[U-Boot] [PATCH 0/3] ARM: fix the Kconfig misconversion of CONFIG_USE_ARCH_MEMCPY/MEMSET
Masahiro Yamada (3): ARM: revive CONFIG_USE_ARCH_MEMCPY/MEMSET for UniPhier and Tegra common/init: remove meaningless defined(CONFIG_USE_ARCH_MEMSET) README: remove description about CONFIG_USE_ARCH_MEMCPY/SET
README | 6 ------ arch/arm/Kconfig | 4 ++-- arch/arm/include/asm/string.h | 4 ++-- common/init/board_init.c | 4 +--- 4 files changed, 5 insertions(+), 13 deletions(-)
Commit be72591bcd64 ("Kconfig: Move USE_ARCH_MEMCPY/MEMSET to Kconfig") is misconversion.
The original logic in include/configs/uniphier.h was as follows:
#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_ARM64) #define CONFIG_USE_ARCH_MEMSET #define CONFIG_USE_ARCH_MEMCPY #endif
This means those configs were enabled when building U-Boot proper, but disabled when building SPL. Likewise for Tegra.
Now "depends on !SPL" prevents any boards with SPL support from reaching these options. This changed the behavior for UniPhier and Tegra SoC family.
Please notice these two options only control the U-Boot proper build. As you see arch/arm/Makefile, ARM-specific memset/memcpy are never compiled for SPL. So, __HAVE_ARCH_MEMCPY/MEMSET should not set for SPL.
Fixes: be72591bcd64 ("Kconfig: Move USE_ARCH_MEMCPY/MEMSET to Kconfig") Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
I am restoring the original behavior for now. But, I have been wondering if we could remove these options entirely.
As you see scripts/config_whitelist.txt, we still have 8000 options. As I stated before, it is a crazy idea to move all of them as they are.
We should refactor the code, and we should delete options if they turned out unneeded.
I think CONFIG_USE_ARCH_MEMSET/MEMCPY are questionable ones.
U-Boot supports arch-optimized memcpy/memset for ARC, ARM (only 32bit), Blackfin, PowerPC, and x86.
Strange enough, only ARM 32bit uses CONFIG_USE_ARCH_MEMSET/MEMCPY to make it user-configurable. (Other architectures always turn on the optimized variants if supported)
Even more strangely, those two options enable/disable ARM-specific memcpy/memset for the U-Boot full image. (Please note they are never compiled for SPL)
The U-Boot full image generally does not have strong memory footprint constraint. So, if we talk about the image size, it shouldn't hurt to enable ARM-optimized memcpy/set all the time.
arch/arm/Kconfig | 4 ++-- arch/arm/include/asm/string.h | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 587f288..6820479 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -129,7 +129,7 @@ config ENABLE_ARM_SOC_BOOT0_HOOK config USE_ARCH_MEMCPY bool "Use an assembly optimized implementation of memcpy" default y if CPU_V7 - depends on !ARM64 && !SPL + depends on !ARM64 help Enable the generation of an optimized version of memcpy. Such implementation may be faster under some conditions @@ -138,7 +138,7 @@ config USE_ARCH_MEMCPY config USE_ARCH_MEMSET bool "Use an assembly optimized implementation of memset" default y if CPU_V7 - depends on !ARM64 && !SPL + depends on !ARM64 help Enable the generation of an optimized version of memset. Such implementation may be faster under some conditions diff --git a/arch/arm/include/asm/string.h b/arch/arm/include/asm/string.h index c6dfb25..11eaa34 100644 --- a/arch/arm/include/asm/string.h +++ b/arch/arm/include/asm/string.h @@ -14,7 +14,7 @@ extern char * strrchr(const char * s, int c); #undef __HAVE_ARCH_STRCHR extern char * strchr(const char * s, int c);
-#ifdef CONFIG_USE_ARCH_MEMCPY +#if CONFIG_IS_ENABLED(USE_ARCH_MEMCPY) #define __HAVE_ARCH_MEMCPY #endif extern void * memcpy(void *, const void *, __kernel_size_t); @@ -26,7 +26,7 @@ extern void * memmove(void *, const void *, __kernel_size_t); extern void * memchr(const void *, int, __kernel_size_t);
#undef __HAVE_ARCH_MEMZERO -#ifdef CONFIG_USE_ARCH_MEMSET +#if CONFIG_IS_ENABLED(USE_ARCH_MEMSET) #define __HAVE_ARCH_MEMSET #endif extern void * memset(void *, int, __kernel_size_t);
On Mon, Dec 19, 2016 at 8:31 AM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Ah, oops, thanks for spotting that one.
We cannot. That was my first attempt and we have a handful of active (I checked) boards with tiny enough SPL constraints that switching to the optimized memcpy/memset push them over size limit and they do not have a "something" to disable to gain the space back. So I went with asking for asking for a conversion to enable by default these options as widely as possible as it's a good thing by and (no pun intended) large.
2016-12-20 6:59 GMT+09:00 Tom Rini trini@konsulko.com:
Perhaps, I may be missing something, but I could not understand why you were talking about SPL size constraints.
As far as I understood arch/arm/lib/Makefile, arch/arm/lib/memset.o is never compiled for SPL in the first place.
I believe CONFIG_USE_ARCH_MEMSET has no impact to SPL.
ifndef CONFIG_SPL_BUILD ifdef CONFIG_ARM64 obj-y += relocate_64.o else obj-y += relocate.o endif
obj-$(CONFIG_CPU_V7M) += cmd_boot.o obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o obj-$(CONFIG_CMD_BOOTI) += bootm.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o obj-$(CONFIG_USE_ARCH_MEMSET) += memset.o obj-$(CONFIG_USE_ARCH_MEMCPY) += memcpy.o else obj-$(CONFIG_SPL_FRAMEWORK) += spl.o obj-$(CONFIG_SPL_FRAMEWORK) += zimage.o endif
Because, blarg, oversight. We want these available to SPL because it fixes problems (due to non-optimized memset being so slow) on some platforms and otherwise is a speed win. I had been testing changes to move this all globally over, and found the size problems there.
But... at this point, no, I shouldn't also pull in making these functions be in SPL as I had intended, I should be good and correct that part in v2017.03. And take your Kconfig fix as-is, as it's correct.
Fixes: be72591bcd64 ("Kconfig: Move USE_ARCH_MEMCPY/MEMSET to Kconfig") Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
CONFIG_USE_ARCH_MEMSET controls nothing about SPL. (it is effective only on U-Boot proper building of ARM).
common/init/board_init.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/common/init/board_init.c b/common/init/board_init.c index ef01a9a..a2edb4e 100644 --- a/common/init/board_init.c +++ b/common/init/board_init.c @@ -15,9 +15,7 @@ DECLARE_GLOBAL_DATA_PTR; * It isn't trivial to figure out whether memcpy() exists. The arch-specific * memcpy() is not normally available in SPL due to code size. */ -#if !defined(CONFIG_SPL_BUILD) || \ - (defined(CONFIG_SPL_LIBGENERIC_SUPPORT) && \ - !defined(CONFIG_USE_ARCH_MEMSET)) +#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBGENERIC_SUPPORT) #define _USE_MEMCPY #endif
That's not true. We have these functions available to SPL and use them there by default now (as it's a speed win and we want out of SPL ASAP).
Hi Tom.
2016-12-20 7:02 GMT+09:00 Tom Rini trini@konsulko.com:
This is not clear to me.
How can you make the optimized memset available to SPL?
As far as see arch/arm/lib/Makefile, memset.o is only compiled (if CONFIG_USE_ARCH_MEMSET is defined) for the U-Boot full image.
These options are now described in the Kconfig help. We do not want to maintain duplicated documentation.
README | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/README b/README index 25cad2f..0bd6e6c 100644 --- a/README +++ b/README @@ -4593,12 +4593,6 @@ Low Level (hardware related) configuration options: addressable memory. This option causes some memory accesses to be mapped through map_sysmem() / unmap_sysmem().
-- CONFIG_USE_ARCH_MEMCPY - CONFIG_USE_ARCH_MEMSET - If these options are used a optimized version of memcpy/memset will - be used if available. These functions may be faster under some - conditions but may increase the binary size. - - CONFIG_X86_RESET_VECTOR If defined, the x86 reset vector code is included. This is not needed when U-Boot is running from Coreboot.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Fabio Estevam fabio.estevam@nxp.com Reviewed-by: Tom Rini trini@konsulko.com
Fabio Estevam
Masahiro Yamada
