[U-Boot-Users] difference between nand writes
5 Jun
2007
5 Jun
'07
3:24 p.m.
Hi, I observe that there are 2 nand writes. nand write -- which we use to flash the kernel nand write.jffs2 which we use to flash the filesystem.
What is the difference between these 2 nand write and nand write.jffs2.
Is it only that when we use nand write.jffs2 bad blocks are skipped.
if so, if there is a bad block in the linux kernel partition - will the write fail?.
Thanks and regards,
Regards, sriram
6547
Ram
