RE: [U-Boot-Users] 16Bit NAND flash
Wolfgang,
Two separate issues here:
1. NAND environment support: It is in CVS. It is called env_nand.c.
2. 16-bit NAND support: I was just wondering if anyone wants to patch cmd_nand.c with 16-bit support. I have it working for my board but it is just a hack. I can share my code with others who hopefully makes it a patch to cmd_nand.c.
Regards, Jian
-----Original Message----- From: wd@denx.de [mailto:wd@denx.de] Sent: Thursday, September 23, 2004 10:08 AM To: Zhang, Jian Cc: hermann.brugger@gmx.de; u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] 16Bit NAND flash
In message
BA2832125C3C994384FCC051CDFC7369B8A292@dlee2k05.ent.ti.com you wrote:
Yes, I did push a patch for NAND based environment. It is available
at
U-Boot site.
Which means it is essentially lost (or at lease significantly delayed). If you want to see it integrated into the source tree, then post it here.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de "Go to Heaven for the climate, Hell for the company." - Mark Twain
Zhang, Jian
