[U-Boot-Users] MPCFADS860T -- any active uboot developers?
I have u-boot up and running on a MPC860T-FADS eval board, but it is extremely unstable... are there active FADS developers using this board currently?
Also, Wolfgang, I have one or two minor patches for this board, but I'm not sure if the differences are intentional. One of the patches adds a FLASH_ internal define to flash.h; last time I did this (in ppc-boot) you indicated not to add any more of those.. what is the policy for adding those in u-boot?
I guess you see just what many people experienced on the FADS: the board itself is unstable.
I don't remember which sort of modifications you mean, but the policy is the same: include/flash.h is a global header file and should not contain board-specific data.
I am in the process of getting a 866ADS - are those any better, or is that just a daughter board for the FADS?
also, here are the minor patches for the FADS; im not sure why the original config file calls for max flash banks 4, when only 1 is (apparently) supported:
Index: board/fads/fads.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/board/fads/fads.c,v retrieving revision 1.1.1.1 diff -u -b -B -w -p -r1.1.1.1 fads.c --- board/fads/fads.c 3 Nov 2002 00:43:23 -0000 1.1.1.1 +++ board/fads/fads.c 1 May 2003 19:25:09 -0000 @@ -208,6 +208,7 @@ int checkboard (void) case 0x22 : case 0x23 : case 0x24 : + case 0x2a : case 0x3f : puts ("FADS"); break; Index: board/fads/flash.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/board/fads/flash.c,v retrieving revision 1.1.1.1 diff -u -b -B -w -p -r1.1.1.1 flash.c --- board/fads/flash.c 17 Aug 2002 09:36:02 -0000 1.1.1.1 +++ board/fads/flash.c 1 May 2003 19:25:09 -0000 @@ -147,7 +147,7 @@ static void flash_get_offsets (ulong bas int i;
/* set up sector start address table */ - if ((info->flash_id & FLASH_TYPEMASK) == FLASH_AM040) { + if ((info->flash_id & FLASH_TYPEMASK) == FLASH_AM040 || (info->flash_id & FLASH_TYPEMASK) == FLASH_AM080 ) { /* set sector offsets for uniform sector type */ for (i = 0; i < info->sector_count; i++) { info->start[i] = base + (i * 0x00040000); @@ -179,6 +179,8 @@ void flash_print_info (flash_info_t *in { case FLASH_AM040: printf ("29F040 or 29LV040 (4 Mbit, uniform sectors)\n"); break; + case FLASH_AM080: printf ("29F080 or 29LV080 (8 Mbit, uniform sectors)\n"); + break; case FLASH_AM400B: printf ("AM29LV400B (4 Mbit, bottom boot sect)\n"); break; case FLASH_AM400T: printf ("AM29LV400T (4 Mbit, top boot sector)\n"); @@ -277,6 +279,12 @@ static ulong flash_get_size (vu_long *ad info->sector_count = 8; info->size = 0x00200000; break; /* => 2 MB */ + + case AMD_ID_F080B: + info->flash_id += FLASH_AM080; + info->sector_count =16; + info->size = 0x00400000; + break; /* => 4 MB */
case AMD_ID_LV400T: info->flash_id += FLASH_AM400T; Index: include/flash.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/flash.h,v retrieving revision 1.4 diff -u -b -B -w -p -r1.4 flash.h --- include/flash.h 26 Mar 2003 06:55:50 -0000 1.4 +++ include/flash.h 1 May 2003 19:25:11 -0000 @@ -129,6 +129,8 @@ extern int flash_real_protect(flash_info /* 4 Mbit, 512K x 8, */ /* 8 64K x 8 uniform sectors */ #define AMD_ID_F080B 0xD5 /* 29F080 ID ( 1 M) */ + /* 8 Mbit, 512K x 16, */ + /* 8 64K x 16 uniform sectors */ #define AMD_ID_F016D 0xAD /* 29F016 ID ( 2 M x 8) */ #define AMD_ID_F032B 0x41 /* 29F032 ID ( 4 M x 8) */ #define AMD_ID_LV116DT 0xC7 /* 29LV116DT ( 2 M x 8, top boot sect) */ @@ -219,13 +221,12 @@ extern int flash_real_protect(flash_info * Be careful when adding new type! Odd numbers are "bottom boot sector" types! */
-#define FLASH_AM040 0x0001 /* AMD Am29F040B, Am29LV040B - * Bright Micro BM29F040 - * Fujitsu MBM29F040A - * STM M29W040B - * SGS Thomson M29F040B - * 8 64K x 8 uniform sectors - */ +#define FLASH_AM040 0x0001 /* AMD Am29F040B, Am29LV040B */ + /* Bright Micro BM29F040 */ + /* Fujitsu MBM29F040A */ + /* STM M29W040B */ + /* SGS Thomson M29F040B */ + /* 8 64K x 8 uniform sectors */ #define FLASH_AM400T 0x0002 /* AMD AM29LV400 */ #define FLASH_AM400B 0x0003 #define FLASH_AM800T 0x0004 /* AMD AM29LV800 */ @@ -236,6 +237,9 @@ extern int flash_real_protect(flash_info #define FLASH_AM160B 0x0007 #define FLASH_AM320T 0x0008 /* AMD AM29LV320 */ #define FLASH_AM320B 0x0009 + +#define FLASH_AM080 0x000A /* AMD Am29F080B */ + /* 16 64K x 8 uniform sectors */
#define FLASH_AMDL322T 0x0010 /* AMD AM29DL322 */ #define FLASH_AMDL322B 0x0011 Index: include/configs/FADS860T.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/FADS860T.h,v retrieving revision 1.1.1.1 diff -u -b -B -w -p -r1.1.1.1 FADS860T.h --- include/configs/FADS860T.h 11 Oct 2002 15:28:19 -0000 1.1.1.1 +++ include/configs/FADS860T.h 1 May 2003 19:25:11 -0000 @@ -159,8 +159,8 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 4 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 8 /* max number of sectors on one chip */ +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 16 /* max number of sectors on one chip */
#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
Nye Liu
