[U-Boot] [PATCH] arm: qemu: fix failure in flash initialization if booting from TF-A
If U-Boot is loaded and started from TF-A (you need to change SYS_TEXT_BASE to 0x60000000), it will hang up at flash initialization.
If secure mode is off (default, or -machine virt,secure=off) at qemu, it will provide dtb with two flash memory banks: flash@0 { bank-width = <0x4>; reg = <0x0 0x0 0x0 0x4000000 0x0 0x4000000 0x0 0x4000000>; compatible = "cfi-flash"; }; If secure mode is on, on the other hand, qemu provides dtb with 1 bank: flash@0 { bank-width = <0x4>; reg = <0x0 0x4000000 0x0 0x4000000>; compatible = "cfi-flash"; };
As a result, flash_init()/flash_get_size() will eventually fail. With this patch applied, relevant CONFIG values are modified.
NOTE: you will not have to modify SYS_TEXT_BASE any more once Yamada-san's patch[1] is merged.
[1] https://lists.denx.de/pipermail/u-boot/2019-June/374178.html
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/configs/qemu-arm.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/qemu-arm.h b/include/configs/qemu-arm.h index 65fdb1e92981..35e3c5ad7a8d 100644 --- a/include/configs/qemu-arm.h +++ b/include/configs/qemu-arm.h @@ -46,8 +46,13 @@ #define CONFIG_SYS_CBSIZE 512
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_FLASH_BASE 0x4000000 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#else #define CONFIG_SYS_FLASH_BASE 0x0 #define CONFIG_SYS_MAX_FLASH_BANKS 2 +#endif #define CONFIG_SYS_MAX_FLASH_SECT 256 /* Sector: 256K, Bank: 64M */
#endif /* __CONFIG_H */
Thanks a lot for solving this problem.
CONFIG_TFABOOT is in arch/arm/cpu/armv8/fsl-layerscape/Kconfig. If the configuration option is relevant for more systems, shouldn't it be moved to arch/arm/cpu/armv8/Kconfig (in a separate patch)? In that case we could also adapt the help text and add 'ARM trusted firmware' to make it easier to understand.
Tested-by: Heinrich Schuchardt xypron.glpk@gmx.de
Yeah, agree, but I was afraid that not all the arm platform will enable TF-A boot with this configuration. So it would be better to add one more new CONFIG:
config SUPPORT_TFABOOT bool
config ARCH_QEMU select SUPPORT_TFABOOT
config FSL_LAYERSCAPE select SUPPORT_TFABOOT
config TFABOOT depends on SUPPORT_TFABOOT
Thanks, -Takahiro Akashi
AKASHI-san,
On Thu, Jun 27, 2019 at 10:08 AM AKASHI Takahiro takahiro.akashi@linaro.org wrote:
No. My patch is unrelated.
You are talking about CONFIG_POSITION_INDEPENDENT, and you can enable it irrespective of my work.
Yamada-san,
On Thu, Jun 27, 2019 at 05:10:37PM +0900, Masahiro Yamada wrote:
AKASHI-san,
Yes, I confirmed this. I might have already enabled this config before I created/tested my patch. I will drop this reference from the commit message.
-- Best Regards Masahiro Yamada
On 6/27/19 10:40 AM, AKASHI Takahiro wrote:
Yamada-san,
AKASHI-san,
I have tested now with this patch and qemu_arm64_config and the following settingss:
CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_POSITION_INDEPENDENT=y CONFIG_TFABOOT=y
and U-Boot runs fine.
Unfortunately in my TF-A build PSCI reset does not work. Do you know how to enable that?
resetting ... INFO: PSCI Power Domain Map: INFO: Domain Node : Level 1, parent_node -1, State ON (0x0) INFO: Domain Node : Level 1, parent_node -1, State OFF (0x2) INFO: CPU Node : MPID 0x0, parent_node 0, State ON (0x0) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 0, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 0, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 0, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2) ERROR: QEMU System Reset: operation not handled. BACKTRACE: START: qemu_system_reset 0: EL3: 0xe0435dc 1: EL3: 0xe04082c 2: EL3: 0xe042e78 3: EL3: 0xe0429a8 4: EL3: 0xe04104c 5: EL3: 0xe044dfc BACKTRACE: END: qemu_system_reset QEMU: Terminated
Best regards
Heinrich
AKASHI Takahiro
Masahiro Yamada
