RE:[U-Boot-Users] U-Boot Not Loading Successfully
Sam, I'm not sure what reset vector is. I am assuming that you are talking about CFG_RESET_ADDRESS, which I have set to 0x80000000. I'm not sure exactly what to set that to, since some board configuration files tell you to set it to a known invalid address, and then some have it set to flash base plus 0x100. Also, the speed of the flash I am using is a 70ns flash device.
Thanks for the help!
--- SAM SONG samsongshu@yahoo.com.cn wrote:
Date: Wed, 31 Dec 2003 13:21:29 -0800 (PST) From: Jeff Stevens jsteve17@yahoo.com To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] U-Boot Not Loading Successfully
I am porting U-Boot over to a new product and am having some difficulty getting U-Boot to load successfully. I have placed our board on a logic analyzer and found (based on System.map) that
U-Boot
seems to crash in cpu/mpc8xx/cpu_init.c in
function
cpu_init_f at lines:
memctl->memc_br0 = CFG_BR0_PRELIM; memctl->memc_or0 = CFG_OR0_PRELIM;
Here is my board configuration: CPU: MPC855T FLASH: AMD AM29LV040B (512kB 8-bit on CS0) SDRAM: Micron MT48LC4M32 (16MB 32-bit on CS2) NVRAM: Simtek STK14C88 (32kB 8-bit on CS4)
The board is set to have the IMMR come up at 0xFF000000 (on hard reset), and that is what I
have
CFG_IMMR set to in my board configuration file. Could this be a problem with the placement of the IMMR.
I
previously had the IMMR at 0x00000000 on hard
reset
and then moved it to 0xFA200000 with CFG_IMMR,
which
had the same effect. Or, could this be an issue with my BR0 and OR0 settings?
Both settings on CFG_IMMR are OK.Only you set CFG_IMMR on 0xFFF80000 would have some problems.I guess
your
trouble don't relate with CFG_IMMR settings.
I read something in that file before those two lines above, which talked about CFG_OR0_REMAP, but didn't quite understand it. Should I be using this?
Here are my BRx, ORx settings: #define FLASH_BASE_PRELIM 0xFFF80000 #define CFG_PRELIM_OR_AM 0xFFFF0000 #define CFG_OR_TIMING_FLASH (OR_CSNT_SAM | OR_ACS_DIV4 | OR_BI | OR_SCY_3_CLK | OR_TRLX | OR_EHTR)
Pls tell us the FLASH SPEED or we cannot check the OR0 configuration for you.Meanwhile,what's your reset vector prefix?0x0000 or 0xfff0?
#define CFG_OR0_PRELIM (CFG_PRELIM_OR_AM | CFG_OR_TIMING_FLASH) #define CFG_BR0_PRELIM ((FLASH_BASE_PRELIM & BR_BA_MSK) | (BR_PS_8 & BR_PS_MSK) | BR_V)
#define SDRAM_BASE_PRELIM 0x00000000 #define SDRAM_MAX_SIZE 0x01000000
#define CFG_OR_TIMING_SDRAM (OR_G5LA | OR_G5LS) #define CFG_OR2_PRELIM (CFG_PRELIM_OR_AM | CFG_OR_TIMING_SDRAM ) #define CFG_BR2_PRELIM ((SDRAM_BASE_PRELIM
BR_BA_MSK) | BR_MS_UPMA | BR_V )
#define CFG_NVRAM_BASE 0xFA000000 #define CFG_OR4_PRELIM (CFG_PRELIM_OR_AM | CFG_OR_TIMING_FLASH) #define CFG_BR4_PRELIM ((CFG_NVRAM_BASE & BR_BA_MSK) | (BR_PS_8 & BR_PS_MSK) | BR_V |
OR_EHTR)
I would appreciate anyones input, since I'm not
too
familiar with the U-Boot beyond the board specific files.
Thanks in advance!
SAM
Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Do you Yahoo!? New Yahoo! Photos - easier uploading and sharing. http://photos.yahoo.com/
__________________________________ Do you Yahoo!? New Yahoo! Photos - easier uploading and sharing. http://photos.yahoo.com/
Jeff Stevens
