Pull request: u-boot-imx u-boot-imx-20220628
Hi Tom,
last i.MX's fixes for the release.
The following changes since commit bfa9306e140c136e43d0efc9574991db46ad8c9e:
Merge branch 'master' of https://source.denx.de/u-boot/custodians/u-boot-sunxi (2022-06-26 21:06:08 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20220628
for you to fetch changes up to b5023254b88a67fcbca913e212e3401dea521fc9:
kontron-sl-mx8mm: Add CAAM support (2022-06-28 15:24:31 +0200)
---------------------------------------------------------------- Fixes for 2022.07
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/12541
---------------------------------------------------------------- Andrejs Cainikovs (1): imx8m: fixup thermal trips
Fabio Estevam (1): kontron-sl-mx8mm: Add CAAM support
Francesco Dolcini (3): toradex: apalis/colibri_imx6: Fix CLKO1/CLKO2 output mx6: ddr: Fix disabling on-die termination board: apalis_imx6: DDR init using mx6_dram_cfg()
Frieder Schrempf (2): pmic: pca9450: Add optional SD_VSEL GPIO for LDO5 imx: kontron-sl-mx8mm: Enable PCA9450 regulator driver and fix SD card access
Marek Vasut (1): ARM: imx: Switch Data Modul i.MX8M Mini eDM SBC to USB251x Hub driver
arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi | 17 +++++ arch/arm/mach-imx/imx8m/Kconfig | 3 + arch/arm/mach-imx/imx8m/soc.c | 49 ++++++++++++++ arch/arm/mach-imx/mx6/ddr.c | 13 +++- board/data_modul/imx8mm_edm_sbc/imx8mm_data_modul_edm_sbc.c | 9 +++ board/kontron/sl-mx8mm/spl.c | 9 +++ board/toradex/apalis_imx6/apalis_imx6.c | 456 +++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------------------------------- board/toradex/colibri_imx6/colibri_imx6.c | 14 ++-- configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/kontron-sl-mx8mm_defconfig | 2 + drivers/power/pmic/pca9450.c | 27 ++++++++ include/configs/imx8mm_data_modul_edm_sbc.h | 20 ------ 12 files changed, 333 insertions(+), 287 deletions(-)
Best regards, Stefano
On Tue, Jun 28, 2022 at 05:08:12PM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
