[U-Boot] [PATCH 0/6] Sync and consolidate Linux-derived printk, BUILD_BUG, BUG, WARN, etc.
buildman is 60% done, and no regression so far.
I will report the full-stat when buildman is complete.
Masahiro Yamada (6): printk: collect printk stuff into <linux/printk.h> treewide: replace with error() with pr_err() common.h: remove error() vsprintf.h: include <linux/types.h> bug.h: sync BUILD_BUG stuff with Linux 4.13 bug.h: move runtime BUG/WARN macros into <linux/bug.h>
arch/arm/mach-omap2/am33xx/board.c | 2 +- arch/arm/mach-omap2/utils.c | 4 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 2 +- arch/arm/mach-rockchip/rk3188-board.c | 2 +- arch/arm/mach-rockchip/rk3368-board-spl.c | 4 +- arch/arm/mach-rockchip/rk3399/sdram_rk3399.c | 2 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 2 +- arch/arm/mach-tegra/ivc.c | 8 +-- arch/arm/mach-tegra/tegra124/xusb-padctl.c | 2 +- arch/arm/mach-tegra/tegra186/nvtboot_mem.c | 4 +- arch/arm/mach-tegra/tegra20/clock.c | 6 +- arch/arm/mach-tegra/tegra210/xusb-padctl.c | 2 +- arch/arm/mach-tegra/tegra30/clock.c | 6 +- arch/arm/mach-tegra/xusb-padctl-common.c | 22 +++--- arch/arm/mach-uniphier/dram_init.c | 3 - arch/arm/mach-uniphier/init.h | 5 -- arch/x86/cpu/tangier/sdram.c | 6 +- board/nvidia/jetson-tk1/jetson-tk1.c | 6 +- board/samsung/common/exynos5-dt.c | 2 +- board/samsung/common/misc.c | 2 +- board/samsung/goni/goni.c | 4 +- board/samsung/odroid/odroid.c | 12 ++-- cmd/fastboot.c | 2 +- cmd/nvedit.c | 6 +- cmd/regulator.c | 2 +- cmd/thordown.c | 6 +- cmd/tpm_test.c | 6 +- cmd/usb_gadget_sdp.c | 4 +- cmd/usb_mass_storage.c | 6 +- common/dfu.c | 6 +- common/fb_mmc.c | 36 +++++----- common/fb_nand.c | 12 ++-- common/spl/spl_dfu.c | 4 +- common/spl/spl_sdp.c | 4 +- common/update.c | 2 +- disk/part_efi.c | 10 +-- drivers/adc/adc-uclass.c | 6 +- drivers/adc/exynos-adc.c | 6 +- drivers/adc/sandbox.c | 6 +- drivers/ata/dwc_ahci.c | 6 +- drivers/bios_emulator/include/x86emu/x86emui.h | 3 - drivers/clk/clk_boston.c | 4 +- drivers/clk/clk_stm32f7.c | 2 +- drivers/clk/rockchip/clk_rk3368.c | 8 +-- drivers/clk/rockchip/clk_rk3399.c | 6 +- drivers/clk/rockchip/clk_rv1108.c | 2 +- drivers/dfu/dfu.c | 14 ++-- drivers/dfu/dfu_mmc.c | 18 ++--- drivers/dfu/dfu_ram.c | 8 +-- drivers/dfu/dfu_tftp.c | 4 +- drivers/dma/dma-uclass.c | 2 +- drivers/dma/lpc32xx_dma.c | 8 +-- drivers/dma/ti-edma3.c | 2 +- drivers/i2c/i2c-gpio.c | 2 +- drivers/i2c/omap24xx_i2c.c | 2 +- drivers/i2c/stm32f7_i2c.c | 16 ++--- drivers/i2c/tegra_i2c.c | 4 +- drivers/misc/tegra186_bpmp.c | 28 ++++---- drivers/mmc/exynos_dw_mmc.c | 2 +- drivers/mmc/hi6220_dw_mmc.c | 2 +- drivers/mmc/xenon_sdhci.c | 4 +- drivers/mtd/nand/lpc32xx_nand_mlc.c | 6 +- drivers/mtd/nand/pxa3xx_nand.c | 2 +- drivers/net/bcm-sf2-eth-gmac.c | 14 ++-- drivers/net/bcm-sf2-eth.c | 18 ++--- drivers/net/cpsw-common.c | 8 +-- drivers/net/cpsw.c | 8 +-- drivers/net/dwc_eth_qos.c | 92 +++++++++++++------------- drivers/net/ep93xx_eth.c | 16 ++--- drivers/net/keystone_net.c | 14 ++-- drivers/pci/pci_tegra.c | 50 +++++++------- drivers/pci/pcie_xilinx.c | 2 +- drivers/phy/marvell/comphy_cp110.c | 40 +++++------ drivers/phy/ti-pipe3-phy.c | 12 ++-- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 2 +- drivers/pinctrl/pinctrl-sti.c | 14 ++-- drivers/pinctrl/pinctrl_stm32.c | 2 +- drivers/power/pmic/as3722.c | 12 ++-- drivers/power/pmic/as3722_gpio.c | 10 +-- drivers/power/pmic/i2c_pmic_emul.c | 6 +- drivers/power/pmic/lp873x.c | 4 +- drivers/power/pmic/lp87565.c | 4 +- drivers/power/pmic/max77686.c | 4 +- drivers/power/pmic/max8997.c | 4 +- drivers/power/pmic/max8998.c | 4 +- drivers/power/pmic/palmas.c | 4 +- drivers/power/pmic/pfuze100.c | 4 +- drivers/power/pmic/s2mps11.c | 4 +- drivers/power/pmic/s5m8767.c | 4 +- drivers/power/pmic/sandbox.c | 6 +- drivers/power/pmic/tps65090.c | 4 +- drivers/power/regulator/fixed.c | 2 +- drivers/power/regulator/gpio-regulator.c | 2 +- drivers/power/regulator/max77686.c | 20 +++--- drivers/power/regulator/sandbox.c | 18 ++--- drivers/ram/rockchip/dmc-rk3368.c | 14 ++-- drivers/ram/stm32_sdram.c | 8 +-- drivers/reset/sti-reset.c | 10 +-- drivers/spi/atmel_spi.c | 2 +- drivers/spi/lpc32xx_ssp.c | 6 +- drivers/sysreset/sysreset_sti.c | 6 +- drivers/sysreset/sysreset_syscon.c | 4 +- drivers/sysreset/sysreset_watchdog.c | 2 +- drivers/tpm/tpm_tis_infineon.c | 2 +- drivers/usb/common/common.c | 2 +- drivers/usb/dwc3/linux-compat.h | 2 - drivers/usb/eth/mcs7830.c | 12 ++-- drivers/usb/gadget/at91_udc.c | 4 +- drivers/usb/gadget/atmel_usba_udc.c | 6 +- drivers/usb/gadget/dwc2_udc_otg.c | 2 +- drivers/usb/gadget/ether.c | 42 ++++++------ drivers/usb/gadget/f_fastboot.c | 10 +-- drivers/usb/gadget/f_sdp.c | 16 ++--- drivers/usb/gadget/f_thor.c | 26 ++++---- drivers/usb/host/dwc2.c | 2 +- drivers/usb/host/ehci-generic.c | 18 ++--- drivers/usb/host/ohci-generic.c | 18 ++--- drivers/usb/host/xhci-dwc3.c | 6 +- drivers/usb/host/xhci-rockchip.c | 12 ++-- drivers/usb/musb-new/linux-compat.h | 2 - drivers/usb/musb-new/ti-musb.c | 12 ++-- drivers/video/am335x-fb.c | 2 +- env/common.c | 8 +-- env/sf.c | 2 +- fs/jffs2/jffs2_nand_1pass.c | 2 +- fs/yaffs2/yaffs_uboot_glue.c | 2 +- include/common.h | 20 +----- include/linux/bug.h | 77 ++++++++------------- include/linux/build_bug.h | 84 +++++++++++++++++++++++ include/linux/compat.h | 26 -------- include/linux/compiler.h | 6 +- include/linux/mtd/mtd.h | 10 +-- include/linux/printk.h | 77 +++++++++++++++++++++ include/vsprintf.h | 1 + 134 files changed, 719 insertions(+), 639 deletions(-) create mode 100644 include/linux/build_bug.h create mode 100644 include/linux/printk.h
When we want to print something to the console, we generally include <common.h>, then use printf() and friends.
When we import code from Linux, planning to sync it from time to time, we want to use printk() and pr_*(). U-Boot does not support them in a clean way. So, people end up with local macros, or compat headers here and there, then we occasionally see build errors of definition conflicts.
We have some compat macros in include/linux/compat.h, but putting all sorts of unrelated things into a single header looks a bad idea to me. One more thing, <linux/compat.h> simply replaces "printk" pattern with "printf", so it needs <common.h> included. This header pulls in tons of headers. Putting #include <common.h> at the beginning of every file is a bad convention.
Hence this patch, to move all printk stuff into <linux/printk.h>. If you want to use printk() stuff, just include this header, and that's it.
Currently, all printk() and pr_*() behave as printf(), except that pr_debug() is enabled only when DEBUG is defined. Of course, it will be easy to implement "loglevel" concept to differentiate pr_*(), but this kind of clean-up must happen first.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/dram_init.c | 3 - arch/arm/mach-uniphier/init.h | 5 -- drivers/bios_emulator/include/x86emu/x86emui.h | 3 - drivers/usb/dwc3/linux-compat.h | 1 - drivers/usb/musb-new/linux-compat.h | 2 - include/common.h | 6 +- include/linux/compat.h | 11 ---- include/linux/mtd/mtd.h | 10 +--- include/linux/printk.h | 77 ++++++++++++++++++++++++++ 9 files changed, 79 insertions(+), 39 deletions(-) create mode 100644 include/linux/printk.h
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index 32d3593..2213685 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -15,9 +15,6 @@ #include "sg-regs.h" #include "soc-info.h"
-#define pr_warn(fmt, args...) printf(fmt, ##args) -#define pr_err(fmt, args...) printf(fmt, ##args) - DECLARE_GLOBAL_DATA_PTR;
struct uniphier_memif_data { diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 29f638d..da20935 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -104,9 +104,4 @@ int uniphier_have_internal_stm(void); int uniphier_boot_from_backend(void); int uniphier_pin_init(const char *pinconfig_name);
-#undef pr_warn -#define pr_warn(fmt, args...) printf(fmt, ##args) -#undef pr_err -#define pr_err(fmt, args...) printf(fmt, ##args) - #endif /* __MACH_INIT_H */ diff --git a/drivers/bios_emulator/include/x86emu/x86emui.h b/drivers/bios_emulator/include/x86emu/x86emui.h index a74957d..3537255 100644 --- a/drivers/bios_emulator/include/x86emu/x86emui.h +++ b/drivers/bios_emulator/include/x86emu/x86emui.h @@ -72,9 +72,6 @@ #include <string.h> #endif
-#define printk printf - - /*--------------------------- Inline Functions ----------------------------*/
#ifdef __cplusplus diff --git a/drivers/usb/dwc3/linux-compat.h b/drivers/usb/dwc3/linux-compat.h index 9e944a3..64db4ec 100644 --- a/drivers/usb/dwc3/linux-compat.h +++ b/drivers/usb/dwc3/linux-compat.h @@ -12,7 +12,6 @@ #ifndef __DWC3_LINUX_COMPAT__ #define __DWC3_LINUX_COMPAT__
-#define pr_debug(format) debug(format) #define WARN(val, format, arg...) debug(format, ##arg) #define dev_WARN(dev, format, arg...) debug(format, ##arg) #define WARN_ON_ONCE(val) debug("Error %d\n", val) diff --git a/drivers/usb/musb-new/linux-compat.h b/drivers/usb/musb-new/linux-compat.h index 4dae83e..7bb53d2 100644 --- a/drivers/usb/musb-new/linux-compat.h +++ b/drivers/usb/musb-new/linux-compat.h @@ -5,8 +5,6 @@ #include <linux/list.h> #include <linux/compat.h>
-#define pr_debug(fmt, args...) debug(fmt, ##args) - #define WARN(condition, fmt, args...) ({ \ int ret_warn = !!condition; \ if (ret_warn) \ diff --git a/include/common.h b/include/common.h index aaed131..ae3b876 100644 --- a/include/common.h +++ b/include/common.h @@ -25,6 +25,7 @@ typedef volatile unsigned char vu_char; #include <linux/bitops.h> #include <linux/delay.h> #include <linux/types.h> +#include <linux/printk.h> #include <linux/string.h> #include <linux/stringify.h> #include <asm/ptrace.h> @@ -54,11 +55,6 @@ typedef volatile unsigned char vu_char; #define _SPL_BUILD 0 #endif
-/* Define this at the top of a file to add a prefix to debug messages */ -#ifndef pr_fmt -#define pr_fmt(fmt) fmt -#endif - /* * Output a debug text when condition "cond" is met. The "cond" should be * computed by a preprocessor in the best case, allowing for the best diff --git a/include/linux/compat.h b/include/linux/compat.h index 2336b56..bc027ad 100644 --- a/include/linux/compat.h +++ b/include/linux/compat.h @@ -25,17 +25,6 @@ extern struct p_current *current; printf(fmt, ##args) #define dev_warn(dev, fmt, args...) \ printf(fmt, ##args) -#define printk printf -#define printk_once printf - -#define KERN_EMERG -#define KERN_ALERT -#define KERN_CRIT -#define KERN_ERR -#define KERN_WARNING -#define KERN_NOTICE -#define KERN_INFO -#define KERN_DEBUG
#define GFP_ATOMIC ((gfp_t) 0) #define GFP_KERNEL ((gfp_t) 0) diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 1fd17c3..3e1694b 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -452,28 +452,20 @@ static inline void mtd_erase_callback(struct erase_info *instr) #define MTD_DEBUG_LEVEL3 (3) /* Noisy */
#ifdef CONFIG_MTD_DEBUG -#define pr_debug(args...) MTDDEBUG(MTD_DEBUG_LEVEL0, args) #define MTDDEBUG(n, args...) \ do { \ if (n <= CONFIG_MTD_DEBUG_VERBOSE) \ printk(KERN_INFO args); \ } while(0) #else /* CONFIG_MTD_DEBUG */ -#define pr_debug(args...) #define MTDDEBUG(n, args...) \ do { \ if (0) \ printk(KERN_INFO args); \ } while(0) #endif /* CONFIG_MTD_DEBUG */ -#define pr_info(args...) MTDDEBUG(MTD_DEBUG_LEVEL0, args) -#define pr_warn(args...) MTDDEBUG(MTD_DEBUG_LEVEL0, args) -#define pr_err(args...) MTDDEBUG(MTD_DEBUG_LEVEL0, args) -#define pr_crit(args...) MTDDEBUG(MTD_DEBUG_LEVEL0, args) -#define pr_cont(args...) MTDDEBUG(MTD_DEBUG_LEVEL0, args) -#define pr_notice(args...) MTDDEBUG(MTD_DEBUG_LEVEL0, args) #endif - + static inline int mtd_is_bitflip(int err) { return err == -EUCLEAN; } diff --git a/include/linux/printk.h b/include/linux/printk.h new file mode 100644 index 0000000..3752567 --- /dev/null +++ b/include/linux/printk.h @@ -0,0 +1,77 @@ +#ifndef __KERNEL_PRINTK__ +#define __KERNEL_PRINTK__ + +#include <linux/compiler.h> + +#define KERN_EMERG +#define KERN_ALERT +#define KERN_CRIT +#define KERN_ERR +#define KERN_WARNING +#define KERN_NOTICE +#define KERN_INFO +#define KERN_DEBUG +#define KERN_CONT + +__printf(1, 2) int printf(const char *fmt, ...); + +/* + * Dummy printk for disabled debugging statements to use whilst maintaining + * gcc's format checking. + */ +#define no_printk(fmt, ...) \ +({ \ + do { \ + if (0) \ + printk(fmt, ##__VA_ARGS__); \ + } while (0); \ + 0; \ +}) + +#define printk(fmt, ...) \ + printf(fmt, ##__VA_ARGS__) + +#ifndef pr_fmt +#define pr_fmt(fmt) fmt +#endif + +#define pr_emerg(fmt, ...) \ + printk(KERN_EMERG pr_fmt(fmt), ##__VA_ARGS__) +#define pr_alert(fmt, ...) \ + printk(KERN_ALERT pr_fmt(fmt), ##__VA_ARGS__) +#define pr_crit(fmt, ...) \ + printk(KERN_CRIT pr_fmt(fmt), ##__VA_ARGS__) +#define pr_err(fmt, ...) \ + printk(KERN_ERR pr_fmt(fmt), ##__VA_ARGS__) +#define pr_warning(fmt, ...) \ + printk(KERN_WARNING pr_fmt(fmt), ##__VA_ARGS__) +#define pr_warn pr_warning +#define pr_notice(fmt, ...) \ + printk(KERN_NOTICE pr_fmt(fmt), ##__VA_ARGS__) +#define pr_info(fmt, ...) \ + printk(KERN_INFO pr_fmt(fmt), ##__VA_ARGS__) + +#define pr_cont(fmt, ...) \ + printk(KERN_CONT fmt, ##__VA_ARGS__) + +/* pr_devel() should produce zero code unless DEBUG is defined */ +#ifdef DEBUG +#define pr_devel(fmt, ...) \ + printk(KERN_DEBUG pr_fmt(fmt), ##__VA_ARGS__) +#else +#define pr_devel(fmt, ...) \ + no_printk(KERN_DEBUG pr_fmt(fmt), ##__VA_ARGS__) +#endif + +#ifdef DEBUG +#define pr_debug(fmt, ...) \ + printk(KERN_DEBUG pr_fmt(fmt), ##__VA_ARGS__) +#else +#define pr_debug(fmt, ...) \ + no_printk(KERN_DEBUG pr_fmt(fmt), ##__VA_ARGS__) +#endif + +#define printk_once(fmt, ...) \ + printk(fmt, ##__VA_ARGS__) + +#endif
U-Boot widely uses error() as a bit noisier variant of printf().
This macro causes name conflict with the following line in include/linux/compiler-gcc.h:
# define __compiletime_error(message) __attribute__((error(message)))
This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG stuff with Linux. (Notice Linux's BUILD_BUG_ON_MSG is defined by using compiletime_assert().)
Let's convert error() into now treewide-available pr_err().
Done with the help of Coccinelle, excluing tools/ directory.
The semantic patch I used is as follows:
// <smpl> @@@@ -error +pr_err (...) // </smpl>
arch/arm/mach-omap2/am33xx/board.c | 2 +- arch/arm/mach-omap2/utils.c | 4 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 2 +- arch/arm/mach-rockchip/rk3188-board.c | 2 +- arch/arm/mach-rockchip/rk3368-board-spl.c | 4 +- arch/arm/mach-rockchip/rk3399/sdram_rk3399.c | 2 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 2 +- arch/arm/mach-tegra/ivc.c | 8 +-- arch/arm/mach-tegra/tegra124/xusb-padctl.c | 2 +- arch/arm/mach-tegra/tegra186/nvtboot_mem.c | 4 +- arch/arm/mach-tegra/tegra20/clock.c | 6 +- arch/arm/mach-tegra/tegra210/xusb-padctl.c | 2 +- arch/arm/mach-tegra/tegra30/clock.c | 6 +- arch/arm/mach-tegra/xusb-padctl-common.c | 22 +++---- arch/x86/cpu/tangier/sdram.c | 6 +- board/nvidia/jetson-tk1/jetson-tk1.c | 6 +- board/samsung/common/exynos5-dt.c | 2 +- board/samsung/common/misc.c | 2 +- board/samsung/goni/goni.c | 4 +- board/samsung/odroid/odroid.c | 12 ++-- cmd/fastboot.c | 2 +- cmd/nvedit.c | 6 +- cmd/regulator.c | 2 +- cmd/thordown.c | 6 +- cmd/tpm_test.c | 6 +- cmd/usb_gadget_sdp.c | 4 +- cmd/usb_mass_storage.c | 6 +- common/dfu.c | 6 +- common/fb_mmc.c | 36 +++++------ common/fb_nand.c | 12 ++-- common/spl/spl_dfu.c | 4 +- common/spl/spl_sdp.c | 4 +- common/update.c | 2 +- disk/part_efi.c | 10 +-- drivers/adc/adc-uclass.c | 6 +- drivers/adc/exynos-adc.c | 6 +- drivers/adc/sandbox.c | 6 +- drivers/ata/dwc_ahci.c | 6 +- drivers/clk/clk_boston.c | 4 +- drivers/clk/clk_stm32f7.c | 2 +- drivers/clk/rockchip/clk_rk3368.c | 8 +-- drivers/clk/rockchip/clk_rk3399.c | 6 +- drivers/clk/rockchip/clk_rv1108.c | 2 +- drivers/dfu/dfu.c | 14 ++-- drivers/dfu/dfu_mmc.c | 18 +++--- drivers/dfu/dfu_ram.c | 8 +-- drivers/dfu/dfu_tftp.c | 4 +- drivers/dma/dma-uclass.c | 2 +- drivers/dma/lpc32xx_dma.c | 8 +-- drivers/dma/ti-edma3.c | 2 +- drivers/i2c/i2c-gpio.c | 2 +- drivers/i2c/omap24xx_i2c.c | 2 +- drivers/i2c/stm32f7_i2c.c | 16 ++--- drivers/i2c/tegra_i2c.c | 4 +- drivers/misc/tegra186_bpmp.c | 28 ++++---- drivers/mmc/exynos_dw_mmc.c | 2 +- drivers/mmc/hi6220_dw_mmc.c | 2 +- drivers/mmc/xenon_sdhci.c | 4 +- drivers/mtd/nand/lpc32xx_nand_mlc.c | 6 +- drivers/mtd/nand/pxa3xx_nand.c | 2 +- drivers/net/bcm-sf2-eth-gmac.c | 14 ++-- drivers/net/bcm-sf2-eth.c | 18 +++--- drivers/net/cpsw-common.c | 8 +-- drivers/net/cpsw.c | 8 +-- drivers/net/dwc_eth_qos.c | 92 +++++++++++++-------------- drivers/net/ep93xx_eth.c | 16 ++--- drivers/net/keystone_net.c | 14 ++-- drivers/pci/pci_tegra.c | 50 +++++++-------- drivers/pci/pcie_xilinx.c | 2 +- drivers/phy/marvell/comphy_cp110.c | 40 ++++++------ drivers/phy/ti-pipe3-phy.c | 12 ++-- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 2 +- drivers/pinctrl/pinctrl-sti.c | 14 ++-- drivers/pinctrl/pinctrl_stm32.c | 2 +- drivers/power/pmic/as3722.c | 12 ++-- drivers/power/pmic/as3722_gpio.c | 10 +-- drivers/power/pmic/i2c_pmic_emul.c | 6 +- drivers/power/pmic/lp873x.c | 4 +- drivers/power/pmic/lp87565.c | 4 +- drivers/power/pmic/max77686.c | 4 +- drivers/power/pmic/max8997.c | 4 +- drivers/power/pmic/max8998.c | 4 +- drivers/power/pmic/palmas.c | 4 +- drivers/power/pmic/pfuze100.c | 4 +- drivers/power/pmic/s2mps11.c | 4 +- drivers/power/pmic/s5m8767.c | 4 +- drivers/power/pmic/sandbox.c | 6 +- drivers/power/pmic/tps65090.c | 4 +- drivers/power/regulator/fixed.c | 2 +- drivers/power/regulator/gpio-regulator.c | 2 +- drivers/power/regulator/max77686.c | 20 +++--- drivers/power/regulator/sandbox.c | 18 +++--- drivers/ram/rockchip/dmc-rk3368.c | 14 ++-- drivers/ram/stm32_sdram.c | 8 +-- drivers/reset/sti-reset.c | 10 +-- drivers/spi/atmel_spi.c | 2 +- drivers/spi/lpc32xx_ssp.c | 6 +- drivers/sysreset/sysreset_sti.c | 6 +- drivers/sysreset/sysreset_syscon.c | 4 +- drivers/sysreset/sysreset_watchdog.c | 2 +- drivers/tpm/tpm_tis_infineon.c | 2 +- drivers/usb/common/common.c | 2 +- drivers/usb/eth/mcs7830.c | 12 ++-- drivers/usb/gadget/at91_udc.c | 4 +- drivers/usb/gadget/atmel_usba_udc.c | 6 +- drivers/usb/gadget/dwc2_udc_otg.c | 2 +- drivers/usb/gadget/ether.c | 42 ++++++------ drivers/usb/gadget/f_fastboot.c | 10 +-- drivers/usb/gadget/f_sdp.c | 16 ++--- drivers/usb/gadget/f_thor.c | 26 ++++---- drivers/usb/host/dwc2.c | 2 +- drivers/usb/host/ehci-generic.c | 18 +++--- drivers/usb/host/ohci-generic.c | 18 +++--- drivers/usb/host/xhci-dwc3.c | 6 +- drivers/usb/host/xhci-rockchip.c | 12 ++-- drivers/usb/musb-new/ti-musb.c | 12 ++-- drivers/video/am335x-fb.c | 2 +- env/common.c | 8 +-- env/sf.c | 2 +- fs/jffs2/jffs2_nand_1pass.c | 2 +- fs/yaffs2/yaffs_uboot_glue.c | 2 +- 121 files changed, 521 insertions(+), 521 deletions(-)
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index 913a44a..ae86b69 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -241,7 +241,7 @@ int arch_misc_init(void) #if defined(CONFIG_DM_ETH) && defined(CONFIG_USB_ETHER) ret = usb_ether_init(); if (ret) { - error("USB ether init failed\n"); + pr_err("USB ether init failed\n"); return ret; } #endif diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index 0b0bf18..f2fafae 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -87,13 +87,13 @@ static u32 omap_mmc_get_part_size(const char *part)
dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { - error("invalid mmc device\n"); + pr_err("invalid mmc device\n"); return 0; }
res = part_get_info_by_name(dev_desc, part, &info); if (res < 0) { - error("cannot find partition: '%s'\n", part); + pr_err("cannot find partition: '%s'\n", part); return 0; }
diff --git a/arch/arm/mach-rockchip/rk3188-board-spl.c b/arch/arm/mach-rockchip/rk3188-board-spl.c index d3866bf..406207e 100644 --- a/arch/arm/mach-rockchip/rk3188-board-spl.c +++ b/arch/arm/mach-rockchip/rk3188-board-spl.c @@ -151,7 +151,7 @@ void board_init_f(ulong dummy) */ pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU); if (IS_ERR(pmu)) - error("pmu syscon returned %ld\n", PTR_ERR(pmu)); + pr_err("pmu syscon returned %ld\n", PTR_ERR(pmu)); SAVE_SP_ADDR = readl(&pmu->sys_reg[2]);
ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); diff --git a/arch/arm/mach-rockchip/rk3188-board.c b/arch/arm/mach-rockchip/rk3188-board.c index 622e046..96859a5 100644 --- a/arch/arm/mach-rockchip/rk3188-board.c +++ b/arch/arm/mach-rockchip/rk3188-board.c @@ -26,7 +26,7 @@ int board_late_init(void)
grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); if (IS_ERR(grf)) { - error("grf syscon returned %ld\n", PTR_ERR(grf)); + pr_err("grf syscon returned %ld\n", PTR_ERR(grf)); } else { /* enable noc remap to mimic legacy loaders */ rk_clrsetreg(&grf->soc_con0, diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c index cabf344..72d2c97 100644 --- a/arch/arm/mach-rockchip/rk3368-board-spl.c +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -38,13 +38,13 @@ void board_init_f(ulong dummy) /* Set up our preloader console */ ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); if (ret) { - error("%s: pinctrl init failed: %d\n", __func__, ret); + pr_err("%s: pinctrl init failed: %d\n", __func__, ret); hang(); }
ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_UART0); if (ret) { - error("%s: failed to set up console UART\n", __func__); + pr_err("%s: failed to set up console UART\n", __func__); hang(); }
diff --git a/arch/arm/mach-rockchip/rk3399/sdram_rk3399.c b/arch/arm/mach-rockchip/rk3399/sdram_rk3399.c index 63342ab..1a44170 100644 --- a/arch/arm/mach-rockchip/rk3399/sdram_rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/sdram_rk3399.c @@ -551,7 +551,7 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, tmp = get_timer(0); do { if (get_timer(tmp) > timeout_ms) { - error("DRAM (%s): phy failed to lock within %ld ms\n", + pr_err("DRAM (%s): phy failed to lock within %ld ms\n", __func__, timeout_ms); return -ETIME; } diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index 66f1ec2..ae16897 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -174,7 +174,7 @@ void socfpga_emac_manage_reset(ulong emacbase, u32 state) emacmask = ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; break; default: - error("emac base address unexpected! %lx", emacbase); + pr_err("emac base address unexpected! %lx", emacbase); hang(); break; } diff --git a/arch/arm/mach-tegra/ivc.c b/arch/arm/mach-tegra/ivc.c index cf6626f..dec7d90 100644 --- a/arch/arm/mach-tegra/ivc.c +++ b/arch/arm/mach-tegra/ivc.c @@ -493,7 +493,7 @@ static int check_ivc_params(ulong qbase1, ulong qbase2, uint32_t nframes, (TEGRA_IVC_ALIGN - 1));
if ((uint64_t)nframes * (uint64_t)frame_size >= 0x100000000) { - error("tegra_ivc: nframes * frame_size overflows\n"); + pr_err("tegra_ivc: nframes * frame_size overflows\n"); return -EINVAL; }
@@ -503,12 +503,12 @@ static int check_ivc_params(ulong qbase1, ulong qbase2, uint32_t nframes, */ if ((qbase1 & (TEGRA_IVC_ALIGN - 1)) || (qbase2 & (TEGRA_IVC_ALIGN - 1))) { - error("tegra_ivc: channel start not aligned\n"); + pr_err("tegra_ivc: channel start not aligned\n"); return -EINVAL; }
if (frame_size & (TEGRA_IVC_ALIGN - 1)) { - error("tegra_ivc: frame size not adequately aligned\n"); + pr_err("tegra_ivc: frame size not adequately aligned\n"); return -EINVAL; }
@@ -521,7 +521,7 @@ static int check_ivc_params(ulong qbase1, ulong qbase2, uint32_t nframes, }
if (ret) { - error("tegra_ivc: queue regions overlap\n"); + pr_err("tegra_ivc: queue regions overlap\n"); return ret; }
diff --git a/arch/arm/mach-tegra/tegra124/xusb-padctl.c b/arch/arm/mach-tegra/tegra124/xusb-padctl.c index d326a6a..bfc0ab8 100644 --- a/arch/arm/mach-tegra/tegra124/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra124/xusb-padctl.c @@ -137,7 +137,7 @@ static int tegra_xusb_padctl_disable(struct tegra_xusb_padctl *padctl) u32 value;
if (padctl->enable == 0) { - error("unbalanced enable/disable"); + pr_err("unbalanced enable/disable"); return 0; }
diff --git a/arch/arm/mach-tegra/tegra186/nvtboot_mem.c b/arch/arm/mach-tegra/tegra186/nvtboot_mem.c index 966cf9f..5224ef6 100644 --- a/arch/arm/mach-tegra/tegra186/nvtboot_mem.c +++ b/arch/arm/mach-tegra/tegra186/nvtboot_mem.c @@ -45,12 +45,12 @@ int dram_init(void)
node = fdt_path_offset(nvtboot_blob, "/memory"); if (node < 0) { - error("Can't find /memory node in nvtboot DTB"); + pr_err("Can't find /memory node in nvtboot DTB"); hang(); } prop = fdt_getprop(nvtboot_blob, node, "reg", &len); if (!prop) { - error("Can't find /memory/reg property in nvtboot DTB"); + pr_err("Can't find /memory/reg property in nvtboot DTB"); hang(); }
diff --git a/arch/arm/mach-tegra/tegra20/clock.c b/arch/arm/mach-tegra/tegra20/clock.c index ec04cf5..81fb1d8 100644 --- a/arch/arm/mach-tegra/tegra20/clock.c +++ b/arch/arm/mach-tegra/tegra20/clock.c @@ -667,7 +667,7 @@ static int tegra_plle_train(void) } while (--timeout);
if (timeout == 0) { - error("timeout waiting for PLLE to become ready"); + pr_err("timeout waiting for PLLE to become ready"); return -ETIMEDOUT; }
@@ -697,7 +697,7 @@ int tegra_plle_enable(void) if ((value & PLLE_MISC_PLL_READY) == 0) { err = tegra_plle_train(); if (err < 0) { - error("failed to train PLLE: %d", err); + pr_err("failed to train PLLE: %d", err); return err; } } @@ -726,7 +726,7 @@ int tegra_plle_enable(void) } while (--timeout);
if (timeout == 0) { - error("timeout waiting for PLLE to lock"); + pr_err("timeout waiting for PLLE to lock"); return -ETIMEDOUT; }
diff --git a/arch/arm/mach-tegra/tegra210/xusb-padctl.c b/arch/arm/mach-tegra/tegra210/xusb-padctl.c index bf85e07..a3e3e37 100644 --- a/arch/arm/mach-tegra/tegra210/xusb-padctl.c +++ b/arch/arm/mach-tegra/tegra210/xusb-padctl.c @@ -125,7 +125,7 @@ static int tegra_xusb_padctl_disable(struct tegra_xusb_padctl *padctl) u32 value;
diff --git a/arch/arm/mach-tegra/tegra30/clock.c b/arch/arm/mach-tegra/tegra30/clock.c index 4fd8b8a..282f34f 100644 --- a/arch/arm/mach-tegra/tegra30/clock.c +++ b/arch/arm/mach-tegra/tegra30/clock.c @@ -696,7 +696,7 @@ static int tegra_plle_train(void) } while (--timeout);
@@ -726,7 +726,7 @@ int tegra_plle_enable(void) if ((value & PLLE_MISC_PLL_READY) == 0) { err = tegra_plle_train(); if (err < 0) { - error("failed to train PLLE: %d", err); + pr_err("failed to train PLLE: %d", err); return err; } } @@ -772,7 +772,7 @@ int tegra_plle_enable(void) } while (--timeout);
diff --git a/arch/arm/mach-tegra/xusb-padctl-common.c b/arch/arm/mach-tegra/xusb-padctl-common.c index abc18c0..c8a468a 100644 --- a/arch/arm/mach-tegra/xusb-padctl-common.c +++ b/arch/arm/mach-tegra/xusb-padctl-common.c @@ -84,7 +84,7 @@ tegra_xusb_padctl_group_parse_dt(struct tegra_xusb_padctl *padctl,
len = ofnode_read_string_count(node, "nvidia,lanes"); if (len < 0) { - error("failed to parse "nvidia,lanes" property"); + pr_err("failed to parse "nvidia,lanes" property"); return -EINVAL; }
@@ -94,7 +94,7 @@ tegra_xusb_padctl_group_parse_dt(struct tegra_xusb_padctl *padctl, ret = ofnode_read_string_index(node, "nvidia,lanes", i, &group->pins[i]); if (ret) { - error("failed to read string from "nvidia,lanes" property"); + pr_err("failed to read string from "nvidia,lanes" property"); return -EINVAL; } } @@ -104,7 +104,7 @@ tegra_xusb_padctl_group_parse_dt(struct tegra_xusb_padctl *padctl, ret = ofnode_read_string_index(node, "nvidia,function", 0, &group->func); if (ret) { - error("failed to parse "nvidia,func" property"); + pr_err("failed to parse "nvidia,func" property"); return -EINVAL; }
@@ -157,14 +157,14 @@ tegra_xusb_padctl_group_apply(struct tegra_xusb_padctl *padctl,
lane = tegra_xusb_padctl_find_lane(padctl, group->pins[i]); if (!lane) { - error("no lane for pin %s", group->pins[i]); + pr_err("no lane for pin %s", group->pins[i]); continue; }
func = tegra_xusb_padctl_lane_find_function(padctl, lane, group->func); if (func < 0) { - error("function %s invalid for lane %s: %d", + pr_err("function %s invalid for lane %s: %d", group->func, lane->name, func); continue; } @@ -206,7 +206,7 @@ tegra_xusb_padctl_config_apply(struct tegra_xusb_padctl *padctl,
err = tegra_xusb_padctl_group_apply(padctl, group); if (err < 0) { - error("failed to apply group %s: %d", + pr_err("failed to apply group %s: %d", group->name, err); continue; } @@ -232,7 +232,7 @@ tegra_xusb_padctl_config_parse_dt(struct tegra_xusb_padctl *padctl,
err = tegra_xusb_padctl_group_parse_dt(padctl, group, subnode); if (err < 0) { - error("failed to parse group %s", group->name); + pr_err("failed to parse group %s", group->name); return err; }
@@ -250,7 +250,7 @@ static int tegra_xusb_padctl_parse_dt(struct tegra_xusb_padctl *padctl,
err = ofnode_read_resource(node, 0, &padctl->regs); if (err < 0) { - error("registers not found"); + pr_err("registers not found"); return err; }
@@ -261,7 +261,7 @@ static int tegra_xusb_padctl_parse_dt(struct tegra_xusb_padctl *padctl, err = tegra_xusb_padctl_config_parse_dt(padctl, config, subnode); if (err < 0) { - error("failed to parse entry %s: %d", + pr_err("failed to parse entry %s: %d", config->name, err); continue; } @@ -289,7 +289,7 @@ int tegra_xusb_process_nodes(ofnode nodes[], unsigned int count,
err = tegra_xusb_padctl_parse_dt(&padctl, nodes[i]); if (err < 0) { - error("failed to parse DT: %d", err); + pr_err("failed to parse DT: %d", err); continue; }
@@ -298,7 +298,7 @@ int tegra_xusb_process_nodes(ofnode nodes[], unsigned int count,
err = tegra_xusb_padctl_config_apply(&padctl, &padctl.config); if (err < 0) { - error("failed to apply pinmux: %d", err); + pr_err("failed to apply pinmux: %d", err); continue; }
diff --git a/arch/x86/cpu/tangier/sdram.c b/arch/x86/cpu/tangier/sdram.c index 5743077..eae8d78 100644 --- a/arch/x86/cpu/tangier/sdram.c +++ b/arch/x86/cpu/tangier/sdram.c @@ -39,7 +39,7 @@ static int sfi_table_check(struct sfi_table_header *sbh) chksum += *pos++;
if (chksum) - error("sfi: Invalid checksum\n"); + pr_err("sfi: Invalid checksum\n");
/* Checksum is OK if zero */ return chksum ? -EILSEQ : 0; @@ -76,7 +76,7 @@ static struct sfi_table_simple *sfi_search_mmap(void) /* Find SYST table */ sb = sfi_get_table_by_sig(SFI_BASE_ADDR, SFI_SIG_SYST); if (!sb) { - error("sfi: failed to locate SYST table\n"); + pr_err("sfi: failed to locate SYST table\n"); return NULL; }
@@ -90,7 +90,7 @@ static struct sfi_table_simple *sfi_search_mmap(void) return (struct sfi_table_simple *)sbh; }
- error("sfi: failed to locate SFI MMAP table\n"); + pr_err("sfi: failed to locate SFI MMAP table\n"); return NULL; }
diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index bd08a2e..c20da29 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -49,7 +49,7 @@ static int as3722_sd_enable(struct udevice *pmic, unsigned int sd)
err = pmic_clrsetbits(pmic, AS3722_SD_CONTROL, 0, 1 << sd); if (err) { - error("failed to update SD control register: %d", err); + pr_err("failed to update SD control register: %d", err); return err; }
@@ -70,13 +70,13 @@ int tegra_pcie_board_init(void)
ret = as3722_sd_enable(dev, 4); if (ret < 0) { - error("failed to enable SD4: %d\n", ret); + pr_err("failed to enable SD4: %d\n", ret); return ret; }
ret = as3722_sd_set_voltage(dev, 4, 0x24); if (ret < 0) { - error("failed to set SD4 voltage: %d\n", ret); + pr_err("failed to set SD4 voltage: %d\n", ret); return ret; }
diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index ae2a6e6..0d17f30 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -161,7 +161,7 @@ int board_usb_init(int index, enum usb_init_type init) samsung_get_base_usb3_phy();
if (!phy) { - error("usb3 phy not supported"); + pr_err("usb3 phy not supported"); return -ENODEV; }
diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 4157349..eba25b7 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -457,7 +457,7 @@ void draw_logo(void)
addr = panel_info.logo_addr; if (!addr) { - error("There is no logo data."); + pr_err("There is no logo data."); return; }
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index d0247ac..debc4c5 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -102,7 +102,7 @@ int board_mmc_init(bd_t *bis)
ret = s5p_mmc_init(0, 4); if (ret) - error("MMC: Failed to init MMC:0.\n"); + pr_err("MMC: Failed to init MMC:0.\n");
/* * SD card (T_FLASH) detect and init @@ -127,7 +127,7 @@ int board_mmc_init(bd_t *bis)
ret_sd = s5p_mmc_init(2, 4); if (ret_sd) - error("MMC: Failed to init SD card (MMC:2).\n"); + pr_err("MMC: Failed to init SD card (MMC:2).\n"); }
return ret & ret_sd; diff --git a/board/samsung/odroid/odroid.c b/board/samsung/odroid/odroid.c index e40a2f6..0df96c1 100644 --- a/board/samsung/odroid/odroid.c +++ b/board/samsung/odroid/odroid.c @@ -429,7 +429,7 @@ int exynos_power_init(void) };
if (regulator_list_autoset(mmc_regulators, NULL, true)) - error("Unable to init all mmc regulators"); + pr_err("Unable to init all mmc regulators");
return 0; } @@ -442,7 +442,7 @@ static int s5pc210_phy_control(int on)
ret = regulator_get_by_platname("VDD_UOTG_3.0V", &dev); if (ret) { - error("Regulator get error: %d", ret); + pr_err("Regulator get error: %d", ret); return ret; }
@@ -487,25 +487,25 @@ int board_usb_init(int index, enum usb_init_type init)
ret = regulator_get_by_platname("VCC_P3V3_2.85V", &dev); if (ret) { - error("Regulator get error: %d", ret); + pr_err("Regulator get error: %d", ret); return ret; }
ret = regulator_set_enable(dev, true); if (ret) { - error("Regulator %s enable setting error: %d", dev->name, ret); + pr_err("Regulator %s enable setting error: %d", dev->name, ret); return ret; }
ret = regulator_set_value(dev, 750000); if (ret) { - error("Regulator %s value setting error: %d", dev->name, ret); + pr_err("Regulator %s value setting error: %d", dev->name, ret); return ret; }
ret = regulator_set_value(dev, 3300000); if (ret) { - error("Regulator %s value setting error: %d", dev->name, ret); + pr_err("Regulator %s value setting error: %d", dev->name, ret); return ret; } #endif diff --git a/cmd/fastboot.c b/cmd/fastboot.c index 488822a..8adcca5 100644 --- a/cmd/fastboot.c +++ b/cmd/fastboot.c @@ -27,7 +27,7 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[])
ret = board_usb_init(controller_index, USB_INIT_DEVICE); if (ret) { - error("USB init failed: %d", ret); + pr_err("USB init failed: %d", ret); return CMD_RET_FAILURE; }
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 4033d90..228e904 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -927,7 +927,7 @@ NXTARG: ; H_MATCH_KEY | H_MATCH_IDENT, &ptr, size, argc, argv); if (len < 0) { - error("Cannot export environment: errno = %d\n", errno); + pr_err("Cannot export environment: errno = %d\n", errno); return 1; } sprintf(buf, "%zX", (size_t)len); @@ -947,7 +947,7 @@ NXTARG: ; H_MATCH_KEY | H_MATCH_IDENT, &res, ENV_SIZE, argc, argv); if (len < 0) { - error("Cannot export environment: errno = %d\n", errno); + pr_err("Cannot export environment: errno = %d\n", errno); return 1; }
@@ -1082,7 +1082,7 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag,
if (himport_r(&env_htab, ptr, size, sep, del ? 0 : H_NOCLEAR, crlf_is_lf, 0, NULL) == 0) { - error("Environment import failed: errno = %d\n", errno); + pr_err("Environment import failed: errno = %d\n", errno); return 1; } gd->flags |= GD_FLG_ENV_READY; diff --git a/cmd/regulator.c b/cmd/regulator.c index 2ef5bc9..b605255 100644 --- a/cmd/regulator.c +++ b/cmd/regulator.c @@ -71,7 +71,7 @@ static int curr_dev_and_platdata(struct udevice **devp,
*uc_pdata = dev_get_uclass_platdata(*devp); if (!*uc_pdata) { - error("Regulator: %s - missing platform data!", currdev->name); + pr_err("Regulator: %s - missing platform data!", currdev->name); return CMD_RET_FAILURE; }
diff --git a/cmd/thordown.c b/cmd/thordown.c index 436b7f5..1bb5fc2 100644 --- a/cmd/thordown.c +++ b/cmd/thordown.c @@ -33,7 +33,7 @@ int do_thor_down(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) int controller_index = simple_strtoul(usb_controller, NULL, 0); ret = board_usb_init(controller_index, USB_INIT_DEVICE); if (ret) { - error("USB init failed: %d", ret); + pr_err("USB init failed: %d", ret); ret = CMD_RET_FAILURE; goto exit; } @@ -42,14 +42,14 @@ int do_thor_down(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
ret = thor_init(); if (ret) { - error("THOR DOWNLOAD failed: %d", ret); + pr_err("THOR DOWNLOAD failed: %d", ret); ret = CMD_RET_FAILURE; goto exit; }
ret = thor_handle(); if (ret) { - error("THOR failed: %d", ret); + pr_err("THOR failed: %d", ret); ret = CMD_RET_FAILURE; goto exit; } diff --git a/cmd/tpm_test.c b/cmd/tpm_test.c index 3306405..37ad2ff 100644 --- a/cmd/tpm_test.c +++ b/cmd/tpm_test.c @@ -303,12 +303,12 @@ static int test_readonly(void) index_0 += 1; if (tpm_nv_write_value(INDEX0, (uint8_t *)&index_0, sizeof(index_0) != TPM_SUCCESS)) { - error("\tcould not write index 0\n"); + pr_err("\tcould not write index 0\n"); } tpm_nv_write_value_lock(INDEX0); if (tpm_nv_write_value(INDEX0, (uint8_t *)&index_0, sizeof(index_0)) == TPM_SUCCESS) - error("\tindex 0 is not locked\n"); + pr_err("\tindex 0 is not locked\n");
printf("\tdone\n"); return 0; @@ -471,7 +471,7 @@ static int test_write_limit(void) case TPM_MAXNVWRITES: assert(i >= TPM_MAX_NV_WRITES_NOOWNER); default: - error("\tunexpected error code %d (0x%x)\n", + pr_err("\tunexpected error code %d (0x%x)\n", result, result); } } diff --git a/cmd/usb_gadget_sdp.c b/cmd/usb_gadget_sdp.c index b1d8b28..ae4d73c 100644 --- a/cmd/usb_gadget_sdp.c +++ b/cmd/usb_gadget_sdp.c @@ -28,13 +28,13 @@ static int do_sdp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
ret = sdp_init(controller_index); if (ret) { - error("SDP init failed: %d", ret); + pr_err("SDP init failed: %d", ret); goto exit; }
/* This command typically does not return but jumps to an image */ sdp_handle(controller_index); - error("SDP ended"); + pr_err("SDP ended");
exit: g_dnl_unregister(); diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index 3353f95..cfeecb7 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -162,21 +162,21 @@ static int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, controller_index = (unsigned int)(simple_strtoul( usb_controller, NULL, 0)); if (board_usb_init(controller_index, USB_INIT_DEVICE)) { - error("Couldn't init USB controller."); + pr_err("Couldn't init USB controller."); rc = CMD_RET_FAILURE; goto cleanup_ums_init; }
rc = fsg_init(ums, ums_count); if (rc) { - error("fsg_init failed"); + pr_err("fsg_init failed"); rc = CMD_RET_FAILURE; goto cleanup_board; }
rc = g_dnl_register("usb_dnl_ums"); if (rc) { - error("g_dnl_register failed"); + pr_err("g_dnl_register failed"); rc = CMD_RET_FAILURE; goto cleanup_board; } diff --git a/common/dfu.c b/common/dfu.c index 546a1ab..07dff31 100644 --- a/common/dfu.c +++ b/common/dfu.c @@ -26,13 +26,13 @@ int run_usb_dnl_gadget(int usbctrl_index, char *usb_dnl_gadget)
ret = board_usb_init(usbctrl_index, USB_INIT_DEVICE); if (ret) { - error("board usb init failed\n"); + pr_err("board usb init failed\n"); return CMD_RET_FAILURE; } g_dnl_clear_detach(); ret = g_dnl_register(usb_dnl_gadget); if (ret) { - error("g_dnl_register failed"); + pr_err("g_dnl_register failed"); return CMD_RET_FAILURE; }
@@ -75,7 +75,7 @@ int run_usb_dnl_gadget(int usbctrl_index, char *usb_dnl_gadget) ret = dfu_flush(dfu_get_defer_flush(), NULL, 0, 0); dfu_set_defer_flush(NULL); if (ret) { - error("Deferred dfu_flush() failed!"); + pr_err("Deferred dfu_flush() failed!"); goto exit; } } diff --git a/common/fb_mmc.c b/common/fb_mmc.c index 26d60b8..cf5b77c 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -84,7 +84,7 @@ static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info, blkcnt = lldiv(blkcnt, info->blksz);
if (blkcnt > info->size) { - error("too large for partition: '%s'\n", part_name); + pr_err("too large for partition: '%s'\n", part_name); fastboot_fail("too large for partition"); return; } @@ -93,7 +93,7 @@ static void write_raw_image(struct blk_desc *dev_desc, disk_partition_t *info,
blks = blk_dwrite(dev_desc, info->start, blkcnt, buffer); if (blks != blkcnt) { - error("failed writing to device %d\n", dev_desc->devnum); + pr_err("failed writing to device %d\n", dev_desc->devnum); fastboot_fail("failed writing to device"); return; } @@ -125,7 +125,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, sector_size = info->blksz; hdr_sectors = DIV_ROUND_UP(sizeof(struct andr_img_hdr), sector_size); if (hdr_sectors == 0) { - error("invalid number of boot sectors: 0"); + pr_err("invalid number of boot sectors: 0"); fastboot_fail("invalid number of boot sectors: 0"); return 0; } @@ -133,7 +133,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, /* Read the boot image header */ res = blk_dread(dev_desc, info->start, hdr_sectors, (void *)hdr); if (res != hdr_sectors) { - error("cannot read header from boot partition"); + pr_err("cannot read header from boot partition"); fastboot_fail("cannot read header from boot partition"); return 0; } @@ -141,7 +141,7 @@ static lbaint_t fb_mmc_get_boot_header(struct blk_desc *dev_desc, /* Check boot header magic string */ res = android_image_check_header(hdr); if (res != 0) { - error("bad boot image magic"); + pr_err("bad boot image magic"); fastboot_fail("boot partition not initialized"); return 0; } @@ -179,7 +179,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, /* Get boot partition info */ res = part_get_info_by_name(dev_desc, BOOT_PARTITION_NAME, &info); if (res < 0) { - error("cannot find boot partition"); + pr_err("cannot find boot partition"); fastboot_fail("cannot find boot partition"); return -1; } @@ -191,14 +191,14 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, /* Read boot image header */ hdr_sectors = fb_mmc_get_boot_header(dev_desc, &info, hdr); if (hdr_sectors == 0) { - error("unable to read boot image header"); + pr_err("unable to read boot image header"); fastboot_fail("unable to read boot image header"); return -1; }
/* Check if boot image has second stage in it (we don't support it) */ if (hdr->second_size > 0) { - error("moving second stage is not supported yet"); + pr_err("moving second stage is not supported yet"); fastboot_fail("moving second stage is not supported yet"); return -1; } @@ -216,7 +216,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = blk_dread(dev_desc, ramdisk_sector_start, ramdisk_sectors, ramdisk_buffer); if (res != ramdisk_sectors) { - error("cannot read ramdisk from boot partition"); + pr_err("cannot read ramdisk from boot partition"); fastboot_fail("cannot read ramdisk from boot partition"); return -1; } @@ -225,7 +225,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, hdr->kernel_size = download_bytes; res = blk_dwrite(dev_desc, info.start, hdr_sectors, (void *)hdr); if (res == 0) { - error("cannot writeback boot image header"); + pr_err("cannot writeback boot image header"); fastboot_fail("cannot write back boot image header"); return -1; } @@ -237,7 +237,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = blk_dwrite(dev_desc, kernel_sector_start, kernel_sectors, download_buffer); if (res == 0) { - error("cannot write new kernel"); + pr_err("cannot write new kernel"); fastboot_fail("cannot write new kernel"); return -1; } @@ -249,7 +249,7 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, res = blk_dwrite(dev_desc, ramdisk_sector_start, ramdisk_sectors, ramdisk_buffer); if (res == 0) { - error("cannot write back original ramdisk"); + pr_err("cannot write back original ramdisk"); fastboot_fail("cannot write back original ramdisk"); return -1; } @@ -268,7 +268,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer,
dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { - error("invalid mmc device\n"); + pr_err("invalid mmc device\n"); fastboot_fail("invalid mmc device"); return; } @@ -322,7 +322,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, #endif
if (part_get_info_by_name_or_alias(dev_desc, cmd, &info) < 0) { - error("cannot find partition: '%s'\n", cmd); + pr_err("cannot find partition: '%s'\n", cmd); fastboot_fail("cannot find partition"); return; } @@ -360,21 +360,21 @@ void fb_mmc_erase(const char *cmd) struct mmc *mmc = find_mmc_device(CONFIG_FASTBOOT_FLASH_MMC_DEV);
if (mmc == NULL) { - error("invalid mmc device"); + pr_err("invalid mmc device"); fastboot_fail("invalid mmc device"); return; }
dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { - error("invalid mmc device"); + pr_err("invalid mmc device"); fastboot_fail("invalid mmc device"); return; }
ret = part_get_info_by_name_or_alias(dev_desc, cmd, &info); if (ret < 0) { - error("cannot find partition: '%s'", cmd); + pr_err("cannot find partition: '%s'", cmd); fastboot_fail("cannot find partition"); return; } @@ -393,7 +393,7 @@ void fb_mmc_erase(const char *cmd)
blks = blk_derase(dev_desc, blks_start, blks_size); if (blks != blks_size) { - error("failed erasing from device %d", dev_desc->devnum); + pr_err("failed erasing from device %d", dev_desc->devnum); fastboot_fail("failed erasing from device"); return; } diff --git a/common/fb_nand.c b/common/fb_nand.c index 3d027d4..aa28046 100644 --- a/common/fb_nand.c +++ b/common/fb_nand.c @@ -40,20 +40,20 @@ static int fb_nand_lookup(const char *partname,
ret = mtdparts_init(); if (ret) { - error("Cannot initialize MTD partitions\n"); + pr_err("Cannot initialize MTD partitions\n"); fastboot_fail("cannot init mtdparts"); return ret; }
ret = find_dev_and_part(partname, &dev, &pnum, part); if (ret) { - error("cannot find partition: '%s'", partname); + pr_err("cannot find partition: '%s'", partname); fastboot_fail("cannot find partition"); return ret; }
if (dev->id->type != MTD_DEV_TYPE_NAND) { - error("partition '%s' is not stored on a NAND device", + pr_err("partition '%s' is not stored on a NAND device", partname); fastboot_fail("not a NAND device"); return -EINVAL; @@ -154,7 +154,7 @@ void fb_nand_flash_write(const char *cmd, void *download_buffer,
ret = fb_nand_lookup(cmd, &mtd, &part); if (ret) { - error("invalid NAND device"); + pr_err("invalid NAND device"); fastboot_fail("invalid NAND device"); return; } @@ -209,7 +209,7 @@ void fb_nand_erase(const char *cmd)
ret = fb_nand_lookup(cmd, &mtd, &part); if (ret) { - error("invalid NAND device"); + pr_err("invalid NAND device"); fastboot_fail("invalid NAND device"); return; } @@ -220,7 +220,7 @@ void fb_nand_erase(const char *cmd)
ret = _fb_nand_erase(mtd, part); if (ret) { - error("failed erasing from device %s", mtd->name); + pr_err("failed erasing from device %s", mtd->name); fastboot_fail("failed erasing from device"); return; } diff --git a/common/spl/spl_dfu.c b/common/spl/spl_dfu.c index 2c97473..05bb210 100644 --- a/common/spl/spl_dfu.c +++ b/common/spl/spl_dfu.c @@ -42,13 +42,13 @@ int spl_dfu_cmd(int usbctrl, char *dfu_alt_info, char *interface, char *devstr) set_default_env(0); str_env = env_get(dfu_alt_info); if (!str_env) { - error(""dfu_alt_info" env variable not defined!\n"); + pr_err(""dfu_alt_info" env variable not defined!\n"); return -EINVAL; }
ret = env_set("dfu_alt_info", str_env); if (ret) { - error("unable to set env variable "dfu_alt_info"!\n"); + pr_err("unable to set env variable "dfu_alt_info"!\n"); return -EINVAL; }
diff --git a/common/spl/spl_sdp.c b/common/spl/spl_sdp.c index 350bcdb..333d518 100644 --- a/common/spl/spl_sdp.c +++ b/common/spl/spl_sdp.c @@ -24,13 +24,13 @@ static int spl_sdp_load_image(struct spl_image_info *spl_image,
ret = sdp_init(controller_index); if (ret) { - error("SDP init failed: %d", ret); + pr_err("SDP init failed: %d", ret); return -ENODEV; }
return -EINVAL; } diff --git a/common/update.c b/common/update.c index 974f465..33bffaa 100644 --- a/common/update.c +++ b/common/update.c @@ -242,7 +242,7 @@ int update_tftp(ulong addr, char *interface, char *devstring) } else if (interface && devstring) { update_tftp_dfu = true; } else { - error("Interface: %s and devstring: %s not supported!\n", + pr_err("Interface: %s and devstring: %s not supported!\n", interface, devstring); return -EINVAL; } diff --git a/disk/part_efi.c b/disk/part_efi.c index 2973d52..e05a138 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -360,7 +360,7 @@ static int set_protective_mbr(struct blk_desc *dev_desc)
/* Read MBR to backup boot code if it exists */ if (blk_dread(dev_desc, 0, 1, p_mbr) != 1) { - error("** Can't read from device %d **\n", dev_desc->devnum); + pr_err("** Can't read from device %d **\n", dev_desc->devnum); return -1; }
@@ -716,7 +716,7 @@ int gpt_verify_partitions(struct blk_desc *dev_desc,
for (i = 0; i < parts; i++) { if (i == gpt_head->num_partition_entries) { - error("More partitions than allowed!\n"); + pr_err("More partitions than allowed!\n"); return -1; }
@@ -729,7 +729,7 @@ int gpt_verify_partitions(struct blk_desc *dev_desc,
if (strncmp(efi_str, (char *)partitions[i].name, sizeof(partitions->name))) { - error("Partition name: %s does not match %s!\n", + pr_err("Partition name: %s does not match %s!\n", efi_str, (char *)partitions[i].name); return -1; } @@ -746,7 +746,7 @@ int gpt_verify_partitions(struct blk_desc *dev_desc, if ((i == parts - 1) && (partitions[i].size == 0)) continue;
- error("Partition %s size: %llu does not match %llu!\n", + pr_err("Partition %s size: %llu does not match %llu!\n", efi_str, (unsigned long long)gpt_part_size, (unsigned long long)partitions[i].size); return -1; @@ -767,7 +767,7 @@ int gpt_verify_partitions(struct blk_desc *dev_desc, (unsigned long long)partitions[i].start);
if (le64_to_cpu(gpt_e[i].starting_lba) != partitions[i].start) { - error("Partition %s start: %llu does not match %llu!\n", + pr_err("Partition %s start: %llu does not match %llu!\n", efi_str, le64_to_cpu(gpt_e[i].starting_lba), (unsigned long long)partitions[i].start); return -1; diff --git a/drivers/adc/adc-uclass.c b/drivers/adc/adc-uclass.c index a5ef722..a4c20f4 100644 --- a/drivers/adc/adc-uclass.c +++ b/drivers/adc/adc-uclass.c @@ -64,7 +64,7 @@ static int adc_supply_enable(struct udevice *dev) }
if (ret) - error("%s: can't enable %s-supply!", dev->name, supply_type); + pr_err("%s: can't enable %s-supply!", dev->name, supply_type);
return ret; } @@ -389,12 +389,12 @@ static int adc_pre_probe(struct udevice *dev) /* Set ADC VDD platdata: polarity, uV, regulator (phandle). */ ret = adc_vdd_platdata_set(dev); if (ret) - error("%s: Can't update Vdd. Error: %d", dev->name, ret); + pr_err("%s: Can't update Vdd. Error: %d", dev->name, ret);
/* Set ADC VSS platdata: polarity, uV, regulator (phandle). */ ret = adc_vss_platdata_set(dev); if (ret) - error("%s: Can't update Vss. Error: %d", dev->name, ret); + pr_err("%s: Can't update Vss. Error: %d", dev->name, ret);
return 0; } diff --git a/drivers/adc/exynos-adc.c b/drivers/adc/exynos-adc.c index 324d72f..3bb065d 100644 --- a/drivers/adc/exynos-adc.c +++ b/drivers/adc/exynos-adc.c @@ -22,7 +22,7 @@ int exynos_adc_channel_data(struct udevice *dev, int channel, struct exynos_adc_v2 *regs = priv->regs;
if (channel != priv->active_channel) { - error("Requested channel is not active!"); + pr_err("Requested channel is not active!"); return -EINVAL; }
@@ -80,7 +80,7 @@ int exynos_adc_probe(struct udevice *dev)
/* Check HW version */ if (readl(®s->version) != ADC_V2_VERSION) { - error("This driver supports only ADC v2!"); + pr_err("This driver supports only ADC v2!"); return -ENXIO; }
@@ -109,7 +109,7 @@ int exynos_adc_ofdata_to_platdata(struct udevice *dev)
priv->regs = (struct exynos_adc_v2 *)devfdt_get_addr(dev); if (priv->regs == (struct exynos_adc_v2 *)FDT_ADDR_T_NONE) { - error("Dev: %s - can't get address!", dev->name); + pr_err("Dev: %s - can't get address!", dev->name); return -ENODATA; }
diff --git a/drivers/adc/sandbox.c b/drivers/adc/sandbox.c index 3718922..80e8e37 100644 --- a/drivers/adc/sandbox.c +++ b/drivers/adc/sandbox.c @@ -61,7 +61,7 @@ int sandbox_adc_channel_data(struct udevice *dev, int channel, /* For single-channel conversion mode, check if channel was selected */ if ((priv->conversion_mode == SANDBOX_ADC_MODE_SINGLE_CHANNEL) && !(priv->active_channel_mask & (1 << channel))) { - error("Request for an inactive channel!"); + pr_err("Request for an inactive channel!"); return -EINVAL; }
@@ -82,12 +82,12 @@ int sandbox_adc_channels_data(struct udevice *dev, unsigned int channel_mask,
/* Return error for single-channel conversion mode */ if (priv->conversion_mode == SANDBOX_ADC_MODE_SINGLE_CHANNEL) { - error("ADC in single-channel mode!"); + pr_err("ADC in single-channel mode!"); return -EPERM; } /* Check channel selection */ if (!(priv->active_channel_mask & channel_mask)) { - error("Request for an inactive channel!"); + pr_err("Request for an inactive channel!"); return -EINVAL; } /* The conversion must be started before reading the data */ diff --git a/drivers/ata/dwc_ahci.c b/drivers/ata/dwc_ahci.c index f614798..b16304b 100644 --- a/drivers/ata/dwc_ahci.c +++ b/drivers/ata/dwc_ahci.c @@ -58,19 +58,19 @@ static int dwc_ahci_probe(struct udevice *dev)
ret = generic_phy_get_by_name(dev, "sata-phy", &phy); if (ret) { - error("can't get the phy from DT\n"); + pr_err("can't get the phy from DT\n"); return ret; }
ret = generic_phy_init(&phy); if (ret) { - error("unable to initialize the sata phy\n"); + pr_err("unable to initialize the sata phy\n"); return ret; }
ret = generic_phy_power_on(&phy); if (ret) { - error("unable to power on the sata phy\n"); + pr_err("unable to power on the sata phy\n"); return ret; }
diff --git a/drivers/clk/clk_boston.c b/drivers/clk/clk_boston.c index 78f1b75..5c05e3d 100644 --- a/drivers/clk/clk_boston.c +++ b/drivers/clk/clk_boston.c @@ -67,13 +67,13 @@ static int clk_boston_ofdata_to_platdata(struct udevice *dev) err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, "regmap", &syscon); if (err) { - error("unable to find syscon device\n"); + pr_err("unable to find syscon device\n"); return err; }
state->regmap = syscon_get_regmap(syscon); if (!state->regmap) { - error("unable to find regmap\n"); + pr_err("unable to find regmap\n"); return -ENODEV; }
diff --git a/drivers/clk/clk_stm32f7.c b/drivers/clk/clk_stm32f7.c index 255a583..ad3cafc 100644 --- a/drivers/clk/clk_stm32f7.c +++ b/drivers/clk/clk_stm32f7.c @@ -224,7 +224,7 @@ static unsigned long stm32_clk_get_rate(struct clk *clk) return sysclk >>= shift; break; default: - error("clock index %ld out of range\n", clk->id); + pr_err("clock index %ld out of range\n", clk->id); return -EINVAL; break; } diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 2be1f57..d46a73a 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -301,7 +301,7 @@ static ulong rk3368_ddr_set_clk(struct rk3368_cru *cru, ulong set_rate) dpll_cfg = &dpll_1600; break; default: - error("Unsupported SDRAM frequency!,%ld\n", set_rate); + pr_err("Unsupported SDRAM frequency!,%ld\n", set_rate); } rkclk_set_pll(cru, DPLL, dpll_cfg);
@@ -359,7 +359,7 @@ static ulong rk3368_spi_get_clk(struct rk3368_cru *cru, ulong clk_id) break;
default: - error("%s: SPI clk-id %ld not supported\n", __func__, clk_id); + pr_err("%s: SPI clk-id %ld not supported\n", __func__, clk_id); return -EINVAL; }
@@ -384,7 +384,7 @@ static ulong rk3368_spi_set_clk(struct rk3368_cru *cru, ulong clk_id, uint hz) break;
@@ -498,7 +498,7 @@ static int rk3368_clk_bind(struct udevice *dev) /* The reset driver does not have a device node, so bind it here */ ret = device_bind_driver(gd->dm_root, "rk3368_sysreset", "reset", &dev); if (ret) - error("bind RK3368 reset driver failed: ret=%d\n", ret); + pr_err("bind RK3368 reset driver failed: ret=%d\n", ret);
return ret; } diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 3edafea..c6859f3 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -661,7 +661,7 @@ static ulong rk3399_spi_get_clk(struct rk3399_cru *cru, ulong clk_id) break;
@@ -685,7 +685,7 @@ static ulong rk3399_spi_set_clk(struct rk3399_cru *cru, ulong clk_id, uint hz) break;
@@ -854,7 +854,7 @@ static ulong rk3399_ddr_set_clk(struct rk3399_cru *cru, {.refdiv = 1, .fbdiv = 116, .postdiv1 = 3, .postdiv2 = 1}; break; default: - error("Unsupported SDRAM frequency!,%ld\n", set_rate); + pr_err("Unsupported SDRAM frequency!,%ld\n", set_rate); } rkclk_set_pll(&cru->dpll_con[0], &dpll_cfg);
diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index cf966bb..9f0ae6c 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -196,7 +196,7 @@ static int rv1108_clk_bind(struct udevice *dev) /* The reset driver does not have a device node, so bind it here */ ret = device_bind_driver(gd->dm_root, "rv1108_sysreset", "reset", &dev); if (ret) - error("No Rv1108 reset driver: ret=%d\n", ret); + pr_err("No Rv1108 reset driver: ret=%d\n", ret);
return 0; } diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index ff732ac..2c22b62 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -64,14 +64,14 @@ int dfu_init_env_entities(char *interface, char *devstr) #endif str_env = env_get("dfu_alt_info"); if (!str_env) { - error(""dfu_alt_info" env variable not defined!\n"); + pr_err(""dfu_alt_info" env variable not defined!\n"); return -EINVAL; }
env_bkp = strdup(str_env); ret = dfu_config_entities(env_bkp, interface, devstr); if (ret) { - error("DFU entities configuration failed!\n"); + pr_err("DFU entities configuration failed!\n"); return ret; }
@@ -132,7 +132,7 @@ static char *dfu_get_hash_algo(void) return s; }
- error("DFU hash method: %s not supported!\n", s); + pr_err("DFU hash method: %s not supported!\n", s); return NULL; }
@@ -273,7 +273,7 @@ int dfu_write(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num)
/* we should be in buffer now (if not then size too large) */ if ((dfu->i_buf + size) > dfu->i_buf_end) { - error("Buffer overflow! (0x%p + 0x%x > 0x%p)\n", dfu->i_buf, + pr_err("Buffer overflow! (0x%p + 0x%x > 0x%p)\n", dfu->i_buf, size, dfu->i_buf_end); dfu_transaction_cleanup(dfu); return -1; @@ -451,7 +451,7 @@ int dfu_config_entities(char *env, char *interface, char *devstr) if (s) { ret = hash_lookup_algo(s, &dfu_hash_algo); if (ret) - error("Hash algorithm %s not supported\n", s); + pr_err("Hash algorithm %s not supported\n", s); }
dfu = calloc(sizeof(*dfu), dfu_alt_num); @@ -576,7 +576,7 @@ int dfu_write_from_mem_addr(struct dfu_entity *dfu, void *buf, int size) dp, left, write); ret = dfu_write(dfu, dp, write, i); if (ret) { - error("DFU write failed\n"); + pr_err("DFU write failed\n"); return ret; }
@@ -586,7 +586,7 @@ int dfu_write_from_mem_addr(struct dfu_entity *dfu, void *buf, int size)
ret = dfu_flush(dfu, NULL, 0, i); if (ret) - error("DFU flush failed!"); + pr_err("DFU flush failed!");
return ret; } diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 39e10b1..47948d3 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -29,7 +29,7 @@ static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu,
mmc = find_mmc_device(dfu->data.mmc.dev_num); if (!mmc) { - error("Device MMC %d - not found!", dfu->data.mmc.dev_num); + pr_err("Device MMC %d - not found!", dfu->data.mmc.dev_num); return -ENODEV; }
@@ -69,11 +69,11 @@ static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, buf); break; default: - error("Operation not supported\n"); + pr_err("Operation not supported\n"); }
if (n != blk_count) { - error("MMC operation failed"); + pr_err("MMC operation failed"); if (dfu->data.mmc.hw_partition >= 0) blk_select_hwpart_devnum(IF_TYPE_MMC, dfu->data.mmc.dev_num, @@ -312,7 +312,7 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) for (; parg < argv + sizeof(argv) / sizeof(*argv); ++parg) { *parg = strsep(&s, " "); if (*parg == NULL) { - error("Invalid number of arguments.\n"); + pr_err("Invalid number of arguments.\n"); return -ENODEV; } } @@ -327,13 +327,13 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s)
mmc = find_mmc_device(dfu->data.mmc.dev_num); if (mmc == NULL) { - error("Couldn't find MMC device no. %d.\n", + pr_err("Couldn't find MMC device no. %d.\n", dfu->data.mmc.dev_num); return -ENODEV; }
if (mmc_init(mmc)) { - error("Couldn't init MMC device.\n"); + pr_err("Couldn't init MMC device.\n"); return -ENODEV; }
@@ -360,7 +360,7 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) int mmcpart = third_arg;
if (part_get_info(blk_dev, mmcpart, &partinfo) != 0) { - error("Couldn't find part #%d on mmc device #%d\n", + pr_err("Couldn't find part #%d on mmc device #%d\n", mmcpart, mmcdev); return -ENODEV; } @@ -374,7 +374,7 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) } else if (!strcmp(entity_type, "ext4")) { dfu->layout = DFU_FS_EXT4; } else { - error("Memory layout (%s) not supported!\n", entity_type); + pr_err("Memory layout (%s) not supported!\n", entity_type); return -ENODEV; }
@@ -397,7 +397,7 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) dfu_file_buf = memalign(CONFIG_SYS_CACHELINE_SIZE, CONFIG_SYS_DFU_MAX_FILE_SIZE); if (!dfu_file_buf) { - error("Could not memalign 0x%x bytes", + pr_err("Could not memalign 0x%x bytes", CONFIG_SYS_DFU_MAX_FILE_SIZE); return -ENOMEM; } diff --git a/drivers/dfu/dfu_ram.c b/drivers/dfu/dfu_ram.c index 6e3f531..2b5e05a 100644 --- a/drivers/dfu/dfu_ram.c +++ b/drivers/dfu/dfu_ram.c @@ -18,12 +18,12 @@ static int dfu_transfer_medium_ram(enum dfu_op op, struct dfu_entity *dfu, u64 offset, void *buf, long *len) { if (dfu->layout != DFU_RAM_ADDR) { - error("unsupported layout: %s\n", dfu_get_layout(dfu->layout)); + pr_err("unsupported layout: %s\n", dfu_get_layout(dfu->layout)); return -EINVAL; }
if (offset > dfu->data.ram.size) { - error("request exceeds allowed area\n"); + pr_err("request exceeds allowed area\n"); return -EINVAL; }
@@ -62,14 +62,14 @@ int dfu_fill_entity_ram(struct dfu_entity *dfu, char *devstr, char *s) for (; parg < argv + sizeof(argv) / sizeof(*argv); ++parg) { *parg = strsep(&s, " "); if (*parg == NULL) { - error("Invalid number of arguments.\n"); + pr_err("Invalid number of arguments.\n"); return -ENODEV; } }
dfu->dev_type = DFU_DEV_RAM; if (strcmp(argv[0], "ram")) { - error("unsupported device: %s\n", argv[0]); + pr_err("unsupported device: %s\n", argv[0]); return -ENODEV; }
diff --git a/drivers/dfu/dfu_tftp.c b/drivers/dfu/dfu_tftp.c index cd71708..62bf797 100644 --- a/drivers/dfu/dfu_tftp.c +++ b/drivers/dfu/dfu_tftp.c @@ -43,7 +43,7 @@ int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len, alt_setting_num = dfu_get_alt(sb); free(sb); if (alt_setting_num < 0) { - error("Alt setting [%d] to write not found!", + pr_err("Alt setting [%d] to write not found!", alt_setting_num); ret = -ENODEV; goto done; @@ -51,7 +51,7 @@ int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len,
dfu = dfu_get_entity(alt_setting_num); if (!dfu) { - error("DFU entity for alt: %d not found!", alt_setting_num); + pr_err("DFU entity for alt: %d not found!", alt_setting_num); ret = -ENODEV; goto done; } diff --git a/drivers/dma/dma-uclass.c b/drivers/dma/dma-uclass.c index ea21fd9..3d0ce22 100644 --- a/drivers/dma/dma-uclass.c +++ b/drivers/dma/dma-uclass.c @@ -33,7 +33,7 @@ int dma_get_device(u32 transfer_type, struct udevice **devp) }
if (!dev) { - error("No DMA device found that supports %x type\n", + pr_err("No DMA device found that supports %x type\n", transfer_type); return -EPROTONOSUPPORT; } diff --git a/drivers/dma/lpc32xx_dma.c b/drivers/dma/lpc32xx_dma.c index 955adfe..63a8a2f 100644 --- a/drivers/dma/lpc32xx_dma.c +++ b/drivers/dma/lpc32xx_dma.c @@ -96,7 +96,7 @@ int lpc32xx_dma_start_xfer(unsigned int channel, { if (unlikely(((BIT_MASK(channel) & alloc_ch) == 0) || (channel >= DMA_NO_OF_CHANNELS))) { - error("Request for xfer on unallocated channel %d", channel); + pr_err("Request for xfer on unallocated channel %d", channel); return -1; } writel(BIT_MASK(channel), &dma->int_tc_clear); @@ -117,7 +117,7 @@ int lpc32xx_dma_wait_status(unsigned int channel)
/* Check if given channel is valid */ if (unlikely(channel >= DMA_NO_OF_CHANNELS)) { - error("Request for status on unallocated channel %d", channel); + pr_err("Request for status on unallocated channel %d", channel); return -1; }
@@ -129,7 +129,7 @@ int lpc32xx_dma_wait_status(unsigned int channel) break;
if (get_timer(start) > CONFIG_SYS_HZ) { - error("DMA status timeout channel %d\n", channel); + pr_err("DMA status timeout channel %d\n", channel); return -ETIMEDOUT; } udelay(1); @@ -138,7 +138,7 @@ int lpc32xx_dma_wait_status(unsigned int channel) if (unlikely(readl(&dma->raw_err_stat) & BIT_MASK(channel))) { setbits_le32(&dma->int_err_clear, BIT_MASK(channel)); setbits_le32(&dma->raw_err_stat, BIT_MASK(channel)); - error("DMA error on channel %d\n", channel); + pr_err("DMA error on channel %d\n", channel); return -1; } setbits_le32(&dma->int_tc_clear, BIT_MASK(channel)); diff --git a/drivers/dma/ti-edma3.c b/drivers/dma/ti-edma3.c index 39e9793..635eb78 100644 --- a/drivers/dma/ti-edma3.c +++ b/drivers/dma/ti-edma3.c @@ -491,7 +491,7 @@ static int ti_edma3_transfer(struct udevice *dev, int direction, void *dst, __edma3_transfer(priv->base, 1, dst, src, len); break; default: - error("Transfer type not implemented in DMA driver\n"); + pr_err("Transfer type not implemented in DMA driver\n"); break; }
diff --git a/drivers/i2c/i2c-gpio.c b/drivers/i2c/i2c-gpio.c index aeeb304..4e8fa21 100644 --- a/drivers/i2c/i2c-gpio.c +++ b/drivers/i2c/i2c-gpio.c @@ -322,7 +322,7 @@ static int i2c_gpio_ofdata_to_platdata(struct udevice *dev)
return 0; error: - error("Can't get %s gpios! Error: %d", dev->name, ret); + pr_err("Can't get %s gpios! Error: %d", dev->name, ret); return ret; }
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index c98c627..5d33815 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -755,7 +755,7 @@ static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed)
ret = __omap24_i2c_setspeed(i2c_base, speed, &adap->waitdelay); if (ret) { - error("%s: set i2c speed failed\n", __func__); + pr_err("%s: set i2c speed failed\n", __func__); return ret; }
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index bf5fefa..196f236 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -549,7 +549,7 @@ static int stm32_i2c_compute_solutions(struct stm32_i2c_setup *setup, }
if (list_empty(solutions)) { - error("%s: no Prescaler solution\n", __func__); + pr_err("%s: no Prescaler solution\n", __func__); ret = -EPERM; }
@@ -627,7 +627,7 @@ static int stm32_i2c_choose_solution(struct stm32_i2c_setup *setup, }
if (!s) { - error("%s: no solution at all\n", __func__); + pr_err("%s: no solution at all\n", __func__); ret = -EPERM; }
@@ -643,14 +643,14 @@ static int stm32_i2c_compute_timing(struct stm32_i2c_priv *i2c_priv, int ret;
if (setup->speed >= STM32_I2C_SPEED_END) { - error("%s: speed out of bound {%d/%d}\n", __func__, + pr_err("%s: speed out of bound {%d/%d}\n", __func__, setup->speed, STM32_I2C_SPEED_END - 1); return -EINVAL; }
if ((setup->rise_time > i2c_specs[setup->speed].rise_max) || (setup->fall_time > i2c_specs[setup->speed].fall_max)) { - error("%s :timings out of bound Rise{%d>%d}/Fall{%d>%d}\n", + pr_err("%s :timings out of bound Rise{%d>%d}/Fall{%d>%d}\n", __func__, setup->rise_time, i2c_specs[setup->speed].rise_max, setup->fall_time, i2c_specs[setup->speed].fall_max); @@ -658,13 +658,13 @@ static int stm32_i2c_compute_timing(struct stm32_i2c_priv *i2c_priv, }
if (setup->dnf > STM32_I2C_DNF_MAX) { - error("%s: DNF out of bound %d/%d\n", __func__, + pr_err("%s: DNF out of bound %d/%d\n", __func__, setup->dnf, STM32_I2C_DNF_MAX); return -EINVAL; }
if (setup->speed_freq > i2c_specs[setup->speed].rate) { - error("%s: Freq {%d/%d}\n", __func__, + pr_err("%s: Freq {%d/%d}\n", __func__, setup->speed_freq, i2c_specs[setup->speed].rate); return -EINVAL; } @@ -711,7 +711,7 @@ static int stm32_i2c_setup_timing(struct stm32_i2c_priv *i2c_priv, setup->clock_src = clk_get_rate(&i2c_priv->clk);
if (!setup->clock_src) { - error("%s: clock rate is 0\n", __func__); + pr_err("%s: clock rate is 0\n", __func__); return -EINVAL; }
@@ -734,7 +734,7 @@ static int stm32_i2c_setup_timing(struct stm32_i2c_priv *i2c_priv, } while (ret);
if (ret) { - error("%s: impossible to compute I2C timings.\n", __func__); + pr_err("%s: impossible to compute I2C timings.\n", __func__); return ret; }
diff --git a/drivers/i2c/tegra_i2c.c b/drivers/i2c/tegra_i2c.c index 3255e8e..7d23e51 100644 --- a/drivers/i2c/tegra_i2c.c +++ b/drivers/i2c/tegra_i2c.c @@ -372,12 +372,12 @@ static int tegra_i2c_probe(struct udevice *dev)
ret = reset_get_by_name(dev, "i2c", &i2c_bus->reset_ctl); if (ret) { - error("reset_get_by_name() failed: %d\n", ret); + pr_err("reset_get_by_name() failed: %d\n", ret); return ret; } ret = clk_get_by_name(dev, "div-clk", &i2c_bus->clk); if (ret) { - error("clk_get_by_name() failed: %d\n", ret); + pr_err("clk_get_by_name() failed: %d\n", ret); return ret; }
diff --git a/drivers/misc/tegra186_bpmp.c b/drivers/misc/tegra186_bpmp.c index d61bacf..1fdf8ef 100644 --- a/drivers/misc/tegra186_bpmp.c +++ b/drivers/misc/tegra186_bpmp.c @@ -44,7 +44,7 @@ static int tegra186_bpmp_call(struct udevice *dev, int mrq, void *tx_msg,
ret = tegra_ivc_write_get_next_frame(&priv->ivc, &ivc_frame); if (ret) { - error("tegra_ivc_write_get_next_frame() failed: %d\n", ret); + pr_err("tegra_ivc_write_get_next_frame() failed: %d\n", ret); return ret; }
@@ -55,7 +55,7 @@ static int tegra186_bpmp_call(struct udevice *dev, int mrq, void *tx_msg,
ret = tegra_ivc_write_advance(&priv->ivc); if (ret) { - error("tegra_ivc_write_advance() failed: %d\n", ret); + pr_err("tegra_ivc_write_advance() failed: %d\n", ret); return ret; }
@@ -63,7 +63,7 @@ static int tegra186_bpmp_call(struct udevice *dev, int mrq, void *tx_msg, for (;;) { ret = tegra_ivc_channel_notified(&priv->ivc); if (ret) { - error("tegra_ivc_channel_notified() failed: %d\n", ret); + pr_err("tegra_ivc_channel_notified() failed: %d\n", ret); return ret; }
@@ -73,7 +73,7 @@ static int tegra186_bpmp_call(struct udevice *dev, int mrq, void *tx_msg,
/* Timeout 20ms; roughly 10x current max observed duration */ if ((timer_get_us() - start_time) > 20 * 1000) { - error("tegra_ivc_read_get_next_frame() timed out (%d)\n", + pr_err("tegra_ivc_read_get_next_frame() timed out (%d)\n", ret); return -ETIMEDOUT; } @@ -86,12 +86,12 @@ static int tegra186_bpmp_call(struct udevice *dev, int mrq, void *tx_msg,
ret = tegra_ivc_read_advance(&priv->ivc); if (ret) { - error("tegra_ivc_write_advance() failed: %d\n", ret); + pr_err("tegra_ivc_write_advance() failed: %d\n", ret); return ret; }
if (err) { - error("BPMP responded with error %d\n", err); + pr_err("BPMP responded with error %d\n", err); /* err isn't a U-Boot error code, so don't that */ return -EIO; } @@ -144,14 +144,14 @@ static ulong tegra186_bpmp_get_shmem(struct udevice *dev, int index) ret = fdtdec_parse_phandle_with_args(gd->fdt_blob, dev_of_offset(dev), "shmem", NULL, 0, index, &args); if (ret < 0) { - error("fdtdec_parse_phandle_with_args() failed: %d\n", ret); + pr_err("fdtdec_parse_phandle_with_args() failed: %d\n", ret); return ret; }
reg = fdtdec_get_addr_size_auto_noparent(gd->fdt_blob, args.node, "reg", 0, NULL, true); if (reg == FDT_ADDR_T_NONE) { - error("fdtdec_get_addr_size_auto_noparent() failed\n"); + pr_err("fdtdec_get_addr_size_auto_noparent() failed\n"); return -ENODEV; }
@@ -166,7 +166,7 @@ static void tegra186_bpmp_ivc_notify(struct tegra_ivc *ivc)
ret = mbox_send(&priv->mbox, NULL); if (ret) - error("mbox_send() failed: %d\n", ret); + pr_err("mbox_send() failed: %d\n", ret); }
static int tegra186_bpmp_probe(struct udevice *dev) @@ -179,18 +179,18 @@ static int tegra186_bpmp_probe(struct udevice *dev)
ret = mbox_get_by_index(dev, 0, &priv->mbox); if (ret) { - error("mbox_get_by_index() failed: %d\n", ret); + pr_err("mbox_get_by_index() failed: %d\n", ret); return ret; }
tx_base = tegra186_bpmp_get_shmem(dev, 0); if (IS_ERR_VALUE(tx_base)) { - error("tegra186_bpmp_get_shmem failed for tx_base\n"); + pr_err("tegra186_bpmp_get_shmem failed for tx_base\n"); return tx_base; } rx_base = tegra186_bpmp_get_shmem(dev, 1); if (IS_ERR_VALUE(rx_base)) { - error("tegra186_bpmp_get_shmem failed for rx_base\n"); + pr_err("tegra186_bpmp_get_shmem failed for rx_base\n"); return rx_base; } debug("shmem: rx=%lx, tx=%lx\n", rx_base, tx_base); @@ -198,7 +198,7 @@ static int tegra186_bpmp_probe(struct udevice *dev) ret = tegra_ivc_init(&priv->ivc, rx_base, tx_base, BPMP_IVC_FRAME_COUNT, BPMP_IVC_FRAME_SIZE, tegra186_bpmp_ivc_notify); if (ret) { - error("tegra_ivc_init() failed: %d\n", ret); + pr_err("tegra_ivc_init() failed: %d\n", ret); return ret; }
@@ -211,7 +211,7 @@ static int tegra186_bpmp_probe(struct udevice *dev)
/* Timeout 100ms */ if ((timer_get_us() - start_time) > 100 * 1000) { - error("Initial IVC reset timed out (%d)\n", ret); + pr_err("Initial IVC reset timed out (%d)\n", ret); ret = -ETIMEDOUT; goto err_free_mbox; } diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index 40f7892..5edd383 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -155,7 +155,7 @@ static int exynos_dwmci_get_config(const void *blob, int node,
priv = malloc(sizeof(struct dwmci_exynos_priv_data)); if (!priv) { - error("dwmci_exynos_priv_data malloc fail!\n"); + pr_err("dwmci_exynos_priv_data malloc fail!\n"); return -ENOMEM; }
diff --git a/drivers/mmc/hi6220_dw_mmc.c b/drivers/mmc/hi6220_dw_mmc.c index d795198..44a8ef8 100644 --- a/drivers/mmc/hi6220_dw_mmc.c +++ b/drivers/mmc/hi6220_dw_mmc.c @@ -44,7 +44,7 @@ int hi6220_dwmci_add_port(int index, u32 regbase, int bus_width)
host = calloc(1, sizeof(struct dwmci_host)); if (!host) { - error("dwmci_host calloc failed!\n"); + pr_err("dwmci_host calloc failed!\n"); return -ENOMEM; }
diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 2b7cb7f..490a01f 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -159,7 +159,7 @@ static int xenon_mmc_phy_init(struct sdhci_host *host) }
if (time <= 0) { - error("Failed to enable MMC internal clock in time\n"); + pr_err("Failed to enable MMC internal clock in time\n"); return -ETIMEDOUT; }
@@ -187,7 +187,7 @@ static int xenon_mmc_phy_init(struct sdhci_host *host) }
if (time <= 0) { - error("Failed to init MMC PHY in time\n"); + pr_err("Failed to init MMC PHY in time\n"); return -ETIMEDOUT; }
diff --git a/drivers/mtd/nand/lpc32xx_nand_mlc.c b/drivers/mtd/nand/lpc32xx_nand_mlc.c index 3af7e6d..e1b3670 100644 --- a/drivers/mtd/nand/lpc32xx_nand_mlc.c +++ b/drivers/mtd/nand/lpc32xx_nand_mlc.c @@ -583,21 +583,21 @@ void board_nand_init(void) /* identify chip */ ret = nand_scan_ident(mtd, CONFIG_SYS_MAX_NAND_CHIPS, NULL); if (ret) { - error("nand_scan_ident returned %i", ret); + pr_err("nand_scan_ident returned %i", ret); return; }
/* finish scanning the chip */ ret = nand_scan_tail(mtd); if (ret) { - error("nand_scan_tail returned %i", ret); + pr_err("nand_scan_tail returned %i", ret); return; }
/* chip is good, register it */ ret = nand_register(0, mtd); if (ret) - error("nand_register returned %i", ret); + pr_err("nand_register returned %i", ret); }
#else /* defined(CONFIG_SPL_BUILD) */ diff --git a/drivers/mtd/nand/pxa3xx_nand.c b/drivers/mtd/nand/pxa3xx_nand.c index 0042a7b..6ab3c8a 100644 --- a/drivers/mtd/nand/pxa3xx_nand.c +++ b/drivers/mtd/nand/pxa3xx_nand.c @@ -1559,7 +1559,7 @@ static int pxa3xx_nand_probe_dt(struct pxa3xx_nand_info *info)
pdata->num_cs = fdtdec_get_int(blob, node, "num-cs", 1); if (pdata->num_cs != 1) { - error("pxa3xx driver supports single CS only\n"); + pr_err("pxa3xx driver supports single CS only\n"); break; }
diff --git a/drivers/net/bcm-sf2-eth-gmac.c b/drivers/net/bcm-sf2-eth-gmac.c index 9ff72fa..a2b594e 100644 --- a/drivers/net/bcm-sf2-eth-gmac.c +++ b/drivers/net/bcm-sf2-eth-gmac.c @@ -610,7 +610,7 @@ int gmac_miiphy_read(struct mii_dev *bus, int phyaddr, int devad, int reg)
/* Busy wait timeout is 1ms */ if (gmac_mii_busywait(1000)) { - error("%s: Prepare MII read: MII/MDIO busy\n", __func__); + pr_err("%s: Prepare MII read: MII/MDIO busy\n", __func__); return -1; }
@@ -622,7 +622,7 @@ int gmac_miiphy_read(struct mii_dev *bus, int phyaddr, int devad, int reg) writel(tmp, GMAC_MII_DATA_ADDR);
if (gmac_mii_busywait(1000)) { - error("%s: MII read failure: MII/MDIO busy\n", __func__); + pr_err("%s: MII read failure: MII/MDIO busy\n", __func__); return -1; }
@@ -638,7 +638,7 @@ int gmac_miiphy_write(struct mii_dev *bus, int phyaddr, int devad, int reg,
/* Busy wait timeout is 1ms */ if (gmac_mii_busywait(1000)) { - error("%s: Prepare MII write: MII/MDIO busy\n", __func__); + pr_err("%s: Prepare MII write: MII/MDIO busy\n", __func__); return -1; }
@@ -651,7 +651,7 @@ int gmac_miiphy_write(struct mii_dev *bus, int phyaddr, int devad, int reg, writel(tmp, GMAC_MII_DATA_ADDR);
if (gmac_mii_busywait(1000)) { - error("%s: MII write failure: MII/MDIO busy\n", __func__); + pr_err("%s: MII write failure: MII/MDIO busy\n", __func__); return -1; }
@@ -742,7 +742,7 @@ int gmac_set_speed(int speed, int duplex) } else if (speed == 10) { speed_cfg = 0; } else { - error("%s: Invalid GMAC speed(%d)!\n", __func__, speed); + pr_err("%s: Invalid GMAC speed(%d)!\n", __func__, speed); return -1; }
@@ -820,7 +820,7 @@ int gmac_mac_init(struct eth_device *dev) writel(0, GMAC0_INT_STATUS_ADDR);
if (dma_init(dma) < 0) { - error("%s: GMAC dma_init failed\n", __func__); + pr_err("%s: GMAC dma_init failed\n", __func__); goto err_exit; }
@@ -855,7 +855,7 @@ int gmac_mac_init(struct eth_device *dev) writel(tmp, GMAC_MII_CTRL_ADDR);
if (gmac_mii_busywait(1000)) { - error("%s: Configure MDIO: MII/MDIO busy\n", __func__); + pr_err("%s: Configure MDIO: MII/MDIO busy\n", __func__); goto err_exit; }
diff --git a/drivers/net/bcm-sf2-eth.c b/drivers/net/bcm-sf2-eth.c index e274736..9056f71 100644 --- a/drivers/net/bcm-sf2-eth.c +++ b/drivers/net/bcm-sf2-eth.c @@ -40,7 +40,7 @@ static int bcm_sf2_eth_init(struct eth_device *dev)
rc = eth->mac_init(dev); if (rc) { - error("%s: Couldn't cofigure MAC!\n", __func__); + pr_err("%s: Couldn't cofigure MAC!\n", __func__); return rc; }
@@ -90,7 +90,7 @@ static int bcm_sf2_eth_send(struct eth_device *dev, void *packet, int length) debug("."); i++; if (i > 20) { - error("%s: Tx timeout: retried 20 times\n", __func__); + pr_err("%s: Tx timeout: retried 20 times\n", __func__); rc = -1; break; } @@ -117,7 +117,7 @@ static int bcm_sf2_eth_receive(struct eth_device *dev) debug("\nNO More Rx\n"); break; } else if ((rcvlen == 0) || (rcvlen > RX_BUF_SIZE)) { - error("%s: Wrong Ethernet packet size (%d B), skip!\n", + pr_err("%s: Wrong Ethernet packet size (%d B), skip!\n", __func__, rcvlen); break; } else { @@ -166,9 +166,9 @@ static int bcm_sf2_eth_open(struct eth_device *dev, bd_t *bt) */ for (i = 0; i < eth->port_num; i++) { if (phy_startup(eth->port[i])) { - error("%s: PHY %d startup failed!\n", __func__, i); + pr_err("%s: PHY %d startup failed!\n", __func__, i); if (i == CONFIG_BCM_SF2_ETH_DEFAULT_PORT) { - error("%s: No default port %d!\n", __func__, i); + pr_err("%s: No default port %d!\n", __func__, i); return -1; } } @@ -205,13 +205,13 @@ int bcm_sf2_eth_register(bd_t *bis, u8 dev_num)
dev = (struct eth_device *)malloc(sizeof(struct eth_device)); if (dev == NULL) { - error("%s: Not enough memory!\n", __func__); + pr_err("%s: Not enough memory!\n", __func__); return -1; }
eth = (struct eth_info *)malloc(sizeof(struct eth_info)); if (eth == NULL) { - error("%s: Not enough memory!\n", __func__); + pr_err("%s: Not enough memory!\n", __func__); return -1; }
@@ -234,7 +234,7 @@ int bcm_sf2_eth_register(bd_t *bis, u8 dev_num) if (gmac_add(dev)) { free(eth); free(dev); - error("%s: Adding GMAC failed!\n", __func__); + pr_err("%s: Adding GMAC failed!\n", __func__); return -1; } #else @@ -263,7 +263,7 @@ int bcm_sf2_eth_register(bd_t *bis, u8 dev_num)
rc = bcm_sf2_eth_init(dev); if (rc != 0) { - error("%s: configuration failed!\n", __func__); + pr_err("%s: configuration failed!\n", __func__); return -1; }
diff --git a/drivers/net/cpsw-common.c b/drivers/net/cpsw-common.c index 8970ee0..0dc83ab 100644 --- a/drivers/net/cpsw-common.c +++ b/drivers/net/cpsw-common.c @@ -29,14 +29,14 @@ static int davinci_emac_3517_get_macid(struct udevice *dev, u16 offset,
syscon = fdtdec_lookup_phandle(fdt, node, "syscon"); if (syscon < 0) { - error("Syscon offset not found\n"); + pr_err("Syscon offset not found\n"); return -ENOENT; }
addr = (u32)map_physmem(fdt_translate_address(fdt, syscon, &gmii), sizeof(u32), MAP_NOCACHE); if (addr == FDT_ADDR_T_NONE) { - error("Not able to get syscon address to get mac efuse address\n"); + pr_err("Not able to get syscon address to get mac efuse address\n"); return -ENOENT; }
@@ -69,14 +69,14 @@ static int cpsw_am33xx_cm_get_macid(struct udevice *dev, u16 offset, int slave,
diff --git a/drivers/net/cpsw.c b/drivers/net/cpsw.c index d7db0fc..b72258f 100644 --- a/drivers/net/cpsw.c +++ b/drivers/net/cpsw.c @@ -1368,7 +1368,7 @@ static int cpsw_eth_ofdata_to_platdata(struct udevice *dev)
mdio_base = cpsw_get_addr_by_node(fdt, subnode); if (mdio_base == FDT_ADDR_T_NONE) { - error("Not able to get MDIO address space\n"); + pr_err("Not able to get MDIO address space\n"); return -ENOENT; } priv->data.mdio_base = mdio_base; @@ -1407,7 +1407,7 @@ static int cpsw_eth_ofdata_to_platdata(struct udevice *dev) subnode);
if (priv->data.gmii_sel == FDT_ADDR_T_NONE) { - error("Not able to get gmii_sel reg address\n"); + pr_err("Not able to get gmii_sel reg address\n"); return -ENOENT; }
@@ -1418,7 +1418,7 @@ static int cpsw_eth_ofdata_to_platdata(struct udevice *dev) phy_sel_compat = fdt_getprop(fdt, subnode, "compatible", NULL); if (!phy_sel_compat) { - error("Not able to get gmii_sel compatible\n"); + pr_err("Not able to get gmii_sel compatible\n"); return -ENOENT; } } @@ -1434,7 +1434,7 @@ static int cpsw_eth_ofdata_to_platdata(struct udevice *dev)
ret = ti_cm_get_macid(dev, active_slave, pdata->enetaddr); if (ret < 0) { - error("cpsw read efuse mac failed\n"); + pr_err("cpsw read efuse mac failed\n"); return ret; }
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 5c4315f..00076cf 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -377,7 +377,7 @@ static int eqos_mdio_read(struct mii_dev *bus, int mdio_addr, int mdio_devad,
ret = eqos_mdio_wait_idle(eqos); if (ret) { - error("MDIO not idle at entry"); + pr_err("MDIO not idle at entry"); return ret; }
@@ -397,7 +397,7 @@ static int eqos_mdio_read(struct mii_dev *bus, int mdio_addr, int mdio_devad,
ret = eqos_mdio_wait_idle(eqos); if (ret) { - error("MDIO read didn't complete"); + pr_err("MDIO read didn't complete"); return ret; }
@@ -421,7 +421,7 @@ static int eqos_mdio_write(struct mii_dev *bus, int mdio_addr, int mdio_devad,
@@ -443,7 +443,7 @@ static int eqos_mdio_write(struct mii_dev *bus, int mdio_addr, int mdio_devad,
@@ -459,37 +459,37 @@ static int eqos_start_clks_tegra186(struct udevice *dev)
ret = clk_enable(&eqos->clk_slave_bus); if (ret < 0) { - error("clk_enable(clk_slave_bus) failed: %d", ret); + pr_err("clk_enable(clk_slave_bus) failed: %d", ret); goto err; }
ret = clk_enable(&eqos->clk_master_bus); if (ret < 0) { - error("clk_enable(clk_master_bus) failed: %d", ret); + pr_err("clk_enable(clk_master_bus) failed: %d", ret); goto err_disable_clk_slave_bus; }
ret = clk_enable(&eqos->clk_rx); if (ret < 0) { - error("clk_enable(clk_rx) failed: %d", ret); + pr_err("clk_enable(clk_rx) failed: %d", ret); goto err_disable_clk_master_bus; }
ret = clk_enable(&eqos->clk_ptp_ref); if (ret < 0) { - error("clk_enable(clk_ptp_ref) failed: %d", ret); + pr_err("clk_enable(clk_ptp_ref) failed: %d", ret); goto err_disable_clk_rx; }
ret = clk_set_rate(&eqos->clk_ptp_ref, 125 * 1000 * 1000); if (ret < 0) { - error("clk_set_rate(clk_ptp_ref) failed: %d", ret); + pr_err("clk_set_rate(clk_ptp_ref) failed: %d", ret); goto err_disable_clk_ptp_ref; }
ret = clk_enable(&eqos->clk_tx); if (ret < 0) { - error("clk_enable(clk_tx) failed: %d", ret); + pr_err("clk_enable(clk_tx) failed: %d", ret); goto err_disable_clk_ptp_ref; }
@@ -533,7 +533,7 @@ static int eqos_start_resets_tegra186(struct udevice *dev)
ret = dm_gpio_set_value(&eqos->phy_reset_gpio, 1); if (ret < 0) { - error("dm_gpio_set_value(phy_reset, assert) failed: %d", ret); + pr_err("dm_gpio_set_value(phy_reset, assert) failed: %d", ret); return ret; }
@@ -541,13 +541,13 @@ static int eqos_start_resets_tegra186(struct udevice *dev)
ret = dm_gpio_set_value(&eqos->phy_reset_gpio, 0); if (ret < 0) { - error("dm_gpio_set_value(phy_reset, deassert) failed: %d", ret); + pr_err("dm_gpio_set_value(phy_reset, deassert) failed: %d", ret); return ret; }
ret = reset_assert(&eqos->reset_ctl); if (ret < 0) { - error("reset_assert() failed: %d", ret); + pr_err("reset_assert() failed: %d", ret); return ret; }
@@ -555,7 +555,7 @@ static int eqos_start_resets_tegra186(struct udevice *dev)
ret = reset_deassert(&eqos->reset_ctl); if (ret < 0) { - error("reset_deassert() failed: %d", ret); + pr_err("reset_deassert() failed: %d", ret); return ret; }
@@ -591,14 +591,14 @@ static int eqos_calibrate_pads_tegra186(struct udevice *dev) ret = wait_for_bit(__func__, &eqos->tegra186_regs->auto_cal_status, EQOS_AUTO_CAL_STATUS_ACTIVE, true, 10, false); if (ret) { - error("calibrate didn't start"); + pr_err("calibrate didn't start"); goto failed; }
ret = wait_for_bit(__func__, &eqos->tegra186_regs->auto_cal_status, EQOS_AUTO_CAL_STATUS_ACTIVE, false, 10, false); if (ret) { - error("calibrate didn't finish"); + pr_err("calibrate didn't finish"); goto failed; }
@@ -713,13 +713,13 @@ static int eqos_set_tx_clk_speed_tegra186(struct udevice *dev) rate = 2.5 * 1000 * 1000; break; default: - error("invalid speed %d", eqos->phy->speed); + pr_err("invalid speed %d", eqos->phy->speed); return -EINVAL; }
ret = clk_set_rate(&eqos->clk_tx, rate); if (ret < 0) { - error("clk_set_rate(tx_clk, %lu) failed: %d", rate, ret); + pr_err("clk_set_rate(tx_clk, %lu) failed: %d", rate, ret); return ret; }
@@ -739,7 +739,7 @@ static int eqos_adjust_link(struct udevice *dev) else ret = eqos_set_half_duplex(dev); if (ret < 0) { - error("eqos_set_*_duplex() failed: %d", ret); + pr_err("eqos_set_*_duplex() failed: %d", ret); return ret; }
@@ -757,24 +757,24 @@ static int eqos_adjust_link(struct udevice *dev) ret = eqos_set_mii_speed_10(dev); break; default: - error("invalid speed %d", eqos->phy->speed); + pr_err("invalid speed %d", eqos->phy->speed); return -EINVAL; } if (ret < 0) { - error("eqos_set_*mii_speed*() failed: %d", ret); + pr_err("eqos_set_*mii_speed*() failed: %d", ret); return ret; }
if (en_calibration) { ret = eqos_calibrate_pads_tegra186(dev); if (ret < 0) { - error("eqos_calibrate_pads_tegra186() failed: %d", ret); + pr_err("eqos_calibrate_pads_tegra186() failed: %d", ret); return ret; } } else { ret = eqos_disable_calibration_tegra186(dev); if (ret < 0) { - error("eqos_disable_calibration_tegra186() failed: %d", + pr_err("eqos_disable_calibration_tegra186() failed: %d", ret); return ret; } @@ -782,7 +782,7 @@ static int eqos_adjust_link(struct udevice *dev)
ret = eqos_set_tx_clk_speed_tegra186(dev); if (ret < 0) { - error("eqos_set_tx_clk_speed_tegra186() failed: %d", ret); + pr_err("eqos_set_tx_clk_speed_tegra186() failed: %d", ret); return ret; }
@@ -848,13 +848,13 @@ static int eqos_start(struct udevice *dev)
ret = eqos_start_clks_tegra186(dev); if (ret < 0) { - error("eqos_start_clks_tegra186() failed: %d", ret); + pr_err("eqos_start_clks_tegra186() failed: %d", ret); goto err; }
ret = eqos_start_resets_tegra186(dev); if (ret < 0) { - error("eqos_start_resets_tegra186() failed: %d", ret); + pr_err("eqos_start_resets_tegra186() failed: %d", ret); goto err_stop_clks; }
@@ -865,13 +865,13 @@ static int eqos_start(struct udevice *dev) ret = wait_for_bit(__func__, &eqos->dma_regs->mode, EQOS_DMA_MODE_SWR, false, 10, false); if (ret) { - error("EQOS_DMA_MODE_SWR stuck"); + pr_err("EQOS_DMA_MODE_SWR stuck"); goto err_stop_resets; }
ret = eqos_calibrate_pads_tegra186(dev); if (ret < 0) { - error("eqos_calibrate_pads_tegra186() failed: %d", ret); + pr_err("eqos_calibrate_pads_tegra186() failed: %d", ret); goto err_stop_resets; }
@@ -881,28 +881,28 @@ static int eqos_start(struct udevice *dev)
eqos->phy = phy_connect(eqos->mii, 0, dev, 0); if (!eqos->phy) { - error("phy_connect() failed"); + pr_err("phy_connect() failed"); goto err_stop_resets; } ret = phy_config(eqos->phy); if (ret < 0) { - error("phy_config() failed: %d", ret); + pr_err("phy_config() failed: %d", ret); goto err_shutdown_phy; } ret = phy_startup(eqos->phy); if (ret < 0) { - error("phy_startup() failed: %d", ret); + pr_err("phy_startup() failed: %d", ret); goto err_shutdown_phy; }
if (!eqos->phy->link) { - error("No link"); + pr_err("No link"); goto err_shutdown_phy; }
ret = eqos_adjust_link(dev); if (ret < 0) { - error("eqos_adjust_link() failed: %d", ret); + pr_err("eqos_adjust_link() failed: %d", ret); goto err_shutdown_phy; }
@@ -1119,7 +1119,7 @@ err_stop_resets: err_stop_clks: eqos_stop_clks_tegra186(dev); err: - error("FAILED: %d", ret); + pr_err("FAILED: %d", ret); return ret; }
@@ -1361,7 +1361,7 @@ static int eqos_probe_resources_tegra186(struct udevice *dev)
ret = reset_get_by_name(dev, "eqos", &eqos->reset_ctl); if (ret) { - error("reset_get_by_name(rst) failed: %d", ret); + pr_err("reset_get_by_name(rst) failed: %d", ret); return ret; }
@@ -1369,38 +1369,38 @@ static int eqos_probe_resources_tegra186(struct udevice *dev) &eqos->phy_reset_gpio, GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); if (ret) { - error("gpio_request_by_name(phy reset) failed: %d", ret); + pr_err("gpio_request_by_name(phy reset) failed: %d", ret); goto err_free_reset_eqos; }
ret = clk_get_by_name(dev, "slave_bus", &eqos->clk_slave_bus); if (ret) { - error("clk_get_by_name(slave_bus) failed: %d", ret); + pr_err("clk_get_by_name(slave_bus) failed: %d", ret); goto err_free_gpio_phy_reset; }
ret = clk_get_by_name(dev, "master_bus", &eqos->clk_master_bus); if (ret) { - error("clk_get_by_name(master_bus) failed: %d", ret); + pr_err("clk_get_by_name(master_bus) failed: %d", ret); goto err_free_clk_slave_bus; }
ret = clk_get_by_name(dev, "rx", &eqos->clk_rx); if (ret) { - error("clk_get_by_name(rx) failed: %d", ret); + pr_err("clk_get_by_name(rx) failed: %d", ret); goto err_free_clk_master_bus; }
ret = clk_get_by_name(dev, "ptp_ref", &eqos->clk_ptp_ref); if (ret) { - error("clk_get_by_name(ptp_ref) failed: %d", ret); + pr_err("clk_get_by_name(ptp_ref) failed: %d", ret); goto err_free_clk_rx; return ret; }
ret = clk_get_by_name(dev, "tx", &eqos->clk_tx); if (ret) { - error("clk_get_by_name(tx) failed: %d", ret); + pr_err("clk_get_by_name(tx) failed: %d", ret); goto err_free_clk_ptp_ref; }
@@ -1454,7 +1454,7 @@ static int eqos_probe(struct udevice *dev)
eqos->regs = devfdt_get_addr(dev); if (eqos->regs == FDT_ADDR_T_NONE) { - error("devfdt_get_addr() failed"); + pr_err("devfdt_get_addr() failed"); return -ENODEV; } eqos->mac_regs = (void *)(eqos->regs + EQOS_MAC_REGS_BASE); @@ -1464,19 +1464,19 @@ static int eqos_probe(struct udevice *dev)
ret = eqos_probe_resources_core(dev); if (ret < 0) { - error("eqos_probe_resources_core() failed: %d", ret); + pr_err("eqos_probe_resources_core() failed: %d", ret); return ret; }
ret = eqos_probe_resources_tegra186(dev); if (ret < 0) { - error("eqos_probe_resources_tegra186() failed: %d", ret); + pr_err("eqos_probe_resources_tegra186() failed: %d", ret); goto err_remove_resources_core; }
eqos->mii = mdio_alloc(); if (!eqos->mii) { - error("mdio_alloc() failed"); + pr_err("mdio_alloc() failed"); goto err_remove_resources_tegra; } eqos->mii->read = eqos_mdio_read; @@ -1486,7 +1486,7 @@ static int eqos_probe(struct udevice *dev)
ret = mdio_register(eqos->mii); if (ret < 0) { - error("mdio_register() failed: %d", ret); + pr_err("mdio_register() failed: %d", ret); goto err_free_mdio; }
diff --git a/drivers/net/ep93xx_eth.c b/drivers/net/ep93xx_eth.c index a94191b..bc45706 100644 --- a/drivers/net/ep93xx_eth.c +++ b/drivers/net/ep93xx_eth.c @@ -324,7 +324,7 @@ static int ep93xx_eth_rcv_packet(struct eth_device *dev) debug("reporting %d bytes...\n", len); } else { /* Do we have an erroneous packet? */ - error("packet rx error, status %08X %08X", + pr_err("packet rx error, status %08X %08X", priv->rx_sq.current->word1, priv->rx_sq.current->word2); dump_rx_descriptor_queue(dev); @@ -401,7 +401,7 @@ static int ep93xx_eth_send_packet(struct eth_device *dev, ; /* noop */
if (!TX_STATUS_TXWE(priv->tx_sq.current)) { - error("packet tx error, status %08X", + pr_err("packet tx error, status %08X", priv->tx_sq.current->word1); dump_tx_descriptor_queue(dev); dump_tx_status_queue(dev); @@ -452,7 +452,7 @@ int ep93xx_eth_initialize(u8 dev_num, int base_addr)
priv = malloc(sizeof(*priv)); if (!priv) { - error("malloc() failed"); + pr_err("malloc() failed"); goto eth_init_failed_0; } memset(priv, 0, sizeof(*priv)); @@ -462,34 +462,34 @@ int ep93xx_eth_initialize(u8 dev_num, int base_addr) priv->tx_dq.base = calloc(NUMTXDESC, sizeof(struct tx_descriptor)); if (priv->tx_dq.base == NULL) { - error("calloc() failed"); + pr_err("calloc() failed"); goto eth_init_failed_1; }
priv->tx_sq.base = calloc(NUMTXDESC, sizeof(struct tx_status)); if (priv->tx_sq.base == NULL) { - error("calloc() failed"); + pr_err("calloc() failed"); goto eth_init_failed_2; }
priv->rx_dq.base = calloc(NUMRXDESC, sizeof(struct rx_descriptor)); if (priv->rx_dq.base == NULL) { - error("calloc() failed"); + pr_err("calloc() failed"); goto eth_init_failed_3; }
priv->rx_sq.base = calloc(NUMRXDESC, sizeof(struct rx_status)); if (priv->rx_sq.base == NULL) { - error("calloc() failed"); + pr_err("calloc() failed"); goto eth_init_failed_4; }
dev = malloc(sizeof *dev); if (dev == NULL) { - error("malloc() failed"); + pr_err("malloc() failed"); goto eth_init_failed_5; } memset(dev, 0, sizeof *dev); diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c index 72ef42c..21ccab4 100644 --- a/drivers/net/keystone_net.c +++ b/drivers/net/keystone_net.c @@ -757,7 +757,7 @@ static int ks2_eth_start(struct udevice *dev) qm_init();
if (ksnav_init(priv->netcp_pktdma, &priv->net_rx_buffs)) { - error("ksnav_init failed\n"); + pr_err("ksnav_init failed\n"); goto err_knav_init; }
@@ -773,7 +773,7 @@ static int ks2_eth_start(struct udevice *dev)
phy_startup(priv->phydev); if (priv->phydev->link == 0) { - error("phy startup failed\n"); + pr_err("phy startup failed\n"); goto err_phy_start; } } @@ -923,7 +923,7 @@ static int ks2_eth_probe(struct udevice *dev) */ mdio_bus = mdio_alloc(); if (!mdio_bus) { - error("MDIO alloc failed\n"); + pr_err("MDIO alloc failed\n"); return -ENOMEM; } priv->mdio_bus = mdio_bus; @@ -935,7 +935,7 @@ static int ks2_eth_probe(struct udevice *dev)
ret = mdio_register(mdio_bus); if (ret) { - error("MDIO bus register failed\n"); + pr_err("MDIO bus register failed\n"); return ret; } } else { @@ -1011,7 +1011,7 @@ static int ks2_eth_bind_slaves(struct udevice *dev, int gbe, int *gbe_0) slave_name, offset_to_ofnode(slave), &sl_dev); if (ret) { - error("ks2_net - not able to bind slave interfaces\n"); + pr_err("ks2_net - not able to bind slave interfaces\n"); return ret; } } @@ -1031,7 +1031,7 @@ static int ks2_eth_bind_slaves(struct udevice *dev, int gbe, int *gbe_0) ret = device_bind_driver_to_node(dev, "eth_ks2_sl", slave_name, offset_to_ofnode(slave), &sl_dev); if (ret) { - error("ks2_net - not able to bind slave interfaces\n"); + pr_err("ks2_net - not able to bind slave interfaces\n"); return ret; } } @@ -1074,7 +1074,7 @@ static int ks2_eth_parse_slave_interface(int netcp, int slave,
mdio = fdt_parent_offset(fdt, phy); if (mdio < 0) { - error("mdio dt not found\n"); + pr_err("mdio dt not found\n"); return -ENODEV; } priv->mdio_base = (void *)fdtdec_get_addr(fdt, mdio, "reg"); diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index cb5cf8b..c15d84b 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -371,7 +371,7 @@ static int tegra_pcie_port_parse_dt(ofnode node, struct tegra_pcie_port *port)
addr = ofnode_get_property(node, "assigned-addresses", &len); if (!addr) { - error("property "assigned-addresses" not found"); + pr_err("property "assigned-addresses" not found"); return -FDT_ERR_NOTFOUND; }
@@ -462,7 +462,7 @@ static int tegra_pcie_parse_port_info(ofnode node, uint *index, uint *lanes)
err = ofnode_read_u32_default(node, "nvidia,num-lanes", -1); if (err < 0) { - error("failed to parse "nvidia,num-lanes" property"); + pr_err("failed to parse "nvidia,num-lanes" property"); return err; }
@@ -470,7 +470,7 @@ static int tegra_pcie_parse_port_info(ofnode node, uint *index, uint *lanes)
err = ofnode_read_pci_addr(node, 0, "reg", &addr); if (err < 0) { - error("failed to parse "reg" property"); + pr_err("failed to parse "reg" property"); return err; }
@@ -493,25 +493,25 @@ static int tegra_pcie_parse_dt(struct udevice *dev, enum tegra_pci_id id,
err = dev_read_resource(dev, 0, &pcie->pads); if (err < 0) { - error("resource "pads" not found"); + pr_err("resource "pads" not found"); return err; }
err = dev_read_resource(dev, 1, &pcie->afi); if (err < 0) { - error("resource "afi" not found"); + pr_err("resource "afi" not found"); return err; }
err = dev_read_resource(dev, 2, &pcie->cs); if (err < 0) { - error("resource "cs" not found"); + pr_err("resource "cs" not found"); return err; }
err = tegra_pcie_board_init(); if (err < 0) { - error("tegra_pcie_board_init() failed: err=%d", err); + pr_err("tegra_pcie_board_init() failed: err=%d", err); return err; }
@@ -520,7 +520,7 @@ static int tegra_pcie_parse_dt(struct udevice *dev, enum tegra_pci_id id, if (pcie->phy) { err = tegra_xusb_phy_prepare(pcie->phy); if (err < 0) { - error("failed to prepare PHY: %d", err); + pr_err("failed to prepare PHY: %d", err); return err; } } @@ -532,7 +532,7 @@ static int tegra_pcie_parse_dt(struct udevice *dev, enum tegra_pci_id id,
err = tegra_pcie_parse_port_info(subnode, &index, &num_lanes); if (err < 0) { - error("failed to obtain root port info"); + pr_err("failed to obtain root port info"); continue; }
@@ -562,7 +562,7 @@ static int tegra_pcie_parse_dt(struct udevice *dev, enum tegra_pci_id id, err = tegra_pcie_get_xbar_config(dev_ofnode(dev), lanes, id, &pcie->xbar); if (err < 0) { - error("invalid lane configuration"); + pr_err("invalid lane configuration"); return err; }
@@ -576,31 +576,31 @@ static int tegra_pcie_power_on(struct tegra_pcie *pcie)
ret = power_domain_on(&pcie->pwrdom); if (ret) { - error("power_domain_on() failed: %d\n", ret); + pr_err("power_domain_on() failed: %d\n", ret); return ret; }
ret = clk_enable(&pcie->clk_afi); if (ret) { - error("clk_enable(afi) failed: %d\n", ret); + pr_err("clk_enable(afi) failed: %d\n", ret); return ret; }
ret = clk_enable(&pcie->clk_pex); if (ret) { - error("clk_enable(pex) failed: %d\n", ret); + pr_err("clk_enable(pex) failed: %d\n", ret); return ret; }
ret = reset_deassert(&pcie->reset_afi); if (ret) { - error("reset_deassert(afi) failed: %d\n", ret); + pr_err("reset_deassert(afi) failed: %d\n", ret); return ret; }
ret = reset_deassert(&pcie->reset_pex); if (ret) { - error("reset_deassert(pex) failed: %d\n", ret); + pr_err("reset_deassert(pex) failed: %d\n", ret); return ret; }
@@ -620,14 +620,14 @@ static int tegra_pcie_power_on(struct tegra_pcie *pcie)
err = tegra_powergate_power_off(TEGRA_POWERGATE_PCIE); if (err < 0) { - error("failed to power off PCIe partition: %d", err); + pr_err("failed to power off PCIe partition: %d", err); return err; }
err = tegra_powergate_sequence_power_up(TEGRA_POWERGATE_PCIE, PERIPH_ID_PCIE); if (err < 0) { - error("failed to power up PCIe partition: %d", err); + pr_err("failed to power up PCIe partition: %d", err); return err; }
@@ -647,7 +647,7 @@ static int tegra_pcie_power_on(struct tegra_pcie *pcie)
err = tegra_plle_enable(); if (err < 0) { - error("failed to enable PLLE: %d\n", err); + pr_err("failed to enable PLLE: %d\n", err); return err; }
@@ -707,7 +707,7 @@ static int tegra_pcie_phy_enable(struct tegra_pcie *pcie) /* wait for the PLL to lock */ err = tegra_pcie_pll_wait(pcie, 500); if (err < 0) { - error("PLL failed to lock: %d", err); + pr_err("PLL failed to lock: %d", err); return err; }
@@ -771,7 +771,7 @@ static int tegra_pcie_enable_controller(struct tegra_pcie *pcie) err = tegra_pcie_phy_enable(pcie);
if (err < 0) { - error("failed to power on PHY: %d\n", err); + pr_err("failed to power on PHY: %d\n", err); return err; } #endif @@ -780,7 +780,7 @@ static int tegra_pcie_enable_controller(struct tegra_pcie *pcie) #ifdef CONFIG_TEGRA186 err = reset_deassert(&pcie->reset_pcie_x); if (err) { - error("reset_deassert(pcie_x) failed: %d\n", err); + pr_err("reset_deassert(pcie_x) failed: %d\n", err); return err; } #else @@ -1145,25 +1145,25 @@ static int pci_tegra_probe(struct udevice *dev)
err = tegra_pcie_power_on(pcie); if (err < 0) { - error("failed to power on"); + pr_err("failed to power on"); return err; }
err = tegra_pcie_enable_controller(pcie); if (err < 0) { - error("failed to enable controller"); + pr_err("failed to enable controller"); return err; }
err = tegra_pcie_setup_translations(dev); if (err < 0) { - error("failed to decode ranges"); + pr_err("failed to decode ranges"); return err; }
err = tegra_pcie_enable(pcie); if (err < 0) { - error("failed to enable PCIe"); + pr_err("failed to enable PCIe"); return err; }
diff --git a/drivers/pci/pcie_xilinx.c b/drivers/pci/pcie_xilinx.c index 08e2e93..6b8b96a 100644 --- a/drivers/pci/pcie_xilinx.c +++ b/drivers/pci/pcie_xilinx.c @@ -189,7 +189,7 @@ static int pcie_xilinx_ofdata_to_platdata(struct udevice *dev) err = fdt_get_resource(gd->fdt_blob, dev_of_offset(dev), "reg", 0, ®_res); if (err < 0) { - error(""reg" resource not found\n"); + pr_err(""reg" resource not found\n"); return err; }
diff --git a/drivers/phy/marvell/comphy_cp110.c b/drivers/phy/marvell/comphy_cp110.c index 3ac405a..3718788 100644 --- a/drivers/phy/marvell/comphy_cp110.c +++ b/drivers/phy/marvell/comphy_cp110.c @@ -509,7 +509,7 @@ static int comphy_pcie_power_up(u32 lane, u32 pcie_width, bool clk_src, debug("Read from reg = %p - value = 0x%x\n", hpipe_addr + HPIPE_LANE_STATUS1_REG, data); - error("HPIPE_LANE_STATUS1_PCLK_EN_MASK is 0\n"); + pr_err("HPIPE_LANE_STATUS1_PCLK_EN_MASK is 0\n"); ret = 0; } } @@ -633,7 +633,7 @@ static int comphy_usb3_power_up(u32 lane, void __iomem *hpipe_base, if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", hpipe_addr + HPIPE_LANE_STATUS1_REG, data); - error("HPIPE_LANE_STATUS1_PCLK_EN_MASK is 0\n"); + pr_err("HPIPE_LANE_STATUS1_PCLK_EN_MASK is 0\n"); ret = 0; }
@@ -666,14 +666,14 @@ static int comphy_sata_power_up(u32 lane, void __iomem *hpipe_base, gd->fdt_blob, sata_node, "marvell,armada-8k-ahci");
if (sata_node == 0) { - error("SATA node not found in FDT\n"); + pr_err("SATA node not found in FDT\n"); return 0; }
sata_base = (void __iomem *)fdtdec_get_addr_size_auto_noparent( gd->fdt_blob, sata_node, "reg", 0, NULL, true); if (sata_base == NULL) { - error("SATA address not found in FDT\n"); + pr_err("SATA address not found in FDT\n"); return 0; }
@@ -976,7 +976,7 @@ static int comphy_sata_power_up(u32 lane, void __iomem *hpipe_base, if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", hpipe_addr + HPIPE_LANE_STATUS1_REG, data); - error("SD_EXTERNAL_STATUS0_PLL_TX is %d, SD_EXTERNAL_STATUS0_PLL_RX is %d\n", + pr_err("SD_EXTERNAL_STATUS0_PLL_TX is %d, SD_EXTERNAL_STATUS0_PLL_RX is %d\n", (data & SD_EXTERNAL_STATUS0_PLL_TX_MASK), (data & SD_EXTERNAL_STATUS0_PLL_RX_MASK)); ret = 0; @@ -1099,7 +1099,7 @@ static int comphy_sgmii_power_up(u32 lane, u32 sgmii_speed, if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", sd_ip_addr + SD_EXTERNAL_STATUS0_REG, data); - error("SD_EXTERNAL_STATUS0_PLL_RX is %d, SD_EXTERNAL_STATUS0_PLL_TX is %d\n", + pr_err("SD_EXTERNAL_STATUS0_PLL_RX is %d, SD_EXTERNAL_STATUS0_PLL_TX is %d\n", (data & SD_EXTERNAL_STATUS0_PLL_RX_MASK), (data & SD_EXTERNAL_STATUS0_PLL_TX_MASK)); ret = 0; @@ -1117,7 +1117,7 @@ static int comphy_sgmii_power_up(u32 lane, u32 sgmii_speed, data = polling_with_timeout(addr, data, mask, 100); if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", sd_ip_addr + SD_EXTERNAL_STATUS0_REG, data); - error("SD_EXTERNAL_STATUS0_RX_INIT is 0\n"); + pr_err("SD_EXTERNAL_STATUS0_RX_INIT is 0\n"); ret = 0; }
@@ -1398,7 +1398,7 @@ static int comphy_sfi_power_up(u32 lane, void __iomem *hpipe_base, data = polling_with_timeout(addr, data, mask, 15000); if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", sd_ip_addr + SD_EXTERNAL_STATUS0_REG, data); - error("SD_EXTERNAL_STATUS0_PLL_RX is %d, SD_EXTERNAL_STATUS0_PLL_TX is %d\n", + pr_err("SD_EXTERNAL_STATUS0_PLL_RX is %d, SD_EXTERNAL_STATUS0_PLL_TX is %d\n", (data & SD_EXTERNAL_STATUS0_PLL_RX_MASK), (data & SD_EXTERNAL_STATUS0_PLL_TX_MASK)); ret = 0; @@ -1418,7 +1418,7 @@ static int comphy_sfi_power_up(u32 lane, void __iomem *hpipe_base, if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", sd_ip_addr + SD_EXTERNAL_STATUS0_REG, data); - error("SD_EXTERNAL_STATUS0_RX_INIT is 0\n"); + pr_err("SD_EXTERNAL_STATUS0_RX_INIT is 0\n"); ret = 0; }
@@ -1577,7 +1577,7 @@ static int comphy_rxauii_power_up(u32 lane, void __iomem *hpipe_base, if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", sd_ip_addr + SD_EXTERNAL_STATUS0_REG, data); - error("SD_EXTERNAL_STATUS0_PLL_RX is %d, SD_EXTERNAL_STATUS0_PLL_TX is %d\n", + pr_err("SD_EXTERNAL_STATUS0_PLL_RX is %d, SD_EXTERNAL_STATUS0_PLL_TX is %d\n", (data & SD_EXTERNAL_STATUS0_PLL_RX_MASK), (data & SD_EXTERNAL_STATUS0_PLL_TX_MASK)); ret = 0; @@ -1596,7 +1596,7 @@ static int comphy_rxauii_power_up(u32 lane, void __iomem *hpipe_base, if (data != 0) { debug("Read from reg = %p - value = 0x%x\n", sd_ip_addr + SD_EXTERNAL_STATUS0_REG, data); - error("SD_EXTERNAL_STATUS0_RX_INIT is 0\n"); + pr_err("SD_EXTERNAL_STATUS0_RX_INIT is 0\n"); ret = 0; }
@@ -1742,7 +1742,7 @@ static int comphy_utmi_power_up(u32 utmi_index, void __iomem *utmi_base_addr, mask = data; data = polling_with_timeout(addr, data, mask, 100); if (data != 0) { - error("Impedance calibration is not done\n"); + pr_err("Impedance calibration is not done\n"); debug("Read from reg = %p - value = 0x%x\n", addr, data); ret = 0; } @@ -1751,7 +1751,7 @@ static int comphy_utmi_power_up(u32 utmi_index, void __iomem *utmi_base_addr, mask = data; data = polling_with_timeout(addr, data, mask, 100); if (data != 0) { - error("PLL calibration is not done\n"); + pr_err("PLL calibration is not done\n"); debug("Read from reg = %p - value = 0x%x\n", addr, data); ret = 0; } @@ -1761,7 +1761,7 @@ static int comphy_utmi_power_up(u32 utmi_index, void __iomem *utmi_base_addr, mask = data; data = polling_with_timeout(addr, data, mask, 100); if (data != 0) { - error("PLL is not ready\n"); + pr_err("PLL is not ready\n"); debug("Read from reg = %p - value = 0x%x\n", addr, data); ret = 0; } @@ -1818,7 +1818,7 @@ static void comphy_utmi_phy_init(u32 utmi_phy_count, cp110_utmi_data[i].usb_cfg_addr, cp110_utmi_data[i].utmi_cfg_addr, cp110_utmi_data[i].utmi_phy_port)) { - error("Failed to initialize UTMI PHY %d\n", i); + pr_err("Failed to initialize UTMI PHY %d\n", i); continue; } printf("UTMI PHY %d initialized to ", i); @@ -1864,7 +1864,7 @@ void comphy_dedicated_phys_init(void) (void __iomem *)fdtdec_get_addr_size_auto_noparent( gd->fdt_blob, node, "reg", 0, NULL, true); if (cp110_utmi_data[i].utmi_base_addr == NULL) { - error("UTMI PHY base address is invalid\n"); + pr_err("UTMI PHY base address is invalid\n"); i++; continue; } @@ -1874,7 +1874,7 @@ void comphy_dedicated_phys_init(void) (void __iomem *)fdtdec_get_addr_size_auto_noparent( gd->fdt_blob, node, "reg", 1, NULL, true); if (cp110_utmi_data[i].usb_cfg_addr == NULL) { - error("UTMI PHY base address is invalid\n"); + pr_err("UTMI PHY base address is invalid\n"); i++; continue; } @@ -1884,7 +1884,7 @@ void comphy_dedicated_phys_init(void) (void __iomem *)fdtdec_get_addr_size_auto_noparent( gd->fdt_blob, node, "reg", 2, NULL, true); if (cp110_utmi_data[i].utmi_cfg_addr == NULL) { - error("UTMI PHY base address is invalid\n"); + pr_err("UTMI PHY base address is invalid\n"); i++; continue; } @@ -1896,7 +1896,7 @@ void comphy_dedicated_phys_init(void) cp110_utmi_data[i].utmi_phy_port = fdtdec_get_int( gd->fdt_blob, node, "utmi-port", UTMI_PHY_INVALID); if (cp110_utmi_data[i].utmi_phy_port == UTMI_PHY_INVALID) { - error("UTMI PHY port type is invalid\n"); + pr_err("UTMI PHY port type is invalid\n"); i++; continue; } @@ -2049,7 +2049,7 @@ int comphy_cp110_init(struct chip_serdes_phy_config *ptr_chip_cfg, * PHY_TYPE_UNCONNECTED state. */ ptr_comphy_map->type = PHY_TYPE_UNCONNECTED; - error("PLL is not locked - Failed to initialize lane %d\n", + pr_err("PLL is not locked - Failed to initialize lane %d\n", lane); } } diff --git a/drivers/phy/ti-pipe3-phy.c b/drivers/phy/ti-pipe3-phy.c index 680e32f..babf2ff 100644 --- a/drivers/phy/ti-pipe3-phy.c +++ b/drivers/phy/ti-pipe3-phy.c @@ -261,7 +261,7 @@ static int pipe3_exit(struct phy *phy) } while (--timeout);
if (!(val & PLL_TICOPWDN) || !(val & PLL_LDOPWDN)) { - error("%s: Failed to power down DPLL: PLL_STATUS 0x%x\n", + pr_err("%s: Failed to power down DPLL: PLL_STATUS 0x%x\n", __func__, val); return -EBUSY; } @@ -284,14 +284,14 @@ static void *get_reg(struct udevice *dev, const char *name) err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, name, &syscon); if (err) { - error("unable to find syscon device for %s (%d)\n", + pr_err("unable to find syscon device for %s (%d)\n", name, err); return NULL; }
regmap = syscon_get_regmap(syscon); if (IS_ERR(regmap)) { - error("unable to find regmap for %s (%ld)\n", + pr_err("unable to find regmap for %s (%ld)\n", name, PTR_ERR(regmap)); return NULL; } @@ -299,7 +299,7 @@ static void *get_reg(struct udevice *dev, const char *name) cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), name, &len); if (len < 2*sizeof(fdt32_t)) { - error("offset not available for %s\n", name); + pr_err("offset not available for %s\n", name); return NULL; }
@@ -318,13 +318,13 @@ static int pipe3_phy_probe(struct udevice *dev)
addr = devfdt_get_addr_size_index(dev, 2, &sz); if (addr == FDT_ADDR_T_NONE) { - error("missing pll ctrl address\n"); + pr_err("missing pll ctrl address\n"); return -EINVAL; }
pipe3->pll_ctrl_base = map_physmem(addr, sz, MAP_NOCACHE); if (!pipe3->pll_ctrl_base) { - error("unable to remap pll ctrl\n"); + pr_err("unable to remap pll ctrl\n"); return -EINVAL; }
diff --git a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c index 27165b0..2bf853e 100644 --- a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c +++ b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c @@ -578,7 +578,7 @@ int armada_37xx_pinctrl_probe(struct udevice *dev)
info->base = (void __iomem *)devfdt_get_addr(dev); if (!info->base) { - error("unable to find regmap\n"); + pr_err("unable to find regmap\n"); return -ENODEV; }
diff --git a/drivers/pinctrl/pinctrl-sti.c b/drivers/pinctrl/pinctrl-sti.c index 40341b4..735e412 100644 --- a/drivers/pinctrl/pinctrl-sti.c +++ b/drivers/pinctrl/pinctrl-sti.c @@ -142,7 +142,7 @@ void sti_pin_configure(struct udevice *dev, struct sti_pin_desc *pin_desc) break;
default: - error("%s invalid direction value: 0x%x\n", + pr_err("%s invalid direction value: 0x%x\n", __func__, pin_desc->dir); BUG(); break; @@ -237,14 +237,14 @@ static int sti_pinctrl_set_state(struct udevice *dev, struct udevice *config) prop_name, "#gpio-cells", 0, 0, &args); if (ret < 0) { - error("Can't get the gpio bank phandle: %d\n", ret); + pr_err("Can't get the gpio bank phandle: %d\n", ret); return ret; }
bank_name = fdt_getprop(blob, args.node, "st,bank-name", &count); if (count < 0) { - error("Can't find bank-name property %d\n", count); + pr_err("Can't find bank-name property %d\n", count); return -EINVAL; }
@@ -254,12 +254,12 @@ static int sti_pinctrl_set_state(struct udevice *dev, struct udevice *config) prop_name, cells, ARRAY_SIZE(cells)); if (count < 0) { - error("Bad pin configuration array %d\n", count); + pr_err("Bad pin configuration array %d\n", count); return -EINVAL; }
if (count > MAX_STI_PINCONF_ENTRIES) { - error("Unsupported pinconf array count %d\n", count); + pr_err("Unsupported pinconf array count %d\n", count); return -EINVAL; }
@@ -284,13 +284,13 @@ static int sti_pinctrl_probe(struct udevice *dev) err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, "st,syscfg", &syscon); if (err) { - error("unable to find syscon device\n"); + pr_err("unable to find syscon device\n"); return err; }
plat->regmap = syscon_get_regmap(syscon); if (!plat->regmap) { - error("unable to find regmap\n"); + pr_err("unable to find regmap\n"); return -ENODEV; }
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index fb2593c..62ba0890 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -160,7 +160,7 @@ static int stm32_pinctrl_set_state_simple(struct udevice *dev,
config_node = fdt_node_offset_by_phandle(fdt, phandle); if (config_node < 0) { - error("prop pinctrl-0 index %d invalid phandle\n", i); + pr_err("prop pinctrl-0 index %d invalid phandle\n", i); return -EINVAL; }
diff --git a/drivers/power/pmic/as3722.c b/drivers/power/pmic/as3722.c index 4efe8ee..3b0427e 100644 --- a/drivers/power/pmic/as3722.c +++ b/drivers/power/pmic/as3722.c @@ -46,14 +46,14 @@ static int as3722_read_id(struct udevice *dev, uint *idp, uint *revisionp)
ret = pmic_reg_read(dev, AS3722_ASIC_ID1); if (ret < 0) { - error("failed to read ID1 register: %d", ret); + pr_err("failed to read ID1 register: %d", ret); return ret; } *idp = ret;
ret = pmic_reg_read(dev, AS3722_ASIC_ID2); if (ret < 0) { - error("failed to read ID2 register: %d", ret); + pr_err("failed to read ID2 register: %d", ret); return ret; } *revisionp = ret; @@ -71,7 +71,7 @@ int as3722_sd_set_voltage(struct udevice *dev, unsigned int sd, u8 value)
ret = pmic_reg_write(dev, AS3722_SD_VOLTAGE(sd), value); if (ret < 0) { - error("failed to write SD%u voltage register: %d", sd, ret); + pr_err("failed to write SD%u voltage register: %d", sd, ret); return ret; }
@@ -87,7 +87,7 @@ int as3722_ldo_set_voltage(struct udevice *dev, unsigned int ldo, u8 value)
ret = pmic_reg_write(dev, AS3722_LDO_VOLTAGE(ldo), value); if (ret < 0) { - error("failed to write LDO%u voltage register: %d", ldo, + pr_err("failed to write LDO%u voltage register: %d", ldo, ret); return ret; } @@ -102,12 +102,12 @@ static int as3722_probe(struct udevice *dev)
ret = as3722_read_id(dev, &id, &revision); if (ret < 0) { - error("failed to read ID: %d", ret); + pr_err("failed to read ID: %d", ret); return ret; }
if (id != AS3722_DEVICE_ID) { - error("unknown device"); + pr_err("unknown device"); return -ENOENT; }
diff --git a/drivers/power/pmic/as3722_gpio.c b/drivers/power/pmic/as3722_gpio.c index d0b681c..5cf4cb6 100644 --- a/drivers/power/pmic/as3722_gpio.c +++ b/drivers/power/pmic/as3722_gpio.c @@ -26,7 +26,7 @@ int as3722_gpio_configure(struct udevice *pmic, unsigned int gpio,
err = pmic_reg_write(pmic, AS3722_GPIO_CONTROL(gpio), value); if (err) { - error("failed to configure GPIO#%u: %d", gpio, err); + pr_err("failed to configure GPIO#%u: %d", gpio, err); return err; }
@@ -46,7 +46,7 @@ static int as3722_gpio_set_value(struct udevice *dev, unsigned int gpio,
err = pmic_reg_read(pmic, AS3722_GPIO_SIGNAL_OUT); if (err < 0) { - error("failed to read GPIO signal out register: %d", err); + pr_err("failed to read GPIO signal out register: %d", err); return err; } value = err; @@ -61,7 +61,7 @@ static int as3722_gpio_set_value(struct udevice *dev, unsigned int gpio,
err = pmic_reg_write(pmic, AS3722_GPIO_SIGNAL_OUT, value); if (err) { - error("failed to set GPIO#%u %s: %d", gpio, l, err); + pr_err("failed to set GPIO#%u %s: %d", gpio, l, err); return err; }
@@ -84,13 +84,13 @@ int as3722_gpio_direction_output(struct udevice *dev, unsigned int gpio,
err = pmic_reg_write(pmic, AS3722_GPIO_CONTROL(gpio), value); if (err) { - error("failed to configure GPIO#%u as output: %d", gpio, err); + pr_err("failed to configure GPIO#%u as output: %d", gpio, err); return err; }
err = as3722_gpio_set_value(pmic, gpio, value); if (err < 0) { - error("failed to set GPIO#%u high: %d", gpio, err); + pr_err("failed to set GPIO#%u high: %d", gpio, err); return err; }
diff --git a/drivers/power/pmic/i2c_pmic_emul.c b/drivers/power/pmic/i2c_pmic_emul.c index 2d35d09..38a2a04 100644 --- a/drivers/power/pmic/i2c_pmic_emul.c +++ b/drivers/power/pmic/i2c_pmic_emul.c @@ -31,7 +31,7 @@ static int sandbox_i2c_pmic_read_data(struct udevice *emul, uchar chip, struct sandbox_i2c_pmic_plat_data *plat = dev_get_platdata(emul);
if (plat->rw_reg + len > SANDBOX_PMIC_REG_COUNT) { - error("Request exceeds PMIC register range! Max register: %#x", + pr_err("Request exceeds PMIC register range! Max register: %#x", SANDBOX_PMIC_REG_COUNT); return -EFAULT; } @@ -68,7 +68,7 @@ static int sandbox_i2c_pmic_write_data(struct udevice *emul, uchar chip, len--;
if (plat->rw_reg + len > SANDBOX_PMIC_REG_COUNT) { - error("Request exceeds PMIC register range! Max register: %#x", + pr_err("Request exceeds PMIC register range! Max register: %#x", SANDBOX_PMIC_REG_COUNT); }
@@ -111,7 +111,7 @@ static int sandbox_i2c_pmic_ofdata_to_platdata(struct udevice *emul) SANDBOX_PMIC_REG_COUNT);
if (!reg_defaults) { - error("Property "reg-defaults" not found for device: %s!", + pr_err("Property "reg-defaults" not found for device: %s!", emul->name); return -EINVAL; } diff --git a/drivers/power/pmic/lp873x.c b/drivers/power/pmic/lp873x.c index f505468..95c2b7e 100644 --- a/drivers/power/pmic/lp873x.c +++ b/drivers/power/pmic/lp873x.c @@ -27,7 +27,7 @@ static int lp873x_write(struct udevice *dev, uint reg, const uint8_t *buff, int len) { if (dm_i2c_write(dev, reg, buff, len)) { - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg); return -EIO; }
@@ -37,7 +37,7 @@ static int lp873x_write(struct udevice *dev, uint reg, const uint8_t *buff, static int lp873x_read(struct udevice *dev, uint reg, uint8_t *buff, int len) { if (dm_i2c_read(dev, reg, buff, len)) { - error("read error from device: %p register: %#x!", dev, reg); + pr_err("read error from device: %p register: %#x!", dev, reg); return -EIO; }
diff --git a/drivers/power/pmic/lp87565.c b/drivers/power/pmic/lp87565.c index 782a46c..506769e 100644 --- a/drivers/power/pmic/lp87565.c +++ b/drivers/power/pmic/lp87565.c @@ -29,7 +29,7 @@ static int lp87565_write(struct udevice *dev, uint reg, const uint8_t *buff,
ret = dm_i2c_write(dev, reg, buff, len); if (ret) - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg);
return ret; } @@ -40,7 +40,7 @@ static int lp87565_read(struct udevice *dev, uint reg, uint8_t *buff, int len)
ret = dm_i2c_read(dev, reg, buff, len); if (ret) - error("read error from device: %p register: %#x!", dev, reg); + pr_err("read error from device: %p register: %#x!", dev, reg);
return ret; } diff --git a/drivers/power/pmic/max77686.c b/drivers/power/pmic/max77686.c index ceca9f9..b3ed849 100644 --- a/drivers/power/pmic/max77686.c +++ b/drivers/power/pmic/max77686.c @@ -31,7 +31,7 @@ static int max77686_write(struct udevice *dev, uint reg, const uint8_t *buff, int len) { if (dm_i2c_write(dev, reg, buff, len)) { - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg); return -EIO; }
@@ -41,7 +41,7 @@ static int max77686_write(struct udevice *dev, uint reg, const uint8_t *buff, static int max77686_read(struct udevice *dev, uint reg, uint8_t *buff, int len) { if (dm_i2c_read(dev, reg, buff, len)) { - error("read error from device: %p register: %#x!", dev, reg); + pr_err("read error from device: %p register: %#x!", dev, reg); return -EIO; }
diff --git a/drivers/power/pmic/max8997.c b/drivers/power/pmic/max8997.c index f749d7d..5ebeb8a 100644 --- a/drivers/power/pmic/max8997.c +++ b/drivers/power/pmic/max8997.c @@ -26,7 +26,7 @@ static int max8997_write(struct udevice *dev, uint reg, const uint8_t *buff,
return ret; } @@ -37,7 +37,7 @@ static int max8997_read(struct udevice *dev, uint reg, uint8_t *buff, int len)
return ret; } diff --git a/drivers/power/pmic/max8998.c b/drivers/power/pmic/max8998.c index 7c4773c..a7e0469 100644 --- a/drivers/power/pmic/max8998.c +++ b/drivers/power/pmic/max8998.c @@ -26,7 +26,7 @@ static int max8998_write(struct udevice *dev, uint reg, const uint8_t *buff,
return ret; } @@ -37,7 +37,7 @@ static int max8998_read(struct udevice *dev, uint reg, uint8_t *buff, int len)
return ret; } diff --git a/drivers/power/pmic/palmas.c b/drivers/power/pmic/palmas.c index 804c0d1..1e1ecb3 100644 --- a/drivers/power/pmic/palmas.c +++ b/drivers/power/pmic/palmas.c @@ -27,7 +27,7 @@ static int palmas_write(struct udevice *dev, uint reg, const uint8_t *buff, int len) { if (dm_i2c_write(dev, reg, buff, len)) { - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg); return -EIO; }
@@ -37,7 +37,7 @@ static int palmas_write(struct udevice *dev, uint reg, const uint8_t *buff, static int palmas_read(struct udevice *dev, uint reg, uint8_t *buff, int len) { if (dm_i2c_read(dev, reg, buff, len)) { - error("read error from device: %p register: %#x!", dev, reg); + pr_err("read error from device: %p register: %#x!", dev, reg); return -EIO; }
diff --git a/drivers/power/pmic/pfuze100.c b/drivers/power/pmic/pfuze100.c index 5f361c7..a06cbc0 100644 --- a/drivers/power/pmic/pfuze100.c +++ b/drivers/power/pmic/pfuze100.c @@ -33,7 +33,7 @@ static int pfuze100_write(struct udevice *dev, uint reg, const uint8_t *buff, int len) { if (dm_i2c_write(dev, reg, buff, len)) { - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg); return -EIO; }
@@ -43,7 +43,7 @@ static int pfuze100_write(struct udevice *dev, uint reg, const uint8_t *buff, static int pfuze100_read(struct udevice *dev, uint reg, uint8_t *buff, int len) { if (dm_i2c_read(dev, reg, buff, len)) { - error("read error from device: %p register: %#x!", dev, reg); + pr_err("read error from device: %p register: %#x!", dev, reg); return -EIO; }
diff --git a/drivers/power/pmic/s2mps11.c b/drivers/power/pmic/s2mps11.c index 9d83059..522105e 100644 --- a/drivers/power/pmic/s2mps11.c +++ b/drivers/power/pmic/s2mps11.c @@ -27,7 +27,7 @@ static int s2mps11_write(struct udevice *dev, uint reg, const uint8_t *buff,
return ret; } @@ -38,7 +38,7 @@ static int s2mps11_read(struct udevice *dev, uint reg, uint8_t *buff, int len)
return ret; } diff --git a/drivers/power/pmic/s5m8767.c b/drivers/power/pmic/s5m8767.c index f8ae5ea..3812e24 100644 --- a/drivers/power/pmic/s5m8767.c +++ b/drivers/power/pmic/s5m8767.c @@ -30,7 +30,7 @@ static int s5m8767_write(struct udevice *dev, uint reg, const uint8_t *buff, int len) { if (dm_i2c_write(dev, reg, buff, len)) { - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg); return -EIO; }
@@ -40,7 +40,7 @@ static int s5m8767_write(struct udevice *dev, uint reg, const uint8_t *buff, static int s5m8767_read(struct udevice *dev, uint reg, uint8_t *buff, int len) { if (dm_i2c_read(dev, reg, buff, len)) { - error("read error from device: %p register: %#x!", dev, reg); + pr_err("read error from device: %p register: %#x!", dev, reg); return -EIO; }
diff --git a/drivers/power/pmic/sandbox.c b/drivers/power/pmic/sandbox.c index 6763303..e8d6fac 100644 --- a/drivers/power/pmic/sandbox.c +++ b/drivers/power/pmic/sandbox.c @@ -31,7 +31,7 @@ static int sandbox_pmic_write(struct udevice *dev, uint reg, const uint8_t *buff, int len) { if (dm_i2c_write(dev, reg, buff, len)) { - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg); return -EIO; }
@@ -42,7 +42,7 @@ static int sandbox_pmic_read(struct udevice *dev, uint reg, uint8_t *buff, int len) { if (dm_i2c_read(dev, reg, buff, len)) { - error("read error from device: %p register: %#x!", dev, reg); + pr_err("read error from device: %p register: %#x!", dev, reg); return -EIO; }
@@ -52,7 +52,7 @@ static int sandbox_pmic_read(struct udevice *dev, uint reg, static int sandbox_pmic_bind(struct udevice *dev) { if (!pmic_bind_children(dev, dev_ofnode(dev), pmic_children_info)) - error("%s:%d PMIC: %s - no child found!", __func__, __LINE__, + pr_err("%s:%d PMIC: %s - no child found!", __func__, __LINE__, dev->name);
/* Always return success for this device - allows for PMIC I/O */ diff --git a/drivers/power/pmic/tps65090.c b/drivers/power/pmic/tps65090.c index 4565e3b..ee5358b 100644 --- a/drivers/power/pmic/tps65090.c +++ b/drivers/power/pmic/tps65090.c @@ -29,7 +29,7 @@ static int tps65090_write(struct udevice *dev, uint reg, const uint8_t *buff, int len) { if (dm_i2c_write(dev, reg, buff, len)) { - error("write error to device: %p register: %#x!", dev, reg); + pr_err("write error to device: %p register: %#x!", dev, reg); return -EIO; }
@@ -42,7 +42,7 @@ static int tps65090_read(struct udevice *dev, uint reg, uint8_t *buff, int len)
ret = dm_i2c_read(dev, reg, buff, len); if (ret) { - error("read error %d from device: %p register: %#x!", ret, dev, + pr_err("read error %d from device: %p register: %#x!", ret, dev, reg); return -EIO; } diff --git a/drivers/power/regulator/fixed.c b/drivers/power/regulator/fixed.c index 35c2922..97b4a98 100644 --- a/drivers/power/regulator/fixed.c +++ b/drivers/power/regulator/fixed.c @@ -117,7 +117,7 @@ static int fixed_regulator_set_enable(struct udevice *dev, bool enable)
ret = dm_gpio_set_value(&dev_pdata->gpio, enable); if (ret) { - error("Can't set regulator : %s gpio to: %d\n", dev->name, + pr_err("Can't set regulator : %s gpio to: %d\n", dev->name, enable); return ret; } diff --git a/drivers/power/regulator/gpio-regulator.c b/drivers/power/regulator/gpio-regulator.c index 42391c6..1031a03 100644 --- a/drivers/power/regulator/gpio-regulator.c +++ b/drivers/power/regulator/gpio-regulator.c @@ -109,7 +109,7 @@ static int gpio_regulator_set_value(struct udevice *dev, int uV)
ret = dm_gpio_set_value(&dev_pdata->gpio, enable); if (ret) { - error("Can't set regulator : %s gpio to: %d\n", dev->name, + pr_err("Can't set regulator : %s gpio to: %d\n", dev->name, enable); return ret; } diff --git a/drivers/power/regulator/max77686.c b/drivers/power/regulator/max77686.c index 8780806..2212d36 100644 --- a/drivers/power/regulator/max77686.c +++ b/drivers/power/regulator/max77686.c @@ -98,7 +98,7 @@ static int max77686_buck_volt2hex(int buck, int uV) if (hex >= 0 && hex <= hex_max) return hex;
- error("Value: %d uV is wrong for BUCK%d", uV, buck); + pr_err("Value: %d uV is wrong for BUCK%d", uV, buck); return -EINVAL; }
@@ -134,7 +134,7 @@ static int max77686_buck_hex2volt(int buck, int hex) return uV;
bad_hex: - error("Value: %#x is wrong for BUCK%d", hex, buck); + pr_err("Value: %#x is wrong for BUCK%d", hex, buck); return -EINVAL; }
@@ -160,7 +160,7 @@ static int max77686_ldo_volt2hex(int ldo, int uV) if (hex >= 0 && hex <= MAX77686_LDO_VOLT_MAX_HEX) return hex;
- error("Value: %d uV is wrong for LDO%d", uV, ldo); + pr_err("Value: %d uV is wrong for LDO%d", uV, ldo); return -EINVAL; }
@@ -189,7 +189,7 @@ static int max77686_ldo_hex2volt(int ldo, int hex) return uV;
bad_hex: - error("Value: %#x is wrong for ldo%d", hex, ldo); + pr_err("Value: %#x is wrong for ldo%d", hex, ldo); return -EINVAL; }
@@ -328,7 +328,7 @@ static int max77686_ldo_val(struct udevice *dev, int op, int *uV)
ldo = dev->driver_data; if (ldo < 1 || ldo > MAX77686_LDO_NUM) { - error("Wrong ldo number: %d", ldo); + pr_err("Wrong ldo number: %d", ldo); return -EINVAL; }
@@ -366,7 +366,7 @@ static int max77686_buck_val(struct udevice *dev, int op, int *uV)
buck = dev->driver_data; if (buck < 1 || buck > MAX77686_BUCK_NUM) { - error("Wrong buck number: %d", buck); + pr_err("Wrong buck number: %d", buck); return -EINVAL; }
@@ -423,7 +423,7 @@ static int max77686_ldo_mode(struct udevice *dev, int op, int *opmode)
@@ -493,7 +493,7 @@ static int max77686_ldo_mode(struct udevice *dev, int op, int *opmode) }
if (mode == 0xff) { - error("Wrong mode: %d for ldo%d", *opmode, ldo); + pr_err("Wrong mode: %d for ldo%d", *opmode, ldo); return -EINVAL; }
@@ -545,7 +545,7 @@ static int max77686_buck_mode(struct udevice *dev, int op, int *opmode)
@@ -614,7 +614,7 @@ static int max77686_buck_mode(struct udevice *dev, int op, int *opmode) }
if (mode == 0xff) { - error("Wrong mode: %d for buck: %d\n", *opmode, buck); + pr_err("Wrong mode: %d for buck: %d\n", *opmode, buck); return -EINVAL; }
diff --git a/drivers/power/regulator/sandbox.c b/drivers/power/regulator/sandbox.c index 06c09fd..f980a17 100644 --- a/drivers/power/regulator/sandbox.c +++ b/drivers/power/regulator/sandbox.c @@ -87,7 +87,7 @@ int out_get_value(struct udevice *dev, int output_count, int reg_type, int ret;
if (dev->driver_data > output_count) { - error("Unknown regulator number: %lu for PMIC %s!", + pr_err("Unknown regulator number: %lu for PMIC %s!", dev->driver_data, dev->name); return -EINVAL; } @@ -95,7 +95,7 @@ int out_get_value(struct udevice *dev, int output_count, int reg_type, reg = (dev->driver_data - 1) * OUT_REG_COUNT + reg_type; ret = pmic_read(dev->parent, reg, ®_val, 1); if (ret) { - error("PMIC read failed: %d\n", ret); + pr_err("PMIC read failed: %d\n", ret); return ret; }
@@ -115,14 +115,14 @@ static int out_set_value(struct udevice *dev, int output_count, int reg_type, int max_value;
max_value = range[dev->driver_data - 1].max; if (value > max_value) { - error("Wrong value for %s: %lu. Max is: %d.", + pr_err("Wrong value for %s: %lu. Max is: %d.", dev->name, dev->driver_data, max_value); return -EINVAL; } @@ -134,7 +134,7 @@ static int out_set_value(struct udevice *dev, int output_count, int reg_type, reg = (dev->driver_data - 1) * OUT_REG_COUNT + reg_type; ret = pmic_write(dev->parent, reg, ®_val, 1); if (ret) { - error("PMIC write failed: %d\n", ret); + pr_err("PMIC write failed: %d\n", ret); return ret; }
@@ -154,7 +154,7 @@ static int out_get_mode(struct udevice *dev) reg = (dev->driver_data - 1) * OUT_REG_COUNT + OUT_REG_OM; ret = pmic_read(dev->parent, reg, ®_val, 1); if (ret) { - error("PMIC read failed: %d\n", ret); + pr_err("PMIC read failed: %d\n", ret); return ret; }
@@ -163,7 +163,7 @@ static int out_get_mode(struct udevice *dev) return uc_pdata->mode[i].id; }
- error("Unknown operation mode for %s!", dev->name); + pr_err("Unknown operation mode for %s!", dev->name); return -EINVAL; }
@@ -188,14 +188,14 @@ static int out_set_mode(struct udevice *dev, int mode) }
if (reg_val == -1) { - error("Unknown operation mode for %s!", dev->name); + pr_err("Unknown operation mode for %s!", dev->name); return -EINVAL; }
reg = (dev->driver_data - 1) * OUT_REG_COUNT + OUT_REG_OM; ret = pmic_write(dev->parent, reg, (uint8_t *)®_val, 1); if (ret) { - error("PMIC write failed: %d\n", ret); + pr_err("PMIC write failed: %d\n", ret); return ret; }
diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c index ca7b1ff..975c812 100644 --- a/drivers/ram/rockchip/dmc-rk3368.c +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -230,7 +230,7 @@ static int memory_init(struct rk3368_ddr_pctl *pctl, tmp = get_timer(0); do { if (get_timer(tmp) > timeout_ms) { - error("%s: POWER_UP_START did not complete in %ld ms\n", + pr_err("%s: POWER_UP_START did not complete in %ld ms\n", __func__, timeout_ms); return -ETIME; } @@ -422,7 +422,7 @@ static int dfi_cfg(struct rk3368_ddr_pctl *pctl) tmp = get_timer(0); do { if (get_timer(tmp) > timeout_ms) { - error("%s: DFI init did not complete within %ld ms\n", + pr_err("%s: DFI init did not complete within %ld ms\n", __func__, timeout_ms); return -ETIME; } @@ -457,7 +457,7 @@ static int pctl_calc_timings(struct rk3368_sdram_params *params, u32 tfaw_as_ps;
if (params->ddr_speed_bin != DDR3_1600K) { - error("%s: unimplemented DDR3 speed bin %d\n", + pr_err("%s: unimplemented DDR3 speed bin %d\n", __func__, params->ddr_speed_bin); return -1; } @@ -585,7 +585,7 @@ static int ddrphy_data_training(struct rk3368_ddr_pctl *pctl, tmp = get_timer(0); do { if (get_timer(tmp) > timeout_ms) { - error("%s: did not complete within %ld ms\n", + pr_err("%s: did not complete within %ld ms\n", __func__, timeout_ms); return -ETIME; } @@ -625,7 +625,7 @@ static int sdram_col_row_detect(struct udevice *dev) }
if (col == 8) { - error("%s: col detect error\n", __func__); + pr_err("%s: col detect error\n", __func__); return -EINVAL; }
@@ -644,7 +644,7 @@ static int sdram_col_row_detect(struct udevice *dev) }
if (row == 11) { - error("%s: row detect error\n", __func__); + pr_err("%s: row detect error\n", __func__); return -EINVAL; }
@@ -764,7 +764,7 @@ static int msch_niu_config(struct rk3368_msch *msch, } }
- error("%s: ddrconf (NIU config) not found\n", __func__); + pr_err("%s: ddrconf (NIU config) not found\n", __func__); return -EINVAL; }
diff --git a/drivers/ram/stm32_sdram.c b/drivers/ram/stm32_sdram.c index b1b0289..fdf088e 100644 --- a/drivers/ram/stm32_sdram.c +++ b/drivers/ram/stm32_sdram.c @@ -262,7 +262,7 @@ static int stm32_fmc_ofdata_to_platdata(struct udevice *dev) bank_name = (char *)ofnode_get_name(bank_node); strsep(&bank_name, "@"); if (!bank_name) { - error("missing sdram bank index"); + pr_err("missing sdram bank index"); return -EINVAL; }
@@ -271,7 +271,7 @@ static int stm32_fmc_ofdata_to_platdata(struct udevice *dev) (long unsigned int *)&bank_params->target_bank);
if (bank_params->target_bank >= MAX_SDRAM_BANK) { - error("Found bank %d , but only bank 0 and 1 are supported", + pr_err("Found bank %d , but only bank 0 and 1 are supported", bank_params->target_bank); return -EINVAL; } @@ -285,7 +285,7 @@ static int stm32_fmc_ofdata_to_platdata(struct udevice *dev) sizeof(struct stm32_sdram_control));
if (!params->bank_params[bank].sdram_control) { - error("st,sdram-control not found for %s", + pr_err("st,sdram-control not found for %s", ofnode_get_name(bank_node)); return -EINVAL; } @@ -298,7 +298,7 @@ static int stm32_fmc_ofdata_to_platdata(struct udevice *dev) sizeof(struct stm32_sdram_timing));
if (!params->bank_params[bank].sdram_timing) { - error("st,sdram-timing not found for %s", + pr_err("st,sdram-timing not found for %s", ofnode_get_name(bank_node)); return -EINVAL; } diff --git a/drivers/reset/sti-reset.c b/drivers/reset/sti-reset.c index a79708c..024b996 100644 --- a/drivers/reset/sti-reset.c +++ b/drivers/reset/sti-reset.c @@ -201,20 +201,20 @@ phys_addr_t sti_reset_get_regmap(const char *compatible) node = fdt_node_offset_by_compatible(gd->fdt_blob, -1, compatible); if (node < 0) { - error("unable to find %s node\n", compatible); + pr_err("unable to find %s node\n", compatible); return node; }
ret = uclass_get_device_by_of_offset(UCLASS_SYSCON, node, &syscon); if (ret) { - error("%s: uclass_get_device_by_of_offset failed: %d\n", + pr_err("%s: uclass_get_device_by_of_offset failed: %d\n", __func__, ret); return ret; }
regmap = syscon_get_regmap(syscon); if (!regmap) { - error("unable to get regmap for %s\n", syscon->name); + pr_err("unable to get regmap for %s\n", syscon->name); return -ENODEV; }
@@ -251,7 +251,7 @@ static int sti_reset_program_hw(struct reset_ctl *reset_ctl, int assert) if (ch->deassert_cnt > 0) return 0; } else - error("Reset balancing error: reset_ctl=%p dev=%p id=%lu\n", + pr_err("Reset balancing error: reset_ctl=%p dev=%p id=%lu\n", reset_ctl, reset_ctl->dev, reset_ctl->id); }
@@ -268,7 +268,7 @@ static int sti_reset_program_hw(struct reset_ctl *reset_ctl, int assert) reg = (void __iomem *)base + ch->ack_offset; if (wait_for_bit(__func__, reg, BIT(ch->ack_bit), ctrl_val, 1000, false)) { - error("Stuck on waiting ack reset_ctl=%p dev=%p id=%lu\n", + pr_err("Stuck on waiting ack reset_ctl=%p dev=%p id=%lu\n", reset_ctl, reset_ctl->dev, reset_ctl->id);
return -ETIMEDOUT; diff --git a/drivers/spi/atmel_spi.c b/drivers/spi/atmel_spi.c index e2f8342..228e714 100644 --- a/drivers/spi/atmel_spi.c +++ b/drivers/spi/atmel_spi.c @@ -474,7 +474,7 @@ static int atmel_spi_probe(struct udevice *bus) ret = gpio_request_list_by_name(bus, "cs-gpios", priv->cs_gpios, ARRAY_SIZE(priv->cs_gpios), 0); if (ret < 0) { - error("Can't get %s gpios! Error: %d", bus->name, ret); + pr_err("Can't get %s gpios! Error: %d", bus->name, ret); return ret; }
diff --git a/drivers/spi/lpc32xx_ssp.c b/drivers/spi/lpc32xx_ssp.c index c5b766c..e2a593b 100644 --- a/drivers/spi/lpc32xx_ssp.c +++ b/drivers/spi/lpc32xx_ssp.c @@ -66,17 +66,17 @@ struct spi_slave *spi_setup_slave(uint bus, uint cs, uint max_hz, uint mode) /* we only set up SSP0 for now, so ignore bus */
if (mode & SPI_3WIRE) { - error("3-wire mode not supported"); + pr_err("3-wire mode not supported"); return NULL; }
if (mode & SPI_SLAVE) { - error("slave mode not supported\n"); + pr_err("slave mode not supported\n"); return NULL; }
if (mode & SPI_PREAMBLE) { - error("preamble byte skipping not supported\n"); + pr_err("preamble byte skipping not supported\n"); return NULL; }
diff --git a/drivers/sysreset/sysreset_sti.c b/drivers/sysreset/sysreset_sti.c index 9b58aa8..bf698a7 100644 --- a/drivers/sysreset/sysreset_sti.c +++ b/drivers/sysreset/sysreset_sti.c @@ -39,7 +39,7 @@ static int sti_sysreset_probe(struct udevice *dev) "st,syscfg", NULL, 0, 0, &syscfg_phandle); if (ret < 0) { - error("Can't get syscfg phandle: %d\n", ret); + pr_err("Can't get syscfg phandle: %d\n", ret); return ret; }
@@ -47,14 +47,14 @@ static int sti_sysreset_probe(struct udevice *dev) syscfg_phandle.node, &syscon); if (ret) { - error("%s: uclass_get_device_by_of_offset failed: %d\n", + pr_err("%s: uclass_get_device_by_of_offset failed: %d\n", __func__, ret); return ret; }
diff --git a/drivers/sysreset/sysreset_syscon.c b/drivers/sysreset/sysreset_syscon.c index 3818fae..3abce7f 100644 --- a/drivers/sysreset/sysreset_syscon.c +++ b/drivers/sysreset/sysreset_syscon.c @@ -45,13 +45,13 @@ int syscon_reboot_probe(struct udevice *dev) err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, "regmap", &syscon); if (err) { - error("unable to find syscon device\n"); + pr_err("unable to find syscon device\n"); return err; }
priv->regmap = syscon_get_regmap(syscon); if (!priv->regmap) { - error("unable to find regmap\n"); + pr_err("unable to find regmap\n"); return -ENODEV; }
diff --git a/drivers/sysreset/sysreset_watchdog.c b/drivers/sysreset/sysreset_watchdog.c index 304ed05..ab250ae 100644 --- a/drivers/sysreset/sysreset_watchdog.c +++ b/drivers/sysreset/sysreset_watchdog.c @@ -38,7 +38,7 @@ int wdt_reboot_probe(struct udevice *dev) err = uclass_get_device_by_phandle(UCLASS_WDT, dev, "wdt", &priv->wdt); if (err) { - error("unable to find wdt device\n"); + pr_err("unable to find wdt device\n"); return err; }
diff --git a/drivers/tpm/tpm_tis_infineon.c b/drivers/tpm/tpm_tis_infineon.c index ef3ff0d..e3e20d8 100644 --- a/drivers/tpm/tpm_tis_infineon.c +++ b/drivers/tpm/tpm_tis_infineon.c @@ -539,7 +539,7 @@ static int tpm_tis_i2c_init(struct udevice *dev) }
if (chip->chip_type != UNKNOWN && vendor != expected_did_vid) { - error("Vendor id did not match! ID was %08x\n", vendor); + pr_err("Vendor id did not match! ID was %08x\n", vendor); return -ENODEV; }
diff --git a/drivers/usb/common/common.c b/drivers/usb/common/common.c index 35c2dc1..e8432bb 100644 --- a/drivers/usb/common/common.c +++ b/drivers/usb/common/common.c @@ -28,7 +28,7 @@ enum usb_dr_mode usb_get_dr_mode(int node)
dr_mode = fdt_getprop(fdt, node, "dr_mode", NULL); if (!dr_mode) { - error("usb dr_mode not found\n"); + pr_err("usb dr_mode not found\n"); return USB_DR_MODE_UNKNOWN; }
diff --git a/drivers/usb/eth/mcs7830.c b/drivers/usb/eth/mcs7830.c index 4abef5d..941d612 100644 --- a/drivers/usb/eth/mcs7830.c +++ b/drivers/usb/eth/mcs7830.c @@ -418,25 +418,25 @@ static int mcs7830_basic_reset(struct usb_device *udev,
rc = mcs7830_set_autoneg(udev); if (rc < 0) { - error("setting autoneg failed\n"); + pr_err("setting autoneg failed\n"); return rc; }
rc = mcs7830_write_mchash(udev, priv); if (rc < 0) { - error("failed to set multicast hash\n"); + pr_err("failed to set multicast hash\n"); return rc; }
rc = mcs7830_write_config(udev, priv); if (rc < 0) { - error("failed to set configuration\n"); + pr_err("failed to set configuration\n"); return rc; }
rc = mcs7830_apply_fixup(udev); if (rc < 0) { - error("fixup application failed\n"); + pr_err("fixup application failed\n"); return rc; }
@@ -541,11 +541,11 @@ static int mcs7830_recv_common(struct ueth_data *ueth, uint8_t *buf) debug("%s() RX want len %d, got len %d, rc %d\n", __func__, wantlen, gotlen, rc); if (rc != 0) { - error("RX: failed to receive\n"); + pr_err("RX: failed to receive\n"); return rc; } if (gotlen > wantlen) { - error("RX: got too many bytes (%d)\n", gotlen); + pr_err("RX: got too many bytes (%d)\n", gotlen); return -EIO; }
diff --git a/drivers/usb/gadget/at91_udc.c b/drivers/usb/gadget/at91_udc.c index 9df6d32..ad2f606 100644 --- a/drivers/usb/gadget/at91_udc.c +++ b/drivers/usb/gadget/at91_udc.c @@ -1456,7 +1456,7 @@ int usb_gadget_register_driver(struct usb_gadget_driver *driver)
ret = driver->bind(&udc->gadget); if (ret) { - error("driver->bind() returned %d\n", ret); + pr_err("driver->bind() returned %d\n", ret); udc->driver = NULL; }
@@ -1468,7 +1468,7 @@ int usb_gadget_unregister_driver(struct usb_gadget_driver *driver) struct at91_udc *udc = controller;
if (!driver || !driver->unbind || !driver->disconnect) { - error("bad paramter\n"); + pr_err("bad paramter\n"); return -EINVAL; }
diff --git a/drivers/usb/gadget/atmel_usba_udc.c b/drivers/usb/gadget/atmel_usba_udc.c index ad31703..c0a95a9 100644 --- a/drivers/usb/gadget/atmel_usba_udc.c +++ b/drivers/usb/gadget/atmel_usba_udc.c @@ -1228,7 +1228,7 @@ int usb_gadget_register_driver(struct usb_gadget_driver *driver)
@@ -1240,7 +1240,7 @@ int usb_gadget_unregister_driver(struct usb_gadget_driver *driver) struct usba_udc *udc = &controller;
@@ -1261,7 +1261,7 @@ static struct usba_ep *usba_udc_pdata(struct usba_platform_data *pdata,
eps = malloc(sizeof(struct usba_ep) * pdata->num_ep); if (!eps) { - error("failed to alloc eps\n"); + pr_err("failed to alloc eps\n"); return NULL; }
diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index cb44374..088811c 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -835,7 +835,7 @@ int dwc2_udc_probe(struct dwc2_plat_otg_data *pdata) ROUND(sizeof(struct usb_ctrlrequest), CONFIG_SYS_CACHELINE_SIZE)); if (!usb_ctrl) { - error("No memory available for UDC!\n"); + pr_err("No memory available for UDC!\n"); return -ENOMEM; }
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 2cf5c8d..2e0ff45 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -1059,7 +1059,7 @@ static int eth_set_config(struct eth_dev *dev, unsigned number, && dev->config && dev->tx_qlen != 0) { /* tx fifo is full, but we can't clear it...*/ - error("can't change configurations"); + pr_err("can't change configurations"); return -ESPIPE; } eth_reset_config(dev); @@ -1233,7 +1233,7 @@ static void rndis_command_complete(struct usb_ep *ep, struct usb_request *req) /* received RNDIS command from USB_CDC_SEND_ENCAPSULATED_COMMAND */ status = rndis_msg_parser(dev->rndis_config, (u8 *) req->buf); if (status < 0) - error("%s: rndis parse error %d", __func__, status); + pr_err("%s: rndis parse error %d", __func__, status); }
#endif /* RNDIS */ @@ -1554,7 +1554,7 @@ static int rx_submit(struct eth_dev *dev, struct usb_request *req, retval = usb_ep_queue(dev->out_ep, req, gfp_flags);
if (retval) - error("rx submit --> %d", retval); + pr_err("rx submit --> %d", retval);
return retval; } @@ -1624,7 +1624,7 @@ static int alloc_requests(struct eth_dev *dev, unsigned n, gfp_t gfp_flags) fail2: usb_ep_free_request(dev->in_ep, dev->tx_req); fail1: - error("can't alloc requests"); + pr_err("can't alloc requests"); return -1; }
@@ -2060,7 +2060,7 @@ static int eth_bind(struct usb_gadget *gadget) * anything less functional on CDC-capable hardware, * so we fail in this case. */ - error("controller '%s' not recognized", + pr_err("controller '%s' not recognized", gadget->name); return -ENODEV; } @@ -2121,7 +2121,7 @@ static int eth_bind(struct usb_gadget *gadget) in_ep = usb_ep_autoconfig(gadget, &fs_source_desc); if (!in_ep) { autoconf_fail: - error("can't autoconfigure on %s\n", + pr_err("can't autoconfigure on %s\n", gadget->name); return -ENODEV; } @@ -2142,7 +2142,7 @@ autoconf_fail: if (status_ep) { status_ep->driver_data = status_ep; /* claim */ } else if (rndis) { - error("can't run RNDIS on %s", gadget->name); + pr_err("can't run RNDIS on %s", gadget->name); return -ENODEV; #ifdef CONFIG_USB_ETH_CDC } else if (cdc) { @@ -2244,7 +2244,7 @@ autoconf_fail: if (rndis) { status = rndis_init(); if (status < 0) { - error("can't init RNDIS, %d", status); + pr_err("can't init RNDIS, %d", status); goto fail; } } @@ -2335,7 +2335,7 @@ fail0: return 0;
fail: - error("%s failed, status = %d", __func__, status); + pr_err("%s failed, status = %d", __func__, status); eth_unbind(gadget); return status; } @@ -2350,7 +2350,7 @@ int dm_usb_init(struct eth_dev *e_dev)
ret = uclass_first_device(UCLASS_USB_DEV_GENERIC, &dev); if (!dev || ret) { - error("No USB device found\n"); + pr_err("No USB device found\n"); return -ENODEV; }
@@ -2369,7 +2369,7 @@ static int _usb_eth_init(struct ether_priv *priv)
#ifdef CONFIG_DM_USB if (dm_usb_init(dev)) { - error("USB ether not found\n"); + pr_err("USB ether not found\n"); return -ENODEV; } #else @@ -2393,11 +2393,11 @@ static int _usb_eth_init(struct ether_priv *priv) sizeof(host_addr));
if (!is_eth_addr_valid(dev_addr)) { - error("Need valid 'usbnet_devaddr' to be set"); + pr_err("Need valid 'usbnet_devaddr' to be set"); goto fail; } if (!is_eth_addr_valid(host_addr)) { - error("Need valid 'usbnet_hostaddr' to be set"); + pr_err("Need valid 'usbnet_hostaddr' to be set"); goto fail; }
@@ -2427,7 +2427,7 @@ static int _usb_eth_init(struct ether_priv *priv) while (!dev->network_started) { /* Handle control-c and timeouts */ if (ctrlc() || (get_timer(ts) > timeout)) { - error("The remote end did not respond in time."); + pr_err("The remote end did not respond in time."); goto fail; } usb_gadget_handle_interrupts(0); @@ -2456,7 +2456,7 @@ static int _usb_eth_send(struct ether_priv *priv, void *packet, int length) rndis_pkt = malloc(length + sizeof(struct rndis_packet_msg_type)); if (!rndis_pkt) { - error("No memory to alloc RNDIS packet"); + pr_err("No memory to alloc RNDIS packet"); goto drop; } rndis_add_hdr(rndis_pkt, length); @@ -2574,7 +2574,7 @@ static int usb_eth_recv(struct eth_device *netdev)
ret = _usb_eth_recv(priv); if (ret) { - error("error packet receive\n"); + pr_err("error packet receive\n"); return ret; }
@@ -2585,7 +2585,7 @@ static int usb_eth_recv(struct eth_device *netdev) net_process_received_packet(net_rx_packets[0], dev->rx_req->length); } else { - error("dev->rx_req invalid"); + pr_err("dev->rx_req invalid"); } packet_received = 0; rx_submit(dev, dev->rx_req, 0); @@ -2641,7 +2641,7 @@ static int usb_eth_recv(struct udevice *dev, int flags, uchar **packetp)
@@ -2650,7 +2650,7 @@ static int usb_eth_recv(struct udevice *dev, int flags, uchar **packetp) *packetp = (uchar *)net_rx_packets[0]; return ethdev->rx_req->length; } else { - error("dev->rx_req invalid"); + pr_err("dev->rx_req invalid"); return -EFAULT; } } @@ -2706,13 +2706,13 @@ int usb_ether_init(void)
ret = uclass_first_device(UCLASS_USB_DEV_GENERIC, &usb_dev); if (!usb_dev || ret) { - error("No USB device found\n"); + pr_err("No USB device found\n"); return ret; }
ret = device_bind_driver(usb_dev, "usb_ether", "usb_ether", &dev); if (!dev || ret) { - error("usb - not able to bind usb_ether device\n"); + pr_err("usb - not able to bind usb_ether device\n"); return ret; }
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index f3382a9..7acffb6 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -410,7 +410,7 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req)
strsep(&cmd, ":"); if (!cmd) { - error("missing variable"); + pr_err("missing variable"); fastboot_tx_write_str("FAILmissing var"); return; } @@ -593,7 +593,7 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req)
strsep(&cmd, ":"); if (!cmd) { - error("missing partition name"); + pr_err("missing partition name"); fastboot_tx_write_str("FAILmissing partition name"); return; } @@ -645,7 +645,7 @@ static void cb_erase(struct usb_ep *ep, struct usb_request *req)
strsep(&cmd, ":"); if (!cmd) { - error("missing partition name"); + pr_err("missing partition name"); fastboot_tx_write_str("FAILmissing partition name"); return; } @@ -718,7 +718,7 @@ static void rx_handler_command(struct usb_ep *ep, struct usb_request *req) }
if (!func_cb) { - error("unknown command: %.*s", req->actual, cmdbuf); + pr_err("unknown command: %.*s", req->actual, cmdbuf); fastboot_tx_write_str("FAILunknown command"); } else { if (req->actual < req->length) { @@ -726,7 +726,7 @@ static void rx_handler_command(struct usb_ep *ep, struct usb_request *req) buf[req->actual] = 0; func_cb(ep, req); } else { - error("buffer overflow"); + pr_err("buffer overflow"); fastboot_tx_write_str("FAILbuffer overflow"); } } diff --git a/drivers/usb/gadget/f_sdp.c b/drivers/usb/gadget/f_sdp.c index 0fae66b..fd3da92 100644 --- a/drivers/usb/gadget/f_sdp.c +++ b/drivers/usb/gadget/f_sdp.c @@ -237,12 +237,12 @@ static void sdp_rx_command_complete(struct usb_ep *ep, struct usb_request *req) u8 report = data[0];
if (status != 0) { - error("Status: %d", status); + pr_err("Status: %d", status); return; }
if (report != 1) { - error("Unexpected report %d", report); + pr_err("Unexpected report %d", report); return; }
@@ -309,7 +309,7 @@ static void sdp_rx_command_complete(struct usb_ep *ep, struct usb_request *req) sdp->next_state = SDP_STATE_IDLE; break; default: - error("Unknown command: %04x\n", be16_to_cpu(cmd->cmd)); + pr_err("Unknown command: %04x\n", be16_to_cpu(cmd->cmd)); } }
@@ -322,12 +322,12 @@ static void sdp_rx_data_complete(struct usb_ep *ep, struct usb_request *req) int datalen = req->length - 1;
if (report != 2) { - error("Unexpected report %d", report); + pr_err("Unexpected report %d", report); return; }
@@ -360,7 +360,7 @@ static void sdp_rx_data_complete(struct usb_ep *ep, struct usb_request *req) sdp->state = SDP_STATE_TX_SEC_CONF; break; default: - error("Invalid state: %d", sdp->state); + pr_err("Invalid state: %d", sdp->state); } }
@@ -370,7 +370,7 @@ static void sdp_tx_complete(struct usb_ep *ep, struct usb_request *req) int status = req->status;
@@ -393,7 +393,7 @@ static void sdp_tx_complete(struct usb_ep *ep, struct usb_request *req) sdp->state = SDP_STATE_IDLE; break; default: - error("Wrong State: %d", sdp->state); + pr_err("Wrong State: %d", sdp->state); sdp->state = SDP_STATE_IDLE; break; } diff --git a/drivers/usb/gadget/f_thor.c b/drivers/usb/gadget/f_thor.c index cd4d9e6..18f233a 100644 --- a/drivers/usb/gadget/f_thor.c +++ b/drivers/usb/gadget/f_thor.c @@ -174,7 +174,7 @@ static long long int download_head(unsigned long long total, transfer_buffer, THOR_STORE_UNIT_SIZE, (*cnt)++); if (ret) { - error("DFU write failed [%d] cnt: %d", + pr_err("DFU write failed [%d] cnt: %d", ret, *cnt); return ret; } @@ -218,20 +218,20 @@ static int download_tail(long long int left, int cnt)
dfu_entity = dfu_get_entity(alt_setting_num); if (!dfu_entity) { - error("Alt setting: %d entity not found!\n", alt_setting_num); + pr_err("Alt setting: %d entity not found!\n", alt_setting_num); return -ENOENT; }
transfer_buffer = dfu_get_buf(dfu_entity); if (!transfer_buffer) { - error("Transfer buffer not allocated!"); + pr_err("Transfer buffer not allocated!"); return -ENXIO; }
if (left) { ret = dfu_write(dfu_entity, transfer_buffer, left, cnt++); if (ret) { - error("DFU write failed [%d]: left: %llu", ret, left); + pr_err("DFU write failed [%d]: left: %llu", ret, left); return ret; } } @@ -245,7 +245,7 @@ static int download_tail(long long int left, int cnt) */ ret = dfu_flush(dfu_entity, transfer_buffer, 0, cnt); if (ret) - error("DFU flush failed!"); + pr_err("DFU flush failed!");
return ret; } @@ -285,7 +285,7 @@ static long long int process_rqt_download(const struct rqt_box *rqt)
alt_setting_num = dfu_get_alt(f_name); if (alt_setting_num < 0) { - error("Alt setting [%d] to write not found!", + pr_err("Alt setting [%d] to write not found!", alt_setting_num); rsp->ack = -ENODEV; ret = rsp->ack; @@ -311,7 +311,7 @@ static long long int process_rqt_download(const struct rqt_box *rqt) debug("DL EXIT\n"); break; default: - error("Operation not supported: %d", rqt->rqt_data); + pr_err("Operation not supported: %d", rqt->rqt_data); ret = -ENOTSUPP; }
@@ -342,7 +342,7 @@ static int process_data(void) puts("RQT: UPLOAD not supported!\n"); break; default: - error("unknown request (%d)", rqt->rqt); + pr_err("unknown request (%d)", rqt->rqt); }
return ret; @@ -541,7 +541,7 @@ static int thor_rx_data(void)
status = usb_ep_queue(dev->out_ep, dev->out_req, 0); if (status) { - error("kill %s: resubmit %d bytes --> %d", + pr_err("kill %s: resubmit %d bytes --> %d", dev->out_ep->name, dev->out_req->length, status); usb_ep_set_halt(dev->out_ep); return -EAGAIN; @@ -575,7 +575,7 @@ static void thor_tx_data(unsigned char *data, int len)
status = usb_ep_queue(dev->in_ep, dev->in_req, 0); if (status) { - error("kill %s: resubmit %d bytes --> %d", + pr_err("kill %s: resubmit %d bytes --> %d", dev->in_ep->name, dev->in_req->length, status); usb_ep_set_halt(dev->in_ep); } @@ -608,7 +608,7 @@ static void thor_rx_tx_complete(struct usb_ep *ep, struct usb_request *req) case -ESHUTDOWN: /* disconnect from host */ case -EREMOTEIO: /* short read */ case -EOVERFLOW: - error("ERROR:%d", status); + pr_err("ERROR:%d", status); break; }
@@ -664,7 +664,7 @@ thor_func_setup(struct usb_function *f, const struct usb_ctrlrequest *ctrl) break;
default: - error("thor_setup: unknown request: %d", ctrl->bRequest); + pr_err("thor_setup: unknown request: %d", ctrl->bRequest); }
if (value >= 0) { @@ -973,7 +973,7 @@ static int thor_func_set_alt(struct usb_function *f, debug("Communication Data interface\n"); result = thor_eps_setup(f); if (result) - error("%s: EPs setup failed!", __func__); + pr_err("%s: EPs setup failed!", __func__); dev->configuration_done = 1; break; } diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 64c42ac..56406f2 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -179,7 +179,7 @@ static int dwc_vbus_supply_init(struct udevice *dev)
ret = regulator_set_enable(vbus_supply, true); if (ret) { - error("Error enabling vbus supply\n"); + pr_err("Error enabling vbus supply\n"); return ret; }
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 03f8d32..3947124 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -51,7 +51,7 @@ static int ehci_usb_probe(struct udevice *dev) break; err = clk_enable(&priv->clocks[i]); if (err) { - error("failed to enable clock %d\n", i); + pr_err("failed to enable clock %d\n", i); clk_free(&priv->clocks[i]); goto clk_err; } @@ -59,7 +59,7 @@ static int ehci_usb_probe(struct udevice *dev) } } else { if (clock_nb != -ENOENT) { - error("failed to get clock phandle(%d)\n", clock_nb); + pr_err("failed to get clock phandle(%d)\n", clock_nb); return clock_nb; } } @@ -80,7 +80,7 @@ static int ehci_usb_probe(struct udevice *dev) break;
if (reset_deassert(&priv->resets[i])) { - error("failed to deassert reset %d\n", i); + pr_err("failed to deassert reset %d\n", i); reset_free(&priv->resets[i]); goto reset_err; } @@ -88,7 +88,7 @@ static int ehci_usb_probe(struct udevice *dev) } } else { if (reset_nb != -ENOENT) { - error("failed to get reset phandle(%d)\n", reset_nb); + pr_err("failed to get reset phandle(%d)\n", reset_nb); goto clk_err; } } @@ -96,14 +96,14 @@ static int ehci_usb_probe(struct udevice *dev) err = generic_phy_get_by_index(dev, 0, &priv->phy); if (err) { if (err != -ENOENT) { - error("failed to get usb phy\n"); + pr_err("failed to get usb phy\n"); goto reset_err; } } else {
err = generic_phy_init(&priv->phy); if (err) { - error("failed to init usb phy\n"); + pr_err("failed to init usb phy\n"); goto reset_err; } } @@ -122,17 +122,17 @@ phy_err: if (generic_phy_valid(&priv->phy)) { ret = generic_phy_exit(&priv->phy); if (ret) - error("failed to release phy\n"); + pr_err("failed to release phy\n"); }
reset_err: ret = reset_release_all(priv->resets, priv->reset_count); if (ret) - error("failed to assert all resets\n"); + pr_err("failed to assert all resets\n"); clk_err: ret = clk_release_all(priv->clocks, priv->clock_count); if (ret) - error("failed to disable all clocks\n"); + pr_err("failed to disable all clocks\n");
return err; } diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index e22ee97..bf55a71 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -47,14 +47,14 @@ static int ohci_usb_probe(struct udevice *dev)
err = clk_enable(&priv->clocks[i]); if (err) { - error("failed to enable clock %d\n", i); + pr_err("failed to enable clock %d\n", i); clk_free(&priv->clocks[i]); goto clk_err; } priv->clock_count++; } } else if (clock_nb != -ENOENT) { - error("failed to get clock phandle(%d)\n", clock_nb); + pr_err("failed to get clock phandle(%d)\n", clock_nb); return clock_nb; }
@@ -74,28 +74,28 @@ static int ohci_usb_probe(struct udevice *dev)
err = reset_deassert(&priv->resets[i]); if (err) { - error("failed to deassert reset %d\n", i); + pr_err("failed to deassert reset %d\n", i); reset_free(&priv->resets[i]); goto reset_err; } priv->reset_count++; } } else if (reset_nb != -ENOENT) { - error("failed to get reset phandle(%d)\n", reset_nb); + pr_err("failed to get reset phandle(%d)\n", reset_nb); goto clk_err; }
err = generic_phy_init(&priv->phy); if (err) { - error("failed to init usb phy\n"); + pr_err("failed to init usb phy\n"); goto reset_err; } } @@ -110,17 +110,17 @@ phy_err: if (generic_phy_valid(&priv->phy)) { ret = generic_phy_exit(&priv->phy); if (ret) - error("failed to release phy\n"); + pr_err("failed to release phy\n"); }
return err; } diff --git a/drivers/usb/host/xhci-dwc3.c b/drivers/usb/host/xhci-dwc3.c index 4191a89..258d1cd 100644 --- a/drivers/usb/host/xhci-dwc3.c +++ b/drivers/usb/host/xhci-dwc3.c @@ -128,13 +128,13 @@ static int xhci_dwc3_probe(struct udevice *dev) ret = generic_phy_get_by_index(dev, 0, &plat->usb_phy); if (ret) { if (ret != -ENOENT) { - error("Failed to get USB PHY for %s\n", dev->name); + pr_err("Failed to get USB PHY for %s\n", dev->name); return ret; } } else { ret = generic_phy_init(&plat->usb_phy); if (ret) { - error("Can't init USB PHY for %s\n", dev->name); + pr_err("Can't init USB PHY for %s\n", dev->name); return ret; } } @@ -161,7 +161,7 @@ static int xhci_dwc3_remove(struct udevice *dev) if (generic_phy_valid(&plat->usb_phy)) { ret = generic_phy_exit(&plat->usb_phy); if (ret) { - error("Can't deinit USB PHY for %s\n", dev->name); + pr_err("Can't deinit USB PHY for %s\n", dev->name); return ret; } } diff --git a/drivers/usb/host/xhci-rockchip.c b/drivers/usb/host/xhci-rockchip.c index ec55f4e..a72d305 100644 --- a/drivers/usb/host/xhci-rockchip.c +++ b/drivers/usb/host/xhci-rockchip.c @@ -48,7 +48,7 @@ static int xhci_usb_ofdata_to_platdata(struct udevice *dev) */ plat->hcd_base = devfdt_get_addr(dev); if (plat->hcd_base == FDT_ADDR_T_NONE) { - error("Can't get the XHCI register base address\n"); + pr_err("Can't get the XHCI register base address\n"); return -ENXIO; }
@@ -62,7 +62,7 @@ static int xhci_usb_ofdata_to_platdata(struct udevice *dev) }
if (plat->phy_base == FDT_ADDR_T_NONE) { - error("Can't get the usbphy register address\n"); + pr_err("Can't get the usbphy register address\n"); return -ENXIO; }
@@ -119,7 +119,7 @@ static int rockchip_xhci_core_init(struct rockchip_xhci *rkxhci,
ret = dwc3_core_init(rkxhci->dwc3_reg); if (ret) { - error("failed to initialize core\n"); + pr_err("failed to initialize core\n"); return ret; }
@@ -151,14 +151,14 @@ static int xhci_usb_probe(struct udevice *dev) if (plat->vbus_supply) { ret = regulator_set_enable(plat->vbus_supply, true); if (ret) { - error("XHCI: failed to set VBus supply\n"); + pr_err("XHCI: failed to set VBus supply\n"); return ret; } }
ret = rockchip_xhci_core_init(ctx, dev); if (ret) { - error("XHCI: failed to initialize controller\n"); + pr_err("XHCI: failed to initialize controller\n"); return ret; }
@@ -181,7 +181,7 @@ static int xhci_usb_remove(struct udevice *dev) if (plat->vbus_supply) { ret = regulator_set_enable(plat->vbus_supply, false); if (ret) - error("XHCI: failed to set VBus supply\n"); + pr_err("XHCI: failed to set VBus supply\n"); }
return ret; diff --git a/drivers/usb/musb-new/ti-musb.c b/drivers/usb/musb-new/ti-musb.c index de10131..233857a 100644 --- a/drivers/usb/musb-new/ti-musb.c +++ b/drivers/usb/musb-new/ti-musb.c @@ -106,7 +106,7 @@ static int ti_musb_ofdata_to_platdata(struct udevice *dev) "mentor,multipoint", -1); if (platdata->musb_config.multipoint < 0) { - error("MUSB multipoint DT entry missing\n"); + pr_err("MUSB multipoint DT entry missing\n"); return -ENOENT; }
@@ -115,14 +115,14 @@ static int ti_musb_ofdata_to_platdata(struct udevice *dev) platdata->musb_config.num_eps = fdtdec_get_int(fdt, node, "mentor,num-eps", -1); if (platdata->musb_config.num_eps < 0) { - error("MUSB num-eps DT entry missing\n"); + pr_err("MUSB num-eps DT entry missing\n"); return -ENOENT; }
platdata->musb_config.ram_bits = fdtdec_get_int(fdt, node, "mentor,ram-bits", -1); if (platdata->musb_config.ram_bits < 0) { - error("MUSB ram-bits DT entry missing\n"); + pr_err("MUSB ram-bits DT entry missing\n"); return -ENOENT; }
@@ -132,7 +132,7 @@ static int ti_musb_ofdata_to_platdata(struct udevice *dev)
platdata->plat.power = fdtdec_get_int(fdt, node, "mentor,power", -1); if (platdata->plat.power < 0) { - error("MUSB mentor,power DT entry missing\n"); + pr_err("MUSB mentor,power DT entry missing\n"); return -ENOENT; }
@@ -183,7 +183,7 @@ static int ti_musb_host_ofdata_to_platdata(struct udevice *dev)
ret = ti_musb_ofdata_to_platdata(dev); if (ret) { - error("platdata dt parse error\n"); + pr_err("platdata dt parse error\n"); return ret; }
@@ -229,7 +229,7 @@ static int ti_musb_wrapper_bind(struct udevice *parent) ret = device_bind_driver_to_node(parent, "ti-musb-host", name, offset_to_ofnode(node), &dev); if (ret) { - error("musb - not able to bind usb host node\n"); + pr_err("musb - not able to bind usb host node\n"); return ret; } break; diff --git a/drivers/video/am335x-fb.c b/drivers/video/am335x-fb.c index bb5cc97..a8b3e74 100644 --- a/drivers/video/am335x-fb.c +++ b/drivers/video/am335x-fb.c @@ -128,7 +128,7 @@ int am335xfb_init(struct am335x_lcdpanel *panel) raster_ctrl |= LCD_TFT_24BPP_MODE; break; default: - error("am335x-fb: invalid bpp value: %d\n", panel->bpp); + pr_err("am335x-fb: invalid bpp value: %d\n", panel->bpp); return -1; }
diff --git a/env/common.c b/env/common.c index b403bd5..70715bb 100644 --- a/env/common.c +++ b/env/common.c @@ -84,7 +84,7 @@ void set_default_env(const char *s) if (himport_r(&env_htab, (char *)default_environment, sizeof(default_environment), '\0', flags, 0, 0, NULL) == 0) - error("Environment import failed: errno = %d\n", errno); + pr_err("Environment import failed: errno = %d\n", errno);
gd->flags |= GD_FLG_ENV_READY; gd->flags |= GD_FLG_ENV_DEFAULT; @@ -172,7 +172,7 @@ int env_import(const char *buf, int check) /* Decrypt the env if desired. */ ret = env_aes_cbc_crypt(ep, 0); if (ret) { - error("Failed to decrypt env!\n"); + pr_err("Failed to decrypt env!\n"); set_default_env("!import failed"); return ret; } @@ -183,7 +183,7 @@ int env_import(const char *buf, int check) return 1; }
- error("Cannot import environment: errno = %d\n", errno); + pr_err("Cannot import environment: errno = %d\n", errno);
@@ -247,7 +247,7 @@ int env_export(env_t *env_out) res = (char *)env_out->data; len = hexport_r(&env_htab, '\0', 0, &res, ENV_SIZE, 0, NULL); if (len < 0) { - error("Cannot export environment: errno = %d\n", errno); + pr_err("Cannot export environment: errno = %d\n", errno); return 1; }
diff --git a/env/sf.c b/env/sf.c index 6f74371..e51b1ae 100644 --- a/env/sf.c +++ b/env/sf.c @@ -236,7 +236,7 @@ static int env_sf_load(void)
ret = env_import((char *)ep, 0); if (!ret) { - error("Cannot import environment: errno = %d\n", errno); + pr_err("Cannot import environment: errno = %d\n", errno); set_default_env("!env_import failed"); }
diff --git a/fs/jffs2/jffs2_nand_1pass.c b/fs/jffs2/jffs2_nand_1pass.c index 1d63fc9..b16005e 100644 --- a/fs/jffs2/jffs2_nand_1pass.c +++ b/fs/jffs2/jffs2_nand_1pass.c @@ -798,7 +798,7 @@ jffs2_1pass_build_lists(struct part_info * part) struct mtdids *id = part->dev->id; mtd = get_nand_dev_by_index(id->num); if (!mtd) { - error("\nno NAND devices available\n"); + pr_err("\nno NAND devices available\n"); return 0; }
diff --git a/fs/yaffs2/yaffs_uboot_glue.c b/fs/yaffs2/yaffs_uboot_glue.c index bd66d31..2a70e4a 100644 --- a/fs/yaffs2/yaffs_uboot_glue.c +++ b/fs/yaffs2/yaffs_uboot_glue.c @@ -168,7 +168,7 @@ void cmd_yaffs_devconfig(char *_mp, int flash_dev,
mtd = get_nand_dev_by_index(flash_dev); if (!mtd) { - error("\nno NAND devices available\n"); + pr_err("\nno NAND devices available\n"); return; }
On 13 September 2017 at 05:45, Masahiro Yamada yamada.masahiro@socionext.com wrote:
U-Boot widely uses error() as a bit noisier variant of printf().
This macro causes name conflict with the following line in include/linux/compiler-gcc.h:
# define __compiletime_error(message) __attribute__((error(message)))
This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG stuff with Linux. (Notice Linux's BUILD_BUG_ON_MSG is defined by using compiletime_assert().)
Let's convert error() into now treewide-available pr_err().
Done with the help of Coccinelle, excluing tools/ directory.
The semantic patch I used is as follows:
// <smpl> @@@@ -error +pr_err (...) // </smpl>
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com
arch/arm/mach-omap2/am33xx/board.c | 2 +- arch/arm/mach-omap2/utils.c | 4 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 2 +- arch/arm/mach-rockchip/rk3188-board.c | 2 +- arch/arm/mach-rockchip/rk3368-board-spl.c | 4 +- arch/arm/mach-rockchip/rk3399/sdram_rk3399.c | 2 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 2 +- arch/arm/mach-tegra/ivc.c | 8 +-- arch/arm/mach-tegra/tegra124/xusb-padctl.c | 2 +- arch/arm/mach-tegra/tegra186/nvtboot_mem.c | 4 +- arch/arm/mach-tegra/tegra20/clock.c | 6 +- arch/arm/mach-tegra/tegra210/xusb-padctl.c | 2 +- arch/arm/mach-tegra/tegra30/clock.c | 6 +- arch/arm/mach-tegra/xusb-padctl-common.c | 22 +++---- arch/x86/cpu/tangier/sdram.c | 6 +- board/nvidia/jetson-tk1/jetson-tk1.c | 6 +- board/samsung/common/exynos5-dt.c | 2 +- board/samsung/common/misc.c | 2 +- board/samsung/goni/goni.c | 4 +- board/samsung/odroid/odroid.c | 12 ++-- cmd/fastboot.c | 2 +- cmd/nvedit.c | 6 +- cmd/regulator.c | 2 +- cmd/thordown.c | 6 +- cmd/tpm_test.c | 6 +- cmd/usb_gadget_sdp.c | 4 +- cmd/usb_mass_storage.c | 6 +- common/dfu.c | 6 +- common/fb_mmc.c | 36 +++++------ common/fb_nand.c | 12 ++-- common/spl/spl_dfu.c | 4 +- common/spl/spl_sdp.c | 4 +- common/update.c | 2 +- disk/part_efi.c | 10 +-- drivers/adc/adc-uclass.c | 6 +- drivers/adc/exynos-adc.c | 6 +- drivers/adc/sandbox.c | 6 +- drivers/ata/dwc_ahci.c | 6 +- drivers/clk/clk_boston.c | 4 +- drivers/clk/clk_stm32f7.c | 2 +- drivers/clk/rockchip/clk_rk3368.c | 8 +-- drivers/clk/rockchip/clk_rk3399.c | 6 +- drivers/clk/rockchip/clk_rv1108.c | 2 +- drivers/dfu/dfu.c | 14 ++-- drivers/dfu/dfu_mmc.c | 18 +++--- drivers/dfu/dfu_ram.c | 8 +-- drivers/dfu/dfu_tftp.c | 4 +- drivers/dma/dma-uclass.c | 2 +- drivers/dma/lpc32xx_dma.c | 8 +-- drivers/dma/ti-edma3.c | 2 +- drivers/i2c/i2c-gpio.c | 2 +- drivers/i2c/omap24xx_i2c.c | 2 +- drivers/i2c/stm32f7_i2c.c | 16 ++--- drivers/i2c/tegra_i2c.c | 4 +- drivers/misc/tegra186_bpmp.c | 28 ++++---- drivers/mmc/exynos_dw_mmc.c | 2 +- drivers/mmc/hi6220_dw_mmc.c | 2 +- drivers/mmc/xenon_sdhci.c | 4 +- drivers/mtd/nand/lpc32xx_nand_mlc.c | 6 +- drivers/mtd/nand/pxa3xx_nand.c | 2 +- drivers/net/bcm-sf2-eth-gmac.c | 14 ++-- drivers/net/bcm-sf2-eth.c | 18 +++--- drivers/net/cpsw-common.c | 8 +-- drivers/net/cpsw.c | 8 +-- drivers/net/dwc_eth_qos.c | 92 +++++++++++++-------------- drivers/net/ep93xx_eth.c | 16 ++--- drivers/net/keystone_net.c | 14 ++-- drivers/pci/pci_tegra.c | 50 +++++++-------- drivers/pci/pcie_xilinx.c | 2 +- drivers/phy/marvell/comphy_cp110.c | 40 ++++++------ drivers/phy/ti-pipe3-phy.c | 12 ++-- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 2 +- drivers/pinctrl/pinctrl-sti.c | 14 ++-- drivers/pinctrl/pinctrl_stm32.c | 2 +- drivers/power/pmic/as3722.c | 12 ++-- drivers/power/pmic/as3722_gpio.c | 10 +-- drivers/power/pmic/i2c_pmic_emul.c | 6 +- drivers/power/pmic/lp873x.c | 4 +- drivers/power/pmic/lp87565.c | 4 +- drivers/power/pmic/max77686.c | 4 +- drivers/power/pmic/max8997.c | 4 +- drivers/power/pmic/max8998.c | 4 +- drivers/power/pmic/palmas.c | 4 +- drivers/power/pmic/pfuze100.c | 4 +- drivers/power/pmic/s2mps11.c | 4 +- drivers/power/pmic/s5m8767.c | 4 +- drivers/power/pmic/sandbox.c | 6 +- drivers/power/pmic/tps65090.c | 4 +- drivers/power/regulator/fixed.c | 2 +- drivers/power/regulator/gpio-regulator.c | 2 +- drivers/power/regulator/max77686.c | 20 +++--- drivers/power/regulator/sandbox.c | 18 +++--- drivers/ram/rockchip/dmc-rk3368.c | 14 ++-- drivers/ram/stm32_sdram.c | 8 +-- drivers/reset/sti-reset.c | 10 +-- drivers/spi/atmel_spi.c | 2 +- drivers/spi/lpc32xx_ssp.c | 6 +- drivers/sysreset/sysreset_sti.c | 6 +- drivers/sysreset/sysreset_syscon.c | 4 +- drivers/sysreset/sysreset_watchdog.c | 2 +- drivers/tpm/tpm_tis_infineon.c | 2 +- drivers/usb/common/common.c | 2 +- drivers/usb/eth/mcs7830.c | 12 ++-- drivers/usb/gadget/at91_udc.c | 4 +- drivers/usb/gadget/atmel_usba_udc.c | 6 +- drivers/usb/gadget/dwc2_udc_otg.c | 2 +- drivers/usb/gadget/ether.c | 42 ++++++------ drivers/usb/gadget/f_fastboot.c | 10 +-- drivers/usb/gadget/f_sdp.c | 16 ++--- drivers/usb/gadget/f_thor.c | 26 ++++---- drivers/usb/host/dwc2.c | 2 +- drivers/usb/host/ehci-generic.c | 18 +++--- drivers/usb/host/ohci-generic.c | 18 +++--- drivers/usb/host/xhci-dwc3.c | 6 +- drivers/usb/host/xhci-rockchip.c | 12 ++-- drivers/usb/musb-new/ti-musb.c | 12 ++-- drivers/video/am335x-fb.c | 2 +- env/common.c | 8 +-- env/sf.c | 2 +- fs/jffs2/jffs2_nand_1pass.c | 2 +- fs/yaffs2/yaffs_uboot_glue.c | 2 +- 121 files changed, 521 insertions(+), 521 deletions(-)
This macro has prevented us from using compiletime_error/assert in <linux/compiler.h>.
Now we can remove it, then we will be able to import more BUILD_BUG macros from Linux.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/common.h | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/include/common.h b/include/common.h index ae3b876..e66b8ff 100644 --- a/include/common.h +++ b/include/common.h @@ -89,11 +89,6 @@ void __assert_fail(const char *assertion, const char *file, unsigned line, ({ if (!(x) && _DEBUG) \ __assert_fail(#x, __FILE__, __LINE__, __func__); })
-#define error(fmt, args...) do { \ - printf("ERROR: " pr_fmt(fmt) "\nat %s:%d/%s()\n", \ - ##args, __FILE__, __LINE__, __func__); \ -} while (0) - #ifndef BUG #define BUG() do { \ printf("BUG: failure at %s:%d/%s()!\n", __FILE__, __LINE__, __FUNCTION__); \
This header uses ulong, size_t, loff_t. Include <linux/types.h> to make this header self-contained.
include/vsprintf.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/vsprintf.h b/include/vsprintf.h index 490c96c..33d05aa 100644 --- a/include/vsprintf.h +++ b/include/vsprintf.h @@ -9,6 +9,7 @@ #define __VSPRINTF_H
#include <stdarg.h> +#include <linux/types.h>
ulong simple_strtoul(const char *cp, char **endp, unsigned int base);
As commit 84b8bf6d5d2a ("bug.h: move BUILD_BUG_* defines to include/linux/bug.h") noted, include/linux/bug.h was locally modified for U-Boot because the name conflict of error() caused build errors at that time.
Now error() is gone, so we can fully sync BUILD_BUG* with Linux. These macros are just compile-time utilities. Nothing is related to platform code, so it makes sense to simply copy Linux's ones.
Please note Linux split BUILD_BUG stuff out into <linux/build_bug.h> by commit bc6245e5efd7. Let's follow it.
include/linux/bug.h | 51 +--------------------------- include/linux/build_bug.h | 84 +++++++++++++++++++++++++++++++++++++++++++++++ include/linux/compiler.h | 6 +++- 3 files changed, 90 insertions(+), 51 deletions(-) create mode 100644 include/linux/build_bug.h
diff --git a/include/linux/bug.h b/include/linux/bug.h index 920e379..133544c 100644 --- a/include/linux/bug.h +++ b/include/linux/bug.h @@ -1,55 +1,6 @@ #ifndef _LINUX_BUG_H #define _LINUX_BUG_H
-#include <linux/compiler.h> - -#ifdef __CHECKER__ -#define BUILD_BUG_ON_NOT_POWER_OF_2(n) (0) -#define BUILD_BUG_ON_ZERO(e) (0) -#define BUILD_BUG_ON_NULL(e) ((void*)0) -#define BUILD_BUG_ON_INVALID(e) (0) -#define BUILD_BUG_ON(condition) (0) -#define BUILD_BUG() (0) -#else /* __CHECKER__ */ - -/* Force a compilation error if a constant expression is not a power of 2 */ -#define BUILD_BUG_ON_NOT_POWER_OF_2(n) \ - BUILD_BUG_ON((n) == 0 || (((n) & ((n) - 1)) != 0)) - -/* Force a compilation error if condition is true, but also produce a - result (of value 0 and type size_t), so the expression can be used - e.g. in a structure initializer (or where-ever else comma expressions - aren't permitted). */ -#define BUILD_BUG_ON_ZERO(e) (sizeof(struct { int:-!!(e); })) -#define BUILD_BUG_ON_NULL(e) ((void *)sizeof(struct { int:-!!(e); })) - -/* - * BUILD_BUG_ON_INVALID() permits the compiler to check the validity of the - * expression but avoids the generation of any code, even if that expression - * has side-effects. - */ -#define BUILD_BUG_ON_INVALID(e) ((void)(sizeof((__force long)(e)))) - -/** - * BUILD_BUG_ON - break compile if a condition is true. - * @condition: the condition which the compiler should know is false. - * - * If you have some code which relies on certain constants being equal, or - * some other compile-time-evaluated condition, you should use BUILD_BUG_ON to - * detect if someone changes it. - * - * The implementation uses gcc's reluctance to create a negative array, but gcc - * (as of 4.4) only emits that error for obvious cases (e.g. not arguments to - * inline functions). Luckily, in 4.3 they added the "error" function - * attribute just for this type of case. Thus, we use a negative sized array - * (should always create an error on gcc versions older than 4.4) and then call - * an undefined function with the error attribute (should always create an - * error on gcc 4.3 and later). If for some reason, neither creates a - * compile-time error, we'll still have a link-time error, which is harder to - * track down. - */ -#define BUILD_BUG_ON(condition) ((void)sizeof(char[1 - 2*!!(condition)])) - -#endif /* __CHECKER__ */ +#include <linux/build_bug.h>
#endif /* _LINUX_BUG_H */ diff --git a/include/linux/build_bug.h b/include/linux/build_bug.h new file mode 100644 index 0000000..b7d22d6 --- /dev/null +++ b/include/linux/build_bug.h @@ -0,0 +1,84 @@ +#ifndef _LINUX_BUILD_BUG_H +#define _LINUX_BUILD_BUG_H + +#include <linux/compiler.h> + +#ifdef __CHECKER__ +#define __BUILD_BUG_ON_NOT_POWER_OF_2(n) (0) +#define BUILD_BUG_ON_NOT_POWER_OF_2(n) (0) +#define BUILD_BUG_ON_ZERO(e) (0) +#define BUILD_BUG_ON_NULL(e) ((void *)0) +#define BUILD_BUG_ON_INVALID(e) (0) +#define BUILD_BUG_ON_MSG(cond, msg) (0) +#define BUILD_BUG_ON(condition) (0) +#define BUILD_BUG() (0) +#else /* __CHECKER__ */ + +/* Force a compilation error if a constant expression is not a power of 2 */ +#define __BUILD_BUG_ON_NOT_POWER_OF_2(n) \ + BUILD_BUG_ON(((n) & ((n) - 1)) != 0) +#define BUILD_BUG_ON_NOT_POWER_OF_2(n) \ + BUILD_BUG_ON((n) == 0 || (((n) & ((n) - 1)) != 0)) + +/* + * Force a compilation error if condition is true, but also produce a + * result (of value 0 and type size_t), so the expression can be used + * e.g. in a structure initializer (or where-ever else comma expressions + * aren't permitted). + */ +#define BUILD_BUG_ON_ZERO(e) (sizeof(struct { int:(-!!(e)); })) +#define BUILD_BUG_ON_NULL(e) ((void *)sizeof(struct { int:(-!!(e)); })) + +/* + * BUILD_BUG_ON_INVALID() permits the compiler to check the validity of the + * expression but avoids the generation of any code, even if that expression + * has side-effects. + */ +#define BUILD_BUG_ON_INVALID(e) ((void)(sizeof((__force long)(e)))) + +/** + * BUILD_BUG_ON_MSG - break compile if a condition is true & emit supplied + * error message. + * @condition: the condition which the compiler should know is false. + * + * See BUILD_BUG_ON for description. + */ +#define BUILD_BUG_ON_MSG(cond, msg) compiletime_assert(!(cond), msg) + +/** + * BUILD_BUG_ON - break compile if a condition is true. + * @condition: the condition which the compiler should know is false. + * + * If you have some code which relies on certain constants being equal, or + * some other compile-time-evaluated condition, you should use BUILD_BUG_ON to + * detect if someone changes it. + * + * The implementation uses gcc's reluctance to create a negative array, but gcc + * (as of 4.4) only emits that error for obvious cases (e.g. not arguments to + * inline functions). Luckily, in 4.3 they added the "error" function + * attribute just for this type of case. Thus, we use a negative sized array + * (should always create an error on gcc versions older than 4.4) and then call + * an undefined function with the error attribute (should always create an + * error on gcc 4.3 and later). If for some reason, neither creates a + * compile-time error, we'll still have a link-time error, which is harder to + * track down. + */ +#ifndef __OPTIMIZE__ +#define BUILD_BUG_ON(condition) ((void)sizeof(char[1 - 2*!!(condition)])) +#else +#define BUILD_BUG_ON(condition) \ + BUILD_BUG_ON_MSG(condition, "BUILD_BUG_ON failed: " #condition) +#endif + +/** + * BUILD_BUG - break compile if used. + * + * If you have some code that you expect the compiler to eliminate at + * build time, you should use BUILD_BUG to detect if it is + * unexpectedly used. + */ +#define BUILD_BUG() BUILD_BUG_ON_MSG(1, "BUILD_BUG failed") + +#endif /* __CHECKER__ */ + +#endif /* _LINUX_BUILD_BUG_H */ diff --git a/include/linux/compiler.h b/include/linux/compiler.h index 020ad16..0ea6c8f 100644 --- a/include/linux/compiler.h +++ b/include/linux/compiler.h @@ -476,7 +476,8 @@ static __always_inline void __write_once_size(volatile void *p, void *res, int s # define __compiletime_error_fallback(condition) do { } while (0) #endif
-#define __compiletime_assert(condition, msg, prefix, suffix) \ +#ifdef __OPTIMIZE__ +# define __compiletime_assert(condition, msg, prefix, suffix) \ do { \ bool __cond = !(condition); \ extern void prefix ## suffix(void) __compiletime_error(msg); \ @@ -484,6 +485,9 @@ static __always_inline void __write_once_size(volatile void *p, void *res, int s prefix ## suffix(); \ __compiletime_error_fallback(__cond); \ } while (0) +#else +# define __compiletime_assert(condition, msg, prefix, suffix) do { } while (0) +#endif
#define _compiletime_assert(condition, msg, prefix, suffix) \ __compiletime_assert(condition, msg, prefix, suffix)
<common.h> and <linux/bug.h> define BUG(_ON) in a different way. To avoid the conflict, they wrap the defines with #ifndef BUG, enabling the first-included one. Horrible.
Collect them into a self-contained header <linux/bug.h> to make these macros easier to use.
drivers/usb/dwc3/linux-compat.h | 1 - include/common.h | 9 +-------- include/linux/bug.h | 28 ++++++++++++++++++++++++++++ include/linux/compat.h | 15 --------------- 4 files changed, 29 insertions(+), 24 deletions(-)
diff --git a/drivers/usb/dwc3/linux-compat.h b/drivers/usb/dwc3/linux-compat.h index 64db4ec..5cbe377 100644 --- a/drivers/usb/dwc3/linux-compat.h +++ b/drivers/usb/dwc3/linux-compat.h @@ -14,7 +14,6 @@
#define WARN(val, format, arg...) debug(format, ##arg) #define dev_WARN(dev, format, arg...) debug(format, ##arg) -#define WARN_ON_ONCE(val) debug("Error %d\n", val)
static inline size_t strlcat(char *dest, const char *src, size_t n) { diff --git a/include/common.h b/include/common.h index e66b8ff..f5344a0 100644 --- a/include/common.h +++ b/include/common.h @@ -23,6 +23,7 @@ typedef volatile unsigned char vu_char; #include <time.h> #include <asm-offsets.h> #include <linux/bitops.h> +#include <linux/bug.h> #include <linux/delay.h> #include <linux/types.h> #include <linux/printk.h> @@ -89,14 +90,6 @@ void __assert_fail(const char *assertion, const char *file, unsigned line, ({ if (!(x) && _DEBUG) \ __assert_fail(#x, __FILE__, __LINE__, __func__); })
-#ifndef BUG -#define BUG() do { \ - printf("BUG: failure at %s:%d/%s()!\n", __FILE__, __LINE__, __FUNCTION__); \ - panic("BUG!"); \ -} while (0) -#define BUG_ON(condition) do { if (unlikely((condition)!=0)) BUG(); } while(0) -#endif /* BUG */ - typedef void (interrupt_handler_t)(void *);
#include <asm/u-boot.h> /* boot information for Linux kernel */ diff --git a/include/linux/bug.h b/include/linux/bug.h index 133544c..f07bb71 100644 --- a/include/linux/bug.h +++ b/include/linux/bug.h @@ -1,6 +1,34 @@ #ifndef _LINUX_BUG_H #define _LINUX_BUG_H
+#include <vsprintf.h> /* for panic() */ #include <linux/build_bug.h> +#include <linux/compiler.h> +#include <linux/printk.h> + +#define BUG() do { \ + printk("BUG at %s:%d/%s()!\n", __FILE__, __LINE__, __func__); \ + panic("BUG!"); \ +} while (0) + +#define BUG_ON(condition) do { if (unlikely(condition)) BUG(); } while (0) + +#define WARN_ON(condition) ({ \ + int __ret_warn_on = !!(condition); \ + if (unlikely(__ret_warn_on)) \ + printk("WARNING at %s:%d/%s()!\n", __FILE__, __LINE__, __func__); \ + unlikely(__ret_warn_on); \ +}) + +#define WARN_ON_ONCE(condition) ({ \ + static bool __warned; \ + int __ret_warn_once = !!(condition); \ + \ + if (unlikely(__ret_warn_once && !__warned)) { \ + __warned = true; \ + WARN_ON(1); \ + } \ + unlikely(__ret_warn_once); \ +})
#endif /* _LINUX_BUG_H */ diff --git a/include/linux/compat.h b/include/linux/compat.h index bc027ad..1b3f089 100644 --- a/include/linux/compat.h +++ b/include/linux/compat.h @@ -87,21 +87,6 @@ static inline void kmem_cache_destroy(struct kmem_cache *cachep)
#define KERNEL_VERSION(a,b,c) (((a) << 16) + ((b) << 8) + (c))
-#ifndef BUG -#define BUG() do { \ - printf("U-Boot BUG at %s:%d!\n", __FILE__, __LINE__); \ -} while (0) - -#define BUG_ON(condition) do { if (condition) BUG(); } while(0) -#endif /* BUG */ - -#define WARN_ON(condition) ({ \ - int __ret_warn_on = !!(condition); \ - if (unlikely(__ret_warn_on)) \ - printf("WARNING in %s line %d\n", __FILE__, __LINE__); \ - unlikely(__ret_warn_on); \ -}) - #define PAGE_SIZE 4096
/* drivers/char/random.c */
2017-09-13 20:45 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
buildman is 60% done, and no regression so far.
I will report the full-stat when buildman is complete.
Finished buildman test.
No regression from the point of C grammar.
But, image size exceeded its platform limit for some boards. (ex. colibri_vf_defconfig)
This is because all pr_*() except pr_debug() are now enabled. So, more are more log message strings are compiled now.
Hmm, I need to implement CONFIG_LOGLEVEL and CONFIG_SPL_LOGLEVEL now to shut up lower priority log functions such as pr_info(), pr_notice() ??
I will take a look.
The full-stat of buildman is as follows:
01: ARM: DRA72x: Add support for detection of DRA71x SR 2.1 aarch64: + nanopi_neo2 bananapi_m64 orangepi_prime orangepi_pc2 pine64_plus orangepi_win a64-olinuxino evb-rk3328 nanopi_a64 sopine_baseboard orangepi_zero_plus2 x86: + qemu-x86_64 qemu-x86_efi_payload64 chromebook_link64 arm: + am43xx_hs_evm am57xx_hs_evm imx6qdl_icore_rqs am335x_hs_evm ethernut5 am43xx_evm imx6qdl_icore_nand imx6qdl_icore_mmc dra7xx_hs_evm am43xx_evm_usbhost_boot db-88f6720 am335x_evm am57xx_evm dra7xx_evm nds32: + adp-ag101p adp-ae3xx + src, &length)) { + ^ +In file included from ../common/spl/spl_fit.c:8:0: +../include/common.h:627:5: note: expected 'long unsigned int *' but argument is of type 'size_t * {aka unsigned int *}' + int gunzip(void *, int, unsigned char *, unsigned long *); + ^~~~~~ + if (gunzip((void *)load_addr, CONFIG_SYS_BOOTM_LEN, + ^ +../include/common.h:627:5: note: expected 'long unsigned int *' but argument is of type 'size_t *' + ^ +../arch/nds32/cpu/n1213/start.S: Assembler messages: +../arch/nds32/cpu/n1213/start.S:109: Error: unknown pseudo-op: `.relax_hint' +../arch/nds32/cpu/n1213/start.S:111: Error: unknown pseudo-op: `.relax_hint' +../arch/nds32/cpu/n1213/start.S:113: Error: unrecognized form of instruction `add5.pc $gp' +make[2]: *** [../scripts/Makefile.build:316: arch/nds32/cpu/n1213/start.o] Error 1 +make[1]: *** [Makefile:1279: arch/nds32/cpu/n1213] Error 2 +make: *** [Makefile:150: sub-make] Error 2 +arch/arm/dts/ethernut5.dtb: Warning (reg_format): "reg" property in /i2c-gpio-0/pcf8563@50 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) +arch/arm/dts/ethernut5.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /i2c-gpio-0/pcf8563@50 +arch/arm/dts/ethernut5.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /i2c-gpio-0/pcf8563@50 +WARNING: BL31 file bl31.bin NOT found, resulting binary is non-functional +Please read the section on ARM Trusted Firmware (ATF) in board/sunxi/README.sunxi64 +<stdout>: Warning (unit_address_vs_reg): Node /images/uboot@1 has a unit name, but no reg property +<stdout>: Warning (unit_address_vs_reg): Node /images/atf@1 has a unit name, but no reg property +<stdout>: Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property +<stdout>: Warning (unit_address_vs_reg): Node /configurations/config@1 has a unit name, but no reg property +<stdout>: Warning (unit_address_vs_reg): Node /images/fdt@2 has a unit name, but no reg property +<stdout>: Warning (unit_address_vs_reg): Node /configurations/config@2 has a unit name, but no reg property + writel((unsigned int) ep->dma_buf, ®->out_endp[ep_num].doepdma); + ^ +../arch/arm/include/asm/io.h:146:34: note: in definition of macro 'writel' + #define writel(v,c) ({ u32 __v = v; __iowmb(); __arch_putl(__v,c); __v; }) + ^ + port->priv->mdio_base = (void *)mdio_addr; + ^ +../arch/x86/lib/crt0_x86_64_efi.S: Assembler messages: +../arch/x86/lib/crt0_x86_64_efi.S:16: Error: bad register name `%rsp' +../arch/x86/lib/crt0_x86_64_efi.S:17: Error: bad register name `%rcx' +../arch/x86/lib/crt0_x86_64_efi.S:18: Error: bad register name `%rdx' +../arch/x86/lib/crt0_x86_64_efi.S:21: Error: bad register name `%rip)' +../arch/x86/lib/crt0_x86_64_efi.S:22: Error: bad register name `%rip)' +../arch/x86/lib/crt0_x86_64_efi.S:24: Error: bad register name `%rcx' +../arch/x86/lib/crt0_x86_64_efi.S:25: Error: bad register name `%rdx' +../arch/x86/lib/crt0_x86_64_efi.S:26: Error: bad register name `%rcx' +../arch/x86/lib/crt0_x86_64_efi.S:27: Error: bad register name `%rdx' +../arch/x86/lib/crt0_x86_64_efi.S:30: Error: bad register name `%rdi' +../arch/x86/lib/crt0_x86_64_efi.S:31: Error: bad register name `%rsi' +../arch/x86/lib/crt0_x86_64_efi.S:34: Error: bad register name `%rsp' +../arch/x86/lib/crt0_x86_64_efi.S:47: Warning: setting incorrect section attributes for .reloc +make[2]: *** [../scripts/Makefile.build:316: arch/x86/lib/crt0_x86_64_efi.o] Error 1 +make[1]: *** [Makefile:1279: arch/x86/lib] Error 2 w+../common/spl/spl_fit.c: In function 'spl_load_fit_image': w+../common/spl/spl_fit.c:201:12: warning: passing argument 4 of 'gunzip' from incompatible pointer type [-Wincompatible-pointer-types] w+../common/spl/spl_fit.c:200:7: warning: passing argument 4 of 'gunzip' from incompatible pointer type w+../drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c: In function 'setdma_rx': w+../drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c:116:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] w+../drivers/net/mvpp2.c: In function 'phy_info_parse': w+../drivers/net/mvpp2.c:4751:27: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] 02: printk: collect printk stuff into <linux/printk.h> arm: + colibri_vf openrd_base vf610twr_nand openrd_ultimate vf610twr openrd_client -../include/common.h:627:5: note: expected 'long unsigned int *' but argument is of type 'size_t * {aka unsigned int *}' -../include/common.h:627:5: note: expected 'long unsigned int *' but argument is of type 'size_t *' +../include/common.h:623:5: note: expected 'long unsigned int *' but argument is of type 'size_t * {aka unsigned int *}' +../include/common.h:623:5: note: expected 'long unsigned int *' but argument is of type 'size_t *' +u-boot-nodtb.bin exceeds file size limit: + limit: 393216 bytes + actual: 434976 bytes + excess: 41760 bytes +make[1]: *** [Makefile:945: u-boot-nodtb.bin] Error 1 + limit: 524288 bytes + actual: 541568 bytes + excess: 17280 bytes + actual: 435000 bytes + excess: 41784 bytes + actual: 541520 bytes + excess: 17232 bytes + actual: 435024 bytes + excess: 41808 bytes + actual: 543952 bytes + excess: 19664 bytes 03: treewide: replace with error() with pr_err() - actual: 434976 bytes - excess: 41760 bytes - actual: 541568 bytes - excess: 17280 bytes - actual: 435000 bytes - excess: 41784 bytes - actual: 541520 bytes - excess: 17232 bytes - actual: 435024 bytes - excess: 41808 bytes - actual: 543952 bytes - excess: 19664 bytes + actual: 434624 bytes + excess: 41408 bytes + actual: 541184 bytes + excess: 16896 bytes + actual: 434656 bytes + excess: 41440 bytes + actual: 541136 bytes + excess: 16848 bytes + actual: 434672 bytes + excess: 41456 bytes + actual: 542608 bytes + excess: 18320 bytes 04: common.h: remove error() -../include/common.h:623:5: note: expected 'long unsigned int *' but argument is of type 'size_t * {aka unsigned int *}' -../include/common.h:623:5: note: expected 'long unsigned int *' but argument is of type 'size_t *' +../include/common.h:618:5: note: expected 'long unsigned int *' but argument is of type 'size_t * {aka unsigned int *}' +../include/common.h:618:5: note: expected 'long unsigned int *' but argument is of type 'size_t *' 05: vsprintf.h: include <linux/types.h> 06: bug.h: sync BUILD_BUG stuff with Linux 4.13 07: bug.h: move runtime BUG/WARN macros into <linux/bug.h> -../include/common.h:618:5: note: expected 'long unsigned int *' but argument is of type 'size_t * {aka unsigned int *}' -../include/common.h:618:5: note: expected 'long unsigned int *' but argument is of type 'size_t *' - actual: 434624 bytes - excess: 41408 bytes - actual: 541184 bytes - excess: 16896 bytes - actual: 434656 bytes - excess: 41440 bytes - actual: 541136 bytes - excess: 16848 bytes - actual: 434672 bytes - excess: 41456 bytes - actual: 542608 bytes - excess: 18320 bytes +../include/common.h:611:5: note: expected 'long unsigned int *' but argument is of type 'size_t * {aka unsigned int *}' +../include/common.h:611:5: note: expected 'long unsigned int *' but argument is of type 'size_t *' + actual: 434760 bytes + excess: 41544 bytes + actual: 541312 bytes + excess: 17024 bytes + actual: 434784 bytes + excess: 41568 bytes + actual: 541272 bytes + excess: 16984 bytes + actual: 434800 bytes + excess: 41584 bytes + actual: 542840 bytes + excess: 18552 bytes
Masahiro Yamada
