[U-Boot] [PATCH] common: hash: fix crc32 verify
did not work:
Colibri T30 # crc32 0x80000000 0x100 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca Colibri T30 # crc32 -v 0x80000000 0x100 c9a057b3 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != ffffffff ** ERROR ** Colibri T30 # crc32 -v 0x80000000 0x100 9eb4f5ca crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != 301eeead ** ERROR **
now works again:
Colibri T30 # crc32 0x80000000 0x100 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca Colibri T30 # crc32 -v 0x80000000 0x100 c9a057b3 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != c9a057b3 ** ERROR ** Colibri T30 # crc32 -v 0x80000000 0x100 9eb4f5ca
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- common/hash.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/hash.c b/common/hash.c index c94c98b..7ae7c2f 100644 --- a/common/hash.c +++ b/common/hash.c @@ -307,7 +307,7 @@ static int parse_verify_sum(struct hash_algo *algo, char *verify_str, env_var = 1; }
- if (!env_var) { + if (env_var) { ulong addr; void *buf;
Hi Marcel,
On Tue, May 5, 2015 at 7:36 AM, Marcel Ziswiler marcel@ziswiler.com wrote:
did not work:
now works again:
if (!env_var) {
if (env_var) {
This is clearly the wrong way to fix this issue since it breaks pretty much every other aspect of hashing. Proper fix forthcoming.
-Joe
On 5 May 2015 19:25:26 CEST, Joe Hershberger joe.hershberger@gmail.com wrote:
I admit that I don't know nothing about any of that hashing stuff off late but it is crystal clear that Nikolay's patch simply broke the crc32 verify we were using for years.
Joe Hershberger
Marcel Ziswiler
