Re: [PATCH 1/1] riscv: support building double-float modules
From: Heinrich Schuchardt heinrich.schuchardt@canonical.com Sent: Saturday, October 08, 2022 5:18 PM To: Rick Jian-Zhi Chen(陳建志) rick@andestech.com; Leo Yu-Chi Liang(梁育齊) ycliang@andestech.com Cc: Tom Rini trini@konsulko.com; u-boot@lists.denx.de; Heinrich Schuchardt heinrich.schuchardt@canonical.com Subject: [PATCH 1/1] riscv: support building double-float modules
The riscv32 toolchain for GCC-12 provided by kernel.org contains libgcc.a compiled for double-float. To link to it we have to adjust how we build U-Boot.
As U-Boot actually does not use floating point at all this should not make a significant difference for the produced binaries.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com
arch/riscv/Kconfig | 14 ++++++++++++++ arch/riscv/Makefile | 17 ++++++++++++++--- 2 files changed, 28 insertions(+), 3 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 32a90b83b5..8add95c8ef 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -152,6 +152,20 @@ config RISCV_ISA_C when building U-Boot, which results in compressed instructions in the U-Boot binary.
+config RISCV_ISA_F
bool "Standard extension for Single-Precision Floating Point"
default y
Shall this default y need to depend on RV32 ?
Reviewed-by: Rick Chen rick@andestech.com
help
Adds "F" to the ISA string passed to the compiler.
+config RISCV_ISA_D
bool "Standard extension forr Double-Precision Floating Point"
depends on RISCV_ISA_F
default y
help
Adds "D" to the ISA string passed to the compiler and changes the
riscv32 ABI from ilp32 to ipl32d.
config RISCV_ISA_A def_bool y
diff --git a/arch/riscv/Makefile b/arch/riscv/Makefile index 53d1194ffb..d1b6e86dd8 100644 --- a/arch/riscv/Makefile +++ b/arch/riscv/Makefile @@ -5,15 +5,24 @@
ifeq ($(CONFIG_ARCH_RV64I),y) ARCH_BASE = rv64im
ABI = lp64
ABI_BASE = lp64
endif ifeq ($(CONFIG_ARCH_RV32I),y) ARCH_BASE = rv32im
ABI = ilp32
ABI_BASE = ilp32
endif ifeq ($(CONFIG_RISCV_ISA_A),y) ARCH_A = a endif +ifeq ($(CONFIG_RISCV_ISA_F),y)
ARCH_F = f
+endif +ifeq ($(CONFIG_RISCV_ISA_D),y)
ARCH_D = d
+ifeq ($(CONFIG_ARCH_RV32I),y)
ABI_D = d
+endif +endif ifeq ($(CONFIG_RISCV_ISA_C),y) ARCH_C = c endif @@ -24,7 +33,9 @@ ifeq ($(CONFIG_CMODEL_MEDANY),y) CMODEL = medany endif
-RISCV_MARCH = $(ARCH_BASE)$(ARCH_A)$(ARCH_C)
+RISCV_MARCH = $(ARCH_BASE)$(ARCH_A)$(ARCH_F)$(ARCH_D)$(ARCH_C) +ABI = $(ABI_BASE)$(ABI_D)
# Newer binutils versions default to ISA spec version 20191213 which moves some # instructions from the I extension to the Zicsr and Zifencei extensions.
+config RISCV_ISA_F
default y
All RV64 boards that we currently support have the F and D extension and these extensions are in RV64GC. There is no need to disable the F option on RV64.
If you wanted to catch if anybody is using floating point calculation in U-Boot, we could let it depend on RV32 until we hit another libgcc pitfall.
Best regards
Heinrich
help
+config RISCV_ISA_D
default y
help
- config RISCV_ISA_A def_bool y
ABI = lp64
endif ifeq ($(CONFIG_ARCH_RV32I),y) ARCH_BASE = rv32imABI_BASE = lp64
ABI = ilp32
endif ifeq ($(CONFIG_RISCV_ISA_A),y) ARCH_A = a endifABI_BASE = ilp32
ARCH_F = f
ARCH_D = d
ABI_D = d
HI Heinrich
+config RISCV_ISA_F
default y
OK, let's keep no change here. Thanks for your explanation.
Thanks, Rick
Best regards
Heinrich
help
+config RISCV_ISA_D
default y
help
ABI = lp64
ABI = ilp32
ARCH_F = f
ARCH_D = d
ABI_D = d
Rick Chen
