[PATCH v3 0/3] binman: Add support for externally encrypted blobs
From: Christian Taedcke christian.taedcke@weidmueller.com
This series adds the functionality to handle externally encrypted blobs to binman. It includes the functionality itself and the corresponding unit tests.
The following block shows an example on how to use this functionality. In the device tree that is parsed by binman a new node encrypted is used:
/ { binman { filename = "u-boot.itb"; fit { ... images { some-bitstream { ... image_bitstream: blob-ext { filename = "bitstream.bin"; }; encrypted { content = <&image_bitstream>; algo = "aes256-gcm"; iv-filename = "bitstream.bin.iv"; key-filename = "bitstream.bin.key"; }; ...
This results in an generated fit image containing the following information:
\ { images { ... some-bitstream { ... data = [...] cipher { algo = "aes256-gcm"; key = <0x...>; iv = <0x...>; }; }; ...
Changes in v3: - rebase on u-boot-dm/mkim-working - remove unnecessary test testEncryptedNoContent - update doc for functions ObtainContents and ProcessContents - update entries.rst - wrap some lines at 80 cols
Changes in v2: - adapt tests for changed entry implementation - add entry documentation - remove global /cipher node - replace key-name-hint with key-source property
Christian Taedcke (3): binman: Add support for externally encrypted blobs binman: Allow cipher node as special section binman: Add tests for etype encrypted
tools/binman/entries.rst | 88 ++++++++++ tools/binman/etype/encrypted.py | 157 ++++++++++++++++++ tools/binman/etype/section.py | 2 +- tools/binman/ftest.py | 52 ++++++ tools/binman/test/291_encrypted_no_algo.dts | 19 +++ .../test/292_encrypted_invalid_iv_file.dts | 23 +++ .../binman/test/293_encrypted_missing_key.dts | 28 ++++ .../binman/test/294_encrypted_key_source.dts | 29 ++++ tools/binman/test/295_encrypted_key_file.dts | 29 ++++ 9 files changed, 426 insertions(+), 1 deletion(-) create mode 100644 tools/binman/etype/encrypted.py create mode 100644 tools/binman/test/291_encrypted_no_algo.dts create mode 100644 tools/binman/test/292_encrypted_invalid_iv_file.dts create mode 100644 tools/binman/test/293_encrypted_missing_key.dts create mode 100644 tools/binman/test/294_encrypted_key_source.dts create mode 100644 tools/binman/test/295_encrypted_key_file.dts
This adds a new etype encrypted that is derived from collection.
It creates a new cipher node in the related image similar to the cipher node used by u-boot, see boot/image-cipher.c.
Signed-off-by: Christian Taedcke christian.taedcke@weidmueller.com ---
Changes in v3: - rebase on u-boot-dm/mkim-working - update doc for functions ObtainContents and ProcessContents - update entries.rst
Changes in v2: - add entry documentation - remove global /cipher node - replace key-name-hint with key-source property
tools/binman/entries.rst | 88 ++++++++++++++++++ tools/binman/etype/encrypted.py | 157 ++++++++++++++++++++++++++++++++ 2 files changed, 245 insertions(+) create mode 100644 tools/binman/etype/encrypted.py
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index b55f424620..d4bc5de1d3 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -468,6 +468,94 @@ updating the EC on startup via software sync.
+.. _etype_encrypted: + +Entry: encrypted: Externally built encrypted binary blob +-------------------------------------------------------- + +This entry provides the functionality to include information about how to +decrypt an encrypted binary. This information is added to the +resulting device tree by adding a new cipher node in the entry's parent +node (i.e. the binary). + +The key that must be used to decrypt the binary is either directly embedded +in the device tree or indirectly by specifying a key source. The key source +can be used as an id of a key that is stored in an external device. + +Using an embedded key +~~~~~~~~~~~~~~~~~~~~~ + +This is an example using an embedded key:: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-filename = "encrypted-blob.bin.key"; + }; + +This entry generates the following device tree structure form the example +above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key = <0x...>; + iv = <0x...>; + }; + +The data property is generated by the blob-ext etype, the cipher node and +its content is generated by this etype. + +Using an external key +~~~~~~~~~~~~~~~~~~~~~ + +Instead of embedding the key itself into the device tree, it is also +possible to address an externally stored key by specifying a 'key-source' +instead of the 'key':: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-source = "external-key-id"; + }; + +This entry generates the following device tree structure form the example +above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key-source = "external-key-id"; + iv = <0x...>; + }; + +Properties +~~~~~~~~~~ + +In addition to the inherited 'collection' for Properties / Entry arguments: + - algo: The encryption algorithm. Currently no algorithm is supported + out-of-the-box. Certain algorithms will be added in future + patches. + - iv-filename: The name of the file containing the initialization + vector (in short iv). See + https://en.wikipedia.org/wiki/Initialization_vector + - key-filename: The name of the file containing the key. Either + key-filename or key-source must be provided. + - key-source: The key that should be used. Either key-filename or + key-source must be provided. + + + .. _etype_fdtmap:
Entry: fdtmap: An entry which contains an FDT map diff --git a/tools/binman/etype/encrypted.py b/tools/binman/etype/encrypted.py new file mode 100644 index 0000000000..7638cfbe7f --- /dev/null +++ b/tools/binman/etype/encrypted.py @@ -0,0 +1,157 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2023 Weidmüller Interface GmbH & Co. KG +# Written by Christian Taedcke christian.taedcke@weidmueller.com +# +# Entry-type module for cipher information of encrypted blobs/binaries +# + +from binman.etype.collection import Entry_collection +from dtoc import fdt_util +from u_boot_pylib import tools + +# This is imported if needed +state = None + + +class Entry_encrypted(Entry_collection): + """Externally built encrypted binary blob + + This entry provides the functionality to include information about how to + decrypt an encrypted binary. This information is added to the + resulting device tree by adding a new cipher node in the entry's parent + node (i.e. the binary). + + The key that must be used to decrypt the binary is either directly embedded + in the device tree or indirectly by specifying a key source. The key source + can be used as an id of a key that is stored in an external device. + + Using an embedded key + ~~~~~~~~~~~~~~~~~~~~~ + + This is an example using an embedded key:: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-filename = "encrypted-blob.bin.key"; + }; + + This entry generates the following device tree structure form the example + above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key = <0x...>; + iv = <0x...>; + }; + + The data property is generated by the blob-ext etype, the cipher node and + its content is generated by this etype. + + Using an external key + ~~~~~~~~~~~~~~~~~~~~~ + + Instead of embedding the key itself into the device tree, it is also + possible to address an externally stored key by specifying a 'key-source' + instead of the 'key':: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-source = "external-key-id"; + }; + + This entry generates the following device tree structure form the example + above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key-source = "external-key-id"; + iv = <0x...>; + }; + + Properties + ~~~~~~~~~~ + + In addition to the inherited 'collection' for Properties / Entry arguments: + - algo: The encryption algorithm. Currently no algorithm is supported + out-of-the-box. Certain algorithms will be added in future + patches. + - iv-filename: The name of the file containing the initialization + vector (in short iv). See + https://en.wikipedia.org/wiki/Initialization_vector + - key-filename: The name of the file containing the key. Either + key-filename or key-source must be provided. + - key-source: The key that should be used. Either key-filename or + key-source must be provided. + """ + + def __init__(self, section, etype, node): + # Put this here to allow entry-docs and help to work without libfdt + global state + from binman import state + + super().__init__(section, etype, node) + self.required_props = ['algo', 'iv-filename'] + self._algo = None + self._iv_filename = None + self._key_name_hint = None + self._key_filename = None + + def ReadNode(self): + super().ReadNode() + + self._algo = fdt_util.GetString(self._node, 'algo') + self._iv_filename = fdt_util.GetString(self._node, 'iv-filename') + self._key_filename = fdt_util.GetString(self._node, 'key-filename') + self._key_source = fdt_util.GetString(self._node, 'key-source') + + if self._key_filename is None and self._key_source is None: + self.Raise("Provide either 'key-filename' or 'key-source'") + + def gen_entries(self): + super().gen_entries() + + iv_filename = tools.get_input_filename(self._iv_filename) + iv = tools.read_file(iv_filename, binary=True) + + cipher_node = state.AddSubnode(self._node.parent, "cipher") + cipher_node.AddString("algo", self._algo) + cipher_node.AddData("iv", iv) + + if self._key_filename: + key_filename = tools.get_input_filename(self._key_filename) + key = tools.read_file(key_filename, binary=True) + cipher_node.AddData("key", key) + + if self._key_source: + cipher_node.AddString("key-source", self._key_source) + + def ObtainContents(self): + """Set to empty contents + + Ensure that linked content is not added to the device tree again from + this entry. + """ + self.SetContents(b'') + return True + + def ProcessContents(self): + """Set to empty contents + + Ensure that linked content is not added to the device tree again from + this entry. + """ + return self.ProcessContentsUpdate(b'')
The new encrypted etype generates a cipher node in the device tree that should not be evaluated by binman, but still be kept in the output device tree.
tools/binman/etype/section.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 7c4d312c16..fb49e85a76 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -179,7 +179,7 @@ class Entry_section(Entry): Returns: bool: True if the node is a special one, else False """ - start_list = ('hash', 'signature', 'template') + start_list = ('cipher', 'hash', 'signature', 'template') return any(node.name.startswith(name) for name in start_list)
def ReadNode(self):
Add tests to reach 100% code coverage for the added etype encrypted.
Changes in v3: - rebase on u-boot-dm/mkim-working - remove unnecessary test testEncryptedNoContent - wrap some lines at 80 cols
tools/binman/ftest.py | 52 +++++++++++++++++++ tools/binman/test/291_encrypted_no_algo.dts | 19 +++++++ .../test/292_encrypted_invalid_iv_file.dts | 23 ++++++++ .../binman/test/293_encrypted_missing_key.dts | 28 ++++++++++ .../binman/test/294_encrypted_key_source.dts | 29 +++++++++++ tools/binman/test/295_encrypted_key_file.dts | 29 +++++++++++ 6 files changed, 180 insertions(+) create mode 100644 tools/binman/test/291_encrypted_no_algo.dts create mode 100644 tools/binman/test/292_encrypted_invalid_iv_file.dts create mode 100644 tools/binman/test/293_encrypted_missing_key.dts create mode 100644 tools/binman/test/294_encrypted_key_source.dts create mode 100644 tools/binman/test/295_encrypted_key_file.dts
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index e53181afb7..d64b1742aa 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -94,6 +94,8 @@ ROCKCHIP_TPL_DATA = b'rockchip-tpl' TEST_FDT1_DATA = b'fdt1' TEST_FDT2_DATA = b'test-fdt2' ENV_DATA = b'var1=1\nvar2="2"' +ENCRYPTED_IV_DATA = b'123456' +ENCRYPTED_KEY_DATA = b'abcd' PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') @@ -226,6 +228,10 @@ class TestFunctional(unittest.TestCase): # Newer OP_TEE file in v1 binary format cls.make_tee_bin('tee.bin')
+ # test files for encrypted tests + TestFunctional._MakeInputFile('encrypted-file.iv', ENCRYPTED_IV_DATA) + TestFunctional._MakeInputFile('encrypted-file.key', ENCRYPTED_KEY_DATA) + cls.comp_bintools = {} for name in COMP_BINTOOLS: cls.comp_bintools[name] = bintool.Bintool.create(name) @@ -6884,6 +6890,52 @@ fdt fdtmap Extract the devicetree blob from the fdtmap # Move to next spl_data = content[:0x18]
+ def testEncryptedNoAlgo(self): + with self.assertRaises(ValueError) as e: + self._DoReadFileDtb('291_encrypted_no_algo.dts') + self.assertIn( + "Node '/binman/fit/images/u-boot/encrypted': 'encrypted' entry is missing properties: algo iv-filename", + str(e.exception)) + + def testEncryptedInvalidIvfile(self): + with self.assertRaises(ValueError) as e: + self._DoReadFileDtb('292_encrypted_invalid_iv_file.dts') + self.assertIn("Filename 'invalid-iv-file' not found in input path", + str(e.exception)) + + def testEncryptedMissingKey(self): + with self.assertRaises(ValueError) as e: + self._DoReadFileDtb('293_encrypted_missing_key.dts') + self.assertIn( + "Node '/binman/fit/images/u-boot/encrypted': Provide either 'key-filename' or 'key-source'", + str(e.exception)) + + def testEncryptedKeySource(self): + data = self._DoReadFileDtb('294_encrypted_key_source.dts')[0] + + dtb = fdt.Fdt.FromData(data) + dtb.Scan() + + node = dtb.GetNode('/images/u-boot/cipher') + self.assertEqual('algo-name', node.props['algo'].value) + self.assertEqual('key-source-value', node.props['key-source'].value) + self.assertEqual(ENCRYPTED_IV_DATA, + tools.to_bytes(''.join(node.props['iv'].value))) + self.assertNotIn('key', node.props) + + def testEncryptedKeyFile(self): + data = self._DoReadFileDtb('295_encrypted_key_file.dts')[0] + + dtb = fdt.Fdt.FromData(data) + dtb.Scan() + + node = dtb.GetNode('/images/u-boot/cipher') + self.assertEqual('algo-name', node.props['algo'].value) + self.assertEqual(ENCRYPTED_IV_DATA, + tools.to_bytes(''.join(node.props['iv'].value))) + self.assertEqual(ENCRYPTED_KEY_DATA, b''.join(node.props['key'].value)) + self.assertNotIn('key-source', node.props) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/291_encrypted_no_algo.dts b/tools/binman/test/291_encrypted_no_algo.dts new file mode 100644 index 0000000000..71975c0116 --- /dev/null +++ b/tools/binman/test/291_encrypted_no_algo.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + fit { + images { + u-boot { + encrypted { + content = <&data>; + }; + + data: data { + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/292_encrypted_invalid_iv_file.dts b/tools/binman/test/292_encrypted_invalid_iv_file.dts new file mode 100644 index 0000000000..1764d5e503 --- /dev/null +++ b/tools/binman/test/292_encrypted_invalid_iv_file.dts @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + fit { + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "some-algo"; + key-source = "key"; + iv-filename = "invalid-iv-file"; + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/293_encrypted_missing_key.dts b/tools/binman/test/293_encrypted_missing_key.dts new file mode 100644 index 0000000000..9d342d6f45 --- /dev/null +++ b/tools/binman/test/293_encrypted_missing_key.dts @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test desc"; + + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "algo-name"; + iv-filename = "encrypted-file.iv"; + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/294_encrypted_key_source.dts b/tools/binman/test/294_encrypted_key_source.dts new file mode 100644 index 0000000000..d2529b9c3a --- /dev/null +++ b/tools/binman/test/294_encrypted_key_source.dts @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test desc"; + + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "algo-name"; + key-source = "key-source-value"; + iv-filename = "encrypted-file.iv"; + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/295_encrypted_key_file.dts b/tools/binman/test/295_encrypted_key_file.dts new file mode 100644 index 0000000000..71f1ab47b1 --- /dev/null +++ b/tools/binman/test/295_encrypted_key_file.dts @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test desc"; + + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "algo-name"; + iv-filename = "encrypted-file.iv"; + key-filename = "encrypted-file.key"; + }; + }; + }; + }; + }; +};
christian.taedcke-oss@weidmueller.com
