Re: [U-Boot] [PATCH 1/3] exynos5: fix GPIO information of exynos5420
Hi Hyungwon,
This patch fixes wrong GPIO information such as GPIO bank, table which is used to convert GPIO name to index, bank base address, and etc.
Change-Id: Ideb0f1f10257c9c258f8bca68befc47aed3c43c7
Please remove Change-Id from commits. (you can run your patch through ./scripts/checkpatch.pl)
Also it is a good practice to use buildman script.
Signed-off-by: Hyungwon Hwang human.hwang@samsung.com
arch/arm/include/asm/arch-exynos/cpu.h | 11 +- arch/arm/include/asm/arch-exynos/gpio.h | 232 +++++++++++++++----------------- 2 files changed, 117 insertions(+), 126 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 7c5c4ff..da4ac6b 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -139,7 +139,7 @@
/* EXYNOS5420 */ #define EXYNOS5420_AUDIOSS_BASE 0x03810000 -#define EXYNOS5420_GPIO_PART6_BASE 0x03860000 +#define EXYNOS5420_GPIO_PART5_BASE 0x03860000 #define EXYNOS5420_PRO_ID 0x10000000 #define EXYNOS5420_CLOCK_BASE 0x10010000 #define EXYNOS5420_POWER_BASE 0x10040000 @@ -161,11 +161,10 @@ #define EXYNOS5420_I2S_BASE 0x12D60000 #define EXYNOS5420_PWMTIMER_BASE 0x12DD0000 #define EXYNOS5420_SPI_ISP_BASE 0x131A0000 -#define EXYNOS5420_GPIO_PART2_BASE 0x13400000 -#define EXYNOS5420_GPIO_PART3_BASE 0x13400C00 -#define EXYNOS5420_GPIO_PART4_BASE 0x13410000 -#define EXYNOS5420_GPIO_PART5_BASE 0x14000000 -#define EXYNOS5420_GPIO_PART1_BASE 0x14010000 +#define EXYNOS5420_GPIO_PART1_BASE 0x13400000 +#define EXYNOS5420_GPIO_PART2_BASE 0x13410000 +#define EXYNOS5420_GPIO_PART3_BASE 0x14000000 +#define EXYNOS5420_GPIO_PART4_BASE 0x14010000 #define EXYNOS5420_MIPI_DSIM_BASE 0x14500000 #define EXYNOS5420_DP_BASE 0x145B0000
diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index 32e045a..431ae3a 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -1028,83 +1028,7 @@ enum exynos5_gpio_pin { };
enum exynos5420_gpio_pin {
- /* GPIO_PART1_STARTS */
- EXYNOS5420_GPIO_A00, /* 0 */
- EXYNOS5420_GPIO_A01,
- EXYNOS5420_GPIO_A02,
- EXYNOS5420_GPIO_A03,
- EXYNOS5420_GPIO_A04,
- EXYNOS5420_GPIO_A05,
- EXYNOS5420_GPIO_A06,
- EXYNOS5420_GPIO_A07,
- EXYNOS5420_GPIO_A10, /* 8 */
- EXYNOS5420_GPIO_A11,
- EXYNOS5420_GPIO_A12,
- EXYNOS5420_GPIO_A13,
- EXYNOS5420_GPIO_A14,
- EXYNOS5420_GPIO_A15,
- EXYNOS5420_GPIO_A16,
- EXYNOS5420_GPIO_A17,
- EXYNOS5420_GPIO_A20, /* 16 0x10 */
- EXYNOS5420_GPIO_A21,
- EXYNOS5420_GPIO_A22,
- EXYNOS5420_GPIO_A23,
- EXYNOS5420_GPIO_A24,
- EXYNOS5420_GPIO_A25,
- EXYNOS5420_GPIO_A26,
- EXYNOS5420_GPIO_A27,
- EXYNOS5420_GPIO_B00, /* 24 0x18 */
- EXYNOS5420_GPIO_B01,
- EXYNOS5420_GPIO_B02,
- EXYNOS5420_GPIO_B03,
- EXYNOS5420_GPIO_B04,
- EXYNOS5420_GPIO_B05,
- EXYNOS5420_GPIO_B06,
- EXYNOS5420_GPIO_B07,
- EXYNOS5420_GPIO_B10, /* 32 0x20 */
- EXYNOS5420_GPIO_B11,
- EXYNOS5420_GPIO_B12,
- EXYNOS5420_GPIO_B13,
- EXYNOS5420_GPIO_B14,
- EXYNOS5420_GPIO_B15,
- EXYNOS5420_GPIO_B16,
- EXYNOS5420_GPIO_B17,
- EXYNOS5420_GPIO_B20, /* 40 0x28 */
- EXYNOS5420_GPIO_B21,
- EXYNOS5420_GPIO_B22,
- EXYNOS5420_GPIO_B23,
- EXYNOS5420_GPIO_B24,
- EXYNOS5420_GPIO_B25,
- EXYNOS5420_GPIO_B26,
- EXYNOS5420_GPIO_B27,
- EXYNOS5420_GPIO_B30, /* 48 0x30 */
- EXYNOS5420_GPIO_B31,
- EXYNOS5420_GPIO_B32,
- EXYNOS5420_GPIO_B33,
- EXYNOS5420_GPIO_B34,
- EXYNOS5420_GPIO_B35,
- EXYNOS5420_GPIO_B36,
- EXYNOS5420_GPIO_B37,
- EXYNOS5420_GPIO_B40, /* 56 0x38 */
- EXYNOS5420_GPIO_B41,
- EXYNOS5420_GPIO_B42,
- EXYNOS5420_GPIO_B43,
- EXYNOS5420_GPIO_B44,
- EXYNOS5420_GPIO_B45,
- EXYNOS5420_GPIO_B46,
- EXYNOS5420_GPIO_B47,
- EXYNOS5420_GPIO_H00, /* 64 0x40 */
- EXYNOS5420_GPIO_H01,
- EXYNOS5420_GPIO_H02,
- EXYNOS5420_GPIO_H03,
- EXYNOS5420_GPIO_H04,
- EXYNOS5420_GPIO_H05,
- EXYNOS5420_GPIO_H06,
- EXYNOS5420_GPIO_H07,
- /* GPIO PART 2 STARTS*/
- EXYNOS5420_GPIO_MAX_PORT_PART_1,/* 72 0x48 */
- EXYNOS5420_GPIO_Y70 = EXYNOS5420_GPIO_MAX_PORT_PART_1,
- EXYNOS5420_GPIO_Y70, EXYNOS5420_GPIO_Y71, EXYNOS5420_GPIO_Y72, EXYNOS5420_GPIO_Y73,
@@ -1112,10 +1036,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y75, EXYNOS5420_GPIO_Y76, EXYNOS5420_GPIO_Y77,
- /* GPIO PART 3 STARTS*/
- EXYNOS5420_GPIO_MAX_PORT_PART_2,/* 80 0x50 */
- EXYNOS5420_GPIO_X00 = EXYNOS5420_GPIO_MAX_PORT_PART_2,
- EXYNOS5420_GPIO_X00, EXYNOS5420_GPIO_X01, EXYNOS5420_GPIO_X02, EXYNOS5420_GPIO_X03,
@@ -1123,7 +1044,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_X05, EXYNOS5420_GPIO_X06, EXYNOS5420_GPIO_X07,
- EXYNOS5420_GPIO_X10, /* 88 0x58 */
- EXYNOS5420_GPIO_X10, EXYNOS5420_GPIO_X11, EXYNOS5420_GPIO_X12, EXYNOS5420_GPIO_X13,
@@ -1131,7 +1052,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_X15, EXYNOS5420_GPIO_X16, EXYNOS5420_GPIO_X17,
- EXYNOS5420_GPIO_X20, /* 96 0x60 */
- EXYNOS5420_GPIO_X20, EXYNOS5420_GPIO_X21, EXYNOS5420_GPIO_X22, EXYNOS5420_GPIO_X23,
@@ -1139,7 +1060,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_X25, EXYNOS5420_GPIO_X26, EXYNOS5420_GPIO_X27,
- EXYNOS5420_GPIO_X30, /* 104 0x68 */
- EXYNOS5420_GPIO_X30, EXYNOS5420_GPIO_X31, EXYNOS5420_GPIO_X32, EXYNOS5420_GPIO_X33,
@@ -1148,9 +1069,8 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_X36, EXYNOS5420_GPIO_X37,
- /* GPIO PART 4 STARTS*/
- EXYNOS5420_GPIO_MAX_PORT_PART_3,/* 112 0x70 */
- EXYNOS5420_GPIO_C00 = EXYNOS5420_GPIO_MAX_PORT_PART_3,
- EXYNOS5420_GPIO_C00 = EXYNOS5420_GPIO_MAX_PORT_PART_1, EXYNOS5420_GPIO_C01, EXYNOS5420_GPIO_C02, EXYNOS5420_GPIO_C03,
@@ -1158,7 +1078,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_C05, EXYNOS5420_GPIO_C06, EXYNOS5420_GPIO_C07,
- EXYNOS5420_GPIO_C10, /* 120 0x78 */
- EXYNOS5420_GPIO_C10, EXYNOS5420_GPIO_C11, EXYNOS5420_GPIO_C12, EXYNOS5420_GPIO_C13,
@@ -1166,7 +1086,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_C15, EXYNOS5420_GPIO_C16, EXYNOS5420_GPIO_C17,
- EXYNOS5420_GPIO_C20, /* 128 0x80 */
- EXYNOS5420_GPIO_C20, EXYNOS5420_GPIO_C21, EXYNOS5420_GPIO_C22, EXYNOS5420_GPIO_C23,
@@ -1174,7 +1094,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_C25, EXYNOS5420_GPIO_C26, EXYNOS5420_GPIO_C27,
- EXYNOS5420_GPIO_C30, /* 136 0x88 */
- EXYNOS5420_GPIO_C30, EXYNOS5420_GPIO_C31, EXYNOS5420_GPIO_C32, EXYNOS5420_GPIO_C33,
@@ -1182,7 +1102,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_C35, EXYNOS5420_GPIO_C36, EXYNOS5420_GPIO_C37,
- EXYNOS5420_GPIO_C40, /* 144 0x90 */
- EXYNOS5420_GPIO_C40, EXYNOS5420_GPIO_C41, EXYNOS5420_GPIO_C42, EXYNOS5420_GPIO_C43,
@@ -1190,7 +1110,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_C45, EXYNOS5420_GPIO_C46, EXYNOS5420_GPIO_C47,
- EXYNOS5420_GPIO_D10, /* 152 0x98 */
- EXYNOS5420_GPIO_D10, EXYNOS5420_GPIO_D11, EXYNOS5420_GPIO_D12, EXYNOS5420_GPIO_D13,
@@ -1198,7 +1118,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_D15, EXYNOS5420_GPIO_D16, EXYNOS5420_GPIO_D17,
- EXYNOS5420_GPIO_Y00, /* 160 0xa0 */
- EXYNOS5420_GPIO_Y00, EXYNOS5420_GPIO_Y01, EXYNOS5420_GPIO_Y02, EXYNOS5420_GPIO_Y03,
@@ -1206,7 +1126,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y05, EXYNOS5420_GPIO_Y06, EXYNOS5420_GPIO_Y07,
- EXYNOS5420_GPIO_Y10, /* 168 0xa8 */
- EXYNOS5420_GPIO_Y10, EXYNOS5420_GPIO_Y11, EXYNOS5420_GPIO_Y12, EXYNOS5420_GPIO_Y13,
@@ -1214,7 +1134,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y15, EXYNOS5420_GPIO_Y16, EXYNOS5420_GPIO_Y17,
- EXYNOS5420_GPIO_Y20, /* 176 0xb0 */
- EXYNOS5420_GPIO_Y20, EXYNOS5420_GPIO_Y21, EXYNOS5420_GPIO_Y22, EXYNOS5420_GPIO_Y23,
@@ -1222,7 +1142,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y25, EXYNOS5420_GPIO_Y26, EXYNOS5420_GPIO_Y27,
- EXYNOS5420_GPIO_Y30, /* 184 0xb8 */
- EXYNOS5420_GPIO_Y30, EXYNOS5420_GPIO_Y31, EXYNOS5420_GPIO_Y32, EXYNOS5420_GPIO_Y33,
@@ -1230,7 +1150,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y35, EXYNOS5420_GPIO_Y36, EXYNOS5420_GPIO_Y37,
- EXYNOS5420_GPIO_Y40, /* 192 0xc0 */
- EXYNOS5420_GPIO_Y40, EXYNOS5420_GPIO_Y41, EXYNOS5420_GPIO_Y42, EXYNOS5420_GPIO_Y43,
@@ -1238,7 +1158,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y45, EXYNOS5420_GPIO_Y46, EXYNOS5420_GPIO_Y47,
- EXYNOS5420_GPIO_Y50, /* 200 0xc8 */
- EXYNOS5420_GPIO_Y50, EXYNOS5420_GPIO_Y51, EXYNOS5420_GPIO_Y52, EXYNOS5420_GPIO_Y53,
@@ -1246,7 +1166,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y55, EXYNOS5420_GPIO_Y56, EXYNOS5420_GPIO_Y57,
- EXYNOS5420_GPIO_Y60, /* 208 0xd0 */
- EXYNOS5420_GPIO_Y60, EXYNOS5420_GPIO_Y61, EXYNOS5420_GPIO_Y62, EXYNOS5420_GPIO_Y63,
@@ -1255,9 +1175,8 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_Y66, EXYNOS5420_GPIO_Y67,
- /* GPIO_PART5_STARTS */
- EXYNOS5420_GPIO_MAX_PORT_PART_4,/* 216 0xd8 */
- EXYNOS5420_GPIO_E00 = EXYNOS5420_GPIO_MAX_PORT_PART_4,
- EXYNOS5420_GPIO_E00 = EXYNOS5420_GPIO_MAX_PORT_PART_2, EXYNOS5420_GPIO_E01, EXYNOS5420_GPIO_E02, EXYNOS5420_GPIO_E03,
@@ -1265,7 +1184,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_E05, EXYNOS5420_GPIO_E06, EXYNOS5420_GPIO_E07,
- EXYNOS5420_GPIO_E10, /* 224 0xe0 */
- EXYNOS5420_GPIO_E10, EXYNOS5420_GPIO_E11, EXYNOS5420_GPIO_E12, EXYNOS5420_GPIO_E13,
@@ -1273,7 +1192,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_E15, EXYNOS5420_GPIO_E16, EXYNOS5420_GPIO_E17,
- EXYNOS5420_GPIO_F00, /* 232 0xe8 */
- EXYNOS5420_GPIO_F00, EXYNOS5420_GPIO_F01, EXYNOS5420_GPIO_F02, EXYNOS5420_GPIO_F03,
@@ -1281,7 +1200,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_F05, EXYNOS5420_GPIO_F06, EXYNOS5420_GPIO_F07,
- EXYNOS5420_GPIO_F10, /* 240 0xf0 */
- EXYNOS5420_GPIO_F10, EXYNOS5420_GPIO_F11, EXYNOS5420_GPIO_F12, EXYNOS5420_GPIO_F13,
@@ -1289,7 +1208,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_F15, EXYNOS5420_GPIO_F16, EXYNOS5420_GPIO_F17,
- EXYNOS5420_GPIO_G00, /* 248 0xf8 */
- EXYNOS5420_GPIO_G00, EXYNOS5420_GPIO_G01, EXYNOS5420_GPIO_G02, EXYNOS5420_GPIO_G03,
@@ -1297,7 +1216,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_G05, EXYNOS5420_GPIO_G06, EXYNOS5420_GPIO_G07,
- EXYNOS5420_GPIO_G10, /* 256 0x100 */
- EXYNOS5420_GPIO_G10, EXYNOS5420_GPIO_G11, EXYNOS5420_GPIO_G12, EXYNOS5420_GPIO_G13,
@@ -1305,7 +1224,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_G15, EXYNOS5420_GPIO_G16, EXYNOS5420_GPIO_G17,
- EXYNOS5420_GPIO_G20, /* 264 0x108 */
- EXYNOS5420_GPIO_G20, EXYNOS5420_GPIO_G21, EXYNOS5420_GPIO_G22, EXYNOS5420_GPIO_G23,
@@ -1313,7 +1232,7 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_G25, EXYNOS5420_GPIO_G26, EXYNOS5420_GPIO_G27,
- EXYNOS5420_GPIO_J40, /* 272 0x110 */
- EXYNOS5420_GPIO_J40, EXYNOS5420_GPIO_J41, EXYNOS5420_GPIO_J42, EXYNOS5420_GPIO_J43,
@@ -1322,15 +1241,89 @@ enum exynos5420_gpio_pin { EXYNOS5420_GPIO_J46, EXYNOS5420_GPIO_J47,
- /* GPIO_PART6_STARTS */
- EXYNOS5420_GPIO_MAX_PORT_PART_5,/* 280 0x118 */
- EXYNOS5420_GPIO_Z0 = EXYNOS5420_GPIO_MAX_PORT_PART_5,
- EXYNOS5420_GPIO_A00 = EXYNOS5420_GPIO_MAX_PORT_PART_3,
- EXYNOS5420_GPIO_Z0 = EXYNOS5420_GPIO_MAX_PORT_PART_4, EXYNOS5420_GPIO_Z1, EXYNOS5420_GPIO_Z2, EXYNOS5420_GPIO_Z3, EXYNOS5420_GPIO_Z4, EXYNOS5420_GPIO_Z5, EXYNOS5420_GPIO_Z6,
@@ -1366,14 +1359,13 @@ static struct gpio_info exynos5_gpio_data[EXYNOS5_GPIO_NUM_PARTS] = { { EXYNOS5_GPIO_PART8_BASE, EXYNOS5_GPIO_MAX_PORT }, };
-#define EXYNOS5420_GPIO_NUM_PARTS 6 +#define EXYNOS5420_GPIO_NUM_PARTS 5 static struct gpio_info exynos5420_gpio_data[EXYNOS5420_GPIO_NUM_PARTS] = { { EXYNOS5420_GPIO_PART1_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_1 }, { EXYNOS5420_GPIO_PART2_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_2 }, { EXYNOS5420_GPIO_PART3_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_3 }, { EXYNOS5420_GPIO_PART4_BASE, EXYNOS5420_GPIO_MAX_PORT_PART_4 },
- { EXYNOS5420_GPIO_PART5_BASE,
EXYNOS5420_GPIO_MAX_PORT_PART_5 },
- { EXYNOS5420_GPIO_PART6_BASE, EXYNOS5420_GPIO_MAX_PORT },
- { EXYNOS5420_GPIO_PART5_BASE, EXYNOS5420_GPIO_MAX_PORT },
static inline struct gpio_info *get_gpio_data(void) @@ -1486,17 +1478,17 @@ static const struct gpio_name_num_table exynos5_gpio_table[] = { };
static const struct gpio_name_num_table exynos5420_gpio_table[] = {
- GPIO_ENTRY('a', EXYNOS5420_GPIO_A00, EXYNOS5420_GPIO_B00, 0),
- GPIO_ENTRY('b', EXYNOS5420_GPIO_B00, EXYNOS5420_GPIO_H00, 0),
- GPIO_ENTRY('h', EXYNOS5420_GPIO_H00, EXYNOS5420_GPIO_Y70, 0), GPIO_ENTRY('x', EXYNOS5420_GPIO_X00, EXYNOS5420_GPIO_C00, 0), GPIO_ENTRY('c', EXYNOS5420_GPIO_C00, EXYNOS5420_GPIO_D10, 0),
- GPIO_ENTRY('d', EXYNOS5420_GPIO_D10, EXYNOS5420_GPIO_Y00,
010),
- GPIO_ENTRY('d', EXYNOS5420_GPIO_D10, EXYNOS5420_GPIO_Y00, 0), GPIO_ENTRY('y', EXYNOS5420_GPIO_Y00, EXYNOS5420_GPIO_E00, 0), GPIO_ENTRY('e', EXYNOS5420_GPIO_E00, EXYNOS5420_GPIO_F00, 0), GPIO_ENTRY('f', EXYNOS5420_GPIO_F00, EXYNOS5420_GPIO_G00, 0), GPIO_ENTRY('g', EXYNOS5420_GPIO_G00, EXYNOS5420_GPIO_J40, 0),
- GPIO_ENTRY('j', EXYNOS5420_GPIO_J40, EXYNOS5420_GPIO_Z0,
040),
- GPIO_ENTRY('j', EXYNOS5420_GPIO_J40, EXYNOS5420_GPIO_A00, 0),
- GPIO_ENTRY('h', EXYNOS5420_GPIO_H00, EXYNOS5420_GPIO_Z0, 0), GPIO_ENTRY('z', EXYNOS5420_GPIO_Z0,
EXYNOS5420_GPIO_MAX_PORT, 0), { 0 } };
It may be not relevant here, but please keep in mind that GPIO subsystem is now under porting to device tree. Please check if your patches are in sync with u-boot-dm (device model) tree.
Lukasz Majewski
