[GIT PULL] u-boot-riscv/next
Hi Tom,
The following changes since commit 3b3c7280b82b1f08807a070ac066cd02919dfde1:
smbios: address build warning (2024-12-15 11:41:32 -0600)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git next
for you to fetch changes up to e59241f8b1315168b7a8a2645c3d3fe73ea5d6d9:
riscv: spl: add FIT name for RISC-V Falcon mode (2024-12-18 13:19:16 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/23926 ---------------------------------------------------------------- - Board: Support LicheeRV Nano - Board: Support bananapi-f3 - Board: Switch to OF_UPSTREAM for StarFive JH7110 - Board: Add sdhci driver for TH1520 SoC ---------------------------------------------------------------- Hal Feng (12): dts: starfive: Switch to using upstream DT riscv: dts: jh7110: Make u-boot device trees adapting to upstream DT mmc: dw_mmc: Add "starfive, jh7110-mmc" compatible to match upstream DT pcie: starfive: Make the driver compatible with upstream DT riscv: dts: jh7110: Move common code to the new jh7110-common-u-boot.dtsi riscv: dts: jh7110: Add u-boot device tree for JH7110 based boards board: starfive: spl: Drop the unneeded DT modification code configs: visionfive2: Enable MULTI_DTB_FIT for JH7110 based board DT riscv: dts: jh7110: Support multiple DTBs in a Fit image board: starfive: spl: Fix the wrong use of CONFIG_IS_ENABLED() board: starfive: spl: Support multiple DTBs for JH7110 based boards riscv: cpu: jh7110: Sort the list of imply statements
Kongyang Liu (2): riscv: spacemit: bananapi_f3: initial support added doc: spacemit: bananapi_f3: document Banana Pi F3 board
Maksim Kiselev (3): mmc: snps_sdhci: Add sdhci driver support for TH1520 SoC riscv: dts: t-head: Add sdhci and emmc nodes configs: th1520_lpi4a: enable mmc controller support
Randolph (1): riscv: spl: add FIT name for RISC-V Falcon mode
Thomas Bonnefille (3): doc: add LicheeRV Nano and SG2002 SoC riscv: dts: sophgo: add device tree for LicheeRV Nano board: add support for LicheeRV Nano
arch/riscv/Kconfig | 9 + arch/riscv/cpu/jh7110/Kconfig | 19 +- arch/riscv/cpu/k1/Kconfig | 18 + arch/riscv/cpu/k1/Makefile | 6 + arch/riscv/cpu/k1/cpu.c | 9 + arch/riscv/cpu/k1/dram.c | 54 ++ arch/riscv/dts/Makefile | 4 +- arch/riscv/dts/jh7110-common-u-boot.dtsi | 195 ++++++ arch/riscv/dts/jh7110-milkv-mars-u-boot.dtsi | 6 + arch/riscv/dts/jh7110-pine64-star64-u-boot.dtsi | 6 + .../dts/jh7110-starfive-visionfive-2-u-boot.dtsi | 117 ---- .../jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi | 6 + .../jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi | 6 + arch/riscv/dts/jh7110-starfive-visionfive-2.dts | 11 - arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi | 380 ---------- arch/riscv/dts/jh7110-u-boot.dtsi | 27 +- arch/riscv/dts/jh7110.dtsi | 761 --------------------- arch/riscv/dts/k1-bananapi-f3.dts | 25 + arch/riscv/dts/k1.dtsi | 459 +++++++++++++ arch/riscv/dts/sg2002-licheerv-nano-b.dts | 45 ++ arch/riscv/dts/sg2002.dtsi | 34 + arch/riscv/dts/th1520-lichee-module-4a.dtsi | 18 + arch/riscv/dts/th1520.dtsi | 34 + board/sophgo/licheerv_nano/Kconfig | 28 + board/sophgo/licheerv_nano/MAINTAINERS | 5 + board/sophgo/licheerv_nano/Makefile | 5 + board/sophgo/licheerv_nano/board.c | 9 + board/spacemit/bananapi-f3/Kconfig | 25 + board/spacemit/bananapi-f3/MAINTAINERS | 6 + board/spacemit/bananapi-f3/Makefile | 5 + board/spacemit/bananapi-f3/board.c | 9 + board/starfive/visionfive2/spl.c | 391 +---------- common/spl/Kconfig | 1 + configs/bananapi-f3_defconfig | 20 + configs/sipeed_licheerv_nano_defconfig | 47 ++ configs/starfive_visionfive2_defconfig | 4 +- configs/th1520_lpi4a_defconfig | 11 +- doc/board/index.rst | 1 + doc/board/sophgo/index.rst | 1 + doc/board/sophgo/licheerv_nano.rst | 72 ++ doc/board/spacemit/bananapi-f3.rst | 106 +++ doc/board/spacemit/index.rst | 9 + drivers/clk/starfive/clk-jh7110-pll.c | 6 +- drivers/clk/starfive/clk-jh7110.c | 44 +- drivers/mmc/Kconfig | 12 + drivers/mmc/Makefile | 1 + drivers/mmc/snps_dw_mmc.c | 1 + drivers/mmc/snps_sdhci.c | 444 ++++++++++++ drivers/pci/pcie_starfive_jh7110.c | 59 +- include/configs/bananapi-f3.h | 13 + include/configs/licheerv_nano.h | 24 + include/dt-bindings/clock/starfive,jh7110-crg.h | 258 ------- include/dt-bindings/reset/starfive,jh7110-crg.h | 183 ----- 53 files changed, 1909 insertions(+), 2140 deletions(-) create mode 100644 arch/riscv/cpu/k1/Kconfig create mode 100644 arch/riscv/cpu/k1/Makefile create mode 100644 arch/riscv/cpu/k1/cpu.c create mode 100644 arch/riscv/cpu/k1/dram.c create mode 100644 arch/riscv/dts/jh7110-common-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-milkv-mars-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-pine64-star64-u-boot.dtsi delete mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.2a-u-boot.dtsi create mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2-v1.3b-u-boot.dtsi delete mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2.dts delete mode 100644 arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi delete mode 100644 arch/riscv/dts/jh7110.dtsi create mode 100644 arch/riscv/dts/k1-bananapi-f3.dts create mode 100644 arch/riscv/dts/k1.dtsi create mode 100644 arch/riscv/dts/sg2002-licheerv-nano-b.dts create mode 100644 arch/riscv/dts/sg2002.dtsi create mode 100644 board/sophgo/licheerv_nano/Kconfig create mode 100644 board/sophgo/licheerv_nano/MAINTAINERS create mode 100644 board/sophgo/licheerv_nano/Makefile create mode 100644 board/sophgo/licheerv_nano/board.c create mode 100644 board/spacemit/bananapi-f3/Kconfig create mode 100644 board/spacemit/bananapi-f3/MAINTAINERS create mode 100644 board/spacemit/bananapi-f3/Makefile create mode 100644 board/spacemit/bananapi-f3/board.c create mode 100644 configs/bananapi-f3_defconfig create mode 100644 configs/sipeed_licheerv_nano_defconfig create mode 100644 doc/board/sophgo/licheerv_nano.rst create mode 100644 doc/board/spacemit/bananapi-f3.rst create mode 100644 doc/board/spacemit/index.rst create mode 100644 drivers/mmc/snps_sdhci.c create mode 100644 include/configs/bananapi-f3.h create mode 100644 include/configs/licheerv_nano.h delete mode 100644 include/dt-bindings/clock/starfive,jh7110-crg.h delete mode 100644 include/dt-bindings/reset/starfive,jh7110-crg.h
Best regards, Leo
On Wed, Dec 18, 2024 at 03:49:44PM +0800, Leo Liang wrote:
Hi Tom,
Leo Liang
