[U-Boot] [PATCH] cmd: fastboot: Kconfig: solve config issue
When FASTBOOT is activated, only one the supported device is supported in code at the same time - CONFIG_FASTBOOT_FLASH_MMC_DEV - CONFIG_FASTBOOT_FLASH_NAND_DEV
But Today the choice is not exclusive in Kconfig and that cause Kconfig issue when : - CONFIG_FASTBOOT, CONFIG_MMC, CONFIG_NAND are activated - CONFIG_FASTBOOT_FLASH_MMC_DEV = 0 - CONFIG_FASTBOOT_FLASH_NAND_DEV is not activated
The patch add a choice in Kconfig to select the FLASH provider - CONFIG_FASTBOOT_FLASH_MMC - CONFIG_FASTBOOT_FLASH_NAND
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
I execute buildman execute on board with CONFIG_FASTBOOT on label v2018.01-rc1 => no new error
board list = A13-OLinuXino A20-OLinuXino-Lime2 A20-OLinuXino-Lime2-eMMC am335x_boneblack am335x_boneblack_vboot am335x_evm am335x_evm_norboot am335x_evm_nor am335x_evm_spiboot am335x_evm_usbspl am57xx_evm am57xx_evm_nodt am57xx_hs_evm bcm23550_w1d bcm28155_ap birdland_bav335a birdland_bav335b cgtqmx6eval CHIP CHIP_pro chromebit_mickey chromebook_jerry chromebook_minnie Cubietruck dra7xx_evm dra7xx_hs_evm evb-rk3036 evb-rk3229 evb-rk3288 evb-rk3328 evb-rv1108 fennec-rk3288 firefly-rk3288 kc1 kylin-rk3036 miqi-rk3288 mx6qsabrelite Nintendo_NES_Classic_Edition nitrogen6dl2g nitrogen6dl nitrogen6q2g nitrogen6q nitrogen6s1g nitrogen6s omap3_beagle omap3_logic parrot_r16 phycore-rk3288 popmetal-rk3288 rock2 Sinlinx_SinA33 sniper stih410-b2260 stm32mp15_basic stm32mp15_fpga_basic stm32mp15_fpga_trusted stm32mp15_trusted tinker-rk3288 xilinx_zynqmp_ep xilinx_zynqmp_zc1751_xm015_dc1 xilinx_zynqmp_zc1751_xm016_dc2 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB
the modified configuration seems OK : $> tools/buildman/buildman -sdeSK
A13-OLinuXino A20-OLinuXino-Lime2 A20-OLinuXino-Lime2-eMMC Cubietruck Sinlinx_SinA33 am57xx_evm am57xx_hs_evm chromebit_mickey chromebook_jerry chromebook_minnie dra7xx_evm dra7xx_hs_evm evb-rk3036 evb-rk3229 evb-rk3288 fennec-rk3288 firefly-rk3288 kc1 kylin-rk3036 miqi-rk3288 parrot_r16 phycore-rk3288 popmetal-rk3288 rock2 sniper tinker-rk3288 xilinx_zynqmp_ep xilinx_zynqmp_zc1751_xm015_dc1 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB : + u-boot.cfg: CONFIG_FASTBOOT_FLASH_MMC=1 + u-boot-spl.cfg: CONFIG_FASTBOOT_FLASH_MMC=1 + all: CONFIG_FASTBOOT_FLASH_MMC=1 CHIP_pro xilinx_zynqmp_zc1751_xm016_dc2 : + u-boot.cfg: CONFIG_FASTBOOT_FLASH_NAND=1 + u-boot-spl.cfg: CONFIG_FASTBOOT_FLASH_NAND=1 + all: CONFIG_FASTBOOT_FLASH_NAND=1 bcm23550_w1d bcm28155_ap evb-rk3328 evb-rv1108 stih410-b2260 : + u-boot.cfg: CONFIG_FASTBOOT_FLASH_MMC=1 + all: CONFIG_FASTBOOT_FLASH_MMC=1
and I test on my custom board (with MMC + NAND + FASTBOOT) the .config is now OK, MMC is selected by default and NAND_DEV is not requested
cmd/fastboot/Kconfig | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
diff --git a/cmd/fastboot/Kconfig b/cmd/fastboot/Kconfig index 4ce7a77..aaf3d78 100644 --- a/cmd/fastboot/Kconfig +++ b/cmd/fastboot/Kconfig @@ -71,9 +71,23 @@ config FASTBOOT_FLASH the downloaded image to a non-volatile storage device. Define this to enable the "fastboot flash" command.
+choice + prompt "Flash provider for FASTBOOT" + depends on FASTBOOT_FLASH + +config FASTBOOT_FLASH_MMC + bool "FASTBOOT on MMC" + depends on MMC + +config FASTBOOT_FLASH_NAND + bool "FASTBOOT on NAND" + depends on NAND + +endchoice + config FASTBOOT_FLASH_MMC_DEV int "Define FASTBOOT MMC FLASH default device" - depends on FASTBOOT_FLASH && MMC + depends on FASTBOOT_FLASH_MMC default 0 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA = -1 default 1 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA != -1 help @@ -83,7 +97,7 @@ config FASTBOOT_FLASH_MMC_DEV
config FASTBOOT_FLASH_NAND_DEV int "Define FASTBOOT NAND FLASH default device" - depends on FASTBOOT_FLASH && NAND + depends on FASTBOOT_FLASH_NAND depends on CMD_MTDPARTS default 0 if ARCH_SUNXI && NAND_SUNXI help
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Maxime
Maxime Ripard
Patrick Delaunay
