[PATCH v2 1/2] phy: mv88e61xx: add support for RGMII TX/RX delay
Clock delay in RGMII is required for some boards.
Clock delay is read from phy-mode dts property. Delay is configured via proper bits in PORT_REG_PHYS_CTRL register.
Cc: Chris Packham judge.packham@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Anatolij Gustschin agust@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Tom Rini trini@konsulko.com Signed-off-by: Pawel Dembicki paweldembicki@gmail.com --- Changes in v2: - change source info about delay: from hardcode to phy-mode propoperty in dts
drivers/net/phy/mv88e61xx.c | 62 ++++++++++++++++++++++++++++++++++++- 1 file changed, 61 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/mv88e61xx.c b/drivers/net/phy/mv88e61xx.c index 7eff37b244..70adec6578 100644 --- a/drivers/net/phy/mv88e61xx.c +++ b/drivers/net/phy/mv88e61xx.c @@ -97,6 +97,8 @@ #define PORT_REG_STATUS_CMODE_1000BASE_X 0x9 #define PORT_REG_STATUS_CMODE_SGMII 0xa
+#define PORT_REG_PHYS_CTRL_RGMII_RX_DELAY BIT(15) +#define PORT_REG_PHYS_CTRL_RGMII_TX_DELAY BIT(14) #define PORT_REG_PHYS_CTRL_PCS_AN_EN BIT(10) #define PORT_REG_PHYS_CTRL_PCS_AN_RST BIT(9) #define PORT_REG_PHYS_CTRL_FC_VALUE BIT(7) @@ -729,7 +731,45 @@ unforce: static int mv88e61xx_fixed_port_setup(struct phy_device *phydev, u8 port) { struct mv88e61xx_phy_priv *priv = phydev->priv; - int val; + ofnode node; + const char *str; + int val, phy_mode; + u32 phy_handle; + + if (!ofnode_valid(phydev->node)) { + node = dev_ofnode(phydev->dev); + phy_handle = ofnode_read_u32_default(node, "phy-handle", -ENXIO); + + if (phy_handle == -ENXIO) { + node = ofnode_first_subnode(node); + + while (ofnode_valid(node)) { + phy_handle = ofnode_read_u32_default(node, "phy-handle", -ENXIO); + if (phy_handle != -ENXIO) + break; + node = ofnode_next_subnode(node); + } + } + + if (phy_handle != -ENXIO) + node = ofnode_get_by_phandle(phy_handle); + else + node = ofnode_null(); + } else { + node = phy_get_ofnode(phydev); + } + + node = ofnode_find_subnode(node, "ports"); + node = ofnode_first_subnode(node); + + while (ofnode_valid(node)) { + u8 port_no = (u8)ofnode_read_u32_default(node, "reg", -1); + + if (port_no == port) + break; + + node = ofnode_next_subnode(node); + }
val = mv88e61xx_port_read(phydev, port, PORT_REG_PHYS_CTRL); if (val < 0) @@ -754,6 +794,26 @@ static int mv88e61xx_fixed_port_setup(struct phy_device *phydev, u8 port) val |= PORT_REG_PHYS_CTRL_LINK_VALUE | PORT_REG_PHYS_CTRL_LINK_FORCE;
+ if (ofnode_valid(node)) { + str = ofnode_read_string(node, "phy-mode"); + if (str) + phy_mode = phy_get_interface_by_name(str); + switch (phy_mode) { + case PHY_INTERFACE_MODE_RGMII_ID: + val |= PORT_REG_PHYS_CTRL_RGMII_RX_DELAY; + val |= PORT_REG_PHYS_CTRL_RGMII_TX_DELAY; + break; + case PHY_INTERFACE_MODE_RGMII_RXID: + val |= PORT_REG_PHYS_CTRL_RGMII_RX_DELAY; + break; + case PHY_INTERFACE_MODE_RGMII_TXID: + val |= PORT_REG_PHYS_CTRL_RGMII_TX_DELAY; + break; + default: + break; + } + } + return mv88e61xx_port_write(phydev, port, PORT_REG_PHYS_CTRL, val); }
This patch add MV88E6171 id to driver data.
Tested on Checkpoint L-50 board.
Cc: Chris Packham judge.packham@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Anatolij Gustschin agust@denx.de Cc: Tim Harvey tharvey@gateworks.com Signed-off-by: Pawel Dembicki paweldembicki@gmail.com --- Changes in v2: - resend only
drivers/net/phy/mv88e61xx.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/net/phy/mv88e61xx.c b/drivers/net/phy/mv88e61xx.c index 70adec6578..432cc4165b 100644 --- a/drivers/net/phy/mv88e61xx.c +++ b/drivers/net/phy/mv88e61xx.c @@ -183,6 +183,7 @@ #define PORT_SWITCH_ID_6071 0x0710 #define PORT_SWITCH_ID_6096 0x0980 #define PORT_SWITCH_ID_6097 0x0990 +#define PORT_SWITCH_ID_6171 0x1710 #define PORT_SWITCH_ID_6172 0x1720 #define PORT_SWITCH_ID_6176 0x1760 #define PORT_SWITCH_ID_6220 0x2200 @@ -1051,6 +1052,7 @@ static int mv88e61xx_probe(struct phy_device *phydev) switch (priv->id) { case PORT_SWITCH_ID_6096: case PORT_SWITCH_ID_6097: + case PORT_SWITCH_ID_6171: case PORT_SWITCH_ID_6172: case PORT_SWITCH_ID_6176: case PORT_SWITCH_ID_6240: @@ -1206,6 +1208,17 @@ static struct phy_driver mv88e61xx_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver mv88e617x_driver = { + .name = "Marvell MV88E617x", + .uid = 0x01410e70, + .mask = 0xfffffff0, + .features = PHY_GBIT_FEATURES, + .probe = mv88e61xx_probe, + .config = mv88e61xx_phy_config, + .startup = mv88e61xx_phy_startup, + .shutdown = &genphy_shutdown, +}; + static struct phy_driver mv88e609x_driver = { .name = "Marvell MV88E609x", .uid = 0x1410c89, @@ -1231,6 +1244,7 @@ static struct phy_driver mv88e6071_driver = { int phy_mv88e61xx_init(void) { phy_register(&mv88e61xx_driver); + phy_register(&mv88e617x_driver); phy_register(&mv88e609x_driver); phy_register(&mv88e6071_driver);
(Note: viewing on mobile device so my comment below could be wrong)
Changes in v2:
dts
int val;
ofnode node;
const char *str;
int val, phy_mode;
u32 phy_handle;
-ENXIO);
break;
else
} else {
break;
} val = mv88e61xx_port_read(phydev, port, PORT_REG_PHYS_CTRL); if (val < 0)
Should the 2 bits be cleared before we set them. In case there is config from an earlier boot stage or eeprom?
if (str)
This would probably be the sensible place to clear the bits as we know we have a phy-mode at this point.
break;
break;
break;
default:
break;
2.25.1
Chris Packham
Pawel Dembicki
