define IMX6QDL_CLK_PLL2_PFD2_396M 6 +#define IMX6QDL_CLK_PLL3_PFD0_720M 7 +#define IMX6QDL_CLK_PLL3_PFD1_540M 8 +#define IMX6QDL_CLK_PLL3_PFD2_508M 9 +#define IMX6QDL_CLK_PLL3_PFD3_454M 10 +#define IMX6QDL_CLK_PLL2_198M 11 +#define IMX6QDL_CLK_PLL3_120M 12 +#define IMX6QDL_CLK_PLL3_80M 13 +#define IMX6QDL_CLK_PLL3_60M 14 +#define IMX6QDL_CLK_TWD 15 +#define IMX6QDL_CLK_STEP 16 +#define IMX6QDL_CLK_PLL1_SW 17 +#define IMX6QDL_CLK_PERIPH_PRE 18 +#define IMX6QDL_CLK_PERIPH2_PRE 19 +#define IMX6QDL_CLK_PERIPH_CLK2_SEL 20 +#define IMX6QDL_CLK_PERIPH2_CLK2_SEL 21 +#define IMX6QDL_CLK_AXI_SEL 22 +#define IMX6QDL_CLK_ESAI_SEL 23 +#define IMX6QDL_CLK_ASRC_SEL 24 +#define IMX6QDL_CLK_SPDIF_SEL 25 +#define IMX6QDL_CLK_GPU2D_AXI 26 +#define IMX6QDL_CLK_GPU3D_AXI 27 +#define IMX6QDL_CLK_GPU2D_CORE_SEL 28 +#define IMX6QDL_CLK_GPU3D_CORE_SEL 29 +#define IMX6QDL_CLK_GPU3D_SHADER_SEL 30 +#define IMX6QDL_CLK_IPU1_SEL 31 +#define IMX6QDL_CLK_IPU2_SEL 32 +#define IMX6QDL_CLK_LDB_DI0_SEL 33 +#define IMX6QDL_CLK_LDB_DI1_SEL 34 +#define IMX6QDL_CLK_IPU1_DI0_PRE_SEL 35 +#define IMX6QDL_CLK_IPU1_DI1_PRE_SEL 36 +#define IMX6QDL_CLK_IPU2_DI0_PRE_SEL 37 +#define IMX6QDL_CLK_IPU2_DI1_PRE_SEL 38 +#define IMX6QDL_CLK_IPU1_DI0_SEL 39 +#define IMX6QDL_CLK_IPU1_DI1_SEL 40 +#define IMX6QDL_CLK_IPU2_DI0_SEL 41 +#define IMX6QDL_CLK_IPU2_DI1_SEL 42 +#define IMX6QDL_CLK_HSI_TX_SEL 43 +#define IMX6QDL_CLK_PCIE_AXI_SEL 44 +#define IMX6QDL_CLK_SSI1_SEL 45 +#define IMX6QDL_CLK_SSI2_SEL 46 +#define IMX6QDL_CLK_SSI3_SEL 47 +#define IMX6QDL_CLK_USDHC1_SEL 48 +#define IMX6QDL_CLK_USDHC2_SEL 49 +#define IMX6QDL_CLK_USDHC3_SEL 50 +#define IMX6QDL_CLK_USDHC4_SEL 51 +#define IMX6QDL_CLK_ENFC_SEL 52 +#define IMX6QDL_CLK_EIM_SEL 53 +#define IMX6QDL_CLK_EIM_SLOW_SEL 54 +#define IMX6QDL_CLK_VDO_AXI_SEL 55 +#define IMX6QDL_CLK_VPU_AXI_SEL 56 +#define IMX6QDL_CLK_CKO1_SEL 57 +#define IMX6QDL_CLK_PERIPH 58 +#define IMX6QDL_CLK_PERIPH2 59 +#define IMX6QDL_CLK_PERIPH_CLK2 60 +#define IMX6QDL_CLK_PERIPH2_CLK2 61 +#define IMX6QDL_CLK_IPG 62 +#define IMX6QDL_CLK_IPG_PER 63 +#define IMX6QDL_CLK_ESAI_PRED 64 +#define IMX6QDL_CLK_ESAI_PODF 65 +#define IMX6QDL_CLK_ASRC_PRED 66 +#define IMX6QDL_CLK_ASRC_PODF 67 +#define IMX6QDL_CLK_SPDIF_PRED 68 +#define IMX6QDL_CLK_SPDIF_PODF 69 +#define IMX6QDL_CLK_CAN_ROOT 70 +#define IMX6QDL_CLK_ECSPI_ROOT 71 +#define IMX6QDL_CLK_GPU2D_CORE_PODF 72 +#define IMX6QDL_CLK_GPU3D_CORE_PODF 73 +#define IMX6QDL_CLK_GPU3D_SHADER 74 +#define IMX6QDL_CLK_IPU1_PODF 75 +#define IMX6QDL_CLK_IPU2_PODF 76 +#define IMX6QDL_CLK_LDB_DI0_PODF 77 +#define IMX6QDL_CLK_LDB_DI1_PODF 78 +#define IMX6QDL_CLK_IPU1_DI0_PRE 79 +#define IMX6QDL_CLK_IPU1_DI1_PRE 80 +#define IMX6QDL_CLK_IPU2_DI0_PRE 81 +#define IMX6QDL_CLK_IPU2_DI1_PRE 82 +#define IMX6QDL_CLK_HSI_TX_PODF 83 +#define IMX6QDL_CLK_SSI1_PRED 84 +#define IMX6QDL_CLK_SSI1_PODF 85 +#define IMX6QDL_CLK_SSI2_PRED 86 +#define IMX6QDL_CLK_SSI2_PODF 87 +#define IMX6QDL_CLK_SSI3_PRED 88 +#define IMX6QDL_CLK_SSI3_PODF 89 +#define IMX6QDL_CLK_UART_SERIAL_PODF 90 +#define IMX6QDL_CLK_USDHC1_PODF 91 +#define IMX6QDL_CLK_USDHC2_PODF 92 +#define IMX6QDL_CLK_USDHC3_PODF 93 +#define IMX6QDL_CLK_USDHC4_PODF 94 +#define IMX6QDL_CLK_ENFC_PRED 95 +#define IMX6QDL_CLK_ENFC_PODF 96 +#define IMX6QDL_CLK_EIM_PODF 97 +#define IMX6QDL_CLK_EIM_SLOW_PODF 98 +#define IMX6QDL_CLK_VPU_AXI_PODF 99 +#define IMX6QDL_CLK_CKO1_PODF 100 +#define IMX6QDL_CLK_AXI 101 +#define IMX6QDL_CLK_MMDC_CH0_AXI_PODF 102 +#define IMX6QDL_CLK_MMDC_CH1_AXI_PODF 103 +#define IMX6QDL_CLK_ARM 104 +#define IMX6QDL_CLK_AHB 105 +#define IMX6QDL_CLK_APBH_DMA 106 +#define IMX6QDL_CLK_ASRC 107 +#define IMX6QDL_CLK_CAN1_IPG 108 +#define IMX6QDL_CLK_CAN1_SERIAL 109 +#define IMX6QDL_CLK_CAN2_IPG 110 +#define IMX6QDL_CLK_CAN2_SERIAL 111 +#define IMX6QDL_CLK_ECSPI1 112 +#define IMX6QDL_CLK_ECSPI2 113 +#define IMX6QDL_CLK_ECSPI3 114 +#define IMX6QDL_CLK_ECSPI4 115 +#define IMX6Q_CLK_ECSPI5 116 +#define IMX6DL_CLK_I2C4 116 +#define IMX6QDL_CLK_ENET 117 +#define IMX6QDL_CLK_ESAI_EXTAL 118 +#define IMX6QDL_CLK_GPT_IPG 119 +#define IMX6QDL_CLK_GPT_IPG_PER 120 +#define IMX6QDL_CLK_GPU2D_CORE 121 +#define IMX6QDL_CLK_GPU3D_CORE 122 +#define IMX6QDL_CLK_HDMI_IAHB 123 +#define IMX6QDL_CLK_HDMI_ISFR 124 +#define IMX6QDL_CLK_I2C1 125 +#define IMX6QDL_CLK_I2C2 126 +#define IMX6QDL_CLK_I2C3 127 +#define IMX6QDL_CLK_IIM 128 +#define IMX6QDL_CLK_ENFC 129 +#define IMX6QDL_CLK_IPU1 130 +#define IMX6QDL_CLK_IPU1_DI0 131 +#define IMX6QDL_CLK_IPU1_DI1 132 +#define IMX6QDL_CLK_IPU2 133 +#define IMX6QDL_CLK_IPU2_DI0 134 +#define IMX6QDL_CLK_LDB_DI0 135 +#define IMX6QDL_CLK_LDB_DI1 136 +#define IMX6QDL_CLK_IPU2_DI1 137 +#define IMX6QDL_CLK_HSI_TX 138 +#define IMX6QDL_CLK_MLB 139 +#define IMX6QDL_CLK_MMDC_CH0_AXI 140 +#define IMX6QDL_CLK_MMDC_CH1_AXI 141 +#define IMX6QDL_CLK_OCRAM 142 +#define IMX6QDL_CLK_OPENVG_AXI 143 +#define IMX6QDL_CLK_PCIE_AXI 144 +#define IMX6QDL_CLK_PWM1 145 +#define IMX6QDL_CLK_PWM2 146 +#define IMX6QDL_CLK_PWM3 147 +#define IMX6QDL_CLK_PWM4 148 +#define IMX6QDL_CLK_PER1_BCH 149 +#define IMX6QDL_CLK_GPMI_BCH_APB 150 +#define IMX6QDL_CLK_GPMI_BCH 151 +#define IMX6QDL_CLK_GPMI_IO 152 +#define IMX6QDL_CLK_GPMI_APB 153 +#define IMX6QDL_CLK_SATA 154 +#define IMX6QDL_CLK_SDMA 155 +#define IMX6QDL_CLK_SPBA 156 +#define IMX6QDL_CLK_SSI1 157 +#define IMX6QDL_CLK_SSI2 158 +#define IMX6QDL_CLK_SSI3 159 +#define IMX6QDL_CLK_UART_IPG 160 +#define IMX6QDL_CLK_UART_SERIAL 161 +#define IMX6QDL_CLK_USBOH3 162 +#define IMX6QDL_CLK_USDHC1 163 +#define IMX6QDL_CLK_USDHC2 164 +#define IMX6QDL_CLK_USDHC3 165 +#define IMX6QDL_CLK_USDHC4 166 +#define IMX6QDL_CLK_VDO_AXI 167 +#define IMX6QDL_CLK_VPU_AXI 168 +#define IMX6QDL_CLK_CKO1 169 +#define IMX6QDL_CLK_PLL1_SYS 170 +#define IMX6QDL_CLK_PLL2_BUS 171 +#define IMX6QDL_CLK_PLL3_USB_OTG 172 +#define IMX6QDL_CLK_PLL4_AUDIO 173 +#define IMX6QDL_CLK_PLL5_VIDEO 174 +#define IMX6QDL_CLK_PLL8_MLB 175 +#define IMX6QDL_CLK_PLL7_USB_HOST 176 +#define IMX6QDL_CLK_PLL6_ENET 177 +#define IMX6QDL_CLK_SSI1_IPG 178 +#define IMX6QDL_CLK_SSI2_IPG 179 +#define IMX6QDL_CLK_SSI3_IPG 180 +#define IMX6QDL_CLK_ROM 181 +#define IMX6QDL_CLK_USBPHY1 182 +#define IMX6QDL_CLK_USBPHY2 183 +#define IMX6QDL_CLK_LDB_DI0_DIV_3_5 184 +#define IMX6QDL_CLK_LDB_DI1_DIV_3_5 185 +#define IMX6QDL_CLK_SATA_REF 186 +#define IMX6QDL_CLK_SATA_REF_100M 187 +#define IMX6QDL_CLK_PCIE_REF 188 +#define IMX6QDL_CLK_PCIE_REF_125M 189 +#define IMX6QDL_CLK_ENET_REF 190 +#define IMX6QDL_CLK_USBPHY1_GATE 191 +#define IMX6QDL_CLK_USBPHY2_GATE 192 +#define IMX6QDL_CLK_PLL4_POST_DIV 193 +#define IMX6QDL_CLK_PLL5_POST_DIV 194 +#define IMX6QDL_CLK_PLL5_VIDEO_DIV 195 +#define IMX6QDL_CLK_EIM_SLOW 196 +#define IMX6QDL_CLK_SPDIF 197 +#define IMX6QDL_CLK_CKO2_SEL 198 +#define IMX6QDL_CLK_CKO2_PODF 199 +#define IMX6QDL_CLK_CKO2 200 +#define IMX6QDL_CLK_CKO 201 +#define IMX6QDL_CLK_VDOA 202 +#define IMX6QDL_CLK_PLL4_AUDIO_DIV 203 +#define IMX6QDL_CLK_LVDS1_SEL 204 +#define IMX6QDL_CLK_LVDS2_SEL 205 +#define IMX6QDL_CLK_LVDS1_GATE 206 +#define IMX6QDL_CLK_LVDS2_GATE 207 +#define IMX6QDL_CLK_ESAI_IPG 208 +#define IMX6QDL_CLK_ESAI_MEM 209 +#define IMX6QDL_CLK_ASRC_IPG 210 +#define IMX6QDL_CLK_ASRC_MEM 211 +#define IMX6QDL_CLK_LVDS1_IN 212 +#define IMX6QDL_CLK_LVDS2_IN 213 +#define IMX6QDL_CLK_ANACLK1 214 +#define IMX6QDL_CLK_ANACLK2 215 +#define IMX6QDL_PLL1_BYPASS_SRC 216 +#define IMX6QDL_PLL2_BYPASS_SRC 217 +#define IMX6QDL_PLL3_BYPASS_SRC 218 +#define IMX6QDL_PLL4_BYPASS_SRC 219 +#define IMX6QDL_PLL5_BYPASS_SRC 220 +#define IMX6QDL_PLL6_BYPASS_SRC 221 +#define IMX6QDL_PLL7_BYPASS_SRC 222 +#define IMX6QDL_CLK_PLL1 223 +#define IMX6QDL_CLK_PLL2 224 +#define IMX6QDL_CLK_PLL3 225 +#define IMX6QDL_CLK_PLL4 226 +#define IMX6QDL_CLK_PLL5 227 +#define IMX6QDL_CLK_PLL6 228 +#define IMX6QDL_CLK_PLL7 229 +#define IMX6QDL_PLL1_BYPASS 230 +#define IMX6QDL_PLL2_BYPASS 231 +#define IMX6QDL_PLL3_BYPASS 232 +#define IMX6QDL_PLL4_BYPASS 233 +#define IMX6QDL_PLL5_BYPASS 234 +#define IMX6QDL_PLL6_BYPASS 235 +#define IMX6QDL_PLL7_BYPASS 236 +#define IMX6QDL_CLK_GPT_3M 237 +#define IMX6QDL_CLK_VIDEO_27M 238 +#define IMX6QDL_CLK_MIPI_CORE_CFG 239 +#define IMX6QDL_CLK_MIPI_IPG 240 +#define IMX6QDL_CLK_CAAM_MEM 241 +#define IMX6QDL_CLK_CAAM_ACLK 242 +#define IMX6QDL_CLK_CAAM_IPG 243 +#define IMX6QDL_CLK_SPDIF_GCLK 244 +#define IMX6QDL_CLK_UART_SEL 245 +#define IMX6QDL_CLK_IPG_PER_SEL 246 +#define IMX6QDL_CLK_ECSPI_SEL 247 +#define IMX6QDL_CLK_CAN_SEL 248 +#define IMX6QDL_CLK_MMDC_CH1_AXI_CG 249 +#define IMX6QDL_CLK_PRE0 250 +#define IMX6QDL_CLK_PRE1 251 +#define IMX6QDL_CLK_PRE2 252 +#define IMX6QDL_CLK_PRE3 253 +#define IMX6QDL_CLK_PRG0_AXI 254 +#define IMX6QDL_CLK_PRG1_AXI 255 +#define IMX6QDL_CLK_PRG0_APB 256 +#define IMX6QDL_CLK_PRG1_APB 257 +#define IMX6QDL_CLK_PRE_AXI 258 +#define IMX6QDL_CLK_END 259 + +#endif /* __DT_BINDINGS_CLOCK_IMX6QDL_H */
i.CoreM6 DualLite/Solo modules are system on module solutions manufactured by Engicam with following characteristics: CPU NXP i.MX6 DL, 800MHz RAM 1GB, 32, 64 bit, DDR3-800/1066 NAND SLC,512MB Power supply Single 5V MAX LCD RES FULLHD
and more info at http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx6dl-icore.dts | 59 +++++++++++ arch/arm/dts/imx6qdl-icore.dtsi | 196 ++++++++++++++++++++++++++++++++++++ board/engicam/icorem6/README | 6 +- configs/imx6qdl_icore_mmc_defconfig | 1 + 6 files changed, 262 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/imx6dl-icore.dts create mode 100644 arch/arm/dts/imx6qdl-icore.dtsi
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 5d549bd..e2431a8 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -98,6 +98,7 @@ config TARGET_MX6QARM2 config TARGET_MX6Q_ICORE bool "Support Engicam i.Core" select MX6QDL + select OF_CONTROL select DM select DM_THERMAL select SUPPORT_SPL diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 19140b4..783352a8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -280,7 +280,8 @@ dtb-$(CONFIG_VF610) += vf500-colibri.dtb \ vf610-twr.dtb \ pcm052.dtb
-dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb +dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ + imx6dl-icore.dtb
dtb-$(CONFIG_SOC_KEYSTONE) += k2hk-evm.dtb \ k2l-evm.dtb \ diff --git a/arch/arm/dts/imx6dl-icore.dts b/arch/arm/dts/imx6dl-icore.dts new file mode 100644 index 0000000..aec332c --- /dev/null +++ b/arch/arm/dts/imx6dl-icore.dts @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-icore.dtsi" + +/ { + model = "Engicam i.CoreM6 DualLite/Solo Starter Kit"; + compatible = "engicam,imx6-icore", "fsl,imx6dl"; +}; + +&can1 { + status = "okay"; +}; + +&can2 { + status = "okay"; +}; diff --git a/arch/arm/dts/imx6qdl-icore.dtsi b/arch/arm/dts/imx6qdl-icore.dtsi new file mode 100644 index 0000000..f424cd5 --- /dev/null +++ b/arch/arm/dts/imx6qdl-icore.dtsi @@ -0,0 +1,196 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + memory { + reg = <0x10000000 0x80000000>; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "3P3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; +}; + +&can1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + xceiver-supply = <®_3p3v>; +}; + +&can2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2>; + xceiver-supply = <®_3p3v>; +}; + +&clks { + assigned-clocks = <&clks IMX6QDL_CLK_LVDS2_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_OSC>; +}; + +&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + nand-on-flash-bbt; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + cd-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>; + no-1-8-v; + status = "okay"; +}; + +&iomuxc { + pinctrl_flexcan1: flexcan1grp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__FLEXCAN1_RX 0x1b020 + MX6QDL_PAD_KEY_COL2__FLEXCAN1_TX 0x1b020 + >; + }; + + pinctrl_flexcan2: flexcan2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x1b020 + MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x1b020 + >; + }; + + pinctrl_gpmi_nand: gpmi-nand { + fsl,pins = < + MX6QDL_PAD_NANDF_CLE__NAND_CLE 0xb0b1 + MX6QDL_PAD_NANDF_ALE__NAND_ALE 0xb0b1 + MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0xb0b1 + MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0xb000 + MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0xb0b1 + MX6QDL_PAD_NANDF_CS1__NAND_CE1_B 0xb0b1 + MX6QDL_PAD_SD4_CMD__NAND_RE_B 0xb0b1 + MX6QDL_PAD_SD4_CLK__NAND_WE_B 0xb0b1 + MX6QDL_PAD_NANDF_D0__NAND_DATA00 0xb0b1 + MX6QDL_PAD_NANDF_D1__NAND_DATA01 0xb0b1 + MX6QDL_PAD_NANDF_D2__NAND_DATA02 0xb0b1 + MX6QDL_PAD_NANDF_D3__NAND_DATA03 0xb0b1 + MX6QDL_PAD_NANDF_D4__NAND_DATA04 0xb0b1 + MX6QDL_PAD_NANDF_D5__NAND_DATA05 0xb0b1 + MX6QDL_PAD_NANDF_D6__NAND_DATA06 0xb0b1 + MX6QDL_PAD_NANDF_D7__NAND_DATA07 0xb0b1 + MX6QDL_PAD_SD4_DAT0__NAND_DQS 0x00b1 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_EIM_D21__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D28__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_5__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1 + MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x130b0 + >; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x1b0b1 + MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__SD1_CMD 0x17070 + MX6QDL_PAD_SD1_CLK__SD1_CLK 0x10070 + MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x17070 + MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x17070 + MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x17070 + MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x17070 + >; + }; +}; diff --git a/board/engicam/icorem6/README b/board/engicam/icorem6/README index cf2eff2..c264a94 100644 --- a/board/engicam/icorem6/README +++ b/board/engicam/icorem6/README @@ -7,15 +7,15 @@ $ make mrproper $ make icorem6qdl_mmc_defconfig $ make
-This will generate the SPL image called SPL and the u-boot.img. +This will generate the SPL image called SPL and the u-boot-dtb.img.
- Flash the SPL image into the micro SD card:
sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync
-- Flash the u-boot.img image into the micro SD card: +- Flash the u-boot-dtb.img image into the micro SD card:
-sudo dd if=u-boot.img of=/dev/mmcblk0 bs=1k seek=69; sync +sudo dd if=u-boot-dtb.img of=/dev/mmcblk0 bs=1k seek=69; sync
- Jumper settings:
diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index c2c2fe8..6786daf 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6Q_ICORE=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" CONFIG_DEFAULT_FDT_FILE="imx6dl-icore.dtb" +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" CONFIG_SYS_PROMPT="icorem6qdl> " CONFIG_SPL=y CONFIG_BOOTDELAY=3
Enable imx6 pinctrl driver support for i.CoreM6.
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/imx6qdl_icore_mmc_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 6786daf..221ea7e 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -30,6 +30,8 @@ CONFIG_FEC_MXC=y CONFIG_MXC_UART=y CONFIG_NETDEVICES=y CONFIG_IMX_THERMAL=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL.
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 2 + board/engicam/icorem6/icorem6.c | 142 ++++++++++++++++++++-------------------- include/configs/imx6qdl_icore.h | 4 ++ 3 files changed, 78 insertions(+), 70 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index e2431a8..762a581 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -100,6 +100,8 @@ config TARGET_MX6Q_ICORE select MX6QDL select OF_CONTROL select DM + select DM_GPIO + select DM_MMC select DM_THERMAL select SUPPORT_SPL
diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index a23cb7e..a370c8b 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -7,8 +7,6 @@ */
#include <common.h> -#include <fsl_esdhc.h> -#include <mmc.h> #include <miiphy.h> #include <netdev.h>
@@ -29,10 +27,6 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ - PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) - #define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_HYS) @@ -55,70 +49,6 @@ static iomux_v3_cfg_t const enet_pads[] = { IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
-static iomux_v3_cfg_t const usdhc1_pads[] = { - IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | MUX_PAD_CTRL(NO_PAD_CTRL)),/* CD */ -}; - -#ifdef CONFIG_FSL_ESDHC -#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 1) - -struct fsl_esdhc_cfg usdhc_cfg[1] = { - {USDHC1_BASE_ADDR, 0, 4}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret = 0; - - switch (cfg->esdhc_base) { - case USDHC1_BASE_ADDR: - ret = !gpio_get_value(USDHC1_CD_GPIO); - break; - } - - return ret; -} - -int board_mmc_init(bd_t *bis) -{ - int i, ret; - - /* - * According to the board_mmc_init() the following map is done: - * (U-boot device node) (Physical Port) - * mmc0 USDHC1 - */ - for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { - switch (i) { - case 0: - SETUP_IOMUX_PADS(usdhc1_pads); - gpio_direction_input(USDHC1_CD_GPIO); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - break; - default: - printf("Warning - USDHC%d controller not supporting\n", - i + 1); - return 0; - } - - ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); - if (ret) { - printf("Warning: failed to initialize mmc dev %d\n", i); - return ret; - } - } - - return 0; -} -#endif - #ifdef CONFIG_FEC_MXC #define ENET_PHY_RST IMX_GPIO_NR(7, 12) static int setup_fec(void) @@ -200,6 +130,78 @@ int dram_init(void) #include <asm/arch/crm_regs.h> #include <asm/arch/mx6-ddr.h>
+/* MMC board initialization is needed till adding DM support in SPL */ +#if defined(CONFIG_FSL_ESDHC) && !defined(CONFIG_DM_MMC) +#include <mmc.h> +#include <fsl_esdhc.h> + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | MUX_PAD_CTRL(NO_PAD_CTRL)),/* CD */ +}; + +#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 1) + +struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC1_BASE_ADDR, 0, 4}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + SETUP_IOMUX_PADS(usdhc1_pads); + gpio_direction_input(USDHC1_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + default: + printf("Warning - USDHC%d controller not supporting\n", + i + 1); + return 0; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + + return 0; +} +#endif + /* * Driving strength: * 0x30 == 40 Ohm diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index ad4c5f2..6b58447 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -127,6 +127,10 @@ #ifdef CONFIG_SPL # define CONFIG_SPL_MMC_SUPPORT # include "imx6_spl.h" +# ifdef CONFIG_SPL_BUILD +# undef CONFIG_DM_GPIO +# undef CONFIG_DM_MMC +# endif #endif
#endif /* __IMX6QLD_ICORE_CONFIG_H */
Add i.MX6Q dtsi support from Linux.
Here is the last commit: "ARM: dts: add gpio-ranges property to iMX GPIO controllers" (sha1: bb728d662bed0fe91b152550e640cb3f6caa972c)
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6q.dtsi | 300 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 300 insertions(+) create mode 100644 arch/arm/dts/imx6q.dtsi
diff --git a/arch/arm/dts/imx6q.dtsi b/arch/arm/dts/imx6q.dtsi new file mode 100644 index 0000000..c30c836 --- /dev/null +++ b/arch/arm/dts/imx6q.dtsi @@ -0,0 +1,300 @@ + +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include "imx6q-pinfunc.h" +#include "imx6qdl.dtsi" + +/ { + aliases { + ipu1 = &ipu2; + spi4 = &ecspi5; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <0>; + next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 975000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; + }; + + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <1>; + next-level-cache = <&L2>; + }; + + cpu@2 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <2>; + next-level-cache = <&L2>; + }; + + cpu@3 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <3>; + next-level-cache = <&L2>; + }; + }; + + soc { + ocram: sram@00900000 { + compatible = "mmio-sram"; + reg = <0x00900000 0x40000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + aips-bus@02000000 { /* AIPS1 */ + spba-bus@02000000 { + ecspi5: ecspi@02018000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; + reg = <0x02018000 0x4000>; + interrupts = <0 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6Q_CLK_ECSPI5>, + <&clks IMX6Q_CLK_ECSPI5>; + clock-names = "ipg", "per"; + dmas = <&sdma 11 7 1>, <&sdma 12 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + }; + + iomuxc: iomuxc@020e0000 { + compatible = "fsl,imx6q-iomuxc"; + }; + }; + + sata: sata@02200000 { + compatible = "fsl,imx6q-ahci"; + reg = <0x02200000 0x4000>; + interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_SATA>, + <&clks IMX6QDL_CLK_SATA_REF_100M>, + <&clks IMX6QDL_CLK_AHB>; + clock-names = "sata", "sata_ref", "ahb"; + status = "disabled"; + }; + + gpu_vg: gpu@02204000 { + compatible = "vivante,gc"; + reg = <0x02204000 0x4000>; + interrupts = <0 11 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_OPENVG_AXI>, + <&clks IMX6QDL_CLK_GPU2D_CORE>; + clock-names = "bus", "core"; + power-domains = <&gpc 1>; + }; + + ipu2: ipu@02800000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ipu"; + reg = <0x02800000 0x400000>; + interrupts = <0 8 IRQ_TYPE_LEVEL_HIGH>, + <0 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_IPU2>, + <&clks IMX6QDL_CLK_IPU2_DI0>, + <&clks IMX6QDL_CLK_IPU2_DI1>; + clock-names = "bus", "di0", "di1"; + resets = <&src 4>; + + ipu2_csi0: port@0 { + reg = <0>; + }; + + ipu2_csi1: port@1 { + reg = <1>; + }; + + ipu2_di0: port@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + + ipu2_di0_disp0: disp0-endpoint { + }; + + ipu2_di0_hdmi: hdmi-endpoint { + remote-endpoint = <&hdmi_mux_2>; + }; + + ipu2_di0_mipi: mipi-endpoint { + remote-endpoint = <&mipi_mux_2>; + }; + + ipu2_di0_lvds0: lvds0-endpoint { + remote-endpoint = <&lvds0_mux_2>; + }; + + ipu2_di0_lvds1: lvds1-endpoint { + remote-endpoint = <&lvds1_mux_2>; + }; + }; + + ipu2_di1: port@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + + ipu2_di1_hdmi: hdmi-endpoint { + remote-endpoint = <&hdmi_mux_3>; + }; + + ipu2_di1_mipi: mipi-endpoint { + remote-endpoint = <&mipi_mux_3>; + }; + + ipu2_di1_lvds0: lvds0-endpoint { + remote-endpoint = <&lvds0_mux_3>; + }; + + ipu2_di1_lvds1: lvds1-endpoint { + remote-endpoint = <&lvds1_mux_3>; + }; + }; + }; + }; + + display-subsystem { + compatible = "fsl,imx-display-subsystem"; + ports = <&ipu1_di0>, <&ipu1_di1>, <&ipu2_di0>, <&ipu2_di1>; + }; + + gpu-subsystem { + compatible = "fsl,imx-gpu-subsystem"; + cores = <&gpu_2d>, <&gpu_3d>, <&gpu_vg>; + }; +}; + +&hdmi { + compatible = "fsl,imx6q-hdmi"; + + port@2 { + reg = <2>; + + hdmi_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_hdmi>; + }; + }; + + port@3 { + reg = <3>; + + hdmi_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_hdmi>; + }; + }; +}; + +&ldb { + clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU2_DI0_SEL>, <&clks IMX6QDL_CLK_IPU2_DI1_SEL>, + <&clks IMX6QDL_CLK_LDB_DI0>, <&clks IMX6QDL_CLK_LDB_DI1>; + clock-names = "di0_pll", "di1_pll", + "di0_sel", "di1_sel", "di2_sel", "di3_sel", + "di0", "di1"; + + lvds-channel@0 { + port@2 { + reg = <2>; + + lvds0_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_lvds0>; + }; + }; + + port@3 { + reg = <3>; + + lvds0_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_lvds0>; + }; + }; + }; + + lvds-channel@1 { + port@2 { + reg = <2>; + + lvds1_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_lvds1>; + }; + }; + + port@3 { + reg = <3>; + + lvds1_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_lvds1>; + }; + }; + }; +}; + +&mipi_dsi { + ports { + port@2 { + reg = <2>; + + mipi_mux_2: endpoint { + remote-endpoint = <&ipu2_di0_mipi>; + }; + }; + + port@3 { + reg = <3>; + + mipi_mux_3: endpoint { + remote-endpoint = <&ipu2_di1_mipi>; + }; + }; + }; +}; + +&vpu { + compatible = "fsl,imx6q-vpu", "cnm,coda960"; +};
Add imx6q pinctrl defines support from Linux.
Here is the last commit: "ARM: dts: imx: pinfunc: add MX6QDL_PAD_GPIO_6__ENET_IRQ" (sha1: d8c765e0d1ddbd5032c2491c82cc9660c2f0e7f2)
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6q-pinfunc.h | 1047 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 1047 insertions(+) create mode 100644 arch/arm/dts/imx6q-pinfunc.h
diff --git a/arch/arm/dts/imx6q-pinfunc.h b/arch/arm/dts/imx6q-pinfunc.h new file mode 100644 index 0000000..9fc6120 --- /dev/null +++ b/arch/arm/dts/imx6q-pinfunc.h @@ -0,0 +1,1047 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + */ + +#ifndef __DTS_IMX6Q_PINFUNC_H +#define __DTS_IMX6Q_PINFUNC_H + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ +#define MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x04c 0x360 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT1__ECSPI5_SS0 0x04c 0x360 0x834 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT1__EIM_CS2_B 0x04c 0x360 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT1__AUD4_TXFS 0x04c 0x360 0x7c8 0x3 0x0 +#define MX6QDL_PAD_SD2_DAT1__KEY_COL7 0x04c 0x360 0x8f0 0x4 0x0 +#define MX6QDL_PAD_SD2_DAT1__GPIO1_IO14 0x04c 0x360 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x050 0x364 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT2__ECSPI5_SS1 0x050 0x364 0x838 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT2__EIM_CS3_B 0x050 0x364 0x000 0x2 0x0 +#define MX6QDL_PAD_SD2_DAT2__AUD4_TXD 0x050 0x364 0x7b8 0x3 0x0 +#define MX6QDL_PAD_SD2_DAT2__KEY_ROW6 0x050 0x364 0x8f8 0x4 0x0 +#define MX6QDL_PAD_SD2_DAT2__GPIO1_IO13 0x050 0x364 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x054 0x368 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT0__ECSPI5_MISO 0x054 0x368 0x82c 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT0__AUD4_RXD 0x054 0x368 0x7b4 0x3 0x0 +#define MX6QDL_PAD_SD2_DAT0__KEY_ROW7 0x054 0x368 0x8fc 0x4 0x0 +#define MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 0x054 0x368 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT0__DCIC2_OUT 0x054 0x368 0x000 0x6 0x0 +#define MX6QDL_PAD_RGMII_TXC__USB_H2_DATA 0x058 0x36c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x058 0x36c 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TXC__SPDIF_EXT_CLK 0x058 0x36c 0x918 0x2 0x0 +#define MX6QDL_PAD_RGMII_TXC__GPIO6_IO19 0x058 0x36c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M 0x058 0x36c 0x000 0x7 0x0 +#define MX6QDL_PAD_RGMII_TD0__HSI_TX_READY 0x05c 0x370 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x05c 0x370 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD0__GPIO6_IO20 0x05c 0x370 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD1__HSI_RX_FLAG 0x060 0x374 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x060 0x374 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD1__GPIO6_IO21 0x060 0x374 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD2__HSI_RX_DATA 0x064 0x378 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x064 0x378 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD2__GPIO6_IO22 0x064 0x378 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TD3__HSI_RX_WAKE 0x068 0x37c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x068 0x37c 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TD3__GPIO6_IO23 0x068 0x37c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__USB_H3_DATA 0x06c 0x380 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x06c 0x380 0x858 0x1 0x0 +#define MX6QDL_PAD_RGMII_RX_CTL__GPIO6_IO24 0x06c 0x380 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD0__HSI_RX_READY 0x070 0x384 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x070 0x384 0x848 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD0__GPIO6_IO25 0x070 0x384 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__USB_H2_STROBE 0x074 0x388 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x074 0x388 0x000 0x1 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__GPIO6_IO26 0x074 0x388 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_TX_CTL__ENET_REF_CLK 0x074 0x388 0x83c 0x7 0x0 +#define MX6QDL_PAD_RGMII_RD1__HSI_TX_FLAG 0x078 0x38c 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x078 0x38c 0x84c 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD1__GPIO6_IO27 0x078 0x38c 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD2__HSI_TX_DATA 0x07c 0x390 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x07c 0x390 0x850 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD2__GPIO6_IO28 0x07c 0x390 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RD3__HSI_TX_WAKE 0x080 0x394 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x080 0x394 0x854 0x1 0x0 +#define MX6QDL_PAD_RGMII_RD3__GPIO6_IO29 0x080 0x394 0x000 0x5 0x0 +#define MX6QDL_PAD_RGMII_RXC__USB_H3_STROBE 0x084 0x398 0x000 0x0 0x0 +#define MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x084 0x398 0x844 0x1 0x0 +#define MX6QDL_PAD_RGMII_RXC__GPIO6_IO30 0x084 0x398 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A25__EIM_ADDR25 0x088 0x39c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI4_SS1 0x088 0x39c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A25__ECSPI2_RDY 0x088 0x39c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI1_PIN12 0x088 0x39c 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A25__IPU1_DI0_D1_CS 0x088 0x39c 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x088 0x39c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A25__HDMI_TX_CEC_LINE 0x088 0x39c 0x88c 0x6 0x0 +#define MX6QDL_PAD_EIM_EB2__EIM_EB2_B 0x08c 0x3a0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB2__ECSPI1_SS0 0x08c 0x3a0 0x800 0x1 0x0 +#define MX6QDL_PAD_EIM_EB2__IPU2_CSI1_DATA19 0x08c 0x3a0 0x8d4 0x3 0x0 +#define MX6QDL_PAD_EIM_EB2__HDMI_TX_DDC_SCL 0x08c 0x3a0 0x890 0x4 0x0 +#define MX6QDL_PAD_EIM_EB2__GPIO2_IO30 0x08c 0x3a0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x08c 0x3a0 0x8a0 0x6 0x0 +#define MX6QDL_PAD_EIM_EB2__SRC_BOOT_CFG30 0x08c 0x3a0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D16__EIM_DATA16 0x090 0x3a4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D16__ECSPI1_SCLK 0x090 0x3a4 0x7f4 0x1 0x0 +#define MX6QDL_PAD_EIM_D16__IPU1_DI0_PIN05 0x090 0x3a4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D16__IPU2_CSI1_DATA18 0x090 0x3a4 0x8d0 0x3 0x0 +#define MX6QDL_PAD_EIM_D16__HDMI_TX_DDC_SDA 0x090 0x3a4 0x894 0x4 0x0 +#define MX6QDL_PAD_EIM_D16__GPIO3_IO16 0x090 0x3a4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D16__I2C2_SDA 0x090 0x3a4 0x8a4 0x6 0x0 +#define MX6QDL_PAD_EIM_D17__EIM_DATA17 0x094 0x3a8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D17__ECSPI1_MISO 0x094 0x3a8 0x7f8 0x1 0x0 +#define MX6QDL_PAD_EIM_D17__IPU1_DI0_PIN06 0x094 0x3a8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D17__IPU2_CSI1_PIXCLK 0x094 0x3a8 0x8e0 0x3 0x0 +#define MX6QDL_PAD_EIM_D17__DCIC1_OUT 0x094 0x3a8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D17__GPIO3_IO17 0x094 0x3a8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D17__I2C3_SCL 0x094 0x3a8 0x8a8 0x6 0x0 +#define MX6QDL_PAD_EIM_D18__EIM_DATA18 0x098 0x3ac 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D18__ECSPI1_MOSI 0x098 0x3ac 0x7fc 0x1 0x0 +#define MX6QDL_PAD_EIM_D18__IPU1_DI0_PIN07 0x098 0x3ac 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D18__IPU2_CSI1_DATA17 0x098 0x3ac 0x8cc 0x3 0x0 +#define MX6QDL_PAD_EIM_D18__IPU1_DI1_D0_CS 0x098 0x3ac 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x098 0x3ac 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D18__I2C3_SDA 0x098 0x3ac 0x8ac 0x6 0x0 +#define MX6QDL_PAD_EIM_D19__EIM_DATA19 0x09c 0x3b0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D19__ECSPI1_SS1 0x09c 0x3b0 0x804 0x1 0x0 +#define MX6QDL_PAD_EIM_D19__IPU1_DI0_PIN08 0x09c 0x3b0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D19__IPU2_CSI1_DATA16 0x09c 0x3b0 0x8c8 0x3 0x0 +#define MX6QDL_PAD_EIM_D19__UART1_CTS_B 0x09c 0x3b0 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__UART1_RTS_B 0x09c 0x3b0 0x91c 0x4 0x0 +#define MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x09c 0x3b0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D19__EPIT1_OUT 0x09c 0x3b0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D20__EIM_DATA20 0x0a0 0x3b4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D20__ECSPI4_SS0 0x0a0 0x3b4 0x824 0x1 0x0 +#define MX6QDL_PAD_EIM_D20__IPU1_DI0_PIN16 0x0a0 0x3b4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D20__IPU2_CSI1_DATA15 0x0a0 0x3b4 0x8c4 0x3 0x0 +#define MX6QDL_PAD_EIM_D20__UART1_RTS_B 0x0a0 0x3b4 0x91c 0x4 0x1 +#define MX6QDL_PAD_EIM_D20__UART1_CTS_B 0x0a0 0x3b4 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D20__GPIO3_IO20 0x0a0 0x3b4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D20__EPIT2_OUT 0x0a0 0x3b4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D21__EIM_DATA21 0x0a4 0x3b8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D21__ECSPI4_SCLK 0x0a4 0x3b8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D21__IPU1_DI0_PIN17 0x0a4 0x3b8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D21__IPU2_CSI1_DATA11 0x0a4 0x3b8 0x8b4 0x3 0x0 +#define MX6QDL_PAD_EIM_D21__USB_OTG_OC 0x0a4 0x3b8 0x944 0x4 0x0 +#define MX6QDL_PAD_EIM_D21__GPIO3_IO21 0x0a4 0x3b8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D21__I2C1_SCL 0x0a4 0x3b8 0x898 0x6 0x0 +#define MX6QDL_PAD_EIM_D21__SPDIF_IN 0x0a4 0x3b8 0x914 0x7 0x0 +#define MX6QDL_PAD_EIM_D22__EIM_DATA22 0x0a8 0x3bc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D22__ECSPI4_MISO 0x0a8 0x3bc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D22__IPU1_DI0_PIN01 0x0a8 0x3bc 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D22__IPU2_CSI1_DATA10 0x0a8 0x3bc 0x8b0 0x3 0x0 +#define MX6QDL_PAD_EIM_D22__USB_OTG_PWR 0x0a8 0x3bc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x0a8 0x3bc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D22__SPDIF_OUT 0x0a8 0x3bc 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D23__EIM_DATA23 0x0ac 0x3c0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI0_D0_CS 0x0ac 0x3c0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x0ac 0x3c0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART3_RTS_B 0x0ac 0x3c0 0x92c 0x2 0x0 +#define MX6QDL_PAD_EIM_D23__UART1_DCD_B 0x0ac 0x3c0 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D23__IPU2_CSI1_DATA_EN 0x0ac 0x3c0 0x8d8 0x4 0x0 +#define MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x0ac 0x3c0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN02 0x0ac 0x3c0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D23__IPU1_DI1_PIN14 0x0ac 0x3c0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB3__EIM_EB3_B 0x0b0 0x3c4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB3__ECSPI4_RDY 0x0b0 0x3c4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB3__UART3_RTS_B 0x0b0 0x3c4 0x92c 0x2 0x1 +#define MX6QDL_PAD_EIM_EB3__UART3_CTS_B 0x0b0 0x3c4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_EB3__UART1_RI_B 0x0b0 0x3c4 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU2_CSI1_HSYNC 0x0b0 0x3c4 0x8dc 0x4 0x0 +#define MX6QDL_PAD_EIM_EB3__GPIO2_IO31 0x0b0 0x3c4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB3__IPU1_DI1_PIN03 0x0b0 0x3c4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_EB3__SRC_BOOT_CFG31 0x0b0 0x3c4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D24__EIM_DATA24 0x0b4 0x3c8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI4_SS2 0x0b4 0x3c8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x0b4 0x3c8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__UART3_RX_DATA 0x0b4 0x3c8 0x930 0x2 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI1_SS2 0x0b4 0x3c8 0x808 0x3 0x0 +#define MX6QDL_PAD_EIM_D24__ECSPI2_SS2 0x0b4 0x3c8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D24__GPIO3_IO24 0x0b4 0x3c8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D24__AUD5_RXFS 0x0b4 0x3c8 0x7d8 0x6 0x0 +#define MX6QDL_PAD_EIM_D24__UART1_DTR_B 0x0b4 0x3c8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D25__EIM_DATA25 0x0b8 0x3cc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI4_SS3 0x0b8 0x3cc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x0b8 0x3cc 0x930 0x2 0x1 +#define MX6QDL_PAD_EIM_D25__UART3_TX_DATA 0x0b8 0x3cc 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI1_SS3 0x0b8 0x3cc 0x80c 0x3 0x0 +#define MX6QDL_PAD_EIM_D25__ECSPI2_SS3 0x0b8 0x3cc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D25__GPIO3_IO25 0x0b8 0x3cc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D25__AUD5_RXC 0x0b8 0x3cc 0x7d4 0x6 0x0 +#define MX6QDL_PAD_EIM_D25__UART1_DSR_B 0x0b8 0x3cc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D26__EIM_DATA26 0x0bc 0x3d0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DI1_PIN11 0x0bc 0x3d0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_CSI0_DATA01 0x0bc 0x3d0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D26__IPU2_CSI1_DATA14 0x0bc 0x3d0 0x8c0 0x3 0x0 +#define MX6QDL_PAD_EIM_D26__UART2_TX_DATA 0x0bc 0x3d0 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__UART2_RX_DATA 0x0bc 0x3d0 0x928 0x4 0x0 +#define MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x0bc 0x3d0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_SISG2 0x0bc 0x3d0 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D26__IPU1_DISP1_DATA22 0x0bc 0x3d0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D27__EIM_DATA27 0x0c0 0x3d4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DI1_PIN13 0x0c0 0x3d4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_CSI0_DATA00 0x0c0 0x3d4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D27__IPU2_CSI1_DATA13 0x0c0 0x3d4 0x8bc 0x3 0x0 +#define MX6QDL_PAD_EIM_D27__UART2_RX_DATA 0x0c0 0x3d4 0x928 0x4 0x1 +#define MX6QDL_PAD_EIM_D27__UART2_TX_DATA 0x0c0 0x3d4 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x0c0 0x3d4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_SISG3 0x0c0 0x3d4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D27__IPU1_DISP1_DATA23 0x0c0 0x3d4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D28__EIM_DATA28 0x0c4 0x3d8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D28__I2C1_SDA 0x0c4 0x3d8 0x89c 0x1 0x0 +#define MX6QDL_PAD_EIM_D28__ECSPI4_MOSI 0x0c4 0x3d8 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D28__IPU2_CSI1_DATA12 0x0c4 0x3d8 0x8b8 0x3 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_CTS_B 0x0c4 0x3d8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_RTS_B 0x0c4 0x3d8 0x924 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_CTS_B 0x0c4 0x3d8 0x924 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__UART2_DTE_RTS_B 0x0c4 0x3d8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x0c4 0x3d8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_EXT_TRIG 0x0c4 0x3d8 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_D28__IPU1_DI0_PIN13 0x0c4 0x3d8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D29__EIM_DATA29 0x0c8 0x3dc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI1_PIN15 0x0c8 0x3dc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D29__ECSPI4_SS0 0x0c8 0x3dc 0x824 0x2 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_RTS_B 0x0c8 0x3dc 0x924 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__UART2_CTS_B 0x0c8 0x3dc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_RTS_B 0x0c8 0x3dc 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D29__UART2_DTE_CTS_B 0x0c8 0x3dc 0x924 0x4 0x1 +#define MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x0c8 0x3dc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D29__IPU2_CSI1_VSYNC 0x0c8 0x3dc 0x8e4 0x6 0x0 +#define MX6QDL_PAD_EIM_D29__IPU1_DI0_PIN14 0x0c8 0x3dc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_D30__EIM_DATA30 0x0cc 0x3e0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DISP1_DATA21 0x0cc 0x3e0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_DI0_PIN11 0x0cc 0x3e0 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D30__IPU1_CSI0_DATA03 0x0cc 0x3e0 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_CTS_B 0x0cc 0x3e0 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D30__UART3_RTS_B 0x0cc 0x3e0 0x92c 0x4 0x2 +#define MX6QDL_PAD_EIM_D30__GPIO3_IO30 0x0cc 0x3e0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D30__USB_H1_OC 0x0cc 0x3e0 0x948 0x6 0x0 +#define MX6QDL_PAD_EIM_D31__EIM_DATA31 0x0d0 0x3e4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DISP1_DATA20 0x0d0 0x3e4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_DI0_PIN12 0x0d0 0x3e4 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_D31__IPU1_CSI0_DATA02 0x0d0 0x3e4 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_D31__UART3_RTS_B 0x0d0 0x3e4 0x92c 0x4 0x3 +#define MX6QDL_PAD_EIM_D31__UART3_CTS_B 0x0d0 0x3e4 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x0d0 0x3e4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_D31__USB_H1_PWR 0x0d0 0x3e4 0x000 0x6 0x0 +#define MX6QDL_PAD_EIM_A24__EIM_ADDR24 0x0d4 0x3e8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_DISP1_DATA19 0x0d4 0x3e8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A24__IPU2_CSI1_DATA19 0x0d4 0x3e8 0x8d4 0x2 0x1 +#define MX6QDL_PAD_EIM_A24__IPU2_SISG2 0x0d4 0x3e8 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A24__IPU1_SISG2 0x0d4 0x3e8 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x0d4 0x3e8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A24__SRC_BOOT_CFG24 0x0d4 0x3e8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A23__EIM_ADDR23 0x0d8 0x3ec 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_DISP1_DATA18 0x0d8 0x3ec 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A23__IPU2_CSI1_DATA18 0x0d8 0x3ec 0x8d0 0x2 0x1 +#define MX6QDL_PAD_EIM_A23__IPU2_SISG3 0x0d8 0x3ec 0x000 0x3 0x0 +#define MX6QDL_PAD_EIM_A23__IPU1_SISG3 0x0d8 0x3ec 0x000 0x4 0x0 +#define MX6QDL_PAD_EIM_A23__GPIO6_IO06 0x0d8 0x3ec 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A23__SRC_BOOT_CFG23 0x0d8 0x3ec 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A22__EIM_ADDR22 0x0dc 0x3f0 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A22__IPU1_DISP1_DATA17 0x0dc 0x3f0 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A22__IPU2_CSI1_DATA17 0x0dc 0x3f0 0x8cc 0x2 0x1 +#define MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x0dc 0x3f0 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A22__SRC_BOOT_CFG22 0x0dc 0x3f0 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A21__EIM_ADDR21 0x0e0 0x3f4 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A21__IPU1_DISP1_DATA16 0x0e0 0x3f4 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A21__IPU2_CSI1_DATA16 0x0e0 0x3f4 0x8c8 0x2 0x1 +#define MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x0e0 0x3f4 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A21__SRC_BOOT_CFG21 0x0e0 0x3f4 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A20__EIM_ADDR20 0x0e4 0x3f8 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A20__IPU1_DISP1_DATA15 0x0e4 0x3f8 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A20__IPU2_CSI1_DATA15 0x0e4 0x3f8 0x8c4 0x2 0x1 +#define MX6QDL_PAD_EIM_A20__GPIO2_IO18 0x0e4 0x3f8 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A20__SRC_BOOT_CFG20 0x0e4 0x3f8 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A19__EIM_ADDR19 0x0e8 0x3fc 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A19__IPU1_DISP1_DATA14 0x0e8 0x3fc 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A19__IPU2_CSI1_DATA14 0x0e8 0x3fc 0x8c0 0x2 0x1 +#define MX6QDL_PAD_EIM_A19__GPIO2_IO19 0x0e8 0x3fc 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A19__SRC_BOOT_CFG19 0x0e8 0x3fc 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A18__EIM_ADDR18 0x0ec 0x400 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A18__IPU1_DISP1_DATA13 0x0ec 0x400 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A18__IPU2_CSI1_DATA13 0x0ec 0x400 0x8bc 0x2 0x1 +#define MX6QDL_PAD_EIM_A18__GPIO2_IO20 0x0ec 0x400 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A18__SRC_BOOT_CFG18 0x0ec 0x400 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A17__EIM_ADDR17 0x0f0 0x404 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A17__IPU1_DISP1_DATA12 0x0f0 0x404 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A17__IPU2_CSI1_DATA12 0x0f0 0x404 0x8b8 0x2 0x1 +#define MX6QDL_PAD_EIM_A17__GPIO2_IO21 0x0f0 0x404 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A17__SRC_BOOT_CFG17 0x0f0 0x404 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_A16__EIM_ADDR16 0x0f4 0x408 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_A16__IPU1_DI1_DISP_CLK 0x0f4 0x408 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_A16__IPU2_CSI1_PIXCLK 0x0f4 0x408 0x8e0 0x2 0x1 +#define MX6QDL_PAD_EIM_A16__GPIO2_IO22 0x0f4 0x408 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_A16__SRC_BOOT_CFG16 0x0f4 0x408 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0x0f8 0x40c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS0__IPU1_DI1_PIN05 0x0f8 0x40c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK 0x0f8 0x40c 0x810 0x2 0x0 +#define MX6QDL_PAD_EIM_CS0__GPIO2_IO23 0x0f8 0x40c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_CS1__EIM_CS1_B 0x0fc 0x410 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_CS1__IPU1_DI1_PIN06 0x0fc 0x410 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI 0x0fc 0x410 0x818 0x2 0x0 +#define MX6QDL_PAD_EIM_CS1__GPIO2_IO24 0x0fc 0x410 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_OE__EIM_OE_B 0x100 0x414 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_OE__IPU1_DI1_PIN07 0x100 0x414 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_OE__ECSPI2_MISO 0x100 0x414 0x814 0x2 0x0 +#define MX6QDL_PAD_EIM_OE__GPIO2_IO25 0x100 0x414 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_RW__EIM_RW 0x104 0x418 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_RW__IPU1_DI1_PIN08 0x104 0x418 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_RW__ECSPI2_SS0 0x104 0x418 0x81c 0x2 0x0 +#define MX6QDL_PAD_EIM_RW__GPIO2_IO26 0x104 0x418 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_RW__SRC_BOOT_CFG29 0x104 0x418 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_LBA__EIM_LBA_B 0x108 0x41c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_LBA__IPU1_DI1_PIN17 0x108 0x41c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_LBA__ECSPI2_SS1 0x108 0x41c 0x820 0x2 0x0 +#define MX6QDL_PAD_EIM_LBA__GPIO2_IO27 0x108 0x41c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_LBA__SRC_BOOT_CFG26 0x108 0x41c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB0__EIM_EB0_B 0x10c 0x420 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU1_DISP1_DATA11 0x10c 0x420 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB0__IPU2_CSI1_DATA11 0x10c 0x420 0x8b4 0x2 0x1 +#define MX6QDL_PAD_EIM_EB0__CCM_PMIC_READY 0x10c 0x420 0x7f0 0x4 0x0 +#define MX6QDL_PAD_EIM_EB0__GPIO2_IO28 0x10c 0x420 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB0__SRC_BOOT_CFG27 0x10c 0x420 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_EB1__EIM_EB1_B 0x110 0x424 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU1_DISP1_DATA10 0x110 0x424 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_EB1__IPU2_CSI1_DATA10 0x110 0x424 0x8b0 0x2 0x1 +#define MX6QDL_PAD_EIM_EB1__GPIO2_IO29 0x110 0x424 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_EB1__SRC_BOOT_CFG28 0x110 0x424 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA0__EIM_AD00 0x114 0x428 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU1_DISP1_DATA09 0x114 0x428 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA0__IPU2_CSI1_DATA09 0x114 0x428 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA0__GPIO3_IO00 0x114 0x428 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA0__SRC_BOOT_CFG00 0x114 0x428 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA1__EIM_AD01 0x118 0x42c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU1_DISP1_DATA08 0x118 0x42c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA1__IPU2_CSI1_DATA08 0x118 0x42c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA1__GPIO3_IO01 0x118 0x42c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA1__SRC_BOOT_CFG01 0x118 0x42c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA2__EIM_AD02 0x11c 0x430 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU1_DISP1_DATA07 0x11c 0x430 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA2__IPU2_CSI1_DATA07 0x11c 0x430 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA2__GPIO3_IO02 0x11c 0x430 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA2__SRC_BOOT_CFG02 0x11c 0x430 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA3__EIM_AD03 0x120 0x434 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU1_DISP1_DATA06 0x120 0x434 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA3__IPU2_CSI1_DATA06 0x120 0x434 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA3__GPIO3_IO03 0x120 0x434 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA3__SRC_BOOT_CFG03 0x120 0x434 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA4__EIM_AD04 0x124 0x438 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU1_DISP1_DATA05 0x124 0x438 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA4__IPU2_CSI1_DATA05 0x124 0x438 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA4__GPIO3_IO04 0x124 0x438 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA4__SRC_BOOT_CFG04 0x124 0x438 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA5__EIM_AD05 0x128 0x43c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU1_DISP1_DATA04 0x128 0x43c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA5__IPU2_CSI1_DATA04 0x128 0x43c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA5__GPIO3_IO05 0x128 0x43c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA5__SRC_BOOT_CFG05 0x128 0x43c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA6__EIM_AD06 0x12c 0x440 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU1_DISP1_DATA03 0x12c 0x440 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA6__IPU2_CSI1_DATA03 0x12c 0x440 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA6__GPIO3_IO06 0x12c 0x440 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA6__SRC_BOOT_CFG06 0x12c 0x440 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA7__EIM_AD07 0x130 0x444 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU1_DISP1_DATA02 0x130 0x444 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA7__IPU2_CSI1_DATA02 0x130 0x444 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA7__GPIO3_IO07 0x130 0x444 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA7__SRC_BOOT_CFG07 0x130 0x444 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA8__EIM_AD08 0x134 0x448 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU1_DISP1_DATA01 0x134 0x448 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA8__IPU2_CSI1_DATA01 0x134 0x448 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA8__GPIO3_IO08 0x134 0x448 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA8__SRC_BOOT_CFG08 0x134 0x448 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA9__EIM_AD09 0x138 0x44c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU1_DISP1_DATA00 0x138 0x44c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA9__IPU2_CSI1_DATA00 0x138 0x44c 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA9__GPIO3_IO09 0x138 0x44c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA9__SRC_BOOT_CFG09 0x138 0x44c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA10__EIM_AD10 0x13c 0x450 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU1_DI1_PIN15 0x13c 0x450 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA10__IPU2_CSI1_DATA_EN 0x13c 0x450 0x8d8 0x2 0x1 +#define MX6QDL_PAD_EIM_DA10__GPIO3_IO10 0x13c 0x450 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA10__SRC_BOOT_CFG10 0x13c 0x450 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA11__EIM_AD11 0x140 0x454 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU1_DI1_PIN02 0x140 0x454 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA11__IPU2_CSI1_HSYNC 0x140 0x454 0x8dc 0x2 0x1 +#define MX6QDL_PAD_EIM_DA11__GPIO3_IO11 0x140 0x454 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA11__SRC_BOOT_CFG11 0x140 0x454 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA12__EIM_AD12 0x144 0x458 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU1_DI1_PIN03 0x144 0x458 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA12__IPU2_CSI1_VSYNC 0x144 0x458 0x8e4 0x2 0x1 +#define MX6QDL_PAD_EIM_DA12__GPIO3_IO12 0x144 0x458 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA12__SRC_BOOT_CFG12 0x144 0x458 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA13__EIM_AD13 0x148 0x45c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA13__IPU1_DI1_D0_CS 0x148 0x45c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x148 0x45c 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA13__SRC_BOOT_CFG13 0x148 0x45c 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA14__EIM_AD14 0x14c 0x460 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA14__IPU1_DI1_D1_CS 0x14c 0x460 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA14__GPIO3_IO14 0x14c 0x460 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA14__SRC_BOOT_CFG14 0x14c 0x460 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_DA15__EIM_AD15 0x150 0x464 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN01 0x150 0x464 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_DA15__IPU1_DI1_PIN04 0x150 0x464 0x000 0x2 0x0 +#define MX6QDL_PAD_EIM_DA15__GPIO3_IO15 0x150 0x464 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_DA15__SRC_BOOT_CFG15 0x150 0x464 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_WAIT_B 0x154 0x468 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_WAIT__EIM_DTACK_B 0x154 0x468 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_WAIT__GPIO5_IO00 0x154 0x468 0x000 0x5 0x0 +#define MX6QDL_PAD_EIM_WAIT__SRC_BOOT_CFG25 0x154 0x468 0x000 0x7 0x0 +#define MX6QDL_PAD_EIM_BCLK__EIM_BCLK 0x158 0x46c 0x000 0x0 0x0 +#define MX6QDL_PAD_EIM_BCLK__IPU1_DI1_PIN16 0x158 0x46c 0x000 0x1 0x0 +#define MX6QDL_PAD_EIM_BCLK__GPIO6_IO31 0x158 0x46c 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x15c 0x470 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK 0x15c 0x470 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_DISP_CLK__GPIO4_IO16 0x15c 0x470 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15 0x160 0x474 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN15__IPU2_DI0_PIN15 0x160 0x474 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN15__AUD6_TXC 0x160 0x474 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN15__GPIO4_IO17 0x160 0x474 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0x164 0x478 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN2__IPU2_DI0_PIN02 0x164 0x478 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN2__AUD6_TXD 0x164 0x478 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN2__GPIO4_IO18 0x164 0x478 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0x168 0x47c 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN3__IPU2_DI0_PIN03 0x168 0x47c 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN3__AUD6_TXFS 0x168 0x47c 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN3__GPIO4_IO19 0x168 0x47c 0x000 0x5 0x0 +#define MX6QDL_PAD_DI0_PIN4__IPU1_DI0_PIN04 0x16c 0x480 0x000 0x0 0x0 +#define MX6QDL_PAD_DI0_PIN4__IPU2_DI0_PIN04 0x16c 0x480 0x000 0x1 0x0 +#define MX6QDL_PAD_DI0_PIN4__AUD6_RXD 0x16c 0x480 0x000 0x2 0x0 +#define MX6QDL_PAD_DI0_PIN4__SD1_WP 0x16c 0x480 0x94c 0x3 0x0 +#define MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x16c 0x480 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 0x170 0x484 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 0x170 0x484 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT0__ECSPI3_SCLK 0x170 0x484 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT0__GPIO4_IO21 0x170 0x484 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0x174 0x488 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 0x174 0x488 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT1__ECSPI3_MOSI 0x174 0x488 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT1__GPIO4_IO22 0x174 0x488 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0x178 0x48c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 0x178 0x48c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT2__ECSPI3_MISO 0x178 0x48c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT2__GPIO4_IO23 0x178 0x48c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0x17c 0x490 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 0x17c 0x490 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT3__ECSPI3_SS0 0x17c 0x490 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT3__GPIO4_IO24 0x17c 0x490 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0x180 0x494 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT4__IPU2_DISP0_DATA04 0x180 0x494 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT4__ECSPI3_SS1 0x180 0x494 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT4__GPIO4_IO25 0x180 0x494 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0x184 0x498 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 0x184 0x498 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT5__ECSPI3_SS2 0x184 0x498 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT5__AUD6_RXFS 0x184 0x498 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT5__GPIO4_IO26 0x184 0x498 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0x188 0x49c 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 0x188 0x49c 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT6__ECSPI3_SS3 0x188 0x49c 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT6__AUD6_RXC 0x188 0x49c 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT6__GPIO4_IO27 0x188 0x49c 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0x18c 0x4a0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 0x18c 0x4a0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT7__ECSPI3_RDY 0x18c 0x4a0 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT7__GPIO4_IO28 0x18c 0x4a0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0x190 0x4a4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 0x190 0x4a4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT8__PWM1_OUT 0x190 0x4a4 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT8__WDOG1_B 0x190 0x4a4 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT8__GPIO4_IO29 0x190 0x4a4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0x194 0x4a8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 0x194 0x4a8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT9__PWM2_OUT 0x194 0x4a8 0x000 0x2 0x0 +#define MX6QDL_PAD_DISP0_DAT9__WDOG2_B 0x194 0x4a8 0x000 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT9__GPIO4_IO30 0x194 0x4a8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0x198 0x4ac 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 0x198 0x4ac 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT10__GPIO4_IO31 0x198 0x4ac 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0x19c 0x4b0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT11__IPU2_DISP0_DATA11 0x19c 0x4b0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT11__GPIO5_IO05 0x19c 0x4b0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0x1a0 0x4b4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT12__IPU2_DISP0_DATA12 0x1a0 0x4b4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT12__GPIO5_IO06 0x1a0 0x4b4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0x1a4 0x4b8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 0x1a4 0x4b8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT13__AUD5_RXFS 0x1a4 0x4b8 0x7d8 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT13__GPIO5_IO07 0x1a4 0x4b8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0x1a8 0x4bc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 0x1a8 0x4bc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT14__AUD5_RXC 0x1a8 0x4bc 0x7d4 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT14__GPIO5_IO08 0x1a8 0x4bc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0x1ac 0x4c0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 0x1ac 0x4c0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI1_SS1 0x1ac 0x4c0 0x804 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT15__ECSPI2_SS1 0x1ac 0x4c0 0x820 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT15__GPIO5_IO09 0x1ac 0x4c0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0x1b0 0x4c4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT16__IPU2_DISP0_DATA16 0x1b0 0x4c4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT16__ECSPI2_MOSI 0x1b0 0x4c4 0x818 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT16__AUD5_TXC 0x1b0 0x4c4 0x7dc 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 0x1b0 0x4c4 0x90c 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT16__GPIO5_IO10 0x1b0 0x4c4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 0x1b4 0x4c8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT17__IPU2_DISP0_DATA17 0x1b4 0x4c8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT17__ECSPI2_MISO 0x1b4 0x4c8 0x814 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT17__AUD5_TXD 0x1b4 0x4c8 0x7d0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 0x1b4 0x4c8 0x910 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT17__GPIO5_IO11 0x1b4 0x4c8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 0x1b8 0x4cc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT18__IPU2_DISP0_DATA18 0x1b8 0x4cc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT18__ECSPI2_SS0 0x1b8 0x4cc 0x81c 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT18__AUD5_TXFS 0x1b8 0x4cc 0x7e0 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT18__AUD4_RXFS 0x1b8 0x4cc 0x7c0 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT18__GPIO5_IO12 0x1b8 0x4cc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT18__EIM_CS2_B 0x1b8 0x4cc 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 0x1bc 0x4d0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT19__IPU2_DISP0_DATA19 0x1bc 0x4d0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT19__ECSPI2_SCLK 0x1bc 0x4d0 0x810 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT19__AUD5_RXD 0x1bc 0x4d0 0x7cc 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT19__AUD4_RXC 0x1bc 0x4d0 0x7bc 0x4 0x0 +#define MX6QDL_PAD_DISP0_DAT19__GPIO5_IO13 0x1bc 0x4d0 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT19__EIM_CS3_B 0x1bc 0x4d0 0x000 0x7 0x0 +#define MX6QDL_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 0x1c0 0x4d4 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT20__IPU2_DISP0_DATA20 0x1c0 0x4d4 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT20__ECSPI1_SCLK 0x1c0 0x4d4 0x7f4 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT20__AUD4_TXC 0x1c0 0x4d4 0x7c4 0x3 0x0 +#define MX6QDL_PAD_DISP0_DAT20__GPIO5_IO14 0x1c0 0x4d4 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 0x1c4 0x4d8 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT21__IPU2_DISP0_DATA21 0x1c4 0x4d8 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT21__ECSPI1_MOSI 0x1c4 0x4d8 0x7fc 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT21__AUD4_TXD 0x1c4 0x4d8 0x7b8 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT21__GPIO5_IO15 0x1c4 0x4d8 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 0x1c8 0x4dc 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT22__IPU2_DISP0_DATA22 0x1c8 0x4dc 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT22__ECSPI1_MISO 0x1c8 0x4dc 0x7f8 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT22__AUD4_TXFS 0x1c8 0x4dc 0x7c8 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT22__GPIO5_IO16 0x1c8 0x4dc 0x000 0x5 0x0 +#define MX6QDL_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 0x1cc 0x4e0 0x000 0x0 0x0 +#define MX6QDL_PAD_DISP0_DAT23__IPU2_DISP0_DATA23 0x1cc 0x4e0 0x000 0x1 0x0 +#define MX6QDL_PAD_DISP0_DAT23__ECSPI1_SS0 0x1cc 0x4e0 0x800 0x2 0x1 +#define MX6QDL_PAD_DISP0_DAT23__AUD4_RXD 0x1cc 0x4e0 0x7b4 0x3 0x1 +#define MX6QDL_PAD_DISP0_DAT23__GPIO5_IO17 0x1cc 0x4e0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1d0 0x4e4 0x840 0x1 0x0 +#define MX6QDL_PAD_ENET_MDIO__ESAI_RX_CLK 0x1d0 0x4e4 0x86c 0x2 0x0 +#define MX6QDL_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT 0x1d0 0x4e4 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDIO__GPIO1_IO22 0x1d0 0x4e4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDIO__SPDIF_LOCK 0x1d0 0x4e4 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1d4 0x4e8 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__ESAI_RX_FS 0x1d4 0x4e8 0x85c 0x2 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1d4 0x4e8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_REF_CLK__SPDIF_SR_CLK 0x1d4 0x4e8 0x000 0x6 0x0 +#define MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x1d8 0x4ec 0x004 0x0 0xff0d0100 +#define MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1d8 0x4ec 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_RX_ER__ESAI_RX_HF_CLK 0x1d8 0x4ec 0x864 0x2 0x0 +#define MX6QDL_PAD_ENET_RX_ER__SPDIF_IN 0x1d8 0x4ec 0x914 0x3 0x1 +#define MX6QDL_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT 0x1d8 0x4ec 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RX_ER__GPIO1_IO24 0x1d8 0x4ec 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1dc 0x4f0 0x858 0x1 0x1 +#define MX6QDL_PAD_ENET_CRS_DV__ESAI_TX_CLK 0x1dc 0x4f0 0x870 0x2 0x0 +#define MX6QDL_PAD_ENET_CRS_DV__SPDIF_EXT_CLK 0x1dc 0x4f0 0x918 0x3 0x1 +#define MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1dc 0x4f0 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD1__MLB_SIG 0x1e0 0x4f4 0x908 0x0 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1e0 0x4f4 0x84c 0x1 0x1 +#define MX6QDL_PAD_ENET_RXD1__ESAI_TX_FS 0x1e0 0x4f4 0x860 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT 0x1e0 0x4f4 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_RXD1__GPIO1_IO26 0x1e0 0x4f4 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1e4 0x4f8 0x848 0x1 0x1 +#define MX6QDL_PAD_ENET_RXD0__ESAI_TX_HF_CLK 0x1e4 0x4f8 0x868 0x2 0x0 +#define MX6QDL_PAD_ENET_RXD0__SPDIF_OUT 0x1e4 0x4f8 0x000 0x3 0x0 +#define MX6QDL_PAD_ENET_RXD0__GPIO1_IO27 0x1e4 0x4f8 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x1e8 0x4fc 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TX_EN__ESAI_TX3_RX2 0x1e8 0x4fc 0x880 0x2 0x0 +#define MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x1e8 0x4fc 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD1__MLB_CLK 0x1ec 0x500 0x900 0x0 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x1ec 0x500 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD1__ESAI_TX2_RX3 0x1ec 0x500 0x87c 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD1__ENET_1588_EVENT0_IN 0x1ec 0x500 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x1ec 0x500 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x1f0 0x504 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_TXD0__ESAI_TX4_RX1 0x1f0 0x504 0x884 0x2 0x0 +#define MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x1f0 0x504 0x000 0x5 0x0 +#define MX6QDL_PAD_ENET_MDC__MLB_DATA 0x1f4 0x508 0x904 0x0 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1f4 0x508 0x000 0x1 0x0 +#define MX6QDL_PAD_ENET_MDC__ESAI_TX5_RX0 0x1f4 0x508 0x888 0x2 0x0 +#define MX6QDL_PAD_ENET_MDC__ENET_1588_EVENT1_IN 0x1f4 0x508 0x000 0x4 0x0 +#define MX6QDL_PAD_ENET_MDC__GPIO1_IO31 0x1f4 0x508 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x1f8 0x5c8 0x7f4 0x0 0x2 +#define MX6QDL_PAD_KEY_COL0__ENET_RX_DATA3 0x1f8 0x5c8 0x854 0x1 0x1 +#define MX6QDL_PAD_KEY_COL0__AUD5_TXC 0x1f8 0x5c8 0x7dc 0x2 0x1 +#define MX6QDL_PAD_KEY_COL0__KEY_COL0 0x1f8 0x5c8 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x1f8 0x5c8 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL0__UART4_RX_DATA 0x1f8 0x5c8 0x938 0x4 0x0 +#define MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x1f8 0x5c8 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL0__DCIC1_OUT 0x1f8 0x5c8 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x1fc 0x5cc 0x7fc 0x0 0x2 +#define MX6QDL_PAD_KEY_ROW0__ENET_TX_DATA3 0x1fc 0x5cc 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW0__AUD5_TXD 0x1fc 0x5cc 0x7d0 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW0__KEY_ROW0 0x1fc 0x5cc 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x1fc 0x5cc 0x938 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW0__UART4_TX_DATA 0x1fc 0x5cc 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x1fc 0x5cc 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW0__DCIC2_OUT 0x1fc 0x5cc 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x200 0x5d0 0x7f8 0x0 0x2 +#define MX6QDL_PAD_KEY_COL1__ENET_MDIO 0x200 0x5d0 0x840 0x1 0x1 +#define MX6QDL_PAD_KEY_COL1__AUD5_TXFS 0x200 0x5d0 0x7e0 0x2 0x1 +#define MX6QDL_PAD_KEY_COL1__KEY_COL1 0x200 0x5d0 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_TX_DATA 0x200 0x5d0 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL1__UART5_RX_DATA 0x200 0x5d0 0x940 0x4 0x0 +#define MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x200 0x5d0 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL1__SD1_VSELECT 0x200 0x5d0 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW1__ECSPI1_SS0 0x204 0x5d4 0x800 0x0 0x2 +#define MX6QDL_PAD_KEY_ROW1__ENET_COL 0x204 0x5d4 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW1__AUD5_RXD 0x204 0x5d4 0x7cc 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW1__KEY_ROW1 0x204 0x5d4 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW1__UART5_RX_DATA 0x204 0x5d4 0x940 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW1__UART5_TX_DATA 0x204 0x5d4 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x204 0x5d4 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW1__SD2_VSELECT 0x204 0x5d4 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL2__ECSPI1_SS1 0x208 0x5d8 0x804 0x0 0x2 +#define MX6QDL_PAD_KEY_COL2__ENET_RX_DATA2 0x208 0x5d8 0x850 0x1 0x1 +#define MX6QDL_PAD_KEY_COL2__FLEXCAN1_TX 0x208 0x5d8 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_COL2__KEY_COL2 0x208 0x5d8 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL2__ENET_MDC 0x208 0x5d8 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL2__GPIO4_IO10 0x208 0x5d8 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE 0x208 0x5d8 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_ROW2__ECSPI1_SS2 0x20c 0x5dc 0x808 0x0 0x1 +#define MX6QDL_PAD_KEY_ROW2__ENET_TX_DATA2 0x20c 0x5dc 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW2__FLEXCAN1_RX 0x20c 0x5dc 0x7e4 0x2 0x0 +#define MX6QDL_PAD_KEY_ROW2__KEY_ROW2 0x20c 0x5dc 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW2__SD2_VSELECT 0x20c 0x5dc 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW2__GPIO4_IO11 0x20c 0x5dc 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x20c 0x5dc 0x88c 0x6 0x1 +#define MX6QDL_PAD_KEY_COL3__ECSPI1_SS3 0x210 0x5e0 0x80c 0x0 0x1 +#define MX6QDL_PAD_KEY_COL3__ENET_CRS 0x210 0x5e0 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL3__HDMI_TX_DDC_SCL 0x210 0x5e0 0x890 0x2 0x1 +#define MX6QDL_PAD_KEY_COL3__KEY_COL3 0x210 0x5e0 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x210 0x5e0 0x8a0 0x4 0x1 +#define MX6QDL_PAD_KEY_COL3__GPIO4_IO12 0x210 0x5e0 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_COL3__SPDIF_IN 0x210 0x5e0 0x914 0x6 0x2 +#define MX6QDL_PAD_KEY_ROW3__ASRC_EXT_CLK 0x214 0x5e4 0x7b0 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW3__HDMI_TX_DDC_SDA 0x214 0x5e4 0x894 0x2 0x1 +#define MX6QDL_PAD_KEY_ROW3__KEY_ROW3 0x214 0x5e4 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x214 0x5e4 0x8a4 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW3__GPIO4_IO13 0x214 0x5e4 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW3__SD1_VSELECT 0x214 0x5e4 0x000 0x6 0x0 +#define MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x218 0x5e8 0x000 0x0 0x0 +#define MX6QDL_PAD_KEY_COL4__IPU1_SISG4 0x218 0x5e8 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x218 0x5e8 0x944 0x2 0x1 +#define MX6QDL_PAD_KEY_COL4__KEY_COL4 0x218 0x5e8 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_COL4__UART5_RTS_B 0x218 0x5e8 0x93c 0x4 0x0 +#define MX6QDL_PAD_KEY_COL4__UART5_CTS_B 0x218 0x5e8 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_COL4__GPIO4_IO14 0x218 0x5e8 0x000 0x5 0x0 +#define MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x21c 0x5ec 0x7e8 0x0 0x0 +#define MX6QDL_PAD_KEY_ROW4__IPU1_SISG5 0x21c 0x5ec 0x000 0x1 0x0 +#define MX6QDL_PAD_KEY_ROW4__USB_OTG_PWR 0x21c 0x5ec 0x000 0x2 0x0 +#define MX6QDL_PAD_KEY_ROW4__KEY_ROW4 0x21c 0x5ec 0x000 0x3 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_CTS_B 0x21c 0x5ec 0x000 0x4 0x0 +#define MX6QDL_PAD_KEY_ROW4__UART5_RTS_B 0x21c 0x5ec 0x93c 0x4 0x1 +#define MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x21c 0x5ec 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x220 0x5f0 0x000 0x0 0x0 +#define MX6QDL_PAD_GPIO_0__KEY_COL5 0x220 0x5f0 0x8e8 0x2 0x0 +#define MX6QDL_PAD_GPIO_0__ASRC_EXT_CLK 0x220 0x5f0 0x7b0 0x3 0x1 +#define MX6QDL_PAD_GPIO_0__EPIT1_OUT 0x220 0x5f0 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x220 0x5f0 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_0__USB_H1_PWR 0x220 0x5f0 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_0__SNVS_VIO_5 0x220 0x5f0 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_1__ESAI_RX_CLK 0x224 0x5f4 0x86c 0x0 0x1 +#define MX6QDL_PAD_GPIO_1__WDOG2_B 0x224 0x5f4 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_1__KEY_ROW5 0x224 0x5f4 0x8f4 0x2 0x0 +#define MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x224 0x5f4 0x004 0x3 0xff0d0101 +#define MX6QDL_PAD_GPIO_1__PWM2_OUT 0x224 0x5f4 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_1__GPIO1_IO01 0x224 0x5f4 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_1__SD1_CD_B 0x224 0x5f4 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_9__ESAI_RX_FS 0x228 0x5f8 0x85c 0x0 0x1 +#define MX6QDL_PAD_GPIO_9__WDOG1_B 0x228 0x5f8 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_9__KEY_COL6 0x228 0x5f8 0x8ec 0x2 0x0 +#define MX6QDL_PAD_GPIO_9__CCM_REF_EN_B 0x228 0x5f8 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_9__PWM1_OUT 0x228 0x5f8 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_9__GPIO1_IO09 0x228 0x5f8 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_9__SD1_WP 0x228 0x5f8 0x94c 0x6 0x1 +#define MX6QDL_PAD_GPIO_3__ESAI_RX_HF_CLK 0x22c 0x5fc 0x864 0x0 0x1 +#define MX6QDL_PAD_GPIO_3__I2C3_SCL 0x22c 0x5fc 0x8a8 0x2 0x1 +#define MX6QDL_PAD_GPIO_3__XTALOSC_REF_CLK_24M 0x22c 0x5fc 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_3__CCM_CLKO2 0x22c 0x5fc 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_3__GPIO1_IO03 0x22c 0x5fc 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_3__USB_H1_OC 0x22c 0x5fc 0x948 0x6 0x1 +#define MX6QDL_PAD_GPIO_3__MLB_CLK 0x22c 0x5fc 0x900 0x7 0x1 +#define MX6QDL_PAD_GPIO_6__ESAI_TX_CLK 0x230 0x600 0x870 0x0 0x1 +#define MX6QDL_PAD_GPIO_6__ENET_IRQ 0x230 0x600 0x03c 0x11 0xff000609 +#define MX6QDL_PAD_GPIO_6__I2C3_SDA 0x230 0x600 0x8ac 0x2 0x1 +#define MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x230 0x600 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_6__SD2_LCTL 0x230 0x600 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_6__MLB_SIG 0x230 0x600 0x908 0x7 0x1 +#define MX6QDL_PAD_GPIO_2__ESAI_TX_FS 0x234 0x604 0x860 0x0 0x1 +#define MX6QDL_PAD_GPIO_2__KEY_ROW6 0x234 0x604 0x8f8 0x2 0x1 +#define MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x234 0x604 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_2__SD2_WP 0x234 0x604 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_2__MLB_DATA 0x234 0x604 0x904 0x7 0x1 +#define MX6QDL_PAD_GPIO_4__ESAI_TX_HF_CLK 0x238 0x608 0x868 0x0 0x1 +#define MX6QDL_PAD_GPIO_4__KEY_COL7 0x238 0x608 0x8f0 0x2 0x1 +#define MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x238 0x608 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_4__SD2_CD_B 0x238 0x608 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_5__ESAI_TX2_RX3 0x23c 0x60c 0x87c 0x0 0x1 +#define MX6QDL_PAD_GPIO_5__KEY_ROW7 0x23c 0x60c 0x8fc 0x2 0x1 +#define MX6QDL_PAD_GPIO_5__CCM_CLKO1 0x23c 0x60c 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x23c 0x60c 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_5__I2C3_SCL 0x23c 0x60c 0x8a8 0x6 0x2 +#define MX6QDL_PAD_GPIO_5__ARM_EVENTI 0x23c 0x60c 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_7__ESAI_TX4_RX1 0x240 0x610 0x884 0x0 0x1 +#define MX6QDL_PAD_GPIO_7__ECSPI5_RDY 0x240 0x610 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_7__EPIT1_OUT 0x240 0x610 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x240 0x610 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_TX_DATA 0x240 0x610 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_7__UART2_RX_DATA 0x240 0x610 0x928 0x4 0x2 +#define MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x240 0x610 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_7__SPDIF_LOCK 0x240 0x610 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_7__USB_OTG_HOST_MODE 0x240 0x610 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_8__ESAI_TX5_RX0 0x244 0x614 0x888 0x0 0x1 +#define MX6QDL_PAD_GPIO_8__XTALOSC_REF_CLK_32K 0x244 0x614 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_8__EPIT2_OUT 0x244 0x614 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x244 0x614 0x7e4 0x3 0x1 +#define MX6QDL_PAD_GPIO_8__UART2_RX_DATA 0x244 0x614 0x928 0x4 0x3 +#define MX6QDL_PAD_GPIO_8__UART2_TX_DATA 0x244 0x614 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_8__GPIO1_IO08 0x244 0x614 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_8__SPDIF_SR_CLK 0x244 0x614 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE 0x244 0x614 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_16__ESAI_TX3_RX2 0x248 0x618 0x880 0x0 0x1 +#define MX6QDL_PAD_GPIO_16__ENET_1588_EVENT2_IN 0x248 0x618 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x248 0x618 0x83c 0x2 0x1 +#define MX6QDL_PAD_GPIO_16__SD1_LCTL 0x248 0x618 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_16__SPDIF_IN 0x248 0x618 0x914 0x4 0x3 +#define MX6QDL_PAD_GPIO_16__GPIO7_IO11 0x248 0x618 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_16__I2C3_SDA 0x248 0x618 0x8ac 0x6 0x2 +#define MX6QDL_PAD_GPIO_16__JTAG_DE_B 0x248 0x618 0x000 0x7 0x0 +#define MX6QDL_PAD_GPIO_17__ESAI_TX0 0x24c 0x61c 0x874 0x0 0x0 +#define MX6QDL_PAD_GPIO_17__ENET_1588_EVENT3_IN 0x24c 0x61c 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_17__CCM_PMIC_READY 0x24c 0x61c 0x7f0 0x2 0x1 +#define MX6QDL_PAD_GPIO_17__SDMA_EXT_EVENT0 0x24c 0x61c 0x90c 0x3 0x1 +#define MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x24c 0x61c 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x24c 0x61c 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__ESAI_TX1 0x250 0x620 0x878 0x0 0x0 +#define MX6QDL_PAD_GPIO_18__ENET_RX_CLK 0x250 0x620 0x844 0x1 0x1 +#define MX6QDL_PAD_GPIO_18__SD3_VSELECT 0x250 0x620 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_18__SDMA_EXT_EVENT1 0x250 0x620 0x910 0x3 0x1 +#define MX6QDL_PAD_GPIO_18__ASRC_EXT_CLK 0x250 0x620 0x7b0 0x4 0x2 +#define MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x250 0x620 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_18__SNVS_VIO_5_CTL 0x250 0x620 0x000 0x6 0x0 +#define MX6QDL_PAD_GPIO_19__KEY_COL5 0x254 0x624 0x8e8 0x0 0x1 +#define MX6QDL_PAD_GPIO_19__ENET_1588_EVENT0_OUT 0x254 0x624 0x000 0x1 0x0 +#define MX6QDL_PAD_GPIO_19__SPDIF_OUT 0x254 0x624 0x000 0x2 0x0 +#define MX6QDL_PAD_GPIO_19__CCM_CLKO1 0x254 0x624 0x000 0x3 0x0 +#define MX6QDL_PAD_GPIO_19__ECSPI1_RDY 0x254 0x624 0x000 0x4 0x0 +#define MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x254 0x624 0x000 0x5 0x0 +#define MX6QDL_PAD_GPIO_19__ENET_TX_ER 0x254 0x624 0x000 0x6 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x258 0x628 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x258 0x628 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_PIXCLK__ARM_EVENTO 0x258 0x628 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x25c 0x62c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x25c 0x62c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x25c 0x62c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_MCLK__ARM_TRACE_CTL 0x25c 0x62c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN 0x260 0x630 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__EIM_DATA00 0x260 0x630 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x260 0x630 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DATA_EN__ARM_TRACE_CLK 0x260 0x630 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x264 0x634 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__EIM_DATA01 0x264 0x634 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x264 0x634 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_VSYNC__ARM_TRACE00 0x264 0x634 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 0x268 0x638 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT4__EIM_DATA02 0x268 0x638 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ECSPI1_SCLK 0x268 0x638 0x7f4 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT4__KEY_COL5 0x268 0x638 0x8e8 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x268 0x638 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT4__GPIO5_IO22 0x268 0x638 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT4__ARM_TRACE01 0x268 0x638 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 0x26c 0x63c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT5__EIM_DATA03 0x26c 0x63c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ECSPI1_MOSI 0x26c 0x63c 0x7fc 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT5__KEY_ROW5 0x26c 0x63c 0x8f4 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x26c 0x63c 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT5__GPIO5_IO23 0x26c 0x63c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT5__ARM_TRACE02 0x26c 0x63c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 0x270 0x640 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT6__EIM_DATA04 0x270 0x640 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ECSPI1_MISO 0x270 0x640 0x7f8 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT6__KEY_COL6 0x270 0x640 0x8ec 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x270 0x640 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT6__GPIO5_IO24 0x270 0x640 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT6__ARM_TRACE03 0x270 0x640 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 0x274 0x644 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT7__EIM_DATA05 0x274 0x644 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ECSPI1_SS0 0x274 0x644 0x800 0x2 0x3 +#define MX6QDL_PAD_CSI0_DAT7__KEY_ROW6 0x274 0x644 0x8f8 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x274 0x644 0x000 0x4 0x0 +#define MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x274 0x644 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT7__ARM_TRACE04 0x274 0x644 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 0x278 0x648 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT8__EIM_DATA06 0x278 0x648 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ECSPI2_SCLK 0x278 0x648 0x810 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT8__KEY_COL7 0x278 0x648 0x8f0 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x278 0x648 0x89c 0x4 0x1 +#define MX6QDL_PAD_CSI0_DAT8__GPIO5_IO26 0x278 0x648 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT8__ARM_TRACE05 0x278 0x648 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 0x27c 0x64c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT9__EIM_DATA07 0x27c 0x64c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ECSPI2_MOSI 0x27c 0x64c 0x818 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT9__KEY_ROW7 0x27c 0x64c 0x8fc 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x27c 0x64c 0x898 0x4 0x1 +#define MX6QDL_PAD_CSI0_DAT9__GPIO5_IO27 0x27c 0x64c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT9__ARM_TRACE06 0x27c 0x64c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 0x280 0x650 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT10__AUD3_RXC 0x280 0x650 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ECSPI2_MISO 0x280 0x650 0x814 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x280 0x650 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__UART1_RX_DATA 0x280 0x650 0x920 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT10__GPIO5_IO28 0x280 0x650 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT10__ARM_TRACE07 0x280 0x650 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 0x284 0x654 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT11__AUD3_RXFS 0x284 0x654 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ECSPI2_SS0 0x284 0x654 0x81c 0x2 0x2 +#define MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x284 0x654 0x920 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT11__UART1_TX_DATA 0x284 0x654 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT11__GPIO5_IO29 0x284 0x654 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT11__ARM_TRACE08 0x284 0x654 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x288 0x658 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT12__EIM_DATA08 0x288 0x658 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x288 0x658 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT12__UART4_RX_DATA 0x288 0x658 0x938 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT12__GPIO5_IO30 0x288 0x658 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT12__ARM_TRACE09 0x288 0x658 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x28c 0x65c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT13__EIM_DATA09 0x28c 0x65c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x28c 0x65c 0x938 0x3 0x3 +#define MX6QDL_PAD_CSI0_DAT13__UART4_TX_DATA 0x28c 0x65c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT13__GPIO5_IO31 0x28c 0x65c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT13__ARM_TRACE10 0x28c 0x65c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x290 0x660 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT14__EIM_DATA10 0x290 0x660 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_TX_DATA 0x290 0x660 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT14__UART5_RX_DATA 0x290 0x660 0x940 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT14__GPIO6_IO00 0x290 0x660 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT14__ARM_TRACE11 0x290 0x660 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x294 0x664 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT15__EIM_DATA11 0x294 0x664 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT15__UART5_RX_DATA 0x294 0x664 0x940 0x3 0x3 +#define MX6QDL_PAD_CSI0_DAT15__UART5_TX_DATA 0x294 0x664 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT15__GPIO6_IO01 0x294 0x664 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT15__ARM_TRACE12 0x294 0x664 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x298 0x668 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT16__EIM_DATA12 0x298 0x668 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_RTS_B 0x298 0x668 0x934 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__UART4_CTS_B 0x298 0x668 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT16__GPIO6_IO02 0x298 0x668 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT16__ARM_TRACE13 0x298 0x668 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x29c 0x66c 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT17__EIM_DATA13 0x29c 0x66c 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_CTS_B 0x29c 0x66c 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT17__UART4_RTS_B 0x29c 0x66c 0x934 0x3 0x1 +#define MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x29c 0x66c 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT17__ARM_TRACE14 0x29c 0x66c 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x2a0 0x670 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT18__EIM_DATA14 0x2a0 0x670 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT18__UART5_RTS_B 0x2a0 0x670 0x93c 0x3 0x2 +#define MX6QDL_PAD_CSI0_DAT18__UART5_CTS_B 0x2a0 0x670 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT18__GPIO6_IO04 0x2a0 0x670 0x000 0x5 0x0 +#define MX6QDL_PAD_CSI0_DAT18__ARM_TRACE15 0x2a0 0x670 0x000 0x7 0x0 +#define MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x2a4 0x674 0x000 0x0 0x0 +#define MX6QDL_PAD_CSI0_DAT19__EIM_DATA15 0x2a4 0x674 0x000 0x1 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_CTS_B 0x2a4 0x674 0x000 0x3 0x0 +#define MX6QDL_PAD_CSI0_DAT19__UART5_RTS_B 0x2a4 0x674 0x93c 0x3 0x3 +#define MX6QDL_PAD_CSI0_DAT19__GPIO6_IO05 0x2a4 0x674 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x2a8 0x690 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x2a8 0x690 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT7__UART1_RX_DATA 0x2a8 0x690 0x920 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT7__GPIO6_IO17 0x2a8 0x690 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x2ac 0x694 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x2ac 0x694 0x920 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT6__UART1_TX_DATA 0x2ac 0x694 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT6__GPIO6_IO18 0x2ac 0x694 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x2b0 0x698 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_TX_DATA 0x2b0 0x698 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT5__UART2_RX_DATA 0x2b0 0x698 0x928 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x2b0 0x698 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x2b4 0x69c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT4__UART2_RX_DATA 0x2b4 0x69c 0x928 0x1 0x5 +#define MX6QDL_PAD_SD3_DAT4__UART2_TX_DATA 0x2b4 0x69c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x2b4 0x69c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CMD__SD3_CMD 0x2b8 0x6a0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_CTS_B 0x2b8 0x6a0 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CMD__UART2_RTS_B 0x2b8 0x6a0 0x924 0x1 0x2 +#define MX6QDL_PAD_SD3_CMD__FLEXCAN1_TX 0x2b8 0x6a0 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_CMD__GPIO7_IO02 0x2b8 0x6a0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_CLK__SD3_CLK 0x2bc 0x6a4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_CLK__UART2_RTS_B 0x2bc 0x6a4 0x924 0x1 0x3 +#define MX6QDL_PAD_SD3_CLK__UART2_CTS_B 0x2bc 0x6a4 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_CLK__FLEXCAN1_RX 0x2bc 0x6a4 0x7e4 0x2 0x2 +#define MX6QDL_PAD_SD3_CLK__GPIO7_IO03 0x2bc 0x6a4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x2c0 0x6a8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_CTS_B 0x2c0 0x6a8 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT0__UART1_RTS_B 0x2c0 0x6a8 0x91c 0x1 0x2 +#define MX6QDL_PAD_SD3_DAT0__FLEXCAN2_TX 0x2c0 0x6a8 0x000 0x2 0x0 +#define MX6QDL_PAD_SD3_DAT0__GPIO7_IO04 0x2c0 0x6a8 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x2c4 0x6ac 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT1__UART1_RTS_B 0x2c4 0x6ac 0x91c 0x1 0x3 +#define MX6QDL_PAD_SD3_DAT1__UART1_CTS_B 0x2c4 0x6ac 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT1__FLEXCAN2_RX 0x2c4 0x6ac 0x7e8 0x2 0x1 +#define MX6QDL_PAD_SD3_DAT1__GPIO7_IO05 0x2c4 0x6ac 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x2c8 0x6b0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT2__GPIO7_IO06 0x2c8 0x6b0 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x2cc 0x6b4 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_CTS_B 0x2cc 0x6b4 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_DAT3__UART3_RTS_B 0x2cc 0x6b4 0x92c 0x1 0x4 +#define MX6QDL_PAD_SD3_DAT3__GPIO7_IO07 0x2cc 0x6b4 0x000 0x5 0x0 +#define MX6QDL_PAD_SD3_RST__SD3_RESET 0x2d0 0x6b8 0x000 0x0 0x0 +#define MX6QDL_PAD_SD3_RST__UART3_RTS_B 0x2d0 0x6b8 0x92c 0x1 0x5 +#define MX6QDL_PAD_SD3_RST__UART3_CTS_B 0x2d0 0x6b8 0x000 0x1 0x0 +#define MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x2d0 0x6b8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CLE__NAND_CLE 0x2d4 0x6bc 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CLE__IPU2_SISG4 0x2d4 0x6bc 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CLE__GPIO6_IO07 0x2d4 0x6bc 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_ALE__NAND_ALE 0x2d8 0x6c0 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_ALE__SD4_RESET 0x2d8 0x6c0 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_ALE__GPIO6_IO08 0x2d8 0x6c0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0x2dc 0x6c4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_WP_B__IPU2_SISG5 0x2dc 0x6c4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_WP_B__GPIO6_IO09 0x2dc 0x6c4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0x2e0 0x6c8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_RB0__IPU2_DI0_PIN01 0x2e0 0x6c8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_RB0__GPIO6_IO10 0x2e0 0x6c8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0x2e4 0x6cc 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS0__GPIO6_IO11 0x2e4 0x6cc 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS1__NAND_CE1_B 0x2e8 0x6d0 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD4_VSELECT 0x2e8 0x6d0 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS1__SD3_VSELECT 0x2e8 0x6d0 0x000 0x2 0x0 +#define MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x2e8 0x6d0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS2__NAND_CE2_B 0x2ec 0x6d4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS2__IPU1_SISG0 0x2ec 0x6d4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS2__ESAI_TX0 0x2ec 0x6d4 0x874 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS2__EIM_CRE 0x2ec 0x6d4 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS2__CCM_CLKO2 0x2ec 0x6d4 0x000 0x4 0x0 +#define MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x2ec 0x6d4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS2__IPU2_SISG0 0x2ec 0x6d4 0x000 0x6 0x0 +#define MX6QDL_PAD_NANDF_CS3__NAND_CE3_B 0x2f0 0x6d8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_CS3__IPU1_SISG1 0x2f0 0x6d8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_CS3__ESAI_TX1 0x2f0 0x6d8 0x878 0x2 0x1 +#define MX6QDL_PAD_NANDF_CS3__EIM_ADDR26 0x2f0 0x6d8 0x000 0x3 0x0 +#define MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x2f0 0x6d8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_CS3__IPU2_SISG1 0x2f0 0x6d8 0x000 0x6 0x0 +#define MX6QDL_PAD_SD4_CMD__SD4_CMD 0x2f4 0x6dc 0x000 0x0 0x0 +#define MX6QDL_PAD_SD4_CMD__NAND_RE_B 0x2f4 0x6dc 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_TX_DATA 0x2f4 0x6dc 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CMD__UART3_RX_DATA 0x2f4 0x6dc 0x930 0x2 0x2 +#define MX6QDL_PAD_SD4_CMD__GPIO7_IO09 0x2f4 0x6dc 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_CLK__SD4_CLK 0x2f8 0x6e0 0x000 0x0 0x0 +#define MX6QDL_PAD_SD4_CLK__NAND_WE_B 0x2f8 0x6e0 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_CLK__UART3_RX_DATA 0x2f8 0x6e0 0x930 0x2 0x3 +#define MX6QDL_PAD_SD4_CLK__UART3_TX_DATA 0x2f8 0x6e0 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_CLK__GPIO7_IO10 0x2f8 0x6e0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D0__NAND_DATA00 0x2fc 0x6e4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D0__SD1_DATA4 0x2fc 0x6e4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x2fc 0x6e4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D1__NAND_DATA01 0x300 0x6e8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D1__SD1_DATA5 0x300 0x6e8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x300 0x6e8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D2__NAND_DATA02 0x304 0x6ec 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D2__SD1_DATA6 0x304 0x6ec 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x304 0x6ec 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D3__NAND_DATA03 0x308 0x6f0 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D3__SD1_DATA7 0x308 0x6f0 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D3__GPIO2_IO03 0x308 0x6f0 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D4__NAND_DATA04 0x30c 0x6f4 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x30c 0x6f4 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x30c 0x6f4 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D5__NAND_DATA05 0x310 0x6f8 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x310 0x6f8 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x310 0x6f8 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D6__NAND_DATA06 0x314 0x6fc 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x314 0x6fc 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D6__GPIO2_IO06 0x314 0x6fc 0x000 0x5 0x0 +#define MX6QDL_PAD_NANDF_D7__NAND_DATA07 0x318 0x700 0x000 0x0 0x0 +#define MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x318 0x700 0x000 0x1 0x0 +#define MX6QDL_PAD_NANDF_D7__GPIO2_IO07 0x318 0x700 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x31c 0x704 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT0__NAND_DQS 0x31c 0x704 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT0__GPIO2_IO08 0x31c 0x704 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x320 0x708 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x320 0x708 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT1__GPIO2_IO09 0x320 0x708 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x324 0x70c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT2__PWM4_OUT 0x324 0x70c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT2__GPIO2_IO10 0x324 0x70c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x328 0x710 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT3__GPIO2_IO11 0x328 0x710 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x32c 0x714 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x32c 0x714 0x928 0x2 0x6 +#define MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA 0x32c 0x714 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT4__GPIO2_IO12 0x32c 0x714 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x330 0x718 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT5__UART2_RTS_B 0x330 0x718 0x924 0x2 0x4 +#define MX6QDL_PAD_SD4_DAT5__UART2_CTS_B 0x330 0x718 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT5__GPIO2_IO13 0x330 0x718 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x334 0x71c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_CTS_B 0x334 0x71c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT6__UART2_RTS_B 0x334 0x71c 0x924 0x2 0x5 +#define MX6QDL_PAD_SD4_DAT6__GPIO2_IO14 0x334 0x71c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x338 0x720 0x000 0x1 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA 0x338 0x720 0x000 0x2 0x0 +#define MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA 0x338 0x720 0x928 0x2 0x7 +#define MX6QDL_PAD_SD4_DAT7__GPIO2_IO15 0x338 0x720 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x33c 0x724 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT1__ECSPI5_SS0 0x33c 0x724 0x834 0x1 0x1 +#define MX6QDL_PAD_SD1_DAT1__PWM3_OUT 0x33c 0x724 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPT_CAPTURE2 0x33c 0x724 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x33c 0x724 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x340 0x728 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT0__ECSPI5_MISO 0x340 0x728 0x82c 0x1 0x1 +#define MX6QDL_PAD_SD1_DAT0__GPT_CAPTURE1 0x340 0x728 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x340 0x728 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x344 0x72c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT3__ECSPI5_SS2 0x344 0x72c 0x000 0x1 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPT_COMPARE3 0x344 0x72c 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x344 0x72c 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_B 0x344 0x72c 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT3__GPIO1_IO21 0x344 0x72c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT3__WDOG2_RESET_B_DEB 0x344 0x72c 0x000 0x6 0x0 +#define MX6QDL_PAD_SD1_CMD__SD1_CMD 0x348 0x730 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_CMD__ECSPI5_MOSI 0x348 0x730 0x830 0x1 0x0 +#define MX6QDL_PAD_SD1_CMD__PWM4_OUT 0x348 0x730 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CMD__GPT_COMPARE1 0x348 0x730 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x348 0x730 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x34c 0x734 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_DAT2__ECSPI5_SS1 0x34c 0x734 0x838 0x1 0x1 +#define MX6QDL_PAD_SD1_DAT2__GPT_COMPARE2 0x34c 0x734 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_DAT2__PWM2_OUT 0x34c 0x734 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_B 0x34c 0x734 0x000 0x4 0x0 +#define MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x34c 0x734 0x000 0x5 0x0 +#define MX6QDL_PAD_SD1_DAT2__WDOG1_RESET_B_DEB 0x34c 0x734 0x000 0x6 0x0 +#define MX6QDL_PAD_SD1_CLK__SD1_CLK 0x350 0x738 0x000 0x0 0x0 +#define MX6QDL_PAD_SD1_CLK__ECSPI5_SCLK 0x350 0x738 0x828 0x1 0x0 +#define MX6QDL_PAD_SD1_CLK__OSC32K_32K_OUT 0x350 0x738 0x000 0x2 0x0 +#define MX6QDL_PAD_SD1_CLK__GPT_CLKIN 0x350 0x738 0x000 0x3 0x0 +#define MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x350 0x738 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_CLK__SD2_CLK 0x354 0x73c 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_CLK__ECSPI5_SCLK 0x354 0x73c 0x828 0x1 0x1 +#define MX6QDL_PAD_SD2_CLK__KEY_COL5 0x354 0x73c 0x8e8 0x2 0x3 +#define MX6QDL_PAD_SD2_CLK__AUD4_RXFS 0x354 0x73c 0x7c0 0x3 0x1 +#define MX6QDL_PAD_SD2_CLK__GPIO1_IO10 0x354 0x73c 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_CMD__SD2_CMD 0x358 0x740 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_CMD__ECSPI5_MOSI 0x358 0x740 0x830 0x1 0x1 +#define MX6QDL_PAD_SD2_CMD__KEY_ROW5 0x358 0x740 0x8f4 0x2 0x2 +#define MX6QDL_PAD_SD2_CMD__AUD4_RXC 0x358 0x740 0x7bc 0x3 0x1 +#define MX6QDL_PAD_SD2_CMD__GPIO1_IO11 0x358 0x740 0x000 0x5 0x0 +#define MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x35c 0x744 0x000 0x0 0x0 +#define MX6QDL_PAD_SD2_DAT3__ECSPI5_SS3 0x35c 0x744 0x000 0x1 0x0 +#define MX6QDL_PAD_SD2_DAT3__KEY_COL6 0x35c 0x744 0x8ec 0x2 0x2 +#define MX6QDL_PAD_SD2_DAT3__AUD4_TXC 0x35c 0x744 0x7c4 0x3 0x1 +#define MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 0x35c 0x744 0x000 0x5 0x0 + +#endif /* __DTS_IMX6Q_PINFUNC_H */
i.CoreM6 Quad/Dual modules are system on module solutions manufactured by Engicam with following characteristics: CPU NXP i.MX6 DQ, 800MHz RAM 1GB, 32, 64 bit, DDR3-800/1066 NAND SLC,512MB Power supply Single 5V MAX LCD RES FULLHD
and more info at http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 3 ++- arch/arm/dts/imx6q-icore.dts | 59 ++++++++++++++++++++++++++++++++++++++++++++ board/engicam/icorem6/README | 9 ++++++- 3 files changed, 69 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx6q-icore.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 783352a8..0cf360f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -281,7 +281,8 @@ dtb-$(CONFIG_VF610) += vf500-colibri.dtb \ pcm052.dtb
dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ - imx6dl-icore.dtb + imx6dl-icore.dtb \ + imx6q-icore.dtb
dtb-$(CONFIG_SOC_KEYSTONE) += k2hk-evm.dtb \ k2l-evm.dtb \ diff --git a/arch/arm/dts/imx6q-icore.dts b/arch/arm/dts/imx6q-icore.dts new file mode 100644 index 0000000..025f543 --- /dev/null +++ b/arch/arm/dts/imx6q-icore.dts @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-icore.dtsi" + +/ { + model = "Engicam i.CoreM6 Quad/Dual Starter Kit"; + compatible = "engicam,imx6-icore", "fsl,imx6q"; +}; + +&can1 { + status = "okay"; +}; + +&can2 { + status = "okay"; +}; diff --git a/board/engicam/icorem6/README b/board/engicam/icorem6/README index c264a94..12d1e21 100644 --- a/board/engicam/icorem6/README +++ b/board/engicam/icorem6/README @@ -1,12 +1,19 @@ How to use U-Boot on Engicam i.CoreM6 DualLite/Solo and Quad/Dual Starter Kit: -----------------------------------------------------------------------------
-- Build U-Boot for Engicam i.CoreM6 QDL: +- Configure U-Boot for Engicam i.CoreM6 QDL:
$ make mrproper $ make icorem6qdl_mmc_defconfig + +- Build for i.CoreM6 DualLite/Solo + $ make
+- Build for i.CoreM6 Quad/Dual + +$ make DEVICE_TREE=imx6q-icore + This will generate the SPL image called SPL and the u-boot-dtb.img.
- Flash the SPL image into the micro SD card:
Added kconfig for NAND_MXS driver.
Cc: Scott Wood oss@buserror.net Cc: Simon Glass sjg@chromium.org Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mtd/nand/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index 5ce7d6d..df154bf 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -80,6 +80,13 @@ config NAND_ARASAN controller. This uses the hardware ECC for read and write operations.
+config NAND_MXS + bool "MXS NAND support" + depends on MX6 + help + This enables NAND driver for the NAND flash controller on the + MXS processors. + comment "Generic NAND options"
# Enhance depends when converting drivers to Kconfig which use this config
Add NAND support for Engicam i.CoreM6 qdl board.
Boot Log: --------
U-Boot SPL 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43) Trying to boot from NAND NAND : 512 MiB
U-Boot 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43 +0530)
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 55C Reset cause: WDOG Model: Engicam i.CoreM6 DualLite/Solo Starter Kit DRAM: 256 MiB NAND: 512 MiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 icorem6qdl>
Cc: Scott Wood oss@buserror.net Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6/icorem6.c | 63 ++++++++++++++++++++++++++++++++++++ configs/imx6qdl_icore_nand_defconfig | 37 +++++++++++++++++++++ include/configs/imx6qdl_icore.h | 25 +++++++++++++- 3 files changed, 124 insertions(+), 1 deletion(-) create mode 100644 configs/imx6qdl_icore_nand_defconfig
diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index a370c8b..c152007 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -101,6 +101,66 @@ int board_eth_init(bd_t *bis) } #endif
+#ifdef CONFIG_NAND_MXS + +#define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_100K_UP) +#define GPMI_PAD_CTRL1 (PAD_CTL_DSE_40ohm | PAD_CTL_SPEED_MED | \ + PAD_CTL_SRE_FAST) +#define GPMI_PAD_CTRL2 (GPMI_PAD_CTRL0 | GPMI_PAD_CTRL1) + +iomux_v3_cfg_t gpmi_pads[] = { + IOMUX_PADS(PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL0)), + IOMUX_PADS(PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), +}; + +static void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + SETUP_IOMUX_PADS(gpmi_pads); + + /* gate ENFC_CLK_ROOT clock first,before clk source switch */ + clrbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* config gpmi and bch clock to 100 MHz */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK, + MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | + MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | + MXC_CCM_CS2CDR_ENFC_CLK_SEL(3)); + + /* enable ENFC_CLK_ROOT clock */ + setbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} +#endif + int board_early_init_f(void) { SETUP_IOMUX_PADS(uart4_pads); @@ -113,6 +173,9 @@ int board_init(void) /* Address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+#ifdef CONFIG_NAND_MXS + setup_gpmi_nand(); +#endif return 0; }
diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig new file mode 100644 index 0000000..8ac3099 --- /dev/null +++ b/configs/imx6qdl_icore_nand_defconfig @@ -0,0 +1,37 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_MX6Q_ICORE=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" +CONFIG_DEFAULT_FDT_FILE="imx6dl-icore.dtb" +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" +CONFIG_SYS_PROMPT="icorem6qdl> " +CONFIG_SPL=y +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTO_COMPLETE=y +CONFIG_SYS_MAXARGS=32 +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_NAND=y +CONFIG_CMD_CACHE=y +CONFIG_OF_LIBFDT=y +CONFIG_FEC_MXC=y +CONFIG_MXC_UART=y +CONFIG_NAND_MXS=y +CONFIG_NETDEVICES=y +CONFIG_IMX_THERMAL=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SPL_DMA_SUPPORT=y diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index 6b58447..cd3aa43 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -27,6 +27,10 @@ /* Environment in MMC */ # if defined(CONFIG_ENV_IS_IN_MMC) # define CONFIG_ENV_OFFSET 0x100000 +/* Environment in NAND */ +# elif defined(CONFIG_ENV_IS_IN_NAND) +# define CONFIG_ENV_OFFSET 0x400000 +# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE # endif #endif
@@ -111,6 +115,20 @@ # define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR #endif
+/* NAND */ +#ifdef CONFIG_NAND_MXS +# define CONFIG_SYS_MAX_NAND_DEVICE 1 +# define CONFIG_SYS_NAND_BASE 0x40000000 +# define CONFIG_SYS_NAND_5_ADDR_CYCLE +# define CONFIG_SYS_NAND_ONFI_DETECTION +# define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +# define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 + +# define CONFIG_APBH_DMA +# define CONFIG_APBH_DMA_BURST +# define CONFIG_APBH_DMA_BURST8 +#endif + /* Ethernet */ #ifdef CONFIG_FEC_MXC # define IMX_FEC_BASE ENET_BASE_ADDR @@ -125,7 +143,12 @@
/* SPL */ #ifdef CONFIG_SPL -# define CONFIG_SPL_MMC_SUPPORT +# ifdef CONFIG_NAND_MXS +# define CONFIG_SPL_NAND_SUPPORT +# else +# define CONFIG_SPL_MMC_SUPPORT +# endif + # include "imx6_spl.h" # ifdef CONFIG_SPL_BUILD # undef CONFIG_DM_GPIO
Enable MTD device, partition and command support.
Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/configs/imx6qdl_icore.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index cd3aa43..6e33ec3 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -124,6 +124,12 @@ # define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE # define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
+/* MTD device */ +# define CONFIG_MTD_DEVICE +# define CONFIG_CMD_MTDPARTS +# define CONFIG_MTD_PARTITIONS +# define MTDIDS_DEFAULT "nand0=nand" + # define CONFIG_APBH_DMA # define CONFIG_APBH_DMA_BURST # define CONFIG_APBH_DMA_BURST8
icorem6qdl> mtdparts
device nand0 <nand>, # parts = 6 0: spl 0x00200000 0x00000000 0 1: uboot 0x00200000 0x00200000 0 2: env 0x00100000 0x00400000 0 3: kernel 0x00400000 0x00500000 0 4: dtb 0x00100000 0x00900000 0 5: rootfs 0x1f600000 0x00a00000 0
Cc: Stefano Babic sbabic@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/configs/imx6qdl_icore.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/imx6qdl_icore.h b/include/configs/imx6qdl_icore.h index 6e33ec3..f8a1263 100644 --- a/include/configs/imx6qdl_icore.h +++ b/include/configs/imx6qdl_icore.h @@ -129,6 +129,8 @@ # define CONFIG_CMD_MTDPARTS # define CONFIG_MTD_PARTITIONS # define MTDIDS_DEFAULT "nand0=nand" +# define MTDPARTS_DEFAULT "mtdparts=nand:2m(spl),2m(uboot)," \ + "1m(env),4m(kernel),1m(dtb),-(rootfs)"
Jagan Teki
