[U-Boot] [PATCH] net: Return -1 when ctrl+c is pressed
Current behavior is that if CTRL+C is pressed command returns 0 that was successful which is not correct behavior. The easiest test case is "tftpboot 80000 uImage && echo yes" and press CTRL+C. Then the second command is called which is incorrect.
Error log: zynq-uboot> tftpb 80000 uImage && echo yes Gem.e000b000:7 is connected to Gem.e000b000. Reconnecting to Gem.e000b000 Gem.e000b000 Waiting for PHY auto negotiation to complete....... done Using Gem.e000b000 device TFTP from server 192.168.0.102; our IP address is 192.168.0.101 Filename 'uImage'. Load address: 0x80000 Loading: ################ Abort yes zynq-uboot>
This patch adds -1 return value when CTRL+C is pressed.
Not sure if -1 is the right error code but I have parsed the code and it looks like that -1 is standard behavior for CTRL+C. But I am happy to change this behavior.
--- net/net.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/net/net.c b/net/net.c index 67e0ad297cf5..738a0db8c2ba 100644 --- a/net/net.c +++ b/net/net.c @@ -565,6 +565,7 @@ restart: /* include a debug print as well incase the debug messages are directed to stderr */ debug_cond(DEBUG_INT_STATE, "--- net_loop Abort!\n"); + ret = -1; goto done; }
}ret = -1; goto done;
Joe, Tom: Any update on this one?
Thanks, Michal
Hi Michal,
ret = -1;
Please replace this with -EINTR.
goto done; }
Slipped through... thanks for the reminder.
On 08/20/2015 06:51 PM, Joe Hershberger wrote:
Hi Michal,
ret = -1;
goto done; }
v2 sent.
Thanks, Michal
Joe, do you want to pick this up? Thanks!
Joe Hershberger
Michal Simek
Michal Simek
