[U-Boot] [PATCH v4 1/2] mx6: Factor out common HDMI setup code
Instead of duplicating HDMI setup code for every mx6 board, factor out the common code
Signed-off-by: Pardeep Kumar Singla b45784@freescale.com --- Changes since v3: Added declaration of enable_ipu_clock(). Made enable_ipu_clock() function public.
arch/arm/cpu/armv7/mx6/clock.c | 8 +++++ arch/arm/cpu/armv7/mx6/soc.c | 43 +++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/clock.h | 2 +- arch/arm/include/asm/arch-mx6/mxc_hdmi.h | 5 +++ board/boundary/nitrogen6x/nitrogen6x.c | 44 ++++------------------- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 46 +++++-------------------- board/wandboard/wandboard.c | 44 +++-------------------- include/configs/mx6qsabrelite.h | 1 + include/configs/nitrogen6x.h | 1 + include/configs/wandboard.h | 1 + 10 files changed, 79 insertions(+), 116 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 3c0d908..a724e66 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -468,6 +468,14 @@ int do_mx6_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+void enable_ipu_clock() +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + int reg; + reg = readl(&mxc_ccm->CCGR3); + reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET; + writel(reg, &mxc_ccm->CCGR3); +} /***************************************************/
U_BOOT_CMD( diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index fc436fb..a79369f 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -32,6 +32,8 @@ #include <asm/imx-common/boot_mode.h> #include <asm/imx-common/dma.h> #include <stdbool.h> +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/crm_regs.h>
struct scu_regs { u32 ctrl; @@ -228,3 +230,44 @@ const struct boot_mode soc_boot_modes[] = { void s_init(void) { } + +#ifdef CONFIG_IMX_HDMI +void imx_enable_hdmi_phy(void) +{ + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + u8 reg; + reg = readb(&hdmi->phy_conf0); + reg |= HDMI_PHY_CONF0_PDZ_MASK; + writeb(reg, &hdmi->phy_conf0); + udelay(3000); + reg |= HDMI_PHY_CONF0_ENTMDS_MASK; + writeb(reg, &hdmi->phy_conf0); + udelay(3000); + reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; + writeb(reg, &hdmi->phy_conf0); + writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); +} + +void imx_setup_hdmi(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + int reg; + + /* Turn on HDMI PHY clock */ + reg = readl(&mxc_ccm->CCGR2); + reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK| + MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; + writel(reg, &mxc_ccm->CCGR2); + writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); + reg = readl(&mxc_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK| + MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK| + MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); + reg |= (CHSCCDR_PODF_DIVIDE_BY_3 + << MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) + |(CHSCCDR_IPU_PRE_CLK_540M_PFD + << MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); +} +#endif diff --git a/arch/arm/include/asm/arch-mx6/clock.h b/arch/arm/include/asm/arch-mx6/clock.h index cfd4edc..d9f7fc5 100644 --- a/arch/arm/include/asm/arch-mx6/clock.h +++ b/arch/arm/include/asm/arch-mx6/clock.h @@ -65,5 +65,5 @@ void enable_ocotp_clk(unsigned char enable); void enable_usboh3_clk(unsigned char enable); int enable_sata_clock(void); int enable_i2c_clk(unsigned char enable, unsigned i2c_num); - +void enable_ipu_clock(); #endif /* __ASM_ARCH_CLOCK_H */ diff --git a/arch/arm/include/asm/arch-mx6/mxc_hdmi.h b/arch/arm/include/asm/arch-mx6/mxc_hdmi.h index 9dccb3f..5cd6aa6 100644 --- a/arch/arm/include/asm/arch-mx6/mxc_hdmi.h +++ b/arch/arm/include/asm/arch-mx6/mxc_hdmi.h @@ -21,6 +21,11 @@ #ifndef __MXC_HDMI_H__ #define __MXC_HDMI_H__
+#ifdef CONFIG_IMX_HDMI +void imx_enable_hdmi_phy(void); +void imx_setup_hdmi(void); +#endif + /* * Hdmi controller registers */ diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 8f0f9b8..1b82633 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -480,22 +480,9 @@ static int detect_hdmi(struct display_info_t const *dev) return readb(&hdmi->phy_stat0) & HDMI_PHY_HPD; }
-static void enable_hdmi(struct display_info_t const *dev) +static void do_enable_hdmi(struct display_info_t const *dev) { - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - u8 reg; - printf("%s: setup HDMI monitor\n", __func__); - reg = readb(&hdmi->phy_conf0); - reg |= HDMI_PHY_CONF0_PDZ_MASK; - writeb(reg, &hdmi->phy_conf0); - - udelay(3000); - reg |= HDMI_PHY_CONF0_ENTMDS_MASK; - writeb(reg, &hdmi->phy_conf0); - udelay(3000); - reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; - writeb(reg, &hdmi->phy_conf0); - writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); + imx_enable_hdmi_phy(); }
static int detect_i2c(struct display_info_t const *dev) @@ -528,7 +515,7 @@ static struct display_info_t const displays[] = {{ .addr = 0, .pixfmt = IPU_PIX_FMT_RGB24, .detect = detect_hdmi, - .enable = enable_hdmi, + .enable = do_enable_hdmi, .mode = { .name = "HDMI", .refresh = 60, @@ -653,25 +640,15 @@ static void setup_display(void) struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - int reg;
+ enable_ipu_clock(); + imx_setup_hdmi(); /* Turn on LDB0,IPU,IPU DI0 clocks */ reg = __raw_readl(&mxc_ccm->CCGR3); - reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET - |MXC_CCM_CCGR3_LDB_DI0_MASK; + reg |= MXC_CCM_CCGR3_LDB_DI0_MASK; writel(reg, &mxc_ccm->CCGR3);
- /* Turn on HDMI PHY clock */ - reg = __raw_readl(&mxc_ccm->CCGR2); - reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK - |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; - writel(reg, &mxc_ccm->CCGR2); - - /* clear HDMI PHY reset */ - writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); - /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); @@ -689,15 +666,8 @@ static void setup_display(void) writel(reg, &mxc_ccm->cscmr2);
reg = readl(&mxc_ccm->chsccdr); - reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); reg |= (CHSCCDR_CLK_SEL_LDB_DI0 - <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) - |(CHSCCDR_PODF_DIVIDE_BY_3 - <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) - |(CHSCCDR_IPU_PRE_CLK_540M_PFD - <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET); writel(reg, &mxc_ccm->chsccdr);
reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 862bc30..3ac4f71 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -452,24 +452,10 @@ static int detect_hdmi(struct display_info_t const *dev) return readb(&hdmi->phy_stat0) & HDMI_PHY_HPD; }
-static void enable_hdmi(struct display_info_t const *dev) +static void do_enable_hdmi(struct display_info_t const *dev) { - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - u8 reg; - printf("%s: setup HDMI monitor\n", __func__); - reg = readb(&hdmi->phy_conf0); - reg |= HDMI_PHY_CONF0_PDZ_MASK; - writeb(reg, &hdmi->phy_conf0); - - udelay(3000); - reg |= HDMI_PHY_CONF0_ENTMDS_MASK; - writeb(reg, &hdmi->phy_conf0); - udelay(3000); - reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; - writeb(reg, &hdmi->phy_conf0); - writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); + imx_enable_hdmi_phy(); } - static int detect_i2c(struct display_info_t const *dev) { return ((0 == i2c_set_bus_num(dev->bus)) @@ -500,7 +486,7 @@ static struct display_info_t const displays[] = {{ .addr = 0, .pixfmt = IPU_PIX_FMT_RGB24, .detect = detect_hdmi, - .enable = enable_hdmi, + .enable = do_enable_hdmi, .mode = { .name = "HDMI", .refresh = 60, @@ -625,25 +611,16 @@ static void setup_display(void) struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - int reg;
+ enable_ipu_clock(); + imx_setup_hdmi(); + /* Turn on LDB0,IPU,IPU DI0 clocks */ reg = __raw_readl(&mxc_ccm->CCGR3); - reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET - |MXC_CCM_CCGR3_LDB_DI0_MASK; + reg |= MXC_CCM_CCGR3_LDB_DI0_MASK; writel(reg, &mxc_ccm->CCGR3);
- /* Turn on HDMI PHY clock */ - reg = __raw_readl(&mxc_ccm->CCGR2); - reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK - |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; - writel(reg, &mxc_ccm->CCGR2); - - /* clear HDMI PHY reset */ - writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); - /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); @@ -661,15 +638,8 @@ static void setup_display(void) writel(reg, &mxc_ccm->cscmr2);
reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 43c02ac..6cd28ed 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -211,23 +211,6 @@ int board_phy_config(struct phy_device *phydev) }
#if defined(CONFIG_VIDEO_IPUV3) -static void enable_hdmi(void) -{ - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - u8 reg; - reg = readb(&hdmi->phy_conf0); - reg |= HDMI_PHY_CONF0_PDZ_MASK; - writeb(reg, &hdmi->phy_conf0); - - udelay(3000); - reg |= HDMI_PHY_CONF0_ENTMDS_MASK; - writeb(reg, &hdmi->phy_conf0); - udelay(3000); - reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; - writeb(reg, &hdmi->phy_conf0); - writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); -} - static struct fb_videomode const hdmi = { .name = "HDMI", .refresh = 60, @@ -253,7 +236,7 @@ int board_video_skip(void) if (ret) printf("HDMI cannot be configured: %d\n", ret);
- enable_hdmi(); + imx_enable_hdmi_phy();
return ret; } @@ -261,33 +244,14 @@ int board_video_skip(void) static void setup_display(void) { struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; int reg;
- /* Turn on IPU clock */ - reg = readl(&mxc_ccm->CCGR3); - reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET; - writel(reg, &mxc_ccm->CCGR3); - - /* Turn on HDMI PHY clock */ - reg = readl(&mxc_ccm->CCGR2); - reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK - | MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; - writel(reg, &mxc_ccm->CCGR2); - - /* clear HDMI PHY reset */ - writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); + enable_ipu_clock(); + imx_setup_hdmi();
reg = readl(&mxc_ccm->chsccdr); - reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK - | MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK - | MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); reg |= (CHSCCDR_CLK_SEL_LDB_DI0 - << MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) - | (CHSCCDR_PODF_DIVIDE_BY_3 - << MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) - | (CHSCCDR_IPU_PRE_CLK_540M_PFD - << MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + << MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET); writel(reg, &mxc_ccm->chsccdr); } #endif /* CONFIG_VIDEO_IPUV3 */ diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index c7db81d..6127347 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -141,6 +141,7 @@ #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_IMX_HDMI
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 74df66c..0b665dc 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -154,6 +154,7 @@ #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT #define CONFIG_CONSOLE_MUX +#define CONFIG_IMX_HDMI
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index dd06bd7..1f83e89 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -100,6 +100,7 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_IMX_HDMI
#if defined(CONFIG_MX6DL) #define CONFIG_DEFAULT_FDT_FILE "imx6dl-wandboard.dtb"
Signed-off-by: Pardeep Kumar Singla b45784@freescale.com --- Changes since v3: Added enable_ipu_clock() function for ipu clock setting
board/freescale/mx6sabresd/mx6sabresd.c | 64 ++++++++++++++++++++++++++++++- include/configs/mx6sabre_common.h | 3 +- include/configs/mx6sabresd.h | 19 +++++++++ 3 files changed, 84 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 222ee98..4694b5c 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -29,7 +29,12 @@ #include <fsl_esdhc.h> #include <miiphy.h> #include <netdev.h> - +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/crm_regs.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ @@ -239,6 +244,60 @@ int board_phy_config(struct phy_device *phydev) return 0; }
+#if defined(CONFIG_VIDEO_IPUV3) +static struct fb_videomode const hdmi = { + .name = "HDMI", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +}; + +int board_video_skip(void) +{ + int ret; + + ret = ipuv3_fb_init(&hdmi, 0, IPU_PIX_FMT_RGB24); + + if (ret) + printf("HDMI cannot be configured: %d\n", ret); + + imx_enable_hdmi_phy(); + return ret; +} + +static void setup_display(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + int reg; + + enable_ipu_clock(); + imx_setup_hdmi(); + + reg = readl(&mxc_ccm->chsccdr); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + << MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); +} +#endif /* CONFIG_VIDEO_IPUV3 */ + +/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + int board_eth_init(bd_t *bis) { int ret; @@ -255,6 +314,9 @@ int board_eth_init(bd_t *bis) int board_early_init_f(void) { setup_iomux_uart(); +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif
return 0; } diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 53cc559..dd93fff 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -20,6 +20,7 @@ #define CONFIG_MX6
#include "mx6_common.h" +#include <asm/sizes.h>
#define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO @@ -32,7 +33,7 @@ #define CONFIG_REVISION_TAG
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +#define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 76675f4..5637c19 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -17,6 +17,9 @@ #ifndef __MX6QSABRESD_CONFIG_H #define __MX6QSABRESD_CONFIG_H
+#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + #define CONFIG_MACH_TYPE 3980 #define CONFIG_MXC_UART_BASE UART1_BASE #define CONFIG_CONSOLE_DEV "ttymxc0" @@ -31,4 +34,20 @@ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SDHC3 */ #endif
+/* Framebuffer */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_VIDEO_BMP_LOGO +#define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_IMX_HDMI + #endif /* __MX6QSABRESD_CONFIG_H */
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
- struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- int reg;
- u8 reg;
- udelay(3000);
- udelay(3000);
- int reg;
- reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK|
- reg = readl(&mxc_ccm->chsccdr);
- reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK|
- reg |= (CHSCCDR_PODF_DIVIDE_BY_3
- writel(reg, &mxc_ccm->chsccdr);
- Hdmi controller registers
- u8 reg;
- udelay(3000);
- udelay(3000);
- .enable = do_enable_hdmi, .mode = { .name = "HDMI", .refresh = 60,
- int reg;
- enable_ipu_clock();
- imx_setup_hdmi(); /* Turn on LDB0,IPU,IPU DI0 clocks */ reg = __raw_readl(&mxc_ccm->CCGR3);
- reg |= MXC_CCM_CCGR3_LDB_DI0_MASK; writel(reg, &mxc_ccm->CCGR3);
reg |= (CHSCCDR_CLK_SEL_LDB_DI0|MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK);
- u8 reg;
- udelay(3000);
- udelay(3000);
}imx_enable_hdmi_phy();
- int reg;
- imx_setup_hdmi();
- /* Turn on LDB0,IPU,IPU DI0 clocks */ reg = __raw_readl(&mxc_ccm->CCGR3);
- u8 reg;
- udelay(3000);
- udelay(3000);
- enable_hdmi();
return ret; }
enable_ipu_clock();
imx_setup_hdmi();
reg |= (CHSCCDR_CLK_SEL_LDB_DI0| MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK);
writel(reg, &mxc_ccm->chsccdr); } #endif /* CONFIG_VIDEO_IPUV3 */<< MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET);
Acked-By: Eric Nelson eric.nelson@boundarydevices.com
Hi Pardeep,
This generates a warning:
warning: function declaration isn't a prototype [-Wstrict-prototypes]
I fix it myself.
Eric Nelson
Stefano Babic
