[U-Boot] [PATCH 00/12] rockchip: switch to use ARM arch/generic timer
Rockchip SoCs other than rk3188, all with ARM arch/generic timer, which is also default used by kernel, switch to use the ARM arch/generic timer if the SoC have it.
Kever Yang (12): rockchip: rk322x: sdram: use udelay instead of rockchip_udelay rockchip: rk322x: use ARM arch timer instead of rk_timer rockchip: rk3036: sdram: use udelay instead of rockchip_udelay rockchip: rk3036: use ARM arch timer instead of rk_timer rockchip: rk3288: use ARM arch timer instead of rk_timer rockchip: rk3128: use ARM arch timer instead of rk_timer rockchip: remove no use header file in board code rockchip: remove rk_timer rockchip: rk3368: move sgrf init to spl as arch_cpu_init() rockchip: rk3368: enable stimer for rk3368 rockchip: rk3368-lion: switch to use ARM generic timer rockchip: evb-px5: switch to use ARM generic timer
arch/arm/dts/rk3368-lion-u-boot.dtsi | 1 - arch/arm/dts/rk3368-px5-evb-u-boot.dtsi | 1 - arch/arm/include/asm/arch-rockchip/timer.h | 3 - arch/arm/mach-rockchip/Makefile | 6 -- arch/arm/mach-rockchip/rk3036-board-spl.c | 29 ++++++- arch/arm/mach-rockchip/rk3036/sdram_rk3036.c | 19 +++-- arch/arm/mach-rockchip/rk3128-board.c | 3 - arch/arm/mach-rockchip/rk3188-board-spl.c | 1 - arch/arm/mach-rockchip/rk322x-board-spl.c | 30 ++++++++ arch/arm/mach-rockchip/rk322x-board-tpl.c | 33 +++++++- arch/arm/mach-rockchip/rk3288-board-spl.c | 32 +++++++- arch/arm/mach-rockchip/rk3288-board-tpl.c | 25 +++++- arch/arm/mach-rockchip/rk3368-board-spl.c | 33 ++++++++ arch/arm/mach-rockchip/rk3368-board-tpl.c | 81 ++++---------------- arch/arm/mach-rockchip/rk3368/rk3368.c | 73 +++++++++++++++++- arch/arm/mach-rockchip/rk_timer.c | 40 ---------- configs/evb-px5_defconfig | 4 - configs/lion-rk3368_defconfig | 4 - drivers/ram/rockchip/sdram_rk322x.c | 29 ++++--- include/configs/rk3036_common.h | 7 +- include/configs/rk3128_common.h | 7 +- include/configs/rk322x_common.h | 7 +- include/configs/rk3288_common.h | 7 +- include/configs/rk3368_common.h | 3 +- scripts/config_whitelist.txt | 1 + 25 files changed, 302 insertions(+), 177 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk_timer.c
Use system api for udelay instead of vendor defined api, and rockchip_udelay() will be removed.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
drivers/ram/rockchip/sdram_rk322x.c | 29 ++++++++++++++--------------- 1 file changed, 14 insertions(+), 15 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index e96ac54c39..94893e17cf 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -16,7 +16,6 @@ #include <asm/arch-rockchip/grf_rk322x.h> #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/sdram_rk322x.h> -#include <asm/arch-rockchip/timer.h> #include <asm/arch-rockchip/uart.h> #include <asm/arch-rockchip/sdram_common.h> #include <asm/types.h> @@ -96,26 +95,26 @@ void phy_pctrl_reset(struct rk322x_cru *cru, 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT | 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT);
- rockchip_udelay(10); + udelay(10);
rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
clrbits_le32(&ddr_phy->ddrphy_reg[0], SOFT_RESET_MASK << SOFT_RESET_SHIFT); - rockchip_udelay(10); + udelay(10); setbits_le32(&ddr_phy->ddrphy_reg[0], SOFT_DERESET_ANALOG); - rockchip_udelay(5); + udelay(5); setbits_le32(&ddr_phy->ddrphy_reg[0], SOFT_DERESET_DIGITAL);
- rockchip_udelay(1); + udelay(1); }
void phy_dll_bypass_set(struct rk322x_ddr_phy *ddr_phy, u32 freq) @@ -154,7 +153,7 @@ static void send_command(struct rk322x_ddr_pctl *pctl, u32 rank, u32 cmd, u32 arg) { writel((START_CMD | (rank << 20) | arg | cmd), &pctl->mcmd); - rockchip_udelay(1); + udelay(1); while (readl(&pctl->mcmd) & START_CMD) ; } @@ -167,7 +166,7 @@ static void memory_init(struct chan_info *chan,
if (dramtype == DDR3) { send_command(pctl, 3, DESELECT_CMD, 0); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, PREA_CMD, 0); send_command(pctl, 3, MRS_CMD, (0x02 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | @@ -196,17 +195,17 @@ static void memory_init(struct chan_info *chan, (0x63 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (0 & LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); - rockchip_udelay(10); + udelay(10); send_command(pctl, 3, MRS_CMD, (0x10 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (0xff & LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, MRS_CMD, (0x10 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (0xff & LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, MRS_CMD, (1 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | (sdram_params->phy_timing.mr[1] & @@ -243,7 +242,7 @@ static u32 data_training(struct chan_info *chan) DQS_SQU_CAL_SEL_CS0); setbits_le32(&ddr_phy->ddrphy_reg[2], DQS_SQU_CAL_START);
- rockchip_udelay(30); + udelay(30); ret = readl(&ddr_phy->ddrphy_reg[0xff]);
clrbits_le32(&ddr_phy->ddrphy_reg[2], @@ -367,9 +366,9 @@ static void phy_softreset(struct dram_info *dram)
writel(GRF_DDRPHY_BUFFEREN_CORE_EN, &grf->soc_con[0]); clrbits_le32(&ddr_phy->ddrphy_reg[0], 0x3 << 2); - rockchip_udelay(1); + udelay(1); setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 2); - rockchip_udelay(5); + udelay(5); setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 3); writel(GRF_DDRPHY_BUFFEREN_CORE_DIS, &grf->soc_con[0]); }
We prefer to use ARM arch timer instead of rockchip timer, so that we are using the same timer for SPL, U-Boot and Kernel, which will make things simple and easy to track to boot time.
arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk322x-board-spl.c | 30 +++++++++++++++++++++ arch/arm/mach-rockchip/rk322x-board-tpl.c | 33 ++++++++++++++++++++--- include/configs/rk322x_common.h | 7 ++--- scripts/config_whitelist.txt | 1 + 5 files changed, 66 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 0c169e9234..933b0a182a 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -42,7 +42,7 @@ endif obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
ifndef CONFIG_ARM64 -ifndef CONFIG_ROCKCHIP_RK3188 +ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X),) obj-y += rk_timer.o endif endif diff --git a/arch/arm/mach-rockchip/rk322x-board-spl.c b/arch/arm/mach-rockchip/rk322x-board-spl.c index c9b41c62c0..c825e31c02 100644 --- a/arch/arm/mach-rockchip/rk322x-board-spl.c +++ b/arch/arm/mach-rockchip/rk322x-board-spl.c @@ -19,6 +19,31 @@ u32 spl_boot_mode(const u32 boot_device) return MMCSD_MODE_RAW; }
+#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +void rockchip_stimer_init(void) +{ + /* If Timer already enabled, don't re-init it */ + u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + + if (reg & TIMER_EN) + return; + + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +} + #define SGRF_DDR_CON0 0x10150000 void board_init_f(ulong dummy) { @@ -31,6 +56,11 @@ void board_init_f(ulong dummy) } preloader_console_init();
+ /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + /* Disable the ddr secure region setting to make it non-secure */ rk_clrreg(SGRF_DDR_CON0, 0x4000); } diff --git a/arch/arm/mach-rockchip/rk322x-board-tpl.c b/arch/arm/mach-rockchip/rk322x-board-tpl.c index 92d40ee43a..a0d7bc9b05 100644 --- a/arch/arm/mach-rockchip/rk322x-board-tpl.c +++ b/arch/arm/mach-rockchip/rk322x-board-tpl.c @@ -10,13 +10,37 @@ #include <spl.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> -#include <asm/arch-rockchip/timer.h>
u32 spl_boot_device(void) { return BOOT_DEVICE_MMC1; }
+#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +void rockchip_stimer_init(void) +{ + /* If Timer already enabled, don't re-init it */ + u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + + if (reg & TIMER_EN) + return; + + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +} + void board_init_f(ulong dummy) { struct udevice *dev; @@ -39,8 +63,11 @@ void board_init_f(ulong dummy) hang(); }
- rockchip_timer_init(); - printf("timer init done\n"); + /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { printf("DRAM init failed: %d\n", ret); diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index 15bb8d63b8..cc08699944 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -13,9 +13,10 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
-#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) -#define CONFIG_SYS_TIMER_BASE 0x110c00a0 /* TIMER5 */ -#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) +#define CONFIG_ROCKCHIP_STIMER_BASE 0x110d0020 +#define COUNTER_FREQUENCY 24000000 +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 24000000
#define CONFIG_SYS_INIT_SP_ADDR 0x61100000 #define CONFIG_SYS_LOAD_ADDR 0x61800800 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d252045d80..a69badb5d2 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1540,6 +1540,7 @@ CONFIG_RMSTP9_ENA CONFIG_ROCKCHIP_CHIP_TAG CONFIG_ROCKCHIP_MAX_INIT_SIZE CONFIG_ROCKCHIP_SDHCI_MAX_FREQ +CONFIG_ROCKCHIP_STIMER_BASE CONFIG_ROM_STUBS CONFIG_ROOTFS_OFFSET CONFIG_ROOTPATH
arch/arm/mach-rockchip/rk3036/sdram_rk3036.c | 19 +++++++++---------- 1 file changed, 9 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c b/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c index 1d940a0d77..c39cbb8111 100644 --- a/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c +++ b/arch/arm/mach-rockchip/rk3036/sdram_rk3036.c @@ -9,7 +9,6 @@ #include <asm/arch-rockchip/grf_rk3036.h> #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/sdram_rk3036.h> -#include <asm/arch-rockchip/timer.h> #include <asm/arch-rockchip/uart.h>
/* @@ -345,7 +344,7 @@ static void rkdclk_init(struct rk3036_sdram_priv *priv)
/* waiting for pll lock */ while (readl(&pll->con1) & (1 << PLL_LOCK_STATUS_SHIFT)) - rockchip_udelay(1); + udelay(1);
/* PLL enter normal-mode */ rk_clrsetreg(&priv->cru->cru_mode_con, DPLL_MODE_MASK, @@ -373,25 +372,25 @@ void phy_pctrl_reset(struct rk3036_sdram_priv *priv) 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT | 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT);
rk_clrreg(&priv->cru->cru_softrst_con[5], 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
rk_clrreg(&priv->cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT); - rockchip_udelay(10); + udelay(10);
clrsetbits_le32(&ddr_phy->ddrphy_reg1, SOFT_RESET_MASK << SOFT_RESET_SHIFT, 0 << SOFT_RESET_SHIFT); - rockchip_udelay(10); + udelay(10); clrsetbits_le32(&ddr_phy->ddrphy_reg1, SOFT_RESET_MASK << SOFT_RESET_SHIFT, 3 << SOFT_RESET_SHIFT);
void phy_dll_bypass_set(struct rk3036_sdram_priv *priv, unsigned int freq) @@ -444,7 +443,7 @@ static void send_command(struct rk3036_ddr_pctl *pctl, u32 rank, u32 cmd, u32 arg) { writel((START_CMD | (rank << 20) | arg | cmd), &pctl->mcmd); - rockchip_udelay(1); + udelay(1); while (readl(&pctl->mcmd) & START_CMD) ; } @@ -454,7 +453,7 @@ static void memory_init(struct rk3036_sdram_priv *priv) struct rk3036_ddr_pctl *pctl = priv->pctl;
send_command(pctl, 3, DESELECT_CMD, 0); - rockchip_udelay(1); + udelay(1); send_command(pctl, 3, PREA_CMD, 0); send_command(pctl, 3, MRS_CMD, (0x02 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | @@ -492,7 +491,7 @@ static void data_training(struct rk3036_sdram_priv *priv) clrsetbits_le32(&ddr_phy->ddrphy_reg2, 0x03, DQS_SQU_CAL_NORMAL_MODE | DQS_SQU_CAL_START);
- rockchip_udelay(1); + udelay(1); while ((readl(&ddr_phy->ddrphy_reg62) & CAL_DONE_MASK) != (HIGH_8BIT_CAL_DONE | LOW_8BIT_CAL_DONE)) { ;
We prefer to use ARM arch timer instead of rockchip timer, so that we are using the same timer for SPL, U-Boot and Kernel, which will make things simple and easy to track the boot time.
arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3036-board-spl.c | 29 ++++++++++++++++++++--- include/configs/rk3036_common.h | 7 +++--- 3 files changed, 31 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 933b0a182a..2a0db0af80 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -42,7 +42,7 @@ endif obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
ifndef CONFIG_ARM64 -ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X),) +ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036),) obj-y += rk_timer.o endif endif diff --git a/arch/arm/mach-rockchip/rk3036-board-spl.c b/arch/arm/mach-rockchip/rk3036-board-spl.c index 110d06dba5..fbc89b66c4 100644 --- a/arch/arm/mach-rockchip/rk3036-board-spl.c +++ b/arch/arm/mach-rockchip/rk3036-board-spl.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * (C) Copyright 2015-2019 Rockchip Electronics Co., Ltd */
#include <common.h> @@ -8,14 +8,37 @@ #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/sdram_rk3036.h> -#include <asm/arch-rockchip/timer.h> + +#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE (0 << 1) +#define TIMER_RMODE (1 << 1) + +void rockchip_stimer_init(void) +{ + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +}
void board_init_f(ulong dummy) { #ifdef CONFIG_DEBUG_UART debug_uart_init(); #endif - rockchip_timer_init(); + + /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + sdram_init();
/* return to maskrom */ diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index f5d09d18e5..73be079b20 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -12,9 +12,10 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
-#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) -#define CONFIG_SYS_TIMER_BASE 0x200440a0 /* TIMER5 */ -#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) +#define CONFIG_ROCKCHIP_STIMER_BASE 0x200440a0 +#define COUNTER_FREQUENCY 24000000 +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 24000000
#define CONFIG_SYS_INIT_SP_ADDR 0x60100000 #define CONFIG_SYS_LOAD_ADDR 0x60800800
arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3288-board-spl.c | 32 +++++++++++++++++++++-- arch/arm/mach-rockchip/rk3288-board-tpl.c | 25 ++++++++++++++++-- include/configs/rk3288_common.h | 7 ++--- 4 files changed, 58 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 2a0db0af80..3e3aa1c421 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -42,7 +42,7 @@ endif obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
ifndef CONFIG_ARM64 -ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036),) +ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036)$(CONFIG_ROCKCHIP_RK3288),) obj-y += rk_timer.o endif endif diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index 3869de9119..c2e168192c 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -22,7 +22,6 @@ #include <asm/arch-rockchip/sdram.h> #include <asm/arch-rockchip/sdram_common.h> #include <asm/arch-rockchip/sys_proto.h> -#include <asm/arch-rockchip/timer.h> #include <dm/root.h> #include <dm/test.h> #include <dm/util.h> @@ -108,6 +107,31 @@ __weak int arch_cpu_init(void) return 0; }
+#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +void rockchip_stimer_init(void) +{ + /* If Timer already enabled, don't re-init it */ + u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + + if (reg & TIMER_EN) + return; + + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +} + void board_init_f(ulong dummy) { struct udevice *dev; @@ -131,7 +155,11 @@ void board_init_f(ulong dummy) hang(); }
- rockchip_timer_init(); + /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + arch_cpu_init();
ret = rockchip_get_clk(&dev); diff --git a/arch/arm/mach-rockchip/rk3288-board-tpl.c b/arch/arm/mach-rockchip/rk3288-board-tpl.c index 5adbe92185..96de7927f0 100644 --- a/arch/arm/mach-rockchip/rk3288-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3288-board-tpl.c @@ -12,7 +12,25 @@ #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> -#include <asm/arch-rockchip/timer.h> + +#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +void rockchip_stimer_init(void) +{ + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +}
void board_init_f(ulong dummy) { @@ -36,7 +54,10 @@ void board_init_f(ulong dummy) hang(); }
ret = rockchip_get_clk(&dev); if (ret) { diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 06073cbb61..5472a90633 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -13,9 +13,10 @@ #define CONFIG_SYS_MALLOC_LEN (32 << 20) #define CONFIG_SYS_CBSIZE 1024
-#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) -#define CONFIG_SYS_TIMER_BASE 0xff810020 /* TIMER7 */ -#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) +#define CONFIG_ROCKCHIP_STIMER_BASE 0xff810020 +#define COUNTER_FREQUENCY 24000000 +#define CONFIG_SYS_ARCH_TIMER +#define CONFIG_SYS_HZ_CLOCK 24000000
#ifdef CONFIG_SPL_ROCKCHIP_BACK_TO_BROM /* Bootrom will load u-boot binary to 0x0 once return from SPL */
arch/arm/mach-rockchip/Makefile | 6 ------ arch/arm/mach-rockchip/rk3128-board.c | 3 --- include/configs/rk3128_common.h | 7 ++++--- 3 files changed, 4 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 3e3aa1c421..9afbb055d5 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -41,12 +41,6 @@ endif
-ifndef CONFIG_ARM64 -ifeq ($(CONFIG_ROCKCHIP_RK3188)$(CONFIG_ROCKCHIP_RK322X)$(CONFIG_ROCKCHIP_RK3036)$(CONFIG_ROCKCHIP_RK3288),) -obj-y += rk_timer.o -endif -endif - obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ obj-$(CONFIG_ROCKCHIP_RK3128) += rk3128/ ifndef CONFIG_TPL_BUILD diff --git a/arch/arm/mach-rockchip/rk3128-board.c b/arch/arm/mach-rockchip/rk3128-board.c index fa71685af8..0945829d0e 100644 --- a/arch/arm/mach-rockchip/rk3128-board.c +++ b/arch/arm/mach-rockchip/rk3128-board.c @@ -12,7 +12,6 @@ #include <asm/arch-rockchip/periph.h> #include <asm/arch-rockchip/grf_rk3128.h> #include <asm/arch-rockchip/boot_mode.h> -#include <asm/arch-rockchip/timer.h> #include <power/regulator.h>
DECLARE_GLOBAL_DATA_PTR; @@ -33,8 +32,6 @@ int board_init(void) { int ret = 0;
- rockchip_timer_init(); - ret = regulators_enable_boot_on(false); if (ret) { debug("%s: Cannot enable boot on regulator\n", __func__); diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index 0c08d7af5b..20d62439fb 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -14,9 +14,10 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
The timer.h is no use any more, remove it from the board files.
arch/arm/mach-rockchip/rk3188-board-spl.c | 1 - arch/arm/mach-rockchip/rk3368-board-tpl.c | 1 - 2 files changed, 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3188-board-spl.c b/arch/arm/mach-rockchip/rk3188-board-spl.c index 84c2a5756f..c3efe0d7a9 100644 --- a/arch/arm/mach-rockchip/rk3188-board-spl.c +++ b/arch/arm/mach-rockchip/rk3188-board-spl.c @@ -22,7 +22,6 @@ #include <asm/arch-rockchip/periph.h> #include <asm/arch-rockchip/pmu_rk3188.h> #include <asm/arch-rockchip/sdram.h> -#include <asm/arch-rockchip/timer.h> #include <dm/root.h> #include <dm/test.h> #include <dm/util.h> diff --git a/arch/arm/mach-rockchip/rk3368-board-tpl.c b/arch/arm/mach-rockchip/rk3368-board-tpl.c index dc65a021c8..42aeb2e91c 100644 --- a/arch/arm/mach-rockchip/rk3368-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3368-board-tpl.c @@ -14,7 +14,6 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rk3368.h> #include <asm/arch-rockchip/hardware.h> -#include <asm/arch-rockchip/timer.h>
/* * The SPL (and also the full U-Boot stage on the RK3368) will run in
We have convert all SoC to use DM timer or ARM arch/generic timer, we can remove this rk_timer now.
arch/arm/include/asm/arch-rockchip/timer.h | 3 -- arch/arm/mach-rockchip/rk_timer.c | 40 ---------------------- 2 files changed, 43 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk_timer.c
diff --git a/arch/arm/include/asm/arch-rockchip/timer.h b/arch/arm/include/asm/arch-rockchip/timer.h index a8379be912..77b5422044 100644 --- a/arch/arm/include/asm/arch-rockchip/timer.h +++ b/arch/arm/include/asm/arch-rockchip/timer.h @@ -15,7 +15,4 @@ struct rk_timer { u32 timer_int_status; };
-void rockchip_timer_init(void); -void rockchip_udelay(unsigned int usec); - #endif diff --git a/arch/arm/mach-rockchip/rk_timer.c b/arch/arm/mach-rockchip/rk_timer.c deleted file mode 100644 index 29d379fa0a..0000000000 --- a/arch/arm/mach-rockchip/rk_timer.c +++ /dev/null @@ -1,40 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2015 Rockchip Electronics Co., Ltd - */ - -#include <common.h> -#include <asm/arch-rockchip/timer.h> -#include <asm/io.h> -#include <linux/types.h> - -struct rk_timer * const timer_ptr = (void *)CONFIG_SYS_TIMER_BASE; - -static uint64_t rockchip_get_ticks(void) -{ - uint64_t timebase_h, timebase_l; - - timebase_l = readl(&timer_ptr->timer_curr_value0); - timebase_h = readl(&timer_ptr->timer_curr_value1); - - return timebase_h << 32 | timebase_l; -} - -void rockchip_udelay(unsigned int usec) -{ - uint64_t tmp; - - /* get timestamp */ - tmp = rockchip_get_ticks() + usec_to_tick(usec); - - /* loop till event */ - while (rockchip_get_ticks() < tmp+1) - ; -} - -void rockchip_timer_init(void) -{ - writel(0xffffffff, &timer_ptr->timer_load_count0); - writel(0xffffffff, &timer_ptr->timer_load_count1); - writel(1, &timer_ptr->timer_ctrl_reg); -}
The SoC related init will move to SPL and keep TPL clean, so that we can reuse the common TPL board file.
arch/arm/mach-rockchip/rk3368-board-spl.c | 6 ++ arch/arm/mach-rockchip/rk3368-board-tpl.c | 69 --------------------- arch/arm/mach-rockchip/rk3368/rk3368.c | 73 ++++++++++++++++++++++- 3 files changed, 78 insertions(+), 70 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c index c651193712..3a7d0b640a 100644 --- a/arch/arm/mach-rockchip/rk3368-board-spl.c +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -11,6 +11,11 @@ #include <asm/io.h> #include <asm/arch-rockchip/periph.h>
+__weak int arch_cpu_init(void) +{ + return 0; +} + void board_init_f(ulong dummy) { struct udevice *dev; @@ -22,6 +27,7 @@ void board_init_f(ulong dummy) hang(); }
+ arch_cpu_init(); preloader_console_init();
ret = uclass_get_device(UCLASS_RAM, 0, &dev); diff --git a/arch/arm/mach-rockchip/rk3368-board-tpl.c b/arch/arm/mach-rockchip/rk3368-board-tpl.c index 42aeb2e91c..a1da8ccb0f 100644 --- a/arch/arm/mach-rockchip/rk3368-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3368-board-tpl.c @@ -8,74 +8,8 @@ #include <dm.h> #include <ram.h> #include <spl.h> -#include <syscon.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> -#include <asm/arch-rockchip/clock.h> -#include <asm/arch-rockchip/cru_rk3368.h> -#include <asm/arch-rockchip/hardware.h> - -/* - * The SPL (and also the full U-Boot stage on the RK3368) will run in - * secure mode (i.e. EL3) and an ATF will eventually be booted before - * starting up the operating system... so we can initialize the SGRF - * here and rely on the ATF installing the final (secure) policy - * later. - */ -static inline uintptr_t sgrf_soc_con_addr(unsigned no) -{ - const uintptr_t SGRF_BASE = - (uintptr_t)syscon_get_first_range(ROCKCHIP_SYSCON_SGRF); - - return SGRF_BASE + sizeof(u32) * no; -} - -static inline uintptr_t sgrf_busdmac_addr(unsigned no) -{ - const uintptr_t SGRF_BASE = - (uintptr_t)syscon_get_first_range(ROCKCHIP_SYSCON_SGRF); - const uintptr_t SGRF_BUSDMAC_OFFSET = 0x100; - const uintptr_t SGRF_BUSDMAC_BASE = SGRF_BASE + SGRF_BUSDMAC_OFFSET; - - return SGRF_BUSDMAC_BASE + sizeof(u32) * no; -} - -static void sgrf_init(void) -{ - struct rk3368_cru * const cru = - (struct rk3368_cru * const)rockchip_get_cru(); - const u16 SGRF_SOC_CON_SEC = GENMASK(15, 0); - const u16 SGRF_BUSDMAC_CON0_SEC = BIT(2); - const u16 SGRF_BUSDMAC_CON1_SEC = GENMASK(15, 12); - - /* Set all configurable IP to 'non secure'-mode */ - rk_setreg(sgrf_soc_con_addr(5), SGRF_SOC_CON_SEC); - rk_setreg(sgrf_soc_con_addr(6), SGRF_SOC_CON_SEC); - rk_setreg(sgrf_soc_con_addr(7), SGRF_SOC_CON_SEC); - - /* - * From rockchip-uboot/arch/arm/cpu/armv8/rk33xx/cpu.c - * Original comment: "ddr space set no secure mode" - */ - rk_clrreg(sgrf_soc_con_addr(8), SGRF_SOC_CON_SEC); - rk_clrreg(sgrf_soc_con_addr(9), SGRF_SOC_CON_SEC); - rk_clrreg(sgrf_soc_con_addr(10), SGRF_SOC_CON_SEC); - - /* Set 'secure dma' to 'non secure'-mode */ - rk_setreg(sgrf_busdmac_addr(0), SGRF_BUSDMAC_CON0_SEC); - rk_setreg(sgrf_busdmac_addr(1), SGRF_BUSDMAC_CON1_SEC); - - dsb(); /* barrier */ - - rk_setreg(&cru->softrst_con[1], DMA1_SRST_REQ); - rk_setreg(&cru->softrst_con[4], DMA2_SRST_REQ); - - dsb(); /* barrier */ - udelay(10); - - rk_clrreg(&cru->softrst_con[1], DMA1_SRST_REQ); - rk_clrreg(&cru->softrst_con[4], DMA2_SRST_REQ); -}
void board_init_f(ulong dummy) { @@ -101,9 +35,6 @@ void board_init_f(ulong dummy) hang(); }
- /* Reset security, so we can use DMA in the MMC drivers */ - sgrf_init(); - ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { debug("DRAM init failed: %d\n", ret); diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index f06d27717d..ffb27b5c8b 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -5,12 +5,13 @@ */
#include <common.h> +#include <syscon.h> #include <asm/armv8/mmu.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rk3368.h> #include <asm/arch-rockchip/grf_rk3368.h> -#include <syscon.h> +#include <asm/arch-rockchip/hardware.h>
@@ -166,4 +167,74 @@ void board_debug_uart_init(void) GPIO2A5_MASK, GPIO2A5_UART2_SOUT); #endif } + +/* + * The SPL (and also the full U-Boot stage on the RK3368) will run in + * secure mode (i.e. EL3) and an ATF will eventually be booted before + * starting up the operating system... so we can initialize the SGRF + * here and rely on the ATF installing the final (secure) policy + * later. + */ +static inline uintptr_t sgrf_soc_con_addr(unsigned int no) +{ + const uintptr_t SGRF_BASE = + (uintptr_t)syscon_get_first_range(ROCKCHIP_SYSCON_SGRF); + + return SGRF_BASE + sizeof(u32) * no; +} + +static inline uintptr_t sgrf_busdmac_addr(unsigned int no) +{ + const uintptr_t SGRF_BASE = + (uintptr_t)syscon_get_first_range(ROCKCHIP_SYSCON_SGRF); + const uintptr_t SGRF_BUSDMAC_OFFSET = 0x100; + const uintptr_t SGRF_BUSDMAC_BASE = SGRF_BASE + SGRF_BUSDMAC_OFFSET; + + return SGRF_BUSDMAC_BASE + sizeof(u32) * no; +} + +static void sgrf_init(void) +{ + struct rk3368_cru * const cru = + (struct rk3368_cru * const)rockchip_get_cru(); + const u16 SGRF_SOC_CON_SEC = GENMASK(15, 0); + const u16 SGRF_BUSDMAC_CON0_SEC = BIT(2); + const u16 SGRF_BUSDMAC_CON1_SEC = GENMASK(15, 12); + + /* Set all configurable IP to 'non secure'-mode */ + rk_setreg(sgrf_soc_con_addr(5), SGRF_SOC_CON_SEC); + rk_setreg(sgrf_soc_con_addr(6), SGRF_SOC_CON_SEC); + rk_setreg(sgrf_soc_con_addr(7), SGRF_SOC_CON_SEC); + + /* + * From rockchip-uboot/arch/arm/cpu/armv8/rk33xx/cpu.c + * Original comment: "ddr space set no secure mode" + */ + rk_clrreg(sgrf_soc_con_addr(8), SGRF_SOC_CON_SEC); + rk_clrreg(sgrf_soc_con_addr(9), SGRF_SOC_CON_SEC); + rk_clrreg(sgrf_soc_con_addr(10), SGRF_SOC_CON_SEC); + + /* Set 'secure dma' to 'non secure'-mode */ + rk_setreg(sgrf_busdmac_addr(0), SGRF_BUSDMAC_CON0_SEC); + rk_setreg(sgrf_busdmac_addr(1), SGRF_BUSDMAC_CON1_SEC); + + dsb(); /* barrier */ + + rk_setreg(&cru->softrst_con[1], DMA1_SRST_REQ); + rk_setreg(&cru->softrst_con[4], DMA2_SRST_REQ); + + dsb(); /* barrier */ + udelay(10); + + rk_clrreg(&cru->softrst_con[1], DMA1_SRST_REQ); + rk_clrreg(&cru->softrst_con[4], DMA2_SRST_REQ); +} + +int arch_cpu_init(void) +{ + /* Reset security, so we can use DMA in the MMC drivers */ + sgrf_init(); + + return 0; +} #endif
Add stimer_init() for spl/tpl so that we able to switch to use arch timer.
arch/arm/mach-rockchip/rk3368-board-spl.c | 27 +++++++++++++++++++++++ arch/arm/mach-rockchip/rk3368-board-tpl.c | 21 ++++++++++++++++++ include/configs/rk3368_common.h | 3 ++- 3 files changed, 50 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c index 3a7d0b640a..6ba106c63b 100644 --- a/arch/arm/mach-rockchip/rk3368-board-spl.c +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -16,6 +16,28 @@ __weak int arch_cpu_init(void) return 0; }
+#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +void rockchip_stimer_init(void) +{ + /* If Timer already enabled, don't re-init it */ + u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + + if (reg & TIMER_EN) + return; + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +} + void board_init_f(ulong dummy) { struct udevice *dev; @@ -27,6 +49,11 @@ void board_init_f(ulong dummy) hang(); }
+ /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ + timer_init(); + arch_cpu_init(); preloader_console_init();
diff --git a/arch/arm/mach-rockchip/rk3368-board-tpl.c b/arch/arm/mach-rockchip/rk3368-board-tpl.c index a1da8ccb0f..fdb1c3b365 100644 --- a/arch/arm/mach-rockchip/rk3368-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3368-board-tpl.c @@ -11,6 +11,22 @@ #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h>
+#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +__weak void rockchip_stimer_init(void) +{ + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +} + void board_init_f(ulong dummy) { struct udevice *dev; @@ -35,6 +51,11 @@ void board_init_f(ulong dummy) hang(); }
+ /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/ */ + timer_init(); + ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { debug("DRAM init failed: %d\n", ret); diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 13630ba386..c5a52d46c9 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -20,7 +20,8 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
-#define COUNTER_FREQUENCY 24000000 +#define CONFIG_ROCKCHIP_STIMER_BASE 0xff810020 +#define COUNTER_FREQUENCY 24000000
#define CONFIG_SYS_NS16550_MEM32
Default to use ARM generic timer in ARM64, switch from rk timer to generic timer.
arch/arm/dts/rk3368-lion-u-boot.dtsi | 1 - configs/lion-rk3368_defconfig | 4 ---- 2 files changed, 5 deletions(-)
diff --git a/arch/arm/dts/rk3368-lion-u-boot.dtsi b/arch/arm/dts/rk3368-lion-u-boot.dtsi index fb4a4fb59c..edc93e438f 100644 --- a/arch/arm/dts/rk3368-lion-u-boot.dtsi +++ b/arch/arm/dts/rk3368-lion-u-boot.dtsi @@ -12,7 +12,6 @@ chosen { stdout-path = "serial0:115200n8"; u-boot,spl-boot-order = &emmc, &sdmmc; - tick-timer = "/timer@ff810000"; };
}; diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index ff3255be7a..2c4e11c4d4 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -88,10 +88,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_TPL_TIMER=y -CONFIG_ROCKCHIP_TIMER=y CONFIG_USE_TINY_PRINTF=y CONFIG_SPL_TINY_MEMSET=y CONFIG_LZO=y
arch/arm/dts/rk3368-px5-evb-u-boot.dtsi | 1 - configs/evb-px5_defconfig | 4 ---- 2 files changed, 5 deletions(-)
diff --git a/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi b/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi index f5406d4c7e..002767a033 100644 --- a/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi @@ -5,7 +5,6 @@ / { chosen { u-boot,spl-boot-order = &emmc; - tick-timer = "/timer@ff810000"; }; };
diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 9afba9b873..a2b72c765d 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -67,10 +67,6 @@ CONFIG_DM_RESET=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_SYSRESET=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_TPL_TIMER=y -CONFIG_ROCKCHIP_TIMER=y CONFIG_USE_TINY_PRINTF=y CONFIG_PANIC_HANG=y CONFIG_SPL_TINY_MEMSET=y
Kever Yang
