[U-Boot] [PATCH 00/10] dm: timer: x86: 64-bit counter support and tsc timer dm conversion
This series enhances timer uclass driver to support 64-bit counter value, and convert tsc timer to driver model to be used by all x86 boards.
As a result of dm conversion, the TSC_CALIBRATION_BYPASS Kconfig option is no longer needed, and the TSC frequency can be specified in the board device tree.
Bin Meng (10): dm: timer: Fix several nits dm: timer: Implement pre_probe() timer: altera: Remove the codes to get clock frequency dm: timer: Support 64-bit counter x86: Reomve MIN_PORT80_KCLOCKS_DELAY x86: tsc: Use notrace from <linux/compiler.h> x86: tsc: Add driver model timer support x86: Convert to use driver model timer x86: tsc: Remove legacy timer codes x86: tsc: Move tsc_timer.c to drivers/timer
arch/x86/Kconfig | 20 ------ arch/x86/cpu/baytrail/valleyview.c | 3 - arch/x86/cpu/coreboot/timestamp.c | 22 ------ arch/x86/cpu/cpu.c | 18 ----- arch/x86/cpu/efi/efi.c | 4 -- arch/x86/cpu/ivybridge/cpu.c | 1 - arch/x86/cpu/qemu/Kconfig | 1 - arch/x86/cpu/qemu/qemu.c | 3 - arch/x86/cpu/quark/Kconfig | 5 -- arch/x86/cpu/quark/quark.c | 3 - arch/x86/cpu/queensbay/tnc.c | 3 - arch/x86/dts/bayleybay.dts | 1 + arch/x86/dts/broadwell_som-6896.dts | 1 + arch/x86/dts/chromebook_link.dts | 1 + arch/x86/dts/chromebox_panther.dts | 1 + arch/x86/dts/crownbay.dts | 1 + arch/x86/dts/efi.dts | 5 ++ arch/x86/dts/galileo.dts | 5 ++ arch/x86/dts/minnowmax.dts | 1 + arch/x86/dts/qemu-x86_i440fx.dts | 5 ++ arch/x86/dts/qemu-x86_q35.dts | 5 ++ arch/x86/dts/tsc_timer.dtsi | 7 ++ arch/x86/include/asm/global_data.h | 3 - arch/x86/lib/Makefile | 1 - configs/bayleybay_defconfig | 1 + configs/chromebook_link_defconfig | 2 +- configs/chromebox_panther_defconfig | 2 +- configs/coreboot-x86_defconfig | 3 +- configs/crownbay_defconfig | 1 + configs/efi-x86_defconfig | 2 +- configs/galileo_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/qemu-x86_defconfig | 1 + drivers/timer/Kconfig | 17 +++-- drivers/timer/Makefile | 1 + drivers/timer/altera_timer.c | 8 +-- drivers/timer/timer-uclass.c | 43 ++++++++++-- {arch/x86/lib => drivers/timer}/tsc_timer.c | 104 ++++++++++++++++------------ include/configs/x86-common.h | 2 - include/timer.h | 17 +++-- lib/time.c | 9 ++- 41 files changed, 168 insertions(+), 167 deletions(-) create mode 100644 arch/x86/dts/tsc_timer.dtsi rename {arch/x86/lib => drivers/timer}/tsc_timer.c (87%)
This changes 'Timer' to 'timer' at several places.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/timer/Kconfig | 10 +++++----- drivers/timer/timer-uclass.c | 4 ++-- include/timer.h | 11 ++++++----- 3 files changed, 13 insertions(+), 12 deletions(-)
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 97c4128..895de38 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -1,19 +1,19 @@ menu "Timer Support"
config TIMER - bool "Enable Driver Model for Timer drivers" + bool "Enable driver model for timer drivers" depends on DM help - Enable driver model for Timer access. It uses the same API as - lib/time.c. But now implemented by the uclass. The first timer + Enable driver model for timer access. It uses the same API as + lib/time.c, but now implemented by the uclass. The first timer will be used. The timer is usually a 32 bits free-running up counter. There may be no real tick, and no timer interrupt.
config ALTERA_TIMER - bool "Altera Timer support" + bool "Altera timer support" depends on TIMER help - Select this to enable an timer for Altera devices. Please find + Select this to enable a timer for Altera devices. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
endmenu diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index 12aee5b..82c6897 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -10,10 +10,10 @@ #include <timer.h>
/* - * Implement a Timer uclass to work with lib/time.c. The timer is usually + * Implement a timer uclass to work with lib/time.c. The timer is usually * a 32 bits free-running up counter. The get_rate() method is used to get * the input clock frequency of the timer. The get_count() method is used - * get the current 32 bits count value. If the hardware is counting down, + * to get the current 32 bits count value. If the hardware is counting down, * the value should be inversed inside the method. There may be no real * tick, and no timer interrupt. */ diff --git a/include/timer.h b/include/timer.h index cdf385d..ed5c685 100644 --- a/include/timer.h +++ b/include/timer.h @@ -10,30 +10,31 @@ /* * Get the current timer count * - * @dev: The Timer device + * @dev: The timer device * @count: pointer that returns the current timer count * @return: 0 if OK, -ve on error */ int timer_get_count(struct udevice *dev, unsigned long *count); + /* * Get the timer input clock frequency * - * @dev: The Timer device + * @dev: The timer device * @return: the timer input clock frequency */ unsigned long timer_get_rate(struct udevice *dev);
/* - * struct timer_ops - Driver model Timer operations + * struct timer_ops - Driver model timer operations * - * The uclass interface is implemented by all Timer devices which use + * The uclass interface is implemented by all timer devices which use * driver model. */ struct timer_ops { /* * Get the current timer count * - * @dev: The Timer device + * @dev: The timer device * @count: pointer that returns the current timer count * @return: 0 if OK, -ve on error */
Hi Bin,
config TIMER
- bool "Enable driver model for timer drivers" depends on DM help
config ALTERA_TIMER
- bool "Altera timer support" depends on TIMER help
endmenu
- Implement a Timer uclass to work with lib/time.c. The timer is usually
- Implement a timer uclass to work with lib/time.c. The timer is usually
- a 32 bits free-running up counter. The get_rate() method is used to get
- the input clock frequency of the timer. The get_count() method is used
- get the current 32 bits count value. If the hardware is counting down,
- to get the current 32 bits count value. If the hardware is counting down,
- the value should be inversed inside the method. There may be no real
- tick, and no timer interrupt.
- Get the current timer count
- @dev: The Timer device
- @dev: The timer device
- @count: pointer that returns the current timer count
- @return: 0 if OK, -ve on error
- Get the timer input clock frequency
- @return: the timer input clock frequency
- struct timer_ops - Driver model Timer operations
- struct timer_ops - Driver model timer operations
- The uclass interface is implemented by all Timer devices which use
- The uclass interface is implemented by all timer devices which use
- driver model.
Thanks. Might need rebase after nios2 timer cleaned up and sandbox timer added. Otherwise,
Ack-by: Thomas Chou thomas@wytron.com.tw
On 5 November 2015 at 23:59, Thomas Chou thomas@wytron.com.tw wrote:
Hi Bin,
Every timer device needs to have a valid clock frequency and it can be specified in the device tree. Use pre_probe() to get this in the timer uclass driver.
drivers/timer/timer-uclass.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index 82c6897..0218591 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -9,6 +9,8 @@ #include <errno.h> #include <timer.h>
+DECLARE_GLOBAL_DATA_PTR; + /* * Implement a timer uclass to work with lib/time.c. The timer is usually * a 32 bits free-running up counter. The get_rate() method is used to get @@ -35,8 +37,19 @@ unsigned long timer_get_rate(struct udevice *dev) return uc_priv->clock_rate; }
+static int timer_pre_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + + uc_priv->clock_rate = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "clock-frequency", 0); + + return 0; +} + UCLASS_DRIVER(timer) = { .id = UCLASS_TIMER, .name = "timer", + .pre_probe = timer_pre_probe, .per_device_auto_alloc_size = sizeof(struct timer_dev_priv), };
Hi Bin,
- struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- uc_priv->clock_rate = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
- UCLASS_DRIVER(timer) = { .id = UCLASS_TIMER, .name = "timer",
- .pre_probe = timer_pre_probe, .per_device_auto_alloc_size = sizeof(struct timer_dev_priv), };
Acked-by: Thomas Chou thomas@wytron.com.tw
On 6 November 2015 at 00:00, Thomas Chou thomas@wytron.com.tw wrote:
Hi Bin,
Since we have timer uclass to get clock frequency for us, remove the custom version in the altera timer driver.
drivers/timer/altera_timer.c | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/drivers/timer/altera_timer.c b/drivers/timer/altera_timer.c index 2ef9ad6..e4d0301 100644 --- a/drivers/timer/altera_timer.c +++ b/drivers/timer/altera_timer.c @@ -27,7 +27,6 @@ struct altera_timer_regs {
struct altera_timer_platdata { struct altera_timer_regs *regs; - unsigned long clock_rate; };
/* control register */ @@ -54,12 +53,9 @@ static int altera_timer_get_count(struct udevice *dev, unsigned long *count)
static int altera_timer_probe(struct udevice *dev) { - struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); struct altera_timer_platdata *plat = dev->platdata; struct altera_timer_regs *const regs = plat->regs;
- uc_priv->clock_rate = plat->clock_rate; - writel(0, ®s->status); writel(0, ®s->control); writel(ALTERA_TIMER_STOP, ®s->control); @@ -77,8 +73,6 @@ static int altera_timer_ofdata_to_platdata(struct udevice *dev)
plat->regs = ioremap(dev_get_addr(dev), sizeof(struct altera_timer_regs)); - plat->clock_rate = fdtdec_get_int(gd->fdt_blob, dev->of_offset, - "clock-frequency", 0);
return 0; }
Hi Bin,
return 0; }
On 6 November 2015 at 00:01, Thomas Chou thomas@wytron.com.tw wrote:
Hi Bin,
There are timers with a 64-bit counter value but current timer uclass driver assumes a 32-bit one. Introduce a device tree property "counter-64bit", and modify timer_get_count() in the timer uclass driver to handle the 32-bit/64-bit conversion automatically.
drivers/timer/altera_timer.c | 2 +- drivers/timer/timer-uclass.c | 28 ++++++++++++++++++++++++---- include/timer.h | 6 ++++-- lib/time.c | 9 ++++++--- 4 files changed, 35 insertions(+), 10 deletions(-)
diff --git a/drivers/timer/altera_timer.c b/drivers/timer/altera_timer.c index e4d0301..b363b19 100644 --- a/drivers/timer/altera_timer.c +++ b/drivers/timer/altera_timer.c @@ -34,7 +34,7 @@ struct altera_timer_platdata { #define ALTERA_TIMER_START (1 << 2) /* Start timer */ #define ALTERA_TIMER_STOP (1 << 3) /* Stop timer */
-static int altera_timer_get_count(struct udevice *dev, unsigned long *count) +static int altera_timer_get_count(struct udevice *dev, u64 *count) { struct altera_timer_platdata *plat = dev->platdata; struct altera_timer_regs *const regs = plat->regs; diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index 0218591..8451b40 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -13,21 +13,39 @@ DECLARE_GLOBAL_DATA_PTR;
/* * Implement a timer uclass to work with lib/time.c. The timer is usually - * a 32 bits free-running up counter. The get_rate() method is used to get + * a 32/64 bits free-running up counter. The get_rate() method is used to get * the input clock frequency of the timer. The get_count() method is used - * to get the current 32 bits count value. If the hardware is counting down, + * to get the current 32/64 bits count value. If the hardware is counting down, * the value should be inversed inside the method. There may be no real * tick, and no timer interrupt. */
-int timer_get_count(struct udevice *dev, unsigned long *count) +int timer_get_count(struct udevice *dev, u64 *count) { const struct timer_ops *ops = device_get_ops(dev); + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + u32 now; + int ret;
if (!ops->get_count) return -ENOSYS;
- return ops->get_count(dev, count); + if (uc_priv->counter_64) { + return ops->get_count(dev, count); + } else { + ret = ops->get_count(dev, count); + if (ret) + return ret; + + now = *count; + /* increment tbh if tbl has rolled over */ + if (now < gd->timebase_l) + gd->timebase_h++; + gd->timebase_l = now; + *count = ((u64)gd->timebase_h << 32) | gd->timebase_l; + + return 0; + } }
unsigned long timer_get_rate(struct udevice *dev) @@ -43,6 +61,8 @@ static int timer_pre_probe(struct udevice *dev)
uc_priv->clock_rate = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "clock-frequency", 0); + uc_priv->counter_64 = fdtdec_get_bool(gd->fdt_blob, dev->of_offset, + "counter-64bit");
return 0; } diff --git a/include/timer.h b/include/timer.h index ed5c685..4e061ed 100644 --- a/include/timer.h +++ b/include/timer.h @@ -14,7 +14,7 @@ * @count: pointer that returns the current timer count * @return: 0 if OK, -ve on error */ -int timer_get_count(struct udevice *dev, unsigned long *count); +int timer_get_count(struct udevice *dev, u64 *count);
/* * Get the timer input clock frequency @@ -38,16 +38,18 @@ struct timer_ops { * @count: pointer that returns the current timer count * @return: 0 if OK, -ve on error */ - int (*get_count)(struct udevice *dev, unsigned long *count); + int (*get_count)(struct udevice *dev, u64 *count); };
/* * struct timer_dev_priv - information about a device used by the uclass * * @clock_rate: the timer input clock frequency + * @counter_64: the timer counter is a 64-bit value or not */ struct timer_dev_priv { unsigned long clock_rate; + bool counter_64; };
#endif /* _TIMER_H_ */ diff --git a/lib/time.c b/lib/time.c index b001745..f37a662 100644 --- a/lib/time.c +++ b/lib/time.c @@ -69,9 +69,9 @@ ulong notrace get_tbclk(void) return timer_get_rate(gd->timer); }
-unsigned long notrace timer_read_counter(void) +uint64_t notrace get_ticks(void) { - unsigned long count; + u64 count; int ret;
ret = dm_timer_init(); @@ -84,7 +84,8 @@ unsigned long notrace timer_read_counter(void)
return count; } -#endif /* CONFIG_TIMER */ + +#else /* !CONFIG_TIMER */
uint64_t __weak notrace get_ticks(void) { @@ -97,6 +98,8 @@ uint64_t __weak notrace get_ticks(void) return ((uint64_t)gd->timebase_h << 32) | gd->timebase_l; }
+#endif /* CONFIG_TIMER */ + /* Returns time in milliseconds */ static uint64_t notrace tick_to_time(uint64_t tick) {
Hi Bin,
Thanks a lot. I tested patches [1-4] on nios2 boards with "ut time" and "sleep". It works fine.
I would suggest that we do not need the additional "counter-64bit" property by requiring the timer always return 64 bits count. We can provide an inline func to do the 32/64 conversion for all 32 bits timers.
Best regards, Thomas
Hi Thomas,
On Fri, Nov 6, 2015 at 3:14 PM, Thomas Chou thomas@wytron.com.tw wrote:
Hi Bin,
Do you mean we move the following codes:
to an inline function, to have 32-bit timer driver to call this inline function in their get_count() op?
This looks duplicate to me.
Regards, Bin
Hi Bin,
On 2015年11月06日 22:35, Bin Meng wrote:
Hi Thomas,
Hi Bin,
gd->timebase_h++;
Yes. If we want to support 64 bits count, it should be the driver's responsibility to return 64 bits count. It would be more natural than adding a property to tell the uclass to to the conversion. The "duplicate" you mentioned could be an alternative to the "counter-64bit" addition. I believe 64 bits hardware counter will become more popular in the future.
Hi Thomas,
On Sat, Nov 7, 2015 at 6:40 AM, Thomas Chou thomas@wytron.com.tw wrote:
Hi Bin,
Hi Thomas,
Hi Bin,
gd->timebase_h++;
OK, will do in v2 and rebase on top of sandbox timer patches.
Regards, Bin
This is not referenced anywhere. Remove it, as well as tsc_base_kclocks and tsc_prev in the global data.
arch/x86/cpu/cpu.c | 18 ------------------ arch/x86/include/asm/global_data.h | 2 -- 2 files changed, 20 deletions(-)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 812c5e4..1707993 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -641,24 +641,6 @@ int cpu_jump_to_64bit(ulong setup_base, ulong target)
void show_boot_progress(int val) { -#if MIN_PORT80_KCLOCKS_DELAY - /* - * Scale the time counter reading to avoid using 64 bit arithmetics. - * Can't use get_timer() here becuase it could be not yet - * initialized or even implemented. - */ - if (!gd->arch.tsc_prev) { - gd->arch.tsc_base_kclocks = rdtsc() / 1000; - gd->arch.tsc_prev = 0; - } else { - uint32_t now; - - do { - now = rdtsc() / 1000 - gd->arch.tsc_base_kclocks; - } while (now < (gd->arch.tsc_prev + MIN_PORT80_KCLOCKS_DELAY)); - gd->arch.tsc_prev = now; - } -#endif outb(val, POST_PORT); }
diff --git a/arch/x86/include/asm/global_data.h b/arch/x86/include/asm/global_data.h index 35148ab..5966b7c 100644 --- a/arch/x86/include/asm/global_data.h +++ b/arch/x86/include/asm/global_data.h @@ -54,8 +54,6 @@ struct arch_global_data { uint8_t x86_mask; uint32_t x86_device; uint64_t tsc_base; /* Initial value returned by rdtsc() */ - uint32_t tsc_base_kclocks; /* Initial tsc as a kclocks value */ - uint32_t tsc_prev; /* For show_boot_progress() */ uint32_t tsc_mhz; /* TSC frequency in MHz */ void *new_fdt; /* Relocated FDT */ uint32_t bist; /* Built-in self test value */
Replace __attribute__((no_instrument_function)) with notrace from <linux/compiler.h>.
arch/x86/lib/tsc_timer.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/x86/lib/tsc_timer.c b/arch/x86/lib/tsc_timer.c index e02b918..5a962ce 100644 --- a/arch/x86/lib/tsc_timer.c +++ b/arch/x86/lib/tsc_timer.c @@ -288,7 +288,7 @@ void timer_set_base(u64 base) * restart. This yields a free running counter guaranteed to take almost 6 * years to wrap around even at 100GHz clock rate. */ -u64 __attribute__((no_instrument_function)) get_ticks(void) +u64 notrace get_ticks(void) { u64 now_tick = rdtsc();
@@ -299,7 +299,7 @@ u64 __attribute__((no_instrument_function)) get_ticks(void) }
/* Get the speed of the TSC timer in MHz */ -unsigned __attribute__((no_instrument_function)) long get_tbclk_mhz(void) +unsigned notrace long get_tbclk_mhz(void) { unsigned long fast_calibrate;
@@ -337,7 +337,7 @@ ulong get_timer(ulong base) return get_ms_timer() - base; }
-ulong __attribute__((no_instrument_function)) timer_get_us(void) +ulong notrace timer_get_us(void) { return get_ticks() / get_tbclk_mhz(); }
This adds driver model timer support to x86 tsc timer driver.
arch/x86/lib/tsc_timer.c | 65 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 65 insertions(+)
diff --git a/arch/x86/lib/tsc_timer.c b/arch/x86/lib/tsc_timer.c index 5a962ce..0f03cc3 100644 --- a/arch/x86/lib/tsc_timer.c +++ b/arch/x86/lib/tsc_timer.c @@ -8,7 +8,9 @@ */
#include <common.h> +#include <dm.h> #include <malloc.h> +#include <timer.h> #include <asm/io.h> #include <asm/i8254.h> #include <asm/ibmpc.h> @@ -278,6 +280,7 @@ success: return delta / 1000; }
+#ifndef CONFIG_TIMER void timer_set_base(u64 base) { gd->arch.tsc_base = base; @@ -297,10 +300,14 @@ u64 notrace get_ticks(void) panic("No tick base available"); return now_tick - gd->arch.tsc_base; } +#endif /* CONFIG_TIMER */
/* Get the speed of the TSC timer in MHz */ unsigned notrace long get_tbclk_mhz(void) { +#ifdef CONFIG_TIMER + return get_tbclk() / 1000000; +#else unsigned long fast_calibrate;
if (gd->arch.tsc_mhz) @@ -320,12 +327,15 @@ unsigned notrace long get_tbclk_mhz(void)
gd->arch.tsc_mhz = fast_calibrate; return fast_calibrate; +#endif }
+#ifndef CONFIG_TIMER unsigned long get_tbclk(void) { return get_tbclk_mhz() * 1000 * 1000; } +#endif
static ulong get_ms_timer(void) { @@ -375,3 +385,58 @@ int timer_init(void)
return 0; } + +#ifdef CONFIG_TIMER +static int tsc_timer_get_count(struct udevice *dev, u64 *count) +{ + u64 now_tick = rdtsc(); + + *count = now_tick - gd->arch.tsc_base; + + return 0; +} + +static int tsc_timer_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + + gd->arch.tsc_base = rdtsc(); + + /* + * If there is no clock frequency specified in the device tree, + * calibrate it by ourselves. + */ + if (!uc_priv->clock_rate) { + unsigned long fast_calibrate; + + fast_calibrate = try_msr_calibrate_tsc(); + if (!fast_calibrate) { + fast_calibrate = quick_pit_calibrate(); + if (!fast_calibrate) + panic("TSC frequency is ZERO"); + } + + uc_priv->clock_rate = fast_calibrate * 1000 * 1000; + } + + return 0; +} + +static const struct timer_ops tsc_timer_ops = { + .get_count = tsc_timer_get_count, +}; + +static const struct udevice_id tsc_timer_ids[] = { + { .compatible = "x86,tsc-timer", }, + { } +}; + +U_BOOT_DRIVER(tsc_timer) = { + .name = "tsc_timer", + .id = UCLASS_TIMER, + .of_match = tsc_timer_ids, + .probe = tsc_timer_probe, + .ops = &tsc_timer_ops, + .flags = DM_FLAG_PRE_RELOC, +}; +#endif /* CONFIG_TIMER */
Convert all x86 boards to use driver model tsc timer.
arch/x86/cpu/baytrail/valleyview.c | 3 --- arch/x86/cpu/coreboot/timestamp.c | 22 ---------------------- arch/x86/cpu/efi/efi.c | 4 ---- arch/x86/cpu/ivybridge/cpu.c | 1 - arch/x86/cpu/qemu/qemu.c | 3 --- arch/x86/cpu/quark/quark.c | 3 --- arch/x86/cpu/queensbay/tnc.c | 3 --- arch/x86/dts/bayleybay.dts | 1 + arch/x86/dts/broadwell_som-6896.dts | 1 + arch/x86/dts/chromebook_link.dts | 1 + arch/x86/dts/chromebox_panther.dts | 1 + arch/x86/dts/crownbay.dts | 1 + arch/x86/dts/efi.dts | 5 +++++ arch/x86/dts/galileo.dts | 5 +++++ arch/x86/dts/minnowmax.dts | 1 + arch/x86/dts/qemu-x86_i440fx.dts | 5 +++++ arch/x86/dts/qemu-x86_q35.dts | 5 +++++ arch/x86/dts/tsc_timer.dtsi | 7 +++++++ configs/bayleybay_defconfig | 1 + configs/chromebook_link_defconfig | 2 +- configs/chromebox_panther_defconfig | 2 +- configs/coreboot-x86_defconfig | 2 +- configs/crownbay_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/galileo_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/qemu-x86_defconfig | 1 + 27 files changed, 42 insertions(+), 42 deletions(-) create mode 100644 arch/x86/dts/tsc_timer.dtsi
diff --git a/arch/x86/cpu/baytrail/valleyview.c b/arch/x86/cpu/baytrail/valleyview.c index a009c14..9b30451 100644 --- a/arch/x86/cpu/baytrail/valleyview.c +++ b/arch/x86/cpu/baytrail/valleyview.c @@ -28,9 +28,6 @@ int arch_cpu_init(void) int ret;
post_code(POST_CPU_INIT); -#ifdef CONFIG_SYS_X86_TSC_TIMER - timer_set_base(rdtsc()); -#endif
ret = x86_cpu_init_f(); if (ret) diff --git a/arch/x86/cpu/coreboot/timestamp.c b/arch/x86/cpu/coreboot/timestamp.c index 0edee6b..b382795 100644 --- a/arch/x86/cpu/coreboot/timestamp.c +++ b/arch/x86/cpu/coreboot/timestamp.c @@ -27,28 +27,6 @@ static struct timestamp_table *ts_table __attribute__((section(".data")));
void timestamp_init(void) { -#ifdef CONFIG_SYS_X86_TSC_TIMER - uint64_t base_time; -#endif - - ts_table = lib_sysinfo.tstamp_table; -#ifdef CONFIG_SYS_X86_TSC_TIMER - /* - * If coreboot is built with CONFIG_COLLECT_TIMESTAMPS, use the value - * of base_time in coreboot's timestamp table as our timer base, - * otherwise TSC counter value will be used. - * - * Sometimes even coreboot is built with CONFIG_COLLECT_TIMESTAMPS, - * the value of base_time in the timestamp table is still zero, so - * we must exclude this case too (this is currently seen on booting - * coreboot in qemu) - */ - if (ts_table && ts_table->base_time) - base_time = ts_table->base_time; - else - base_time = rdtsc(); - timer_set_base(base_time); -#endif timestamp_add_now(TS_U_BOOT_INITTED); }
diff --git a/arch/x86/cpu/efi/efi.c b/arch/x86/cpu/efi/efi.c index 75ba0d4..993ab8d 100644 --- a/arch/x86/cpu/efi/efi.c +++ b/arch/x86/cpu/efi/efi.c @@ -10,10 +10,6 @@
int arch_cpu_init(void) { -#ifdef CONFIG_SYS_X86_TSC_TIMER - timer_set_base(rdtsc()); -#endif - return 0; }
diff --git a/arch/x86/cpu/ivybridge/cpu.c b/arch/x86/cpu/ivybridge/cpu.c index 0e6512c..0387444 100644 --- a/arch/x86/cpu/ivybridge/cpu.c +++ b/arch/x86/cpu/ivybridge/cpu.c @@ -118,7 +118,6 @@ static void set_spi_speed(void) int arch_cpu_init(void) { post_code(POST_CPU_INIT); - timer_set_base(rdtsc());
return x86_cpu_init_f(); } diff --git a/arch/x86/cpu/qemu/qemu.c b/arch/x86/cpu/qemu/qemu.c index 7c03e02..13e83a1 100644 --- a/arch/x86/cpu/qemu/qemu.c +++ b/arch/x86/cpu/qemu/qemu.c @@ -14,9 +14,6 @@ int arch_cpu_init(void) int ret;
ret = x86_cpu_init_f(); if (ret) diff --git a/arch/x86/cpu/quark/quark.c b/arch/x86/cpu/quark/quark.c index f737e19..c2bf497 100644 --- a/arch/x86/cpu/quark/quark.c +++ b/arch/x86/cpu/quark/quark.c @@ -233,9 +233,6 @@ int arch_cpu_init(void) int ret;
ret = x86_cpu_init_f(); if (ret) diff --git a/arch/x86/cpu/queensbay/tnc.c b/arch/x86/cpu/queensbay/tnc.c index 933d189..fb81919 100644 --- a/arch/x86/cpu/queensbay/tnc.c +++ b/arch/x86/cpu/queensbay/tnc.c @@ -52,9 +52,6 @@ int arch_cpu_init(void) int ret;
ret = x86_cpu_init_f(); if (ret) diff --git a/arch/x86/dts/bayleybay.dts b/arch/x86/dts/bayleybay.dts index 52d0999..f8901c3 100644 --- a/arch/x86/dts/bayleybay.dts +++ b/arch/x86/dts/bayleybay.dts @@ -12,6 +12,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "Intel Bayley Bay"; diff --git a/arch/x86/dts/broadwell_som-6896.dts b/arch/x86/dts/broadwell_som-6896.dts index a6b5d0f..194f0eb 100644 --- a/arch/x86/dts/broadwell_som-6896.dts +++ b/arch/x86/dts/broadwell_som-6896.dts @@ -3,6 +3,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "Advantech SOM-6896"; diff --git a/arch/x86/dts/chromebook_link.dts b/arch/x86/dts/chromebook_link.dts index f27263a..d3e0758 100644 --- a/arch/x86/dts/chromebook_link.dts +++ b/arch/x86/dts/chromebook_link.dts @@ -3,6 +3,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "Google Link"; diff --git a/arch/x86/dts/chromebox_panther.dts b/arch/x86/dts/chromebox_panther.dts index 61e8f2f..4e2b517 100644 --- a/arch/x86/dts/chromebox_panther.dts +++ b/arch/x86/dts/chromebox_panther.dts @@ -3,6 +3,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "Google Panther"; diff --git a/arch/x86/dts/crownbay.dts b/arch/x86/dts/crownbay.dts index 3e354c4..c0a640d 100644 --- a/arch/x86/dts/crownbay.dts +++ b/arch/x86/dts/crownbay.dts @@ -11,6 +11,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "Intel Crown Bay"; diff --git a/arch/x86/dts/efi.dts b/arch/x86/dts/efi.dts index 1f50428..68b42e7 100644 --- a/arch/x86/dts/efi.dts +++ b/arch/x86/dts/efi.dts @@ -7,6 +7,7 @@ /dts-v1/;
/include/ "skeleton.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "EFI"; @@ -16,6 +17,10 @@ stdout-path = &serial; };
+ tsc-timer { + clock-frequency = <100000000>; + }; + serial: serial { compatible = "efi,uart"; }; diff --git a/arch/x86/dts/galileo.dts b/arch/x86/dts/galileo.dts index b49b1f5..2342de7 100644 --- a/arch/x86/dts/galileo.dts +++ b/arch/x86/dts/galileo.dts @@ -11,6 +11,7 @@
/include/ "skeleton.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "Intel Galileo"; @@ -28,6 +29,10 @@ stdout-path = &pciuart0; };
+ tsc-timer { + clock-frequency = <400000000>; + }; + mrc { compatible = "intel,quark-mrc"; flags = <MRC_FLAG_SCRAMBLE_EN>; diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index b03f987..bbfd6d4 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -12,6 +12,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "Intel Minnowboard Max"; diff --git a/arch/x86/dts/qemu-x86_i440fx.dts b/arch/x86/dts/qemu-x86_i440fx.dts index fc74cd0..4861b09 100644 --- a/arch/x86/dts/qemu-x86_i440fx.dts +++ b/arch/x86/dts/qemu-x86_i440fx.dts @@ -11,6 +11,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "QEMU x86 (I440FX)"; @@ -43,6 +44,10 @@ }; };
+ tsc-timer { + clock-frequency = <100000000>; + }; + pci { compatible = "pci-x86"; #address-cells = <3>; diff --git a/arch/x86/dts/qemu-x86_q35.dts b/arch/x86/dts/qemu-x86_q35.dts index 7f16971..ff293fe 100644 --- a/arch/x86/dts/qemu-x86_q35.dts +++ b/arch/x86/dts/qemu-x86_q35.dts @@ -21,6 +21,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi"
/ { model = "QEMU x86 (Q35)"; @@ -54,6 +55,10 @@ }; };
+ tsc-timer { + clock-frequency = <100000000>; + }; + pci { compatible = "pci-x86"; #address-cells = <3>; diff --git a/arch/x86/dts/tsc_timer.dtsi b/arch/x86/dts/tsc_timer.dtsi new file mode 100644 index 0000000..d1cc31e --- /dev/null +++ b/arch/x86/dts/tsc_timer.dtsi @@ -0,0 +1,7 @@ +/ { + tsc-timer { + compatible = "x86,tsc-timer"; + u-boot,dm-pre-reloc; + counter-64bit; + }; +}; diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index fc40da8..e9abbd0 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -24,6 +24,7 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_VIDEO_VESA=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 78a9470..c280478 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -26,7 +26,7 @@ CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_DEBUG_UART_BOARD_INIT=y -CONFIG_DM_TPM=y +CONFIG_TIMER=y CONFIG_TPM_TIS_LPC=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 663aab0..fca6e53 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -21,7 +21,7 @@ CONFIG_CROS_EC_LPC=y CONFIG_SPI_FLASH=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y -CONFIG_DM_TPM=y +CONFIG_TIMER=y CONFIG_TPM_TIS_LPC=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 438e43b..3f2cff8 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -17,7 +17,7 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y -CONFIG_DM_TPM=y +CONFIG_TIMER=y CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index d036c05..7ae36b6 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -23,6 +23,7 @@ CONFIG_E1000=y CONFIG_PCH_GBE=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_VIDEO_VESA=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 43fb0c4..fd90739 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -13,4 +13,5 @@ CONFIG_DEBUG_EFI_CONSOLE=y CONFIG_DEBUG_UART_BASE=0 CONFIG_DEBUG_UART_CLOCK=0 # CONFIG_X86_SERIAL is not set +CONFIG_TIMER=y CONFIG_EFI=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 1e1ce95..6421e5b 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -18,6 +18,7 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 8f99f0e..ef3b816 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -25,6 +25,7 @@ CONFIG_DM_RTC=y CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_VIDEO_VESA=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index f4cc862..2835e03 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -18,6 +18,7 @@ CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_DM_RTC=y +CONFIG_TIMER=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y
Hi Bin,
-#endif
uint64_t base_time;
-#endif
* coreboot in qemu)
else
-#endif
Where does this code end up now? It seems to be deleted.
Hi Simon,
On Fri, Nov 6, 2015 at 8:08 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
-#endif
uint64_t base_time;
-#endif
* coreboot in qemu)
else
-#endif
The TSC base was saved when TSC timer driver is probed. Please see tsc_timer.c::tsc_timer_probe().
Regards, Bin
On 6 November 2015 at 06:28, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
-#endif
uint64_t base_time;
-#endif
* coreboot in qemu)
else
-#endif
Thanks.
Now that we have converted all x86 boards to use driver model timer, remove these legacy timer codes in the tsc driver.
Note this also removes the TSC_CALIBRATION_BYPASS Kconfig option, as it is not needed with driver model.
arch/x86/Kconfig | 20 -------------- arch/x86/cpu/qemu/Kconfig | 1 - arch/x86/cpu/quark/Kconfig | 5 ---- arch/x86/include/asm/global_data.h | 1 - arch/x86/lib/tsc_timer.c | 53 -------------------------------------- configs/coreboot-x86_defconfig | 1 - configs/efi-x86_defconfig | 1 - 7 files changed, 82 deletions(-)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 8914be3..fef5601 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -279,26 +279,6 @@ config AP_STACK_SIZE the memory used by this initialisation process. Typically 4KB is enough space.
-config TSC_CALIBRATION_BYPASS - bool "Bypass Time-Stamp Counter (TSC) calibration" - default n - help - By default U-Boot automatically calibrates Time-Stamp Counter (TSC) - running frequency via Model-Specific Register (MSR) and Programmable - Interval Timer (PIT). If the calibration does not work on your board, - select this option and provide a hardcoded TSC running frequency with - CONFIG_TSC_FREQ_IN_MHZ below. - - Normally this option should be turned on in a simulation environment - like qemu. - -config TSC_FREQ_IN_MHZ - int "Time-Stamp Counter (TSC) running frequency in MHz" - depends on TSC_CALIBRATION_BYPASS - default 1000 - help - The running frequency in MHz of Time-Stamp Counter (TSC). - config HAVE_VGA_BIOS bool "Add a VGA BIOS image" help diff --git a/arch/x86/cpu/qemu/Kconfig b/arch/x86/cpu/qemu/Kconfig index fb775d7..4f98621 100644 --- a/arch/x86/cpu/qemu/Kconfig +++ b/arch/x86/cpu/qemu/Kconfig @@ -6,7 +6,6 @@
config QEMU bool - select TSC_CALIBRATION_BYPASS
if QEMU
diff --git a/arch/x86/cpu/quark/Kconfig b/arch/x86/cpu/quark/Kconfig index bc961ef..163caac 100644 --- a/arch/x86/cpu/quark/Kconfig +++ b/arch/x86/cpu/quark/Kconfig @@ -7,7 +7,6 @@ config INTEL_QUARK bool select HAVE_RMU - select TSC_CALIBRATION_BYPASS
if INTEL_QUARK
@@ -119,8 +118,4 @@ config SYS_CAR_SIZE Space in bytes in eSRAM used as Cache-As-ARM (CAR). Note this size must not exceed eSRAM's total size.
-config TSC_FREQ_IN_MHZ - int - default 400 - endif diff --git a/arch/x86/include/asm/global_data.h b/arch/x86/include/asm/global_data.h index 5966b7c..0ca518c 100644 --- a/arch/x86/include/asm/global_data.h +++ b/arch/x86/include/asm/global_data.h @@ -54,7 +54,6 @@ struct arch_global_data { uint8_t x86_mask; uint32_t x86_device; uint64_t tsc_base; /* Initial value returned by rdtsc() */ - uint32_t tsc_mhz; /* TSC frequency in MHz */ void *new_fdt; /* Relocated FDT */ uint32_t bist; /* Built-in self test value */ enum pei_boot_mode_t pei_boot_mode; diff --git a/arch/x86/lib/tsc_timer.c b/arch/x86/lib/tsc_timer.c index 0f03cc3..ab0bec8 100644 --- a/arch/x86/lib/tsc_timer.c +++ b/arch/x86/lib/tsc_timer.c @@ -280,63 +280,12 @@ success: return delta / 1000; }
-#ifndef CONFIG_TIMER -void timer_set_base(u64 base) -{ - gd->arch.tsc_base = base; -} - -/* - * Get the number of CPU time counter ticks since it was read first time after - * restart. This yields a free running counter guaranteed to take almost 6 - * years to wrap around even at 100GHz clock rate. - */ -u64 notrace get_ticks(void) -{ - u64 now_tick = rdtsc(); - - /* We assume that 0 means the base hasn't been set yet */ - if (!gd->arch.tsc_base) - panic("No tick base available"); - return now_tick - gd->arch.tsc_base; -} -#endif /* CONFIG_TIMER */ - /* Get the speed of the TSC timer in MHz */ unsigned notrace long get_tbclk_mhz(void) { -#ifdef CONFIG_TIMER return get_tbclk() / 1000000; -#else - unsigned long fast_calibrate; - - if (gd->arch.tsc_mhz) - return gd->arch.tsc_mhz; - -#ifdef CONFIG_TSC_CALIBRATION_BYPASS - fast_calibrate = CONFIG_TSC_FREQ_IN_MHZ; -#else - fast_calibrate = try_msr_calibrate_tsc(); - if (!fast_calibrate) { - - fast_calibrate = quick_pit_calibrate(); - if (!fast_calibrate) - panic("TSC frequency is ZERO"); - } -#endif - - gd->arch.tsc_mhz = fast_calibrate; - return fast_calibrate; -#endif }
-#ifndef CONFIG_TIMER -unsigned long get_tbclk(void) -{ - return get_tbclk_mhz() * 1000 * 1000; -} -#endif - static ulong get_ms_timer(void) { return (get_ticks() * 1000) / get_tbclk(); @@ -386,7 +335,6 @@ int timer_init(void) return 0; }
-#ifdef CONFIG_TIMER static int tsc_timer_get_count(struct udevice *dev, u64 *count) { u64 now_tick = rdtsc(); @@ -439,4 +387,3 @@ U_BOOT_DRIVER(tsc_timer) = { .ops = &tsc_timer_ops, .flags = DM_FLAG_PRE_RELOC, }; -#endif /* CONFIG_TIMER */ diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 3f2cff8..6fb38f0 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -1,7 +1,6 @@ CONFIG_X86=y CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y -CONFIG_TSC_CALIBRATION_BYPASS=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index fd90739..7354f04 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -2,7 +2,6 @@ CONFIG_X86=y CONFIG_VENDOR_EFI=y CONFIG_DEFAULT_DEVICE_TREE="efi" CONFIG_TARGET_EFI=y -CONFIG_TSC_CALIBRATION_BYPASS=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_NET is not set CONFIG_OF_CONTROL=y
To group all dm timer drivers together, move tsc timer to drivers/timer directory.
arch/x86/lib/Makefile | 1 - drivers/timer/Kconfig | 7 +++++++ drivers/timer/Makefile | 1 + {arch/x86/lib => drivers/timer}/tsc_timer.c | 0 include/configs/x86-common.h | 2 -- 5 files changed, 8 insertions(+), 3 deletions(-) rename {arch/x86/lib => drivers/timer}/tsc_timer.c (100%)
diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index d676e2c..cd5ecb6 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -34,7 +34,6 @@ obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += smbios.o obj-y += string.o obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o obj-y += tables.o -obj-$(CONFIG_SYS_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_CMD_ZBOOT) += zimage.o obj-$(CONFIG_HAVE_FSP) += fsp/
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 895de38..570d479 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -16,4 +16,11 @@ config ALTERA_TIMER Select this to enable a timer for Altera devices. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
+config X86_TSC_TIMER + bool "x86 Time-Stamp Counter (TSC) timer support" + depends on TIMER && X86 + default y if X86 + help + Select this to enable Time-Stamp Counter (TSC) timer for x86. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index ae66c07..882c89a 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -6,3 +6,4 @@
obj-$(CONFIG_TIMER) += timer-uclass.o obj-$(CONFIG_ALTERA_TIMER) += altera_timer.o +obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o diff --git a/arch/x86/lib/tsc_timer.c b/drivers/timer/tsc_timer.c similarity index 100% rename from arch/x86/lib/tsc_timer.c rename to drivers/timer/tsc_timer.c diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index ab9fa0b..7c3b673 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -154,8 +154,6 @@ * CPU Features */
-#define CONFIG_SYS_X86_TSC_TIMER - #define CONFIG_SYS_STACK_SIZE (32 * 1024) #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MALLOC_LEN 0x200000
Bin Meng
Thomas Chou
