[U-Boot] [PATCH 1/2] SECURE BOOT: add version info for ISBC
T4/B4 SoC's have a different version of ISBC. The secure boot functionality is different with the new version of ISBC compared to the earlier SoC's. So the version information is added in file config_mpc85xx.h
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com Signed-off-by: Aneesh Bansal aneesh.bansal@freescale.com --- README | 3 +++ arch/powerpc/include/asm/config_mpc85xx.h | 9 +++++++++ 2 files changed, 12 insertions(+)
diff --git a/README b/README index aea82be..6c3a8d1 100644 --- a/README +++ b/README @@ -423,6 +423,9 @@ The following options need to be configured: CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT This value denotes start offset of DSP CCSR space.
+ CONFIG_SYS_FSL_ISBC_VER + This value indicates the major ISBC version on the platform. + CONFIG_SYS_FSL_SINGLE_SOURCE_CLK Single Source Clock is clocking mode present in some of FSL SoC's. In this mode, a single differential clock is used to supply diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 54ce2f0..ba5b6fe 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -151,6 +151,7 @@ #define CONFIG_SYS_FSL_ERRATUM_IFC_A003399 #define CONFIG_SYS_FSL_ERRATUM_A005125 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 +#define CONFIG_SYS_FSL_ISBC_VER 1 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x10
/* P1011 is single core version of P1020 */ @@ -383,6 +384,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A004849 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x11 +#define CONFIG_SYS_FSL_ISBC_VER 1
#elif defined(CONFIG_PPC_P3041) #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 @@ -421,6 +423,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A005812 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x20 +#define CONFIG_SYS_FSL_ISBC_VER 1
#elif defined(CONFIG_PPC_P4080) /* also supports P4040 */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 @@ -470,6 +473,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A005812 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x20 +#define CONFIG_SYS_FSL_ISBC_VER 1
#elif defined(CONFIG_PPC_P5020) /* also supports P5010 */ #define CONFIG_SYS_PPC64 /* 64-bit core */ @@ -504,6 +508,7 @@ #define CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x20 +#define CONFIG_SYS_FSL_ISBC_VER 1
#elif defined(CONFIG_PPC_P5040) #define CONFIG_SYS_PPC64 @@ -536,6 +541,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV 0x10 #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 #define CONFIG_SYS_FSL_ERRATUM_A005812 +#define CONFIG_SYS_FSL_ISBC_VER 1
#elif defined(CONFIG_BSC9131) #define CONFIG_MAX_CPUS 1 @@ -575,6 +581,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A005125 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x11 +#define CONFIG_SYS_FSL_ISBC_VER 1
#elif defined(CONFIG_PPC_T4240) || defined(CONFIG_PPC_T4160) #define CONFIG_E6500 @@ -631,6 +638,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A006593 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_PCI_VER_3_X +#define CONFIG_SYS_FSL_ISBC_VER 2
#elif defined(CONFIG_PPC_B4860) || defined(CONFIG_PPC_B4420) #define CONFIG_E6500 @@ -657,6 +665,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A006379 #define CONFIG_SYS_FSL_ERRATUM_A006593 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 +#define CONFIG_SYS_FSL_ISBC_VER 2
#ifdef CONFIG_PPC_B4860 #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 4
Dear Aneesh Bansal,
In message 1390202676-8167-1-git-send-email-aneesh.bansal@freescale.com you wrote:
- CONFIG_SYS_FSL_SINGLE_SOURCE_CLK Single Source Clock is clocking mode present in some of FSL SoC's. In this mode, a single differential clock is used to supply
You already have all relevant information present in the current configuration. There is no need to add yet another CONFIG_SYS_ option; the information can easily be derived from the existing data.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Ernest asks Frank how long he has been working for the company. "Ever since they threatened to fire me."
ISBC (Internal Secure Boot Code) is an IP which has different versions on different SOC's. The major difference which this CONFIG represents is whether CAAM block is being used for cryptographic operations or not. I will be adding more details in the description IN README and resend the patch.
The only other way that this can be derived is by doing SoC specific checking which would become a little messy.
Regards, Aneesh Bansal
Dear "aneesh.bansal@freescale.com",
In message aba33ec5436c40939359f93b6d243b08@DM2PR03MB415.namprd03.prod.outlook.com you wrote:
ISBC (Internal Secure Boot Code) is an IP which has different versions on different SOC's. The major difference which this CONFIG represents is whether CAAM block is being used for cryptographic operations or not. I will be adding more details in the de scription IN README and resend the patch.
But this is what I had in mind. It appears to be a simple 1:1 mapping from SoC to ISBC version to me, or am I wrong here?
ISBC (Internal Secure Boot Code) is an IP which has different versions on different SOC's. >The major difference which this CONFIG represents is whether CAAM block is being used >for cryptographic operations or not. I will be adding more details in the de scription IN README and resend the patch.
The only other way that this can be derived is by doing SoC specific checking which >would become a little messy.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de When the ax entered the forest, the trees said, "The handle is one of us!" -- Turkish proverb
Yes, it is a 1:1 mapping from SoC to ISBC version but we have multiple SoC's having the same ISBC version. So using the SoC names would result in having a long list of SoC's wherever we are doing some stuff specific to the ISBC version. Also in future, we might have new versions of ISBC with more features. SO having multiple SoC specific checks inside the code would lead to confusion.
Aneesh Bansal
