[U-Boot] U-Boot DWC2 warning removal
Oleksandr, I made the following changes to remove some warnings from your DWC2 driver. I'm not sure they're correct; perhaps they expose some bugs...
diff --git a/drivers/usb/host/dwc_otg-hcd.c b/drivers/usb/host/dwc_otg-hcd.c index a964681..e3c26f3 100644 --- a/drivers/usb/host/dwc_otg-hcd.c +++ b/drivers/usb/host/dwc_otg-hcd.c @@ -249,7 +249,6 @@ static int dwc_otg_submit_rh_msg(struct usb_device *dev, unsigned long pipe, int stat = 0; __u16 bmRType_bReq; __u16 wValue;
- __u16 wIndex; __u16 wLength; unsigned char data[32]; hprt0_data_t hprt0 = {.d32 = 0 };
@@ -261,7 +260,6 @@ static int dwc_otg_submit_rh_msg(struct usb_device *dev, unsigned long pipe,
bmRType_bReq = cmd->requesttype | (cmd->request << 8); wValue = cpu_to_le16 (cmd->value);
wIndex = cpu_to_le16 (cmd->index); wLength = cpu_to_le16 (cmd->length);
switch (bmRType_bReq) {
Perhaps wIndex should be used?
@@ -598,7 +596,6 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, hctsiz_data_t hctsiz; dwc_otg_host_if_t *host_if = g_core_if.host_if; dwc_otg_hc_regs_t *hc_regs = host_if->hc_regs[CHANNEL];
- hcint_data_t hcint; hcint_data_t hcint_new; /* For CONTROL endpoint pid should start with DATA1 */ int status_direction;
@@ -632,9 +629,6 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, hcchar.d32 = dwc_read_reg32(&hc_regs->hcchar); hcchar.b.multicnt = 1;
- /* Remember original int status */
- hcint.d32 = dwc_read_reg32(&hc_regs->hcint);
Does this read have a side-effect; should I keep the call to dwc_read_reg32(), but just remove the assignment?
The comment implies this value is saved so that it can be restored later. However, I don't see anywhere that restores it; does that code need to be added?
- /* Set host channel enable after all other setup is complete. */ hcchar.b.chen = 1; hcchar.b.chdis = 0;
@@ -677,8 +671,6 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, hcchar.d32 = dwc_read_reg32(&hc_regs->hcchar); hcchar.b.multicnt = 1;
@@ -731,8 +723,6 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, hcchar.d32 = dwc_read_reg32(&hc_regs->hcchar); hcchar.b.multicnt = 1;
Stephen Warren
